TDA4VMXEVM: Segmentation Fault while importing a Pointnet Caffe model using TIDL importer
Part Number: TDA4VMXEVM
Hello Friends,
   I tried importing a pointnet based caffe model using the TIDL importer.I got the following error:
Name of the Network : pointnet_cls_basic
WARNING: Reshape layer only supports following with avg-pooling/inner product/ssd context.
Segmentation fault
I have hereby attached the corresponding prototxt file for your reference(I have renamed the extension since the tool did not allow to upload the file with .prototxt extension).I request you to assist me in solving the issue.
Vijay
# ---------------------- data layer ---------------
#layer {
#  name: "data"
#  type: "HDF5Data"
#  top: "data"
#  top: "label"
#  hdf5_data_param {
#    source: "data/modelnet40_ply_hdf5_2048/train_files.txt"
#    batch_size: 32
#  include: { phase: TRAIN }
#layer {
 # name: "data"
 # type: "HDF5Data"
 # top: "data"
 # top: "label"
 # hdf5_data_param {
 #   source: "data/modelnet40_ply_hdf5_2048/test_files.txt"
 #   batch_size: 32
 # include: { phase: TEST }
layer {
    type: "Reshape"
    bottom: "data"
    top: "data_reshape"
    reshape_param {
      shape {
        dim: 0  # copy the dimension from below
        dim: 1
        dim: -1
        dim: 3 # infer it from the other dimensions
# -------------------- input tansform net ---------------------
layer {
  type: "Convolution"
  bottom: "data_reshape"
  top: "conv1_tnet1"
  param {
    lr_mult: 1
  param {
    lr_mult: 2
  convolution_param {
    num_output: 64
    pad: 0
    kernel_w: 3
    kernel_h: 1
    stride: 1
    weight_filler {
      type: "xavier"
    bias_filler {
      type: "constant"
      value: 0
layer {
  type: "BatchNorm"
  bottom: "conv1_tnet1"
  top: "conv1_tnet1"
layer {
    top: "conv1_tnet1"
    type: "Scale"
    scale_param {
        bias_term: true
layer {
  type: "ReLU"
  top: "conv1_tnet1"
layer {
  type: "Convolution"
  top: "conv2_tnet1"
  param {
    lr_mult: 1
  param {
    lr_mult: 2
  convolution_param {
    num_output: 128
    pad: 0
    kernel_w: 1
    kernel_h: 1
    stride: 1
    weight_filler {
      type: "xavier"
    bias_filler {
      type: "constant"
      value: 0
layer {
  type: "BatchNorm"
  bottom: "conv2_tnet1"
  top: "conv2_tnet1"
layer {
    top: "conv2_tnet1"
    type: "Scale"
    scale_param {
        bias_term: true
layer {
  type: "ReLU"
  top: "conv2_tnet1"
layer {
  type: "Convolution"
  top: "conv3_tnet1"
  param {
    lr_mult: 1
  param {
    lr_mult: 2
  convolution_param {
    num_output: 1024
    pad: 0
    kernel_w: 1
    kernel_h: 1
    stride: 1
    weight_filler {
      type: "xavier"
    bias_filler {
      type: "constant"
      value: 0
layer {
  type: "BatchNorm"
  bottom: "conv3_tnet1"
  top: "conv3_tnet1"
layer {
    top: "conv3_tnet1"
    type: "Scale"
    scale_param {
        bias_term: true
layer {
  type: "ReLU"
  top: "conv3_tnet1"
layer {
  type: "Pooling"
  top: "global_feat_tnet1"
  pooling_param {
    pool: MAX
    pad: 0
    kernel_h: 2048
    kernel_w: 1
    stride: 1
layer {
  type: "InnerProduct"
  bottom: "global_feat_tnet1"
  top: "fc1_tnet1"
  param {
    lr_mult: 1
    decay_mult: 1
  param {
    lr_mult: 1
    decay_mult: 1
  inner_product_param {
    num_output: 512
    weight_filler {
      type: "gaussian"
      std: 0.001
    bias_filler {
      type: "constant"
      value: 0
layer {
  type: "BatchNorm"
  bottom: "fc1_tnet1"
  top: "fc1_tnet1"
layer {
    bottom: "fc1_tnet1"
    top: "fc1_tnet1"
    type: "Scale"
    scale_param {
        bias_term: true
layer {
  type: "ReLU"
  bottom: "fc1_tnet1"
  top: "fc1_tnet1"
layer {
  bottom: "fc1_tnet1"
