I'm using PSDKLA Release 06.02.00 for J7-EVM. GPU driver crashes often under load, and sometimes causes an unrecoverable kernel crash. After this crash the display freezes and kernel is in an unrecoverable state.
To reproduce the issue, autoboot TI Linux SDK prebuilt images and run the following command on shell after login:
# for i in `seq 1 100`; do glmark2-es2-wayland; done
Let the test run till the issue is reproduced. Here's a test log for PSDKLA Release 06.02.00 prebuilt images:
[desktop] blur-radius=5:effect=blur:passes=1:separable=true:wind[ 8801.695086] PVR_K: 1273: GPU 3D command buffer usage high (92). This is not an error but the application may not run optimally. ows=4:[ 8815.923127] PVR_K:(Error): 338: DevicesWatchdogThread: Device status not OK!!! [ 8815.930521] PVR_K: 338: ------------[ PVR DBG: START (High) ]------------ [ 8815.937386] PVR_K: 338: OS kernel info: Linux 4.19.94-g5a23bc00e0 #1 SMP PREEMPT Mon Feb 17 09:01:06 UTC 2020 aarch64 [ 8815.948065] PVR_K: 338: DDK info: Rogue_DDK_Linux_WS rogueddk 1.10@5371573 (release) j721e_linux [ 8815.956977] PVR_K: 338: Time now: 00000020d78d3ef [ 8815.961761] PVR_K: 338: Services State: OK [ 8815.965944] PVR_K: 338: Active connects: 733 (weston), 1273 (glmark2-es2-way) [ 8815.973159] PVR_K: 338: ------[ Driver Info ]------ [ 8815.978212] PVR_K: 338: UM info: 1.10 @ 5371573 (release) build options: 0x80000810 [ 8815.986121] PVR_K: 338: KM info: 1.10 @ 5371573 (release) build options: 0x00000810 [ 8815.994027] PVR_K: 338: FW info: 1.10 @ 5371573 (release) build options: 0x80000810 [ 8816.001928] PVR_K: 338: Comparison of UM/KM components: MATCHING [ 8816.008012] PVR_K: 338: KM Arch: 64 Bit [ 8816.011926] PVR_K: 338: UM Connected Clients: 64 Bit [ 8816.016969] PVR_K: 338: ------[ RGX summary ]------ [ 8816.021923] PVR_K: 338: RGX BVNC: 22.104.208.318 [ 8816.026620] PVR_K: 338: RGX Device State: Active [ 8816.031314] PVR_K: 338: RGX Power State: ON [ 8816.035581] PVR_K: 338: BIF0 - OK [ 8816.038970] PVR_K: 338: RGX FW State: NOT RESPONDING - KCCB stalled (HWRState 0x00000001: HWR OK; ) [ 8816.048085] PVR_K: 338: RGX FW Power State: RGXFWIF_POW_ON (APM disabled: 0 ok, 0 denied, 0 non-idle, 0 other, 0 total. Latency: 100 ms) [ 8816.060464] PVR_K: 338: RGX DVFS: 0 frequency changes. Current frequency: 749 MHz (sampled at 8049903458a) [ 8816.070189] PVR_K: 338: RGX FW OS 0 State: 0x00000003 (Active: Yes, Freelists: Ok, Grow Request Pending: No) [ 8816.080086] PVR_K: 338: RGX FW OS 1 State: 0x00000003 (Active: Yes, Freelists: Ok, Grow Request Pending: No) [ 8816.089989] PVR_K: 338: Number of HWR: GP(0/0+0), 2D(0/0+0), TA(4/4+0), 3D(2/2+0), CDM(0/0+0), FALSE(0,0,0,0,0) [ 8816.100147] PVR_K: 338: DM 0 (GP) [ 8816.103547] PVR_K: 338: DM 1 (HWRflags 0x00000000: working; ) [ 8816.109373] PVR_K: 338: DM 2 (HWRflags 0x00000000: working; ) [ 8816.115196] PVR_K: 338: Recovery 1: PID = 1225, frame = 8723, HWRTData = 0xC0075C00, EventStatus = 0x00004410, Innocent Lockup [ 8816.126827] PVR_K: 338: CRTimer = 0x000495AD588A, OSTimer = 6730.711539377, CyclesElapsed = 32131840 [ 8816.137243] PVR_K: 338: PreResetTimeInCycles = 151552, HWResetTimeInCycles = 40140288, FreelistReconTimeInCycles = 1177735680, TotalRecoveryTimeInCycles = 1218027520 [ 8816.153295] PVR_K: 338: Recovery 2: PID = 1225, frame = 8785, HWRTData = 0xC0075C00, EventStatus = 0x00004410, Guilty Lockup [ 8816.164782] PVR_K: 338: CRTimer = 0x000495F7E06A, OSTimer = 6732.378764447, CyclesElapsed = 32129280 [ 8816.175201] PVR_K: 338: PreResetTimeInCycles = 49408, HWResetTimeInCycles = 40139520, FreelistReconTimeInCycles = 230144, TotalRecoveryTimeInCycles = 40419072 [ 8816.190720] PVR_K: 338: Recovery 3: PID = 1225, frame = 8787, HWRTData = 0xC0075C00, EventStatus = 0x00004410, Innocent Lockup [ 8816.202355] PVR_K: 338: CRTimer = 0x000495FC5454, OSTimer = 6732.478371658, CyclesElapsed = 32129792 [ 8816.212772] PVR_K: 338: PreResetTimeInCycles = 153088, HWResetTimeInCycles = 40139008, FreelistReconTimeInCycles = 248064, TotalRecoveryTimeInCycles = 40540160 [ 8816.228304] PVR_K: 338: Recovery 4: PID = 1225, frame = 8788, HWRTData = 0xC0075D80, EventStatus = 0x00004410, Guilty Lockup [ 8816.239759] PVR_K: 338: CRTimer = 0x00049600B75D, OSTimer = 6732.576503967, CyclesElapsed = 32120832 [ 8816.250176] PVR_K: 338: PreResetTimeInCycles = 47616, HWResetTimeInCycles = 40139008, FreelistReconTimeInCycles = 283392, TotalRecoveryTimeInCycles = 40470016 [ 8816.265619] PVR_K: 338: DM 3 (HWRflags 0x00000000: working; ) [ 8816.271484] PVR_K: 338: Recovery 1: PID = 1225, frame = 8783, HWRTData = 0xC0075C00, EventStatus = 0x00004410, Innocent Lockup [ 8816.283141] PVR_K: 338: CRTimer = 0x000495AD5920, OSTimer = 6730.711590577, CyclesElapsed = 32018944 [ 8816.293560] PVR_K: 338: PreResetTimeInCycles = 113152, HWResetTimeInCycles = 40140288, FreelistReconTimeInCycles = 1177735680, TotalRecoveryTimeInCycles = 1217989120 [ 8816.309612] PVR_K: 338: Recovery 3: PID = 733, frame = 270931, HWRTData = 0xC0075340, EventStatus = 0x00004410, Innocent Lockup [ 8816.321335] PVR_K: 338: CRTimer = 0x000495FC54DD, OSTimer = 6732.478418421, CyclesElapsed = 32032768 [ 8816.331751] PVR_K: 338: PreResetTimeInCycles = 118016, HWResetTimeInCycles = 40139008, FreelistReconTimeInCycles = 248064, TotalRecoveryTimeInCycles = 40505088 [ 8816.347283] PVR_K: 338: DM 4 (HWRflags 0x00000000: working; ) [ 8816.353106] PVR_K: 338: ------[ RGX registers ]------ [ 8816.358264] PVR_K: 338: RGX Register Base Address (Linear): 0x000000006ef3663f [ 8816.365733] PVR_K: 338: RGX Register Base Address (Physical): 0x4E20000000 [ 8816.372694] PVR_K: 338: CORE_ID : 0x0000000008470000 [ 8816.379678] PVR_K: 338: CORE_REVISION : 0x00D0013E [ 8816.385937] PVR_K: 338: DESIGNER_REV_FIELD1 : 0x00000000 [ 8816.392193] PVR_K: 338: DESIGNER_REV_FIELD2 : 0x00000000 [ 8816.398449] PVR_K: 338: CHANGESET_NUMBER : 0x0000000000000000 [ 8816.405397] PVR_K: 338: CLK_CTRL : 0x0AAAAA002A2AAAAA [ 8816.412346] PVR_K: 338: CLK_STATUS : 0x0000000000600000 [ 8816.419294] PVR_K: 338: CLK_CTRL2 : 0x0000000000000000 [ 8816.426243] PVR_K: 338: CLK_STATUS2 : 0x0000000000000000 [ 8816.433190] PVR_K: 338: EVENT_STATUS : 0x00004410 [ 8816.439446] PVR_K: 338: TIMER : 0x0000000601E0EF23 [ 8816.446394] PVR_K: 338: BIF_FAULT_BANK0_MMU_STATUS : 0x00000000 [ 8816.452655] PVR_K: 338: BIF_FAULT_BANK0_REQ_STATUS : 0x0000000000000000 [ 8816.459604] PVR_K: 338: BIF_FAULT_BANK1_MMU_STATUS : 0x00000000 [ 8816.465860] PVR_K: 338: BIF_FAULT_BANK1_REQ_STATUS : 0x0000000000000000 [ 8816.472808] PVR_K: 338: BIF_MMU_STATUS : 0x00000000 [ 8816.479063] PVR_K: 338: BIF_MMU_ENTRY : 0x00000000 [ 8816.485346] PVR_K: 338: BIF_MMU_ENTRY_STATUS : 0x0000000000000000 [ 8816.492299] PVR_K: 338: BIF_STATUS_MMU : 0x00000000 [ 8816.498553] PVR_K: 338: BIF_READS_EXT_STATUS : 0x00000000 [ 8816.504809] PVR_K: 338: BIF_READS_INT_STATUS : 0x00000000 [ 8816.511063] PVR_K: 338: BIFPM_STATUS_MMU : 0x00000000 [ 8816.517318] PVR_K: 338: BIFPM_READS_EXT_STATUS : 0x00000000 [ 8816.523572] PVR_K: 338: BIFPM_READS_INT_STATUS : 0x00000000 [ 8816.529827] PVR_K: 338: Warning: BRN44871 is present [ 8816.534869] PVR_K: 338: BIF_CAT_BASE_INDEX : 0x0000000000000401 [ 8816.541817] PVR_K: 338: BIF_CAT_BASE0 : 0x0000000000000000 [ 8816.548765] PVR_K: 338: BIF_CAT_BASE1 : 0x00000008C6E10000 [ 8816.555713] PVR_K: 338: BIF_CAT_BASE2 : 0x0000000888CF0000 [ 8816.562661] PVR_K: 338: BIF_CAT_BASE3 : 0x00000008891B0000 [ 8816.569610] PVR_K: 338: BIF_CAT_BASE4 : 0x0000000887FE0000 [ 8816.576558] PVR_K: 338: BIF_CAT_BASE5 : 0x00000008DF330000 [ 8816.583512] PVR_K: 338: BIF_CAT_BASE6 : 0x00000008D52C0000 [ 8816.590489] PVR_K: 338: BIF_CAT_BASE7 : 0x00000008846D0000 [ 8816.597463] PVR_K: 338: BIF_CTRL_INVAL : 0x00000000 [ 8816.603720] PVR_K: 338: BIF_CTRL : 0x000000C0 [ 8816.609977] PVR_K: 338: BIF_PM_CAT_BASE_VCE0 : 0x00000008C873D001 [ 8816.616926] PVR_K: 338: BIF_PM_CAT_BASE_TE0 : 0x00000008C8732001 [ 8816.623876] PVR_K: 338: BIF_PM_CAT_BASE_ALIST0 : 0x00000008C8727001 [ 8816.630824] PVR_K: 338: BIF_PM_CAT_BASE_VCE1 : 0x00000008CAD73001 [ 8816.637773] PVR_K: 338: BIF_PM_CAT_BASE_TE1 : 0x0000000892FB4001 [ 8816.644737] PVR_K: 338: BIF_PM_CAT_BASE_ALIST1 : 0x00000008D86B6001 [ 8816.651686] PVR_K: 338: PERF_TA_PHASE : 0x0022C513 [ 8816.657941] PVR_K: 338: PERF_TA_CYCLE : 0x65F3F3DF [ 8816.664197] PVR_K: 338: PERF_3D_PHASE : 0x002315DA [ 8816.670451] PVR_K: 338: PERF_3D_CYCLE : 0x6C2F003C [ 8816.676708] PVR_K: 338: PERF_TA_OR_3D_CYCLE : 0x81EEBFEF [ 8816.682962] PVR_K: 338: PERF_TA_AND_3D_CYCLE : 0x5034342C [ 8816.689216] PVR_K: 338: PERF_COMPUTE_PHASE : 0x00000000 [ 8816.695470] PVR_K: 338: PERF_COMPUTE_CYCLE : 0x00000000 [ 8816.701726] PVR_K: 338: PM_PARTIAL_RENDER_ENABLE : 0x00000000 [ 8816.707981] PVR_K: 338: ISP_RENDER : 0x00000003 [ 8816.714244] PVR_K: 338: TLA_STATUS : 0x0000000000000000 [ 