CPU Stall due to memory access failure when closing UART port. Linux Kernel 4.4.57. The following is the kernel backtrace.
INFO: rcu_preempt self-detected stall on CPU
[16696455.621185] 0-...: (1654942656 ticks this GP) idle=9d3/140000000000002/0 softirq=4514/4514 fqs=0
[16696455.630380] (t=1669616376 jiffies g=790 c=789 q=213)
[16696455.635774] rcu_preempt kthread starved for 1669616376 jiffies! g790 c789 f0x0 s3 ->state=0x1
[16696455.644537] Task dump for CPU 0:
[16696455.648012] launchupgrade.s R running 0 425 1 0x00000007
[16696455.654619] Backtrace:
[16696455.657330] [<c0013470>] (dump_backtrace) from [<c001366c>] (show_stack+0x18/0x1c)
[16696455.665141] r7:00000098 r6:c0872154 r5:00000001 r4:cf438000
[16696455.671074] [<c0013654>] (show_stack) from [<c005a964>] (sched_show_task+0xbc/0x110)
[16696455.679064] [<c005a8a8>] (sched_show_task) from [<c005b954>] (dump_cpu_task+0x2c/0x30)
[16696455.687220] r5:80070193 r4:00000001
[16696455.691060] [<c005b928>] (dump_cpu_task) from [<c007908c>] (rcu_dump_cpu_stacks+0xa8/0xfc)
[16696455.699570] [<c0078fe4>] (rcu_dump_cpu_stacks) from [<c007ca84>] (rcu_check_callbacks+0x488/0x8c0)
[16696455.708765] r10:00000000 r9:c0872154 r8:c087214c r7:c08806ec r6:c08802c0 r5:c08802c0
[16696455.716864] r4:c0880744 r3:cf906000
[16696455.720705] [<c007c5fc>] (rcu_check_callbacks) from [<c00801ec>] (update_process_times+0x40/0x6c)
[16696455.729815] r10:c08812cc r9:cf906000 r8:c0090a34 r7:003b5156 r6:85d08b0d r5:00000000
[16696455.737914] r4:cf438000
[16696455.740710] [<c00801ac>] (update_process_times) from [<c0090a30>] (tick_sched_handle+0x50/0x54)
[16696455.749646] r5:cf907be8 r4:c0881bc0
[16696455.753488] [<c00909e0>] (tick_sched_handle) from [<c0090a98>] (tick_sched_timer+0x64/0xb8)
[16696455.762086] [<c0090a34>] (tick_sched_timer) from [<c0080f24>] (__hrtimer_run_queues.constprop.6+0x138/0x1d0)
[16696455.772148] r7:00000000 r6:c08812c0 r5:c0881bc0 r4:c0881280
[16696455.778081] [<c0080dec>] (__hrtimer_run_queues.constprop.6) from [<c00811ec>] (hrtimer_interrupt+0xb4/0x260)
[16696455.788144] r10:c0881338 r9:cf907af0 r8:ffffffff r7:00000003 r6:cf906000 r5:7fffffff
[16696455.796243] r4:c0881280
[16696455.799037] [<c0081138>] (hrtimer_interrupt) from [<c0015f70>] (twd_handler+0x38/0x48)
[16696455.807193] r10:00000000 r9:cf9520c0 r8:ef6c9140 r7:00000012 r6:ef01bbc0 r5:c089aac8
[16696455.815292] r4:00000001
[16696455.818085] [<c0015f38>] (twd_handler) from [<c0073814>] (handle_percpu_devid_irq+0x68/0x80)
[16696455.826761] r5:c089aac8 r4:ef004d80
[16696455.830600] [<c00737ac>] (handle_percpu_devid_irq) from [<c006f6dc>] (generic_handle_irq+0x2c/0x3c)
[16696455.839883] r9:cf9520c0 r8:ef008000 r7:00000001 r6:cf907d00 r5:00000000 r4:c089a984
[16696455.847901] [<c006f6b0>] (generic_handle_irq) from [<c006f948>] (__handle_domain_irq+0x5c/0xb0)
[16696455.856842] [<c006f8ec>] (__handle_domain_irq) from [<c00094d8>] (gic_handle_irq+0x40/0x6c)
[16696455.865431] r9:cf9520c0 r8:fa241100 r7:fa240100 r6:cf907be8 r5:fa24010c r4:c08724a8
[16696455.873448] [<c0009498>] (gic_handle_irq) from [<c0014114>] (__irq_svc+0x54/0x90)
[16696455.881173] Exception stack(0xcf907be8 to 0xcf907c30)
[16696455.886474] 7be0: c08c2b40 00404404 c08c2b00 00000000 00000202 00000000
[16696455.894896] 7c00: 00000000 00000001 ef008000 cf9520c0 00000000 cf907c94 cf907c98 cf907c38
