Other Parts Discussed in Thread: AM1808
We are about to start desing an L138/AM1808 design, Where we could find recomended bga layout ( pad sizes, solder and paste masks )
Best Regards
Best Regards
Unfortunately no. We only provide the Allegro 15.0 version of the footprint.
Jeff
We recommend using the IPC specifications found here:
For the ZWT 0.8mm package, the 0.4mm is the recommended pad size in a non-solder mask defined style (which is recommended).
The solder mask must have some clearance, usually 4 mils on all sides is sufficient, but this can be determined by the designer.
The paste mask is normally the same size as the pad, since you want the paste to cover the whole pad.
Jeff
