TDA4VM: vision_apps init failed on 06_02's PSDK
Part Number: TDA4VM
Hi TI members:
I also meet the questions same as thread
root@j7-evm:~# source /opt/vision_apps/vision_apps_init.sh
root@j7-evm:~# APP_LOG: Mapping 0xb8000000 ...
APP_LOG: Mapped 0xb8000000 -> (nil) of size 262144 bytes
APP_LOG: ERROR: Unable to map memory @ 0xb8000000 of size 262144 bytes !!!
but my PSDKLA/PSDKRA are 06_02 version.
And I also try the prebuild image which on 06_02 PSDKLA and the image which build by myself,
but they all meet the same question.
I attached the boot logs.
Can you help to check is there any problem?
U-Boot SPL 2019.01-g350f3927b8 (Mar 11 2020 - 13:43:47 +0000)
SYSFW ABI: 2.9 (firmware rev 0x0013 '19.12.1-v2019.12a (Terrific Lla')
Trying to boot from MMC2
Loading Environment from MMC... *** Warning - No MMC card found, using default environment
Remoteproc 2 started successfully
** File not found /lib/firmware/j7-mcu-r5f0_0-fw **
Starting ATF on ARM64 core...
NOTICE:  BL31: v2.2(release):ti2019.05-rc1
NOTICE:  BL31: Built : 11:25:55, Mar 11 2020
I/TC:
I/TC: OP-TEE version: ti2019.05-rc1-dev (gcc version 8.3.0 (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36))) #1 Wed Mar 11 12:38:08 UTC 2020 aarch64
I/TC: Initialized
U-Boot SPL 2019.01-g350f3927b8 (Mar 11 2020 - 13:45:58 +0000)
Detected: J7X-BASE-CPB rev E3
Detected: J7X-VSC8514-ETH rev E2
U-Boot 2019.01-g350f3927b8 (Mar 11 2020 - 13:45:58 +0000)
SoC:   J721E PG 1.0
Model: Texas Instruments K3 J721E SoC
Board: J721EX-PM2-SOM rev E7
DRAM:  4 GiB
Flash: 0 Bytes
MMC:   sdhci@4f80000: 0, sdhci@4fb0000: 1
Loading Environment from MMC... OK
In:    serial@2800000
Out:   serial@2800000
Err:   serial@2800000
Net:   eth0: ethernet@046000000
Hit any key to stop autoboot:  0
switch to partitions #0, OK
mmc1 is current device
SD/MMC found on device 1
** Unable to read file boot.scr **
81 bytes read in 0 ms
Loaded env from uEnv.txt
Importing environment from mmc1 ...
12288860 bytes read in 259 ms (45.2 MiB/s)
Load Remote Processor 3 with data@addr=0x80080000 12288860 bytes: Success!
** File not found /lib/firmware/j7-main-r5f1_0-fw **
8965648 bytes read in 187 ms (45.7 MiB/s)
Load Remote Processor 6 with data@addr=0x80080000 8965648 bytes: Success!
8964660 bytes read in 187 ms (45.7 MiB/s)
Load Remote Processor 7 with data@addr=0x80080000 8964660 bytes: Success!
11907736 bytes read in 748 ms (15.2 MiB/s)
Load Remote Processor 8 with data@addr=0x80080000 11907736 bytes: Success!
13338632 bytes read in 282 ms (45.1 MiB/s)
99354 bytes read in 3 ms (31.6 MiB/s)
** File not found /boot/k3-j721e-auto-common.dtbo **
4250 bytes read in 1 ms (4.1 MiB/s)
## Flattened Device Tree blob at 82000000
   Booting using the fdt blob at 0x82000000
   Loading Device Tree to 00000000fdda3000, end 00000000fdebefff ... OK
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd080]
[    0.000000] Linux version 4.19.94-g5a23bc00e0 (oe-user@oe-host) (gcc version 8.3.0 (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36))) #1 SMP PREEMPT Wed Mar 11 06:54:55 UTC 2020
[    0.000000] Machine model: Texas Instruments K3 J721E SoC
[    0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '')
[    0.000000] bootconsole [ns16550a0] enabled
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a0000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node r5f-memory@a0100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a1000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node r5f-memory@a1100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a2000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node r5f-memory@a2100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a3000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a3000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a3100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node r5f-memory@a3100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a4000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a4000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a4100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node r5f-memory@a4100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a5000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a5000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a5100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node r5f-memory@a5100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a6000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node c66-dma-memory@a6000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a6100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node c66-memory@a6100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a7000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node c66-dma-memory@a7000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a7100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node c66-memory@a7100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a8000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node c71-dma-memory@a8000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a8100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node c71-memory@a8100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000ac000000, size 32 MiB
[    0.000000] OF: reserved mem: initialized node vision_apps-dma-memory@ab000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000ae000000, size 512 MiB
[    0.000000] OF: reserved mem: initialized node vision_apps_shared-memories@ad000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000ce000000, size 736 MiB
[    0.000000] OF: reserved mem: initialized node vision_apps-core-heap-memory@cd000000, compatible id shared-dma-pool
[    0.000000] cma: Failed to reserve 512 MiB
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: Trusted OS migration not required
[    0.000000] psci: SMC Calling Convention v1.1
[    0.000000] random: get_random_bytes called from start_kernel+0x94/0x3e4 with crng_init=0
[    0.000000] percpu: Embedded 2 pages/cpu s48536 r8192 d74344 u131072
[    0.000000] Detected PIPT I-cache on CPU0
[    0.000000] CPU features: enabling workaround for EL2 vector hardening
[    0.000000] Speculative Store Bypass Disable mitigation not required
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 49999
[    0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 mtdparts=47040000.spi.0:512k(ospi.tiboot3),2m(ospi.tispl),4m(ospi.u-boot),128k(ospi.env),128k(ospi.env.backup),1m(ospi.sysfw),-@8m(ospi.rootfs);47034000.hyperbus:512k(hbmc.tiboot3),2m(hbmc.tispl),4m(hbmc.u-boot),256k(hbmc.env),1m(hbmc.sysfw),-@8m(hbmc.rootfs) root=PARTUUID=34691810-02 rw rootfstype=ext4 rootwait
[    0.000000] Dentry cache hash table entries: 524288 (order: 6, 4194304 bytes)
[    0.000000] Inode-cache hash table entries: 262144 (order: 5, 2097152 bytes)
[    0.000000] software IO TLB: mapped [mem 0x9a800000-0x9e800000] (64MB)
[    0.000000] Memory: 2587008K/3203072K available (8510K kernel code, 738K rwdata, 3136K rodata, 576K init, 641K bss, 616064K reserved, 0K cma-reserved)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=2.
[    0.000000]  Tasks RCU enabled.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[    0.000000] GICv3: Distributor has no Range Selector support
[    0.000000] GICv3: no VLPI support, no direct LPI support
[    0.000000] ITS [mem 0x01820000-0x0182ffff]
[    0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
[    0.000000] ITS@0x0000000001820000: allocated 1048576 Devices @8c0800000 (flat, esz 8, psz 64K, shr 0)
[    0.000000] ITS: using cache flushing for cmd queue
[    0.000000] GIC: using LPI property table @0x00000008c00a0000
[    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001900000
[    0.000000] CPU0: using LPI pending table @0x00000008c00b0000
[    0.000000] GIC: using cache flushing for LPI property table
[    0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
[    0.000002] sched_clock: 56 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
[    0.008367] Console: colour dummy device 80x25
[    0.012927] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
[    0.023596] pid_max: default: 32768 minimum: 301
[    0.028342] Security Framework initialized
[    0.032549] Mount-cache hash table entries: 8192 (order: 0, 65536 bytes)
[    0.039406] Mountpoint-cache hash table entries: 8192 (order: 0, 65536 bytes)
[    0.070748] ASID allocator initialised with 32768 entries
[    0.084277] rcu: Hierarchical SRCU implementation.
[    0.097241] Platform MSI: gic-its@1820000 domain created
[    0.102877] PCI/MSI: /interconnect@100000/interrupt-controller@1800000/gic-its@1820000 domain created
[    0.120314] smp: Bringing up secondary CPUs ...
[    0.157231] Detected PIPT I-cache on CPU1
[    0.157254] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000
[    0.157283] CPU1: using LPI pending table @0x00000008c0310000
[    0.157311] CPU1: Booted secondary processor 0x0000000001 [0x411fd080]
[    0.157362] smp: Brought up 1 node, 2 CPUs
[    0.185202] SMP: Total of 2 processors activated.
[    0.190012] CPU features: detected: GIC system register CPU interface
[    0.196594] CPU features: detected: 32-bit EL0 Support
[    0.202094] CPU: All CPU(s) started at EL2
[    0.206282] alternatives: patching kernel code
[    0.211431] devtmpfs: initialized
[    0.219995] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.229963] futex hash table entries: 512 (order: -1, 32768 bytes)
[    0.236405] pinctrl core: initialized pinctrl subsystem
[    0.242145] NET: Registered protocol family 16
[    0.247040] vdso: 2 pages (1 code @ (____ptrval____), 1 data @ (____ptrval____))
[    0.254602] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.261661] DMA: preallocated 256 KiB pool for atomic allocations
[    0.275222] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.282077] HugeTLB registered 512 MiB page size, pre-allocated 0 pages
[    0.289565] cryptd: max_cpu_qlen set to 1000
[    0.294573] vsys_3v3: supplied by evm_12v0
[    0.298844] vsys_5v0: supplied by evm_12v0
[    0.303413] SCSI subsystem initialized
[    0.307475] media: Linux media interface: v0.10
[    0.312110] videodev: Linux video capture interface: v2.00
[    0.317723] pps_core: LinuxPPS API ver. 1 registered
[    0.322793] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.332129] PTP clock support registered
[    0.336139] EDAC MC: Ver: 3.0.0
[    0.340063] Advanced Linux Sound Architecture Driver Initialized.
[    0.346681] clocksource: Switched to clocksource arch_sys_counter
[    0.352991] VFS: Disk quotas dquot_6.6.0
[    0.357035] VFS: Dquot-cache hash table entries: 8192 (order 0, 65536 bytes)
[    0.366644] NET: Registered protocol family 2
[    0.371424] tcp_listen_portaddr_hash hash table entries: 4096 (order: 0, 65536 bytes)
[    0.379480] TCP established hash table entries: 32768 (order: 2, 262144 bytes)
[    0.386964] TCP bind hash table entries: 32768 (order: 3, 524288 bytes)
[    0.394218] TCP: Hash tables configured (established 32768 bind 32768)
[    0.400958] UDP hash table entries: 2048 (order: 0, 65536 bytes)
[    0.407147] UDP-Lite hash table entries: 2048 (order: 0, 65536 bytes)
[    0.413830] NET: Registered protocol family 1
[    0.418515] RPC: Registered named UNIX socket transport module.
[    0.424568] RPC: Registered udp transport module.
[    0.429371] RPC: Registered tcp transport module.
