AM6548: USB1 issue
Part Number: AM6548
Hi TI team,
Currently, I am testing the AM65x industrial development kit.
The SDK version I use is ti-processor-sdk-linux-rt-am65xx-evm-06.02.00.81.
Normally, I can get two usb device by key in "lsusb" command.
root@am65xx-evm:~# lsusb
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
However, after I remove the  x2 Lane PCIe Personality Card and boot up the board, I can't get any usb device by  key in "lsusb" command.
unable to initialize libusb: -99
Based on schematic, the usb0 is in x2 Lane PCIe Personality Card and usb 1 is in main board.
Theoretically, I can get one usb device which in main board at least, isn't it?
Is it an SDK bug?
    I removed the card & i still am able to see the USB instances;
    lsusb
    uname -a
    Linux am65xx-evm 4.19.79-g77dfab56c6 #1 SMP PREEMPT Sun Jan 5 03:08:18 UTC 2020 aarch64 GNU/Linux
    I am not on RT-Linux though. I am on ti-processor-sdk-linux-am65xx-evm-06.02.00.81 SDK.
    Can you please share the full log so that we can see the exact behavior & it will be easy to reproduce the issue.
    - Keerthy
  • Hi Keerthy:
    Log as below.
    with x2 Lane PCIe Personality Card
    U-Boot SPL 2019.01-ga141f7abfd (Jan 05 2020 - 03:55:36 +0000)
    SYSFW ABI: 2.7 (firmware rev 0x0013 '19.9.0-v2019.09 (Terrific Llama')
    Trying to boot from MMC2
    Starting ATF on ARM64 core...
    NOTICE:  BL31: v2.2(release):ti2019.05-rc1
    NOTICE:  BL31: Built : 03:29:45, Jan  5 2020
    I/TC:
    I/TC: OP-TEE version: ti2019.05-rc1-dev (gcc version 8.3.0 (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36))) #1 Sun Jan  5 03:28:58 UTC 2020 aarch64
    I/TC: Initialized
    U-Boot SPL 2019.01-ga141f7abfd (Jan 05 2020 - 03:53:46 +0000)
    Detected: AM6-IDKAPPEVM rev E4
    Detected: SER-PCIE2LEVM rev E3
    U-Boot 2019.01-ga141f7abfd (Jan 05 2020 - 03:53:46 +0000)
    SoC:   AM654 PG 1.0
    Model: Texas Instruments AM654 Base Board
    Board: AM6-COMPROCEVM rev E4
    DRAM:  4 GiB
    MMC:   sdhci@4f80000: 0, sdhci@04FA0000: 1
    Loading Environment from MMC... OK
    In:    serial
    Out:   serial
    Err:   serial
    Net:   eth3: pruss1_eth, eth2: pruss0_eth
    Warning: cpsw_nuss@046000000 using MAC address from ROM
    , eth0: cpsw_nuss@046000000, eth1: pruss2_eth
    Hit any key to stop autoboot:  2  1  0
    switch to partitions #0, OK
    mmc1 is current device
    SD/MMC found on device 1
    ** Unable to read file boot.scr **
    1490 bytes read in 2 ms (727.5 KiB/s)
    Loaded env from uEnv.txt
    Importing environment from mmc1 ...
    Running uenvcmd ...
    1 bytes read in 3 ms (0 Bytes/s)
    Already setup.
    12644360 bytes read in 1054 ms (11.4 MiB/s)
    73168 bytes read in 9 ms (7.8 MiB/s)
    11325 bytes read in 2 ms (5.4 MiB/s)
    2084 bytes read in 3 ms (677.7 KiB/s)
    ## Flattened Device Tree blob at 82000000
       Booting using the fdt blob at 0x82000000
       Loading Device Tree to 00000000fddb3000, end 00000000fdec7fff ... OK
    Starting kernel ...
    [    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
    [    0.000000] Linux version 4.19.79-rt28-g5baf382c8f (oe-user@oe-host) (gcc version 8.3.0 (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36))) #1 SMP PREEMPT RT Sun Jan 5 02:57:52 UTC 2020
    [    0.000000] Machine model: Texas Instruments AM654 Base Board
    [    0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '')
    [    0.000000] bootconsole [ns16550a0] enabled
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a0000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-memory@a0100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a1000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-memory@a1100000, compatible id shared-dma-pool
    [    0.000000] cma: Reserved 24 MiB at 0x00000000fe800000
    [    0.000000] psci: probing for conduit method from DT.
    [    0.000000] psci: PSCIv1.1 detected in firmware.
    [    0.000000] psci: Using standard PSCI v0.2 function IDs
    [    0.000000] psci: Trusted OS migration not required
    [    0.000000] psci: SMC Calling Convention v1.1
    [    0.000000] random: get_random_bytes called from start_kernel+0x94/0x3ec with crng_init=0
    [    0.000000] percpu: Embedded 22 pages/cpu s50560 r8192 d31360 u90112
    [    0.000000] Detected VIPT I-cache on CPU0
    [    0.000000] CPU features: enabling workaround for ARM erratum 845719
    [    0.000000] Speculative Store Bypass Disable mitigation not required
    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 1017344
    [    0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 mtdparts=47040000.spi.0:512k(ospi.tiboot3),2m(ospi.tispl),4m(ospi.u-boot),128k(ospi.env),128k(ospi.env.backup),1m(ospi.sysfw),-@8m(ospi.rootfs) root=PARTUUID=000b6d4a-02 rw rootfstype=ext4 rootwait
    [    0.000000] Dentry cache hash table entries: 524288 (order: 11, 8388608 bytes)
    [    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
    [    0.000000] software IO TLB: mapped [mem 0xf9db3000-0xfddb3000] (64MB)
    [    0.000000] Memory: 3954720K/4134912K available (8190K kernel code, 572K rwdata, 2948K rodata, 576K init, 369K bss, 155616K reserved, 24576K cma-reserved)
    [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
    [    0.000000] rcu: Preemptible hierarchical RCU implementation.
    [    0.000000] rcu: 	RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=4.
    [    0.000000] rcu: 	RCU priority boosting: priority 1 delay 500 ms.
    [    0.000000] 	No expedited grace period (rcu_normal_after_boot).
    [    0.000000] 	Tasks RCU enabled.
    [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
    [    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
    [    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
    [    0.000000] GICv3: Distributor has no Range Selector support
    [    0.000000] GICv3: no VLPI support, no direct LPI support
    [    0.000000] ITS [mem 0x01820000-0x0182ffff]
    [    0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
    [    0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19
    [    0.000000] ITS@0x0000000001820000: allocated 524288 Devices @8fa400000 (flat, esz 8, psz 64K, shr 0)
    [    0.000000] ITS: using cache flushing for cmd queue
    [    0.000000] GIC: using LPI property table @0x00000008fac30000
    [    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001880000
    [    0.000000] GIC: using cache flushing for LPI property table
    [    0.000000] GICv3: CPU0: using LPI pending table @0x00000008fac40000
    [    0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
    [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
    [    0.000005] sched_clock: 56 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
    [    0.000490] Console: colour dummy device 80x25
    [    0.356840] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
    [    0.356849] pid_max: default: 32768 minimum: 301
    [    0.356966] Security Framework initialized
    [    0.357068] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
    [    0.357094] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
    [    0.380332] ASID allocator initialised with 32768 entries
    [    0.432385] rcu: Hierarchical SRCU implementation.
    [    0.460590] Platform MSI: gic-its@1820000 domain created
    [    0.466310] PCI/MSI: /interconnect@100000/interrupt-controller@1800000/gic-its@1820000 domain created
    [    0.480517] smp: Bringing up secondary CPUs ...
    [    0.541048] Detected VIPT I-cache on CPU1
    [    0.541083] GICv3: CPU1: found redistributor 1 region 0:0x00000000018a0000
    [    0.541093] GICv3: CPU1: using LPI pending table @0x00000008fac50000
    [    0.541140] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
    [    0.626828] Detected VIPT I-cache on CPU2
    [    0.626867] GICv3: CPU2: found redistributor 100 region 0:0x00000000018c0000
    [    0.626876] GICv3: CPU2: using LPI pending table @0x00000008fac60000
    [    0.626924] CPU2: Booted secondary processor 0x0000000100 [0x410fd034]
    [    0.683294] Detected VIPT I-cache on CPU3
    [    0.683318] GICv3: CPU3: found redistributor 101 region 0:0x00000000018e0000
    [    0.683326] GICv3: CPU3: using LPI pending table @0x00000008fac70000
    [    0.683353] CPU3: Booted secondary processor 0x0000000101 [0x410fd034]
    [    0.683510] smp: Brought up 1 node, 4 CPUs
    [    0.760955] SMP: Total of 4 processors activated.
    [    0.765770] CPU features: detected: GIC system register CPU interface
    [    0.772357] CPU features: detected: 32-bit EL0 Support
    [    0.778071] CPU: All CPU(s) started at EL2
    [    0.782279] alternatives: patching kernel code
    [    0.783765] devtmpfs: initialized
    [    0.809576] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
    [    0.819564] futex hash table entries: 1024 (order: 4, 65536 bytes)
    [    0.827013] pinctrl core: initialized pinctrl subsystem
    [    0.833563] NET: Registered protocol family 16
    [    0.839685] vdso: 2 pages (1 code @ (____ptrval____), 1 data @ (____ptrval____))
    [    0.847254] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
    [    0.856574] DMA: preallocated 256 KiB pool for atomic allocations
    [    0.891164] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
    [    0.901071] SCSI subsystem initialized
    [    0.905779] media: Linux media interface: v0.10
    [    0.910450] videodev: Linux video capture interface: v2.00
    [    0.916114] pps_core: LinuxPPS API ver. 1 registered
    [    0.921190] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [    0.930546] PTP clock support registered
    [    0.934584] EDAC MC: Ver: 3.0.0
    [    0.939663] Advanced Linux Sound Architecture Driver Initialized.
