TDA2PXEVM: Not getting any graphics display for SgxFrmcpy
Part Number: TDA2PXEVM
Hello everyone,
I am trying to run a custom algorithm which reads a video file and try to get a graphic display using SgxFrmcpy,
 even though there was no run time error i am not getting anything on the display. i attached the usecase and run-time log.
Following is my usecase:
NullSource (A15) -> Decode -> VPE -> Alg_openglFrameCopy (A15) -> SgxFrmcpy (A15)
// display on m4
SgxFrmcpy -> Display_M4 (IPU1_0)
// Graphics overlay display
GrpxSrc -> Display_Grpx
Following is the run-time log::
[HOST] [HOST  ]     60.515250 s:  IPC_OUT_0   : Create in progress !!!
 [HOST] [HOST  ]     60.515311 s:  IPC_OUT_0   : Create Done !!!
 [HOST] [IPU2  ]     60.515463 s:  IPC_IN_0   : Create in progress !!!
 [HOST] [IPU2  ]     60.516653 s:  IPC_IN_0   : Create Done !!!
 [HOST] [IPU2  ]     60.517049 s:  DECODE: Create in progress ... !!!
 [HOST] [IPU2  ]     60.726865 s:  DECODE: Creating CH0 of 1280 x 720 [1] [0],t
 [HOST] [IPU2  ]     60.727749 s:  DECODE: All CH Create ... DONE !!!
 [HOST] [IPU2  ]     60.729793 s:  DECODE: Create ... DONE !!!
 [HOST] [IPU2  ]     60.730220 s:  VPE: Create in progress !!!
 [HOST] algId = 16  ALGORITHM_LINK_ALG_MAXNUM = 17loaded module : gbm_pvr.so
found valid GBM backend : gbm_pvr.so
 [HOST] [HOST  ]     60.865033 s:  IPC_IN_0   : Create in progress !!!
 [HOST] [HOST  ]     60.865491 s:  IPC_IN_0   : Create Done !!!
 [HOST] [HOST  ]     60.865582 s:  ALGORITHM: Create in progress (algId = 16) !!
 [HOST] [HOST  ]     60.867717 s:  ALGORITHM: Create Done (algId = 16) !!!
 [HOST] [HOST  ]     60.867778 s:  SGXFRMCPY: Create in progress for resolution!
 [HOST] [HOST  ]     60.871439 s:  SYSTEM_PVRSCOPE: FIFO /opt/vision_sdk/gpufif
 [HOST] [IPU2  ]     60.863600 s:  VPE: Loading Down-scaling Co-effs
 [HOST] [IPU2  ]     60.863844 s:  VPE: Co-effs Loading ... DONE !!!
 [HOST] [IPU2  ]     60.864057 s:  VPE: Create Done !!!
 [HOST] [IPU2  ]     60.864454 s:  IPC_OUT_0   : Create in progress !!!
 [HOST] [IPU2  ]     60.864789 s:  IPC_OUT_0   : Create Done !!!
 [HOST] [HOST  ]     60.885194 s:  EGL: version 1.4
 [HOST] [HOST  ]     60.893552 s:  EGL: GL Version = (null)
 [HOST] [HOST  ]     60.893552 s:  EGL: GL Vendor = (null)
 [HOST] [HOST  ]     60.893582 s:  EGL: GL Renderer = (null)
 [HOST] [HOST  ]     60.893582 s:  EGL: GL Extensions = (null)
 [HOST] [HOST  ]     60.931525 s:  SGXFRMCPY: Create Done for resolution: 1920x!
 [HOST] [HOST  ]     60.931617 s:  IPC_OUT_1   : Create in progress !!!
 [HOST] [HOST  ]     60.931647 s:  IPC_OUT_1   : Create Done !!!
 [HOST] [IPU2  ]     60.931800 s:  IPC_IN_1   : Create in progress !!!
 [HOST] [IPU2  ]     60.932959 s:  IPC_IN_1   : Create Done !!!
 [HOST] [IPU2  ]     60.933416 s:  DISPLAY: Create in progress !!!
 [HOST] [IPU2  ]     60.933904 s:  DISPLAY: Create Done !!!