[    0.434173] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.441090] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[    0.450804] Initialise system trusted keyrings
[    0.455416] workingset: timestamp_bits=46 max_order=16 bucket_order=0
[    0.463555] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.469730] NFS: Registering the id_resolver key type
[    0.474903] Key type id_resolver registered
[    0.479176] Key type id_legacy registered
[    0.483273] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    0.490196] 9p: Installing v9fs 9p2000 file system support
[    0.497306] Key type asymmetric registered
[    0.501495] Asymmetric key parser 'x509' registered
[    0.506502] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[    0.514064] io scheduler noop registered
[    0.518070] io scheduler deadline registered
[    0.522477] io scheduler cfq registered (default)
[    0.527284] io scheduler mq-deadline registered
[    0.531910] io scheduler kyber registered
[    0.536935] pinctrl-single 4301c000.pinmux: 94 pins, size 376
[    0.543030] pinctrl-single 11c000.pinmux: 173 pins, size 692
[    0.549181] pinctrl-single a40000.timesync_router: 512 pins, size 2048
[    0.558369] ti-pat 31010000.pat: Found PAT Rev 1.0 with 16384 pages
[    0.564804] ti-pat 31010000.pat: Failed to create 31010000.pat debugfs directory
[    0.572508] ti-pat 31011000.pat: Found PAT Rev 1.0 with 16384 pages
[    0.578920] ti-pat 31011000.pat: Failed to create 31011000.pat debugfs directory
[    0.586564] ti-pat 31012000.pat: Found PAT Rev 1.0 with 16384 pages
[    0.592975] ti-pat 31012000.pat: Failed to create 31012000.pat debugfs directory
[    0.600623] ti-pat 31013000.pat: Found PAT Rev 1.0 with 2048 pages
[    0.606944] ti-pat 31013000.pat: Failed to create 31013000.pat debugfs directory
[    0.614586] ti-pat 31014000.pat: Found PAT Rev 1.0 with 2048 pages
[    0.620907] ti-pat 31014000.pat: Failed to create 31014000.pat debugfs directory
[    0.629838] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
[    0.637762] panel-simple dummy-panel: dummy-panel supply power not found, using dummy regulator
[    0.646697] panel-simple dummy-panel: Linked as a consumer to regulator.0
[    0.657351] brd: module loaded
[    0.663350] loop: module loaded
[    0.667853] libphy: Fixed MDIO Bus: probed
[    0.672205] tun: Universal TUN/TAP device driver, 1.6
[    0.677609] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[    0.685614] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[    0.691682] sky2: driver version 1.30
[    0.695995] VFIO - User Level meta-driver version: 0.3
[    0.701639] i2c /dev entries driver
[    0.705659] sdhci: Secure Digital Host Controller Interface driver
[    0.711976] sdhci: Copyright(c) Pierre Ossman
[    0.716629] sdhci-pltfm: SDHCI platform and OF driver helper
[    0.722873] ledtrig-cpu: registered to indicate activity on CPUs
[    0.789496] optee: probing for conduit method from DT.
[    0.794764] optee: revision 3.7 (5208e5c1)
[    0.794912] optee: initialized driver
[    0.803581] NET: Registered protocol family 17
[    0.808200] 9pnet: Installing 9P2000 support
[    0.812588] Key type dns_resolver registered
[    0.817168] registered taskstats version 1
[    0.821353] Loading compiled-in X.509 certificates
[    0.830701] ti-sci 44083000.dmsc: ABI: 2.9 (firmware rev 0x0013 '19.12.1-v2019.12a (Terrific Lla')
[    0.856093] random: fast init done
[    0.899586] omap_i2c 40b00000.i2c: bus 0 rev0.12 at 100 kHz
[    0.905533] omap_i2c 40b10000.i2c: bus 1 rev0.12 at 100 kHz
[    0.911481] omap_i2c 42120000.i2c: bus 2 rev0.12 at 100 kHz
[    0.917503] pca953x 3-0020: 3-0020 supply vcc not found, using dummy regulator
[    0.924914] pca953x 3-0020: Linked as a consumer to regulator.0
[    0.955248] pca953x 3-0022: 3-0022 supply vcc not found, using dummy regulator
[    0.962650] pca953x 3-0022: Linked as a consumer to regulator.0
[    0.969523] GPIO line 481 (MCASP/TRACE_MUX_S0) hogged as output/low
[    0.976246] GPIO line 482 (MCASP/TRACE_MUX_S1) hogged as output/high
[    0.982810] omap_i2c 2000000.i2c: bus 3 rev0.12 at 400 kHz
[    0.988734] omap_i2c 2020000.i2c: bus 4 rev0.12 at 100 kHz
[    0.994666] pca953x 5-0020: 5-0020 supply vcc not found, using dummy regulator
[    1.002073] pca953x 5-0020: Linked as a consumer to regulator.0
[    1.031350] GPIO line 464 (CODEC_RSTz) hogged as output/high
[    1.037255] omap_i2c 2030000.i2c: bus 5 rev0.12 at 400 kHz
[    1.043122] omap_i2c 2040000.i2c: bus 6 rev0.12 at 100 kHz
[    1.048966] omap_i2c 2050000.i2c: bus 7 rev0.12 at 100 kHz
[    1.063684] cdns-pcie-host d000000.pcie: missing "mem"
[    1.069309] cdns-pcie-host d000000.pcie: Linked as a consumer to phy-5000000.serdes.0
[    2.078686] cdns-pcie-host d000000.pcie: Phy link never came up
[    2.084738] cdns-pcie-host d000000.pcie: host bridge /interconnect@100000/pcie@2900000/pcie@d000000 ranges:
[    2.094709] cdns-pcie-host d000000.pcie:    IO 0x10001000..0x10010fff -> 0x10001000
[    2.102541] cdns-pcie-host d000000.pcie:   MEM 0x4000000000..0x407fffffff -> 0x00000000
[    2.110791] cdns-pcie-host d000000.pcie: PCI host bridge to bus 0000:00
[    2.117553] pci_bus 0000:00: root bus resource [bus 00-0f]
[    2.123159] pci_bus 0000:00: root bus resource [io  0x0000-0xffff] (bus address [0x10001000-0x10010fff])
[    2.132849] pci_bus 0000:00: root bus resource [mem 0x4000000000-0x407fffffff] (bus address [0x00000000-0x7fffffff])
[    2.143634] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x4 may corrupt adjacent RW1C bits
[    2.153504] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x4 may corrupt adjacent RW1C bits
[    2.163400] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x92 may corrupt adjacent RW1C bits
[    2.173361] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0xb2 may corrupt adjacent RW1C bits
[    2.183349] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x84 may corrupt adjacent RW1C bits
[    2.195268] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[    2.203451] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x3e may corrupt adjacent RW1C bits
[    2.213413] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x3e may corrupt adjacent RW1C bits
[    2.223372] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x3e may corrupt adjacent RW1C bits
[    2.233330] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x6 may corrupt adjacent RW1C bits
[    2.245108] pci_bus 0000:00: 1-byte config write to 0000:00:00.0 offset 0x1a may corrupt adjacent RW1C bits
[    2.255078] pci 0000:00:00.0: PCI bridge to [bus 01]
[    2.260583] cdns-pcie-host d800000.pcie: missing "mem"
[    2.266247] cdns-pcie-host d800000.pcie: Linked as a consumer to phy-5010000.serdes.1
[    3.275624] cdns-pcie-host d800000.pcie: Phy link never came up
[    3.281680] cdns-pcie-host d800000.pcie: host bridge /interconnect@100000/pcie@2910000/pcie@d800000 ranges:
[    3.291647] cdns-pcie-host d800000.pcie:    IO 0x18001000..0x18010fff -> 0x18001000
[    3.299477] cdns-pcie-host d800000.pcie:   MEM 0x4100000000..0x417fffffff -> 0x00000000
[    3.307713] cdns-pcie-host d800000.pcie: PCI host bridge to bus 0001:00
[    3.314474] pci_bus 0001:00: root bus resource [bus 00-0f]
[    3.320079] pci_bus 0001:00: root bus resource [io  0x10000-0x1ffff] (bus address [0x18001000-0x18010fff])
[    3.329948] pci_bus 0001:00: root bus resource [mem 0x4100000000-0x417fffffff] (bus address [0x00000000-0x7fffffff])
[    3.342639] pci 0001:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[    3.352748] pci 0001:00:00.0: PCI bridge to [bus 01]
[    3.358225] cdns-pcie-host e000000.pcie: missing "mem"
[    3.363822] cdns-pcie-host e000000.pcie: Linked as a consumer to phy-5020000.serdes.2
[    4.373198] cdns-pcie-host e000000.pcie: Phy link never came up
[    4.379250] cdns-pcie-host e000000.pcie: host bridge /interconnect@100000/pcie@2920000/pcie@e000000 ranges:
[    4.389218] cdns-pcie-host e000000.pcie:    IO 0x4400001000..0x4400010fff -> 0x00001000
[    4.397403] cdns-pcie-host e000000.pcie:   MEM 0x4400011000..0x4407ffffff -> 0x00011000
[    4.405640] cdns-pcie-host e000000.pcie: PCI host bridge to bus 0002:00
[    4.412402] pci_bus 0002:00: root bus resource [bus 00-0f]
[    4.418006] pci_bus 0002:00: root bus resource [io  0x20000-0x2ffff] (bus address [0x1000-0x10fff])
[    4.427253] pci_bus 0002:00: root bus resource [mem 0x4400011000-0x4407ffffff] (bus address [0x00011000-0x07ffffff])
[    4.439906] pci 0002:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[    4.450002] pci 0002:00:00.0: PCI bridge to [bus 01]
[    4.455550] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:235
[    4.465434] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled
[    4.472195] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66346100, num_proxies:64
[    4.479859] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[440,150] sci-dev-id:211
[    4.489998] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled
[    4.496759] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66346100, num_proxies:64
[    4.504382] omap8250 40a00000.serial: PM domain pd:149 will not be powered off
[    4.511924] 40a00000.serial: ttyS1 at MMIO 0x40a00000 (irq = 7, base_baud = 6000000) is a 8250
[    4.521043] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 18, base_baud = 3000000) is a 8250
[    4.529782] console [ttyS2] enabled
[    4.536817] bootconsole [ns16550a0] disabled
[    4.545727] 2810000.serial: ttyS3 at MMIO 0x2810000 (irq = 19, base_baud = 3000000) is a 8250
[    4.554527] 2840000.serial: ttyS6 at MMIO 0x2840000 (irq = 20, base_baud = 3000000) is a 8250
[    4.563253] arm-smmu-v3 36600000.smmu: ias 48-bit, oas 48-bit (features 0x00001faf)
[    4.571820] arm-smmu-v3 36600000.smmu: msi_domain absent - falling back to wired irqs
[    4.580604] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    4.587211] [drm] No driver support for vblank timestamp query.