    [    0.946962] clocksource: Switched to clocksource arch_sys_counter
    [    0.953463] VFS: Disk quotas dquot_6.6.0
    [    0.957547] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
    [    0.975054] NET: Registered protocol family 2
    [    0.980432] tcp_listen_portaddr_hash hash table entries: 2048 (order: 5, 131072 bytes)
    [    0.988679] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
    [    0.996504] TCP bind hash table entries: 32768 (order: 8, 1835008 bytes)
    [    1.005179] TCP: Hash tables configured (established 32768 bind 32768)
    [    1.012216] UDP hash table entries: 2048 (order: 6, 262144 bytes)
    [    1.018732] UDP-Lite hash table entries: 2048 (order: 6, 262144 bytes)
    [    1.025940] NET: Registered protocol family 1
    [    1.035174] RPC: Registered named UNIX socket transport module.
    [    1.041229] RPC: Registered udp transport module.
    [    1.046039] RPC: Registered tcp transport module.
    [    1.050847] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    1.058695] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
    [    1.068861] Initialise system trusted keyrings
    [    1.073612] workingset: timestamp_bits=46 max_order=20 bucket_order=0
    [    1.089059] squashfs: version 4.0 (2009/01/31) Phillip Lougher
    [    1.095889] NFS: Registering the id_resolver key type
    [    1.101102] Key type id_resolver registered
    [    1.105380] Key type id_legacy registered
    [    1.109492] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
    [    1.116583] 9p: Installing v9fs 9p2000 file system support
    [    1.127545] Key type asymmetric registered
    [    1.131742] Asymmetric key parser 'x509' registered
    [    1.136822] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
    [    1.144407] io scheduler noop registered
    [    1.148418] io scheduler deadline registered
    [    1.152941] io scheduler cfq registered (default)
    [    1.157753] io scheduler mq-deadline registered
    [    1.162387] io scheduler kyber registered
    [    1.169873] pinctrl-single 4301c000.pinmux: 70 pins, size 280
    [    1.176628] pinctrl-single 11c000.pinmux: 185 pins, size 740
    [    1.182654] pinctrl-single 11c2e8.pinmux: 9 pins, size 36
    [    1.189616] pinctrl-single a40000.timesync_router: 512 pins, size 2048
    [    1.213357] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
    [    1.242659] brd: module loaded
    [    1.258128] loop: module loaded
    [    1.266144] libphy: Fixed MDIO Bus: probed
    [    1.271315] tun: Universal TUN/TAP device driver, 1.6
    [    1.277493] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
    [    1.285502] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
    [    1.291628] sky2: driver version 1.30
    [    1.297790] VFIO - User Level meta-driver version: 0.3
    [    1.304553] i2c /dev entries driver
    [    1.310419] sdhci: Secure Digital Host Controller Interface driver
    [    1.316753] sdhci: Copyright(c) Pierre Ossman
    [    1.322039] sdhci-pltfm: SDHCI platform and OF driver helper
    [    1.329943] ti-sci interconnect@100000:interconnect@28380000:interconnect@42040000:dmsc: invalid resource
    [    1.342127] optee: probing for conduit method from DT.
    [    1.347412] optee: revision 3.7 (5208e5c1)
    [    1.347797] optee: initialized driver
    [    1.358149] NET: Registered protocol family 17
    [    1.363032] 9pnet: Installing 9P2000 support
    [    1.367507] Key type dns_resolver registered
    [    1.372754] registered taskstats version 1
    [    1.376942] Loading compiled-in X.509 certificates
    [    1.402741] ti-sci interconnect@100000:interconnect@28380000:interconnect@42040000:dmsc: invalid resource
    [    1.412958] ti-sci interconnect@100000:interconnect@28380000:interconnect@42040000:dmsc: ABI: 2.7 (firmware rev 0x0013 '19.9.0-v2019.09 (Terrific Llama')
    [    1.450584] random: fast init done
    [    2.016152] omap_i2c 42120000.i2c: bus 0 rev0.12 at 400 kHz
    [    2.022763] omap_i2c 40b00000.i2c: bus 1 rev0.12 at 100 kHz
    [    2.029560] pca953x 2-0041: 2-0041 supply vcc not found, using dummy regulator
    [    2.037081] pca953x 2-0041: Linked as a consumer to regulator.0
    [    2.067859] pca953x 2-0021: 2-0021 supply vcc not found, using dummy regulator
    [    2.075331] pca953x 2-0021: Linked as a consumer to regulator.0
    [    2.082163] omap_i2c 2000000.i2c: bus 2 rev0.12 at 400 kHz
    [    2.088685] omap_i2c 2010000.i2c: bus 3 rev0.12 at 400 kHz
    [    2.095206] omap_i2c 2020000.i2c: bus 4 rev0.12 at 400 kHz
    [    2.101658] omap_i2c 2030000.i2c: bus 5 rev0.12 at 100 kHz
    [    2.118792] keystone-pcie 5500000.pcie: Linked as a consumer to phy-900000.serdes.0
    [    2.126672] keystone-pcie 5500000.pcie: Linked as a consumer to phy-910000.serdes.1
    [    2.139990] keystone-pcie 5500000.pcie: host bridge /interconnect@100000/pcie@5500000 ranges:
    [    2.148734] keystone-pcie 5500000.pcie:    IO 0x10020000..0x1002ffff -> 0x00000000
    [    2.156498] keystone-pcie 5500000.pcie:   MEM 0x10030000..0x17ffffff -> 0x10030000
    [    3.164656] keystone-pcie 5500000.pcie: Phy link never came up
    [    3.170802] keystone-pcie 5500000.pcie: PCI host bridge to bus 0000:00
    [    3.177485] pci_bus 0000:00: root bus resource [bus 00-ff]
    [    3.183099] pci_bus 0000:00: root bus resource [io  0x0000-0xffff]
    [    3.189425] pci_bus 0000:00: root bus resource [mem 0x10030000-0x17ffffff]
    [    3.205620] pci 0000:00:00.0: BAR 6: assigned [mem 0x10030000-0x1003ffff pref]
    [    3.213024] pci 0000:00:00.0: PCI bridge to [bus 01-ff]
    [    3.220104] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,160] sci-dev-id:195
    [    3.230108] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: enabled
    [    3.236786] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66344100, num_proxies:64
    [    3.244792] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:818, gp-rings[304,464] sci-dev-id:187
    [    3.254848] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: enabled
    [    3.261546] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66344100, num_proxies:64
    [    3.269431] omap8250 40a00000.serial: PM domain pd:149 will not be powered off
    [    3.277331] 40a00000.serial: ttyS1 at MMIO 0x40a00000 (irq = 8, base_baud = 6000000) is a 8250
    [    3.287352] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 22, base_baud = 3000000) is a 8250
    [    3.296117] console [ttyS2] enabled
    [    3.303157] bootconsole [ns16550a0] disabled
    [    3.312789] 2810000.serial: ttyS3 at MMIO 0x2810000 (irq = 23, base_baud = 3000000) is a 8250
    [    3.322294] 2820000.serial: ttyS4 at MMIO 0x2820000 (irq = 24, base_baud = 3000000) is a 8250
    [    3.334720] cadence-qspi 47040000.spi: mt35xu512aba (65536 Kbytes)
    [    3.340914] 7 cmdlinepart partitions found on MTD device 47040000.spi.0
    [    3.347518] Creating 7 MTD partitions on "47040000.spi.0":
    [    3.353000] 0x000000000000-0x000000080000 : "ospi.tiboot3"
    [    3.359713] 0x000000080000-0x000000280000 : "ospi.tispl"
    [    3.366065] 0x000000280000-0x000000680000 : "ospi.u-boot"
    [    3.372462] 0x000000680000-0x0000006a0000 : "ospi.env"
    [    3.378597] 0x0000006a0000-0x0000006c0000 : "ospi.env.backup"
    [    3.385374] 0x0000006c0000-0x0000007c0000 : "ospi.sysfw"
    [    3.391745] 0x000000800000-0x000004000000 : "ospi.rootfs"
    [    3.623359] cadence-qspi 47040000.spi: Cadence QSPI NOR probe failed -517
    [    3.641368] am65-cpsw-nuss 46000000.ethernet: rx-flow-id-base is not set -22
    [    3.648478] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA07100, cpsw version 0x6BA80100 Ports: 2
    [    3.660154] UDMA has not been proped
    [    3.663749] am65-cpsw-nuss 46000000.ethernet: Failed to request tx dma channel -517
    [    3.674206] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a2109, freq:200000000, add_val:4 pps:0
    [    3.683100] thermal thermal_zone1: failed to read out thermal zone (-22)
    [    3.689814] thermal thermal_zone2: failed to read out thermal zone (-22)
    [    3.697579] keystone-wdt 40610000.rti: heartbeat 60 sec
    [    3.704180] mmc0: Unknown controller version (4). You may experience problems.
    [    3.742922] mmc0: SDHCI controller on 4f80000.sdhci [4f80000.sdhci] using ADMA 64-bit
    [    3.751883] mmc1: Unknown controller version (4). You may experience problems.
