Other Parts Discussed in Thread: INA226
This problem has been stated in various threads, however I would like to extend the question a bit.
I am using Vision SDK 3.03 / SYS BIOS to run TIDL_OD example, I have done a few modifications to it (like sending the frame via Pcie), but the essentials are the same.
My goal is to make sure that input FPS (belonging to the mp4 file that is converted to h264 and bin files) is the same as the input/output FPS of ALG_ObjectDraw.
The reason I want to do this is to make sure I know which frame is being processed in the mp4, by just looking at the logs.
However, the problem is input FPS is never the same as output FPS of Alg_ObjectDraw.
The problems are;
1) In 20+ fps files, VPE drops FPS significantly. 30fps drops to 20.1 fps.
In order to solve this problem, I simply inputted 20fps file, the issue is resolved.
But I would still like to know how to solve VPE FPS drop when the input is 30fps.
[IPU1-0] 41.231501 s: [ VPE ] LATENCY,
[IPU1-0] 41.231531 s: ********************
[IPU1-0] 41.231592 s: Local Link Latency : Avg = 1300 us, Min = 1281 us, Max =
[IPU1-0] 41.231714 s: Source to Link Latency : Avg = 254009 us, Min = 201092 us, Max =
[IPU1-0] 41.231836 s:
[IPU1-0] 41.231897 s: CPU [ IPU1-0], LinkID [ 25], Link Statistics not available !
[IPU1-0] 41.232080 s:
[IPU1-0] 41.232111 s: ### CPU [IPU1-0], LinkID [ 0],
[IPU1-0] 41.232172 s:
[IPU1-0] 41.232233 s: [ IPC_OUT_0 ] Link Statistics,
[IPU1-0] 41.232294 s: ******************************
[IPU1-0] 41.232355 s:
[IPU1-0] 41.232416 s: Elapsed time = 7569 msec
[IPU1-0] 41.232477 s:
[IPU1-0] 41.232538 s: New data Recv = 20.8 fps
[IPU1-0] 41.232599 s: Release data Recv = 20.8 fps
[IPU1-0] 41.232690 s: Driver/Notify Cb = 120.9 fps
[IPU1-0] 41.232751 s:
[IPU1-0] 41.232782 s: Input Statistics,
[IPU1-0] 41.232843 s:
[IPU1-0] 41.232873 s: CH | In Recv | In Drop | In User Drop | In Process
[IPU1-0] 41.232965 s: | FPS | FPS | FPS | FPS
[IPU1-0] 41.233026 s: --------------------------------------------------
[IPU1-0] 41.233117 s: 0 | 20. 8 0. 0 0. 0 20. 8
[IPU1-0] 41.233239 s:
[IPU1-0] 41.233270 s: Output Statistics,
[IPU1-0] 41.233331 s:
[IPU1-0] 41.233575 s: CH | Out | Out | Out Drop | Out User Drop
[IPU1-0] 41.233666 s: | ID | FPS | FPS | FPS
[IPU1-0] 41.233727 s: ---------------------------------------------
[IPU1-0] 41.233819 s: 0 | 0 20. 8 0. 0 0. 0
Additionally, there is the mention of making VPE output buffer bigger in order to overcome frame drop. Can somebody please tell me how it is achieved in the code?
I increased the one for pOdDrawPrm, but can't seem to find one for VPE.
pOdDrawPrm->numOutBuffers = 7;
2) I would like to know what all the fractional FPS differences mean. Why do I get 20.8 FPS in the output of VPE when the input is exactly 20.0 FPS?
Similarly, why Alg_Object_Draw input is 20.5 fps when its input, Sync link, has 19.35 fps output.
Why there is this discrepency?
3) Third problem is with Sync link, it always drops some fps, maybe indirectly causing fps drop at the input of Alg_ObjectDraw.
In order to avoid this problem, I played with SYNC_THRESHOLD and SYNC_DELTA, making them 1000 and 100, respectively. But no help.
[IPU1-0] 47.798267 s: [ SYNC_0 ] Link Statistics,
[IPU1-0] 47.798328 s: ******************************
[IPU1-0] 47.798389 s:
[IPU1-0] 47.798420 s: Elapsed time = 14418 msec
[IPU1-0] 47.798511 s:
[IPU1-0] 47.798542 s: New data Recv = 68.80 fps
[IPU1-0] 47.798633 s: Get Full Buf Cb = 19.35 fps
[IPU1-0] 47.798725 s: Put Empty Buf Cb = 19.35 fps
[IPU1-0] 47.798816 s: Driver/Notify Cb = 30.23 fps
[IPU1-0] 47.798877 s:
[IPU1-0] 47.798908 s: Input Statistics,
[IPU1-0] 47.798969 s:
[IPU1-0] 47.798999 s: CH | In Recv | In Drop | In User Drop | In Process
[IPU1-0] 47.799091 s: | FPS | FPS | FPS | FPS
[IPU1-0] 47.799182 s: --------------------------------------------------
[IPU1-0] 47.799243 s: 0 | 19.62 0. 0 0. 0 19.35
[IPU1-0] 47.799365 s: 1 | 19.35 0. 0 0. 0 19.35
[IPU1-0] 47.799518 s:
[IPU1-0] 47.799762 s: Output Statistics,
[IPU1-0] 47.799823 s:
[IPU1-0] 47.799853 s: CH | Out | Out | Out Drop | Out User Drop
[IPU1-0] 47.799945 s: | ID | FPS | FPS | FPS
[IPU1-0] 47.800006 s: ---------------------------------------------
[IPU1-0] 47.800097 s: 0 | 0 19.35 0. 0 0. 0
[IPU1-0] 47.800189 s:
[IPU1-0] 47.800250 s: [ SYNC_0 ] LATENCY,
[IPU1-0] 47.800280 s: ********************
[IPU1-0] 47.800341 s: Local Link Latency : Avg = 111607 us, Min = 30 us, Max =
[IPU1-0] 47.800463 s: Source to Link Latency : Avg = 477414 us, Min = 376594 us, Max =
[IPU1-0] 47.800616 s:
[IPU1-0] 47.800768 s:
4) As a final point, I would like to know how to make sure TIDL process is not dropping frames.
[IPU1-0] 46.781888 s: CH | In Recv | In Drop | In User Drop | In Process
[IPU1-0] 46.781980 s: | FPS | FPS | FPS | FPS
[IPU1-0] 46.782041 s: --------------------------------------------------
[IPU1-0] 46.782132 s: 0 | 5. 3 0. 0 0. 0 4.95
[IPU1-0] 46.782254 s:
[IPU1-0] 46.782285 s: Output Statistics,
[IPU1-0] 46.782346 s:
[IPU1-0] 46.782376 s: CH | Out | Out | Out Drop | Out User Drop
[IPU1-0] 46.782468 s: | ID | FPS | FPS | FPS
[IPU1-0] 46.782559 s: ---------------------------------------------
[IPU1-0] 46.782651 s: 0 | 0 4.95 0. 0 0. 0
All in all, I would like to achieve Input FPS = Alg_ObjectDraw FPS, Is it possible ?
Thank you very much for your help.
NOTE: Full log given below:
Log is given below for a 20fps input file:
[IPU1-1] 33.322912 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1023
[IPU1-1] 33.323064 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 6)
[IPU1-0] 41.094430 s:
[IPU1-0] 41.094491 s: CPU [IPU1-0 ] Statistics,
[IPU1-0] 41.094552 s: *************************
[IPU1-0] 41.094613 s:
[IPU1-0] 41.094674 s: LOAD: CPU: 17.6% HWI: 2.1%, SWI:0.9%, Low Power: 78.2%
[IPU1-0] 41.094827 s:
[IPU1-0] 41.094857 s: LOAD: TSK: DUP0 : 0.1%
[IPU1-0] 41.094949 s: LOAD: TSK: DUP1 : 0.1%
[IPU1-0] 41.095040 s: LOAD: TSK: IPC_IN_0 : 0.2%
[IPU1-0] 41.095162 s: LOAD: TSK: IPC_OUT_0 : 0.4%
[IPU1-0] 41.095406 s: LOAD: TSK: MERGE0 : 0.1%
[IPU1-0] 41.095528 s: LOAD: TSK: NULL_SRC0 : 1.8%
[IPU1-0] 41.095620 s: LOAD: TSK: SYNC0 : 0.5%
[IPU1-0] 41.095711 s: LOAD: TSK: DISPLAY0 : 0.3%
[IPU1-0] 41.095803 s: LOAD: TSK: DEC0 : 0.4%
[IPU1-0] 41.095894 s: LOAD: TSK: VPE0 : 0.7%
[IPU1-0] 41.095986 s: LOAD: TSK: VPE1 : 0.5%
[IPU1-0] 41.096077 s: LOAD: TSK: ALGORITHM0 : 2.9%
[IPU1-0] 41.096199 s: LOAD: TSK: GrpxSrc0 : 0.1%
[IPU1-0] 41.096291 s: LOAD: TSK: STAT_COLL : 3.6%
[IPU1-0] 41.096413 s: LOAD: TSK: DEC_PROCESS_TSK_0 : 0.9%
[IPU1-0] 41.096504 s: LOAD: TSK: MISC : 2.0%
[IPU1-0] 41.096596 s:
[IPU1-0] 41.096626 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1022
[IPU1-0] 41.096718 s:
[IPU1-0] 41.096748 s: SYSTEM: Sempahores Objects, 123 of 1024 free
[IPU1-0] 41.096840 s: SYSTEM: Task Objects , 16 of 100 free
[IPU1-0] 41.096931 s: SYSTEM: Clock Objects , 93 of 100 free
[IPU1-0] 41.097023 s: SYSTEM: Hwi Objects , 89 of 100 free
[IPU1-0] 41.097114 s:
[IPU1-0] 41.097145 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 2)
[IPU1-0] 41.097328 s: SYSTEM: Heap = SR_OCMC @ 0x00000000, Total size = 0)
[IPU1-0] 41.097511 s: SYSTEM: Heap = SR_DDR_CACHED @ 0x8d903000, Total size = 7)
[IPU1-0] 41.097694 s: SYSTEM: Heap = SR_DDR_NON_CACHED @ 0xbf000000, Total size = 1)
[IPU1-0] 41.097846 s:
[IPU1-0] 41.097907 s:
[IPU1-0] 41.097938 s: CPU [IPU1-1 ] Statistics,
[IPU1-0] 41.097999 s: *************************
[IPU1-0] 41.098060 s:
[IPU1-0] 41.098090 s: LOAD: CPU: 1.2% HWI: 0.8%, SWI:0.3%, Low Power: 65.8%
[IPU1-0] 41.098243 s:
[IPU1-0] 41.098365 s: LOAD: TSK: MISC : 0.1%
[IPU1-0] 41.098670 s:
[IPU1-0] 41.098731 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1022
[IPU1-0] 41.098822 s:
[IPU1-0] 41.098853 s: SYSTEM: Sempahores Objects, 411 of 1024 free
[IPU1-0] 41.098944 s: SYSTEM: Task Objects , 38 of 100 free
[IPU1-0] 41.099036 s: SYSTEM: Clock Objects , 99 of 100 free
[IPU1-0] 41.099097 s: SYSTEM: Hwi Objects , 99 of 100 free
[IPU1-0] 41.099188 s:
[IPU1-0] 41.099249 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 6)