  top: "fc2_tnet1"
  param {
    lr_mult: 1
    decay_mult: 1
  param {
    lr_mult: 1
    decay_mult: 1
    num_output: 256
    weight_filler {
      type: "gaussian"
      std: 0.001
    bias_filler {
      type: "constant"
      value: 0
layer {
  type: "BatchNorm"
  bottom: "fc2_tnet1"
  top: "fc2_tnet1"
layer {
    bottom: "fc2_tnet1"
    top: "fc2_tnet1"
    type: "Scale"
    scale_param {
        bias_term: true
layer {
  type: "ReLU"
  bottom: "fc2_tnet1"
  top: "fc2_tnet1"
layer {
  bottom: "fc2_tnet1"
  top: "fc3_tnet1"
  param {
    lr_mult: 1
    decay_mult: 1
  param {
    lr_mult: 1
    decay_mult: 1
    num_output: 9
    weight_filler {
      type: "constant"
      value: 0
    bias_filler {
      type: "constant"
      value: 0
layer {
    type: "Reshape"
    bottom: "fc3_tnet1"
    top: "fc3_tnet1_reshape"
    reshape_param {
      shape {
		dim: -1
        dim: 3
        dim: 3
#layer {
#  name: "eye_tnet1"
#  type: "Python"
#  bottom: "fc3_tnet1"
#  top: "eye_tnet1"
#  python_param {
 #   module: "eye_matrix_layer"
 #   layer: "EyeMatrixLayer"
 #   param_str: "{\'K\': 3}"
layer {
  type: "Eltwise"
  bottom: "fc3_tnet1_reshape"
 # bottom: "eye_tnet1"
  top: "transform1"
  eltwise_param { operation: SUM }
# -------------------- input transform ---------------------
#layer {
#  name: "matmul_input"
#  type: "MatrixMultiplication"
#  bottom: "data" # BxNx3
#  bottom: "transform1" # 3x3
#  top: "data_transform1"  # 10x1x1 # BxNx3
layer {
    type: "Reshape"
    bottom: "data_transform1"
    top: "data_transform1_reshape"
    reshape_param {
      shape {
        dim: 1
        dim: -1
# -------------------- mlp ---------------------
layer {
  type: "Convolution"
  bottom: "data_transform1_reshape"
  top: "conv1"
  param {
    lr_mult: 1
  param {
    lr_mult: 2
  convolution_param {
    num_output: 64
    pad: 0
    kernel_w: 3
    kernel_h: 1
    stride: 1
    weight_filler {
      type: "xavier"
    bias_filler {
      type: "constant"
      value: 0
layer {
  type: "BatchNorm"
  bottom: "conv1"
  top: "conv1"
layer {
    bottom: "conv1"
    top: "conv1"
    type: "Scale"
    scale_param {
        bias_term: true
layer {
  type: "ReLU"
  bottom: "conv1"
  top: "conv1"
layer {
  type: "Convolution"
  bottom: "conv1"
  top: "conv2"
  param {
    lr_mult: 1
  param {
    lr_mult: 2
  convolution_param {
    num_output: 64
    pad: 0
    kernel_w: 1
    kernel_h: 1
    stride: 1
    weight_filler {
      type: "xavier"
    bias_filler {
      type: "constant"
      value: 0
layer {
  type: "BatchNorm"
  bottom: "conv2"
  top: "conv2"
layer {
    bottom: "conv2"
    top: "conv2"
    type: "Scale"
    scale_param {
        bias_term: true
layer {
  type: "ReLU"
  bottom: "conv2"
  top: "conv2"
# -------------------- feat tansform net ---------------------
layer {
  type: "Convolution"
  bottom: "conv2"
  top: "conv1_tnet2"
  param {
    lr_mult: 1
  param {
    lr_mult: 2
  convolution_param {
    num_output: 64
    pad: 0
    kernel_w: 1
    kernel_h: 1
    stride: 1
    weight_filler {
      type: "xavier"
    bias_filler {
      type: "constant"
      value: 0
layer {
  type: "BatchNorm"
  bottom: "conv1_tnet2"
  top: "conv1_tnet2"
layer {
    top: "conv1_tnet2"
    type: "Scale"
    scale_param {
        bias_term: true
layer {
  type: "ReLU"
  top: "conv1_tnet2"
layer {
  type: "Convolution"
  top: "conv2_tnet2"
  param {
    lr_mult: 1
  param {
    lr_mult: 2
  convolution_param {
    num_output: 128
    pad: 0
    kernel_w: 1
    kernel_h: 1
    stride: 1
    weight_filler {
      type: "xavier"
    bias_filler {
      type: "constant"
      value: 0
layer {
  type: "BatchNorm"