[    4.594549] [drm] Initialized tidss 1.0.0 20180215 for 4a00000.dss on minor 0
[    4.654959] Console: switching to colour frame buffer device 240x67
[    4.677567] tidss 4a00000.dss: fb0: DRM emulated frame buffer device
[    4.688480] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vdd-hba-supply regulator, assuming enabled
[    4.698984] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vcc-supply regulator, assuming enabled
[    4.709136] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq-supply regulator, assuming enabled
[    4.719375] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq2-supply regulator, assuming enabled
[    4.730144] scsi host0: ufshcd
[    4.745339] cadence-qspi 47040000.spi: mt35xu512aba (65536 Kbytes)
[    4.751519] 7 cmdlinepart partitions found on MTD device 47040000.spi.0
[    4.758117] Creating 7 MTD partitions on "47040000.spi.0":
[    4.760043] cdns-ufshcd 4e84000.ufs: ufshcd_print_pwr_info:[RX, TX]: gear=[1, 1], lane[1, 1], pwr[SLOWAUTO_MODE, SLOWAUTO_MODE], rate = 0
[    4.763591] 0x000000000000-0x000000080000 : "ospi.tiboot3"
[    4.781668] 0x000000080000-0x000000280000 : "ospi.tispl"
[    4.787171] 0x000000280000-0x000000680000 : "ospi.u-boot"
[    4.792763] 0x000000680000-0x0000006a0000 : "ospi.env"
[    4.798117] 0x0000006a0000-0x0000006c0000 : "ospi.env.backup"
[    4.801743] cdns-ufshcd 4e84000.ufs: ufshcd_print_pwr_info:[RX, TX]: gear=[3, 3], lane[2, 2], pwr[FAST MODE, FAST MODE], rate = 2
[    4.815523] cdns-ufshcd 4e84000.ufs: ufshcd_find_max_sup_active_icc_level: Regulator capability was not set, actvIccLevel=0
[    4.818868] 0x0000006c0000-0x0000007c0000 : "ospi.sysfw"
[    4.826804] scsi 0:0:0:49488: Well-known LUN    TOSHIBA  THGAF8G8T23BAILB 0300 PQ: 0 ANSI: 6
[    4.832157] 0x000000800000-0x000004000000 : "ospi.rootfs"
[    4.845890] scsi 0:0:0:49476: Well-known LUN    TOSHIBA  THGAF8G8T23BAILB 0300 PQ: 0 ANSI: 6
[    4.854643] cdns-ufshcd 4e84000.ufs: ufshcd_scsi_add_wlus: BOOT WLUN not found
[    4.962771] cadence-qspi 47040000.spi: Cadence QSPI NOR probe failed -517
[    4.970388] cadence-qspi 47050000.spi: n25q512a (65536 Kbytes)
[    4.990777] cadence-qspi 47050000.spi: Cadence QSPI NOR probe failed -517
[    4.998103] am65-cpsw-nuss 46000000.ethernet: rx-flow-id-base is not set -22
[    5.005159] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2
[    5.016573] UDMA has not been proped
[    5.020151] am65-cpsw-nuss 46000000.ethernet: Failed to request tx dma channel -517
[    5.028634] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010a, freq:200000000, add_val:4 pps:0
[    5.037157] mmc0: Unknown controller version (4). You may experience problems.
[    5.044383] mmc0: CQHCI version 5.10
[    5.078672] mmc0: SDHCI controller on 4f80000.sdhci [4f80000.sdhci] using ADMA 64-bit
[    5.092939] vdd_mmc1: supplied by vsys_3v3
[    5.097689] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fc7100
[    5.104662] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fc7100
[    5.111615] omap-mailbox 31f82000.mailbox: omap mailbox rev 0x66fc7100
[    5.118487] omap-mailbox 31f83000.mailbox: omap mailbox rev 0x66fc7100
[    5.125363] omap-mailbox 31f84000.mailbox: omap mailbox rev 0x66fc7100
[    5.155455] mmc0: Command Queue Engine enabled
[    5.159901] mmc0: new HS400 MMC card at address 0001
[    5.165280] mmcblk0: mmc0:0001 S0J56X 14.8 GiB
[    5.170083] mmcblk0boot0: mmc0:0001 S0J56X partition 1 31.5 MiB
[    5.176308] mmcblk0boot1: mmc0:0001 S0J56X partition 2 31.5 MiB
[    5.182329] mmcblk0rpmb: mmc0:0001 S0J56X partition 3 4.00 MiB, chardev (242:0)
[    5.195502]  mmcblk0: p1
[    5.460402] ti-udma 285c0000.udmap: Channels: 24 (tchan: 48, echan: 0, rchan: 48, rflow: 96)
[    5.469996] ti-udma 31150000.udmap: Channels: 84 (tchan: 140, echan: 160, rchan: 140, rflow: 300)
[    5.482378] cadence-qspi 47040000.spi: mt35xu512aba (65536 Kbytes)
[    5.488563] 7 cmdlinepart partitions found on MTD device 47040000.spi.0
[    5.495163] Creating 7 MTD partitions on "47040000.spi.0":
[    5.500636] 0x000000000000-0x000000080000 : "ospi.tiboot3"
[    5.506436] 0x000000080000-0x000000280000 : "ospi.tispl"
[    5.511942] 0x000000280000-0x000000680000 : "ospi.u-boot"
[    5.517564] 0x000000680000-0x0000006a0000 : "ospi.env"
[    5.522885] 0x0000006a0000-0x0000006c0000 : "ospi.env.backup"
[    5.528815] 0x0000006c0000-0x0000007c0000 : "ospi.sysfw"
[    5.534308] 0x000000800000-0x000004000000 : "ospi.rootfs"
[    5.541952] cadence-qspi 47050000.spi: n25q512a (65536 Kbytes)
[    5.549734] am65-cpsw-nuss 46000000.ethernet: rx-flow-id-base is not set -22
[    5.556799] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2
[    5.574199] am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48
[    5.584637] pps pps0: new PPS source ptp1
[    5.588776] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010a, freq:500000000, add_val:1 pps:1
[    5.597720] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 0.4
[    5.604927] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
[    5.650688] am65-cpsw-nuss 46000000.ethernet: davinci mdio revision 9.7, bus freq 1000000
[    5.658848] libphy: 46000000.ethernet: probed
[    5.664593] sdhci-am654 4fb0000.sdhci: Linked as a consumer to regulator.4
[    5.671481] sdhci-am654 4fb0000.sdhci: Linked as a consumer to regulator.5
[    5.678370] mmc1: Unknown controller version (4). You may experience problems.
[    5.685603] mmc1: CQHCI version 5.10
[    5.719244] mmc1: SDHCI controller on 4fb0000.sdhci [4fb0000.sdhci] using ADMA 64-bit
[    5.735906] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[    5.742765] hctosys: unable to open rtc device (rtc0)
[    5.769391] ALSA device list:
[    5.772353]   No soundcards found.
[    5.776025] Waiting for root device PARTUUID=34691810-02...
[    7.074707] mmc1: new ultra high speed DDR50 SDHC card at address 59b4
[    7.081809] mmcblk1: mmc1:59b4 SD    28.9 GiB
[    7.092652]  mmcblk1: p1 p2
[    7.149303] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Opts: (null)
[    7.157410] VFS: Mounted root (ext4 filesystem) on device 179:98.
[    7.167928] devtmpfs: mounted
[    7.171024] Freeing unused kernel memory: 576K
[    7.175473] Run /sbin/init as init process
[    7.330634] systemd[1]: System time before build time, advancing clock.
[    7.377499] NET: Registered protocol family 10
[    7.382363] Segment Routing with IPv6
[    7.399806] systemd[1]: systemd 239 running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR +SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN2 -IDN -PCRE2 default-hierarchy=hybrid)
[    7.421287] systemd[1]: Detected architecture arm64.
Welcome to Arago 2019.11!
[    7.447224] systemd[1]: Set hostname to <j7-evm>.
[    7.463156] random: systemd: uninitialized urandom read (16 bytes read)
[    7.469780] systemd[1]: Initializing machine ID from random generator.
[    7.571301] systemd[1]: Configuration file /lib/systemd/system/local-fs.target is marked executable. Please remove executable permission bits. Proceeding anyway.
[    7.585718] systemd[1]: Configuration file /lib/systemd/system/local-fs.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    7.603345] systemd[1]: Configuration file /lib/systemd/system/swap.target is marked executable. Please remove executable permission bits. Proceeding anyway.
[    7.617415] systemd[1]: Configuration file /lib/systemd/system/swap.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    7.632993] systemd[1]: Configuration file /lib/systemd/system/umount.target is marked executable. Please remove executable permission bits. Proceeding anyway.
[    7.647236] systemd[1]: Configuration file /lib/systemd/system/umount.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    7.751249] random: systemd: uninitialized urandom read (16 bytes read)
[  OK  ] Reached target Swap.
[    7.770752] random: systemd: uninitialized urandom read (16 bytes read)
[  OK  ] Created slice system-getty.slice.
[  OK  ] Listening on Journal Socket (/dev/log).
[  OK  ] Listening on Network Service Netlink Socket.
[  OK  ] Reached target Remote File Systems.
[  OK  ] Listening on udev Kernel Socket.
[  OK  ] Listening on Process Core Dump Socket.
[  OK  ] Listening on initctl Compatibility Named Pipe.
[  OK  ] Started Forward Password Requests to Wall Directory Watch.
[  OK  ] Listening on Journal Socket.
         Starting Create list of required st…ce nodes for the current kernel...
         Starting Journal Service...
         Mounting Huge Pages File System...
         Starting Load Kernel Modules...
[    7.979965] cmemk: loading out-of-tree module taints kernel.
[  OK  ] Started Hardware RNG Entropy Gatherer Daemon.[    7.989868] CMEMK module: reference Linux version 4.19.94
[    8.000055] no physical memory specified
[    8.004006] cmemk initialized
         Mounting Temporary Directory (/tmp)...
[    8.015907] cryptodev: driver 1.9 loaded.
         Mounting Kernel Debug File System...
         Mounting POSIX Message Queue File System...
[  OK  ] Created slice User and Session Slice.
[  OK  ] Reached target Slices.
         Starting Remount Root and Kernel File Systems...
[  OK  ] Listening on udev Control Socket.
[    8.092350] EXT4-fs (mmcblk1p2): re-mounted. Opts: (null)
         Starting udev Coldplug all Devices...
[  OK  ] Created slice system-serial\x2dgetty.slice.
[  OK  ] Started Dispatch Password Requests to Console Directory Watch.
[  OK  ] Reached target Paths.
[  OK  ] Started Journal Service.
[  OK  ] Started Create list of required sta…vice nodes for the current kernel.
[  OK  ] Mounted Huge Pages File System.
[  OK  ] Started Load Kernel Modules.
[  OK  ] Mounted Temporary Directory (/tmp).
[  OK  ] Mounted Kernel Debug File System.
[  OK  ] Mounted POSIX Message Queue File System.
[  OK  ] Started Remount Root and Kernel File Systems.
         Starting Create System Users...
         Starting Rebuild Hardware Database...
         Mounting Kernel Configuration File System...
         Starting Apply Kernel Variables...
         Starting Flush Journal to Persistent Storage...
[  OK  ] Mounted Kernel Configuration File System.
[    8.385113] systemd-journald[145]: Received request to flush runtime journal from PID 1
[  OK  ] Started udev Coldplug all Devices.
[  OK  ] Started Apply Kernel Variables.
[  OK  ] Started Flush Journal to Persistent Storage.
[  OK  ] Started Create System Users.
         Starting Create Static Device Nodes in /dev...
[  OK  ] Started Create Static Device Nodes in /dev.
[  OK  ] Reached target Local File Systems (Pre).
         Mounting /var/volatile...
         Mounting /media/ram...
[  OK  ] Reached target Containers.
[  OK  ] Mounted /var/volatile.
[  OK  ] Mounted /media/ram.
[  OK  ] Reached target Local File Systems.
         Starting Create Volatile Files and Directories...
         Starting Rebuild Dynamic Linker Cache...
         Starting Rebuild Journal Catalog...
         Starting Load/Save Random Seed...
[  OK  ] Started Create Volatile Files and Directories.
[  OK  ] Started Load/Save Random Seed.
         Starting Update UTMP about System Boot/Shutdown...
         Starting Network Time Synchronization...
         Starting Run pending postinsts...
[  OK  ] Started Rebuild Journal Catalog.
[  OK  ] Started Update UTMP about System Boot/Shutdown.
[  OK  ] Started Network Time Synchronization.
[  OK  ] Reached target System Time Synchronized.
[  OK  ] Started Rebuild Hardware Database.
         Starting udev Kernel Device Manager...
[  OK  ] Started udev Kernel Device Manager.
         Starting Network Service...
[  OK  ] Started Network Service.
         Starting Network Name Resolution...
         Starting Wait for Network to be Configured...
[  OK  ] Started Network Name Resolution.
[  OK  ] Reached target Network.
[  OK  ] Reached target Host and Network Name Lookups.
