Part Number: TDA4VM
Hello there,
Recently i am using 6.2.00.21-SDK, and meets following questions:
After compiled vision app, created SD card; and run the vision-app, found:
1. in dmesg: It shows all firmware are works in IPC-only mode; seems it enables ipc echo test automatically.
what's the ipc-only mode?
2. Use my own C71 IPC test firmware replace the one in /lib/firmware/j7-c71_0-fw. and found only 8bytes can be received in C71 via ipc; it there any limitation code/macro in it?
3. is there any loop count setting for the ipc echo test, or it just a infinite test?
4. I also tracked HWI No.5 and No.6 in C71 are enabled. what's HWI No5,6 stands for?
Best Regards
Samuel