    [    3.788810] mmc1: SDHCI controller on 4fa0000.sdhci [4fa0000.sdhci] using ADMA 64-bit
    [    3.798324] mmc0: new HS200 MMC card at address 0001
    [    3.804585] mmcblk0: mmc0:0001 S0J56X 14.8 GiB
    [    3.810048] mmcblk0boot0: mmc0:0001 S0J56X partition 1 31.5 MiB
    [    3.820084] mmcblk0boot1: mmc0:0001 S0J56X partition 2 31.5 MiB
    [    3.830474] mmcblk0rpmb: mmc0:0001 S0J56X partition 3 4.00 MiB, chardev (243:0)
    [    3.843230] pca953x 0-0039: 0-0039 supply vcc not found, using dummy regulator
    [    3.850550] pca953x 0-0039: Linked as a consumer to regulator.0
    [    3.851016]  mmcblk0: p1 p2
    [    3.884864] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fc5900
    [    3.891947] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fc5900
    [    3.899704] ti-udma 285c0000.udmap: Channels: 96 (tchan: 48, echan: 0, rchan: 48, rflow: 96)
    [    3.917608] ti-udma 31150000.udmap: Channels: 267 (tchan: 120, echan: 32, rchan: 150, rflow: 300)
    [    3.951885] cadence-qspi 47040000.spi: mt35xu512aba (65536 Kbytes)
    [    3.958075] 7 cmdlinepart partitions found on MTD device 47040000.spi.0
    [    3.964678] Creating 7 MTD partitions on "47040000.spi.0":
    [    3.970167] 0x000000000000-0x000000080000 : "ospi.tiboot3"
    [    3.976907] 0x000000080000-0x000000280000 : "ospi.tispl"
    [    3.983308] 0x000000280000-0x000000680000 : "ospi.u-boot"
    [    3.989716] 0x000000680000-0x0000006a0000 : "ospi.env"
    [    3.995868] 0x0000006a0000-0x0000006c0000 : "ospi.env.backup"
    [    4.002606] 0x0000006c0000-0x0000007c0000 : "ospi.sysfw"
    [    4.008907] 0x000000800000-0x000004000000 : "ospi.rootfs"
    [    4.024472] m25p80 spi7.0: n25q128a13 (16384 Kbytes)
    [    4.031532] am65-cpsw-nuss 46000000.ethernet: rx-flow-id-base is not set -22
    [    4.038634] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA07100, cpsw version 0x6BA80100 Ports: 2
    [    4.062297] am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48
    [    4.077001] pps pps0: new PPS source ptp1
    [    4.081252] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a2109, freq:200000000, add_val:4 pps:1
    [    4.090202] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 0.4
    [    4.097413] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
    [    4.142997] am65-cpsw-nuss 46000000.ethernet: davinci mdio revision 9.7, bus freq 1000000
    [    4.151162] libphy: 46000000.ethernet: probed
    [    4.160821] input: gpio-keys as /devices/platform/gpio-keys/input/input0
    [    4.167880] hctosys: unable to open rtc device (rtc0)
    [    4.287484] ALSA device list:
    [    4.290457]   No soundcards found.
    [    4.294754] Waiting for root device PARTUUID=000b6d4a-02...
    [    4.995373] mmc1: new high speed SDHC card at address aaaa
    [    5.002189] mmcblk1: mmc1:aaaa SB16G 14.8 GiB
    [    5.011378]  mmcblk1: p1 p2
    [    5.630551] EXT4-fs (mmcblk1p2): recovery complete
    [    5.636602] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Opts: (null)
    [    5.644758] VFS: Mounted root (ext4 filesystem) on device 179:98.
    [    5.661144] devtmpfs: mounted
    [    5.664778] Freeing unused kernel memory: 576K
    [    5.669363] Run /sbin/init as init process
    [    6.025693] systemd[1]: System time before build time, advancing clock.
    [    6.152092] NET: Registered protocol family 10
    [    6.157881] Segment Routing with IPv6
    [    6.178466] systemd[1]: systemd 239 running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR +SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN2 -IDN -PCRE2 default-hierarchy=hybrid)
    [    6.200248] systemd[1]: Detected architecture arm64.
    Welcome to Arago 2019.11!
    [    6.230031] systemd[1]: Set hostname to <am65xx-evm>.
    [    6.447598] systemd[1]: File /lib/systemd/system/systemd-journald.service:36 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
    [    6.464629] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
    [    6.737283] random: systemd: uninitialized urandom read (16 bytes read)
    [    6.748714] systemd[1]: Created slice system-serial\x2dgetty.slice.
    [  OK  ] Created slice system-serial\x2dgetty.slice.
    [    6.767236] random: systemd: uninitialized urandom read (16 bytes read)
    [    6.796951] systemd[1]: Listening on Process Core Dump Socket.
    [  OK  ] Listening on Process Core Dump Socket.
    [    6.815183] random: systemd: uninitialized urandom read (16 bytes read)
    [    6.822432] systemd[1]: Listening on udev Control Socket.
    [  OK  ] Listening on udev Control Socket.
    [    6.858674] systemd[1]: Listening on Journal Socket (/dev/log).
    [  OK  ] Listening on Journal Socket (/dev/log).
    [    6.875746] systemd[1]: Listening on udev Kernel Socket.
    [  OK  ] Listening on udev Kernel Socket.
    [  OK  ] Reached target Swap.
    [  OK  ] Created slice User and Session Slice.
    [  OK  ] Reached target Slices.
    [  OK  ] Created slice system-getty.slice.
    [  OK  ] Started Dispatch Password Requests to Console Directory Watch.
    [  OK  ] Listening on initctl Compatibility Named Pipe.
    [  OK  ] Listening on Network Service Netlink Socket.
    [  OK  ] Started Forward Password Requests to Wall Directory Watch.
    [  OK  ] Reached target Paths.
    [  OK  ] Listening on Journal Socket.
             Starting udev Coldplug all Devices...
             Starting Journal Service...
             Mounting POSIX Message Queue File System...
             Mounting Kernel Debug File System...
             Mounting Temporary Directory (/tmp)...
             Starting Create list of required st�Kce nodes for the current kernel...
             Starting Load Kernel Modules...
    [  OK  ] Started Hardware RNG Entropy Gatherer Daemon[    7.208634] cryptodev: loading out-of-tree module taints kernel.
    [    7.221972] cryptodev: driver 1.9 loaded.
             Mounting Huge Pages File System...
             Starting Remount Root and Kernel File Systems...
    [  OK  ] Reached target Remote File Systems.
    [    7.308425] EXT4-fs (mmcblk1p2): re-mounted. Opts: (null)
    [  OK  ] Started Journal Service.
    [  OK  ] Mounted POSIX Message Queue File System.
    [  OK  ] Mounted Kernel Debug File System.
    [  OK  ] Mounted Temporary Directory (/tmp).
    [  OK  ] Started Create list of required sta�Kvice nodes for the current kernel.
    [  OK  ] Started Load Kernel Modules.
    [  OK  ] Mounted Huge Pages File System.
    [  OK  ] Started Remount Root and Kernel File Systems.
             Starting Apply Kernel Variables...
             Mounting Kernel Configuration File System...
             Starting Create Static Device Nodes in /dev...
             Starting Flush Journal to Persistent Storage...
    [  OK  ] Started Apply Kernel Variables.
    [  OK  ] Mounted Kernel Configuration File System.
    [  OK  ] Started Create Static Device Nodes in /dev.
    [    7.672704] systemd-journald[170]: Received request to flush runtime journal from PID 1
    [  OK  ] Reached target Local File Systems (Pre).
             Mounting /media/ram...
    [  OK  ] Reached target Containers.
             Mounting /var/volatile...
             Starting udev Kernel Device Manager...
    [  OK  ] Started Flush Journal to Persistent Storage.
    [  OK  ] Mounted /media/ram.
    [  OK  ] Mounted /var/volatile.
             Starting Load/Save Random Seed...
    [  OK  ] Reached target Local File Systems.
             Starting Create Volatile Files and Directories...
    [  OK  ] Started udev Kernel Device Manager.
    [  OK  ] Started Load/Save Random Seed.
    [  OK  ] Started Create Volatile Files and Directories.
             Starting Network Time Synchronization...
             Starting Update UTMP about System Boot/Shutdown...
             Starting Network Service...
    [  OK  ] Started Update UTMP about System Boot/Shutdown.
    [    8.517842] input: gpio-decoder as /devices/platform/gpio-decoder/input/input1
    [  OK  ] Started Network Service.
             Starting Network Name Resolution...
    [    9.097181] [drm] Initialized pvr 1.17.4948957 20110701 for 7000000.gpu on minor 0
    [    9.220092] dwc3 4010000.usb: Failed to get clk 'ref': -2
    [    9.241909] dwc3 4030000.usb: Failed to get clk 'ref': -2
    [    9.247984] OF: graph: no port node found in /interconnect@100000/phy@4110000
             Starting Wait for Network to be Configured...
    [  OK  ] Started Network Time Synchronization.
    [    9.355462] CAN device driver interface
    [  OK  ] Found device /dev/ttyS2.
    [  OK  ] Reached target System Time Synchronized.
    [  OK  ] Found device /dev/ttyS1.
    [    9.552414] m_can 40528000.mcan: m_can device registered (irq=17, version=32)
    [    9.670638] m_can 40568000.mcan: m_can device registered (irq=19, version=32)
    [  OK  ] Started Network Name Resolution.