[   10.035910] rti-wdt 2200000.rti: heartbeat 60 sec
[   10.051493] rti-wdt 2210000.rti: heartbeat 60 sec
[   10.131117] pcm3168a 5-0044: Linked as a consumer to regulator.2
[  OK  ] Found device /dev/ttyS2.
[   10.202839] pcm3168a 5-0044: Linked as a consumer to regulator.3
[   10.307195] img_enc 4200000.video-encoder: vxe_enc_probe: adding heap of type 1
[   10.315944] k3-dsp-rproc 4d80800000.dsp: assigned reserved memory node c66-dma-memory@a7000000
[   10.335555] pci-endpoint-test 0000:00:00.0: of_irq_parse_pci: failed with rc=-22
[   10.335965] img_enc 4200000.video-encoder: vxe_enc_probe: using heap 1 for internal alloc
[   10.349062] pci_generic_config_write32: 29 callbacks suppressed
[   10.349067] pci_bus 0000:00: 1-byte config write to 0000:00:00.0 offset 0x3c may corrupt adjacent RW1C bits
[   10.353356] k3-dsp-rproc 4d80800000.dsp: configured DSP for IPC-only mode
[   10.381022] pci-endpoint-test 0001:00:00.0: of_irq_parse_pci: failed with rc=-22
[   10.418763] pci_bus 0001:00: 1-byte config write to 0001:00:00.0 offset 0x3c may corrupt adjacent RW1C bits
[   10.434652] img_enc 4200000.video-encoder: encoder registered as /dev/video0
[   10.444569] remoteproc remoteproc0: 4d80800000.dsp is available
[   10.456226] pci-endpoint-test 0002:00:00.0: of_irq_parse_pci: failed with rc=-22
[   10.474773] pci_bus 0002:00: 1-byte config write to 0002:00:00.0 offset 0x3c may corrupt adjacent RW1C bits
[   10.480692] k3-dsp-rproc 4d81800000.dsp: assigned reserved memory node c66-dma-memory@a6000000
[  OK  ] Started Run pending postinsts.
[   10.501807] k3-dsp-rproc 4d81800000.dsp: configured DSP for IPC-only mode
[   10.514763] remoteproc remoteproc1: 4d81800000.dsp is available
[   10.526985] k3-dsp-rproc 64800000.dsp: assigned reserved memory node c71-dma-memory@a8000000
[   10.537996] k3-dsp-rproc 64800000.dsp: configured DSP for IPC-only mode
[   10.551073] remoteproc remoteproc2: 64800000.dsp is available
[  OK  ] Found device /dev/ttyS1.
[   10.740614] ntb_hw_epf 0000:00:00.0: of_irq_parse_pci: failed with rc=-22
[   10.754792] pci_bus 0000:00: 1-byte config write to 0000:00:00.0 offset 0x3c may corrupt adjacent RW1C bits
[   10.793642] ntb_hw_epf 0001:00:00.0: of_irq_parse_pci: failed with rc=-22
[   10.816463] pci_bus 0001:00: 1-byte config write to 0001:00:00.0 offset 0x3c may corrupt adjacent RW1C bits
[   10.829789] ntb_hw_epf 0002:00:00.0: of_irq_parse_pci: failed with rc=-22
[   10.839056] pci_bus 0002:00: 1-byte config write to 0002:00:00.0 offset 0x3c may corrupt adjacent RW1C bits
[   10.910668] TI DP83867 k3-cpsw-mdio:00: attached PHY driver [TI DP83867] (mii_bus:phy_addr=k3-cpsw-mdio:00, irq=POLL)
[   10.928183] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[   10.964553] k3_r5_rproc interconnect@100000:interconnect@28380000:r5fss@41000000: creating child devices for R5F cores
[   11.012436] platform 41000000.r5f: configured R5F for remoteproc mode
[   11.034810] platform 41000000.r5f: assigned reserved memory node r5f-dma-memory@a0000000
[   11.043070] remoteproc remoteproc0: powering up 4d80800000.dsp
[   11.048989] remoteproc remoteproc0: Booting fw image j7-c66_0-fw, size 8965648
[   11.058358] remoteproc remoteproc0: erroneous trace resource entry
[   11.070261] remoteproc remoteproc0: Failed to process resources: -22
[   11.072742] remoteproc remoteproc3: 41000000.r5f is available
[   11.089322] remoteproc remoteproc1: powering up 4d81800000.dsp
[   11.095691] remoteproc remoteproc1: Booting fw image j7-c66_1-fw, size 8964660
[   11.104478] remoteproc remoteproc3: Direct firmware load for j7-mcu-r5f0_0-fw failed with error -2
[   11.106859] remoteproc remoteproc1: erroneous trace resource entry
[   11.114995] remoteproc remoteproc3: powering up 41000000.r5f
[   11.126677] remoteproc remoteproc1: Failed to process resources: -22
[   11.127882] k3_r5_rproc interconnect@100000:r5fss@5c00000: creating child devices for R5F cores
[   11.142403] remoteproc remoteproc3: Direct firmware load for j7-mcu-r5f0_0-fw failed with error -2
[   11.151710] remoteproc remoteproc2: powering up 64800000.dsp
[   11.152146] remoteproc remoteproc3: request_firmware failed: -2
[   11.157790] remoteproc remoteproc2: Booting fw image j7-c71_0-fw, size 11907736
[   11.173651] platform 5c00000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1)
[   11.177222] remoteproc remoteproc2: erroneous trace resource entry
[   11.191686] platform 5c00000.r5f: configured R5F for IPC-only mode
[   11.198814] remoteproc remoteproc2: Failed to process resources: -22
[   11.199832] platform 5c00000.r5f: assigned reserved memory node r5f-dma-memory@a2000000
[   11.250900] remoteproc remoteproc4: 5c00000.r5f is available
[   11.273916] platform 5d00000.r5f: configured R5F for IPC-only mode
[   11.293085] platform 5d00000.r5f: assigned reserved memory node r5f-dma-memory@a3000000
[   11.309983] remoteproc remoteproc5: 5d00000.r5f is available
[   11.318472] k3_r5_rproc interconnect@100000:r5fss@5e00000: creating child devices for R5F cores
[   11.337042] remoteproc remoteproc4: powering up 5c00000.r5f
[   11.344424] platform 5e00000.r5f: configured R5F for remoteproc mode
[   11.346835] remoteproc remoteproc4: Booting fw image j7-main-r5f0_0-fw, size 1887056
[   11.353789] platform 5e00000.r5f: assigned reserved memory node r5f-dma-memory@a4000000
[   11.379004] remoteproc remoteproc6: 5e00000.r5f is available
[   11.398296] remoteproc remoteproc6: Direct firmware load for j7-main-r5f1_0-fw failed with error -2
[   11.411740] platform 5f00000.r5f: configured R5F for remoteproc mode
[   11.418187] remoteproc remoteproc6: powering up 5e00000.r5f
[   11.425116] remoteproc remoteproc6: Direct firmware load for j7-main-r5f1_0-fw failed with error -2
[   11.437381] remoteproc remoteproc6: request_firmware failed: -2
[   11.448121] platform 5f00000.r5f: assigned reserved memory node r5f-dma-memory@a5000000
[   11.464432] j721e-audio sound@0: pcm3168a-dac <-> 2ba0000.mcasp mapping ok
[   11.476647] remoteproc remoteproc7: 5f00000.r5f is available
[   11.485863] j721e-audio sound@0: pcm3168a-adc <-> 2ba0000.mcasp mapping ok
[   11.488284] remoteproc remoteproc7: Direct firmware load for j7-main-r5f1_1-fw failed with error -2
[   11.505366] remoteproc remoteproc7: powering up 5f00000.r5f
[   11.514323] remoteproc remoteproc7: Direct firmware load for j7-main-r5f1_1-fw failed with error -2
[   11.530182] remoteproc remoteproc7: request_firmware failed: -2
[   11.710554] remoteproc remoteproc5: powering up 5d00000.r5f
[   11.716757] remoteproc remoteproc5: Booting fw image j7-main-r5f0_1-fw, size 12288860
[   11.730749] remoteproc remoteproc5: erroneous trace resource entry
[   11.741325] remoteproc remoteproc5: Failed to process resources: -22
[  OK  ] Created slice system-systemd\x2dfsck.slice.
[   11.955972] am65-cpsw-nuss 46000000.ethernet eth0: Link is Down
[   12.053365] cdns-usb3 6000000.usb: DRD version v1 (ID: 0004024e, rev: 00000200)
[   12.069202] omap_rng 4e10000.trng: Random Number Generator ver. 241b34c
[   12.075928] random: crng init done
[   12.079377] random: 7 urandom warning(s) missed due to ratelimiting
[   12.163359] cdns-usb3 6400000.usb: DRD version v1 (ID: 0004024e, rev: 00000200)
[   12.212723] remoteproc remoteproc8: b034000.pru is available
[   12.228862] pru-rproc b034000.pru: PRU rproc node pru@b034000 probed successfully
[   12.236961] remoteproc remoteproc9: b004000.rtu is available
[   12.250134] pru-rproc b004000.rtu: PRU rproc node rtu@b004000 probed successfully
[   12.264256] remoteproc remoteproc10: b00a000.txpru is available
[   12.270989] pru-rproc b00a000.txpru: PRU rproc node txpru@b00a000 probed successfully
[   12.280024] remoteproc remoteproc11: b038000.pru is available
[   12.286225] pru-rproc b038000.pru: PRU rproc node pru@b038000 probed successfully
[  OK  ] Started Rebuild Dynamic Linker Cache.
         Starting Update is Completed...
[   12.312841] remoteproc remoteproc12: b006000.rtu is available
[  OK  ] Started Update is Completed.
[   12.337426] pru-rproc b006000.rtu: PRU rproc node rtu@b006000 probed successfully
[   12.350644] remoteproc remoteproc13: b00c000.txpru is available
[   12.360462] pru-rproc b00c000.txpru: PRU rproc node txpru@b00c000 probed successfully
[   12.381010] remoteproc remoteproc14: b134000.pru is available
[   12.394594] pru-rproc b134000.pru: PRU rproc node pru@b134000 probed successfully
[   12.407796] remoteproc remoteproc15: b104000.rtu is available
[   12.420494] pru-rproc b104000.rtu: PRU rproc node rtu@b104000 probed successfully
[   12.435142] remoteproc remoteproc16: b10a000.txpru is available
[   12.448226] pru-rproc b10a000.txpru: PRU rproc node txpru@b10a000 probed successfully
[   12.460359] remoteproc remoteproc17: b138000.pru is available
[   12.469014] pru-rproc b138000.pru: PRU rproc node pru@b138000 probed successfully
[   12.483290] remoteproc remoteproc18: b106000.rtu is available
[   12.493492] pru-rproc b106000.rtu: PRU rproc node rtu@b106000 probed successfully
[   12.509435] remoteproc remoteproc19: b10c000.txpru is available
[   12.517936] pru-rproc b10c000.txpru: PRU rproc node txpru@b10c000 probed successfully
[   12.623150] usbcore: registered new interface driver usbfs
[   12.636977] usbcore: registered new interface driver hub
[   12.651035] usbcore: registered new device driver usb
[  OK  ] Found device /dev/mmcblk0p1.
[   12.694840] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller
         Starting File System Check on /dev/mmcblk0p1...