8816.721193] PVR_K: 338: MCU_FENCE : 0x0000018000000000 [ 8816.728141] PVR_K: 338: VDM_CONTEXT_STORE_STATUS : 0x00000001 [ 8816.734395] PVR_K: 338: VDM_CONTEXT_STORE_TASK0 : 0x0002020522001004 [ 8816.741344] PVR_K: 338: VDM_CONTEXT_STORE_TASK1 : 0x0000000000020240 [ 8816.748292] PVR_K: 338: VDM_CONTEXT_STORE_TASK2 : 0x0002000000000420 [ 8816.755242] PVR_K: 338: VDM_CONTEXT_RESUME_TASK0 : 0x0002030520011004 [ 8816.762191] PVR_K: 338: VDM_CONTEXT_RESUME_TASK1 : 0x0000000000020340 [ 8816.769139] PVR_K: 338: VDM_CONTEXT_RESUME_TASK2 : 0x0002010000000420 [ 8816.776087] PVR_K: 338: ISP_CTL : 0x0002B000 [ 8816.782342] PVR_K: 338: ISP_STATUS : 0x00000003 [ 8816.788597] PVR_K: 338: MTS_INTCTX : 0x00000000 [ 8816.794852] PVR_K: 338: MTS_BGCTX : 0x00000000 [ 8816.801106] PVR_K: 338: MTS_BGCTX_COUNTED_SCHEDULE : 0x0000006B [ 8816.807387] PVR_K: 338: MTS_SCHEDULE : 0x00000000 [ 8816.813642] PVR_K: 338: MTS_GPU_INT_STATUS : 0x00004550 [ 8816.819898] PVR_K: 338: CDM_CONTEXT_STORE_STATUS : 0x00000000 [ 8816.826152] PVR_K: 338: CDM_CONTEXT_PDS0 : 0x0000000000000000 [ 8816.833100] PVR_K: 338: CDM_CONTEXT_PDS1 : 0x0000000000000000 [ 8816.840052] PVR_K: 338: CDM_TERMINATE_PDS : 0x0000000000000000 [ 8816.847002] PVR_K: 338: CDM_TERMINATE_PDS1 : 0x0000000000000000 [ 8816.853950] PVR_K: 338: SIDEKICK_IDLE : 0x0000007E [ 8816.860206] PVR_K: 338: SLC_IDLE : 0x000000FF [ 8816.866460] PVR_K: 338: SLC_STATUS0 : 0x00000000 [ 8816.872715] PVR_K: 338: SLC_STATUS1 : 0x0000000000000000 [ 8816.879663] PVR_K: 338: SLC_CTRL_BYPASS : 0x01000000 [ 8816.885919] PVR_K: 338: SLC_CTRL_MISC : 0x0000000000200003 [ 8816.892867] PVR_K: 338: MIPS_ADDR_REMAP1_CONFIG1 : 0x1FC00001 [ 8816.899124] PVR_K: 338: MIPS_ADDR_REMAP1_CONFIG2 : 0x00000008C4F5F00C [ 8816.906072] PVR_K: 338: MIPS_ADDR_REMAP2_CONFIG1 : 0x1FC01001 [ 8816.912327] PVR_K: 338: MIPS_ADDR_REMAP2_CONFIG2 : 0x00000008C591E00C [ 8816.919328] PVR_K: 338: MIPS_ADDR_REMAP3_CONFIG1 : 0x1FC02001 [ 8816.925587] PVR_K: 338: MIPS_ADDR_REMAP3_CONFIG2 : 0x00000008C4F5E00C [ 8816.932535] PVR_K: 338: MIPS_ADDR_REMAP4_CONFIG1 : 0xC63E0001 [ 8816.938791] PVR_K: 338: MIPS_ADDR_REMAP4_CONFIG2 : 0x000000001FC0000E [ 8816.945738] PVR_K: 338: MIPS_ADDR_REMAP5_CONFIG1 : 0x00000001 [ 8816.951994] PVR_K: 338: MIPS_ADDR_REMAP5_CONFIG2 : 0x00000008C4F5F00C [ 8816.958942] PVR_K: 338: MIPS_WRAPPER_CONFIG : 0x000000000001CF40 [ 8816.965891] PVR_K: 338: MIPS_EXCEPTION_STATUS : 0x00000022 [ 8816.972232] PVR_K: 338: ---- [ MIPS internal state ] ---- [ 8816.977709] PVR_K: 338: PC : 0x9FC0233A [ 8816.983962] PVR_K: 338: STATUS_REGISTER : 0x00481006 [ 8816.990217] PVR_K: 338: CAUSE_REGISTER : 0x40800C10 [ 8816.996471] PVR_K: 338: Cause exception: Address error exception (load/instruction fetch) [ 8817.005066] PVR_K: 338: BAD_REGISTER : 0xC00E811F [ 8817.011320] PVR_K: 338: EPC : 0xC000A8C8 [ 8817.017575] PVR_K: 338: SP : 0xCF600E70 [ 8817.023846] PVR_K: 338: BAD_INSTRUCTION : 0x00000000 [ 8817.030103] PVR_K: 338: TLB : [ 8817.035406] PVR_K: 338: 0) VA 0xCF400000 (256k) -> PA0 0xE20000000 DV , PA1 0x00000000 C [ 8817.044003] PVR_K: 338: 1) VA 0xCF000000 ( 16k) -> PA0 0x8C69B0000 DVGC, PA1 0x8C69B4000 DVGC [ 8817.052684] PVR_K: 338: 2) VA 0xCF600000 ( 4k) -> PA0 0x8C591F000 DV C, PA1 0x00000000 C [ 8817.061279] PVR_K: 338: 3) VA 0xC0074000 ( 4k) -> PA0 0x8C4F42000 DVG , PA1 0x8C7630000 DVGC [ 8817.069961] PVR_K: 338: 4) VA 0xC00E6000 ( 4k) -> PA0 0x88C045000 DVGC, PA1 0x88C046000 DVGC [ 8817.078645] PVR_K: 338: 5) VA 0xC0042000 ( 4k) -> PA0 0x8C5912000 DVGC, PA1 0x8C5913000 DVGC [ 8817.087326] PVR_K: 338: 6) VA 0xF000C000 ( 4k) -> PA0 0x00000000 C, PA1 0x00000000 C [ 8817.095834] PVR_K: 338: 7) VA 0xC00E2000 ( 4k) -> PA0 0x88C041000 DVGC, PA1 0x88C042000 DVGC [ 8817.104521] PVR_K: 338: 8) VA 0xC00E8000 ( 4k) -> PA0 0x88C047000 DVGC, PA1 0x894120000 DVGC [ 8817.113204] PVR_K: 338: 9) VA 0xC00E0000 ( 4k) -> PA0 0xEB402E000 , PA1 0x88C040000 DV C [ 8817.121885] PVR_K: 338: 10) VA 0xC0040000 ( 4k) -> PA0 0x8C5910000 DVGC, PA1 0x8C5911000 DVGC [ 8817.130567] PVR_K: 338: 11) VA 0xC00E4000 ( 4k) -> PA0 0x88C043000 DVGC, PA1 0x88C044000 DVGC [ 8817.139248] PVR_K: 338: 12) VA 0xC001A000 ( 4k) -> PA0 0x8C4ADA000 DVGC, PA1 0x8C4ADB000 DVGC [ 8817.147930] PVR_K: 338: 13) VA 0xC00B0000 ( 4k) -> PA0 0x8D4000000 DVG , PA1 0x8CCB80000 DVG [ 8817.156611] PVR_K: 338: 14) VA 0xC000A000 ( 4k) -> PA0 0x8C72DA000 DVGC, PA1 0x8C72DB000 DVGC [ 8817.165292] PVR_K: 338: 15) VA 0xC0052000 ( 4k) -> PA0 0x8C4740000 DVG , PA1 0x8C6C10000 VGC [ 8817.173975] PVR_K: 338: -------------------------------- [ 8817.179364] PVR_K: 338: RGX Kernel CCB WO:0x29 RO:0x3E [ 8817.184579] PVR_K: 338: RGX Firmware CCB WO:0x18 RO:0x18 [ 8817.189968] PVR_K: 338: RGX Kernel CCB commands executed = 21032638 [ 8817.196327] PVR_K: 338: Thread0: FW IRQ count = 14947679 [ 8817.201718] PVR_K: 338: Last sampled IRQ count in LISR = 14947679 [ 8817.207887] PVR_K: 338: FW OS config flags = 0x800127 (Ctx switch: TA; 3D; CDM; VDM CS INDEX mode; Medium CSW profile; Use extended; HWR EN; ) [ 8817.220732] PVR_K: 338: Device System Power State: ON [ 8817.225867] PVR_K: 338: Debug log type: none [ 8817.230217] PVR_K: 338: RGX FW thread 0: Trace buffer not yet allocated [ 8817.236910] PVR_K: 338: ------[ Stalled FWCtxs ]------ [ 8817.242131] PVR_K: 338: FWCtx 0xC0075100 @ 29480 (TA-P733-T733-weston) pending on FENCE: [ 8817.250293] PVR_K: 338: Addr:0xc0078050 Value=0x0005fe9a [ 8817.255942] PVR_K: 338: Addr:0xc007c021 Value=0x00000519 [ 8817.261590] PVR_K: 338: Addr:0xc00c0001 Value=0x00000519 [ 8817.267239] PVR_K: 338: FWCtx 0xC0075100 fenced command is of type TA [ 8817.273839] PVR_K: 338: preventing UPDATE: [ 8817.278101] PVR_K: 338: Addr:0xc0078050 Value=0x0005fe9b [ 8817.283749] PVR_K: 338: Addr:0xc0079000 Value=0x0000579c [ 8817.289397] PVR_K: 338: Addr:0xc0079004 Value=0x0000a240 [ 8817.295044] PVR_K: 338: Addr:0xc0079008 Value=0x00000000 [ 8817.300692] PVR_K: 338: Addr:0xc007900c Value=0x00018bd4 [ 8817.306338] PVR_K: 338: Addr:0xc0079010 Value=0x00017034 [ 8817.311986] PVR_K: 338: Addr:0xc0079014 Value=0x00000000 [ 8817.317634] PVR_K: 338: Addr:0xc007d011 Value=0x00000519 [ 8817.323323] PVR_K: 338: FWCtx 0xC00751A0 @ 50112 (3D-P733-T733-weston) pending on FENCE_PR: [ 8817.331747] PVR_K: 338: Addr:0xc0078050 Value=0x0005fe9b [ 8817.337396] PVR_K: 338: FWCtx 0xC00751A0 fenced command is of type 3D_PR [ 8817.344259] PVR_K: 338: FWCtx 0xC00B4240 @ 0 (TA-P1273-T1273-glmark2-es2-wa) pending on FENCE: [ 8817.352942] PVR_K: 338: Addr:0xc00b0084 Value=0x00000000 [ 8817.358610] PVR_K: 338: FWCtx 0xC00B4240 fenced command is of type TA [ 8817.365219] PVR_K: 338: preventing UPDATE: [ 8817.369480] PVR_K: 338: Addr:0xc00b0084 Value=0x00000001 [ 8817.375128] PVR_K: 338: Addr:0xc00b1000 Value=0x00000054 [ 8817.380805] PVR_K: 338: Addr:0xc00b1004 Value=0x00000040 [ 8817.386455] PVR_K: 338: Addr:0xc00b1008 Value=0x00000000 [ 8817.392102] PVR_K: 338: Addr:0xc00b100c Value=0x00000040 [ 8817.397749] PVR_K: 338: Addr:0xc00b1010 Value=0x00000074 [ 8817.403397] PVR_K: 338: Addr:0xc00b1048 Value=0x00000000 [ 8817.409045] PVR_K: 338: Addr:0xc00b2001 Value=0x00000519 [ 8817.414709] PVR_K: 338: FWCtx 0xC00B42E0 @ 0 (3D-P1273-T1273-glmark2-es2-wa) pending on FENCE_PR: [ 8817.423653] PVR_K: 338: Addr:0xc00b0084 Value=0x00000001 [ 8817.429300] PVR_K: 338: FWCtx 0xC00B42E0 fenced command is of type 3D_PR [ 8817.436168] PVR_K: 338: ------[ Active Sync Checkpoints ]------ [ 8817.442164] PVR_K: 338: - ID = 22578405, FWAddr = 0xc00bf5a0, r1:e0:f0: es3-DoKickTA-1 [ 8817.450239] PVR_K: 338: - ID = 22578404, FWAddr = 0xc00b2640, r1:e0:f0: es3-DoKickTA-1 [ 8817.458313] PVR_K: 338: - ID = 22578403, FWAddr = 0xc00bf598, r1:e0:f0: es3-DoKickTA-1 [ 8817.466389] PVR_K: 338: - ID = 22578402, FWAddr = 0xc00b2638, r1:e0:f0: es3-DoKickTA-1 [ 8817.474463] PVR_K: 338: - ID = 22578401, FWAddr = 0xc00bf590, r1:e0:f0: es3-DoKickTA-1 [ 8817.482538] PVR_K: 338: - ID = 22578400, FWAddr = 0xc00b2630, r1:e0:f0: es3-DoKickTA-1 [ 8817.490613] PVR_K: 338: - ID = 22578399, FWAddr = 0xc00bf588, r1:e0:f0: es3-DoKickTA-1 [ 8817.498717] PVR_K: 338: - ID = 22578398, FWAddr = 0xc00b2628, r1:e0:f0: es3-DoKickTA-1 [ 8817.506796] PVR_K: 338: - ID = 22578397, FWAddr = 0xc00bf580, r1:e0:f0: es3-DoKickTA-1 [ 8817.514872] PVR_K: 338: - ID = 22578396, FWAddr = 0xc00b2620, r1:e0:f0: es3-DoKickTA-1 [ 8817.522946] PVR_K: 338: - ID = 22578395, FWAddr = 0xc00bf578, r1:e0:f0: es3-DoKickTA-1 [ 8817.531036] PVR_K: 338: - ID = 22578394, FWAddr = 0xc00b2618, r1:e0:f0: es3-DoKickTA-1 [ 8817.539113] PVR_K: 338: - ID = 22578393, FWAddr = 0xc00bf570, r1:e0:f0: es3-DoKickTA-1 [ 8817.547189] PVR_K: 338: - ID = 22578392, FWAddr = 0xc00b2610, r1:e0:f0: es3-DoKickTA-1 [ 8817.555264] PVR_K: 338: - ID = 22578391, FWAddr = 0xc00bf568, r1:e0:f0: es3-DoKickTA-1 [ 8817.563339] PVR_K: 338: - ID = 22578390, FWAddr = 0xc00b2608, r1:e0:f0: es3-DoKickTA-1 [ 8817.571415] PVR_K: 338: - ID = 22578389, FWAddr = 0xc00bf560, r1:e0:f0: es3-DoKickTA-1 [ 8817.579490] PVR_K: 338: - ID = 22578388, FWAddr = 0xc00b2600, r1:e0:f0: es3-DoKickTA-1 [ 8817.587565] PVR_K: 338: - ID = 22578387, FWAddr = 0xc00bf558, r1:e0:f0: es3-DoKickTA-1 [ 8817.595661] PVR_K: 338: - ID = 22578386, FWAddr = 0xc00b25f8, r1:e0:f0: es3-DoKickTA-1 [ 8817.603739] PVR_K: 338: - ID = 22578385, FWAddr = 0xc00bf550, r1:e0:f0: es3-DoKickTA-1 [ 8817.611816] PVR_K: 338: - ID = 22578384, FWAddr = 0xc00b25f0, r1:e0:f0: es3-DoKickTA-1 [ 8817.619891] PVR_K: 338: - ID = 22578383, FWAddr = 0xc00bf548, r1:e0:f0: es3-DoKickTA-1 [ 8817.627972] PVR_K: 338: - ID = 22578382, FWAddr = 0xc00b25e8, r1:e0:f0: es3-DoKickTA-1 [ 8817.636047] PVR_K: 338: - ID = 22578381, FWAddr = 0xc00bf540, r1:e0:f0: es3-DoKickTA-1 [ 8817.644124] PVR_K: 338: - ID = 22578380, FWAddr = 0xc00b25e0, r1:e0:f0: es3-DoKickTA-1 [ 8817.652198] PVR_K: 338: - ID = 22578379, FWAddr = 0xc00bf538, r1:e0:f0: es3-DoKickTA-1 [ 8817.660273] PVR_K: 338: - ID = 22578378, FWAddr = 0xc00b25d8, r1:e0:f0: es3-DoKickTA-1 [ 8817.668348] PVR_K: 338: - ID = 22578377, FWAddr = 0xc00bf530, r1:e0:f0: es3-DoKickTA-1 [ 8817.676437] PVR_K: 338: - ID = 22578376, FWAddr = 0xc00b25d0, r1:e0:f0: es3-DoKickTA-1 [ 8817.684513] PVR_K: 338: - ID = 22578375, FWAddr = 0xc00bf528, r1:e0:f0: es3-DoKickTA-1 [ 8817.692589] PVR_K: 338: - ID = 22578374, FWAddr = 0xc00b25c8, r1:e0:f0: es3-DoKickTA-1 [ 8817.700679] PVR_K: 338: - ID = 22578373, FWAddr = 0xc00bf520, r1:e0:f0: es3-DoKickTA-1 [ 8817.708756] PVR_K: 338: - ID = 22578372, FWAddr = 0xc00b25c0, r1:e0:f0: es3-DoKickTA-1 [ 8817.716833] PVR_K: 338: - ID = 22578371, FWAddr = 0xc00bf518, r1:e0:f0: es3-DoKickTA-1 [ 8817.724909] PVR_K: 338: - ID = 22578370, FWAddr = 0xc00b25b8, r1:e0:f0: es3-DoKickTA-1 [ 8817.732984] PVR_K: 338: - ID = 22578369, FWAddr = 0xc00bf510, r1:e0:f0: es3-DoKickTA-1 [ 8817.741060] PVR_K: 338: - ID = 22578368, FWAddr = 0xc00b25b0, r1:e0:f0: es3-DoKickTA-1 [ 8817.749135] PVR_K: 338: - ID = 22578367, FWAddr = 0xc00bf508, r1:e0:f0: es3-DoKickTA-1 [ 8817.757216] PVR_K: 338: - ID = 22578366, FWAddr = 0xc00b25a8, r1:e0:f0: es3-DoKickTA-1 [ 8817.765291] PVR_K: 338: - ID = 22578365, FWAddr = 0xc00bf500, r1:e0:f0: es3-DoKickTA-1 [ 8817.773367] PVR_K: 338: - ID = 22578364, FWAddr = 0xc00b25a0, r1:e0:f0: es3-DoKickTA-1 [ 8817.781442] PVR_K: 338: - ID = 22578363, FWAddr = 0xc00bf4f8, r1:e0:f0: es3-DoKickTA-1 [ 8817.789517] PVR_K: 338: - ID = 22578362, FWAddr = 0xc00b2598, r1:e0:f0: es3-DoKickTA-1 [ 8817.797591] PVR_K: 338: - ID = 22578361, FWAddr = 0xc00bf4f0, r1:e0:f0: es3-DoKickTA-1 [ 8817.805667] PVR_K: 338: - ID = 22578360, FWAddr = 0xc00b2590, r1:e0:f0: es3-DoKickTA-1 [ 8817.813743] PVR_K: 338: - ID = 22578359, FWAddr = 0xc00bf4e8, r1:e0:f0: es3-DoKickTA-1 [ 8817.821819] PVR_K: 338: - ID = 22578358, FWAddr = 0xc00b2588, r1:e0:f0: es3-DoKickTA-1 [ 8817.829894] PVR_K: 338: - ID = 22578357, FWAddr = 0xc00bf4e0, r1:e0:f0: es3-DoKickTA-1 [ 8817.837969] PVR_K: 338: - ID = 22578356, FWAddr = 0xc00b2580, r1:e0:f0: es3-DoKickTA-1 [ 8817.846044] PVR_K: 338: - ID = 22578355, FWAddr = 0xc00bf4d8, r1:e0:f0: es3-DoKickTA-1 [ 8817.854120] PVR_K: 338: - ID = 22578354, FWAddr = 0xc00b2578, r1:e0:f0: es3-DoKickTA-1 [ 8817.862194] PVR_K: 338: - ID = 22578353, FWAddr = 0xc00bf4d0, r1:e0:f0: es3-DoKickTA-1 [ 8817.870269] PVR_K: 338: - ID = 22578352, FWAddr = 0xc00b2570, r1:e0:f0: es3-DoKickTA-1 [ 8817.878344] PVR_K: 338: - ID = 22578351, FWAddr = 0xc00bf4c8, r1:e0:f0: es3-DoKickTA-1 [ 8817.886424] PVR_K: 338: - ID = 22578350, FWAddr = 0xc00b2568, r1:e0:f0: es3-DoKickTA-1 [ 8817.894500] PVR_K: 338: - ID = 22578349, FWAddr = 0xc00bf4c0, r1:e0:f0: es3-DoKickTA-1 [ 8817.902576] PVR_K: 338: - ID = 22578348, FWAddr = 0xc00b2560, r1:e0:f0: es3-DoKickTA-1 [ 8817.910659] PVR_K: 338: - ID = 22578347, FWAddr = 0xc00bf4b8, r1:e0:f0: es3-DoKickTA-1 [ 8817.918735] PVR_K: 338: - ID = 22578346, FWAddr = 0xc00b2558, r1:e0:f0: es3-DoKickTA-1 [ 8817.926810] PVR_K: 338: - ID = 22578345, FWAddr = 0xc00bf4b0, r1:e0:f0: es3-DoKickTA-1 [ 8817.934886] PVR_K: 338: - ID = 22578344, FWAddr = 0xc00b2550, r1:e0:f0: es3-DoKickTA-1 [ 8817.942961] PVR_K: 338: - ID = 22578343, FWAddr = 0xc00bf4a8, r1:e0:f0: es3-DoKickTA-1 [ 8817.951036] PVR_K: 338: - ID = 22578342, FWAddr = 0xc00b2548, r1:e0:f0: es3-DoKickTA-1 [ 8817.959123] PVR_K: 338: - ID = 22578341, FWAddr = 0xc00bf4a0, r1:e0:f0: es3-DoKickTA-1 [ 8817.967200] PVR_K: 338: - ID = 22578340, FWAddr = 0xc00b2540, r1:e0:f0: es3-DoKickTA-1 [ 8817.975275] PVR_K: 338: - ID = 22578339, FWAddr = 0xc00bf498, r1:e0:f0: es3-DoKickTA-1 [ 8817.983350] PVR_K: 338: - ID = 22578338, FWAddr = 0xc00b2538, r1:e0:f0: es3-DoKickTA-1 [ 8817.991426] PVR_K: 338: - ID = 22578337, FWAddr = 0xc00bf490, r1:e0:f0: es3-DoKickTA-1 [ 8817.999502] PVR_K: 338: - ID = 22578336, FWAddr = 0xc00b2530, r1:e0:f0: es3-DoKickTA-1 [ 8818.007577] PVR_K: 338: - ID = 22578335, FWAddr = 0xc00bf488, r1:e0:f0: es3-DoKickTA-1 [ 8818.015658] PVR_K: 338: - ID = 22578334, FWAddr = 0xc00b2528, r1:e0:f0: es3-DoKickTA-1 [ 8818.023732] PVR_K: 338: - ID = 22578333, FWAddr = 0xc00bf480, r1:e0:f0: es3-DoKickTA-1 [ 8818.031808] PVR_K: 338: - ID = 22578332, FWAddr = 0xc00b2520, r1:e0:f0: es3-DoKickTA-1 [ 8818.039883] PVR_K: 338: - ID = 22578331, FWAddr = 0xc00bf478, r1:e0:f0: es3-DoKickTA-1 [ 8818.047978] PVR_K: 338: - ID = 22578330, FWAddr = 0xc00b2518, r1:e0:f0: es3-DoKickTA-1 [ 8818.056055] PVR_K: 338: - ID = 22578329, FWAddr = 0xc00bf470, r1:e0:f0: es3-DoKickTA-1 [ 8818.064131] PVR_K: 338: - ID = 22578328, FWAddr = 0xc00b2510, r1:e0:f0: es3-DoKickTA-1 [ 8818.072206] PVR_K: 338: - ID = 22578327, FWAddr = 0xc00bf468, r1:e0:f0: es3-DoKickTA-1 [ 8818.080294] PVR_K: 338: - ID = 22578326, FWAddr = 0xc00b2508, r1:e0:f0: es3-DoKickTA-1 [ 8818.088370] PVR_K: 338: - ID = 22578325, FWAddr = 0xc00bf460, r1:e0:f0: es3-DoKickTA-1 [ 8818.096446] PVR_K: 338: - ID = 22578324, FWAddr = 0xc00b2500, r1:e0:f0: es3-DoKickTA-1 [ 8818.104520] PVR_K: 338: - ID = 22578323, FWAddr = 0xc00bf458, r1:e0:f0: es3-DoKickTA-1 [ 8818.112596] PVR_K: 338: - ID = 22578322, FWAddr = 0xc00b24f8, r1:e0:f0: es3-DoKickTA-1 [ 8818.120670] PVR_K: 338: - ID = 22578321, FWAddr = 0xc00bf450, r1:e0:f0: es3-DoKickTA-1 [ 8818.128763] PVR_K: 338: - ID = 22578320, FWAddr = 0xc00b24f0, r1:e0:f0: es3-DoKickTA-1 [ 8818.136839] PVR_K: 338: - ID = 22578319, FWAddr = 0xc00bf448, r1:e0:f0: es3-DoKickTA-1 [ 8818.144920] PVR_K: 338: - ID = 22578318, FWAddr = 0xc00b24e8, r1:e0:f0: es3-DoKickTA-1 [ 8818.152995] PVR_K: 338: - ID = 22578317, FWAddr = 0xc00bf440, r1:e0:f0: es3-DoKickTA-1 [ 8818.161084] PVR_K: 338: - ID = 22578316, FWAddr = 0xc00b24e0, r1:e0:f0: es3-DoKickTA-1 [ 8818.169160] PVR_K: 338: - ID = 22578315, FWAddr = 0xc00bf438, r1:e0:f0: es3-DoKickTA-1 [ 8818.177236] PVR_K: 338: - ID = 22578314, FWAddr = 0xc00b24d8, r1:e0:f0: es3-DoKickTA-1 [ 8818.185311] PVR_K: 338: - ID = 22578313, FWAddr = 0xc00bf430, r1:e0:f0: es3-DoKickTA-1 [ 8818.193386] PVR_K: 338: - ID = 22578312, FWAddr = 0xc00b24d0, r1:e0:f0: es3-DoKickTA-1 [ 8818.201460] PVR_K: 338: - ID = 22578311, FWAddr = 0xc00bf428, r1:e0:f0: es3-DoKickTA-1 [ 8818.209536] PVR_K: 338: - ID = 22578310, FWAddr = 0xc00b24c8, r1:e0:f0: es3-DoKickTA-1 [ 8818.217610] PVR_K: 338: - ID = 22578309, FWAddr = 0xc00bf420, r1:e0:f0: es3-DoKickTA-1 [ 8818.225686] PVR_K: 338: - ID = 22578308, FWAddr = 0xc00b24c0, r1:e0:f0: es3-DoKickTA-1 [ 8818.233760] PVR_K: 338: - ID = 22578307, FWAddr = 0xc00bf418, r1:e0:f0: es3-DoKickTA-1 [ 8818.241835] PVR_K: 338: - ID = 22578306, FWAddr = 0xc00b24b8, r1:e0:f0: es3-DoKickTA-1 [ 8818.249910] PVR_K: 338: - ID = 22578305, FWAddr = 0xc00bf410, r1:e0:f0: es3-DoKickTA-1 [ 8818.257986] PVR_K: 338: - ID = 22578304, FWAddr = 0xc00b24b0, r1:e0:f0: es3-DoKickTA-1 [ 8818.266060] PVR_K: 338: - ID = 22578303, FWAddr = 0xc00bf408, r1:e0:f0: es3-DoKickTA-1 [ 8818.274140] PVR_K: 338: - ID = 22578302, FWAddr = 0xc00b24a8, r1:e0:f0: es3-DoKickTA-1 [ 8818.282214] PVR_K: 338: - ID = 22578301, FWAddr = 0xc00bf400, r1:e0:f0: es3-DoKickTA-1 [ 8818.290291] PVR_K: 338: - ID = 22578300, FWAddr = 0xc00b24a0, r1:e0:f0: es3-DoKickTA-1 [ 8818.298365] PVR_K: 338: - ID = 22578299, FWAddr = 0xc00bf3f8, r1:e0:f0: es3-DoKickTA-1 [ 8818.306440] PVR_K: 338: - ID = 22578298, FWAddr = 0xc00b2498, r1:e0:f0: es3-DoKickTA-1 [ 8818.314515] PVR_K: 338: - ID = 22578297, FWAddr = 0xc00bf3f0, r1:e0:f0: es3-DoKickTA-1 [ 8818.322589] PVR_K: 338: - ID = 22578296, FWAddr = 0xc00b2490, r1:e0:f0: es3-DoKickTA-1 [ 8818.330663] PVR_K: 338: - ID = 22578295, FWAddr = 0xc00bf3e8, r1:e0:f0: es3-DoKickTA-1 [ 8818.338739] PVR_K: 338: - ID = 22578294, FWAddr = 0xc00b2488, r1:e0:f0: es3-DoKickTA-1 [ 8818.346813] PVR_K: 338: - ID = 22578293, FWAddr = 0xc00bf3e0, r1:e0:f0: es3-DoKickTA-1 [ 8818.354890] PVR_K: 338: - ID = 22578292, FWAddr = 