    [  OK  ] Reached target Host and Network Name Lookups.
    [  OK  ] Reached target Network.
    [    9.850458] TI DP83867 k3-cpsw-mdio:00: attached PHY driver [TI DP83867] (mii_bus:phy_addr=k3-cpsw-mdio:00, irq=POLL)
    [    9.866061] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
    [  OK  ] Started udev Coldplug all Devices.
    [  OK  ] Reached target System Initialization.
    [  OK  ] Listening on RPCbind Server Activation Socket.
             Starting Reboot and dump vmcore via kexec...
    [  OK  ] Started Daily rotation of log files.
    [  OK  ] Listening on D-Bus System Message Bus Socket.
    [  OK  ] Started Daily Cleanup of Temporary Directories.
    [  OK  ] Reached target Timers.
    [  OK  ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
    [  OK  ] Listening on dropbear.socket.
    [  OK  ] Reached target Sockets.
    [  OK  ] Reached target Basic System.
             Starting RPC Bind Service...
    [  OK  ] Started Job spooling tools.
             Starting rc.pvr.service...
    [  OK  ] Started Periodic Command Scheduler.
             Starting Permit User Sessions...
    [  OK  ] Started irqbalance daemon.
    [   10.316871] PVR_K: UM DDK-(4948957) and KM DDK-(4948957) match. [ OK ]
    [  OK  ] Started D-Bus System Message Bus.
    [  OK  ] Started TEE Supplicant.
    [   10.830068] omap_rng 4e10000.trng: Random Number Generator ver. 230b34c
    [   10.830141] random: crng init done
    [   10.830152] random: 7 urandom warning(s) missed due to ratelimiting
    [   10.876359] am65-cpsw-nuss 46000000.ethernet eth0: Link is Down
    [   10.908179] usbcore: registered new interface driver usbfs
    [   10.918573] usbcore: registered new interface driver hub
    [   10.932736] usbcore: registered new device driver usb
             Starting Simple Network Management Protocol (SNMP) Daemon....
    [   11.023126] davinci_mdio b032400.mdio: davinci mdio revision 1.7, bus freq 1000000
    [   11.030715] libphy: b032400.mdio: probed
    [   11.061059] k3_r5_rproc interconnect@100000:interconnect@28380000:r5fss@41000000: creating child devices for R5F cores
    [   11.071361] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller
    [   11.077623] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 1
    [   11.086225] xhci-hcd xhci-hcd.2.auto: hcc params 0x0298fe6d hci version 0x110 quirks 0x0000000000010010
    [   11.093093] davinci_mdio b032400.mdio: phy[0]: device b032400.mdio:00, driver TI DP83867
    [   11.093105] davinci_mdio b032400.mdio: phy[3]: device b032400.mdio:03, driver TI DP83867
    [   11.113247] xhci-hcd xhci-hcd.2.auto: irq 308, io mem 0x04010000
    [   11.121589] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
    [   11.129903] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [   11.137222] usb usb1: Product: xHCI Host Controller
    [   11.155431] usb usb1: Manufacturer: Linux 4.19.79-rt28-g5baf382c8f xhci-hcd
    [   11.171569] usb usb1: SerialNumber: xhci-hcd.2.auto
    [   11.174460] hub 1-0:1.0: USB hub found
    [   11.174514] hub 1-0:1.0: 1 port detected
    [   11.176375] platform 41000000.r5f: configured R5F for remoteproc mode
    [   11.180653] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller
    [   11.180681] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 2
    [   11.180706] xhci-hcd xhci-hcd.2.auto: Host supports USB 3.0 SuperSpeed
    [   11.180825] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
    [   11.180990] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 4.19
    [   11.180998] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [   11.181005] usb usb2: Product: xHCI Host Controller
    [   11.181011] usb usb2: Manufacturer: Linux 4.19.79-rt28-g5baf382c8f xhci-hcd
    [   11.181018] usb usb2: SerialNumber: xhci-hcd.2.auto
    [   11.182374] platform 41000000.r5f: assigned reserved memory node r5f-dma-memory@a0000000
    [   11.229385] remoteproc remoteproc0: 41000000.r5f is available
    [   11.254102] hub 2-0:1.0: USB hub found
    [   11.254398] hub 2-0:1.0: 1 port detected
             Starting Print notice about GPLv3 packages...
    [   11.395211] davinci_mdio b132400.mdio: davinci mdio revision 1.7, bus freq 1000000
    [   11.405043] libphy: b132400.mdio: probed
    [   11.445663] davinci_mdio b132400.mdio: phy[0]: device b132400.mdio:00, driver TI DP83867
    [   11.453812] davinci_mdio b132400.mdio: phy[3]: device b132400.mdio:03, driver TI DP83867
    [   11.493706] remoteproc remoteproc0: powering up 41000000.r5f
    [   11.499499] remoteproc remoteproc0: Booting fw image am65x-mcu-r5f0_0-fw, size 4142860
             Starting Lightning Fast Webserver With Light System Req[   11.512268] platform 41000000.r5f: booting R5F core using boot addr = 0x0
    uirements...
    [   11.538464] virtio_rpmsg_bus virtio0: rpmsg host is online
    [   11.544094] remoteproc remoteproc0: registered virtio0 (type 7)
    [   11.550023] remoteproc remoteproc0: remote processor 41000000.r5f is now up
    [   11.559605] virtio_rpmsg_bus virtio0: creating channel rpmsg-proto addr 0x3d
             Starting TI IPC Daemon...
    [   11.675107] davinci_mdio b232400.mdio: davinci mdio revision 1.7, bus freq 1000000
    [   11.682832] libphy: b232400.mdio: probed
    [   11.720969] davinci_mdio b232400.mdio: phy[0]: device b232400.mdio:00, driver TI DP83867
    [   11.729800] davinci_mdio b232400.mdio: phy[3]: device b232400.mdio:03, driver TI DP83867
             Starting Avahi mDNS/DNS-SD Stack...
             Starting Login Service...
    [  OK  ] Started Reboot and dump vmcore via kexec.
    [  OK  ] Started RPC Bind Service.
    [  OK  ] Started rc.pvr.service.
    [  OK  ] Started Simple Network Management Protocol (SNMP) Daemon..
    [  OK  ] Started Permit User Sessions.
    [  OK  ] Started Lightning Fast Webserver With Light System Requirements.
    [  OK  ] Started TI IPC Daemon.
    [   12.594121] remoteproc remoteproc1: b034000.pru is available
    [   12.603951] pru-rproc b034000.pru: PRU rproc node pru@b034000 probed successfully
    [   12.630508] remoteproc remoteproc2: b004000.rtu is available
    [   12.640288] pru-rproc b004000.rtu: PRU rproc node rtu@b004000 probed successfully
    [   12.649307] remoteproc remoteproc3: b038000.pru is available
    [   12.655176] pru-rproc b038000.pru: PRU rproc node pru@b038000 probed successfully
    [   12.663594] remoteproc remoteproc4: b006000.rtu is available
    [   12.669404] pru-rproc b006000.rtu: PRU rproc node rtu@b006000 probed successfully
    [   12.702040] remoteproc remoteproc5: b134000.pru is available
    [   12.709113] pru-rproc b134000.pru: PRU rproc node pru@b134000 probed successfully
    [   12.754091] remoteproc remoteproc6: b104000.rtu is available
    [   12.761693] pru-rproc b104000.rtu: PRU rproc node rtu@b104000 probed successfully
    [   12.807687] remoteproc remoteproc7: b138000.pru is available
    [   12.813648] pru-rproc b138000.pru: PRU rproc node pru@b138000 probed successfully
    [   12.827916] remoteproc remoteproc8: b106000.rtu is available
    [   12.835356] pru-rproc b106000.rtu: PRU rproc node rtu@b106000 probed successfully
    [   12.848386] remoteproc remoteproc9: b234000.pru is available
    [   12.858697] pru-rproc b234000.pru: PRU rproc node pru@b234000 probed successfully
    [   12.869105] remoteproc remoteproc10: b204000.rtu is available
    [   12.879646] pru-rproc b204000.rtu: PRU rproc node rtu@b204000 probed successfully
    [   12.893199] remoteproc remoteproc11: b238000.pru is available
    [   12.902189] pru-rproc b238000.pru: PRU rproc node pru@b238000 probed successfully
    [   12.912656] remoteproc remoteproc12: b206000.rtu is available
    [   12.921332] pru-rproc b206000.rtu: PRU rproc node rtu@b206000 probed successfully
    [   13.018267] icssg-prueth pruss1_eth: TI PRU ethernet driver initialized: dual EMAC mode
    [   13.120381] icssg-prueth pruss0_eth: TI PRU ethernet driver initialized: dual EMAC mode
    [   13.191463] icssg-prueth pruss2_eth: TI PRU ethernet driver initialized: dual EMAC mode
    [  OK  ] Created slice system-systemd\x2dfsck.slice.
    [  OK  ] Started Getty on tty1.
    [  OK  ] Started Serial Getty on ttyS1.
    [  OK  ] Started Serial Getty on ttyS2.
    [  OK  ] Reached target Login Prompts.
             Starting Synchronize System and HW clocks...
             Starting weston.service...
    [  OK  ] Started NFS status monitor for NFSv2/3 locking..
    [FAILED] Failed to start Synchronize System and HW clocks.
    See 'systemctl status sync-clocks.service' for details.
    [  OK  ] Started Avahi mDNS/DNS-SD Stack.
    [  OK  ] Started Login Service.
