Other Parts Discussed in Thread: OMAP3530
Hi
We need to use vlib to meet our spec. However we'd also like to use C6accel.
Will the standard c6accel add the support to vlib ? When if so ?
We are working with OMAP3530.
Hi
Hello John, yes, that is something we are working on. The current plan is to make the support available by middle this year. If you need access to beta release or have other feedback, please feel free to write to us at: http://processors.wiki.ti.com/index.php/C6Accel#Developer_Mailing_List
Cheers,
Gagan
Hello Gagan
Thanks. It's ok.We've already started by ourself the dev of the port VLIB in C6accel. We can't wait to mid-year.
Best regards
That is good to know and all the best. If you face any issues, please feel free to write to us
Cheers,
Gagan
Hi Gagan
ok, thank you for your proposition. Yes, it takes so much time, we've almost finished with the codes.Need some testers to debug it. Don't you have any professionnal TI engineer employees for that ?
Otherwise, it's just matter of time.
thank you anyway.
Hello Gagan,
Just test the vlib port, here some reports, only testable functions were tested ...
'i' : C6accel_VLIB_integralImage all OK
'n' : C6accel_VLIB_normalFlow failed
'k' : C6accel_VLIB_kalmanFilter exited with error
'b' : C6accel_VLIB_bhattacharyaDistance no response
'c' : C6accel_VLIB_testCannyEdgeDetector failed
'o' : C6accel_VLIB_testConnectedComponents no response + have to restard beagle board
'v' : C6accel_VLIB_convertUYVY failed
'e' : C6accel_VLIB_erode + dilate erode no response, dilate failed
'x' : C6accel_VLIB_extract8bitBackground VLIB_testExtractLumaFromUYUV() = ok, other failed
'p' : C6accel_VLIB_gauss5x5PyramidKernel VLIB_testGauss5x5PyramidKernel_16() = ok, other failed
'h' : C6accel_VLIB_harrisScore_7x7 failed
's' : C6accel_ VLIB_histogram_1D exited with error
'H' : C6accel_VLIB_houghLineFromList failed
'P' : C6accel_VLIB_imagePyramid VLIB_testImagePyramid8() = ok, other failed
'm' : C6accel_VLIB_initMeanWithLuma failed
'V' : C6accel_VLIB_initVarWithConst failed + exited with error
'L' : C6accel_VLIB_L1Distance no response
'l' : C6accel_VLIB_legendreMoments no response
'M' : C6accel_VLIB_testMixtureOfGaussians failed
'S' : C6accel_VLIB_nonMaxSuppress_3x3 VLIB_testNonMaxSuppress_3x3_16s() = ok, VLIB_testNonMaxSuppress_7x7_16s() = ok, other failed
'a' : C6accel_VLIB_packMask failed
'R' : C6accel_VLIB_recursiveFilter no response + have to restard beagle board
'B' : C6accel_VLIB_subtractBackground no response
't' : C6accel_VLIB_trackFeaturesLucasKanade_7x7 all OK
'E' : C6accel_VLIB_updateEWRMean failed + exited
'U' : C6accel_VLIB_updateUWRMean failed
'W' : C6accel_ VLIB_weightedHistogram failed + exited
I wonder what tools do you have to debug in c6accel ?
Thank you all
Best regards
John,
Here are the debugging options you have while adding a new function to the C6Accel framework.
If you want us to help you debug some of the functions can you share your code at the C6Accel Developers list mentioned by Gagan.
Rahul
Hello Rahul,
Thank you for your quick answer. But how to share codes at the C6Accel Developers list ? You mean to directly send the packed tgz file to the mailing list ? Isn't there a svn depot ?
Bye
John,
Just wanted to check if you have been able to debug and test VLIB kernels you integrated with C6Accel.
Rahul
Hi Rahul,
It's nice to have a message from you. So until now, I don't have got too much time to make any improvement to my previous work. Moreover I don't have anymore the beagleboard. Now, we're swtiching to the Sti7105 (SH4 Cpu) board. So, maybe Iater, we'll get back...
Best regards
