Other Parts Discussed in Thread: DRA718, DRA722
hi all experts,
my board is custom board with soc DRA711, and DDR3 is 512M, now i port earlyboot with VisionSDK0304 from J6entry EVM board.
now i encounter IPU2 lateattach mmufault, kernel log as following:
[root@x ~]# dmesg
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.14.54-01924-gfacc25e0-dirty (fanchenxin@hp) (gcc version 7.2.1 20171011 (Linaro GCC 7.2-2017.11)) #1 SMP PREEMPT Tue Apr 7 15:24:31 CST 2020
[ 0.000000] CPU: ARMv7 Processor [412fc0f2] revision 2 (ARMv7), cr=30c5387d
[ 0.000000] CPU: div instructions available: patching division code
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
[ 0.000000] OF: fdt: Machine model: TI DRA718 DCARD
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] Reserved memory: created DMA memory pool at 0x0000000040300000, size 3 MiB
[ 0.000000] OF: reserved mem: initialized node cmem@40300000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x0000000084000000, size 128 MiB
[ 0.000000] OF: reserved mem: initialized node vsdk_sr1_mem@84000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x0000000095000000, size 80 MiB
[ 0.000000] OF: reserved mem: initialized node ipu2_cma@95800000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x000000009a000000, size 28 MiB
[ 0.000000] OF: reserved mem: initialized node ipu1_cma@9d000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x000000009c000000, size 16 MiB
[ 0.000000] OF: reserved mem: initialized node png_resource_mem@9C000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x000000009d000000, size 32 MiB
[ 0.000000] OF: reserved mem: initialized node cmem@9D000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x000000009f000000, size 5 MiB
[ 0.000000] OF: reserved mem: initialized node vsdk_sr0_mem@9F000000, compatible id shared-dma-pool
[ 0.000000] cma: Reserved 64 MiB at 0x0000000091000000
[ 0.000000] OMAP4: Map 0x000000009fd00000 to fe600000 for dram barrier
[ 0.000000] Hit pending asynchronous external abort (FSR=0x00000211) during first unmask, this is most likely caused by a firmware/bootloader bug.
[ 0.000000] On node 0 totalpages: 56064
[ 0.000000] free_area_init_node: node 0, pgdat c0c34000, node_mem_map d0b80000
[ 0.000000] DMA zone: 1146 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 56064 pages, LIFO batch:15
[ 0.000000] DRA722 ES2.1
[ 0.000000] percpu: Embedded 15 pages/cpu @dfc7c000 s31116 r8192 d22132 u61440
[ 0.000000] pcpu-alloc: s31116 r8192 d22132 u61440 alloc=15*4096
[ 0.000000] pcpu-alloc: [0] 0
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 54918
[ 0.000000] Kernel command line: console=ttyS2,115200n8 elevator=noop root=PARTUUID=2966335c-02 rw rootwait fixrtc omapdrm.num_crtc=2 consoleblank=0 cma=64M rootfstype=ext4 snd.slots_reserved=1,1
[ 0.000000] PID hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.000000] Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
[ 0.000000] Memory: 145028K/224256K available (6144K kernel code, 216K rwdata, 1608K rodata, 2048K init, 371K bss, 13692K reserved, 65536K cma-reserved, 0K highmem)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
[ 0.000000] vmalloc : 0xe0000000 - 0xff800000 ( 504 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xdfd00000 ( 509 MB)
[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
[ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
[ 0.000000] .text : 0xc0008000 - 0xc0800000 (8160 kB)
[ 0.000000] .init : 0xc0a00000 - 0xc0c00000 (2048 kB)
[ 0.000000] .data : 0xc0c00000 - 0xc0c363c0 ( 217 kB)
[ 0.000000] .bss : 0xc0c38000 - 0xc0c94d14 ( 372 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] RCU restricting CPUs from NR_CPUS=2 to nr_cpu_ids=1.