    [  OK  ] Started weston.service.
    [   13.949007] am65-cpsw-nuss 46000000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
    [   13.951098] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
             Starting Matrix GUI...
             Starting telnetd.service...
    [  OK  ] Started telnetd.service.
    [  OK  ] Started Matrix GUI.
             Starting thttpd.service...
    NOTICE: This file system contains the following GPLv3 packages:
    	autoconf
    	bash-dev
    	bash
    	bc
    	binutils
    	cifs-utils
    	cpio
    	cpp-symlinks
    	cpp
    	dosfstools
    	elfutils
    	g++-symlinks
    	g++
    	gawk
    	gcc-symlinks
    	gcc
    	gdb
    	gdbserver
    	gettext
    	glmark2
    	gstreamer1.0-libav
    	gzip
    	hidapi
    	libbfd
    	libcairo-perf-utils
    	libdw1
    	libelf1
    	libgdbm-compat4
    	libgdbm-dev
    	libgdbm6
    	libgettextlib
    	libgettextsrc
    	libgmp10
    	libidn2-0
    	libmpc3
    	libmpfr6
    	libreadline-dev
    	libreadline7
    	libunistring2
    	m4-dev
    	m4
    	make
    	nettle
    	parted
    	pdm-anomaly-detection
    	swig-dev
    	swig
    	which
    If you do not wish to distribute GPLv3 components please remove
    the above packages prior to distribution.  This can be done using
    the opkg remove command.  i.e.:
        opkg remove <package>
    Where <package> is the name printed in the list above
    NOTE: If the package is a dependency of another package you
          will be notified of the dependent packages.  You should
          use the --force-removal-of-dependent-packages option to
          also remove the dependent packages as well
    [  OK  ] Started Print notice about GPLv3 packages.
    [  OK  ] Started thttpd.service.
    [   15.579127] remoteproc remoteproc7: powering up b138000.pru
    [   15.615684] remoteproc remoteproc7: Booting fw image ti-pruss/am65x-pru1-prueth-fw.elf, size 16460
    [   15.625020] remoteproc remoteproc7: remote processor b138000.pru is now up
    [   15.631953] remoteproc remoteproc8: powering up b106000.rtu
    [   15.642597] remoteproc remoteproc8: Booting fw image ti-pruss/am65x-rtu1-prueth-fw.elf, size 15540
    [   15.651649] remoteproc remoteproc8: remote processor b106000.rtu is now up
    [   15.660446] net eth2: started
    [   15.664216] IPv6: ADDRCONF(NETDEV_UP): eth2: link is not ready
    [   15.719799] NET: Registered protocol family 45
    [   15.844686] remoteproc remoteproc5: powering up b134000.pru
    [   15.858078] remoteproc remoteproc5: Booting fw image ti-pruss/am65x-pru0-prueth-fw.elf, size 16460
    [   15.867230] remoteproc remoteproc5: remote processor b134000.pru is now up
    [   15.874157] remoteproc remoteproc6: powering up b104000.rtu
    [   15.884865] remoteproc remoteproc6: Booting fw image ti-pruss/am65x-rtu0-prueth-fw.elf, size 15540
    [   15.893869] remoteproc remoteproc6: remote processor b104000.rtu is now up
    [   15.902656] net eth1: started
    [   15.906566] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
    [   15.951820] remoteproc remoteproc3: powering up b038000.pru
    [   15.957838] remoteproc remoteproc3: Booting fw image ti-pruss/am65x-pru1-prueth-fw.elf, size 16460
    [   15.970872] remoteproc remoteproc3: remote processor b038000.pru is now up
    [   15.977803] remoteproc remoteproc4: powering up b006000.rtu
    [   15.986674] remoteproc remoteproc4: Booting fw image ti-pruss/am65x-rtu1-prueth-fw.elf, size 15540
    [   15.995754] remoteproc remoteproc4: remote processor b006000.rtu is now up
    [   16.004699] net eth4: started
    [   16.008809] IPv6: ADDRCONF(NETDEV_UP): eth4: link is not ready
    [   16.036162] remoteproc remoteproc1: powering up b034000.pru
    [   16.042227] remoteproc remoteproc1: Booting fw image ti-pruss/am65x-pru0-prueth-fw.elf, size 16460
    [   16.051591] remoteproc remoteproc1: remote processor b034000.pru is now up
    [   16.058512] remoteproc remoteproc2: powering up b004000.rtu
    [   16.064696] remoteproc remoteproc2: Booting fw image ti-pruss/am65x-rtu0-prueth-fw.elf, size 15540
    [   16.073691] remoteproc remoteproc2: remote processor b004000.rtu is now up
    [   16.082336] net eth3: started
    [   16.085909] IPv6: ADDRCONF(NETDEV_UP): eth3: link is not ready
    [  OK  ] Found device /dev/mmcblk0p1.
    [   16.184441] remoteproc remoteproc11: powering up b238000.pru
    [   16.190606] remoteproc remoteproc11: Booting fw image ti-pruss/am65x-pru1-prueth-fw.elf, size 16460
    [   16.199896] remoteproc remoteproc11: remote processor b238000.pru is now up
    [   16.206921] remoteproc remoteproc12: powering up b206000.rtu
    [   16.213046] remoteproc remoteproc12: Booting fw image ti-pruss/am65x-rtu1-prueth-fw.elf, size 15540
    [   16.222260] remoteproc remoteproc12: remote processor b206000.rtu is now up
    [   16.231215] net eth6: started
    [   16.234806] IPv6: ADDRCONF(NETDEV_UP): eth6: link is not ready
    [  OK  ] Found device /dev/mmcblk0p2.
    [   16.286254] remoteproc remoteproc9: powering up b234000.pru
    [   16.292562] remoteproc remoteproc9: Booting fw image ti-pruss/am65x-pru0-prueth-fw.elf, size 16460
    [   16.301579] remoteproc remoteproc9: remote processor b234000.pru is now up
    [   16.308501] remoteproc remoteproc10: powering up b204000.rtu
             Starting File System Check on /dev/mmcblk0p2...
    [   16.314322] remoteproc remoteproc10: Booting fw image ti-pruss/am65x-rtu0-prueth-fw.elf, size 15540
    [   16.328340] remoteproc remoteproc10: remote processor b204000.rtu is now up
    [   16.337173] net eth5: started
             Starting File System Check on /dev/mmcblk0p1...
    [   16.340613] IPv6: ADDRCONF(NETDEV_UP): eth5: link is not ready
    [  OK  ] Started Hardware RNG Entropy Gatherer Daemon.
    [  OK  ] Found device /dev/mmcblk1p1.
    [  OK  ] Started File System Check on /dev/mmcblk0p2.
    [  OK  ] Started File System Check on /dev/mmcblk0p1.
    [  OK  ] Created slice system-systemd\x2dcoredump.slice.
    [  OK  ] Started Process Core Dump (PID 1263/UID 0).
             Mounting /run/media/mmcblk0p1...
             Mounting /run/media/mmcblk0p2...
             Starting File System Check on /dev/mmcblk1p1...
    [   16.673068] EXT4-fs (mmcblk0p2): mounting ext3 file system using the ext4 subsystem
    [  OK  ] Mounted /run/media/mmcblk0p1.
    [   16.695476] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
    [  OK  ] Mounted /run/media/mmcblk0p2.
    [  OK  ] Started File System Check on /dev/mmcblk1p1.
             Mounting /run/media/mmcblk1p1...
    [  OK  ] Mounted /run/media/mmcblk1p1.
     _____                    _____           _         _
    |  _  |___ ___ ___ ___   |  _  |___ ___  |_|___ ___| |_
    |     |  _| .'| . | . |  |   __|  _| . | | | -_|  _|  _|
    |__|__|_| |__,|_  |___|  |__|  |_| |___|_| |___|___|_|
                  |___|                    |___|
    Arago Project http://arago-project.org am65xx-evm ttyS2
    Arago 2019.11 am65xx-evm ttyS2
    am65xx-evm login: root
    root@am65xx-evm:~# uname -a
    Linux am65xx-evm 4.19.79-rt28-g5baf382c8f #1 SMP PREEMPT RT Sun Jan 5 02:57:52 UTC 2020 aarch64 GNU/Linux
    root@am65xx-evm:~#
    without x2 Lane PCIe Personality Card
    I/TC:
    I/TC: Initialized
    SoC:   AM654 PG 1.0
    DRAM:  4 GiB
    In:    serial
    Out:   serial
    Err:   serial
    1490 bytes read in 1 ms (1.4 MiB/s)
    Running uenvcmd ...
    Already setup.
    12644360 bytes read in 1055 ms (11.4 MiB/s)
    Starting kernel ...
    [    0.000006] sched_clock: 56 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
    [    0.000477] Console: colour dummy device 80x25
    [    0.356847] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
    [    0.356856] pid_max: default: 32768 minimum: 301
    [    0.356974] Security Framework initialized
    [    0.357078] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
    [    0.357104] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
    [    0.380329] ASID allocator initialised with 32768 entries
    [    0.432381] rcu: Hierarchical SRCU implementation.
    [    0.460586] Platform MSI: gic-its@1820000 domain created
    [    0.466294] PCI/MSI: /interconnect@100000/interrupt-controller@1800000/gic-its@1820000 domain created
    [    0.480513] smp: Bringing up secondary CPUs ...