[IPU1-0] 41.099432 s:
[IPU1-0] 41.099493 s:
[IPU1-0] 41.099524 s: CPU [HOST ] Statistics,
[IPU1-0] 41.099585 s: *************************
[IPU1-0] 41.099646 s:
[IPU1-0] 41.099707 s: LOAD: CPU: 28.0% HWI: 0.1%, SWI:0.2%, Low Power: 70.9%
[IPU1-0] 41.099829 s:
[IPU1-0] 41.099951 s: LOAD: TSK: PCIeS0 : 6.7%
[IPU1-0] 41.100042 s: LOAD: TSK: MISC : 21.0%
[IPU1-0] 41.100103 s:
[IPU1-0] 41.100164 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1022
[IPU1-0] 41.100256 s:
[IPU1-0] 41.100286 s: SYSTEM: Sempahores Objects, 376 of 1024 free
[IPU1-0] 41.100378 s: SYSTEM: Task Objects , 35 of 100 free
[IPU1-0] 41.100500 s: SYSTEM: Clock Objects , 95 of 100 free
[IPU1-0] 41.100591 s: SYSTEM: Hwi Objects , 98 of 100 free
[IPU1-0] 41.100652 s:
[IPU1-0] 41.100713 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 6)
[IPU1-0] 41.100866 s:
[IPU1-0] 41.100896 s:
[IPU1-0] 41.100957 s: CPU [DSP1 ] Statistics,
[IPU1-0] 41.101018 s: *************************
[IPU1-0] 41.101079 s:
[IPU1-0] 41.101110 s: LOAD: CPU: 60.5% HWI: 0.4%, SWI:0.2%, Low Power: 39.0%
[IPU1-0] 41.101262 s:
[IPU1-0] 41.101293 s: LOAD: TSK: SYSTEM_TSK_MULTI_MBX: 59.7%
[IPU1-0] 41.101415 s: LOAD: TSK: MISC : 0.2%
[IPU1-0] 41.101506 s:
[IPU1-0] 41.101567 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1022
[IPU1-0] 41.101628 s:
[IPU1-0] 41.101689 s: SYSTEM: Sempahores Objects, 420 of 1024 free
[IPU1-0] 41.101781 s: SYSTEM: Task Objects , 91 of 100 free
[IPU1-0] 41.101842 s: SYSTEM: Clock Objects , 98 of 100 free
[IPU1-0] 41.101933 s: SYSTEM: Hwi Objects , 100 of 100 free
[IPU1-0] 41.102025 s:
[IPU1-0] 41.102055 s: SYSTEM: Heap = LOCAL_L2 @ 0x00800000, Total size = 2)
[IPU1-0] 41.102238 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 5)
[IPU1-0] 41.102513 s:
[IPU1-0] 41.102574 s:
[IPU1-0] 41.102604 s: CPU [DSP2 ] Statistics,
[IPU1-0] 41.102665 s: *************************
[IPU1-0] 41.102726 s:
[IPU1-0] 41.102757 s: LOAD: CPU: 0.3% HWI: 0.1%, SWI:0.0%, Low Power: 99.0%
[IPU1-0] 41.102909 s:
[IPU1-0] 41.102970 s: LOAD: TSK: MISC : 0.2%
[IPU1-0] 41.103062 s:
[IPU1-0] 41.103092 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1022
[IPU1-0] 41.103184 s:
[IPU1-0] 41.103214 s: SYSTEM: Sempahores Objects, 425 of 1024 free
[IPU1-0] 41.103306 s: SYSTEM: Task Objects , 91 of 100 free
[IPU1-0] 41.103611 s: SYSTEM: Clock Objects , 99 of 100 free
[IPU1-0] 41.103702 s: SYSTEM: Hwi Objects , 100 of 100 free
[IPU1-0] 41.103794 s:
[IPU1-0] 41.103824 s: SYSTEM: Heap = LOCAL_L2 @ 0x00800000, Total size = 2)
[IPU1-0] 41.104007 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 5)
[IPU1-0] 41.104160 s:
[IPU1-0] 41.104190 s:
[IPU1-0] 41.104221 s: CPU [EVE1 ] Statistics,
[IPU1-0] 41.104282 s: *************************
[IPU1-0] 41.104343 s:
[IPU1-0] 41.104434 s: LOAD: CPU: 91.1% HWI: 0.3%, SWI:0.2%, Low Power: 8.1%
[IPU1-0] 41.104587 s:
[IPU1-0] 41.104648 s: LOAD: TSK: SYSTEM_TSK_MULTI_MBX: 90.3%
[IPU1-0] 41.104739 s: LOAD: TSK: MISC : 0.3%
[IPU1-0] 41.104831 s:
[IPU1-0] 41.104861 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1022
[IPU1-0] 41.104953 s:
[IPU1-0] 41.104983 s: SYSTEM: Sempahores Objects, 425 of 1024 free
[IPU1-0] 41.105075 s: SYSTEM: Task Objects , 92 of 100 free
[IPU1-0] 41.105166 s: SYSTEM: Clock Objects , 98 of 100 free
[IPU1-0] 41.105258 s: SYSTEM: Hwi Objects , 99 of 100 free
[IPU1-0] 41.105319 s:
[IPU1-0] 41.105746 s: SYSTEM: Heap = LOCAL_L2 @ 0x40020000, Total size = 2)
[IPU1-0] 41.105929 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 2)
[IPU1-0] 41.106081 s:
[IPU1-0] 41.106112 s:
[IPU1-0] 41.106142 s: CPU [EVE2 ] Statistics,
[IPU1-0] 41.106203 s: *************************
[IPU1-0] 41.106264 s:
[IPU1-0] 41.106325 s: LOAD: CPU: 91.1% HWI: 0.3%, SWI:0.2%, Low Power: 8.1%
[IPU1-0] 41.106722 s:
[IPU1-0] 41.106783 s: LOAD: TSK: SYSTEM_TSK_MULTI_MBX: 90.3%
[IPU1-0] 41.106905 s: LOAD: TSK: MISC : 0.3%
[IPU1-0] 41.106966 s:
[IPU1-0] 41.107027 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1022
[IPU1-0] 41.107118 s:
[IPU1-0] 41.107149 s: SYSTEM: Sempahores Objects, 425 of 1024 free
[IPU1-0] 41.107240 s: SYSTEM: Task Objects , 92 of 100 free
[IPU1-0] 41.107332 s: SYSTEM: Clock Objects , 98 of 100 free
[IPU1-0] 41.107667 s: SYSTEM: Hwi Objects , 99 of 100 free
[IPU1-0] 41.107759 s:
[IPU1-0] 41.107820 s: SYSTEM: Heap = LOCAL_L2 @ 0x40020000, Total size = 2)
[IPU1-0] 41.107972 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 2)
[IPU1-0] 41.108125 s:
[IPU1-0] 41.108186 s:
[IPU1-0] 41.108643 s: CPU [EVE3 ] Statistics,
[IPU1-0] 41.108704 s: *************************
[IPU1-0] 41.108765 s:
[IPU1-0] 41.109467 s: LOAD: CPU: 91.0% HWI: 0.3%, SWI:0.2%, Low Power: 8.2%
[IPU1-0] 41.109650 s:
[IPU1-0] 41.109711 s: LOAD: TSK: SYSTEM_TSK_MULTI_MBX: 90.3%
[IPU1-0] 41.109833 s: LOAD: TSK: MISC : 0.2%
[IPU1-0] 41.109894 s:
[IPU1-0] 41.109955 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1022
[IPU1-0] 41.110046 s:
[IPU1-0] 41.110077 s: SYSTEM: Sempahores Objects, 425 of 1024 free
[IPU1-0] 41.110168 s: SYSTEM: Task Objects , 92 of 100 free
[IPU1-0] 41.110260 s: SYSTEM: Clock Objects , 98 of 100 free
[IPU1-0] 41.110351 s: SYSTEM: Hwi Objects , 99 of 100 free
[IPU1-0] 41.110473 s:
[IPU1-0] 41.110534 s: SYSTEM: Heap = LOCAL_L2 @ 0x40020000, Total size = 2)
[IPU1-0] 41.110687 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 2)
[IPU1-0] 41.110839 s:
[IPU1-0] 41.110900 s:
[IPU1-0] 41.110931 s: CPU [EVE4 ] Statistics,
[IPU1-0] 41.110992 s: *************************
[IPU1-0] 41.111053 s:
[IPU1-0] 41.111114 s: LOAD: CPU: 90.8% HWI: 0.3%, SWI:0.2%, Low Power: 8.4%
[IPU1-0] 41.111236 s:
[IPU1-0] 41.112182 s: LOAD: TSK: SYSTEM_TSK_MULTI_MBX: 90.1%
[IPU1-0] 41.112304 s: LOAD: TSK: MISC : 0.2%
[IPU1-0] 41.112456 s:
[IPU1-0] 41.112487 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1022
[IPU1-0] 41.112578 s:
[IPU1-0] 41.112609 s: SYSTEM: Sempahores Objects, 425 of 1024 free
[IPU1-0] 41.112700 s: SYSTEM: Task Objects , 92 of 100 free
[IPU1-0] 41.112792 s: SYSTEM: Clock Objects , 98 of 100 free
[IPU1-0] 41.112883 s: SYSTEM: Hwi Objects , 99 of 100 free
[IPU1-0] 41.112975 s:
[IPU1-0] 41.113798 s: SYSTEM: Heap = LOCAL_L2 @ 0x40020000, Total size = 2)
[IPU1-0] 41.113981 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 2)
[IPU1-0] 41.114134 s:
[IPU1-0] 41.114195 s:
[IPU1-0] 41.114225 s: CPU [IPU2 ] Statistics,
[IPU1-0] 41.114286 s: *************************
[IPU1-0] 41.114347 s:
[IPU1-0] 41.114439 s: LOAD: CPU: 0.9% HWI: 0.4%, SWI:0.3%, Low Power: 96.0%
[IPU1-0] 41.114591 s:
[IPU1-0] 41.114713 s: LOAD: TSK: MISC : 0.2%
[IPU1-0] 41.114774 s:
[IPU1-0] 41.114835 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1022
[IPU1-0] 41.114896 s:
[IPU1-0] 41.114957 s: SYSTEM: Sempahores Objects, 416 of 1024 free
[IPU1-0] 41.115049 s: SYSTEM: Task Objects , 39 of 100 free
[IPU1-0] 41.115110 s: SYSTEM: Clock Objects , 99 of 100 free
[IPU1-0] 41.115201 s: SYSTEM: Hwi Objects , 99 of 100 free
[IPU1-0] 41.115293 s:
[IPU1-0] 41.115323 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 2)
[IPU1-0] 41.115506 s:
[IPU1-0] 41.115842 s:
[IPU1-0] 41.115903 s: UTILS_PRCM_STATS: Current Temperature,
[IPU1-0] 41.115964 s:
[IPU1-0] 41.115994 s: Voltage Rail || Curr Temp Min - Max
[IPU1-0] 41.116086 s: ---------------------------------------------------------
[IPU1-0] 41.116177 s: PMHAL_PRCM_VD_MPU || [40.400 , 40.800]
[IPU1-0] 41.116299 s: PMHAL_PRCM_VD_CORE || [40.400 , 40.800]
[IPU1-0] 41.116421 s: PMHAL_PRCM_VD_IVAHD || [40. 0 , 40.400]
[IPU1-0] 41.116543 s: PMHAL_PRCM_VD_DSPEVE || [38.800 , 39.200]
[IPU1-0] 41.116665 s: PMHAL_PRCM_VD_GPU || [40.800 , 41.200]
[IPU1-0] 41.116757 s:
[IPU1-0] 41.116787 s: ==================================================================
[IPU1-0] 41.116909 s: Name | Bus (mV) | Res (mOhm) | Shunt (uV) | Current (mA) |)
[IPU1-0] 41.117001 s: ------------------------------------------------------------------
[IPU1-0] 41.118648 s: UTILS_PRCM_STATS: Reading the regulator data failed
[IPU1-0] 41.118739 s: UTILS_PRCM_STATS: PM INA226 Power Read Failed !!