[16696455.903316] 7c20: c003a108 c0039c54 60070113 ffffffff
[16696455.908612] r9:cf9520c0 r8:ef008000 r7:cf907c1c r6:ffffffff r5:60070113 r4:c0039c54
[16696455.916631] [<c0039bb4>] (__do_softirq) from [<c003a108>] (irq_exit+0xec/0x120)
[16696455.924181] r10:00000000 r9:cf9520c0 r8:ef008000 r7:00000001 r6:00000000 r5:00000000
[16696455.932280] r4:c089a984
[16696455.935072] [<c003a01c>] (irq_exit) from [<c006f94c>] (__handle_domain_irq+0x60/0xb0)
[16696455.943142] r5:00000000 r4:c089a984
[16696455.946980] [<c006f8ec>] (__handle_domain_irq) from [<c00094d8>] (gic_handle_irq+0x40/0x6c)
[16696455.955569] r9:cf9520c0 r8:fa241100 r7:fa240100 r6:cf907d00 r5:fa24010c r4:c08724a8
[16696455.963586] [<c0009498>] (gic_handle_irq) from [<c0014114>] (__irq_svc+0x54/0x90)
[16696455.971310] Exception stack(0xcf907d00 to 0xcf907d48)
[16696455.976613] 7d00: c08f69bc 00000000 00000730 00000000 00000004 00000000 c08f69bc 00000001
[16696455.985035] 7d20: 00000004 cf9520c0 00000000 cf907d5c cf907d50 cf907d50 c001b77c c001b788
[16696455.993453] 7d40: a0070013 ffffffff
[16696455.997188] r9:cf9520c0 r8:00000004 r7:cf907d34 r6:ffffffff r5:a0070013 r4:c001b788
[16696456.005209] [<c001b758>] (arm_heavy_mb) from [<c03a8e48>] (mem_serial_out+0x24/0x34)
[16696456.013199] [<c03a8e24>] (mem_serial_out) from [<c03b00bc>] (omap_8250_shutdown+0x74/0xf4)
[16696456.021702] r7:00000001 r6:cf8b0200 r5:c08f69bc r4:c08f69bc
[16696456.027634] [<c03b0048>] (omap_8250_shutdown) from [<c03a9c74>] (serial8250_shutdown+0x1c/0x28)
[16696456.036570] r5:c08f69bc r4:ef2090b8
[16696456.040411] [<c03a9c58>] (serial8250_shutdown) from [<c03a4274>] (uart_shutdown+0x120/0x174)
[16696456.049095] [<c03a4154>] (uart_shutdown) from [<c03a4e80>] (uart_hangup+0x4c/0x13c)
[16696456.056992] r5:ef209130 r4:ef2090b8
[16696456.060834] [<c03a4e34>] (uart_hangup) from [<c0386c38>] (__tty_hangup+0x2e8/0x508)
[16696456.068730] r7:00000001 r6:cf906000 r5:cf8b0200 r4:ffffffff
[16696456.074664] [<c0386950>] (__tty_hangup) from [<c03874d4>] (disassociate_ctty.part.8+0x3c/0x2f4)
[16696456.083600] r10:cf907ec8 r9:cf89cfc0 r8:cf4daa00 r7:cf8ee000 r6:cf8ee034 r5:cf8b0200
[16696456.091699] r4:00000001
[16696456.094493] [<c0387498>] (disassociate_ctty.part.8) from [<c03877e8>] (disassociate_ctty+0x30/0x34)
[16696456.103776] r7:cf8ee000 r6:cf8ee034 r5:cf8ee000 r4:cf438000
[16696456.109708] [<c03877b8>] (disassociate_ctty) from [<c0038fe8>] (do_exit+0x6dc/0x9e8)
[16696456.117697] [<c003890c>] (do_exit) from [<c0039374>] (do_group_exit+0x44/0xf8)
[16696456.125160] r7:cf907edc
[16696456.127952] [<c0039330>] (do_group_exit) from [<c00437f8>] (get_signal+0x208/0x5fc)
[16696456.135848] r5:00000009 r4:cf906000
[16696456.139690] [<c00435f0>] (get_signal) from [<c0012b9c>] (do_signal+0xd0/0x42c)
[16696456.147153] r10:00000000 r9:cf906000 r8:b6dadabc r7:cf907ec8 r6:00000000 r5:b6dadab8
[16696456.155252] r4:cf907fb0
[16696456.158047] [<c0012acc>] (do_signal) from [<c00130c0>] (do_work_pending+0xa8/0xc0)
[16696456.165857] r10:00000000 r9:cf906000 r8:c000fb44 r7:00000025 r6:cf907fb0 r5:c000fb44
[16696456.173956] r4:cf906010
[16696456.176750] [<c0013018>] (do_work_pending) from [<c000f9d4>] (slow_work_pending+0xc/0x20)
[16696456.185166] r7:00000025 r6:000ed290 r5:000001d7 r4:00000000