    [    0.541044] Detected VIPT I-cache on CPU1
    [    0.541081] GICv3: CPU1: found redistributor 1 region 0:0x00000000018a0000
    [    0.541090] GICv3: CPU1: using LPI pending table @0x00000008fac50000
    [    0.541137] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
    [    0.626824] Detected VIPT I-cache on CPU2
    [    0.626862] GICv3: CPU2: found redistributor 100 region 0:0x00000000018c0000
    [    0.626872] GICv3: CPU2: using LPI pending table @0x00000008fac60000
    [    0.626919] CPU2: Booted secondary processor 0x0000000100 [0x410fd034]
    [    0.683292] Detected VIPT I-cache on CPU3
    [    0.683316] GICv3: CPU3: found redistributor 101 region 0:0x00000000018e0000
    [    0.683324] GICv3: CPU3: using LPI pending table @0x00000008fac70000
    [    0.683351] CPU3: Booted secondary processor 0x0000000101 [0x410fd034]
    [    0.683504] smp: Brought up 1 node, 4 CPUs
    [    0.760949] SMP: Total of 4 processors activated.
    [    0.765762] CPU features: detected: GIC system register CPU interface
    [    0.772350] CPU features: detected: 32-bit EL0 Support
    [    0.778059] CPU: All CPU(s) started at EL2
    [    0.782268] alternatives: patching kernel code
    [    0.783766] devtmpfs: initialized
    [    0.809429] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
    [    0.819442] futex hash table entries: 1024 (order: 4, 65536 bytes)
    [    0.826890] pinctrl core: initialized pinctrl subsystem
    [    0.833453] NET: Registered protocol family 16
    [    0.839568] vdso: 2 pages (1 code @ (____ptrval____), 1 data @ (____ptrval____))
    [    0.847155] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
    [    0.856481] DMA: preallocated 256 KiB pool for atomic allocations
    [    0.890310] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
    [    0.900136] SCSI subsystem initialized
    [    0.904862] media: Linux media interface: v0.10
    [    0.909563] videodev: Linux video capture interface: v2.00
    [    0.915222] pps_core: LinuxPPS API ver. 1 registered
    [    0.920299] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [    0.929666] PTP clock support registered
    [    0.933706] EDAC MC: Ver: 3.0.0
    [    0.938747] Advanced Linux Sound Architecture Driver Initialized.
    [    0.946033] clocksource: Switched to clocksource arch_sys_counter
    [    0.952513] VFS: Disk quotas dquot_6.6.0
    [    0.956607] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
    [    0.974098] NET: Registered protocol family 2
    [    0.979351] tcp_listen_portaddr_hash hash table entries: 2048 (order: 5, 131072 bytes)
    [    0.987646] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
    [    0.995468] TCP bind hash table entries: 32768 (order: 8, 1835008 bytes)
    [    1.004145] TCP: Hash tables configured (established 32768 bind 32768)
    [    1.011196] UDP hash table entries: 2048 (order: 6, 262144 bytes)
    [    1.017714] UDP-Lite hash table entries: 2048 (order: 6, 262144 bytes)
    [    1.024932] NET: Registered protocol family 1
    [    1.030149] RPC: Registered named UNIX socket transport module.
    [    1.036204] RPC: Registered udp transport module.
    [    1.041013] RPC: Registered tcp transport module.
    [    1.045822] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    1.053676] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
    [    1.063788] Initialise system trusted keyrings
    [    1.068613] workingset: timestamp_bits=46 max_order=20 bucket_order=0
    [    1.083989] squashfs: version 4.0 (2009/01/31) Phillip Lougher
    [    1.090869] NFS: Registering the id_resolver key type
    [    1.096062] Key type id_resolver registered
    [    1.100351] Key type id_legacy registered
    [    1.104462] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
    [    1.111563] 9p: Installing v9fs 9p2000 file system support
    [    1.122225] Key type asymmetric registered
    [    1.126422] Asymmetric key parser 'x509' registered
    [    1.131472] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
    [    1.139042] io scheduler noop registered
    [    1.143057] io scheduler deadline registered
    [    1.147590] io scheduler cfq registered (default)
    [    1.152401] io scheduler mq-deadline registered
    [    1.157035] io scheduler kyber registered
    [    1.164318] pinctrl-single 4301c000.pinmux: 70 pins, size 280
    [    1.171056] pinctrl-single 11c000.pinmux: 185 pins, size 740
    [    1.177077] pinctrl-single 11c2e8.pinmux: 9 pins, size 36
    [    1.183983] pinctrl-single a40000.timesync_router: 512 pins, size 2048
    [    1.207126] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
    [    1.236462] brd: module loaded
    [    1.252301] loop: module loaded
    [    1.260085] libphy: Fixed MDIO Bus: probed
    [    1.265135] tun: Universal TUN/TAP device driver, 1.6
    [    1.271287] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
    [    1.279307] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
    [    1.285437] sky2: driver version 1.30
    [    1.291556] VFIO - User Level meta-driver version: 0.3
    [    1.298305] i2c /dev entries driver
    [    1.304066] sdhci: Secure Digital Host Controller Interface driver
    [    1.310412] sdhci: Copyright(c) Pierre Ossman
    [    1.315669] sdhci-pltfm: SDHCI platform and OF driver helper
    [    1.323519] ti-sci interconnect@100000:interconnect@28380000:interconnect@42040000:dmsc: invalid resource
    [    1.335824] optee: probing for conduit method from DT.
    [    1.341135] optee: revision 3.7 (5208e5c1)
    [    1.341534] optee: initialized driver
    [    1.351825] NET: Registered protocol family 17
    [    1.356614] 9pnet: Installing 9P2000 support
    [    1.361081] Key type dns_resolver registered
    [    1.366469] registered taskstats version 1
    [    1.370677] Loading compiled-in X.509 certificates
    [    1.395197] ti-sci interconnect@100000:interconnect@28380000:interconnect@42040000:dmsc: invalid resource
    [    1.405455] ti-sci interconnect@100000:interconnect@28380000:interconnect@42040000:dmsc: ABI: 2.7 (firmware rev 0x0013 '19.9.0-v2019.09 (Terrific Llama')
    [    1.445020] random: fast init done
    [    2.013531] omap_i2c 42120000.i2c: bus 0 rev0.12 at 400 kHz
    [    2.020146] omap_i2c 40b00000.i2c: bus 1 rev0.12 at 100 kHz
    [    2.026956] pca953x 2-0041: 2-0041 supply vcc not found, using dummy regulator
    [    2.034445] pca953x 2-0041: Linked as a consumer to regulator.0
    [    2.062995] pca953x 2-0021: 2-0021 supply vcc not found, using dummy regulator
    [    2.070494] pca953x 2-0021: Linked as a consumer to regulator.0
    [    2.077377] omap_i2c 2000000.i2c: bus 2 rev0.12 at 400 kHz
    [    2.083873] omap_i2c 2010000.i2c: bus 3 rev0.12 at 400 kHz
    [    2.090430] omap_i2c 2020000.i2c: bus 4 rev0.12 at 400 kHz
    [    2.096848] omap_i2c 2030000.i2c: bus 5 rev0.12 at 100 kHz
    [    2.108833] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,160] sci-dev-id:195
    [    2.118807] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: enabled
    [    2.125507] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66344100, num_proxies:64
    [    2.133513] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:818, gp-rings[304,464] sci-dev-id:187
    [    2.143583] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: enabled
    [    2.150260] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66344100, num_proxies:64
    [    2.158157] omap8250 40a00000.serial: PM domain pd:149 will not be powered off
    [    2.166067] 40a00000.serial: ttyS1 at MMIO 0x40a00000 (irq = 8, base_baud = 6000000) is a 8250
    [    2.176096] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 22, base_baud = 3000000) is a 8250
    [    2.184858] console [ttyS2] enabled
    [    2.191930] bootconsole [ns16550a0] disabled
    [    2.201596] 2810000.serial: ttyS3 at MMIO 0x2810000 (irq = 23, base_baud = 3000000) is a 8250
    [    2.211098] 2820000.serial: ttyS4 at MMIO 0x2820000 (irq = 24, base_baud = 3000000) is a 8250
    [    2.223596] cadence-qspi 47040000.spi: mt35xu512aba (65536 Kbytes)
    [    2.229791] 7 cmdlinepart partitions found on MTD device 47040000.spi.0
    [    2.236395] Creating 7 MTD partitions on "47040000.spi.0":
    [    2.241877] 0x000000000000-0x000000080000 : "ospi.tiboot3"
    [    2.248606] 0x000000080000-0x000000280000 : "ospi.tispl"
    [    2.255023] 0x000000280000-0x000000680000 : "ospi.u-boot"
    [    2.261454] 0x000000680000-0x0000006a0000 : "ospi.env"
    [    2.267659] 0x0000006a0000-0x0000006c0000 : "ospi.env.backup"
    [    2.274520] 0x0000006c0000-0x0000007c0000 : "ospi.sysfw"
    [    2.280885] 0x000000800000-0x000004000000 : "ospi.rootfs"
    [    2.498457] cadence-qspi 47040000.spi: Cadence QSPI NOR probe failed -517
    [    2.516585] am65-cpsw-nuss 46000000.ethernet: rx-flow-id-base is not set -22
    [    2.523681] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA07100, cpsw version 0x6BA80100 Ports: 2
    [    2.535362] UDMA has not been proped
    [    2.538939] am65-cpsw-nuss 46000000.ethernet: Failed to request tx dma channel -517
    [    2.549367] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a2109, freq:200000000, add_val:4 pps:0
    [    2.558214] thermal thermal_zone1: failed to read out thermal zone (-22)
    [    2.564928] thermal thermal_zone2: failed to read out thermal zone (-22)
    [    2.572697] keystone-wdt 40610000.rti: heartbeat 60 sec
    [    2.579305] mmc0: Unknown controller version (4). You may experience problems.