[IPU1-0] 41.119044 s:
[IPU1-0] 41.119166 s: Statistics Collector,
[IPU1-0] 41.119227 s:
[IPU1-0] 41.119258 s: STATISTIC Avg Data Peak Data
[IPU1-0] 41.119349 s: COLLECTOR MB/s MB/s
[IPU1-0] 41.119471 s: --------------------------------------------------
[IPU1-0] 41.119563 s: SCI_EMIF1 RD+WR | 231.932205 997.982300
[IPU1-0] 41.119685 s: SCI_EMIF2 RD+WR | 231.349932 996.566371
[IPU1-0] 41.119807 s: SCI_EMIF1 RD ONLY | 155.109292 665.231507
[IPU1-0] 41.119898 s: SCI_EMIF1 WR ONLY | 76.910693 996.202735
[IPU1-0] 41.120020 s: SCI_EMIF2 RD ONLY | 154.229430 661.504998
[IPU1-0] 41.120112 s: SCI_EMIF2 WR ONLY | 77.242480 996.119066
[IPU1-0] 41.120234 s: SCI_MA_MPU_P1 | 7.601337 205.104294
[IPU1-0] 41.120325 s: SCI_MA_MPU_P2 | 7.561597 205.168711
[IPU1-0] 41.120478 s: SCI_DSS | 44.009495 260.004285
[IPU1-0] 41.120600 s: SCI_IPU1 | 16.406409 151.529180
[IPU1-0] 41.120691 s: SCI_VIP1_P1 | 0.000000 0.000000
[IPU1-0] 41.120783 s: SCI_VIP1_P2 | 0.000000 0.000000
[IPU1-0] 41.120905 s: SCI_VPE_P1 | 6.977063 134.169344
[IPU1-0] 41.120996 s: SCI_VPE_P2 | 6.978138 134.169344
[IPU1-0] 41.121118 s: SCI_DSP1_MDMA | 14.940570 779.688924
[IPU1-0] 41.121210 s: SCI_DSP1_EDMA | 0.000071 0.143084
[IPU1-0] 41.121332 s: SCI_DSP2_MDMA | 0.092683 19.992714
[IPU1-0] 41.121454 s: SCI_DSP2_EDMA | 0.000000 0.000000
[IPU1-0] 41.121576 s: SCI_EVE1_TC0 | 75.612153 654.247787
[IPU1-0] 41.121667 s: SCI_EVE1_TC1 | 106.885901 859.816073
[IPU1-0] 41.121789 s: SCI_EVE2_TC0 | 74.205659 657.258246
[IPU1-0] 41.121881 s: SCI_EVE2_TC1 | 105.619425 862.886845
[IPU1-0] 41.122003 s: SCI_EDMA_TC0_RD | 0.000000 0.000000
[IPU1-0] 41.122094 s: SCI_EDMA_TC0_WR | 0.000000 0.000000
[IPU1-0] 41.122186 s: SCI_EDMA_TC1_RD | 4.418568 276.498311
[IPU1-0] 41.122399 s: SCI_EDMA_TC1_WR | 4.420506 276.345718
[IPU1-0] 41.122521 s: SCI_VIP2_P1 | 0.000000 0.000000
[IPU1-0] 41.122643 s: SCI_VIP2_P2 | 0.000000 0.000000
[IPU1-0] 41.122735 s: SCI_VIP3_P1 | 0.000000 0.000000
[IPU1-0] 41.122826 s: SCI_VIP3_P2 | 0.000000 0.000000
[IPU1-0] 41.122948 s: SCI_EVE3_TC0 | 6.530724 519.993563
[IPU1-0] 41.123040 s: SCI_EVE3_TC1 | 0.000000 0.000000
[IPU1-0] 41.123131 s: SCI_EVE4_TC0 | 7.782526 519.490603
[IPU1-0] 41.123253 s: SCI_EVE4_TC1 | 0.000000 0.000000
[IPU1-0] 41.123345 s: SCI_IVA | 0.000000 0.000000
[IPU1-0] 41.123711 s: SCI_GPU_P1 | 0.000000 0.000000
[IPU1-0] 41.123833 s: SCI_GPU_P2 | 0.000000 0.000000
[IPU1-0] 41.123924 s: SCI_GMAC_SW | 0.000000 0.000000
[IPU1-0] 41.124016 s: SCI_OCMC_RAM1 | 0.032760 65.509796
[IPU1-0] 41.124138 s: SCI_OCMC_RAM2 | 0.032760 65.496701
[IPU1-0] 41.124229 s: SCI_OCMC_RAM3 | 0.000000 0.000000
[IPU1-0] 41.224425 s:
[IPU1-0] 41.224486 s:
[IPU1-0] 41.224638 s:
[IPU1-0] 41.224699 s: ### CPU [IPU1-0], LinkID [ 57],
[IPU1-0] 41.224760 s:
[IPU1-0] 41.224821 s: [ NULL_SRC ] Link Statistics,
[IPU1-0] 41.224882 s: ******************************
[IPU1-0] 41.224943 s:
[IPU1-0] 41.224974 s: Elapsed time = 7819 msec
[IPU1-0] 41.225035 s:
[IPU1-0] 41.225096 s: New data Recv = 20.7 fps
[IPU1-0] 41.225157 s: Get Full Buf Cb = 20.7 fps
[IPU1-0] 41.225248 s: Put Empty Buf Cb = 20.7 fps
[IPU1-0] 41.225309 s: Driver/Notify Cb = 19.95 fps
[IPU1-0] 41.225584 s:
[IPU1-0] 41.225614 s: Input Statistics,
[IPU1-0] 41.225675 s:
[IPU1-0] 41.225706 s: CH | In Recv | In Drop | In User Drop | In Process
[IPU1-0] 41.225797 s: | FPS | FPS | FPS | FPS
[IPU1-0] 41.225889 s: --------------------------------------------------
[IPU1-0] 41.225950 s: 0 | 20. 7 0. 0 0. 0 20. 7
[IPU1-0] 41.226102 s:
[IPU1-0] 41.226194 s: Output Statistics,
[IPU1-0] 41.226255 s:
[IPU1-0] 41.226316 s: CH | Out | Out | Out Drop | Out User Drop
[IPU1-0] 41.226407 s: | ID | FPS | FPS | FPS
[IPU1-0] 41.226499 s: ---------------------------------------------
[IPU1-0] 41.226590 s: 0 | 0 20. 7 0. 0 0. 0
[IPU1-0] 41.226712 s:
[IPU1-0] 41.226743 s: [ NULL_SRC ] LATENCY,
[IPU1-0] 41.226804 s: ********************
[IPU1-0] 41.226865 s:
[IPU1-0] 41.227017 s:
[IPU1-0] 41.227078 s: ### CPU [IPU1-0], LinkID [ 82],
[IPU1-0] 41.227139 s:
[IPU1-0] 41.227170 s: [ DECODE ] Link Statistics,
[IPU1-0] 41.227261 s: ******************************
[IPU1-0] 41.227322 s:
[IPU1-0] 41.227353 s: Elapsed time = 7816 msec
[IPU1-0] 41.227444 s:
[IPU1-0] 41.227505 s: New data Recv = 20.8 fps
[IPU1-0] 41.227566 s: Release data Recv = 20.8 fps
[IPU1-0] 41.227658 s: Get Full Buf Cb = 39.53 fps
[IPU1-0] 41.227749 s: Put Empty Buf Cb = 20.8 fps
[IPU1-0] 41.227810 s:
[IPU1-0] 41.227841 s: Input Statistics,
[IPU1-0] 41.227902 s:
[IPU1-0] 41.227932 s: CH | In Recv | In Drop | In User Drop | In Process
[IPU1-0] 41.228024 s: | FPS | FPS | FPS | FPS
[IPU1-0] 41.228115 s: --------------------------------------------------
[IPU1-0] 41.228176 s: 0 | 20. 8 0. 0 0. 0 20. 8
[IPU1-0] 41.228329 s:
[IPU1-0] 41.228359 s: Output Statistics,
[IPU1-0] 41.228756 s:
[IPU1-0] 41.228817 s: CH | Out | Out | Out Drop | Out User Drop
[IPU1-0] 41.228878 s: | ID | FPS | FPS | FPS
[IPU1-0] 41.228939 s: ---------------------------------------------
[IPU1-0] 41.229030 s: 0 | 0 20. 8 0. 0 0. 0
[IPU1-0] 41.229152 s:
[IPU1-0] 41.229183 s: [ DECODE ] LATENCY,
[IPU1-0] 41.229244 s: ********************
[IPU1-0] 41.229305 s: Local Link Latency : Avg = 252441 us, Min = 199536 us, Max =
[IPU1-0] 41.229457 s: Source to Link Latency : Avg = 252563 us, Min = 199689 us, Max =
[IPU1-0] 41.229579 s:
[IPU1-0] 41.229732 s:
[IPU1-0] 41.229762 s: ### CPU [IPU1-0], LinkID [ 77],
[IPU1-0] 41.229823 s:
[IPU1-0] 41.229884 s: [ VPE ] Link Statistics,
[IPU1-0] 41.229945 s: ******************************
[IPU1-0] 41.230006 s:
[IPU1-0] 41.230037 s: Elapsed time = 7567 msec
[IPU1-0] 41.230098 s:
[IPU1-0] 41.230128 s: New data Recv = 20.8 fps
[IPU1-0] 41.230220 s: Get Full Buf Cb = 20.8 fps
[IPU1-0] 41.230281 s: Put Empty Buf Cb = 39.51 fps
[IPU1-0] 41.230372 s: Driver/Notify Cb = 20.8 fps
[IPU1-0] 41.230464 s:
[IPU1-0] 41.230494 s: Input Statistics,
[IPU1-0] 41.230555 s:
[IPU1-0] 41.230586 s: CH | In Recv | In Drop | In User Drop | In Process
[IPU1-0] 41.230677 s: | FPS | FPS | FPS | FPS
[IPU1-0] 41.230738 s: --------------------------------------------------
[IPU1-0] 41.230830 s: 0 | 20. 8 0. 0 0. 0 20. 8
[IPU1-0] 41.230952 s:
[IPU1-0] 41.230982 s: Output Statistics,
[IPU1-0] 41.231043 s:
[IPU1-0] 41.231074 s: CH | Out | Out | Out Drop | Out User Drop
[IPU1-0] 41.231165 s: | ID | FPS | FPS | FPS
[IPU1-0] 41.231226 s: ---------------------------------------------
[IPU1-0] 41.231318 s: 0 | 0 20. 8 0. 0 0. 0
[IPU1-0] 41.231440 s:
[IPU1-0] 41.233941 s:
[IPU1-0] 41.233971 s: [ IPC_OUT_0 ] LATENCY,
[IPU1-0] 41.234032 s: ********************
[IPU1-0] 41.234093 s: Local Link Latency : Avg = 8 us, Min = 0 us, Max =
[IPU1-0] 41.234185 s: Source to Link Latency : Avg = 254255 us, Min = 201336 us, Max =
[IPU1-0] 41.234307 s:
[IPU1-0] 41.733697 s:
[IPU1-0] 41.733788 s: ### CPU [ HOST], LinkID [ 10],
[IPU1-0] 41.733910 s:
[IPU1-0] 41.733971 s: [ IPC_IN_0 ] Link Statistics,
[IPU1-0] 41.734032 s: ******************************
[IPU1-0] 41.734093 s:
[IPU1-0] 41.734124 s: Elapsed time = 8070 msec
[IPU1-0] 41.734185 s:
[IPU1-0] 41.734246 s: Get Full Buf Cb = 20.7 fps
[IPU1-0] 41.734307 s: Put Empty Buf Cb = 20.7 fps
[IPU1-0] 41.734429 s: Driver/Notify Cb = 19.95 fps