[   12.715552] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 1
[   12.723976] xhci-hcd xhci-hcd.2.auto: hcc params 0x200073c9 hci version 0x100 quirks 0x0000000000010010
[   12.736973] xhci-hcd xhci-hcd.2.auto: irq 321, io mem 0x06410000
[   12.743660] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[   12.752224] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   12.759988] usb usb1: Product: xHCI Host Controller
[   12.765492] usb usb1: Manufacturer: Linux 4.19.94-g5a23bc00e0 xhci-hcd
[   12.772821] usb usb1: SerialNumber: xhci-hcd.2.auto
[   12.780475] hub 1-0:1.0: USB hub found
[   12.784896] hub 1-0:1.0: 1 port detected
[   12.790168] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller
[   12.797284] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 2
[   12.805620] xhci-hcd xhci-hcd.2.auto: Host supports USB 3.0 SuperSpeed
[   12.816329] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[   12.830528] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 4.19
[   12.839329] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   12.847126] usb usb2: Product: xHCI Host Controller
[   12.852571] usb usb2: Manufacturer: Linux 4.19.94-g5a23bc00e0 xhci-hcd
[  OK  ] Started File System Check on /dev/mmcblk0p1.[   12.861597] usb usb2: SerialNumber: xhci-hcd.2.auto
         Mounting /run/media/mmcblk0p1...
[   12.879457] hub 2-0:1.0: USB hub found
[   12.885012] hub 2-0:1.0: 1 port detected
[   12.918858] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[  OK  ] Mounted /run/media/mmcblk0p1.
[  OK  ] Found device /dev/mmcblk1p1.
         Starting File System Check on /dev/mmcblk1p1...
[   13.122741] usb 1-1: new high-speed USB device number 2 using xhci-hcd
[  OK  ] Reached target System Initialization.
         Starting Reboot and dump vmcore via kexec...
[  OK  ] Started Daily Cleanup of Temporary Directories.
[  OK  ] Started Daily rotation of log files.
[  OK  ] Reached target Timers.
[  OK  ] Listening on D-Bus System Message Bus Socket.
[  OK  ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
[  OK  ] Listening on dropbear.socket.
[  OK  ] Listening on RPCbind Server Activation Socket.
[  OK  ] Reached target Sockets.
[  OK  ] Reached target Basic System.
[  OK  ] Started D-Bus System Message Bus.
         Starting Permit User Sessions...
[  OK  ] Started irqbalance daemon.
[  OK  ] Started Periodic Command Scheduler.
         Starting Print notice about GPLv3 packages...
[  OK  ] Started TEE Supplicant.
[   13.275680] usb 1-1: New USB device found, idVendor=0451, idProduct=8142, bcdDevice= 1.00
         [   13.285938] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=1
Starting Save/Restore Sound Card State...
         Starting Login Service...
[  OK  ] Started Job spooling tools.
[   13.303530] usb 1-1: SerialNumber: BD0100897885
         Starting Avahi mDNS/DNS-SD Stack...
         Starting rc.pvr.service...
         Starting RPC Bind Service...
[   13.334660] hub 1-1:1.0: USB hub found
[   13.338627] hub 1-1:1.0: 4 ports detected
[  OK  ] Started File System Check on /dev/mmcblk1p1.
[  OK  ] Started Reboot and dump vmcore via kexec.
[  OK  ] Started Permit User Sessions.
[  OK  ] Started Save/Restore Sound Card State.
[  OK  ] Started RPC Bind Service.
[  OK  ] Started NFS status monitor for NFSv2/3 locking..
[  OK  ] Reached target Sound Card.
[  OK  ] Started Getty on tty1.
[  OK  ] Started Serial Getty on ttyS1.
[  OK  ] Started Serial Getty on ttyS2.
[  OK  ] Reached target Login Prompts.
         Starting Synchronize System and HW clocks...
         Mounting /run/media/mmcblk1p1...
[FAILED] Failed to start Synchronize System and HW clocks.
See 'systemctl status sync-clocks.service' for details.
[  OK  ] Started Avahi mDNS/DNS-SD Stack.
[  OK  ] Started Login Service.
[   13.492832] pvrsrvkm 4e20000000.gpu: Linked as a consumer to genpd:0:4e20000000.gpu
[   13.500820] pvrsrvkm 4e20000000.gpu: Linked as a consumer to genpd:1:4e20000000.gpu
[   13.508656] PVR_K:  939: Read BVNC 22.104.208.318 from HW device registers
[   13.515566] PVR_K:  939: RGX Device initialised with BVNC 22.104.208.318
[   13.522662] [drm] Initialized pvr 1.10.5371573 20170530 for 4e20000000.gpu on minor 1
[  OK  ] Mounted /run/media/mmcblk1p1.
[  OK  ] Started rc.pvr.service.
         Starting weston.service...
[  OK  ] Started weston.service.
         Starting DEMO...
         Starting telnetd.service...
[  OK  ] Started DEMO.
[  OK  ] Started telnetd.service.
         Starting thttpd.service...
[  OK  ] Started thttpd.service.
NOTICE: This file system contains the following GPLv3 packages:
        autoconf
        bash-dev
        bash
        bc
        binutils
        cifs-utils
        cpio
        cpp-symlinks
        cpp
        dosfstools
        elfutils
        g++-symlinks
        g++
        gawk
        gcc-symlinks
        gcc
        gdb
        gdbserver
        gettext
        glmark2
        gstreamer1.0-libav
        gzip
        libbfd
        libcairo-perf-utils
        libdw1
        libelf1
        libgdbm-compat4
        libgdbm-dev
        libgdbm6
        libgettextlib
        libgettextsrc
        libgmp10
        libidn2-0
        libmpc3
        libmpfr6
        libreadline-dev
        libreadline7
        libunistring2
        m4-dev
        m4
        make
        nettle
        parted
        which
If you do not wish to distribute GPLv3 components please remove
the above packages prior to distribution.  This can be done using
the opkg remove command.  i.e.:
    opkg remove <package>
Where <package> is the name printed in the list above
NOTE: If the package is a dependency of another package you
      will be notified of the dependent packages.  You should
      use the --force-removal-of-dependent-packages option to
      also remove the dependent packages as well
[  OK  ] Started Print notice about GPLv3 packages.
 _____                    _____           _         _
|  _  |___ ___ ___ ___   |  _  |___ ___  |_|___ ___| |_
|     |  _| .'| . | . |  |   __|  _| . | | | -_|  _|  _|
|__|__|_| |__,|_  |___|  |__|  |_| |___|_| |___|___|_|
              |___|                    |___|
Arago Project http://arago-project.org j7-evm ttyS2
Arago 2019.11 j7-evm ttyS2
j7-evm login: root
root@j7-evm:~#
root@j7-evm:~#
root@j7-evm:~#
root@j7-evm:~# cd /opt/vision_apps/
root@j7-evm:/opt/vision_apps# source ./vision_apps_init.sh
root@j7-evm:/opt/vision_apps# APP_LOG: Mapping 0xb8000000 ...
U-Boot SPL 2019.01-g350f3927b8 (Feb 17 2020 - 09:46:23 +0000)
NOTICE:  BL31: Built : 09:32:00, Feb 17 2020
I/TC:
I/TC: OP-TEE version: ti2019.05-rc1-dev (gcc version 8.3.0 (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36))) #1 Mon Feb 17 09:40:16 UTC 2020 aarch64
I/TC: Initialized
U-Boot SPL 2019.01-g350f3927b8 (Feb 17 2020 - 09:48:06 +0000)
U-Boot 2019.01-g350f3927b8 (Feb 17 2020 - 09:48:06 +0000)
SoC:   J721E PG 1.0
DRAM:  4 GiB
Flash: 0 Bytes
In:    serial@2800000
Out:   serial@2800000
Err:   serial@2800000
81 bytes read in 1 ms (79.1 KiB/s)
12288860 bytes read in 260 ms (45.1 MiB/s)
11907736 bytes read in 732 ms (15.5 MiB/s)
99354 bytes read in 2 ms (47.4 MiB/s)
Starting kernel ...
[    0.000000] Linux version 4.19.94-g5a23bc00e0 (oe-user@oe-host) (gcc version 8.3.0 (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36))) #1 SMP PREEMPT Mon Feb 17 09:01:06 UTC 2020
[    0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 mtdparts=47040000.spi.0:512k(ospi.tiboot3),2m(ospi.tispl),4m(ospi.u-boot),128k(ospi.env),128k(ospi.env.backup),1m(ospi.sysfw),-@8m(ospi.rootfs);47034000.hyperbus:512k(hbmc.tiboot3),2m(hbmc.tispl),4m(hbmc.u-boot),256k(hbmc.env),1m(hbmc.sysfw),-@8m(hbmc.rootfs) root=PARTUUID=cf782362-02 rw rootfstype=ext4 rootwait
[    0.008397] Console: colour dummy device 80x25
[    0.012957] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
[    0.023626] pid_max: default: 32768 minimum: 301
[    0.028369] Security Framework initialized
[    0.032576] Mount-cache hash table entries: 8192 (order: 0, 65536 bytes)
[    0.039433] Mountpoint-cache hash table entries: 8192 (order: 0, 65536 bytes)
[    0.070772] ASID allocator initialised with 32768 entries
[    0.084299] rcu: Hierarchical SRCU implementation.
[    0.097265] Platform MSI: gic-its@1820000 domain created
[    0.102907] PCI/MSI: /interconnect@100000/interrupt-controller@1800000/gic-its@1820000 domain created
[    0.120342] smp: Bringing up secondary CPUs ...
[    0.157256] Detected PIPT I-cache on CPU1
[    0.157278] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000
[    0.157307] CPU1: using LPI pending table @0x00000008c0310000
[    0.157336] CPU1: Booted secondary processor 0x0000000001 [0x411fd080]
[    0.157388] smp: Brought up 1 node, 2 CPUs
[    0.185229] SMP: Total of 2 processors activated.
[    0.190040] CPU features: detected: GIC system register CPU interface
[    0.196622] CPU features: detected: 32-bit EL0 Support
[    0.202120] CPU: All CPU(s) started at EL2
[    0.206308] alternatives: patching kernel code
[    0.211425] devtmpfs: initialized
[    0.219973] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.229943] futex hash table entries: 512 (order: -1, 32768 bytes)
[    0.236386] pinctrl core: initialized pinctrl subsystem
[    0.242130] NET: Registered protocol family 16
[    0.247033] vdso: 2 pages (1 code @ (____ptrval____), 1 data @ (____ptrval____))
[    0.254596] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.261651] DMA: preallocated 256 KiB pool for atomic allocations
[    0.275267] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.282124] HugeTLB registered 512 MiB page size, pre-allocated 0 pages
[    0.289592] cryptd: max_cpu_qlen set to 1000
[    0.294592] vsys_3v3: supplied by evm_12v0
[    0.298866] vsys_5v0: supplied by evm_12v0
[    0.303429] SCSI subsystem initialized
[    0.307493] media: Linux media interface: v0.10
[    0.312128] videodev: Linux video capture interface: v2.00
[    0.317741] pps_core: LinuxPPS API ver. 1 registered
[    0.322811] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.332147] PTP clock support registered
[    0.336157] EDAC MC: Ver: 3.0.0
[    0.340085] Advanced Linux Sound Architecture Driver Initialized.
[    0.346706] clocksource: Switched to clocksource arch_sys_counter
[    0.353022] VFS: Disk quotas dquot_6.6.0
[    0.357067] VFS: Dquot-cache hash table entries: 8192 (order 0, 65536 bytes)
[    0.366660] NET: Registered protocol family 2
[    0.371429] tcp_listen_portaddr_hash hash table entries: 4096 (order: 0, 65536 bytes)
[    0.379484] TCP established hash table entries: 32768 (order: 2, 262144 bytes)
[    0.386967] TCP bind hash table entries: 32768 (order: 3, 524288 bytes)
[    0.394225] TCP: Hash tables configured (established 32768 bind 32768)
[    0.400957] UDP hash table entries: 2048 (order: 0, 65536 bytes)
[    0.407141] UDP-Lite hash table entries: 2048 (order: 0, 65536 bytes)
[    0.413821] NET: Registered protocol family 1
[    0.418498] RPC: Registered named UNIX socket transport module.