  bottom: "conv2_tnet2"
  top: "conv2_tnet2"
layer {
    top: "conv2_tnet2"
    type: "Scale"
    scale_param {
        bias_term: true
layer {
  type: "ReLU"
  top: "conv2_tnet2"
layer {
  type: "Convolution"
  top: "conv3_tnet2"
  param {
    lr_mult: 1
  param {
    lr_mult: 2
  convolution_param {
    num_output: 1024
    pad: 0
    kernel_w: 1
    kernel_h: 1
    stride: 1
    weight_filler {
      type: "xavier"
    bias_filler {
      type: "constant"
      value: 0
layer {
  type: "BatchNorm"
  bottom: "conv3_tnet2"
  top: "conv3_tnet2"
layer {
    top: "conv3_tnet2"
    type: "Scale"
    scale_param {
        bias_term: true
layer {
  type: "ReLU"
  top: "conv3_tnet2"
layer {
  type: "Pooling"
  top: "global_feat_tnet2"
  pooling_param {
    pool: MAX
    pad: 0
    kernel_h: 2048
    kernel_w: 1
    stride: 1
layer {
  bottom: "global_feat_tnet2"
  top: "fc1_tnet2"
  param {
    lr_mult: 1
    decay_mult: 1
  param {
    lr_mult: 1
    decay_mult: 1
    num_output: 512
    weight_filler {
      type: "gaussian"
      std: 0.001
    bias_filler {
      type: "constant"
      value: 0
layer {
  type: "BatchNorm"
  bottom: "fc1_tnet2"
  top: "fc1_tnet2"
layer {
    bottom: "fc1_tnet2"
    top: "fc1_tnet2"
    type: "Scale"
    scale_param {
        bias_term: true
layer {
  type: "ReLU"
  bottom: "fc1_tnet2"
  top: "fc1_tnet2"
layer {
  bottom: "fc1_tnet2"
  top: "fc2_tnet2"
  param {
    lr_mult: 1
    decay_mult: 1
  param {
    lr_mult: 1
    decay_mult: 1
    num_output: 256
    weight_filler {
      type: "gaussian"
      std: 0.001
    bias_filler {
      type: "constant"
      value: 0
layer {
  type: "BatchNorm"
  bottom: "fc2_tnet2"
  top: "fc2_tnet2"
layer {
    bottom: "fc2_tnet2"
    top: "fc2_tnet2"
    type: "Scale"
    scale_param {
        bias_term: true
layer {
  type: "ReLU"
  bottom: "fc2_tnet2"
  top: "fc2_tnet2"
layer {
  bottom: "fc2_tnet2"
  top: "fc3_tnet2"
  param {
    lr_mult: 1
    decay_mult: 1
  param {
    lr_mult: 1
    decay_mult: 1
    num_output: 4096 # 64*64
    weight_filler {
      type: "constant"
      value: 0
    bias_filler {
      type: "constant"
      value: 0
layer {
    type: "Reshape"
    bottom: "fc3_tnet2"
    top: "fc3_tnet2_reshape"
    reshape_param {
      shape {
		dim: -1
        dim: 64
        dim: 64
#layer {
#  name: "eye_tnet2"
#  type: "Python"
#  bottom: "fc3_tnet2"
#  top: "eye_tnet2"
#  python_param {
#	param_str: "{\'K\': 64}"
layer {
  type: "Eltwise"
  bottom: "fc3_tnet2_reshape"
 # bottom: "eye_tnet2"
  top: "transform2"
# -------------------- feat transform ---------------------
layer {
  type: "Permute"
  bottom: "conv2" # Bx64xNx1
  top: "scale2_permute" # BxNx64x1
  permute_param {
    order: 0
    order: 2
    order: 1
    order: 3
layer {
    type: "Reshape"
    bottom: "scale2_permute"  # BxNx64x1
    top: "scale2_reshape"  # BxNx64
    reshape_param {
      shape {
        dim: -1
        dim: 64 # infer it from the other dimensions
#layer {
#  name: "matmul_feat"
#  bottom: "scale2_reshape" # BxNx64
#  bottom: "transform2" # 64x64
#  top: "scale2_transform2" # BxNx64
layer {
  type: "Permute"
  bottom: "scale2_transform2" # BxNx64
  top: "scale2_permute_transform2" # Bx64xN
  permute_param {
    order: 0
    order: 2
    order: 1
layer {
    type: "Reshape"
    bottom: "scale2_permute_transform2" # Bx64xN
    top: "scale2_transform2_reshape" # Bx64xNx1
    reshape_param {
      shape {
        dim: 0
        dim: 0
        dim: 1
layer {
  type: "Convolution"
  bottom: "scale2_transform2_reshape"
  top: "conv3"
  param {
    lr_mult: 1
  param {
    lr_mult: 2
  convolution_param {
    num_output: 64
    pad: 0