[ 0.000000] Tasks RCU enabled.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=1
[ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] OMAP clockevent source: timer1 at 31475 Hz
[ 0.000000] arch_timer: cp15 timer(s) running at 5.90MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x15c70fb29, max_idle_ns: 440795202138 ns
[ 0.000005] sched_clock: 56 bits at 5MHz, resolution 169ns, wraps every 4398046511093ns
[ 0.000014] Switching to timer-based delay loop, resolution 169ns
[ 0.000335] clocksource: 32k_counter: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 58327039986419 ns
[ 0.000340] OMAP clocksource: 32k_counter at 32768 Hz
[ 0.000737] Console: colour dummy device 80x30
[ 0.000759] Calibrating delay loop (skipped), value calculated using timer frequency.. 11.80 BogoMIPS (lpj=59016)
[ 0.000773] pid_max: default: 32768 minimum: 301
[ 0.000877] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.000885] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.001362] CPU: Testing write buffer coherency: ok
[ 0.001569] /cpus/cpu@0 missing clock-frequency property
[ 0.001579] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.039875] Setting up static identity map for 0x80200000 - 0x80200060
[ 0.059878] Hierarchical SRCU implementation.
[ 0.099930] smp: Bringing up secondary CPUs ...
[ 0.099937] smp: Brought up 1 node, 1 CPU
[ 0.099944] SMP: Total of 1 processors activated (11.80 BogoMIPS).
[ 0.099950] CPU: All CPU(s) started in HYP mode.
[ 0.099954] CPU: Virtualization extensions available.
[ 0.100251] devtmpfs: initialized
[ 0.116095] random: get_random_u32 called from bucket_table_alloc+0x108/0x230 with crng_init=0
[ 0.116212] VFP support v0.3: implementor 41 architecture 4 part 30 variant f rev 0
[ 0.116401] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.116414] futex hash table entries: 256 (order: 2, 16384 bytes)
[ 0.117800] pinctrl core: initialized pinctrl subsystem
[ 0.118346] NET: Registered protocol family 16
[ 0.120785] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.121436] omap_hwmod: l3_main_2 using broken dt data from ocp
[ 0.172434] cpuidle: using governor ladder
[ 0.172463] cpuidle: using governor menu
[ 0.178898] platform 43300000.edma: Cannot lookup hwmod 'tpcc'
[ 0.179157] platform 43400000.tptc: Cannot lookup hwmod 'tptc0'
[ 0.179419] platform 43500000.tptc: Cannot lookup hwmod 'tptc1'
[ 0.180095] gpio gpiochip0: (gpio): added GPIO chardev (254:0)
[ 0.180160] gpiochip_setup_dev: registered GPIOs 0 to 31 on device: gpiochip0 (gpio)
[ 0.180223] OMAP GPIO hardware version 0.1
[ 0.180881] gpio gpiochip1: (gpio): added GPIO chardev (254:1)
[ 0.180943] gpiochip_setup_dev: registered GPIOs 32 to 63 on device: gpiochip1 (gpio)
[ 0.181592] gpio gpiochip2: (gpio): added GPIO chardev (254:2)
[ 0.181653] gpiochip_setup_dev: registered GPIOs 64 to 95 on device: gpiochip2 (gpio)
[ 0.182313] gpio gpiochip3: (gpio): added GPIO chardev (254:3)
[ 0.182378] gpiochip_setup_dev: registered GPIOs 96 to 127 on device: gpiochip3 (gpio)
[ 0.183028] gpio gpiochip4: (gpio): added GPIO chardev (254:4)
[ 0.183093] gpiochip_setup_dev: registered GPIOs 128 to 159 on device: gpiochip4 (gpio)
[ 0.183745] gpio gpiochip5: (gpio): added GPIO chardev (254:5)
[ 0.183804] gpiochip_setup_dev: registered GPIOs 160 to 191 on device: gpiochip5 (gpio)
[ 0.184455] gpio gpiochip6: (gpio): added GPIO chardev (254:6)
[ 0.184516] gpiochip_setup_dev: registered GPIOs 192 to 223 on device: gpiochip6 (gpio)
[ 0.185180] gpio gpiochip7: (gpio): added GPIO chardev (254:7)
[ 0.185241] gpiochip_setup_dev: registered GPIOs 224 to 255 on device: gpiochip7 (gpio)
[ 0.195383] platform 4a140000.sata: Cannot lookup hwmod 'sata'
[ 0.197403] platform 4b500000.aes: Cannot lookup hwmod 'aes1'
[ 0.197665] platform 4b700000.aes: Cannot lookup hwmod 'aes2'
[ 0.197928] platform 480a5000.des: Cannot lookup hwmod 'des'
[ 0.198185] platform 4b101000.sham: Cannot lookup hwmod 'sham'
[ 0.198448] platform 48090000.rng: Cannot lookup hwmod 'rng'
[ 0.200404] No ATAGs?