[    0.424551] RPC: Registered udp transport module.
[    0.429354] RPC: Registered tcp transport module.
[    0.434157] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.441087] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[    0.450805] Initialise system trusted keyrings
[    0.455417] workingset: timestamp_bits=46 max_order=16 bucket_order=0
[    0.463557] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.469738] NFS: Registering the id_resolver key type
[    0.474910] Key type id_resolver registered
[    0.479182] Key type id_legacy registered
[    0.483279] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    0.490202] 9p: Installing v9fs 9p2000 file system support
[    0.497328] Key type asymmetric registered
[    0.501518] Asymmetric key parser 'x509' registered
[    0.506530] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[    0.514091] io scheduler noop registered
[    0.518097] io scheduler deadline registered
[    0.522504] io scheduler cfq registered (default)
[    0.527311] io scheduler mq-deadline registered
[    0.531938] io scheduler kyber registered
[    0.536923] pinctrl-single 4301c000.pinmux: 94 pins, size 376
[    0.543016] pinctrl-single 11c000.pinmux: 173 pins, size 692
[    0.549163] pinctrl-single a40000.timesync_router: 512 pins, size 2048
[    0.558366] ti-pat 31010000.pat: Found PAT Rev 1.0 with 16384 pages
[    0.564801] ti-pat 31010000.pat: Failed to create 31010000.pat debugfs directory
[    0.572504] ti-pat 31011000.pat: Found PAT Rev 1.0 with 16384 pages
[    0.578916] ti-pat 31011000.pat: Failed to create 31011000.pat debugfs directory
[    0.600622] ti-pat 31013000.pat: Found PAT Rev 1.0 with 2048 pages
[    0.614584] ti-pat 31014000.pat: Found PAT Rev 1.0 with 2048 pages
[    0.620906] ti-pat 31014000.pat: Failed to create 31014000.pat debugfs directory
[    0.629855] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
[    0.637827] panel-simple dummy-panel: dummy-panel supply power not found, using dummy regulator
[    0.646756] panel-simple dummy-panel: Linked as a consumer to regulator.0
[    0.657483] brd: module loaded
[    0.663509] loop: module loaded
[    0.668034] libphy: Fixed MDIO Bus: probed
[    0.672394] tun: Universal TUN/TAP device driver, 1.6
[    0.677820] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[    0.685826] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[    0.691893] sky2: driver version 1.30
[    0.696233] VFIO - User Level meta-driver version: 0.3
[    0.701859] i2c /dev entries driver
[    0.705870] sdhci: Secure Digital Host Controller Interface driver
[    0.712187] sdhci: Copyright(c) Pierre Ossman
[    0.716837] sdhci-pltfm: SDHCI platform and OF driver helper
[    0.723094] ledtrig-cpu: registered to indicate activity on CPUs
[    0.789699] optee: probing for conduit method from DT.
[    0.794965] optee: revision 3.7 (5208e5c1)
[    0.795120] optee: initialized driver
[    0.803789] NET: Registered protocol family 17
[    0.808407] 9pnet: Installing 9P2000 support
[    0.812795] Key type dns_resolver registered
[    0.817400] registered taskstats version 1
[    0.821584] Loading compiled-in X.509 certificates
[    0.830839] ti-sci 44083000.dmsc: ABI: 2.9 (firmware rev 0x0013 '19.12.1-v2019.12a (Terrific Lla')
[    0.856239] random: fast init done
[    0.899644] omap_i2c 40b00000.i2c: bus 0 rev0.12 at 100 kHz
[    0.905595] omap_i2c 40b10000.i2c: bus 1 rev0.12 at 100 kHz
[    0.911539] omap_i2c 42120000.i2c: bus 2 rev0.12 at 100 kHz
[    0.917554] pca953x 3-0020: 3-0020 supply vcc not found, using dummy regulator
[    0.924967] pca953x 3-0020: Linked as a consumer to regulator.0
[    0.955272] pca953x 3-0022: 3-0022 supply vcc not found, using dummy regulator
[    0.962673] pca953x 3-0022: Linked as a consumer to regulator.0
[    0.969545] GPIO line 481 (MCASP/TRACE_MUX_S0) hogged as output/low
[    0.976268] GPIO line 482 (MCASP/TRACE_MUX_S1) hogged as output/high
[    0.982832] omap_i2c 2000000.i2c: bus 3 rev0.12 at 400 kHz
[    0.988758] omap_i2c 2020000.i2c: bus 4 rev0.12 at 100 kHz
[    0.994708] pca953x 5-0020: 5-0020 supply vcc not found, using dummy regulator
[    1.002110] pca953x 5-0020: Linked as a consumer to regulator.0
[    1.031371] GPIO line 464 (CODEC_RSTz) hogged as output/high
[    1.037277] omap_i2c 2030000.i2c: bus 5 rev0.12 at 400 kHz
[    1.043147] omap_i2c 2040000.i2c: bus 6 rev0.12 at 100 kHz
[    1.048989] omap_i2c 2050000.i2c: bus 7 rev0.12 at 100 kHz
[    1.063660] cdns-pcie-host d000000.pcie: missing "mem"
[    1.069290] cdns-pcie-host d000000.pcie: Linked as a consumer to phy-5000000.serdes.0
[    2.078667] cdns-pcie-host d000000.pcie: Phy link never came up
[    2.084722] cdns-pcie-host d000000.pcie: host bridge /interconnect@100000/pcie@2900000/pcie@d000000 ranges:
[    2.094691] cdns-pcie-host d000000.pcie:    IO 0x10001000..0x10010fff -> 0x10001000
[    2.102522] cdns-pcie-host d000000.pcie:   MEM 0x4000000000..0x407fffffff -> 0x00000000
[    2.110776] cdns-pcie-host d000000.pcie: PCI host bridge to bus 0000:00
[    2.117538] pci_bus 0000:00: root bus resource [bus 00-0f]
[    2.123143] pci_bus 0000:00: root bus resource [io  0x0000-0xffff] (bus address [0x10001000-0x10010fff])
[    2.132834] pci_bus 0000:00: root bus resource [mem 0x4000000000-0x407fffffff] (bus address [0x00000000-0x7fffffff])
[    2.143619] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x4 may corrupt adjacent RW1C bits
[    2.153490] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x4 may corrupt adjacent RW1C bits
[    2.163385] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x92 may corrupt adjacent RW1C bits
[    2.173346] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0xb2 may corrupt adjacent RW1C bits
[    2.183336] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x84 may corrupt adjacent RW1C bits
[    2.195189] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[    2.203372] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x3e may corrupt adjacent RW1C bits
[    2.213331] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x3e may corrupt adjacent RW1C bits
[    2.223290] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x3e may corrupt adjacent RW1C bits
[    2.233249] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x6 may corrupt adjacent RW1C bits
[    2.244803] pci_bus 0000:00: 1-byte config write to 0000:00:00.0 offset 0x1a may corrupt adjacent RW1C bits
[    2.254773] pci 0000:00:00.0: PCI bridge to [bus 01]
[    2.260276] cdns-pcie-host d800000.pcie: missing "mem"
[    2.265938] cdns-pcie-host d800000.pcie: Linked as a consumer to phy-5010000.serdes.1
[    3.275315] cdns-pcie-host d800000.pcie: Phy link never came up
[    3.281370] cdns-pcie-host d800000.pcie: host bridge /interconnect@100000/pcie@2910000/pcie@d800000 ranges:
[    3.291337] cdns-pcie-host d800000.pcie:    IO 0x18001000..0x18010fff -> 0x18001000
[    3.299167] cdns-pcie-host d800000.pcie:   MEM 0x4100000000..0x417fffffff -> 0x00000000
[    3.307403] cdns-pcie-host d800000.pcie: PCI host bridge to bus 0001:00
[    3.314164] pci_bus 0001:00: root bus resource [bus 00-0f]
[    3.319769] pci_bus 0001:00: root bus resource [io  0x10000-0x1ffff] (bus address [0x18001000-0x18010fff])
[    3.329638] pci_bus 0001:00: root bus resource [mem 0x4100000000-0x417fffffff] (bus address [0x00000000-0x7fffffff])
[    3.342264] pci 0001:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[    3.352148] pci 0001:00:00.0: PCI bridge to [bus 01]
[    3.357628] cdns-pcie-host e000000.pcie: missing "mem"
[    3.363226] cdns-pcie-host e000000.pcie: Linked as a consumer to phy-5020000.serdes.2
[    4.372602] cdns-pcie-host e000000.pcie: Phy link never came up
[    4.378656] cdns-pcie-host e000000.pcie: host bridge /interconnect@100000/pcie@2920000/pcie@e000000 ranges:
[    4.388623] cdns-pcie-host e000000.pcie:    IO 0x4400001000..0x4400010fff -> 0x00001000
[    4.396809] cdns-pcie-host e000000.pcie:   MEM 0x4400011000..0x4407ffffff -> 0x00011000
[    4.405045] cdns-pcie-host e000000.pcie: PCI host bridge to bus 0002:00
[    4.411806] pci_bus 0002:00: root bus resource [bus 00-0f]
[    4.417411] pci_bus 0002:00: root bus resource [io  0x20000-0x2ffff] (bus address [0x1000-0x10fff])
[    4.426658] pci_bus 0002:00: root bus resource [mem 0x4400011000-0x4407ffffff] (bus address [0x00011000-0x07ffffff])
[    4.439248] pci 0002:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[    4.449118] pci 0002:00:00.0: PCI bridge to [bus 01]
[    4.454656] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:235
[    4.464539] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled
[    4.471299] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66346100, num_proxies:64
[    4.478965] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[440,150] sci-dev-id:211
[    4.489105] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled
[    4.495867] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66346100, num_proxies:64
[    4.503492] omap8250 40a00000.serial: PM domain pd:149 will not be powered off
[    4.511036] 40a00000.serial: ttyS1 at MMIO 0x40a00000 (irq = 7, base_baud = 6000000) is a 8250
[    4.520159] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 18, base_baud = 3000000) is a 8250
[    4.528898] console [ttyS2] enabled
[    4.535932] bootconsole [ns16550a0] disabled
[    4.544841] 2810000.serial: ttyS3 at MMIO 0x2810000 (irq = 19, base_baud = 3000000) is a 8250
[    4.553643] 2840000.serial: ttyS6 at MMIO 0x2840000 (irq = 20, base_baud = 3000000) is a 8250
[    4.562363] arm-smmu-v3 36600000.smmu: ias 48-bit, oas 48-bit (features 0x00001faf)
[    4.570947] arm-smmu-v3 36600000.smmu: msi_domain absent - falling back to wired irqs
[    4.579725] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    4.586340] [drm] No driver support for vblank timestamp query.