 [HOST] [IPU2  ]     60.934301 s:  GRPXSRC: Create in progress !!!
 [HOST] [IPU2  ]     62.352254 s:  GRPXSRC: Create Done !!!
 [HOST] [IPU2  ]     62.352803 s:  DISPLAY: Create in progress !!!
 [HOST] [IPU2  ]     62.353504 s:  DISPLAY: Create Done !!!
 [HOST] [IPU2  ]     62.355456 s:  *** UTILS: CPU KHz = 20000 Khz ***
 [HOST] [DSP1  ]     62.454187 s:  SYSTEM: SW Message Box Msg Pool, Free Msg Co
 [HOST] [DSP1  ]     62.454248 s:  SYSTEM: Heap = LOCAL_L2             @ 0x0080)
 [HOST] [DSP1  ]     62.454279 s:  SYSTEM: Heap = LOCAL_DDR            @ 0x0000)
 [HOST] [DSP2  ]     62.454462 s:  SYSTEM: SW Message Box Msg Pool, Free Msg Co
 [HOST] [DSP2  ]     62.454523 s:  SYSTEM: Heap = LOCAL_L2             @ 0x0080)
 [HOST] [DSP2  ]     62.454553 s:  SYSTEM: Heap = LOCAL_DDR            @ 0x0000)
 [HOST] [EVE1  ]     62.455041 s:  SYSTEM: SW Message Box Msg Pool, Free Msg Co
 [HOST] [EVE1  ]     62.455346 s:  SYSTEM: Heap = LOCAL_L2             @ 0x4002)
 [HOST] [EVE1  ]     62.455865 s:  SYSTEM: Heap = LOCAL_DDR            @ 0x0000)
 [HOST] [EVE2  ]     62.456871 s:  SYSTEM: SW Message Box Msg Pool, Free Msg Co
 [HOST] [EVE2  ]     62.457146 s:  SYSTEM: Heap = LOCAL_L2             @ 0x4002)
 [HOST] [HOST  ]     62.466449 s:  SGXFRMCPY: Start in progress !!!
 [HOST] [HOST  ]     62.466479 s:  SGXFRMCPY: Start Done !!!
 [HOST] [EVE2  ]     62.457695 s:  SYSTEM: Heap = LOCAL_DDR            @ 0x0000)
 [HOST] [IPU2  ]     62.458488 s:  SYSTEM: SW Message Box Msg Pool, Free Msg Co
 [HOST] [IPU2  ]     62.458640 s:  SYSTEM: Heap = LOCAL_DDR            @ 0x0000)
 [HOST] [IPU2  ]     62.458793 s:  SYSTEM: Heap = SR_OCMC              @ 0x0000)
 [HOST] [IPU2  ]     62.458945 s:  SYSTEM: Heap = SR_DDR_CACHED        @ 0x8420)
 [HOST] [IPU2  ]     62.459128 s:  SYSTEM: Heap = SR_DDR_NON_CACHED    @ 0xa010)
 [HOST] [IPU2  ]     62.459525 s:  DISPLAY: Start in progress !!!
 [HOST] [IPU2  ]     62.459586 s:  DISPLAY: Start Done !!!
 [HOST] [IPU2  ]     62.465900 s:  DISPLAY: Start in progress !!!
 [HOST] [IPU2  ]     62.465991 s:  DISPLAY: Start Done !!!
 [HOST] [HOST  ]     62.476331 s:  IPC_OUT_1   : Stop Done !!!
 [HOST] [HOST  ]     62.476361 s:  SGXFRMCPY: Stop in progress !!!
 [HOST] [HOST  ]     62.476392 s:  SGXFRMCPY: Stop Done !!!
 [HOST] [HOST  ]     62.476422 s:  ALGORITHM: Stop in progress (algId = 16) !!!
 [HOST] [HOST  ]     62.476453 s:  ALGORITHM: Stop Done (algId = 16) !!!
 [HOST] [HOST  ]     62.476483 s:  IPC_IN_0   : Stop Done !!!