0xc00b2480, r1:e0:f0: es3-DoKickTA-1 [ 8818.362964] PVR_K: 338: - ID = 22578291, FWAddr = 0xc00bf3d8, r1:e0:f0: es3-DoKickTA-1 [ 8818.371040] PVR_K: 338: - ID = 22578290, FWAddr = 0xc00b2478, r1:e0:f0: es3-DoKickTA-1 [ 8818.379115] PVR_K: 338: - ID = 22578289, FWAddr = 0xc00bf3d0, r1:e0:f0: es3-DoKickTA-1 [ 8818.387191] PVR_K: 338: - ID = 22578288, FWAddr = 0xc00b2470, r1:e0:f0: es3-DoKickTA-1 [ 8818.395266] PVR_K: 338: - ID = 22578287, FWAddr = 0xc00bf3c8, r1:e0:f0: es3-DoKickTA-1 [ 8818.403347] PVR_K: 338: - ID = 22578286, FWAddr = 0xc00b2468, r1:e0:f0: es3-DoKickTA-1 [ 8818.411422] PVR_K: 338: - ID = 22578285, FWAddr = 0xc00bf3c0, r1:e0:f0: es3-DoKickTA-1 [ 8818.419498] PVR_K: 338: - ID = 22578284, FWAddr = 0xc00b2460, r1:e0:f0: es3-DoKickTA-1 [ 8818.427572] PVR_K: 338: - ID = 22578283, FWAddr = 0xc00bf3b8, r1:e0:f0: es3-DoKickTA-1 [ 8818.435648] PVR_K: 338: - ID = 22578282, FWAddr = 0xc00b2458, r1:e0:f0: es3-DoKickTA-1 [ 8818.443722] PVR_K: 338: - ID = 22578281, FWAddr = 0xc00bf3b0, r1:e0:f0: es3-DoKickTA-1 [ 8818.451797] PVR_K: 338: - ID = 22578280, FWAddr = 0xc00b2450, r1:e0:f0: es3-DoKickTA-1 [ 8818.459872] PVR_K: 338: - ID = 22578279, FWAddr = 0xc00bf3a8, r1:e0:f0: es3-DoKickTA-1 [ 8818.467947] PVR_K: 338: - ID = 22578278, FWAddr = 0xc00b2448, r1:e0:f0: es3-DoKickTA-1 [ 8818.476023] PVR_K: 338: - ID = 22578277, FWAddr = 0xc00bf3a0, r1:e0:f0: es3-DoKickTA-1 [ 8818.484098] PVR_K: 338: - ID = 22578276, FWAddr = 0xc00b2440, r1:e0:f0: es3-DoKickTA-1 [ 8818.492173] PVR_K: 338: - ID = 22578275, FWAddr = 0xc00bf398, r1:e0:f0: es3-DoKickTA-1 [ 8818.500282] PVR_K: 338: - ID = 22578274, FWAddr = 0xc00b2438, r1:e0:f0: es3-DoKickTA-1 [ 8818.508359] PVR_K: 338: - ID = 22578273, FWAddr = 0xc00bf390, r1:e0:f0: es3-DoKickTA-1 [ 8818.516434] PVR_K: 338: - ID = 22578272, FWAddr = 0xc00b2430, r1:e0:f0: es3-DoKickTA-1 [ 8818.524509] PVR_K: 338: - ID = 22578271, FWAddr = 0xc00bf388, r1:e0:f0: es3-DoKickTA-1 [ 8818.532590] PVR_K: 338: - ID = 22578270, FWAddr = 0xc00b2428, r1:e0:f0: es3-DoKickTA-1 [ 8818.540665] PVR_K: 338: - ID = 22578269, FWAddr = 0xc00bf380, r1:e0:f0: es3-DoKickTA-1 [ 8818.548754] PVR_K: 338: - ID = 22578268, FWAddr = 0xc00b2420, r1:e0:f0: es3-DoKickTA-1 [ 8818.556831] PVR_K: 338: - ID = 22578267, FWAddr = 0xc00bf378, r1:e0:f0: es3-DoKickTA-1 [ 8818.564907] PVR_K: 338: - ID = 22578266, FWAddr = 0xc00b2418, r1:e0:f0: es3-DoKickTA-1 [ 8818.572981] PVR_K: 338: - ID = 22578265, FWAddr = 0xc00bf370, r1:e0:f0: es3-DoKickTA-1 [ 8818.581069] PVR_K: 338: - ID = 22578264, FWAddr = 0xc00b2410, r1:e0:f0: es3-DoKickTA-1 [ 8818.589167] PVR_K: 338: - ID = 22578263, FWAddr = 0xc00bf368, r1:e0:f0: es3-DoKickTA-1 [ 8818.597244] PVR_K: 338: - ID = 22578262, FWAddr = 0xc00b2408, r1:e0:f0: es3-DoKickTA-1 [ 8818.605318] PVR_K: 338: - ID = 22578261, FWAddr = 0xc00bf360, r1:e0:f0: es3-DoKickTA-1 [ 8818.613394] PVR_K: 338: - ID = 22578260, FWAddr = 0xc00b2400, r1:e0:f0: es3-DoKickTA-1 [ 8818.621470] PVR_K: 338: - ID = 22578259, FWAddr = 0xc00bf358, r1:e0:f0: es3-DoKickTA-1 [ 8818.629546] PVR_K: 338: - ID = 22578258, FWAddr = 0xc00b23f8, r1:e0:f0: es3-DoKickTA-1 [ 8818.637621] PVR_K: 338: - ID = 22578257, FWAddr = 0xc00bf350, r1:e0:f0: es3-DoKickTA-1 [ 8818.645697] PVR_K: 338: - ID = 22578256, FWAddr = 0xc00b23f0, r1:e0:f0: es3-DoKickTA-1 [ 8818.653771] PVR_K: 338: - ID = 22578255, FWAddr = 0xc00bf348, r1:e0:f0: es3-DoKickTA-1 [ 8818.661850] PVR_K: 338: - ID = 22578254, FWAddr = 0xc00b23e8, r1:e0:f0: es3-DoKickTA-1 [ 8818.669926] PVR_K: 338: - ID = 22578253, FWAddr = 0xc00bf340, r1:e0:f0: es3-DoKickTA-1 [ 8818.678015] PVR_K: 338: - ID = 22578252, FWAddr = 0xc00b23e0, r1:e0:f0: es3-DoKickTA-1 [ 8818.686090] PVR_K: 338: - ID = 22578251, FWAddr = 0xc00bf338, r1:e0:f0: es3-DoKickTA-1 [ 8818.694166] PVR_K: 338: - ID = 22578250, FWAddr = 0xc00b23d8, r1:e0:f0: es3-DoKickTA-1 [ 8818.702241] PVR_K: 338: - ID = 22578249, FWAddr = 0xc00bf330, r1:e0:f0: es3-DoKickTA-1 [ 8818.710318] PVR_K: 338: - ID = 22578248, FWAddr = 0xc00b23d0, r1:e0:f0: es3-DoKickTA-1 [ 8818.718392] PVR_K: 338: - ID = 22578247, FWAddr = 0xc00bf328, r1:e0:f0: es3-DoKickTA-1 [ 8818.726467] PVR_K: 338: - ID = 22578246, FWAddr = 0xc00b23c8, r1:e0:f0: es3-DoKickTA-1 [ 8818.734543] PVR_K: 338: - ID = 22578245, FWAddr = 0xc00bf320, r1:e0:f0: es3-DoKickTA-1 [ 8818.742618] PVR_K: 338: - ID = 22578244, FWAddr = 0xc00b23c0, r1:e0:f0: es3-DoKickTA-1 [ 8818.750692] PVR_K: 338: - ID = 22578243, FWAddr = 0xc00bf318, r1:e0:f0: es3-DoKickTA-1 [ 8818.758768] PVR_K: 338: - ID = 22578242, FWAddr = 0xc00b23b8, r1:e0:f0: es3-DoKickTA-1 [ 8818.766841] PVR_K: 338: - ID = 22578241, FWAddr = 0xc00bf310, r1:e0:f0: es3-DoKickTA-1 [ 8818.774916] PVR_K: 338: - ID = 22578240, FWAddr = 0xc00b23b0, r1:e0:f0: es3-DoKickTA-1 [ 8818.782991] PVR_K: 338: - ID = 22578239, FWAddr = 0xc00bf308, r1:e0:f0: es3-DoKickTA-1 [ 8818.791072] PVR_K: 338: - ID = 22578238, FWAddr = 0xc00b23a8, r1:e0:f0: es3-DoKickTA-1 [ 8818.799146] PVR_K: 338: - ID = 22578237, FWAddr = 0xc00bf300, r1:e0:f0: es3-DoKickTA-1 [ 8818.807221] PVR_K: 338: - ID = 22578236, FWAddr = 0xc00b23a0, r1:e0:f0: es3-DoKickTA-1 [ 8818.815296] PVR_K: 338: - ID = 22578235, FWAddr = 0xc00bf2f8, r1:e0:f0: es3-DoKickTA-1 [ 8818.823372] PVR_K: 338: - ID = 22578234, FWAddr = 0xc00b2398, r1:e0:f0: es3-DoKickTA-1 [ 8818.831446] PVR_K: 338: - ID = 22578233, FWAddr = 0xc00bf2f0, r1:e0:f0: es3-DoKickTA-1 [ 8818.839522] PVR_K: 338: - ID = 22578232, FWAddr = 0xc00b2390, r1:e0:f0: es3-DoKickTA-1 [ 8818.847597] PVR_K: 338: - ID = 22578231, FWAddr = 0xc00bf2e8, r1:e0:f0: es3-DoKickTA-1 [ 8818.855672] PVR_K: 338: - ID = 22578230, FWAddr = 0xc00b2388, r1:e0:f0: es3-DoKickTA-1 [ 8818.863746] PVR_K: 338: - ID = 22578229, FWAddr = 0xc00bf2e0, r1:e0:f0: es3-DoKickTA-1 [ 8818.871822] PVR_K: 338: - ID = 22578228, FWAddr = 0xc00b2380, r1:e0:f0: es3-DoKickTA-1 [ 8818.879917] PVR_K: 338: - ID = 22578227, FWAddr = 0xc00bf2d8, r1:e0:f0: es3-DoKickTA-1 [ 8818.887994] PVR_K: 338: - ID = 22578226, FWAddr = 0xc00b2378, r1:e0:f0: es3-DoKickTA-1 [ 8818.896068] PVR_K: 338: - ID = 22578225, FWAddr = 0xc00bf2d0, r1:e0:f0: es3-DoKickTA-1 [ 8818.904144] PVR_K: 338: - ID = 22578224, FWAddr = 0xc00b2370, r1:e0:f0: es3-DoKickTA-1 [ 8818.912218] PVR_K: 338: - ID = 22578223, FWAddr = 0xc00bf2c8, r1:e0:f0: es3-DoKickTA-1 [ 8818.920335] PVR_K: 338: - ID = 22578222, FWAddr = 0xc00b2368, r1:e0:f0: es3-DoKickTA-1 [ 8818.928413] PVR_K: 338: - ID = 22578221, FWAddr = 0xc00bf2c0, r1:e0:f0: es3-DoKickTA-1 [ 8818.936498] PVR_K: 338: - ID = 22578220, FWAddr = 0xc00b2360, r1:e0:f0: es3-DoKickTA-1 [ 8818.944573] PVR_K: 338: - ID = 22578219, FWAddr = 0xc00bf2b8, r1:e0:f0: es3-DoKickTA-1 [ 8818.952649] PVR_K: 338: - ID = 22578218, FWAddr = 0xc00b2358, r1:e0:f0: es3-DoKickTA-1 [ 8818.960724] PVR_K: 338: - ID = 22578217, FWAddr = 0xc00bf2b0, r1:e0:f0: es3-DoKickTA-1 [ 8818.968800] PVR_K: 338: - ID = 22578216, FWAddr = 0xc00b2350, r1:e0:f0: es3-DoKickTA-1 [ 8818.976875] PVR_K: 338: - ID = 22578215, FWAddr = 0xc00bf2a8, r1:e0:f0: es3-DoKickTA-1 [ 8818.984950] PVR_K: 338: - ID = 22578214, FWAddr = 0xc00b2348, r1:e0:f0: es3-DoKickTA-1 [ 8818.993024] PVR_K: 338: - ID = 22578213, FWAddr = 0xc00bf2a0, r1:e0:f0: es3-DoKickTA-1 [ 8819.001100] PVR_K: 338: - ID = 22578212, FWAddr = 0xc00b2340, r1:e0:f0: es3-DoKickTA-1 [ 8819.009175] PVR_K: 338: - ID = 22578211, FWAddr = 0xc00bf298, r1:e0:f0: es3-DoKickTA-1 [ 8819.017250] PVR_K: 338: - ID = 22578210, FWAddr = 0xc00b2338, r1:e0:f0: es3-DoKickTA-1 [ 8819.025326] PVR_K: 338: - ID = 22578209, FWAddr = 0xc00bf290, r1:e0:f0: es3-DoKickTA-1 [ 8819.033401] PVR_K: 338: - ID = 22578208, FWAddr = 0xc00b2330, r1:e0:f0: es3-DoKickTA-1 [ 8819.041476] PVR_K: 338: - ID = 22578207, FWAddr = 0xc00bf288, r1:e0:f0: es3-DoKickTA-1 [ 8819.049556] PVR_K: 338: - ID = 22578206, FWAddr = 0xc00b2328, r1:e0:f0: es3-DoKickTA-1 [ 8819.057631] PVR_K: 338: - ID = 22578205, FWAddr = 0xc00bf280, r1:e0:f0: es3-DoKickTA-1 [ 8819.065707] PVR_K: 338: - ID = 22578204, FWAddr = 0xc00b2320, r1:e0:f0: es3-DoKickTA-1 [ 8819.073781] PVR_K: 338: - ID = 22578203, FWAddr = 0xc00bf278, r1:e0:f0: es3-DoKickTA-1 [ 8819.081857] PVR_K: 338: - ID = 22578202, FWAddr = 0xc00b2318, r1:e0:f0: es3-DoKickTA-1 [ 8819.089931] PVR_K: 338: - ID = 22578201, FWAddr = 0xc00bf270, r1:e0:f0: es3-DoKickTA-1 [ 8819.098006] PVR_K: 338: - ID = 22578200, FWAddr = 0xc00b2310, r1:e0:f0: es3-DoKickTA-1 [ 8819.106081] PVR_K: 338: - ID = 22578199, FWAddr = 0xc00bf268, r1:e0:f0: es3-DoKickTA-1 [ 8819.114157] PVR_K: 338: - ID = 22578198, FWAddr = 0xc00b2308, r1:e0:f0: es3-DoKickTA-1 [ 8819.122231] PVR_K: 338: - ID = 22578197, FWAddr = 0xc00bf260, r1:e0:f0: es3-DoKickTA-1 [ 8819.130307] PVR_K: 338: - ID = 22578196, FWAddr = 0xc00b2300, r1:e0:f0: es3-DoKickTA-1 [ 8819.138381] PVR_K: 338: - ID = 22578195, FWAddr = 0xc00bf258, r1:e0:f0: es3-DoKickTA-1 [ 8819.146456] PVR_K: 338: - ID = 22578194, FWAddr = 0xc00b22f8, r1:e0:f0: es3-DoKickTA-1 [ 8819.154532] PVR_K: 338: - ID = 22578193, FWAddr = 0xc00bf250, r1:e0:f0: es3-DoKickTA-1 [ 8819.162608] PVR_K: 338: - ID = 22578192, FWAddr = 0xc00b22f0, r1:e0:f0: es3-DoKickTA-1 [ 8819.170682] PVR_K: 338: - ID = 22578191, FWAddr = 0xc00bf248, r1:e0:f0: es3-DoKickTA-1 [ 8819.178761] PVR_K: 338: - ID = 22578190, FWAddr = 0xc00b22e8, r1:e0:f0: es3-DoKickTA-1 [ 8819.186836] PVR_K: 338: - ID = 22578189, FWAddr = 0xc00bf240, r1:e0:f0: es3-DoKickTA-1 [ 8819.194911] PVR_K: 338: - ID = 22578188, FWAddr = 0xc00b22e0, r1:e0:f0: es3-DoKickTA-1 [ 8819.202985] PVR_K: 338: - ID = 22578187, FWAddr = 0xc00bf238, r1:e0:f0: es3-DoKickTA-1 [ 8819.211061] PVR_K: 338: - ID = 22578186, FWAddr = 0xc00b22d8, r1:e0:f0: es3-DoKickTA-1 [ 8819.219136] PVR_K: 338: - ID = 22578185, FWAddr = 0xc00bf230, r1:e0:f0: es3-DoKickTA-1 [ 8819.227211] PVR_K: 338: - ID = 22578184, FWAddr = 0xc00b22d0, r1:e0:f0: es3-DoKickTA-1 [ 8819.235286] PVR_K: 338: - ID = 22578183, FWAddr = 0xc00bf228, r1:e0:f0: es3-DoKickTA-1 [ 8819.243362] PVR_K: 338: - ID = 22578182, FWAddr = 0xc00b22c8, r1:e0:f0: es3-DoKickTA-1 [ 8819.251437] PVR_K: 338: - ID = 22578181, FWAddr = 0xc00bf220, r1:e0:f0: es3-DoKickTA-1 [ 8819.259512] PVR_K: 338: - ID = 22578180, FWAddr = 0xc00b22c0, r1:e0:f0: es3-DoKickTA-1 [ 8819.267588] PVR_K: 338: - ID = 22578179, FWAddr = 0xc00bf218, r1:e0:f0: es3-DoKickTA-1 [ 8819.275663] PVR_K: 338: - ID = 22578178, FWAddr = 0xc00b22b8, r1:e0:f0: es3-DoKickTA-1 [ 8819.283737] PVR_K: 338: - ID = 22578177, FWAddr = 0xc00bf210, r1:e0:f0: es3-DoKickTA-1 [ 8819.291833] PVR_K: 338: - ID = 22578176, FWAddr = 0xc00b22b0, r1:e0:f0: es3-DoKickTA-1 [ 8819.299923] PVR_K: 338: - ID = 22578175, FWAddr = 0xc00bf208, r1:e0:f0: es3-DoKickTA-1 [ 8819.308021] PVR_K: 338: - ID = 22578174, FWAddr = 0xc00b22a8, r1:e0:f0: es3-DoKickTA-1 [ 8819.316098] PVR_K: 338: - ID = 22578173, FWAddr = 0xc00bf200, r1:e0:f0: es3-DoKickTA-1 [ 8819.324173] PVR_K: 338: - ID = 22578172, FWAddr = 0xc00b22a0, r1:e0:f0: es3-DoKickTA-1 [ 8819.332269] PVR_K: 338: - ID = 22578171, FWAddr = 0xc00bf1f8, r1:e0:f0: es3-DoKickTA-1 [ 8819.340348] PVR_K: 338: - ID = 22578170, FWAddr = 0xc00b2298, r1:e0:f0: es3-DoKickTA-1 [ 8819.348422] PVR_K: 338: - ID = 22578169, FWAddr = 0xc00bf1f0, r1:e0:f0: es3-DoKickTA-1 [ 8819.356498] PVR_K: 338: - ID = 22578168, FWAddr = 0xc00b2290, r1:e0:f0: es3-DoKickTA-1 [ 8819.364572] PVR_K: 338: - ID = 22578167, FWAddr = 0xc00bf1e8, r1:e0:f0: es3-DoKickTA-1 [ 8819.372648] PVR_K: 338: - ID = 22578166, FWAddr = 0xc00b2288, r1:e0:f0: es3-DoKickTA-1 [ 8819.380736] PVR_K: 338: - ID = 22578165, FWAddr = 0xc00bf1e0, r1:e0:f0: es3-DoKickTA-1 [ 8819.388812] PVR_K: 338: - ID = 22578164, FWAddr = 0xc00b2280, r1:e0:f0: es3-DoKickTA-1 [ 8819.396887] PVR_K: 338: - ID = 22578163, FWAddr = 0xc00bf1d8, r1:e0:f0: es3-DoKickTA-1 [ 8819.404963] PVR_K: 338: - ID = 22578162, FWAddr = 0xc00b2278, r1:e0:f0: es3-DoKickTA-1 [ 8819.413038] PVR_K: 338: - ID = 22578161, FWAddr = 0xc00bf1d0, r1:e0:f0: es3-DoKickTA-1 [ 8819.421114] PVR_K: 338: - ID = 22578160, FWAddr = 0xc00b2270, r1:e0:f0: es3-DoKickTA-1 [ 8819.429189] PVR_K: 338: - ID = 22578159, FWAddr = 0xc00bf1c8, r1:e0:f0: es3-DoKickTA-1 [ 8819.437271] PVR_K: 338: - ID = 22578158, FWAddr = 0xc00b2268, r1:e0:f0: es3-DoKickTA-1 [ 8819.445346] PVR_K: 338: - ID = 22578157, FWAddr = 0xc00bf1c0, r1:e0:f0: es3-DoKickTA-1 [ 8819.453422] PVR_K: 338: - ID = 22578156, FWAddr = 0xc00b2260, r1:e0:f0: es3-DoKickTA-1 [ 8819.461496] PVR_K: 338: - ID = 22578155, FWAddr = 0xc00bf1b8, r1:e0:f0: es3-DoKickTA-1 [ 8819.469572] PVR_K: 338: - ID = 22578154, FWAddr = 0xc00b2258, r1:e0:f0: es3-DoKickTA-1 [ 8819.477647] PVR_K: 338: - ID = 22578153, FWAddr = 0xc00bf1b0, r1:e0:f0: es3-DoKickTA-1 [ 8819.485722] PVR_K: 338: - ID = 22578152, FWAddr = 0xc00b2250, r1:e0:f0: es3-DoKickTA-1 [ 8819.493797] PVR_K: 338: - ID = 22578151, FWAddr = 0xc00bf1a8, r1:e0:f0: es3-DoKickTA-1 [ 8819.501873] PVR_K: 338: - ID = 22578150, FWAddr = 0xc00b2248, r1:e0:f0: es3-DoKickTA-1 [ 8819.509948] PVR_K: 338: - ID = 22578149, FWAddr = 0xc00bf1a0, r1:e0:f0: es3-DoKickTA-1 [ 8819.518024] PVR_K: 338: - ID = 22578148, FWAddr = 0xc00b2240, r1:e0:f0: es3-DoKickTA-1 [ 8819.526099] PVR_K: 338: - ID = 22578147, FWAddr = 0xc00bf198, r1:e0:f0: es3-DoKickTA-1 [ 8819.534175] PVR_K: 338: - ID = 22578146, FWAddr = 0xc00b2238, r1:e0:f0: es3-DoKickTA-1 [ 8819.542249] PVR_K: 338: - ID = 22578145, FWAddr = 0xc00bf190, r1:e0:f0: es3-DoKickTA-1 [ 8819.550324] PVR_K: 338: - ID = 22578144, FWAddr = 0xc00b2230, r1:e0:f0: es3-DoKickTA-1 [ 8819.558398] PVR_K: 338: - ID = 22578143, FWAddr = 0xc00bf188, r1:e0:f0: es3-DoKickTA-1 [ 8819.566478] PVR_K: 338: - ID = 22578142, FWAddr = 0xc00b2228, r1:e0:f0: es3-DoKickTA-1 [ 8819.574553] PVR_K: 338: - ID = 22578141, FWAddr = 0xc00bf180, r1:e0:f0: es3-DoKickTA-1 [ 8819.582629] PVR_K: 338: - ID = 22578140, FWAddr = 0xc00b2220, r1:e0:f0: es3-DoKickTA-1 [ 8819.590703] PVR_K: 338: - ID = 22578139, FWAddr = 0xc00bf178, r1:e0:f0: es3-DoKickTA-1 [ 8819.598806] PVR_K: 338: - ID = 22578138, FWAddr = 0xc00b2218, r1:e0:f0: es3-DoKickTA-1 [ 8819.606883] PVR_K: 338: - ID = 22578137, FWAddr = 0xc00bf170, r1:e0:f0: es3-DoKickTA-1 [ 8819.614959] PVR_K: 338: - ID = 22578136, FWAddr = 0xc00b2210, r1:e0:f0: es3-DoKickTA-1 [ 8819.623034] PVR_K: 338: - ID = 22578135, FWAddr = 0xc00bf168, r1:e0:f0: es3-DoKickTA-1 [ 8819.631111] PVR_K: 338: - ID = 22578134, FWAddr = 0xc00b2208, r1:e0:f0: es3-DoKickTA-1 [ 8819.639186] PVR_K: 338: - ID = 22578133, FWAddr = 0xc00bf160, r1:e0:f0: es3-DoKickTA-1 [ 8819.647262] PVR_K: 338: - ID = 22578132, FWAddr = 0xc00b2200, r1:e0:f0: es3-DoKickTA-1 [ 8819.655337] PVR_K: 338: - ID = 22578131, FWAddr = 0xc00bf158, r1:e0:f0: es3-DoKickTA-1 [ 8819.663413] PVR_K: 338: - ID = 22578130, FWAddr = 0xc00b21f8, r1:e0:f0: es3-DoKickTA-1 [ 8819.671487] PVR_K: 338: - ID = 22578129, FWAddr = 0xc00bf150, r1:e0:f0: es3-DoKickTA-1 [ 8819.679576] PVR_K: 338: - ID = 22578128, FWAddr = 0xc00b21f0, r1:e0:f0: es3-DoKickTA-1 [ 8819.687652] PVR_K: 338: - ID = 22578127, FWAddr = 0xc00bf148, r1:e0:f0: es3-DoKickTA-1 [ 8819.695743] PVR_K: 338: - ID = 22578126, FWAddr = 0xc00b21e8, r1:e0:f0: es3-DoKickTA-1 [ 8819.703818] PVR_K: 338: - ID = 22578125, FWAddr = 0xc00bf140, r1:e0:f0: es3-DoKickTA-1 [ 8819.711895] PVR_K: 338: - ID = 22578124, FWAddr = 0xc00b21e0, r1:e0:f0: es3-DoKickTA-1 [ 8819.719971] PVR_K: 338: - ID = 22578123, FWAddr = 0xc00bf138, r1:e0:f0: es3-DoKickTA-1 [ 8819.728046] PVR_K: 338: - ID = 22578122, FWAddr = 0xc00b21d8, r1:e0:f0: es3-DoKickTA-1 [ 8819.736121] PVR_K: 338: - ID = 22578121, FWAddr = 0xc00bf130, r1:e0:f0: es3-DoKickTA-1 [ 8819.744197] PVR_K: 338: - ID = 22578120, FWAddr = 0xc00b21d0, r1:e0:f0: es3-DoKickTA-1 [ 8819.752271] PVR_K: 338: - ID = 22578119, FWAddr = 0xc00bf128, r1:e0:f0: es3-DoKickTA-1 [ 8819.760346] PVR_K: 338: - ID = 22578118, FWAddr = 0xc00b21c8, r1:e0:f0: es3-DoKickTA-1 [ 8819.768421] PVR_K: 338: - ID = 22578117, FWAddr = 0xc00bf120, r1:e0:f0: es3-DoKickTA-1 [ 8819.776497] PVR_K: 338: - ID = 22578116, FWAddr = 0xc00b21c0, r1:e0:f0: es3-DoKickTA-1 [ 8819.784571] PVR_K: 338: - ID = 22578115, FWAddr = 0xc00bf118, r1:e0:f0: es3-DoKickTA-1 [ 8819.792648] PVR_K: 338: - ID = 22578114, FWAddr = 0xc00b21b8, r1:e0:f0: es3-DoKickTA-1 [ 8819.800722] PVR_K: 338: - ID = 22578113, FWAddr = 0xc00bf110, r1:e0:f0: es3-DoKickTA-1 [ 8819.808798] PVR_K: 338: - ID = 22578112, FWAddr = 0xc00b21b0, r1:e0:f0: es3-DoKickTA-1 [ 8819.816873] PVR_K: 338: - ID = 22578111, FWAddr = 0xc00bf108, r1:e0:f0: es3-DoKickTA-1 [ 8819.824953] PVR_K: 338: - ID = 22578110, FWAddr = 0xc00b21a8, r1:e0:f0: es3-DoKickTA-1 [ 8819.833027] PVR_K: 338: - ID = 22578109, FWAddr = 0xc00bf100, r1:e0:f0: es3-DoKickTA-1 [ 8819.841102] PVR_K: 338: - ID = 22578108, FWAddr = 0xc00b21a0, r1:e0:f0: es3-DoKickTA-1 [ 8819.849177] PVR_K: 338: - ID = 22578107, FWAddr = 0xc00bf0f8, r1:e0:f0: es3-DoKickTA-1 [ 8819.857252] PVR_K: 338: - ID = 22578106, FWAddr = 0xc00b2198, r1:e0:f0: es3-DoKickTA-1 [ 8819.865327] PVR_K: 338: - ID = 22578105, FWAddr = 0xc00bf0f0, r1:e0:f0: es3-DoKickTA-1 [ 8819.873402] PVR_K: 338: - ID = 22578104, FWAddr = 0xc00b2190, r1:e0:f0: es3-DoKickTA-1 [ 8819.881477] PVR_K: 338: - ID = 22578103, FWAddr = 0xc00bf0e8, r1:e0:f0: es3-DoKickTA-1 [ 8819.889553] PVR_K: 338: - ID = 22578102, FWAddr = 0xc00b2188, r1:e0:f0: es3-DoKickTA-1 [ 8819.897627] PVR_K: 338: - ID = 22578101, FWAddr = 0xc00bf0e0, r1:e0:f0: es3-DoKickTA-1 [ 8819.905703] PVR_K: 338: - ID = 22578100, FWAddr = 0xc00b2180, r1:e0:f0: es3-DoKickTA-1 [ 8819.913795] PVR_K: 338: - ID = 22578099, FWAddr = 0xc00bf0d8, r1:e1:f0: es3-DoKickTA-1 [ 8819.921873] PVR_K: 338: - ID = 22578098, FWAddr = 0xc00b2178, r1:e1:f0: es3-DoKickTA-1 [ 8819.929956] PVR_K: 338: - ID = 22578097, FWAddr = 0xc00b2170, r1:e1:f0: es3-DoKickTA-1 [ 8819.938032] PVR_K: 338: - ID = 