Part Number: AM5729
Dear Champs,
My customer successfully to build IPC example(ex02_messageq) and run it well.
But, they failed to build after adding below in the DSP cfg file.
(ipc_3_50_04_07\examples\DRA7XX_linux_elf\ex02_messageq\dsp1\Dsp1.cfg)
/* Override the default resource table with my own */
var Resource = xdc.useModule('ti.ipc.remoteproc.Resource');
Resource.customTable = true;
They failed build as below when 'make ti-ipc-linux-examples' was executed.
# Making bin/debug/server_dsp2.xe66 ...
/home/yjhong/Kisan/S2/TI_AM57x/sdk/ProcSDK_rtos_06.01.00.08/ti-cgt-c6000_8.3.2/bin/cl6x -z -w -q -u _c_int00 -c -m bin/debug/obj/server_dsp2.xe66.map -o bin/debug/server_dsp2.xe66 bin/debug/obj/MainDsp2.oe66 bin/debug/obj/Server.oe66 \
bin/debug/configuro/linker.cmd -l /home/yjhong/Kisan/S2/TI_AM57x/sdk/ProcSDK_rtos_06.01.00.08/ti-cgt-c6000_8.3.2/lib/libc.a
<Linking>
undefined first referenced
symbol in file
ti_ipc_remoteproc_ResourceTable /home/yjhong/Kisan/S2/TI_AM57x/sdk/ProcSDK_rtos_06.01.00.08/ipc_3_50_04_07/examples/DRA7XX_linux_elf/ex02_messageq/dsp2/bin/debug/configuro/package/cfg/Dsp2_pe66.oe66
error: unresolved symbols remain
error: errors encountered during linking; "bin/debug/server_dsp2.xe66" not
built
>> Compilation failure
makefile:66: recipe for target 'bin/debug/server_dsp2.xe66' failed
make[4]: *** [bin/debug/server_dsp2.xe66] Error 1
My customer checked below documents, but could not find what is wrong and what procedure should be added.
Could you please let me know how they can resolve this compile error?
AM57x Processor SDK Linux®: Customizing Multicore Applications to Run on New Platforms
Thanks and Best Regards,
SI.