 [HOST] [HOST  ]     62.478008 s:  IPC_OUT_0   : Stop Done !!!
 [HOST] [IPU2  ]     62.469285 s:  DISPLAY: Stop in progress !!!
 [HOST] [IPU2  ]     62.469438 s:  DISPLAY: Stop Done !!!
 [HOST] [IPU2  ]     62.475690 s:  DISPLAY: Stop in progress !!!
 [HOST] [IPU2  ]     62.475812 s:  DISPLAY: Stop Done !!!
 [HOST] [IPU2  ]     62.476117 s:  IPC_IN_1   : Stop Done !!!
 [HOST] [IPU2  ]     62.476605 s:  IPC_OUT_0   : Stop Done !!!
 [HOST] [IPU2  ]     62.476910 s:  VPE: Stop in progress !!!
 [HOST] [IPU2  ]     62.477002 s:  VPE: Stop Done !!!
 [HOST] [IPU2  ]     62.477307 s:  DECODE: Stop in progress !!!
 [HOST] [IPU2  ]     62.477459 s:  DECODE: Stop Done !!!
 [HOST] [IPU2  ]     62.477795 s:  IPC_IN_0   : Stop Done !!!
 [HOST] [IPU2  ]     62.478161 s:  DISPLAY: Delete in progress !!!
 [HOST] [IPU2  ]     62.478313 s:  DISPLAY: Delete Done !!!
 [HOST] [HOST  ]     62.487860 s:  IPC_OUT_1   : Delete in progress !!!
 [HOST] [HOST  ]     62.487891 s:  IPC_OUT_1   : Delete Done !!!
 [HOST] [HOST  ]     62.487921 s:  SGXFRMCPY: Delete in progress !!!
 [HOST] [IPU2  ]     62.485420 s:  GRPXSRC: Delete in progress !!!
 [HOST] [IPU2  ]     62.486122 s:  GRPXSRC: Delete Done !!!
 [HOST] [IPU2  ]     62.486579 s:  DISPLAY: Delete in progress !!!
 [HOST] [IPU2  ]     62.486732 s:  DISPLAY: Delete Done !!!
 [HOST] [IPU2  ]     62.487037 s:  IPC_IN_1   : Delete in progress !!!
 [HOST] [IPU2  ]     62.487555 s:  IPC_IN_1   : Delete Done !!!
 [HOST] [IPU2  ]     62.587994 s:  IPC_OUT_0   : Delete in progress !!!
 [HOST] [IPU2  ]     62.588116 s:  IPC_OUT_0   : Delete Done !!!
 [HOST] [IPU2  ]     62.588452 s:  VPE: Delete in progress !!!
 [HOST] [IPU2  ]     62.590343 s:  VPE: Delete Done !!!
 [HOST] [IPU2  ]     62.590800 s:  DECODE: Stop in progress !!!
 [HOST] [IPU2  ]     62.590922 s:  DECODE: Stop Done !!!
 [HOST] [IPU2  ]     62.590983 s:  DECODE: Delete in progress !!!
 [HOST] [IPU2  ]     62.594278 s:  DECODE: Delete Done !!!
 [HOST] [IPU2  ]     62.594735 s:  IPC_IN_0   : Delete in progress !!!
 [HOST] [IPU2  ]     62.595193 s:  IPC_IN_0   : Delete Done !!!
 [HOST] [HOST  ]     62.586561 s:  SGXFRMCPY: Delete Done !!!
 [HOST] [HOST  ]     62.586622 s:  ALGORITHM: Delete in progress (algId = 16) !!
 [HOST] [HOST  ]     62.587811 s:  ALGORITHM: Delete Done (algId = 16) !!!
 [HOST] [HOST  ]     62.587872 s:  IPC_IN_0   : Delete in progress !!!
 [HOST] [HOST  ]     62.587872 s:  IPC_IN_0   : Delete Done !!!
 [HOST] [HOST  ]     62.595559 s:  IPC_OUT_0   : Delete in progress !!!
 [HOST] [HOST  ]     62.595559 s:  IPC_OUT_0   : Delete Done !!!
 [HOST] [HOST  ]     62.600103 s:
Praveen