[ 0.200445] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.200451] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.200800] omap4_sram_init:Unable to allocate sram needed to handle errata I688
[ 0.200807] omap4_sram_init:Unable to get sram pool needed to handle errata I688
[ 0.201038] OMAP DMA hardware revision 0.0
[ 0.231092] edma3-tptc 43400000.tptc: _od_fail_runtime_resume: FIXME: missing hwmod/omap_dev info
[ 0.231149] edma3-tptc 43500000.tptc: _od_fail_runtime_resume: FIXME: missing hwmod/omap_dev info
[ 0.231346] edma 43300000.edma: _od_fail_runtime_resume: FIXME: missing hwmod/omap_dev info
[ 0.231355] edma 43300000.edma: pm_runtime_get_sync() failed
[ 0.238296] omap-dma-engine 4a056000.dma-controller: OMAP DMA engine driver (LinkedList1/2/3 supported)
[ 0.238686] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/fixedregulator-sd[0]'
[ 0.238875] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/smps4[0]'
[ 0.240486] omap-iommu 58882000.mmu: 58882000.mmu registered
[ 0.240716] omap-iommu 55082000.mmu: 55082000.mmu registered
[ 0.240966] iommu: Adding device 55020000.ipu to group 1
[ 0.241651] omap_i2c 48070000.i2c: bus 0 rev0.12 at 100 kHz
[ 0.241782] media: Linux media interface: v0.10
[ 0.241819] Linux video capture interface: v2.00
[ 0.241858] pps_core: LinuxPPS API ver. 1 registered
[ 0.241864] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.241880] PTP clock support registered
[ 0.242333] omap-mailbox 48840000.mailbox: omap mailbox rev 0x400
[ 0.242535] omap-mailbox 48842000.mailbox: omap mailbox rev 0x400
[ 0.250430] clocksource: Switched to clocksource arch_sys_counter
[ 0.252967] NET: Registered protocol family 2
[ 0.253452] TCP established hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.253475] TCP bind hash table entries: 2048 (order: 2, 16384 bytes)
[ 0.253511] TCP: Hash tables configured (established 2048 bind 2048)
[ 0.253574] UDP hash table entries: 256 (order: 1, 8192 bytes)
[ 0.253593] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[ 0.253718] NET: Registered protocol family 1
[ 0.254452] hw perfevents: no interrupt-affinity property for /pmu, guessing.
[ 0.254571] hw perfevents: enabled with armv7_cortex_a15 PMU driver, 7 counters available
[ 0.255465] workingset: timestamp_bits=14 max_order=16 bucket_order=2
[ 0.260522] io scheduler noop registered (default)
[ 0.260530] io scheduler deadline registered
[ 0.265215] pinctrl-single 4a003400.pinmux: 282 pins at pa fc003400 size 1128
[ 0.265314] pinctrl-single 4a002e8c.pinmux: please update dts to use #pinctrl-cells = <1>
[ 0.265378] pinctrl-single 4a002e8c.pinmux: initialized with no interrupts
[ 0.265386] pinctrl-single 4a002e8c.pinmux: 1 pins at pa fc002e8c size 4
[ 0.270173] Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled
[ 0.272314] console [ttyS2] disabled
[ 0.272360] 48020000.serial: ttyS2 at MMIO 0x48020000 (irq = 43, base_baud = 3000000) is a 8250
[ 0.272444] console [ttyS2] enabled
[ 0.273657] omap_rng 48090000.rng: _od_fail_runtime_resume: FIXME: missing hwmod/omap_dev info
[ 0.273670] omap_rng 48090000.rng: Failed to runtime_get device: -19
[ 0.273677] omap_rng 48090000.rng: initialization failed.
[ 0.274395] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 0.274401] [drm] No driver support for vblank timestamp query.
[ 0.274539] [drm] Initialized omapdrm 1.0.0 20110917 for 44000000.ocp:vdrm@0 on minor 0
[ 0.274999] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 0.275004] [drm] No driver support for vblank timestamp query.
[ 0.275120] [drm] Initialized omapdrm 1.0.0 20110917 for 44000000.ocp:vdrm@1 on minor 1
[ 0.275559] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 0.275564] [drm] No driver support for vblank timestamp query.
[ 0.275684] [drm] Initialized omapdrm 1.0.0 20110917 for 44000000.ocp:vdrm@2 on minor 2
[ 0.282830] brd: module loaded
[ 0.285955] loop: module loaded
[ 0.286795] i2c /dev entries driver
[ 0.290305] cpu cpu0: dev_pm_opp_set_regulators: no regulator (vdd) found: -19
[ 0.291022] sdhci-omap 4809c000.mmc: GPIO lookup for consumer cd
[ 0.291030] sdhci-omap 4809c000.mmc: using device tree for GPIO lookup
[ 0.291042] of_get_named_gpiod_flags: can't parse 'cd-gpios' property of node '/ocp/mmc@4809c000[0]'
[ 0.291052] of_get_named_gpiod_flags: can't parse 'cd-gpio' property of node '/ocp/mmc@4809c000[0]'
[ 0.291059] sdhci-omap 4809c000.mmc: using lookup tables for GPIO lookup
[ 0.291067] sdhci-omap 4809c000.mmc: lookup for GPIO cd failed
[ 0.291076] sdhci-omap 4809c000.mmc: GPIO lookup for consumer wp
[ 0.291082] sdhci-omap 4809c000.mmc: using device tree for GPIO lookup
[ 0.291092] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/ocp/mmc@4809c000[0]'
[ 0.291100] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/ocp/mmc@4809c000[0]'
[ 0.291107] sdhci-omap 4809c000.mmc: using lookup tables for GPIO lookup
[ 0.291114] sdhci-omap 4809c000.mmc: lookup for GPIO wp failed
[ 0.291246] sdhci-omap 4809c000.mmc: 4809c000.mmc supply vqmmc not found, using dummy regulator
[ 0.291454] sdhci-omap 4809c000.mmc: no pinctrl state for sdr104 mode
[ 0.291462] sdhci-omap 4809c000.mmc: no pinctrl state for ddr50 mode
[ 0.291469] sdhci-omap 4809c000.mmc: no pinctrl state for sdr50 mode
[ 0.291475] sdhci-omap 4809c000.mmc: no pinctrl state for sdr25 mode
[ 0.291482] sdhci-omap 4809c000.mmc: no pinctrl state for sdr12 mode
[ 0.291488] sdhci-omap 4809c000.mmc: no pinctrl state for ddr_1_8v mode
[ 0.291496] sdhci-omap 4809c000.mmc: no pinctrl state for hs200_1_8v mode
[ 0.350474] mmc0: SDHCI controller on 4809c000.mmc [4809c000.mmc] using ADMA
[ 0.354363] omap-rproc 55020000.ipu: assigned reserved memory node ipu2_cma@95800000
[ 0.354429] remoteproc remoteproc0: 55020000.ipu is available
[ 0.354857] NET: Registered protocol family 17
[ 0.354875] NET: Registered protocol family 44
[ 0.354986] omap_voltage_late_init: Voltage driver support not added
[ 0.354992] Power Management for TI OMAP4+ devices.
[ 0.355201] Registering SWP/SWPB emulation handler
[ 0.358734] [drm] Initialized pvr 1.14.3699939 20110701 for 56000000.gpu on minor 3
[ 0.367892] remoteproc remoteproc0: Direct firmware load for dra7-ipu2-fw.xem4 failed with error -2
[ 0.367900] remoteproc remoteproc0: Falling back to user helper
[ 0.378204] hctosys: unable to open rtc device (rtc0)
[ 0.378841] Waiting for root device PARTUUID=2966335c-02...
[ 0.397528] mmc0: host does not support reading read-only switch, assuming write-enable
[ 0.399449] mmc0: new high speed SDHC card at address b368
[ 0.399738] mmcblk0: mmc0:b368 NCard 7.48 GiB
[ 0.400786] mmcblk0: p1 p2
[ 0.450801] EXT4-fs (mmcblk0p2): warning: mounting fs with errors, running e2fsck is recommended
[ 0.455322] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 0.455358] VFS: Mounted root (ext4 filesystem) on device 179:2.