[    4.593678] [drm] Initialized tidss 1.0.0 20180215 for 4a00000.dss on minor 0
[    4.654074] Console: switching to colour frame buffer device 240x67
[    4.676695] tidss 4a00000.dss: fb0: DRM emulated frame buffer device
[    4.687608] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vdd-hba-supply regulator, assuming enabled
[    4.698115] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vcc-supply regulator, assuming enabled
[    4.708267] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq-supply regulator, assuming enabled
[    4.718504] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq2-supply regulator, assuming enabled
[    4.729279] scsi host0: ufshcd
[    4.745357] cadence-qspi 47040000.spi: mt35xu512aba (65536 Kbytes)
[    4.751541] 7 cmdlinepart partitions found on MTD device 47040000.spi.0
[    4.758140] Creating 7 MTD partitions on "47040000.spi.0":
[    4.760059] cdns-ufshcd 4e84000.ufs: ufshcd_print_pwr_info:[RX, TX]: gear=[1, 1], lane[1, 1], pwr[SLOWAUTO_MODE, SLOWAUTO_MODE], rate = 0
[    4.763613] 0x000000000000-0x000000080000 : "ospi.tiboot3"
[    4.781686] 0x000000080000-0x000000280000 : "ospi.tispl"
[    4.787187] 0x000000280000-0x000000680000 : "ospi.u-boot"
[    4.792775] 0x000000680000-0x0000006a0000 : "ospi.env"
[    4.798127] 0x0000006a0000-0x0000006c0000 : "ospi.env.backup"
[    4.801755] cdns-ufshcd 4e84000.ufs: ufshcd_print_pwr_info:[RX, TX]: gear=[3, 3], lane[2, 2], pwr[FAST MODE, FAST MODE], rate = 2
[    4.815532] cdns-ufshcd 4e84000.ufs: ufshcd_find_max_sup_active_icc_level: Regulator capability was not set, actvIccLevel=0
[    4.818894] 0x0000006c0000-0x0000007c0000 : "ospi.sysfw"
[    4.826812] scsi 0:0:0:49488: Well-known LUN    TOSHIBA  THGAF8G8T23BAILB 0300 PQ: 0 ANSI: 6
[    4.832160] 0x000000800000-0x000004000000 : "ospi.rootfs"
[    4.845896] scsi 0:0:0:49476: Well-known LUN    TOSHIBA  THGAF8G8T23BAILB 0300 PQ: 0 ANSI: 6
[    4.854654] cdns-ufshcd 4e84000.ufs: ufshcd_scsi_add_wlus: BOOT WLUN not found
[    4.966798] cadence-qspi 47040000.spi: Cadence QSPI NOR probe failed -517
[    4.974395] cadence-qspi 47050000.spi: n25q512a (65536 Kbytes)
[    4.994792] cadence-qspi 47050000.spi: Cadence QSPI NOR probe failed -517
[    5.002118] am65-cpsw-nuss 46000000.ethernet: rx-flow-id-base is not set -22
[    5.009181] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2
[    5.020596] UDMA has not been proped
[    5.024173] am65-cpsw-nuss 46000000.ethernet: Failed to request tx dma channel -517
[    5.032261] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010a, freq:200000000, add_val:4 pps:0
[    5.040780] mmc0: Unknown controller version (4). You may experience problems.
[    5.048007] mmc0: CQHCI version 5.10
[    5.082309] mmc0: SDHCI controller on 4f80000.sdhci [4f80000.sdhci] using ADMA 64-bit
[    5.096544] vdd_mmc1: supplied by vsys_3v3
[    5.101374] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fc7100
[    5.108322] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fc7100
[    5.115248] omap-mailbox 31f82000.mailbox: omap mailbox rev 0x66fc7100
[    5.122116] omap-mailbox 31f83000.mailbox: omap mailbox rev 0x66fc7100
[    5.128986] omap-mailbox 31f84000.mailbox: omap mailbox rev 0x66fc7100
[    5.159089] mmc0: Command Queue Engine enabled
[    5.163536] mmc0: new HS400 MMC card at address 0001
[    5.168918] mmcblk0: mmc0:0001 S0J56X 14.8 GiB
[    5.173727] mmcblk0boot0: mmc0:0001 S0J56X partition 1 31.5 MiB
[    5.179965] mmcblk0boot1: mmc0:0001 S0J56X partition 2 31.5 MiB
[    5.185987] mmcblk0rpmb: mmc0:0001 S0J56X partition 3 4.00 MiB, chardev (242:0)
[    5.199604]  mmcblk0: p1
[    5.460421] ti-udma 285c0000.udmap: Channels: 24 (tchan: 48, echan: 0, rchan: 48, rflow: 96)
[    5.470032] ti-udma 31150000.udmap: Channels: 84 (tchan: 140, echan: 160, rchan: 140, rflow: 300)
[    5.482386] cadence-qspi 47040000.spi: mt35xu512aba (65536 Kbytes)
[    5.488571] 7 cmdlinepart partitions found on MTD device 47040000.spi.0
[    5.495171] Creating 7 MTD partitions on "47040000.spi.0":
[    5.500645] 0x000000000000-0x000000080000 : "ospi.tiboot3"
[    5.506440] 0x000000080000-0x000000280000 : "ospi.tispl"
[    5.511941] 0x000000280000-0x000000680000 : "ospi.u-boot"
[    5.517568] 0x000000680000-0x0000006a0000 : "ospi.env"
[    5.522894] 0x0000006a0000-0x0000006c0000 : "ospi.env.backup"
[    5.528821] 0x0000006c0000-0x0000007c0000 : "ospi.sysfw"
[    5.534345] 0x000000800000-0x000004000000 : "ospi.rootfs"
[    5.541948] cadence-qspi 47050000.spi: n25q512a (65536 Kbytes)
[    5.549723] am65-cpsw-nuss 46000000.ethernet: rx-flow-id-base is not set -22
[    5.556783] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2
[    5.574181] am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48
[    5.584633] pps pps0: new PPS source ptp1
[    5.588770] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010a, freq:500000000, add_val:1 pps:1
[    5.597715] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 0.4
[    5.604925] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
[    5.650710] am65-cpsw-nuss 46000000.ethernet: davinci mdio revision 9.7, bus freq 1000000
[    5.658872] libphy: 46000000.ethernet: probed
[    5.664603] sdhci-am654 4fb0000.sdhci: Linked as a consumer to regulator.4
[    5.671492] sdhci-am654 4fb0000.sdhci: Linked as a consumer to regulator.5
[    5.678383] mmc1: Unknown controller version (4). You may experience problems.
[    5.685614] mmc1: CQHCI version 5.10
[    5.719268] mmc1: SDHCI controller on 4fb0000.sdhci [4fb0000.sdhci] using ADMA 64-bit
[    5.735914] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[    5.742771] hctosys: unable to open rtc device (rtc0)
[    5.769436] ALSA device list:
[    5.772399]   No soundcards found.
[    5.776066] Waiting for root device PARTUUID=cf782362-02...
[    7.060078] mmc1: new ultra high speed DDR50 SDHC card at address 59b4
[    7.067168] mmcblk1: mmc1:59b4 SD    28.9 GiB
[    7.078027]  mmcblk1: p1 p2
[    7.101316] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Opts: (null)
[    7.109423] VFS: Mounted root (ext4 filesystem) on device 179:98.
[    7.120259] devtmpfs: mounted
[    7.123357] Freeing unused kernel memory: 576K
[    7.127806] Run /sbin/init as init process
[    7.278130] systemd[1]: System time before build time, advancing clock.
[    7.325522] NET: Registered protocol family 10
[    7.330385] Segment Routing with IPv6
[    7.351407] systemd[1]: systemd 239 running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR +SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN2 -IDN -PCRE2 default-hierarchy=hybrid)
[    7.372883] systemd[1]: Detected architecture arm64.
[    7.399252] systemd[1]: Set hostname to <j7-evm>.
[    7.411399] random: systemd: uninitialized urandom read (16 bytes read)
[    7.418020] systemd[1]: Initializing machine ID from random generator.
[    7.525619] systemd[1]: Configuration file /lib/systemd/system/local-fs.target is marked executable. Please remove executable permission bits. Proceeding anyway.
[    7.540068] systemd[1]: Configuration file /lib/systemd/system/local-fs.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    7.557679] systemd[1]: Configuration file /lib/systemd/system/swap.target is marked executable. Please remove executable permission bits. Proceeding anyway.
[    7.571756] systemd[1]: Configuration file /lib/systemd/system/swap.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    7.587330] systemd[1]: Configuration file /lib/systemd/system/umount.target is marked executable. Please remove executable permission bits. Proceeding anyway.
[    7.601569] systemd[1]: Configuration file /lib/systemd/system/umount.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    7.702764] random: systemd: uninitialized urandom read (16 bytes read)
[    7.732379] random: systemd: uninitialized urandom read (16 bytes read)
[    7.838536] cmemk: loading out-of-tree module taints kernel.
[    7.845187] CMEMK module: reference Linux version 4.19.94
[  OK  ] Started Hardware RNG Entropy Gatherer Daemon.[    7.850995] no physical memory specified
[    7.860421] cmemk initialized
[    7.867989] cryptodev: driver 1.9 loaded.