22578096, FWAddr = 0xc00bf0d0, r1:e1:f0: es3-DoKickTA-1 [ 8819.946107] PVR_K: 338: - ID = 22578095, FWAddr = 0xc00b2168, r1:e1:f0: es3-DoKickTA-1 [ 8819.954188] PVR_K: 338: - ID = 22578094, FWAddr = 0xc007e008, r1:e1:f0: es3-DoKickTA-392858 [ 8819.962708] PVR_K: 338: - ID = 22578093, FWAddr = 0xc007d010, r1:e1:f0: es3-DoKickTA-392858 [ 8819.971218] PVR_K: 338: - ID = 22578092, FWAddr = 0xc007c008, r1:e1:f0: update fence [ 8819.979118] PVR_K: 338: - ID = 22578091, FWAddr = 0xc00bf0c8, r1:e1:f0: es3-DoKickTA-1 [ 8819.987194] PVR_K: 338: - ID = 22578090, FWAddr = 0xc00b2160, r1:e1:f0: es3-DoKickTA-1 [ 8819.995268] PVR_K: 338: - ID = 22578089, FWAddr = 0xc00b2158, r1:e1:f0: es3-DoKickTA-1 [ 8820.003344] PVR_K: 338: - ID = 22578088, FWAddr = 0xc00bf0c0, r1:e1:f0: es3-DoKickTA-1 [ 8820.011418] PVR_K: 338: - ID = 22578087, FWAddr = 0xc00b2150, r1:e1:f0: es3-DoKickTA-1 [ 8820.019493] PVR_K: 338: - ID = 22578086, FWAddr = 0xc00bf0b8, r1:e1:f0: es3-DoKickTA-1 [ 8820.027568] PVR_K: 338: - ID = 22578085, FWAddr = 0xc00b2148, r1:e1:f0: es3-DoKickTA-1 [ 8820.035644] PVR_K: 338: - ID = 22578084, FWAddr = 0xc00b2140, r1:e1:f0: es3-DoKickTA-1 [ 8820.043718] PVR_K: 338: - ID = 22578083, FWAddr = 0xc00bf0b0, r1:e1:f0: es3-DoKickTA-1 [ 8820.051807] PVR_K: 338: - ID = 22578082, FWAddr = 0xc00b2138, r1:e1:f0: es3-DoKickTA-1 [ 8820.059884] PVR_K: 338: - ID = 22578081, FWAddr = 0xc00bf0a8, r1:e1:f0: es3-DoKickTA-1 [ 8820.067959] PVR_K: 338: - ID = 22578080, FWAddr = 0xc00b2130, r1:e1:f0: es3-DoKickTA-1 [ 8820.076034] PVR_K: 338: - ID = 22578079, FWAddr = 0xc00b2128, r1:e1:f0: es3-DoKickTA-1 [ 8820.084114] PVR_K: 338: - ID = 22578078, FWAddr = 0xc00bf0a0, r1:e1:f0: es3-DoKickTA-1 [ 8820.092188] PVR_K: 338: - ID = 22578077, FWAddr = 0xc00b2120, r1:e1:f0: es3-DoKickTA-1 [ 8820.100264] PVR_K: 338: - ID = 22578076, FWAddr = 0xc00bf098, r1:e1:f0: es3-DoKickTA-0 [ 8820.108338] PVR_K: 338: - ID = 22578075, FWAddr = 0xc00b2118, r1:e1:f0: es3-DoKickTA-0 [ 8820.116414] PVR_K: 338: - ID = 22578074, FWAddr = 0xc00c0000, r1:e2:f0: update fence [ 8820.124315] PVR_K: 338: - ID = 22578073, FWAddr = 0xc00bf090, r1:e1:f0: es3-DoKickTA-0 [ 8820.132403] PVR_K: 338: - ID = 22578072, FWAddr = 0xc00b2110, r1:e1:f0: es3-DoKickTA-0 [ 8820.140479] PVR_K: 338: - ID = 22578071, FWAddr = 0xc00bf088, r1:e1:f0: es3-DoKickTA-0 [ 8820.148555] PVR_K: 338: - ID = 22578070, FWAddr = 0xc00b2108, r1:e1:f0: es3-DoKickTA-0 [ 8820.156630] PVR_K: 338: - ID = 22578069, FWAddr = 0xc00b2100, r1:e1:f0: es3-DoKickTA-0 [ 8820.164705] PVR_K: 338: - ID = 22578068, FWAddr = 0xc00bf080, r1:e1:f0: es3-DoKickTA-0 [ 8820.172780] PVR_K: 338: - ID = 22578067, FWAddr = 0xc00b20f8, r1:e1:f0: es3-DoKickTA-0 [ 8820.180856] PVR_K: 338: - ID = 22578066, FWAddr = 0xc00bf078, r1:e1:f0: es3-DoKickTA-0 [ 8820.188931] PVR_K: 338: - ID = 22578065, FWAddr = 0xc00b20f0, r1:e1:f0: es3-DoKickTA-0 [ 8820.197007] PVR_K: 338: - ID = 22578064, FWAddr = 0xc00b20e8, r1:e1:f0: es3-DoKickTA-0 [ 8820.205081] PVR_K: 338: - ID = 22578063, FWAddr = 0xc00bf070, r1:e1:f0: es3-DoKickTA-0 [ 8820.213178] PVR_K: 338: - ID = 22578062, FWAddr = 0xc00b20e0, r1:e1:f0: es3-DoKickTA-0 [ 8820.221254] PVR_K: 338: - ID = 22578061, FWAddr = 0xc00b20d8, r1:e1:f0: es3-DoKickTA-0 [ 8820.229331] PVR_K: 338: - ID = 22578060, FWAddr = 0xc00bf068, r1:e1:f0: es3-DoKickTA-0 [ 8820.237406] PVR_K: 338: - ID = 22578059, FWAddr = 0xc00b20d0, r1:e1:f0: es3-DoKickTA-0 [ 8820.245482] PVR_K: 338: - ID = 22578058, FWAddr = 0xc00b20c8, r1:e1:f0: es3-DoKickTA-0 [ 8820.253556] PVR_K: 338: - ID = 22578057, FWAddr = 0xc00bf060, r1:e1:f0: es3-DoKickTA-0 [ 8820.261632] PVR_K: 338: - ID = 22578056, FWAddr = 0xc00b20c0, r1:e1:f0: es3-DoKickTA-0 [ 8820.269706] PVR_K: 338: - ID = 22578055, FWAddr = 0xc00b20b8, r1:e1:f0: es3-DoKickTA-0 [ 8820.277782] PVR_K: 338: - ID = 22578054, FWAddr = 0xc00bf058, r1:e1:f0: es3-DoKickTA-0 [ 8820.285857] PVR_K: 338: - ID = 22578053, FWAddr = 0xc00b20b0, r1:e1:f0: es3-DoKickTA-0 [ 8820.293932] PVR_K: 338: - ID = 22578052, FWAddr = 0xc00b20a8, r1:e1:f0: es3-DoKickTA-0 [ 8820.302007] PVR_K: 338: - ID = 22578051, FWAddr = 0xc00bf050, r1:e1:f0: es3-DoKickTA-0 [ 8820.310083] PVR_K: 338: - ID = 22578050, FWAddr = 0xc00b20a0, r1:e1:f0: es3-DoKickTA-0 [ 8820.318158] PVR_K: 338: - ID = 22578049, FWAddr = 0xc00b2098, r1:e1:f0: es3-DoKickTA-0 [ 8820.326233] PVR_K: 338: - ID = 22578048, FWAddr = 0xc00bf048, r1:e1:f0: es3-DoKickTA-0 [ 8820.334308] PVR_K: 338: - ID = 22578047, FWAddr = 0xc00b2090, r1:e1:f0: es3-DoKickTA-0 [ 8820.342387] PVR_K: 338: - ID = 22578046, FWAddr = 0xc00bf040, r1:e1:f0: es3-DoKickTA-0 [ 8820.350462] PVR_K: 338: - ID = 22578045, FWAddr = 0xc00b2088, r1:e1:f0: es3-DoKickTA-0 [ 8820.358538] PVR_K: 338: - ID = 22578044, FWAddr = 0xc00b2080, r1:e1:f0: es3-DoKickTA-0 [ 8820.366612] PVR_K: 338: - ID = 22578043, FWAddr = 0xc00bf038, r1:e1:f0: es3-DoKickTA-0 [ 8820.374687] PVR_K: 338: - ID = 22578042, FWAddr = 0xc00b2078, r1:e1:f0: es3-DoKickTA-0 [ 8820.382761] PVR_K: 338: - ID = 22578041, FWAddr = 0xc00bf030, r1:e1:f0: es3-DoKickTA-0 [ 8820.390836] PVR_K: 338: - ID = 22578040, FWAddr = 0xc00b2070, r1:e1:f0: es3-DoKickTA-0 [ 8820.398911] PVR_K: 338: - ID = 22578039, FWAddr = 0xc00b2068, r1:e1:f0: es3-DoKickTA-0 [ 8820.406986] PVR_K: 338: - ID = 22578038, FWAddr = 0xc00bf028, r1:e1:f0: es3-DoKickTA-0 [ 8820.415061] PVR_K: 338: - ID = 22578037, FWAddr = 0xc00b2060, r1:e1:f0: es3-DoKickTA-0 [ 8820.423136] PVR_K: 338: - ID = 22578036, FWAddr = 0xc00b2058, r1:e1:f0: es3-DoKickTA-0 [ 8820.431212] PVR_K: 338: - ID = 22578035, FWAddr = 0xc00bf020, r1:e1:f0: es3-DoKickTA-0 [ 8820.439288] PVR_K: 338: - ID = 22578034, FWAddr = 0xc00b2050, r1:e1:f0: es3-DoKickTA-0 [ 8820.447363] PVR_K: 338: - ID = 22578033, FWAddr = 0xc00b2048, r1:e1:f0: es3-DoKickTA-0 [ 8820.455438] PVR_K: 338: - ID = 22578032, FWAddr = 0xc00bf018, r1:e1:f0: es3-DoKickTA-0 [ 8820.463513] PVR_K: 338: - ID = 22578031, FWAddr = 0xc00b2040, r1:e1:f0: es3-DoKickTA-0 [ 8820.471592] PVR_K: 338: - ID = 22578030, FWAddr = 0xc00b2038, r1:e1:f0: es3-DoKickTA-0 [ 8820.479667] PVR_K: 338: - ID = 22578029, FWAddr = 0xc00bf010, r1:e1:f0: es3-DoKickTA-0 [ 8820.487742] PVR_K: 338: - ID = 22578028, FWAddr = 0xc00b2030, r1:e1:f0: es3-DoKickTA-0 [ 8820.495834] PVR_K: 338: - ID = 22578027, FWAddr = 0xc00b2028, r1:e1:f0: es3-DoKickTA-0 [ 8820.503935] PVR_K: 338: - ID = 22578026, FWAddr = 0xc00bf008, r1:e1:f0: es3-DoKickTA-0 [ 8820.512012] PVR_K: 338: - ID = 22578025, FWAddr = 0xc00b2020, r1:e1:f0: es3-DoKickTA-0 [ 8820.520088] PVR_K: 338: - ID = 22578024, FWAddr = 0xc00b2018, r1:e1:f0: es3-DoKickTA-0 [ 8820.528162] PVR_K: 338: - ID = 22578023, FWAddr = 0xc00bf000, r1:e1:f0: es3-DoKickTA-0 [ 8820.536238] PVR_K: 338: - ID = 22578022, FWAddr = 0xc00b2010, r1:e1:f0: es3-DoKickTA-0 [ 8820.544313] PVR_K: 338: - ID = 22578021, FWAddr = 0xc00b2008, r1:e1:f0: es3-DoKickTA-0 [ 8820.552389] PVR_K: 338: - ID = 22578020, FWAddr = 0xc00ba008, r1:e2:f0: TQM [ 8820.559512] PVR_K: 338: - ID = 22578019, FWAddr = 0xc00b2000, r1:e1:f0: es3-DoKickTA-0 [ 8820.567593] PVR_K: 338: ------[ Pending Server Syncs ]------ [ 8820.573326] ------[ Native Fence Sync: timelines ]------ [ 8820.578629] foreign_sync: @0 ctx=1 refs=1 [ 8820.582631] sw: RM_SWTimeline-weston-733 @0 cur=0 [ 8820.587328] rogue-ta3d: @392859 ctx=3 refs=3 [ 8820.591584] @392857: (++) refs=2 fwaddr=0xc007c019 enqueue=1 status=Signalled 392857-update fence [ 8820.600519] @392858: (+-) refs=3 fwaddr=0xc007c009 enqueue=1 status=Active 392858-update fence [ 8820.609466] V3-weston-733: @392859 ctx=5 refs=3 [ 8820.613982] @392857: (++) refs=1 fwaddr=0xc007d019 enqueue=1 status=Signalled 392857-es3-DoKickTA-392857 [ 8820.623524] @392858: (+-) refs=3 fwaddr=0xc007d011 enqueue=1 status=Active 392858-es3-DoKickTA-392858 [ 8820.633074] P3-weston-733: @392859 ctx=6 refs=3 [ 8820.637589] @392857: (++) refs=1 fwaddr=0xc007e021 enqueue=1 status=Signalled 392857-es3-DoKickTA-392857 [ 8820.647131] @392858: (+-) refs=3 fwaddr=0xc007e009 enqueue=1 status=Active 392858-es3-DoKickTA-392858 [ 8820.656678] rogue-tq3d: @0 ctx=8 refs=1 [ 8820.660509] QE-weston-733: @149 ctx=9 refs=2 [ 8820.664764] @148: (++) refs=1 fwaddr=0xc00ad001 enqueue=2 status=Signalled 148-TQM [ 8820.672405] sw: RM_SWTimeline-glmark2-es2-wayla @0 cur=0 [ 8820.677738] rogue-tq3d: @0 ctx=6355349 refs=1 [ 8820.682087] QE-wayland-glmark2-es2-way-1273: @10 ctx=6355350 refs=2 [ 8820.688336] @9: (+-) refs=4 fwaddr=0xc00ba009 enqueue=2 status=Active 9-TQM [ 8820.695632] rogue-ta3d: @13034 ctx=6481724 refs=1 [ 8820.700320] @13033: (++) refs=1 fwaddr=0xc00bc011 enqueue=2 status=Signalled 13033-update fence [ 8820.709087] P3-wayland-glmark2-es2-way-1273: @13034 ctx=6481728 refs=1 [ 8820.715595] @13033: (++) refs=1 fwaddr=0xc00be001 enqueue=1 status=Signalled 13033-es3-DoKickTA-13033 [ 8820.724897] rogue-ta3d: @1 ctx=6495358 refs=2 [ 8820.729239] @0: (+-) refs=2 fwaddr=0xc00c0001 enqueue=2 status=Active 0-update fence [ 8820.737319] V3-wayland-glmark2-es2-way-1273: @203 ctx=6495361 refs=49 [ 8820.743742] @0: (+-) refs=2 fwaddr=0xc00b2001 enqueue=1 status=Active 0-es3-DoKickTA-0 [ 8820.751984] @1: (+-) refs=2 fwaddr=0xc00b2009 enqueue=1 status=Active 1-es3-DoKickTA-0 [ 8820.760225] @2: (+-) refs=2 fwaddr=0xc00b2011 enqueue=1 status=Active 2-es3-DoKickTA-0 [ 8820.768466] @3: (+-) refs=2 fwaddr=0xc00b2019 enqueue=1 status=Active 3-es3-DoKickTA-0 [ 8820.776708] @4: (+-) refs=2 fwaddr=0xc00b2021 enqueue=1 status=Active 4-es3-DoKickTA-0 [ 8820.784948] @5: (+-) refs=2 fwaddr=0xc00b2029 enqueue=1 status=Active 5-es3-DoKickTA-0 [ 8820.793189] @6: (+-) refs=2 fwaddr=0xc00b2031 enqueue=1 status=Active 6-es3-DoKickTA-0 [ 8820.801430] @7: (+-) refs=2 fwaddr=0xc00b2039 enqueue=1 status=Active 7-es3-DoKickTA-0 [ 8820.809671] @8: (+-) refs=2 fwaddr=0xc00b2041 enqueue=1 status=Active 8-es3-DoKickTA-0 [ 8820.817912] @9: (+-) refs=2 fwaddr=0xc00b2049 enqueue=1 status=Active 9-es3-DoKickTA-0 [ 8820.826153] @10: (+-) refs=2 fwaddr=0xc00b2051 enqueue=1 status=Active 10-es3-DoKickTA-0 [ 8820.834568] @11: (+-) refs=2 fwaddr=0xc00b2059 enqueue=1 status=Active 11-es3-DoKickTA-0 [ 8820.842983] @12: (+-) refs=2 fwaddr=0xc00b2061 enqueue=1 status=Active 12-es3-DoKickTA-0 [ 8820.851398] @13: (+-) refs=2 fwaddr=0xc00b2069 enqueue=1 status=Active 13-es3-DoKickTA-0 [ 8820.859813] @14: (+-) refs=2 fwaddr=0xc00b2071 enqueue=1 status=Active 14-es3-DoKickTA-0 [ 8820.868228] @15: (+-) refs=2 fwaddr=0xc00b2079 enqueue=1 status=Active 15-es3-DoKickTA-0 [ 8820.876642] @16: (+-) refs=2 fwaddr=0xc00b2081 enqueue=1 status=Active 16-es3-DoKickTA-0 [ 8820.885057] @17: (+-) refs=2 fwaddr=0xc00b2089 enqueue=1 status=Active 17-es3-DoKickTA-0 [ 8820.893471] @18: (+-) refs=2 fwaddr=0xc00b2091 enqueue=1 status=Active 18-es3-DoKickTA-0 [ 8820.901885] @19: (+-) refs=2 fwaddr=0xc00b2099 enqueue=1 status=Active 19-es3-DoKickTA-0 [ 8820.910300] @20: (+-) refs=2 fwaddr=0xc00b20a1 enqueue=1 status=Active 20-es3-DoKickTA-0 [ 8820.918715] @21: (+-) refs=2 fwaddr=0xc00b20a9 enqueue=1 status=Active 21-es3-DoKickTA-0 [ 8820.927129] @22: (+-) refs=2 fwaddr=0xc00b20b1 enqueue=1 status=Active 22-es3-DoKickTA-0 [ 8820.935544] @23: (+-) refs=2 fwaddr=0xc00b20b9 enqueue=1 status=Active 23-es3-DoKickTA-0 [ 8820.943959] @24: (+-) refs=2 fwaddr=0xc00b20c1 enqueue=1 status=Active 24-es3-DoKickTA-0 [ 8820.952373] @25: (+-) refs=2 fwaddr=0xc00b20c9 enqueue=1 status=Active 25-es3-DoKickTA-0 [ 8820.960788] @26: (+-) refs=2 fwaddr=0xc00b20d1 enqueue=1 status=Active 26-es3-DoKickTA-0 [ 8820.969203] @27: (+-) refs=2 fwaddr=0xc00b20d9 enqueue=1 status=Active 27-es3-DoKickTA-0 [ 8820.977617] @28: (+-) refs=2 fwaddr=0xc00b20e1 enqueue=1 status=Active 28-es3-DoKickTA-0 [ 8820.986032] @29: (+-) refs=2 fwaddr=0xc00b20e9 enqueue=1 status=Active 29-es3-DoKickTA-0 [ 8820.994446] @30: (+-) refs=2 fwaddr=0xc00b20f1 enqueue=1 status=Active 30-es3-DoKickTA-0 [ 8821.002861] @31: (+-) refs=2 fwaddr=0xc00b20f9 enqueue=1 status=Active 31-es3-DoKickTA-0 [ 8821.011275] @32: (+-) refs=2 fwaddr=0xc00b2101 enqueue=1 status=Active 32-es3-DoKickTA-0 [ 8821.019690] @33: (+-) refs=2 fwaddr=0xc00b2109 enqueue=1 status=Active 33-es3-DoKickTA-0 [ 8821.028105] @34: (+-) refs=2 fwaddr=0xc00b2111 enqueue=1 status=Active 34-es3-DoKickTA-0 [ 8821.036519] @35: (+-) refs=4 fwaddr=0xc00b2119 enqueue=1 status=Active 35-es3-DoKickTA-0 [ 8821.044934] @36: (+-) refs=2 fwaddr=0xc00b2121 enqueue=1 status=Active 36-es3-DoKickTA-1 [ 8821.053348] @37: (+-) refs=2 fwaddr=0xc00b2129 enqueue=1 status=Active 37-es3-DoKickTA-1 [ 8821.061763] @38: (+-) refs=2 fwaddr=0xc00b2131 enqueue=1 status=Active 38-es3-DoKickTA-1 [ 8821.070177] @39: (+-) refs=2 fwaddr=0xc00b2139 enqueue=1 status=Active 39-es3-DoKickTA-1 [ 8821.078591] @40: (+-) refs=2 fwaddr=0xc00b2141 enqueue=1 status=Active 40-es3-DoKickTA-1 [ 8821.087005] @41: (+-) refs=2 fwaddr=0xc00b2149 enqueue=1 status=Active 41-es3-DoKickTA-1 [ 8821.095420] @42: (+-) refs=2 fwaddr=0xc00b2151 enqueue=1 status=Active 42-es3-DoKickTA-1 [ 8821.103835] @43: (+-) refs=2 fwaddr=0xc00b2159 enqueue=1 status=Active 43-es3-DoKickTA-1 [ 8821.112250] @44: (+-) refs=2 fwaddr=0xc00b2161 enqueue=1 status=Active 44-es3-DoKickTA-1 [ 8821.120664] @45: (+-) refs=2 fwaddr=0xc00b2169 enqueue=1 status=Active 45-es3-DoKickTA-1 [ 8821.129079] @46: (+-) refs=2 fwaddr=0xc00b2171 enqueue=1 status=Active 46-es3-DoKickTA-1 [ 8821.137493] @47: (+-) refs=2 fwaddr=0xc00b2179 enqueue=1 status=Active 47-es3-DoKickTA-1 [ 8821.146097] P3-wayland-glmark2-es2-way-1273: @183 ctx=6495362 refs=29 [ 8821.152520] @0: (+-) refs=2 fwaddr=0xc00bf001 enqueue=1 status=Active 0-es3-DoKickTA-0 [ 8821.160762] @1: (+-) refs=2 fwaddr=0xc00bf009 enqueue=1 status=Active 1-es3-DoKickTA-0 [ 8821.169003] @2: (+-) refs=2 fwaddr=0xc00bf011 enqueue=1 status=Active 2-es3-DoKickTA-0 [ 8821.177244] @3: (+-) refs=2 fwaddr=0xc00bf019 enqueue=1 status=Active 3-es3-DoKickTA-0 [ 8821.185485] @4: (+-) refs=2 fwaddr=0xc00bf021 enqueue=1 status=Active 4-es3-DoKickTA-0 [ 8821.193726] @5: (+-) refs=2 fwaddr=0xc00bf029 enqueue=1 status=Active 5-es3-DoKickTA-0 [ 8821.201967] @6: (+-) refs=2 fwaddr=0xc00bf031 enqueue=1 status=Active 6-es3-DoKickTA-0 [ 8821.210209] @7: (+-) refs=2 fwaddr=0xc00bf039 enqueue=1 status=Active 7-es3-DoKickTA-0 [ 8821.218450] @8: (+-) refs=2 fwaddr=0xc00bf041 enqueue=1 status=Active 8-es3-DoKickTA-0 [ 8821.226691] @9: (+-) refs=2 fwaddr=0xc00bf049 enqueue=1 status=Active 9-es3-DoKickTA-0 [ 8821.234932] @10: (+-) refs=2 fwaddr=0xc00bf051 enqueue=1 status=Active 10-es3-DoKickTA-0 [ 8821.243346] @11: (+-) refs=2 fwaddr=0xc00bf059 enqueue=1 status=Active 11-es3-DoKickTA-0 [ 8821.251761] @12: (+-) refs=2 fwaddr=0xc00bf061 enqueue=1 status=Active 12-es3-DoKickTA-0 [ 8821.260176] @13: (+-) refs=2 fwaddr=0xc00bf069 enqueue=1 status=Active 13-es3-DoKickTA-0 [ 8821.268590] @14: (+-) refs=2 fwaddr=0xc00bf071 enqueue=1 status=Active 14-es3-DoKickTA-0 [ 8821.277005] @15: (+-) refs=2 fwaddr=0xc00bf079 enqueue=1 status=Active 15-es3-DoKickTA-0 [ 8821.285420] @16: (+-) refs=2 fwaddr=0xc00bf081 enqueue=1 status=Active 16-es3-DoKickTA-0 [ 8821.293834] @17: (+-) refs=2 fwaddr=0xc00bf089 enqueue=1 status=Active 17-es3-DoKickTA-0 [ 8821.302249] @18: (+-) refs=2 fwaddr=0xc00bf091 enqueue=1 status=Active 18-es3-DoKickTA-0 [ 8821.310664] @19: (+-) refs=3 fwaddr=0xc00bf099 enqueue=1 status=Active 19-es3-DoKickTA-0 [ 8821.319078] @20: (+-) refs=2 fwaddr=0xc00bf0a1 enqueue=1 status=Active 20-es3-DoKickTA-1 [ 8821.327493] @21: (+-) refs=2 fwaddr=0xc00bf0a9 enqueue=1 status=Active 21-es3-DoKickTA-1 [ 8821.335908] @22: (+-) refs=2 fwaddr=0xc00bf0b1 enqueue=1 status=Active 22-es3-DoKickTA-1 [ 8821.344322] @23: (+-) refs=2 fwaddr=0xc00bf0b9 enqueue=1 status=Active 23-es3-DoKickTA-1 [ 8821.352737] @24: (+-) refs=2 fwaddr=0xc00bf0c1 enqueue=1 status=Active 24-es3-DoKickTA-1 [ 8821.361151] @25: (+-) refs=2 fwaddr=0xc00bf0c9 enqueue=1 status=Active 25-es3-DoKickTA-1 [ 8821.369566] @26: (+-) refs=2 fwaddr=0xc00bf0d1 enqueue=1 status=Active 26-es3-DoKickTA-1 [ 8821.377981] @27: (+-) refs=2 fwaddr=0xc00bf0d9 enqueue=1 status=Active 27-es3-DoKickTA-1 [ 8821.386560] PVR_K: 338: ------[ Debug summary ]------ [ 8821.391698] PVR_K: 338: BIF0 - OK [ 8821.395091] PVR_K: 338: RGX FW State: NOT RESPONDING - KCCB stalled (HWRState 0x00000001: HWR OK; ) [ 8821.404211] PVR_K: 338: RGX FW Power State: RGXFWIF_POW_ON (APM disabled: 0 ok, 0 denied, 0 non-idle, 0 other, 0 total. Latency: 100 ms) [ 8821.416538] PVR_K: 338: RGX DVFS: 0 frequency changes. Current frequency: 749 MHz (sampled at 8049903458a) [ 8821.426262] PVR_K: 338: RGX FW OS 0 State: 0x00000003 (Active: Yes, Freelists: Ok, Grow Request Pending: No) [ 8821.436160] PVR_K: 338: RGX FW OS 1 State: 0x00000003 (Active: Yes, Freelists: Ok, Grow Request Pending: No) [ 8821.446064] PVR_K: 338: Number of HWR: GP(0/0+0), 2D(0/0+0), TA(4/4+0), 3D(2/2+0), CDM(0/0+0), FALSE(0,0,0,0,0) [ 8821.456226] PVR_K: 338: DM 0 (GP) [ 8821.459626] PVR_K: 338: DM 1 (HWRflags 0x00000000: working; ) [ 8821.465451] PVR_K: 338: DM 2 (HWRflags 0x00000000: working; ) [ 8821.471274] PVR_K: 338: Recovery 1: PID = 1225, frame = 8723, HWRTData = 0xC0075C00, EventStatus = 0x00004410, Innocent Lockup [ 8821.482903] PVR_K: 338: CRTimer = 0x000495AD588A, OSTimer = 6730.711539377, CyclesElapsed = 32131840 [ 8821.493319] PVR_K: 338: PreResetTimeInCycles = 151552, HWResetTimeInCycles = 40140288, FreelistReconTimeInCycles = 1177735680, TotalRecoveryTimeInCycles = 1218027520 [ 8821.509388] PVR_K: 338: Recovery 2: PID = 1225, frame = 8785, HWRTData = 0xC0075C00, EventStatus = 0x00004410, Guilty Lockup [ 8821.520861] PVR_K: 338: CRTimer = 0x000495F7E06A, OSTimer = 6732.378764447, CyclesElapsed = 32129280 [ 8821.531281] PVR_K: 338: PreResetTimeInCycles = 