[IPU1-0] 41.734490 s:
[IPU1-0] 41.734551 s: Input Statistics,
[IPU1-0] 41.734581 s:
[IPU1-0] 41.734642 s: CH | In Recv | In Drop | In User Drop | In Process
[IPU1-0] 41.734703 s: | FPS | FPS | FPS | FPS
[IPU1-0] 41.734795 s: --------------------------------------------------
[IPU1-0] 41.734856 s: 0 | 20. 7 0. 0 0. 0 20. 7
[IPU1-0] 41.735008 s:
[IPU1-0] 41.735039 s: Output Statistics,
[IPU1-0] 41.735100 s:
[IPU1-0] 41.735130 s: CH | Out | Out | Out Drop | Out User Drop
[IPU1-0] 41.735191 s: | ID | FPS | FPS | FPS
[IPU1-0] 41.735283 s: ---------------------------------------------
[IPU1-0] 41.735344 s: 0 | 0 20. 7 0. 0 0. 0
[IPU1-0] 41.735496 s:
[IPU1-0] 41.735527 s: [ IPC_IN_0 ] LATENCY,
[IPU1-0] 41.735588 s: ********************
[IPU1-0] 41.735649 s: Local Link Latency : Avg = 4 us, Min = 0 us, Max =
[IPU1-0] 41.735740 s: Source to Link Latency : Avg = 254348 us, Min = 201427 us, Max =
[IPU1-0] 41.735862 s:
[IPU1-0] 41.736015 s:
[IPU1-0] 41.736045 s: ### CPU [ HOST], LinkID [ 49],
[IPU1-0] 41.736137 s:
[IPU1-0] 41.736167 s: [ ALG_TIDLPREPROC ] Link Statistics,
[IPU1-0] 41.736228 s: ******************************
[IPU1-0] 41.736289 s:
[IPU1-0] 41.736320 s: Elapsed time = 8073 msec
[IPU1-0] 41.736411 s:
[IPU1-0] 41.736472 s: New data Recv = 20.6 fps
[IPU1-0] 41.736533 s:
[IPU1-0] 41.736564 s: Input Statistics,
[IPU1-0] 41.736625 s:
[IPU1-0] 41.736655 s: CH | In Recv | In Drop | In User Drop | In Process
[IPU1-0] 41.736747 s: | FPS | FPS | FPS | FPS
[IPU1-0] 41.737296 s: --------------------------------------------------
[IPU1-0] 41.737540 s: 0 | 20. 6 0. 0 0. 0 20. 6
[IPU1-0] 41.739919 s:
[IPU1-0] 41.740010 s: Output Statistics,
[IPU1-0] 41.740041 s:
[IPU1-0] 41.740102 s: CH | Out | Out | Out Drop | Out User Drop
[IPU1-0] 41.740163 s: | ID | FPS | FPS | FPS
[IPU1-0] 41.740254 s: ---------------------------------------------
[IPU1-0] 41.740315 s: 0 | 0 20. 6 0. 0 0. 0
[IPU1-0] 41.740498 s:
[IPU1-0] 41.740529 s: [ ALG_TIDLPREPROC ] LATENCY,
[IPU1-0] 41.740620 s: ********************
[IPU1-0] 41.740681 s: Local Link Latency : Avg = 257 us, Min = 213 us, Max =
[IPU1-0] 41.740773 s: Source to Link Latency : Avg = 265473 us, Min = 212560 us, Max =
[IPU1-0] 41.740895 s:
[IPU1-0] 41.741048 s:
[IPU1-0] 41.741109 s: ### CPU [ HOST], LinkID [ 3],
[IPU1-0] 41.741170 s:
[IPU1-0] 41.741200 s: [ IPC_OUT_3 ] Link Statistics,
[IPU1-0] 41.741292 s: ******************************
[IPU1-0] 41.741353 s:
[IPU1-0] 41.741383 s: Elapsed time = 7919 msec
[IPU1-0] 41.741475 s:
[IPU1-0] 41.741536 s: New data Recv = 5.5 fps
[IPU1-0] 41.741597 s: Release data Recv = 4.92 fps
[IPU1-0] 41.741688 s: Driver/Notify Cb = 104.93 fps
[IPU1-0] 41.741749 s:
[IPU1-0] 41.741780 s: Input Statistics,
[IPU1-0] 41.741841 s:
[IPU1-0] 41.741871 s: CH | In Recv | In Drop | In User Drop | In Process
[IPU1-0] 41.741963 s: | FPS | FPS | FPS | FPS
[IPU1-0] 41.742024 s: --------------------------------------------------
[IPU1-0] 41.742115 s: 0 | 5. 5 0. 0 0. 0 5. 5
[IPU1-0] 41.742268 s:
[IPU1-0] 41.742298 s: Output Statistics,
[IPU1-0] 41.742359 s:
[IPU1-0] 41.742420 s: CH | Out | Out | Out Drop | Out User Drop
[IPU1-0] 41.742481 s: | ID | FPS | FPS | FPS
[IPU1-0] 41.742573 s: ---------------------------------------------
[IPU1-0] 41.742634 s: 0 | 0 5. 5 0. 0 0. 0
[IPU1-0] 41.742756 s:
[IPU1-0] 41.742786 s: [ IPC_OUT_3 ] LATENCY,
[IPU1-0] 41.742847 s: ********************
[IPU1-0] 41.742908 s: Local Link Latency : Avg = 2 us, Min = 0 us, Max =
[IPU1-0] 41.743030 s: Source to Link Latency : Avg = 280646 us, Min = 212560 us, Max =
[IPU1-0] 41.743152 s:
[IPU1-0] 42.242573 s:
[IPU1-0] 42.242634 s: ### CPU [ EVE4], LinkID [ 10],
[IPU1-0] 42.242878 s:
[IPU1-0] 42.242939 s: [ IPC_IN_0 ] Link Statistics,
[IPU1-0] 42.243000 s: ******************************
[IPU1-0] 42.243061 s:
[IPU1-0] 42.243091 s: Elapsed time = 8420 msec
[IPU1-0] 42.243152 s:
[IPU1-0] 42.243213 s: Get Full Buf Cb = 9.97 fps
[IPU1-0] 42.243274 s: Put Empty Buf Cb = 4.98 fps
[IPU1-0] 42.243366 s: Driver/Notify Cb = 4.98 fps
[IPU1-0] 42.243701 s:
[IPU1-0] 42.243762 s: Input Statistics,
[IPU1-0] 42.243823 s:
[IPU1-0] 42.243854 s: CH | In Recv | In Drop | In User Drop | In Process
[IPU1-0] 42.243945 s: | FPS | FPS | FPS | FPS
[IPU1-0] 42.244006 s: --------------------------------------------------
[IPU1-0] 42.244098 s: 0 | 5.10 0. 0 0. 0 5.10
[IPU1-0] 42.244220 s:
[IPU1-0] 42.244250 s: Output Statistics,
[IPU1-0] 42.244311 s:
[IPU1-0] 42.244342 s: CH | Out | Out | Out Drop | Out User Drop
[IPU1-0] 42.244464 s: | ID | FPS | FPS | FPS
[IPU1-0] 42.244555 s: ---------------------------------------------
[IPU1-0] 42.244738 s: 0 | 0 5.10 0. 0 0. 0
[IPU1-0] 42.244921 s:
[IPU1-0] 42.244982 s: [ IPC_IN_0 ] LATENCY,
[IPU1-0] 42.245043 s: ********************
[IPU1-0] 42.245104 s: Local Link Latency : Avg = 33 us, Min = 30 us, Max =
[IPU1-0] 42.245196 s: Source to Link Latency : Avg = 283320 us, Min = 212835 us, Max =
[IPU1-0] 42.245318 s:
[IPU1-0] 42.245501 s:
[IPU1-0] 42.245562 s: ### CPU [ EVE4], LinkID [ 49],
[IPU1-0] 42.245623 s:
[IPU1-0] 42.245684 s: [ ALG_TIDL ] Link Statistics,
[IPU1-0] 42.245745 s: ******************************
[IPU1-0] 42.245806 s:
[IPU1-0] 42.245836 s: Elapsed time = 8423 msec
[IPU1-0] 42.245897 s:
[IPU1-0] 42.245928 s: New data Recv = 9.97 fps
[IPU1-0] 42.246019 s:
[IPU1-0] 42.246050 s: Input Statistics,
[IPU1-0] 42.246111 s:
[IPU1-0] 42.246141 s: CH | In Recv | In Drop | In User Drop | In Process
[IPU1-0] 42.246233 s: | FPS | FPS | FPS | FPS
[IPU1-0] 42.246294 s: --------------------------------------------------
[IPU1-0] 42.246385 s: 0 | 5.10 0. 0 0. 0 4.98
[IPU1-0] 42.246538 s:
[IPU1-0] 42.246568 s: Output Statistics,
[IPU1-0] 42.246629 s:
[IPU1-0] 42.246660 s: CH | Out | Out | Out Drop | Out User Drop
[IPU1-0] 42.246751 s: | ID | FPS | FPS | FPS
[IPU1-0] 42.246812 s: ---------------------------------------------
[IPU1-0] 42.246904 s: 0 | 0 4.98 0. 0 0. 0
[IPU1-0] 42.246995 s:
[IPU1-0] 42.247056 s: [ ALG_TIDL ] LATENCY,
[IPU1-0] 42.247117 s: ********************
[IPU1-0] 42.247148 s: Local Link Latency : Avg = 180667 us, Min = 180413 us, Max =
[IPU1-0] 42.247270 s: Source to Link Latency : Avg = 463415 us, Min = 393674 us, Max =
[IPU1-0] 42.247392 s:
[IPU1-0] 42.247575 s:
[IPU1-0] 42.247605 s: ### CPU [ EVE4], LinkID [ 0],
[IPU1-0] 42.247697 s:
[IPU1-0] 42.247727 s: [ IPC_OUT_0 ] Link Statistics,
[IPU1-0] 42.247788 s: ******************************
[IPU1-0] 42.247849 s:
[IPU1-0] 42.247880 s: Elapsed time = 8244 msec
[IPU1-0] 42.247971 s:
[IPU1-0] 42.248002 s: New data Recv = 5.9 fps
[IPU1-0] 42.248063 s: Release data Recv = 4.97 fps
[IPU1-0] 42.248154 s: Driver/Notify Cb = 15.4 fps
[IPU1-0] 42.248215 s:
[IPU1-0] 42.248246 s: Input Statistics,
[IPU1-0] 42.248307 s:
[IPU1-0] 42.248337 s: CH | In Recv | In Drop | In User Drop | In Process
[IPU1-0] 42.248642 s: | FPS | FPS | FPS | FPS
[IPU1-0] 42.248734 s: --------------------------------------------------
[IPU1-0] 42.248825 s: 0 | 5. 9 0. 0 0. 0 5. 9
[IPU1-0] 42.248947 s:
[IPU1-0] 42.248978 s: Output Statistics,
[IPU1-0] 42.249039 s:
[IPU1-0] 42.249069 s: CH | Out | Out | Out Drop | Out User Drop
[IPU1-0] 42.249161 s: | ID | FPS | FPS | FPS