    [    2.618080] mmc0: SDHCI controller on 4f80000.sdhci [4f80000.sdhci] using ADMA 64-bit
    [    2.627024] mmc1: Unknown controller version (4). You may experience problems.
    [    2.663170] mmc1: SDHCI controller on 4fa0000.sdhci [4fa0000.sdhci] using ADMA 64-bit
    [    2.673090] mmc0: new HS200 MMC card at address 0001
    [    2.679387] mmcblk0: mmc0:0001 S0J56X 14.8 GiB
    [    2.684828] mmcblk0boot0: mmc0:0001 S0J56X partition 1 31.5 MiB
    [    2.694843] mmcblk0boot1: mmc0:0001 S0J56X partition 2 31.5 MiB
    [    2.705193] mmcblk0rpmb: mmc0:0001 S0J56X partition 3 4.00 MiB, chardev (243:0)
    [    2.717475] pca953x 0-0039: 0-0039 supply vcc not found, using dummy regulator
    [    2.724790] pca953x 0-0039: Linked as a consumer to regulator.0
    [    2.732547]  mmcblk0: p1 p2
    [    2.755976] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fc5900
    [    2.763067] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fc5900
    [    2.770863] ti-udma 285c0000.udmap: Channels: 96 (tchan: 48, echan: 0, rchan: 48, rflow: 96)
    [    2.788806] ti-udma 31150000.udmap: Channels: 267 (tchan: 120, echan: 32, rchan: 150, rflow: 300)
    [    2.823137] cadence-qspi 47040000.spi: mt35xu512aba (65536 Kbytes)
    [    2.829329] 7 cmdlinepart partitions found on MTD device 47040000.spi.0
    [    2.835932] Creating 7 MTD partitions on "47040000.spi.0":
    [    2.841414] 0x000000000000-0x000000080000 : "ospi.tiboot3"
    [    2.848167] 0x000000080000-0x000000280000 : "ospi.tispl"
    [    2.854590] 0x000000280000-0x000000680000 : "ospi.u-boot"
    [    2.861020] 0x000000680000-0x0000006a0000 : "ospi.env"
    [    2.867192] 0x0000006a0000-0x0000006c0000 : "ospi.env.backup"
    [    2.874002] 0x0000006c0000-0x0000007c0000 : "ospi.sysfw"
    [    2.880455] 0x000000800000-0x000004000000 : "ospi.rootfs"
    [    2.896158] m25p80 spi7.0: n25q128a13 (16384 Kbytes)
    [    2.903201] am65-cpsw-nuss 46000000.ethernet: rx-flow-id-base is not set -22
    [    2.910296] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA07100, cpsw version 0x6BA80100 Ports: 2
    [    2.934247] am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48
    [    2.949103] pps pps0: new PPS source ptp1
    [    2.953317] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a2109, freq:200000000, add_val:4 pps:1
    [    2.962268] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 0.4
    [    2.969480] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
    [    3.014067] am65-cpsw-nuss 46000000.ethernet: davinci mdio revision 9.7, bus freq 1000000
    [    3.022233] libphy: 46000000.ethernet: probed
    [    3.031803] input: gpio-keys as /devices/platform/gpio-keys/input/input0
    [    3.038831] hctosys: unable to open rtc device (rtc0)
    [    3.161379] ALSA device list:
    [    3.164352]   No soundcards found.
    [    3.168716] Waiting for root device PARTUUID=000b6d4a-02...
    [    3.870375] mmc1: new high speed SDHC card at address aaaa
    [    3.877290] mmcblk1: mmc1:aaaa SB16G 14.8 GiB
    [    3.886558]  mmcblk1: p1 p2
    [    4.418880] EXT4-fs (mmcblk1p2): recovery complete
    [    4.433458] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Opts: (null)
    [    4.441606] VFS: Mounted root (ext4 filesystem) on device 179:98.
    [    4.458649] devtmpfs: mounted
    [    4.462367] Freeing unused kernel memory: 576K
    [    4.466950] Run /sbin/init as init process
    [    4.823108] systemd[1]: System time before build time, advancing clock.
    [    4.955254] NET: Registered protocol family 10
    [    4.961036] Segment Routing with IPv6
    [    4.981790] systemd[1]: systemd 239 running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR +SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN2 -IDN -PCRE2 default-hierarchy=hybrid)
    [    5.003576] systemd[1]: Detected architecture arm64.
    [    5.033118] systemd[1]: Set hostname to <am65xx-evm>.
    [    5.250227] systemd[1]: File /lib/systemd/system/systemd-journald.service:36 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
    [    5.267260] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
    [    5.539262] random: systemd: uninitialized urandom read (16 bytes read)
    [    5.546555] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
    [    5.566223] random: systemd: uninitialized urandom read (16 bytes read)
    [    5.577361] systemd[1]: Created slice system-serial\x2dgetty.slice.
    [    5.594299] random: systemd: uninitialized urandom read (16 bytes read)
    [    5.601372] systemd[1]: Listening on udev Kernel Socket.
    [    5.619050] systemd[1]: Listening on Journal Socket.
    [    5.639339] systemd[1]: Mounting POSIX Message Queue File System...
    [    5.738943] EXT4-fs (mmcblk1p2): re-mounted. Opts: (null)
    [  OK  ] Started Dispatch Password Requests to Console[    5.763853] cryptodev: loading out-of-tree module taints kernel.
     Directory Watch.
    [    5.776115] cryptodev: driver 1.9 loaded.
    [    6.588646] systemd-journald[182]: Received request to flush runtime journal from PID 1
    [    7.484980] input: gpio-decoder as /devices/platform/gpio-decoder/input/input1
    [    8.023768] [drm] Initialized pvr 1.17.4948957 20110701 for 7000000.gpu on minor 0
    [    8.101700] dwc3 4030000.usb: Failed to get clk 'ref': -2
    [    8.109145] OF: graph: no port node found in /interconnect@100000/phy@4110000
    [    8.214721] CAN device driver interface
    [    8.376418] m_can 40528000.mcan: m_can device registered (irq=17, version=32)
    [    8.497808] m_can 40568000.mcan: m_can device registered (irq=19, version=32)
    [    8.807828] TI DP83867 k3-cpsw-mdio:00: attached PHY driver [TI DP83867] (mii_bus:phy_addr=k3-cpsw-mdio:00, irq=POLL)
    [    8.822450] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
    [    8.987745] omap_rng 4e10000.trng: Random Number Generator ver. 230b34c
    [    8.988419] random: crng init done
    [    8.988428] random: 7 urandom warning(s) missed due to ratelimiting
    [    9.022478] k3_r5_rproc interconnect@100000:interconnect@28380000:r5fss@41000000: creating child devices for R5F cores
    [  OK  ] Reached target System Initialization.[    9.037466] platform 41000000.r5f: configured R5F for remoteproc mode
    [    9.046551] platform 41000000.r5f: assigned reserved memory node r5f-dma-memory@a0000000
    [    9.055169] remoteproc remoteproc0: 41000000.r5f is available
    [    9.256892] remoteproc remoteproc0: powering up 41000000.r5f
    [    9.264652] remoteproc remoteproc0: Booting fw image am65x-mcu-r5f0_0-fw, size 4142860
    [    9.282331] platform 41000000.r5f: booting R5F core using boot addr = 0x0
    [  OK  ] Listening on Avahi mDNS/DNS-SD Stack Activati[    9.313978] virtio_rpmsg_bus virtio0: rpmsg host is online
    [    9.314943] virtio_rpmsg_bus virtio0: creating channel rpmsg-proto addr 0x3d
    on Socket.
    [    9.326912] remoteproc remoteproc0: registered virtio0 (type 7)
    [    9.333804] remoteproc remoteproc0: remote processor 41000000.r5f is now up
    [    9.851497] am65-cpsw-nuss 46000000.ethernet eth0: Link is Down
    [    9.862376] davinci_mdio b032400.mdio: davinci mdio revision 1.7, bus freq 1000000
    [    9.870000] libphy: b032400.mdio: probed
    [    9.920617] davinci_mdio b032400.mdio: phy[0]: device b032400.mdio:00, driver TI DP83867
    [    9.929437] davinci_mdio b032400.mdio: phy[3]: device b032400.mdio:03, driver TI DP83867
             Starting Lightning Fast Webserver With Light System Requirements...