    kernel_w: 1
    kernel_h: 1
    stride: 1
    weight_filler {
      type: "xavier"
    bias_filler {
      type: "constant"
      value: 0
layer {
  type: "BatchNorm"
  bottom: "conv3"
  top: "conv3"
layer {
    bottom: "conv3"
    top: "conv3"
    type: "Scale"
    scale_param {
        bias_term: true
layer {
  type: "ReLU"
  bottom: "conv3"
  top: "conv3"
layer {
  type: "Convolution"
  bottom: "conv3"
  top: "conv4"
  param {
    lr_mult: 1
  param {
    lr_mult: 2
  convolution_param {
    num_output: 128
    pad: 0
    kernel_w: 1
    kernel_h: 1
    stride: 1
    weight_filler {
      type: "xavier"
    bias_filler {
      type: "constant"
      value: 0
layer {
  type: "BatchNorm"
  bottom: "conv4"
  top: "conv4"
layer {
    bottom: "conv4"
    top: "conv4"
    type: "Scale"
    scale_param {
        bias_term: true
layer {
  type: "ReLU"
  bottom: "conv4"
  top: "conv4"
layer {
  type: "Convolution"
  bottom: "conv4"
  top: "conv5"
  param {
    lr_mult: 1
  param {
    lr_mult: 2
  convolution_param {
    num_output: 1024
    pad: 0
    kernel_w: 1
    kernel_h: 1
    stride: 1
    weight_filler {
      type: "xavier"
    bias_filler {
      type: "constant"
      value: 0
layer {
  type: "BatchNorm"
  bottom: "conv5"
  top: "conv5"
layer {
    bottom: "conv5"
    top: "conv5"
    type: "Scale"
    scale_param {
        bias_term: true
layer {
  type: "ReLU"
  bottom: "conv5"
  top: "conv5"
# -------------------- max pool ---------------------
layer {
  type: "Pooling"
  bottom: "conv5"
  top: "global_feat"
  pooling_param {
    pool: MAX
    pad: 0
    kernel_h: 2048
    kernel_w: 1
    stride: 1
# -------------------- fc ---------------------
layer {
  bottom: "global_feat"
  top: "fc1"
  param {
    lr_mult: 1
    decay_mult: 1
  param {
    lr_mult: 1
    decay_mult: 1
    num_output: 512
    weight_filler {
      type: "gaussian"
      std: 0.001
    bias_filler {
      type: "constant"
      value: 0
layer {
  type: "BatchNorm"
  bottom: "fc1"
  top: "fc1"
layer {
    bottom: "fc1"
    top: "fc1"
    type: "Scale"
    scale_param {
        bias_term: true
layer {
  type: "ReLU"
  bottom: "fc1"
  top: "fc1"
layer {
  bottom: "fc1"
  top: "fc2"
  param {
    lr_mult: 1
    decay_mult: 1
  param {
    lr_mult: 1
    decay_mult: 1
    num_output: 256
    weight_filler {
      type: "gaussian"
      std: 0.001
    bias_filler {
      type: "constant"
      value: 0
layer {
  type: "BatchNorm"
  bottom: "fc2"
  top: "fc2"
layer {
    bottom: "fc2"
    top: "fc2"
    type: "Scale"
    scale_param {
        bias_term: true
layer {
  type: "ReLU"
  bottom: "fc2"
  top: "fc2"
layer {
  type: "Dropout"
  bottom: "fc2"
  top: "drop1"
  dropout_param {
    dropout_ratio: 0.3
layer {
  bottom: "drop1"
  top: "fc3"
  param {
    lr_mult: 1
    decay_mult: 1
  param {
    lr_mult: 1
    decay_mult: 1
    num_output: 40
    weight_filler {
      type: "gaussian"
      std: 0.001
    bias_filler {
      type: "constant"
      value: 0
#layer {
 # name: "accuracy"
 # type: "Accuracy"
 # bottom: "fc3"
 # bottom: "label"
 # top: "accuracy"
 # include {
 #   phase: TEST
layer {
  #type: "SoftmaxWithLoss"
  type:"Softmax"
  bottom: "fc3"
  bottom: "label"
  top: "loss"
# Enforce the transformation as orthogonal matrix
layer {
  type: "Permute"
  bottom: "transform2" # Bx64x64
  top: "transform2_transpose" # Bx64x64
  permute_param {
    order: 0
    order: 2
    order: 1
#layer {
 # name: "matmul_feat_loss"
 # bottom: "transform2_transpose"
 # top: "transform2_mul" # Bx64x64
#layer {
#  name: "loss_feat"
#  type: "EuclideanLoss"
#  bottom: "transform2_mul"
#  top: "loss_feat"
#  loss_weight: 0.001