[IPU1-0] 42.249222 s: ---------------------------------------------
[IPU1-0] 42.249283 s: 0 | 0 5. 9 0. 0 0. 0
[IPU1-0] 42.249435 s:
[IPU1-0] 42.249496 s: [ IPC_OUT_0 ] LATENCY,
[IPU1-0] 42.249557 s: ********************
[IPU1-0] 42.249618 s: Local Link Latency : Avg = 27 us, Min = 0 us, Max =
[IPU1-0] 42.249801 s: Source to Link Latency : Avg = 463759 us, Min = 394010 us, Max =
[IPU1-0] 42.249923 s:
[IPU1-0] 42.749588 s:
[IPU1-0] 42.749649 s: ### CPU [ DSP1], LinkID [ 13],
[IPU1-0] 42.749710 s:
[IPU1-0] 42.749771 s: [ IPC_IN_3 ] Link Statistics,
[IPU1-0] 42.749832 s: ******************************
[IPU1-0] 42.749893 s:
[IPU1-0] 42.749923 s: Elapsed time = 8746 msec
[IPU1-0] 42.749984 s:
[IPU1-0] 42.750045 s: Get Full Buf Cb = 20.0 fps
[IPU1-0] 42.750106 s: Put Empty Buf Cb = 5.3 fps
[IPU1-0] 42.750198 s: Driver/Notify Cb = 4.91 fps
[IPU1-0] 42.750259 s:
[IPU1-0] 42.750289 s: Input Statistics,
[IPU1-0] 42.750350 s:
[IPU1-0] 42.750381 s: CH | In Recv | In Drop | In User Drop | In Process
[IPU1-0] 42.750503 s: | FPS | FPS | FPS | FPS
[IPU1-0] 42.750594 s: --------------------------------------------------
[IPU1-0] 42.750716 s: 0 | 5. 3 0. 0 0. 0 5. 3
[IPU1-0] 42.750838 s:
[IPU1-0] 42.750899 s: Output Statistics,
[IPU1-0] 42.750930 s:
[IPU1-0] 42.750991 s: CH | Out | Out | Out Drop | Out User Drop
[IPU1-0] 42.751052 s: | ID | FPS | FPS | FPS
[IPU1-0] 42.751113 s: ---------------------------------------------
[IPU1-0] 42.751204 s: 0 | 0 5. 3 0. 0 0. 0
[IPU1-0] 42.751326 s:
[IPU1-0] 42.751357 s: [ IPC_IN_3 ] LATENCY,
[IPU1-0] 42.751448 s: ********************
[IPU1-0] 42.751509 s: Local Link Latency : Avg = 8 us, Min = 0 us, Max =
[IPU1-0] 42.751631 s: Source to Link Latency : Avg = 465378 us, Min = 394162 us, Max =
[IPU1-0] 42.751723 s:
[IPU1-0] 43.251570 s:
[IPU1-0] 43.251631 s: ### CPU [ HOST], LinkID [ 2],
[IPU1-0] 43.251723 s:
[IPU1-0] 43.251753 s: [ IPC_OUT_2 ] Link Statistics,
[IPU1-0] 43.251814 s: ******************************
[IPU1-0] 43.251875 s:
[IPU1-0] 43.251936 s: Elapsed time = 9478 msec
[IPU1-0] 43.251997 s:
[IPU1-0] 43.252028 s: New data Recv = 5.6 fps
[IPU1-0] 43.252180 s: Release data Recv = 4.95 fps
[IPU1-0] 43.252241 s: Driver/Notify Cb = 104.87 fps
[IPU1-0] 43.252333 s:
[IPU1-0] 43.252363 s: Input Statistics,
[IPU1-0] 43.252424 s:
[IPU1-0] 43.252485 s: CH | In Recv | In Drop | In User Drop | In Process
[IPU1-0] 43.252577 s: | FPS | FPS | FPS | FPS
[IPU1-0] 43.252638 s: --------------------------------------------------
[IPU1-0] 43.252729 s: 0 | 5. 6 0. 0 0. 0 5. 6
[IPU1-0] 43.252851 s:
[IPU1-0] 43.252882 s: Output Statistics,
[IPU1-0] 43.252943 s:
[IPU1-0] 43.252973 s: CH | Out | Out | Out Drop | Out User Drop
[IPU1-0] 43.253065 s: | ID | FPS | FPS | FPS
[IPU1-0] 43.253126 s: ---------------------------------------------
[IPU1-0] 43.253187 s: 0 | 0 5. 6 0. 0 0. 0
[IPU1-0] 43.253309 s:
[IPU1-0] 43.253370 s: [ IPC_OUT_2 ] LATENCY,
[IPU1-0] 43.253431 s: ********************
[IPU1-0] 43.253675 s: Local Link Latency : Avg = 1 us, Min = 0 us, Max =
[IPU1-0] 43.253827 s: Source to Link Latency : Avg = 250708 us, Min = 214696 us, Max =
[IPU1-0] 43.253919 s:
[IPU1-0] 43.753736 s:
[IPU1-0] 43.753827 s: ### CPU [ EVE3], LinkID [ 10],
[IPU1-0] 43.753888 s:
[IPU1-0] 43.753949 s: [ IPC_IN_0 ] Link Statistics,
[IPU1-0] 43.754010 s: ******************************
[IPU1-0] 43.754071 s:
[IPU1-0] 43.754102 s: Elapsed time = 9980 msec
[IPU1-0] 43.754163 s:
[IPU1-0] 43.754224 s: Get Full Buf Cb = 9.81 fps
[IPU1-0] 43.754285 s: Put Empty Buf Cb = 4.90 fps
[IPU1-0] 43.754346 s: Driver/Notify Cb = 4.90 fps
[IPU1-0] 43.754437 s:
[IPU1-0] 43.754529 s: Input Statistics,
[IPU1-0] 43.754590 s:
[IPU1-0] 43.754620 s: CH | In Recv | In Drop | In User Drop | In Process
[IPU1-0] 43.754681 s: | FPS | FPS | FPS | FPS
[IPU1-0] 43.754773 s: --------------------------------------------------
[IPU1-0] 43.754864 s: 0 | 5. 1 0. 0 0. 0 5. 1
[IPU1-0] 43.754986 s:
[IPU1-0] 43.755017 s: Output Statistics,
[IPU1-0] 43.755078 s:
[IPU1-0] 43.755108 s: CH | Out | Out | Out Drop | Out User Drop
[IPU1-0] 43.755169 s: | ID | FPS | FPS | FPS
[IPU1-0] 43.755261 s: ---------------------------------------------
[IPU1-0] 43.755322 s: 0 | 0 5. 1 0. 0 0. 0
[IPU1-0] 43.755810 s:
[IPU1-0] 43.755871 s: [ IPC_IN_0 ] LATENCY,
[IPU1-0] 43.755932 s: ********************
[IPU1-0] 43.755993 s: Local Link Latency : Avg = 32 us, Min = 30 us, Max =
[IPU1-0] 43.756115 s: Source to Link Latency : Avg = 253562 us, Min = 214970 us, Max =
[IPU1-0] 43.756237 s:
[IPU1-0] 43.756694 s:
[IPU1-0] 43.756755 s: ### CPU [ EVE3], LinkID [ 49],
[IPU1-0] 43.756847 s:
[IPU1-0] 43.756877 s: [ ALG_TIDL ] Link Statistics,
[IPU1-0] 43.756938 s: ******************************
[IPU1-0] 43.757030 s:
[IPU1-0] 43.757060 s: Elapsed time = 9982 msec
[IPU1-0] 43.757121 s:
[IPU1-0] 43.757152 s: New data Recv = 9.91 fps
[IPU1-0] 43.757243 s:
[IPU1-0] 43.757274 s: Input Statistics,
[IPU1-0] 43.757335 s:
[IPU1-0] 43.757640 s: CH | In Recv | In Drop | In User Drop | In Process
[IPU1-0] 43.757731 s: | FPS | FPS | FPS | FPS
[IPU1-0] 43.757823 s: --------------------------------------------------
[IPU1-0] 43.757884 s: 0 | 5. 0 0. 0 0. 0 5. 0
[IPU1-0] 43.758036 s:
[IPU1-0] 43.758067 s: Output Statistics,
[IPU1-0] 43.758128 s:
[IPU1-0] 43.758158 s: CH | Out | Out | Out Drop | Out User Drop
[IPU1-0] 43.758219 s: | ID | FPS | FPS | FPS
[IPU1-0] 43.758311 s: ---------------------------------------------
[IPU1-0] 43.758829 s: 0 | 0 5. 0 0. 0 0. 0
[IPU1-0] 43.758982 s:
[IPU1-0] 43.759012 s: [ ALG_TIDL ] LATENCY,
[IPU1-0] 43.759714 s: ********************
[IPU1-0] 43.759775 s: Local Link Latency : Avg = 180776 us, Min = 180443 us, Max =
[IPU1-0] 43.759928 s: Source to Link Latency : Avg = 434513 us, Min = 395962 us, Max =
[IPU1-0] 43.760050 s:
[IPU1-0] 43.760202 s:
[IPU1-0] 43.760263 s: ### CPU [ EVE3], LinkID [ 0],
[IPU1-0] 43.760324 s:
[IPU1-0] 43.760355 s: [ IPC_OUT_0 ] Link Statistics,
[IPU1-0] 43.760477 s: ******************************
[IPU1-0] 43.760782 s:
[IPU1-0] 43.760843 s: Elapsed time = 9806 msec
[IPU1-0] 43.760904 s:
[IPU1-0] 43.760934 s: New data Recv = 5.9 fps
[IPU1-0] 43.761026 s: Release data Recv = 4.99 fps
[IPU1-0] 43.761087 s: Driver/Notify Cb = 14.99 fps
[IPU1-0] 43.761178 s:
[IPU1-0] 43.761209 s: Input Statistics,
[IPU1-0] 43.761270 s:
[IPU1-0] 43.761300 s: CH | In Recv | In Drop | In User Drop | In Process
[IPU1-0] 43.761392 s: | FPS | FPS | FPS | FPS
[IPU1-0] 43.761514 s: --------------------------------------------------
[IPU1-0] 43.762215 s: 0 | 5. 9 0. 0 0. 0 5. 9
[IPU1-0] 43.762398 s:
[IPU1-0] 43.762429 s: Output Statistics,
[IPU1-0] 43.762520 s:
[IPU1-0] 43.762581 s: CH | Out | Out | Out Drop | Out User Drop
[IPU1-0] 43.762642 s: | ID | FPS | FPS | FPS
[IPU1-0] 43.762734 s: ---------------------------------------------
[IPU1-0] 43.762795 s: 0 | 0 5. 9 0. 0 0. 0
[IPU1-0] 43.762917 s:
[IPU1-0] 43.762947 s: [ IPC_OUT_0 ] LATENCY,
[IPU1-0] 43.763008 s: ********************
[IPU1-0] 43.763069 s: Local Link Latency : Avg = 28 us, Min = 0 us, Max =
[IPU1-0] 43.763191 s: Source to Link Latency : Avg = 434857 us, Min = 396297 us, Max =
[IPU1-0] 43.764076 s:
[IPU1-0] 44.264015 s:
[IPU1-0] 44.264076 s: ### CPU [ DSP1], LinkID [ 12],
[IPU1-0] 44.264167 s:
[IPU1-0] 44.264198 s: [ IPC_IN_2 ] Link Statistics,
[IPU1-0] 44.264259 s: ******************************
[IPU1-0] 44.264320 s:
[IPU1-0] 44.264350 s: Elapsed time = 10309 msec
[IPU1-0] 44.264442 s:
[IPU1-0] 44.264533 s: Get Full Buf Cb = 20.7 fps
[IPU1-0] 44.264594 s: Put Empty Buf Cb = 5.4 fps
[IPU1-0] 44.264686 s: Driver/Notify Cb = 4.94 fps
[IPU1-0] 44.264747 s:
[IPU1-0] 44.264777 s: Input Statistics,
[IPU1-0] 44.264838 s:
[IPU1-0] 44.264869 s: CH | In Recv | In Drop | In User Drop | In Process
[IPU1-0] 44.264960 s: | FPS | FPS | FPS | FPS
[IPU1-0] 44.265021 s: --------------------------------------------------
[IPU1-0] 44.265113 s: 0 | 5. 4 0. 0 0. 0 5. 4
[IPU1-0] 44.265235 s:
[IPU1-0] 44.265265 s: Output Statistics,
[IPU1-0] 44.265326 s:
[IPU1-0] 44.265357 s: CH | Out | Out | Out Drop | Out User Drop
[IPU1-0] 44.265448 s: | ID | FPS | FPS | FPS
[IPU1-0] 44.265540 s: ---------------------------------------------
[IPU1-0] 44.265631 s: 0 | 0 5. 4 0. 0 0. 0
[IPU1-0] 44.265753 s:
[IPU1-0] 44.265784 s: [ IPC_IN_2 ] LATENCY,
[IPU1-0] 44.265845 s: ********************
[IPU1-0] 44.265875 s: Local Link Latency : Avg = 11 us, Min = 0 us, Max =
[IPU1-0] 44.265997 s: Source to Link Latency : Avg = 437400 us, Min = 396450 us, Max =
[IPU1-0] 44.266119 s:
[IPU1-0] 44.765692 s:
[IPU1-0] 44.765753 s: ### CPU [ HOST], LinkID [ 1],
[IPU1-0] 44.765845 s:
[IPU1-0] 44.765875 s: [ IPC_OUT_1 ] Link Statistics,
[IPU1-0] 44.765936 s: ******************************
[IPU1-0] 44.765997 s:
[IPU1-0] 44.766058 s: Elapsed time = 11044 msec
[IPU1-0] 44.766119 s:
[IPU1-0] 44.766150 s: New data Recv = 5.7 fps
[IPU1-0] 44.766241 s: Release data Recv = 4.98 fps
[IPU1-0] 44.766302 s: Driver/Notify Cb = 104.94 fps
[IPU1-0] 44.766363 s:
[IPU1-0] 44.766424 s: Input Statistics,
[IPU1-0] 44.766516 s:
[IPU1-0] 44.766546 s: CH | In Recv | In Drop | In User Drop | In Process
[IPU1-0] 44.766638 s: | FPS | FPS | FPS | FPS
[IPU1-0] 44.766699 s: --------------------------------------------------
[IPU1-0] 44.766790 s: 0 | 5. 7 0. 0 0. 0 5. 7
[IPU1-0] 44.766912 s:
[IPU1-0] 44.766943 s: Output Statistics,
[IPU1-0] 44.767004 s:
[IPU1-0] 44.767034 s: CH | Out | Out | Out Drop | Out User Drop
[IPU1-0] 44.767126 s: | ID | FPS | FPS | FPS
[IPU1-0] 44.767187 s: ---------------------------------------------
[IPU1-0] 44.767278 s: 0 | 0 5. 7 0. 0 0. 0
[IPU1-0] 44.767400 s:
[IPU1-0] 44.767431 s: [ IPC_OUT_1 ] LATENCY,
[IPU1-0] 44.767522 s: ********************
[IPU1-0] 44.767583 s: Local Link Latency : Avg = 2 us, Min = 0 us, Max =
[IPU1-0] 44.767705 s: Source to Link Latency : Avg = 271907 us, Min = 214634 us, Max =
[IPU1-0] 44.767827 s:
[IPU1-0] 45.267736 s:
[IPU1-0] 45.267827 s: ### CPU [ EVE2], LinkID [ 10],
[IPU1-0] 45.267888 s:
[IPU1-0] 45.267919 s: [ IPC_IN_0 ] Link Statistics,
[IPU1-0] 45.267980 s: ******************************
[IPU1-0] 45.268041 s:
[IPU1-0] 45.268102 s: Elapsed time = 11546 msec
[IPU1-0] 45.268163 s:
[IPU1-0] 45.268193 s: Get Full Buf Cb = 9.87 fps
[IPU1-0] 45.268285 s: Put Empty Buf Cb = 4.93 fps
[IPU1-0] 45.268346 s: Driver/Notify Cb = 4.93 fps
[IPU1-0] 45.268437 s:
[IPU1-0] 45.268468 s: Input Statistics,
[IPU1-0] 45.268742 s:
[IPU1-0] 45.268803 s: CH | In Recv | In Drop | In User Drop | In Process
[IPU1-0] 45.268895 s: | FPS | FPS | FPS | FPS
[IPU1-0] 45.268956 s: --------------------------------------------------
[IPU1-0] 45.269047 s: 0 | 5. 2 0. 0 0. 0 5. 2
[IPU1-0] 45.269169 s:
[IPU1-0] 45.269200 s: Output Statistics,
[IPU1-0] 45.269261 s:
[IPU1-0] 45.269291 s: CH | Out | Out | Out Drop | Out User Drop
[IPU1-0] 45.269383 s: | ID | FPS | FPS | FPS
[IPU1-0] 45.269444 s: ---------------------------------------------
[IPU1-0] 45.269535 s: 0 | 0 5. 2 0. 0 0. 0
[IPU1-0] 45.269688 s:
[IPU1-0] 45.269718 s: [ IPC_IN_0 ] LATENCY,
[IPU1-0] 45.269779 s: ********************
[IPU1-0] 45.269840 s: Local Link Latency : Avg = 34 us, Min = 30 us, Max =
[IPU1-0] 45.269932 s: Source to Link Latency : Avg = 270374 us, Min = 214909 us, Max =
[IPU1-0] 45.270054 s:
[IPU1-0] 45.270206 s:
[IPU1-0] 45.270237 s: ### CPU [ EVE2], LinkID [ 49],
[IPU1-0] 45.270328 s:
[IPU1-0] 45.270359 s: [ ALG_TIDL ] Link Statistics,
[IPU1-0] 45.270420 s: ******************************
[IPU1-0] 45.270511 s:
[IPU1-0] 45.270542 s: Elapsed time = 11549 msec
[IPU1-0] 45.270633 s:
[IPU1-0] 45.270664 s: New data Recv = 9.87 fps
[IPU1-0] 45.270725 s:
[IPU1-0] 45.270786 s: Input Statistics,
[IPU1-0] 45.270816 s:
[IPU1-0] 45.270877 s: CH | In Recv | In Drop | In User Drop | In Process
[IPU1-0] 45.270938 s: | FPS | FPS | FPS | FPS
[IPU1-0] 45.271030 s: --------------------------------------------------
[IPU1-0] 45.271091 s: 0 | 5. 2 0. 0 0. 0 4.93
[IPU1-0] 45.271243 s:
[IPU1-0] 45.271274 s: Output Statistics,
[IPU1-0] 45.271335 s:
[IPU1-0] 45.271365 s: CH | Out | Out | Out Drop | Out User Drop
[IPU1-0] 45.271426 s: | ID | FPS | FPS | FPS
[IPU1-0] 45.271518 s: ---------------------------------------------
[IPU1-0] 45.271609 s: 0 | 0 4.93 0. 0 0. 0
[IPU1-0] 45.271731 s:
[IPU1-0] 45.271914 s: [ ALG_TIDL ] LATENCY,
[IPU1-0] 45.271975 s: ********************
[IPU1-0] 45.272036 s: Local Link Latency : Avg = 180867 us, Min = 180534 us, Max =
[IPU1-0] 45.272158 s: Source to Link Latency : Avg = 452245 us, Min = 395931 us, Max =
[IPU1-0] 45.272280 s:
[IPU1-0] 45.272433 s:
[IPU1-0] 45.272463 s: ### CPU [ EVE2], LinkID [ 0],
[IPU1-0] 45.272616 s:
[IPU1-0] 45.272646 s: [ IPC_OUT_0 ] Link Statistics,
[IPU1-0] 45.272707 s: ******************************
[IPU1-0] 45.272768 s:
[IPU1-0] 45.272829 s: Elapsed time = 11370 msec
[IPU1-0] 45.272890 s:
[IPU1-0] 45.272921 s: New data Recv = 5.1 fps
[IPU1-0] 45.273012 s: Release data Recv = 4.92 fps
[IPU1-0] 45.273073 s: Driver/Notify Cb = 15.3 fps
[IPU1-0] 45.273165 s:
[IPU1-0] 45.273195 s: Input Statistics,
[IPU1-0] 45.273256 s:
[IPU1-0] 45.273287 s: CH | In Recv | In Drop | In User Drop | In Process
[IPU1-0] 45.273378 s: | FPS | FPS | FPS | FPS
[IPU1-0] 45.273470 s: --------------------------------------------------
[IPU1-0] 45.273775 s: 0 | 5. 1 0. 0 0. 0 5. 1
[IPU1-0] 45.273927 s:
[IPU1-0] 45.273958 s: Output Statistics,
[IPU1-0] 45.274019 s:
[IPU1-0] 45.274080 s: CH | Out | Out | Out Drop | Out User Drop
[IPU1-0] 45.274141 s: | ID | FPS | FPS | FPS
[IPU1-0] 45.274202 s: ---------------------------------------------
[IPU1-0] 45.274293 s: 0 | 0 5. 1 0. 0 0. 0
[IPU1-0] 45.274415 s:
[IPU1-0] 45.274446 s: [ IPC_OUT_0 ] LATENCY,
[IPU1-0] 45.274537 s: ********************
[IPU1-0] 45.274598 s: Local Link Latency : Avg = 26 us, Min = 0 us, Max =
[IPU1-0] 45.274720 s: Source to Link Latency : Avg = 452597 us, Min = 396267 us, Max =
[IPU1-0] 45.274842 s:
[IPU1-0] 45.774781 s:
[IPU1-0] 45.774873 s: ### CPU [ DSP1], LinkID [ 11],
[IPU1-0] 45.774934 s:
[IPU1-0] 45.774964 s: [ IPC_IN_1 ] Link Statistics,
[IPU1-0] 45.775056 s: ******************************
[IPU1-0] 45.775117 s:
[IPU1-0] 45.775147 s: Elapsed time = 11872 msec
[IPU1-0] 45.775208 s:
[IPU1-0] 45.775269 s: Get Full Buf Cb = 20.4 fps
[IPU1-0] 45.775330 s: Put Empty Buf Cb = 5.5 fps
[IPU1-0] 45.775422 s: Driver/Notify Cb = 4.96 fps
[IPU1-0] 45.775544 s:
[IPU1-0] 45.775574 s: Input Statistics,
[IPU1-0] 45.775635 s:
[IPU1-0] 45.775666 s: CH | In Recv | In Drop | In User Drop | In Process
[IPU1-0] 45.775757 s: | FPS | FPS | FPS | FPS
[IPU1-0] 45.775849 s: --------------------------------------------------
[IPU1-0] 45.775940 s: 0 | 5. 5 0. 0 0. 0 5. 5
[IPU1-0] 45.776062 s:
[IPU1-0] 45.776093 s: Output Statistics,
[IPU1-0] 45.776276 s:
[IPU1-0] 45.776306 s: CH | Out | Out | Out Drop | Out User Drop
[IPU1-0] 45.776398 s: | ID | FPS | FPS | FPS
[IPU1-0] 45.776489 s: ---------------------------------------------
[IPU1-0] 45.776581 s: 0 | 0 5. 5 0. 0 0. 0
[IPU1-0] 45.776733 s:
[IPU1-0] 45.776764 s: [ IPC_IN_1 ] LATENCY,
[IPU1-0] 45.776825 s: ********************
[IPU1-0] 45.776886 s: Local Link Latency : Avg = 11 us, Min = 0 us, Max =
[IPU1-0] 45.777008 s: Source to Link Latency : Avg = 453434 us, Min = 396419 us, Max =
[IPU1-0] 45.777099 s:
[IPU1-0] 46.276672 s:
[IPU1-0] 46.276733 s: ### CPU [ HOST], LinkID [ 0],
[IPU1-0] 46.276825 s:
[IPU1-0] 46.276855 s: [ IPC_OUT_0 ] Link Statistics,
[IPU1-0] 46.276916 s: ******************************
[IPU1-0] 46.276977 s:
[IPU1-0] 46.277038 s: Elapsed time = 12602 msec
[IPU1-0] 46.277099 s:
[IPU1-0] 46.277130 s: New data Recv = 5.7 fps
[IPU1-0] 46.277221 s: Release data Recv = 4.99 fps
[IPU1-0] 46.277282 s: Driver/Notify Cb = 104.98 fps
[IPU1-0] 46.277374 s:
[IPU1-0] 46.277404 s: Input Statistics,
[IPU1-0] 46.277435 s:
[IPU1-0] 46.277496 s: CH | In Recv | In Drop | In User Drop | In Process
[IPU1-0] 46.277618 s: | FPS | FPS | FPS | FPS
[IPU1-0] 46.277709 s: --------------------------------------------------
[IPU1-0] 46.277770 s: 0 | 5. 7 0. 0 0. 0 5. 7
[IPU1-0] 46.277923 s:
[IPU1-0] 46.277954 s: Output Statistics,
[IPU1-0] 46.278015 s:
[IPU1-0] 46.278045 s: CH | Out | Out | Out Drop | Out User Drop
[IPU1-0] 46.278106 s: | ID | FPS | FPS | FPS
[IPU1-0] 46.278198 s: ---------------------------------------------
[IPU1-0] 46.278259 s: 0 | 0 5. 7 0. 0 0. 0
[IPU1-0] 46.278381 s:
[IPU1-0] 46.278442 s: [ IPC_OUT_0 ] LATENCY,
[IPU1-0] 46.278503 s: ********************
[IPU1-0] 46.278564 s: Local Link Latency : Avg = 0 us, Min = 0 us, Max =
[IPU1-0] 46.278686 s: Source to Link Latency : Avg = 264627 us, Min = 165620 us, Max =
[IPU1-0] 46.278808 s:
[IPU1-0] 46.778747 s:
[IPU1-0] 46.778808 s: ### CPU [ EVE1], LinkID [ 10],
[IPU1-0] 46.778899 s:
[IPU1-0] 46.778930 s: [ IPC_IN_0 ] Link Statistics,
[IPU1-0] 46.778991 s: ******************************
[IPU1-0] 46.779052 s:
[IPU1-0] 46.779113 s: Elapsed time = 13104 msec
[IPU1-0] 46.779174 s:
[IPU1-0] 46.779204 s: Get Full Buf Cb = 9.92 fps
[IPU1-0] 46.779296 s: Put Empty Buf Cb = 4.96 fps
[IPU1-0] 46.779357 s: Driver/Notify Cb = 4.96 fps
[IPU1-0] 46.779448 s:
[IPU1-0] 46.779479 s: Input Statistics,
[IPU1-0] 46.779784 s:
[IPU1-0] 46.779814 s: CH | In Recv | In Drop | In User Drop | In Process
[IPU1-0] 46.779906 s: | FPS | FPS | FPS | FPS
[IPU1-0] 46.779967 s: --------------------------------------------------
[IPU1-0] 46.780058 s: 0 | 5. 3 0. 0 0. 0 5. 3
[IPU1-0] 46.780180 s:
[IPU1-0] 46.780241 s: Output Statistics,
[IPU1-0] 46.780272 s:
[IPU1-0] 46.780333 s: CH | Out | Out | Out Drop | Out User Drop
[IPU1-0] 46.780394 s: | ID | FPS | FPS | FPS
[IPU1-0] 46.780455 s: ---------------------------------------------
[IPU1-0] 46.780577 s: 0 | 0 5. 3 0. 0 0. 0
[IPU1-0] 46.780699 s:
[IPU1-0] 46.780729 s: [ IPC_IN_0 ] LATENCY,
[IPU1-0] 46.780790 s: ********************
[IPU1-0] 46.780851 s: Local Link Latency : Avg = 32 us, Min = 30 us, Max =
[IPU1-0] 46.780973 s: Source to Link Latency : Avg = 263433 us, Min = 165619 us, Max =
[IPU1-0] 46.781095 s:
[IPU1-0] 46.781217 s:
[IPU1-0] 46.781248 s: ### CPU [ EVE1], LinkID [ 49],
[IPU1-0] 46.781339 s:
[IPU1-0] 46.781370 s: [ ALG_TIDL ] Link Statistics,
[IPU1-0] 46.781431 s: ******************************
[IPU1-0] 46.781492 s:
[IPU1-0] 46.781553 s: Elapsed time = 13107 msec
[IPU1-0] 46.781644 s:
[IPU1-0] 46.781675 s: New data Recv = 9.91 fps
[IPU1-0] 46.781766 s:
[IPU1-0] 46.781797 s: Input Statistics,
[IPU1-0] 46.781858 s:
[IPU1-0] 46.782773 s:
[IPU1-0] 46.782803 s: [ ALG_TIDL ] LATENCY,
[IPU1-0] 46.782864 s: ********************
[IPU1-0] 46.782925 s: Local Link Latency : Avg = 180871 us, Min = 180199 us, Max =
[IPU1-0] 46.783047 s: Source to Link Latency : Avg = 444427 us, Min = 346672 us, Max =
[IPU1-0] 46.783139 s:
[IPU1-0] 46.783291 s:
[IPU1-0] 46.783322 s: ### CPU [ EVE1], LinkID [ 0],
[IPU1-0] 46.783413 s:
[IPU1-0] 46.783444 s: [ IPC_OUT_0 ] Link Statistics,
[IPU1-0] 46.783505 s: ******************************
[IPU1-0] 46.783596 s:
[IPU1-0] 46.783627 s: Elapsed time = 12928 msec
[IPU1-0] 46.783688 s:
[IPU1-0] 46.783749 s: New data Recv = 5.2 fps
[IPU1-0] 46.783810 s: Release data Recv = 4.95 fps
[IPU1-0] 46.783901 s: Driver/Notify Cb = 15.0 fps
[IPU1-0] 46.783962 s:
[IPU1-0] 46.783993 s: Input Statistics,
[IPU1-0] 46.784877 s:
[IPU1-0] 46.786006 s: CH | In Recv | In Drop | In User Drop | In Process
[IPU1-0] 46.786128 s: | FPS | FPS | FPS | FPS
[IPU1-0] 46.786219 s: --------------------------------------------------
[IPU1-0] 46.786280 s: 0 | 5. 2 0. 0 0. 0 5. 2
[IPU1-0] 46.786433 s:
[IPU1-0] 46.786463 s: Output Statistics,
[IPU1-0] 46.786524 s:
[IPU1-0] 46.786585 s: CH | Out | Out | Out Drop | Out User Drop
[IPU1-0] 46.786677 s: | ID | FPS | FPS | FPS
[IPU1-0] 46.786768 s: ---------------------------------------------
[IPU1-0] 46.786829 s: 0 | 0 5. 2 0. 0 0. 0
[IPU1-0] 46.786951 s:
[IPU1-0] 46.786982 s: [ IPC_OUT_0 ] LATENCY,
[IPU1-0] 46.787043 s: ********************
[IPU1-0] 46.787104 s: Local Link Latency : Avg = 25 us, Min = 0 us, Max =
[IPU1-0] 46.787226 s: Source to Link Latency : Avg = 444781 us, Min = 347008 us, Max =
[IPU1-0] 46.787348 s:
[IPU1-0] 47.286677 s:
[IPU1-0] 47.286738 s: ### CPU [ DSP1], LinkID [ 10],
[IPU1-0] 47.286829 s:
[IPU1-0] 47.286860 s: [ IPC_IN_0 ] Link Statistics,
[IPU1-0] 47.286921 s: ******************************
[IPU1-0] 47.286982 s:
[IPU1-0] 47.287043 s: Elapsed time = 13431 msec
[IPU1-0] 47.287104 s:
[IPU1-0] 47.287134 s: Get Full Buf Cb = 20.2 fps
[IPU1-0] 47.287226 s: Put Empty Buf Cb = 4.98 fps
[IPU1-0] 47.287287 s: Driver/Notify Cb = 4.98 fps
[IPU1-0] 47.287378 s:
[IPU1-0] 47.287409 s: Input Statistics,
[IPU1-0] 47.287470 s:
[IPU1-0] 47.287500 s: CH | In Recv | In Drop | In User Drop | In Process
[IPU1-0] 47.287622 s: | FPS | FPS | FPS | FPS
[IPU1-0] 47.287714 s: --------------------------------------------------
[IPU1-0] 47.287805 s: 0 | 5. 6 0. 0 0. 0 5. 6
[IPU1-0] 47.287927 s:
[IPU1-0] 47.287958 s: Output Statistics,
[IPU1-0] 47.288019 s:
[IPU1-0] 47.288049 s: CH | Out | Out | Out Drop | Out User Drop
[IPU1-0] 47.288110 s: | ID | FPS | FPS | FPS
[IPU1-0] 47.288202 s: ---------------------------------------------
[IPU1-0] 47.288263 s: 0 | 0 5. 6 0. 0 0. 0
[IPU1-0] 47.288385 s:
[IPU1-0] 47.288415 s: [ IPC_IN_0 ] LATENCY,
[IPU1-0] 47.288476 s: ********************
[IPU1-0] 47.288568 s: Local Link Latency : Avg = 8 us, Min = 0 us, Max =
[IPU1-0] 47.288690 s: Source to Link Latency : Avg = 445128 us, Min = 347160 us, Max =
[IPU1-0] 47.288812 s:
[IPU1-0] 47.288842 s: CPU [ DSP1], LinkID [ 38], Link Statistics not available !