    [   10.110214] davinci_mdio b132400.mdio: davinci mdio revision 1.7, bus freq 1000000
    [   10.118284] libphy: b132400.mdio: probed
    [   10.164208] davinci_mdio b132400.mdio: phy[0]: device b132400.mdio:00, driver TI DP83867
    [   10.172459] davinci_mdio b132400.mdio: phy[3]: device b132400.mdio:03, driver TI DP83867
    [   10.354155] davinci_mdio b232400.mdio: davinci mdio revision 1.7, bus freq 1000000
    [   10.361735] libphy: b232400.mdio: probed
    [   10.412995] davinci_mdio b232400.mdio: phy[0]: device b232400.mdio:00, driver TI DP83867
    [   10.423189] davinci_mdio b232400.mdio: phy[3]: device b232400.mdio:03, driver TI DP83867
    [   11.172507] remoteproc remoteproc1: b034000.pru is available
    [   11.178499] pru-rproc b034000.pru: PRU rproc node pru@b034000 probed successfully
    [   11.208271] remoteproc remoteproc2: b004000.rtu is available
    [   11.227085] pru-rproc b004000.rtu: PRU rproc node rtu@b004000 probed successfully
    [   11.259203] remoteproc remoteproc3: b038000.pru is available
    [   11.266413] pru-rproc b038000.pru: PRU rproc node pru@b038000 probed successfully
    [   11.316620] remoteproc remoteproc4: b006000.rtu is available
    [   11.325965] pru-rproc b006000.rtu: PRU rproc node rtu@b006000 probed successfully
    [   11.366995] remoteproc remoteproc5: b134000.pru is available
    [   11.381583] pru-rproc b134000.pru: PRU rproc node pru@b134000 probed successfully
    [   11.398406] remoteproc remoteproc6: b104000.rtu is available
    [   11.471351] pru-rproc b104000.rtu: PRU rproc node rtu@b104000 probed successfully
    [   11.497120] PVR_K: UM DDK-(4948957) and KM DDK-(4948957) match. [ OK ]
    [   11.509224] remoteproc remoteproc7: b138000.pru is available
    [   11.594397] pru-rproc b138000.pru: PRU rproc node pru@b138000 probed successfully
    [  OK  ] [   11.615936] remoteproc remoteproc8: b106000.rtu is available
    [   11.622905] pru-rproc b106000.rtu: PRU rproc node rtu@b106000 probed successfully
    [   11.645455] remoteproc remoteproc9: b234000.pru is available
    [   11.664658] pru-rproc b234000.pru: PRU rproc node pru@b234000 probed successfully
    [   11.699115] remoteproc remoteproc10: b204000.rtu is available
    [   11.712902] pru-rproc b204000.rtu: PRU rproc node rtu@b204000 probed successfully
    [   11.747243] remoteproc remoteproc11: b238000.pru is available
    [   11.768386] pru-rproc b238000.pru: PRU rproc node pru@b238000 probed successfully
    [   11.779036] remoteproc remoteproc12: b206000.rtu is available
    [   11.786306] pru-rproc b206000.rtu: PRU rproc node rtu@b206000 probed successfully
    [   11.887202] icssg-prueth pruss1_eth: TI PRU ethernet driver initialized: dual EMAC mode
    [   11.947746] icssg-prueth pruss0_eth: TI PRU ethernet driver initialized: dual EMAC mode
    [   11.997949] icssg-prueth pruss2_eth: TI PRU ethernet driver initialized: dual EMAC mode
    [   13.774615] NET: Registered protocol family 45
    [   13.860960] remoteproc remoteproc3: powering up b038000.pru
    [   13.873378] remoteproc remoteproc3: Booting fw image ti-pruss/am65x-pru1-prueth-fw.elf, size 16460
    [   13.882499] remoteproc remoteproc3: remote processor b038000.pru is now up
    [   13.889420] remoteproc remoteproc4: powering up b006000.rtu
    [   13.915480] remoteproc remoteproc4: Booting fw image ti-pruss/am65x-rtu1-prueth-fw.elf, size 15540
    [   13.928517] remoteproc remoteproc4: remote processor b006000.rtu is now up
    [   13.945724] net eth4: started
    [   13.951611] am65-cpsw-nuss 46000000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
    [   13.969088] IPv6: ADDRCONF(NETDEV_UP): eth4: link is not ready
    [   13.975404] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
    [   14.080583] remoteproc remoteproc7: powering up b138000.pru
    [   14.086759] remoteproc remoteproc7: Booting fw image ti-pruss/am65x-pru1-prueth-fw.elf, size 16460
    [   14.097537] remoteproc remoteproc7: remote processor b138000.pru is now up
    [   14.104458] remoteproc remoteproc8: powering up b106000.rtu
    [   14.111878] remoteproc remoteproc8: Booting fw image ti-pruss/am65x-rtu1-prueth-fw.elf, size 15540
    [   14.120885] remoteproc remoteproc8: remote processor b106000.rtu is now up
    [   14.131707] net eth2: started
    [   14.137431] IPv6: ADDRCONF(NETDEV_UP): eth2: link is not ready
    [   14.261256] remoteproc remoteproc11: powering up b238000.pru
    [   14.267485] remoteproc remoteproc11: Booting fw image ti-pruss/am65x-pru1-prueth-fw.elf, size 16460
    [   14.276858] remoteproc remoteproc11: remote processor b238000.pru is now up
    [   14.283856] remoteproc remoteproc12: powering up b206000.rtu
    [   14.289637] remoteproc remoteproc12: Booting fw image ti-pruss/am65x-rtu1-prueth-fw.elf, size 15540
    [   14.298737] remoteproc remoteproc12: remote processor b206000.rtu is now up
    [   14.307594] net eth6: started
    [   14.311173] IPv6: ADDRCONF(NETDEV_UP): eth6: link is not ready
    [   14.345778] remoteproc remoteproc1: powering up b034000.pru
    [   14.358937] remoteproc remoteproc1: Booting fw image ti-pruss/am65x-pru0-prueth-fw.elf, size 16460
    [   14.367939] remoteproc remoteproc1: remote processor b034000.pru is now up
    [   14.374853] remoteproc remoteproc2: powering up b004000.rtu
    [   14.383076] remoteproc remoteproc2: Booting fw image ti-pruss/am65x-rtu0-prueth-fw.elf, size 15540
    [   14.392095] remoteproc remoteproc2: remote processor b004000.rtu is now up
    [   14.401322] net eth3: started
    [  OK  [   14.407350] IPv6: ADDRCONF(NETDEV_UP): eth3: link is not ready
    [   14.440175] remoteproc remoteproc9: powering up b234000.pru
    [   14.446499] remoteproc remoteproc9: Booting fw image ti-pruss/am65x-pru0-prueth-fw.elf, size 16460
    [   14.455514] remoteproc remoteproc9: remote processor b234000.pru is now up
    [   14.462495] remoteproc remoteproc10: powering up b204000.rtu
    [   14.477799] remoteproc remoteproc10: Booting fw image ti-pruss/am65x-rtu0-prueth-fw.elf, size 15540
    [   14.487178] remoteproc remoteproc10: remote processor b204000.rtu is now up
    [   14.501289] net eth5: started
    [   14.505582] IPv6: ADDRCONF(NETDEV_UP): eth5: link is not ready
    [   14.529760] remoteproc remoteproc5: powering up b134000.pru
    [   14.535739] remoteproc remoteproc5: Booting fw image ti-pruss/am65x-pru0-prueth-fw.elf, size 16460
    [   14.544925] remoteproc remoteproc5: remote processor b134000.pru is now up
    [   14.551832] remoteproc remoteproc6: powering up b104000.rtu
    [   14.557552] remoteproc remoteproc6: Booting fw image ti-pruss/am65x-rtu0-prueth-fw.elf, size 15540
    [   14.566636] remoteproc remoteproc6: remote processor b104000.rtu is now up
    [  OK  ] [   14.575734] net eth1: started
    [   14.580434] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
    [   14.822469] EXT4-fs (mmcblk0p2): mounting ext3 file system using the ext4 subsystem
    [   14.842241] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
    	autoconf
    	bash-dev
    	bash
    	bc
    	binutils
    	cifs-utils
    	cpio
    	cpp-symlinks
    	cpp
    	dosfstools
    	elfutils
    	g++-symlinks
    	g++
    	gawk
    	gcc-symlinks
    	gcc
    	gdb
    	gdbserver
    	gettext
    	glmark2
    	gstreamer1.0-libav
    	gzip
    	hidapi
    	libbfd
    	libcairo-perf-utils
    	libdw1
    	libelf1
    	libgdbm-compat4
    	libgdbm-dev
    	libgdbm6
    	libgettextlib
    	libgettextsrc
    	libgmp10
    	libidn2-0
    	libmpc3
    	libmpfr6
    	libreadline-dev
    	libreadline7
    	libunistring2
    	m4-dev
    	m4
    	make
    	nettle
    	parted
    	swig-dev
    	swig
    	which
    [  OK  ] Started Process Core Dump (PID 1261/UID 0).
     _____                    _____           _         _
                  |___|                    |___|
    root@am65xx-evm:~# ua name -a
    root@am65xx-evm:~# lsusb
    unable to initialize libusb: -99
    root@am65xx-evm:~#
    I now have exact rt release as used by you. I am not seeing the issue you are seeing.
    Attaching the log for your reference. can you share a picture of the your board with the card removed
    So that i know which exact card you removed. I have a Rev 1.0 EVM.
    Keerthy
    rt-am6-log-without-card.zip
  • Hi Keerthy,
    Picture as below.
    The board I remove marked with a red color box.
    I am not sure the board's version I use.
    Could you tell me how to check?
    Thanks! I consulted the USB expert and it seems what you are seeing is indeed fine on IDK.
    Also the difference in behavior is different EVM that i was having.
    USB0 and USB1 are independent of each other as you rightly observed.
    On base board
    &usb1 {
            pinctrl-names = "default";
            pinctrl-0 = <&usb1_pins_default>;
            dr_mode = "otg";
    So USB on base board will default to device mode and will not show up in lsusb.
    To test device mode load any gadget driver an connect to PC host.
    e.g.
    modprobe g_mass_storage removable=1
    To put USB1 in host mode, you need to connect a otg to host adapter to it
    which will pull ID pin low. That is when it will show up in lsusb.
    Hope that clarifies your question.
    If yes please resolve the issue.
    Keerthy