49408, HWResetTimeInCycles = 40139520, FreelistReconTimeInCycles = 230144, TotalRecoveryTimeInCycles = 40419072 [ 8821.546737] PVR_K: 338: Recovery 3: PID = 1225, frame = 8787, HWRTData = 0xC0075C00, EventStatus = 0x00004410, Innocent Lockup [ 8821.558368] PVR_K: 338: CRTimer = 0x000495FC5454, OSTimer = 6732.478371658, CyclesElapsed = 32129792 [ 8821.568786] PVR_K: 338: PreResetTimeInCycles = 153088, HWResetTimeInCycles = 40139008, FreelistReconTimeInCycles = 248064, TotalRecoveryTimeInCycles = 40540160 [ 8821.584320] PVR_K: 338: Recovery 4: PID = 1225, frame = 8788, HWRTData = 0xC0075D80, EventStatus = 0x00004410, Guilty Lockup [ 8821.595778] PVR_K: 338: CRTimer = 0x00049600B75D, OSTimer = 6732.576503967, CyclesElapsed = 32120832 [ 8821.606196] PVR_K: 338: PreResetTimeInCycles = 47616, HWResetTimeInCycles = 40139008, FreelistReconTimeInCycles = 283392, TotalRecoveryTimeInCycles = 40470016 [ 8821.621640] PVR_K: 338: DM 3 (HWRflags 0x00000000: working; ) [ 8821.627464] PVR_K: 338: Recovery 1: PID = 1225, frame = 8783, HWRTData = 0xC0075C00, EventStatus = 0x00004410, Innocent Lockup [ 8821.639224] PVR_K: 338: CRTimer = 0x000495AD5920, OSTimer = 6730.711590577, CyclesElapsed = 32018944 [ 8821.649652] PVR_K: 338: PreResetTimeInCycles = 113152, HWResetTimeInCycles = 40140288, FreelistReconTimeInCycles = 1177735680, TotalRecoveryTimeInCycles = 1217989120 [ 8821.665704] PVR_K: 338: Recovery 3: PID = 733, frame = 270931, HWRTData = 0xC0075340, EventStatus = 0x00004410, Innocent Lockup [ 8821.677421] PVR_K: 338: CRTimer = 0x000495FC54DD, OSTimer = 6732.478418421, CyclesElapsed = 32032768 [ 8821.687840] PVR_K: 338: PreResetTimeInCycles = 118016, HWResetTimeInCycles = 40139008, FreelistReconTimeInCycles = 248064, TotalRecoveryTimeInCycles = 40505088 [ 8821.703397] PVR_K: 338: DM 4 (HWRflags 0x00000000: working; ) [ 8821.709228] PVR_K: 338: ------[ Server Thread Summary ]------ [ 8821.715051] PVR_K: 338: pvr_defer_free : Running [ 8821.719921] PVR_K: 338: Number of deferred cleanup items : 0 [ 8821.726003] PVR_K: 338: pvr_device_wdg : Running [ 8821.730870] PVR_K: 338: pvr_cacheop : Running [ 8821.735481] PVR_K: 338: Configuration: QSZ: 16, UKT: -1, KDFT: 131072, KGFT: -1, LINESIZE: 64, PGSIZE: 65536, KDF: Yes, URBF: Yes, KGF: No, KRBF: Yes [ 8821.749362] PVR_K: 338: Pending deferred CacheOp entries : 0 [ 8821.755444] PVR_K: 338: ------[ AppHint Settings ]------ [ 8821.760831] PVR_K: 338: Build Vars [ 8821.764496] PVR_K: 338: HWRDebugDumpLimit: 0x00000001 [ 8821.769978] PVR_K: 338: EnableTrustedDeviceAceConfig: N [ 8821.775654] PVR_K: 338: CleanupThreadPriority: 0x00000005 [ 8821.781497] PVR_K: 338: CleanupThreadWeight: 0x00000000 [ 8821.787166] PVR_K: 338: WatchdogThreadPriority: 0x00000000 [ 8821.793084] PVR_K: 338: WatchdogThreadWeight: 0x00000000 [ 8821.798828] PVR_K: 338: HWPerfClientBufferSize: 0x000c0000 [ 8821.804775] PVR_K: 338: Module Params [ 8821.808694] PVR_K: 338: EnableSignatureChecks: N [ 8821.813769] PVR_K: 338: SignatureChecksBufSize: 0x00002000 [ 8821.819679] PVR_K: 338: DisableClockGating: N [ 8821.824462] PVR_K: 338: BIFTilingMode: 0x00000004 [ 8821.829589] PVR_K: 338: DisableDMOverlap: N [ 8821.834198] PVR_K: 338: EnableCDMKillingRandMode: N [ 8821.839499] PVR_K: 338: EnableFWContextSwitch: 0x00000007 [ 8821.845320] PVR_K: 338: VDMContextSwitchMode: 0x00000000 [ 8821.851055] PVR_K: 338: EnableRDPowerIsland: 0x00000002 [ 8821.856703] PVR_K: 338: GeneralNon4KHeapPageSize: 0x00004000 [ 8821.862783] PVR_K: 338: DriverMode: 0x7fffffff [ 8821.867652] PVR_K: 338: FirmwarePerf: 0x00000000 [ 8821.872693] PVR_K: 338: FWContextSwitchProfile: 0x00000002 [ 8821.878602] PVR_K: 338: HWPerfDisableCustomCounterFilter: N [ 8821.884596] PVR_K: 338: HWPerfFWBufSizeInKB: 0x00000800 [ 8821.890245] PVR_K: 338: HWPerfHostBufSizeInKB: 0x00000800 [ 8821.896065] PVR_K: 338: JonesDisableMask: 0x00000000 [ 8821.901478] PVR_K: 338: NewFilteringMode: Y [ 8821.906094] PVR_K: 338: TruncateMode: 0x00000000 [ 8821.911151] PVR_K: 338: UseMETAT1: 0x00000000 [ 8821.915933] PVR_K: 338: EmuMaxFreq: 0x00000000 [ 8821.920802] PVR_K: 338: GPIOValidationMode: 0x00000000 [ 8821.926362] PVR_K: 338: RGXBVNC: (none) [ 8821.930624] PVR_K: 338: FWContextSwitchCrossDM: 0x00000000 [ 8821.936533] PVR_K: 338: OSidRegion0Min: 0x00000000 0x04000000 0x10000000 0x18000000 0x20000000 0x28000000 0x30000000 0x38000000 [ 8821.948421] PVR_K: 338: OSidRegion0Max: 0x3FFFFFFF 0x0FFFFFFF 0x17FFFFFF 0x1FFFFFFF 0x27FFFFFF 0x2FFFFFFF 0x37FFFFFF 0x3FFFFFFF [ 8821.960321] PVR_K: 338: OSidRegion1Min: 0x3F000000 0x3F000000 0x3F000000 0x3F000000 0x3F000000 0x3F000000 0x3F000000 0x3F000000 [ 8821.972212] PVR_K: 338: OSidRegion1Max: 0x3FFFFFFF 0x3FFFFFFF 0x3FFFFFFF 0x3FFFFFFF 0x3FFFFFFF 0x3FFFFFFF 0x3FFFFFFF 0x3FFFFFFF [ 8821.984100] PVR_K: 338: HTBufferSizeInKB: 0x00000040 [ 8821.989489] PVR_K: 338: FBCDCVersionOverride: 0x00000000 [ 8821.995223] PVR_K: 338: Debugfs Params [ 8821.999225] PVR_K: 338: EnableHTBLogGroup: none [ 8822.004179] PVR_K: 338: HTBOperationMode: dropoldest [ 8822.009568] PVR_K: 338: EnableFTraceGPU: N [ 8822.014089] PVR_K: 338: HWPerfFWFilter: 0x0000000000000000 [ 8822.019997] PVR_K: 338: HWPerfHostFilter: 0x00000000 [ 8822.025399] PVR_K: 338: HWPerfClientFilter_Services: 0x00000000 [ 8822.031747] PVR_K: 338: HWPerfClientFilter_EGL: 0x00000000 [ 8822.037672] PVR_K: 338: HWPerfClientFilter_OpenGLES: 0x00000000 [ 8822.044028] PVR_K: 338: HWPerfClientFilter_OpenCL: 0x00000000 [ 8822.050197] PVR_K: 338: HWPerfClientFilter_OpenRL: 0x00000000 [ 8822.056460] PVR_K: 338: HWPerfClientFilter_Vulkan: 0x00000000 [ 8822.062632] PVR_K: 338: CacheOpConfig: 0x0000000d [ 8822.067763] PVR_K: 338: CacheOpGFThresholdSize: 0xffffffff [ 8822.073672] PVR_K: 338: CacheOpUMKMThresholdSize: 0xffffffff [ 8822.079754] PVR_K: 338: TimeCorrClock: mono [ 8822.084364] PVR_K: 338: Debugfs Params Device ID: 0 [ 8822.089493] PVR_K: 338: AssertOnHWRTrigger: N [ 8822.094273] PVR_K: 338: AssertOutOfMemory: N [ 8822.098985] PVR_K: 338: CheckMList: N [ 8822.103075] PVR_K: 338: EnableHWR: Y [ 8822.107095] PVR_K: 338: EnableLogGroup: none [ 8822.111790] PVR_K: 338: FirmwareLogType: trace [ 8822.116659] PVR_K: 338: EnableAPM: 0x00000002 [ 8822.121440] PVR_K: 338: DisableFEDLogging: N [ 8822.126138] PVR_K: 338: ZeroFreelist: N [ 8822.130398] PVR_K: 338: DustRequestInject: N [ 8822.135093] PVR_K: 338: DisablePDumpPanic: Y [ 8822.139786] PVR_K: 338: EnableFWPoisonOnFree: N [ 8822.144742] PVR_K: 338: FWPoisonOnFreeValue: 0x000000bd [ 8822.150389] PVR_K: 338: ------[ HTB Log state: Off ]------ [ 8822.155955] PVR_K: 338: ------------[ PVR DBG: END ]------------ [ 8822.162040] ------------[ cut here ]------------ [ 8822.166740] WARNING: CPU: 0 PID: 338 at /jenkins/psdkla-thud/auto_release/j7-evm/yocto/tisdk/build/arago-tmp-external-arm-toolchain/work/j7_evm-linux/ti-img-rogue-driver/1.10.5371573-r0e/git/binary_j721e_lin] [ 8822.195868] Modules linked in: xfrm_user xfrm4_tunnel tunnel4 ipcomp xfrm_ipcomp esp4 ah4 af_key xfrm_algo xhci_plat_hcd xhci_hcd usbcore pru_rproc irq_pruss_intc ti_am335x_adc omap_rng rng_core kfifo_buf pr6 [ 8822.251723] CPU: 0 PID: 338 Comm: pvr_device_wdg Tainted: G W O 4.19.94-g5a23bc00e0 #1 [ 8822.260745] Hardware name: Texas Instruments K3 J721E SoC (DT) [ 8822.266560] pstate: 40000005 (nZcv daif -PAN -UAO) [ 8822.271379] pc : PVRSRVDebugRequest+0x308/0x310 [pvrsrvkm] [ 8822.276889] lr : PVRSRVDebugRequest+0x308/0x310 [pvrsrvkm] [ 8822.282356] sp : ffff00000960fca0 [ 8822.285655] x29: ffff00000960fca0 x28: 0000000000000000 [ 8822.290950] x27: ffff800845679538 x26: 0000000000000002 [ 8822.296245] x25: ffff800842e86500 x24: 0000000000000009 [ 8822.301540] x23: 0000000000000000 x22: 0000000000000000 [ 8822.306835] x21: 0000000000000003 x20: ffff800842e865d8 [ 8822.312129] x19: ffff80084567b020 x18: 0000000000000010 [ 8822.317423] x17: 0000000000000000 x16: 0000000000000000 [ 8822.322718] x15: ffffffffffffffff x14: ffff000008cb3648 [ 8822.328012] x13: ffff000088d768a7 x12: ffff000008d768af [ 8822.333307] x11: ffff000008cc9000 x10: ffff00000960f9d0 [ 8822.338601] x9 : 00000000ffffffd0 x8 : ffff0000084e7d80 [ 8822.343896] x7 : 5d20657265682074 x6 : ffff80087fab17e8 [ 8822.349190] x5 : ffff80087fab17e8 x4 : 0000000000000000 [ 8822.354483] x3 : ffff80087fab8560 x2 : 8f5f313550e98b00 [ 8822.359776] x1 : 0000000000000000 x0 : 0000000000000024 [ 8822.365072] Call trace: [ 8822.367548] PVRSRVDebugRequest+0x308/0x310 [pvrsrvkm] [ 8822.372712] DevicesWatchdogThread_ForEachVaCb+0xb8/0xd0 [pvrsrvkm] [ 8822.379000] List_PVRSRV_DEVICE_NODE_ForEach_va+0x74/0xb0 [pvrsrvkm] [ 8822.385376] DevicesWatchdogThread+0x128/0x228 [pvrsrvkm] [ 8822.390793] OSThreadRun+0x20/0x68 [pvrsrvkm] [ 8822.395140] kthread+0x124/0x128 [ 8822.398356] ret_from_fork+0x10/0x18 [ 8822.401916] ---[ end trace 21f443f69d6dab1b ]--- ^C^C^C^C ^C ^C ^C ^C^C