[IPU1-0] 47.289056 s:
[IPU1-0] 47.289086 s: ### CPU [ DSP1], LinkID [ 49],
[IPU1-0] 47.289147 s:
[IPU1-0] 47.289208 s: [ ALG_TIDL ] Link Statistics,
[IPU1-0] 47.289269 s: ******************************
[IPU1-0] 47.289330 s:
[IPU1-0] 47.289361 s: Elapsed time = 13434 msec
[IPU1-0] 47.289422 s:
[IPU1-0] 47.289483 s: New data Recv = 39.97 fps
[IPU1-0] 47.289757 s:
[IPU1-0] 47.289818 s: Input Statistics,
[IPU1-0] 47.289879 s:
[IPU1-0] 47.289910 s: CH | In Recv | In Drop | In User Drop | In Process
[IPU1-0] 47.289971 s: | FPS | FPS | FPS | FPS
[IPU1-0] 47.290062 s: --------------------------------------------------
[IPU1-0] 47.290154 s: 0 | 20. 2 0. 0 0. 0 19.94
[IPU1-0] 47.290276 s:
[IPU1-0] 47.290306 s: Output Statistics,
[IPU1-0] 47.290367 s:
[IPU1-0] 47.290398 s: CH | Out | Out | Out Drop | Out User Drop
[IPU1-0] 47.290489 s: | ID | FPS | FPS | FPS
[IPU1-0] 47.290581 s: ---------------------------------------------
[IPU1-0] 47.290672 s: 0 | 0 19.94 0. 0 0. 0
[IPU1-0] 47.290794 s:
[IPU1-0] 47.290825 s: [ ALG_TIDL ] LATENCY,
[IPU1-0] 47.290886 s: ********************
[IPU1-0] 47.290947 s: Local Link Latency : Avg = 29841 us, Min = 29464 us, Max =
[IPU1-0] 47.291618 s: Source to Link Latency : Avg = 477137 us, Min = 376167 us, Max =
[IPU1-0] 47.291831 s:
[IPU1-0] 47.293204 s:
[IPU1-0] 47.293265 s: ### CPU [ DSP1], LinkID [ 0],
[IPU1-0] 47.293356 s:
[IPU1-0] 47.293387 s: [ IPC_OUT_0 ] Link Statistics,
[IPU1-0] 47.293478 s: ******************************
[IPU1-0] 47.293539 s:
[IPU1-0] 47.293600 s: Elapsed time = 13408 msec
[IPU1-0] 47.293692 s:
[IPU1-0] 47.293722 s: New data Recv = 20.6 fps
[IPU1-0] 47.293814 s: Release data Recv = 20.13 fps
[IPU1-0] 47.293905 s: Driver/Notify Cb = 120.7 fps
[IPU1-0] 47.293966 s:
[IPU1-0] 47.293997 s: Input Statistics,
[IPU1-0] 47.294058 s:
[IPU1-0] 47.294088 s: CH | In Recv | In Drop | In User Drop | In Process
[IPU1-0] 47.294180 s: | FPS | FPS | FPS | FPS
[IPU1-0] 47.294241 s: --------------------------------------------------
[IPU1-0] 47.294332 s: 0 | 20. 6 0. 0 0. 0 20. 6
[IPU1-0] 47.294454 s:
[IPU1-0] 47.294515 s: Output Statistics,
[IPU1-0] 47.294820 s:
[IPU1-0] 47.294881 s: CH | Out | Out | Out Drop | Out User Drop
[IPU1-0] 47.294942 s: | ID | FPS | FPS | FPS
[IPU1-0] 47.295034 s: ---------------------------------------------
[IPU1-0] 47.295095 s: 0 | 0 20. 6 0. 0 0. 0
[IPU1-0] 47.295217 s:
[IPU1-0] 47.295247 s: [ IPC_OUT_0 ] LATENCY,
[IPU1-0] 47.295339 s: ********************
[IPU1-0] 47.295369 s: Local Link Latency : Avg = 3 us, Min = 0 us, Max =
[IPU1-0] 47.295491 s: Source to Link Latency : Avg = 476889 us, Min = 376259 us, Max =
[IPU1-0] 47.295644 s:
[IPU1-0] 47.795705 s:
[IPU1-0] 47.795796 s: ### CPU [IPU1-0], LinkID [ 10],
[IPU1-0] 47.795857 s:
[IPU1-0] 47.795918 s: [ IPC_IN_0 ] Link Statistics,
[IPU1-0] 47.795979 s: ******************************
[IPU1-0] 47.796040 s:
[IPU1-0] 47.796071 s: Elapsed time = 13910 msec
[IPU1-0] 47.796132 s:
[IPU1-0] 47.796193 s: Get Full Buf Cb = 40.4 fps
[IPU1-0] 47.796254 s: Put Empty Buf Cb = 20.5 fps
[IPU1-0] 47.796346 s: Driver/Notify Cb = 19.98 fps
[IPU1-0] 47.796407 s:
[IPU1-0] 47.796468 s: Input Statistics,
[IPU1-0] 47.796498 s:
[IPU1-0] 47.796529 s: CH | In Recv | In Drop | In User Drop | In Process
[IPU1-0] 47.796651 s: | FPS | FPS | FPS | FPS
[IPU1-0] 47.796742 s: --------------------------------------------------
[IPU1-0] 47.796834 s: 0 | 20. 5 0. 0 0. 0 20. 5
[IPU1-0] 47.796956 s:
[IPU1-0] 47.796986 s: Output Statistics,
[IPU1-0] 47.797047 s:
[IPU1-0] 47.797078 s: CH | Out | Out | Out Drop | Out User Drop
[IPU1-0] 47.797169 s: | ID | FPS | FPS | FPS
[IPU1-0] 47.797230 s: ---------------------------------------------
[IPU1-0] 47.797322 s: 0 | 0 20. 5 0. 0 0. 0
[IPU1-0] 47.797444 s:
[IPU1-0] 47.797474 s: [ IPC_IN_0 ] LATENCY,
[IPU1-0] 47.797535 s: ********************
[IPU1-0] 47.797627 s: Local Link Latency : Avg = 19 us, Min = 0 us, Max =
[IPU1-0] 47.797749 s: Source to Link Latency : Avg = 477221 us, Min = 376411 us, Max =
[IPU1-0] 47.797871 s:
[IPU1-0] 47.797932 s: CPU [ IPU1-0], LinkID [ 38], Link Statistics not available !
[IPU1-0] 47.798115 s:
[IPU1-0] 47.798145 s: ### CPU [IPU1-0], LinkID [ 34],
[IPU1-0] 47.798237 s:
[IPU1-0] 47.800799 s: ### CPU [IPU1-0], LinkID [ 49],
[IPU1-0] 47.800890 s:
[IPU1-0] 47.800921 s: [ ALG_OBJECT_DRAW ] Link Statistics,
[IPU1-0] 47.801012 s: ******************************
[IPU1-0] 47.801073 s:
[IPU1-0] 47.801104 s: Elapsed time = 13915 msec
[IPU1-0] 47.801165 s:
[IPU1-0] 47.801226 s: New data Recv = 20.5 fps
[IPU1-0] 47.801287 s:
[IPU1-0] 47.801317 s: Input Statistics,
[IPU1-0] 47.801378 s:
[IPU1-0] 47.801409 s: CH | In Recv | In Drop | In User Drop | In Process
[IPU1-0] 47.801500 s: | FPS | FPS | FPS | FPS
[IPU1-0] 47.801744 s: --------------------------------------------------
[IPU1-0] 47.801836 s: 0 | 20. 5 0. 0 0. 0 20. 5
[IPU1-0] 47.801988 s:
[IPU1-0] 47.802019 s: Output Statistics,
[IPU1-0] 47.802080 s:
[IPU1-0] 47.802110 s: CH | Out | Out | Out Drop | Out User Drop
[IPU1-0] 47.802171 s: | ID | FPS | FPS | FPS
[IPU1-0] 47.802263 s: ---------------------------------------------
[IPU1-0] 47.802324 s: 0 | 0 20. 5 0. 0 0. 0
[IPU1-0] 47.802446 s:
[IPU1-0] 47.802476 s: [ ALG_OBJECT_DRAW ] LATENCY,
[IPU1-0] 47.802598 s: ********************
[IPU1-0] 47.802659 s: Local Link Latency : Avg = 1409 us, Min = 335 us, Max =
[IPU1-0] 47.802781 s: Source to Link Latency : Avg = 478923 us, Min = 377509 us, Max =
[IPU1-0] 47.802903 s:
[IPU1-0] 47.802934 s: CPU [ IPU1-0], LinkID [ 26], Link Statistics not available !
[IPU1-0] 47.803147 s:
[IPU1-0] 47.803178 s: ### CPU [IPU1-0], LinkID [ 73],
[IPU1-0] 47.803269 s:
[IPU1-0] 47.803300 s: [ DISPLAY ] Link Statistics,
[IPU1-0] 47.803361 s: ******************************
[IPU1-0] 47.803422 s:
[IPU1-0] 47.803483 s: Elapsed time = 13915 msec
[IPU1-0] 47.803544 s:
[IPU1-0] 47.803605 s: New data Recv = 19.97 fps
[IPU1-0] 47.803696 s: Driver/Notify Cb = 60.0 fps
[IPU1-0] 47.803757 s:
[IPU1-0] 47.803788 s: Input Statistics,
[IPU1-0] 47.803849 s:
[IPU1-0] 47.803879 s: CH | In Recv | In Drop | In User Drop | In Process
[IPU1-0] 47.803971 s: | FPS | FPS | FPS | FPS
[IPU1-0] 47.804032 s: --------------------------------------------------
[IPU1-0] 47.804123 s: 0 | 20. 5 0. 0 0. 0 20. 5
[IPU1-0] 47.804245 s:
[IPU1-0] 47.804306 s: [ DISPLAY ] LATENCY,
[IPU1-0] 47.804337 s: ********************
[IPU1-0] 47.804398 s: Local Link Latency : Avg = 45 us, Min = 30 us, Max =
[IPU1-0] 47.804520 s: Source to Link Latency : Avg = 479204 us, Min = 377753 us, Max =
[IPU1-0] 47.804855 s:
[IPU1-0] 47.804916 s: Display UnderFlow Count = 0
[IPU1-0] 47.804977 s:
[IPU1-0] 47.805130 s:
