Other Parts Discussed in Thread: SPRC223
I am looking for initialization and McASP setup for stereo in and out. More specifically example code for this.
THank you,
Frank
THank you,
Frank
Hi Frank,
For example codes, you can refer to the following links:
http://focus.ti.com/docs/toolsw/folders/print/tmdspdk6727.html
and
http://www.lyrtech.com/Products/Professional_audio_development_kit.php
Ankit Agrawal
Hello Ankit,
Thank you for responding but this is not what I need. The links you provided are for DDSP development kits and I need example software to initialize the 6727 and set up the McASP to get audio in and out of the 6727. I am not seeing example code for this in the links you sent.
Thank you,
Frank
Hi Frank,
You can download a .zip file from the following link containing sample codes for McASP. You can check code for initialization of C6727 and setup the McASP.
http://focus.ti.com/docs/toolsw/folders/print/sprc223.html
And the second link that I gave was
If you do not get sample codes for the same, you can contact Lyrtech for the same.
Ankit Agrawal