[    7.884747] EXT4-fs (mmcblk1p2): re-mounted. Opts: (null)
[    8.347434] systemd-journald[154]: Received request to flush runtime journal from PID 1
[    9.648906] rti-wdt 2200000.rti: heartbeat 60 sec
[    9.690038] rti-wdt 2210000.rti: heartbeat 60 sec
[    9.737214] pcm3168a 5-0044: Linked as a consumer to regulator.2
[    9.787611] pcm3168a 5-0044: Linked as a consumer to regulator.3
[    9.857486] pci-endpoint-test 0000:00:00.0: of_irq_parse_pci: failed with rc=-22
[    9.873095] img_enc 4200000.video-encoder: vxe_enc_probe: adding heap of type 1
[    9.887125] k3-dsp-rproc 4d80800000.dsp: assigned reserved memory node c66-dma-memory@a7000000
[    9.908856] pci_generic_config_write32: 29 callbacks suppressed
[    9.908863] pci_bus 0000:00: 1-byte config write to 0000:00:00.0 offset 0x3c may corrupt adjacent RW1C bits
[    9.952634] img_enc 4200000.video-encoder: vxe_enc_probe: using heap 1 for internal alloc
[    9.969853] k3-dsp-rproc 4d80800000.dsp: configured DSP for IPC-only mode
[   10.019889] remoteproc remoteproc0: 4d80800000.dsp is available
[   10.047300] pci-endpoint-test 0001:00:00.0: of_irq_parse_pci: failed with rc=-22
[   10.055262] k3-dsp-rproc 4d81800000.dsp: assigned reserved memory node c66-dma-memory@a6000000
[   10.059476] pci_bus 0001:00: 1-byte config write to 0001:00:00.0 offset 0x3c may corrupt adjacent RW1C bits
[   10.074034] img_enc 4200000.video-encoder: encoder registered as /dev/video0
[   10.085065] k3-dsp-rproc 4d81800000.dsp: configured DSP for IPC-only mode
[   10.088560] pci-endpoint-test 0002:00:00.0: of_irq_parse_pci: failed with rc=-22
[   10.100178] remoteproc remoteproc1: 4d81800000.dsp is available
[   10.101777] pci_bus 0002:00: 1-byte config write to 0002:00:00.0 offset 0x3c may corrupt adjacent RW1C bits
[   10.117668] k3-dsp-rproc 64800000.dsp: assigned reserved memory node c71-dma-memory@a8000000
[   10.129956] k3-dsp-rproc 64800000.dsp: configured DSP for IPC-only mode
[   10.138257] remoteproc remoteproc2: 64800000.dsp is available
[   10.402007] ntb_hw_epf 0000:00:00.0: of_irq_parse_pci: failed with rc=-22
[   10.414477] k3_r5_rproc interconnect@100000:interconnect@28380000:r5fss@41000000: creating child devices for R5F cores
[   10.418759] pci_bus 0000:00: 1-byte config write to 0000:00:00.0 offset 0x3c may corrupt adjacent RW1C bits
[   10.435458] ntb_hw_epf 0001:00:00.0: of_irq_parse_pci: failed with rc=-22
[   10.438886] platform 41000000.r5f: configured R5F for remoteproc mode
[   10.442284] pci_bus 0001:00: 1-byte config write to 0001:00:00.0 offset 0x3c may corrupt adjacent RW1C bits
[   10.460499] platform 41000000.r5f: assigned reserved memory node r5f-dma-memory@a0000000
[   10.464899] ntb_hw_epf 0002:00:00.0: of_irq_parse_pci: failed with rc=-22
[   10.475517] pci_bus 0002:00: 1-byte config write to 0002:00:00.0 offset 0x3c may corrupt adjacent RW1C bits
[   10.475970] remoteproc remoteproc3: 41000000.r5f is available
[   10.517549] remoteproc remoteproc3: Direct firmware load for j7-mcu-r5f0_0-fw failed with error -2
[   10.529597] remoteproc remoteproc3: powering up 41000000.r5f
[   10.544514] TI DP83867 k3-cpsw-mdio:00: attached PHY driver [TI DP83867] (mii_bus:phy_addr=k3-cpsw-mdio:00, irq=POLL)
[   10.547642] remoteproc remoteproc3: Direct firmware load for j7-mcu-r5f0_0-fw failed with error -2
[   10.561288] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[   10.564643] k3_r5_rproc interconnect@100000:r5fss@5c00000: creating child devices for R5F cores
[   10.579668] remoteproc remoteproc3: request_firmware failed: -2
[   10.619021] platform 5c00000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1)
[   10.639380] platform 5c00000.r5f: configured R5F for IPC-only mode
[   10.658830] platform 5c00000.r5f: assigned reserved memory node r5f-dma-memory@a2000000
[   10.700005] remoteproc remoteproc4: 5c00000.r5f is available
[   10.746752] platform 5d00000.r5f: configured R5F for IPC-only mode
[   10.758401] remoteproc remoteproc0: powering up 4d80800000.dsp
[   10.764377] remoteproc remoteproc1: powering up 4d81800000.dsp
[   10.764559] remoteproc remoteproc0: Booting fw image j7-c66_0-fw, size 8965648
[   10.771412] remoteproc remoteproc1: Booting fw image j7-c66_1-fw, size 8964660
[   10.802855] remoteproc remoteproc1: erroneous trace resource entry
[   10.802881] remoteproc remoteproc0: erroneous trace resource entry
[   10.812540] remoteproc remoteproc1: Failed to process resources: -22
[   10.819331] remoteproc remoteproc0: Failed to process resources: -22
[   10.834960] platform 5d00000.r5f: assigned reserved memory node r5f-dma-memory@a3000000
[   10.862461] remoteproc remoteproc5: 5d00000.r5f is available
[   10.868755] remoteproc remoteproc2: powering up 64800000.dsp
[   10.874541] remoteproc remoteproc2: Booting fw image j7-c71_0-fw, size 11907736
[   10.886982] remoteproc remoteproc4: powering up 5c00000.r5f
[   10.892721] remoteproc remoteproc4: Booting fw image j7-main-r5f0_0-fw, size 1887056
[   10.906590] remoteproc remoteproc2: erroneous trace resource entry
[   10.917510] remoteproc remoteproc2: Failed to process resources: -22
[   10.929605] k3_r5_rproc interconnect@100000:r5fss@5e00000: creating child devices for R5F cores
[   10.971678] platform 5e00000.r5f: configured R5F for remoteproc mode
[   10.987028] platform 5e00000.r5f: assigned reserved memory node r5f-dma-memory@a4000000
[   11.006936] remoteproc remoteproc6: 5e00000.r5f is available
[   11.022895] remoteproc remoteproc6: Direct firmware load for j7-main-r5f1_0-fw failed with error -2
[   11.035987] remoteproc remoteproc6: powering up 5e00000.r5f
[   11.042081] platform 5f00000.r5f: configured R5F for remoteproc mode
[   11.044568] j721e-audio sound@0: pcm3168a-dac <-> 2ba0000.mcasp mapping ok
[   11.048467] remoteproc remoteproc6: Direct firmware load for j7-main-r5f1_0-fw failed with error -2
[   11.048471] remoteproc remoteproc6: request_firmware failed: -2
[   11.070981] platform 5f00000.r5f: assigned reserved memory node r5f-dma-memory@a5000000
[   11.074402] j721e-audio sound@0: pcm3168a-adc <-> 2ba0000.mcasp mapping ok
[   11.082960] remoteproc remoteproc7: 5f00000.r5f is available
[   11.099287] remoteproc remoteproc7: Direct firmware load for j7-main-r5f1_1-fw failed with error -2
[   11.114766] remoteproc remoteproc7: powering up 5f00000.r5f
[   11.121115] remoteproc remoteproc7: Direct firmware load for j7-main-r5f1_1-fw failed with error -2
[   11.137620] remoteproc remoteproc7: request_firmware failed: -2
[   11.319710] remoteproc remoteproc5: powering up 5d00000.r5f
[   11.325476] remoteproc remoteproc5: Booting fw image j7-main-r5f0_1-fw, size 12288860
[   11.338692] remoteproc remoteproc5: erroneous trace resource entry
[   11.350489] remoteproc remoteproc5: Failed to process resources: -22
[   11.606319] am65-cpsw-nuss 46000000.ethernet eth0: Link is Down
[   11.762702] cdns-usb3 6000000.usb: DRD version v1 (ID: 0004024e, rev: 00000200)
[   11.779136] omap_rng 4e10000.trng: Random Number Generator ver. 241b34c
[   11.785927] random: crng init done
[   11.789476] random: 7 urandom warning(s) missed due to ratelimiting
[   11.871073] cdns-usb3 6400000.usb: DRD version v1 (ID: 0004024e, rev: 00000200)
[   11.894173] remoteproc remoteproc8: b034000.pru is available
[   11.904118] pru-rproc b034000.pru: PRU rproc node pru@b034000 probed successfully
[   11.927458] remoteproc remoteproc9: b004000.rtu is available
[   11.958152] pru-rproc b004000.rtu: PRU rproc node rtu@b004000 probed successfully
[   11.984167] remoteproc remoteproc10: b00a000.txpru is available
[   11.991656] pru-rproc b00a000.txpru: PRU rproc node txpru@b00a000 probed successfully
[   12.004342] remoteproc remoteproc11: b038000.pru is available
[   12.020233] pru-rproc b038000.pru: PRU rproc node pru@b038000 probed successfully
[   12.060040] remoteproc remoteproc12: b006000.rtu is available
[   12.110818] pru-rproc b006000.rtu: PRU rproc node rtu@b006000 probed successfully
[   12.130426] remoteproc remoteproc13: b00c000.txpru is available
[   12.141074] pru-rproc b00c000.txpru: PRU rproc node txpru@b00c000 probed successfully
[   12.164757] remoteproc remoteproc14: b134000.pru is available
[   12.174966] pru-rproc b134000.pru: PRU rproc node pru@b134000 probed successfully
[   12.189379] remoteproc remoteproc15: b104000.rtu is available
[   12.196499] pru-rproc b104000.rtu: PRU rproc node rtu@b104000 probed successfully
[   12.212942] remoteproc remoteproc16: b10a000.txpru is available
[   12.225375] pru-rproc b10a000.txpru: PRU rproc node txpru@b10a000 probed successfully
[   12.247082] remoteproc remoteproc17: b138000.pru is available
[   12.260675] pru-rproc b138000.pru: PRU rproc node pru@b138000 probed successfully
[   12.274823] remoteproc remoteproc18: b106000.rtu is available
[   12.286189] pru-rproc b106000.rtu: PRU rproc node rtu@b106000 probed successfully
[   12.311356] remoteproc remoteproc19: b10c000.txpru is available
[   12.320466] pru-rproc b10c000.txpru: PRU rproc node txpru@b10c000 probed successfully
[   12.502541] usbcore: registered new interface driver usbfs
[   12.526203] usbcore: registered new interface driver hub
[   12.534350] usbcore: registered new device driver usb
[   12.579509] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller
[   12.595265] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 1
[   12.607105] xhci-hcd xhci-hcd.2.auto: hcc params 0x200073c9 hci version 0x100 quirks 0x0000000000010010
[   12.627097] xhci-hcd xhci-hcd.2.auto: irq 321, io mem 0x06410000
[   12.652751] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[   12.674288] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   12.696216] usb usb1: Product: xHCI Host Controller
[   12.710747] usb usb1: Manufacturer: Linux 4.19.94-g5a23bc00e0 xhci-hcd
[   12.727512] usb usb1: SerialNumber: xhci-hcd.2.auto
[   12.753294] hub 1-0:1.0: USB hub found
[   12.762531] hub 1-0:1.0: 1 port detected
[   12.782514] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller
[   12.794878] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 2
[   12.811774] xhci-hcd xhci-hcd.2.auto: Host supports USB 3.0 SuperSpeed
[   12.832745] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[   12.847730] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 4.19
[   12.870773] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   12.886362] usb usb2: Product: xHCI Host Controller
[   12.901823] usb usb2: Manufacturer: Linux 4.19.94-g5a23bc00e0 xhci-hcd
[   12.918645] usb usb2: SerialNumber: xhci-hcd.2.auto
[  OK[   12.929757] hub 2-0:1.0: USB hub found
[  OK     12.941695] hub 2-0:1.0: 1 port detected
m] Started Daily rotation of log files.
[  OK  ] Started File System Check on /dev/m[   13.114774] usb 1-1: new high-speed USB device number 2 using xhci-hcd
mcblk1p1.
[   13.165801] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[   13.188406] pvrsrvkm 4e20000000.gpu: Linked as a consumer to genpd:0:4e20000000.gpu
[   13.196289] pvrsrvkm 4e20000000.gpu: Linked as a consumer to genpd:1:4e20000000.gpu
[   13.204212] PVR_K:  898: Read BVNC 22.104.208.318 from HW device registers
[   13.211631] PVR_K:  898: RGX Device initialised with BVNC 22.104.208.318
[   13.223030] [drm] Initialized pvr 1.10.5371573 20170530 for 4e20000000.gpu on minor 1
[   13.275026] usb 1-1: New USB device found, idVendor=0451, idProduct=8142, bcdDevice= 1.00
[   13.283210] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=1
[   13.290374] usb 1-1: SerialNumber: BD0100897885
[   13.295561] hub 1-1:1.0: USB hub found
[   13.299383] hub 1-1:1.0: 4 ports detected
         Starting DEMO...
        autoconf
        bash-dev
        bash
        bc
        binutils
        cifs-utils
        cpio
        cpp-symlinks
        cpp
        dosfstools
        elfutils
        g++-symlinks
        g++
        gawk
        gcc-symlinks
        gcc
        gdb
        gdbserver
        gettext
        glmark2
        gstreamer1.0-libav
        gzip
        libbfd
        libcairo-perf-utils
        libdw1
        libelf1
        libgdbm-compat4
        libgdbm-dev
        libgdbm6
        libgettextlib
        libgettextsrc
        libgmp10
        libidn2-0
        libmpc3
        libmpfr6
        libreadline-dev
        libreadline7
        libunistring2
        m4-dev
        m4
        make
        nettle
        parted
        which
 _____                    _____           _         _
              |___|                    |___|
j7-evm login: root
root@j7-evm:~# cat /proc/version
APP_LOG: Mapped 0xb8000000 -> (nil) of size 262144 bytes
APP_LOG: ERROR: Unable to map memory @ 0xb8000000 of size 262144 bytes !!!
[  129.529543] NET: Registered protocol family 15
[  129.574088] Initializing XFRM netlink socket