[ 0.459129] devtmpfs: mounted
[ 0.460407] Freeing unused kernel memory: 2048K
[ 0.616029] memcache: loading out-of-tree module taints kernel.
[ 0.616368] DMA: Module install successful, device major num = 244
[ 0.616373] DRV: Module install successful
[ 0.632644] CMEMK module: reference Linux version 4.14.54
[ 0.633807] allocated heap buffer 0x97000000 of size 0x2000000
[ 0.633836] cmemk initialized
[ 0.639964] random: fast init done
[ 0.648439] omap_l3_noc 44000000.ocp: L3 application error: target 5 mod:1 (unclearable)
[ 0.648453] omap_l3_noc 44000000.ocp: L3 debug error: target 5 mod:1 (unclearable)
[ 0.733869] pvr: UM DDK-(3699939) and KM DDK-(3699939) match
[ 1.056439] remoteproc remoteproc0: powering up 55020000.ipu
[ 1.056453] remoteproc remoteproc0: Booting fw image dra7-ipu2-fw.xem4, size 3411420
[ 1.057137] virtio_rpmsg_bus virtio0: buffers: va e1240000, dma 0x95040000
[ 1.057330] virtio_rpmsg_bus virtio0: rpmsg host is online
[ 1.057363] remoteproc remoteproc0: registered virtio0 (type 7)
[ 1.057371] remoteproc remoteproc0: remote processor 55020000.ipu is now up
[ 1.069895] omap-iommu 55082000.mmu: iommu fault: da 0x95d52c00 flags 0x0
[ 1.069906] remoteproc remoteproc0: crash detected in 55020000.ipu: type mmufault
[ 1.069922] omap-iommu 55082000.mmu: 55082000.mmu: errs:0x00000002 da:0x95d52c00 pgd:0xe66f2574 *pgd:px00000000
[ 1.069939] remoteproc remoteproc0: handling crash #1 in 55020000.ipu
[ 1.069946] remoteproc remoteproc0: recovering 55020000.ipu
[ 1.070474] remoteproc remoteproc0: stopped remote processor 55020000.ipu
[ 1.070483] remoteproc remoteproc0: powering up 55020000.ipu
[ 1.078710] remoteproc remoteproc0: Booting fw image dra7-ipu2-fw.xem4, size 3411420
[ 1.078792] omap-iommu 55082000.mmu: 55082000.mmu: version 2.1
[ 1.138897] virtio_rpmsg_bus virtio0: buffers: va e1240000, dma 0x95040000
[ 1.139913] virtio_rpmsg_bus virtio0: rpmsg host is online
[ 1.140012] remoteproc remoteproc0: registered virtio0 (type 7)
[ 1.140021] remoteproc remoteproc0: remote processor 55020000.ipu is now up
[ 1.190059] omap-rproc 55020000.ipu: received echo reply from 55020000.ipu
[ 1.190363] virtio_rpmsg_bus virtio0: creating channel rpmsg-proto addr 0x50
[ 1.395137] omap_l3_noc 44000000.ocp: L3 application error: target 3 mod:2 (unclearable)
[ 1.395152] omap_l3_noc 44000000.ocp: L3 debug error: target 3 mod:2 (unclearable)
and IPU2 have XDC error as following:
[HOST] [IPU2 ] 2.576709 s: Connection established with HLOS, calling rpmsgInit
[HOST] [IPU2 ] 2.576953 s:
[HOST] [IPU2 ] 2.577014 s: ### XDC ASSERT - ERROR CALLBACK START ###
[HOST] [IPU2 ] 2.577075 s:
[core 1.083491707]Start loop with fastest frame rate
[render 1.117932473]missing resource: cluster/logo_mask.png
[HOST] [IPU2 ] 2.649118 s: [IPU2, TDA2EX]IPU_primary_core_init In progress....
program id = 210003
[HOST] [IPU2 ] 2.677118 s: ***** IPU2 Firmware build time 17:08:13 Apr 7 2020
[HOST] [IPU2 ] 2.677301 s: *** SYSTEM: CPU Frequency <ORG = 212800000 Hz>, <NEW = 221600000 Hz>
[HOST] [IPU2 ] 2.680046 s: SYSTEM: System Common Init in progress !!!
[HOST] [IPU2 ] 2.689196 s: UTILS: CIO: Init Done !!!
could anyone give me a hint about this problem?
best regards!
