Part Number: TDA2EXEVM
Hi,I want to konw how to use SD card to run and boot,I see the doc of process SDK userguide,but still don'n get ti on.
I build up a appimage file and copy it into SD ,the S4 switch?
Hi Dan,
the steps for SD card boot are outlined in section "3.5 Load using SD card" in VisionSDK_UserGuide_TDA2Ex.pdf.
Can you give more details what you did and where exactly you face problems?
Also you may look at this training and see if it helps:
Yordan
