AM5729: Unable to import YOLO models
Part Number: AM5729
I am trying to import YOLO v2, v2-tiny, v3, v3-tiny (Darknet) models, but even after converting them to TensorFlow , TFLite and ONNX, importing them using the import tool gives me some form of error. Part of the log is added below. I have tried all 4 frameworks but failed. Is there an alternative ?
[linux-devkit]:~/ti-processor-sdk-linux-am57xx-evm-06.02.00.81> ./linux-devkit/sysroots/x86_64-arago-linux/usr/bin/tidl_model_import.out ./linux-devkit/sysroots/x86_64-arago-linux/usr/share/ti/tidl/utils/test/testvecs/config/import/tflite/popo_tidl_import_yolo_v2_tiny_coco.txt
=============================== TIDL import - parsing ===============================
TFLite Model (Flatbuf) File  : linux-devkit/sysroots/armv7at2hf-neon-linux-gnueabi/usr/share/arm/armnn/models/yolo-v2-tiny-coco.tflite
TIDL Network File      : linux-devkit/sysroots/armv7at2hf-neon-linux-gnueabi/usr/share/arm/armnn/models/tidl_bin_yolo-v2-tiny-coco-tflite.bin
TIDL IO Info File      : linux-devkit/sysroots/armv7at2hf-neon-linux-gnueabi/usr/share/arm/armnn/models/tidl_param_yolo-v2-tiny-coco-tflite.bin
TFLite node size: 39
 TFlite operator MAXIMUM is not suported now..  By passing
Segmentation fault (core dumped)
TFLite Model (Flatbuf) File  : linux-devkit/sysroots/armv7at2hf-neon-linux-gnueabi/usr/share/arm/armnn/models/quantized-yolo-v2-tiny-coco.tflite
Only float and DT_INT32 tensor is suported
TIDL limitation: TFLite operator CONV_2D cannot be mapped to a TIDL layer.
[linux-devkit]:~/ti-processor-sdk-linux-am57xx-evm-06.02.00.81> ./linux-devkit/sysroots/x86_64-arago-linux/usr/bin/tidl_model_import.out ./linux-devkit/sysroots/x86_64-arago-linux/usr/share/ti/tidl/utils/test/testvecs/config/import/tensorflow/popo_tidl_import_mobileNetv1.txt
TF Model (Proto) File  : linux-devkit/sysroots/armv7at2hf-neon-linux-gnueabi/usr/share/arm/armnn/models/DW2TF-yolo-v2-tiny-coco.pb
TIDL Network File      : linux-devkit/sysroots/armv7at2hf-neon-linux-gnueabi/usr/share/arm/armnn/models/DW2TF_tidl_bin_yolo-v2-tiny-coco.bin
TIDL Params File       : linux-devkit/sysroots/armv7at2hf-neon-linux-gnueabi/usr/share/arm/armnn/models/DW2TF_tidl_param_yolo-v2-tiny-coco.bin
TIDL limitation: TensorFlow operator RandomUniform is not suported.
TIDL limitation: TensorFlow operator Sub is not suported.
TIDL limitation: TensorFlow operator VariableV2 is not suported.
[libprotobuf FATAL /oe/bld/build-CORTEX_1/arago-tmp-external-arm-toolchain/work/x86_64-nativesdk-arago-linux/nativesdk-tidl-import/01.01.03.00-r0/recipe-sysroot-native/usr/include/google/protobuf/repeated_field.h:1506] CHECK failed: (index) < (current_size_):
terminate called after throwing an instance of 'google::protobuf::FatalException'
  what():  CHECK failed: (index) < (current_size_):
Aborted (core dumped)
[linux-devkit]:~/ti-processor-sdk-linux-am57xx-evm-06.02.00.81> ./linux-devkit/sysroots/x86_64-arago-linux/usr/bin/tidl_model_import.out ./linux-devkit/sysroots/x86_64-arago-linux/usr/share/ti/tidl/utils/test/testvecs/config/import/onnx/popo_tidl_import_yolov3tiny.txt
ONNX Model (Proto) File: linux-devkit/sysroots/x86_64-arago-linux/usr/share/ti/tidl/utils/test/testvecs/config/import/onnx/zldrobit_yolo_v3_tiny.onnx
TIDL Network File      : linux-devkit/sysroots/x86_64-arago-linux/usr/share/ti/tidl/utils/test/testvecs/config/import/onnx/tidl_net_zldrobit_yolo_v3_tiny
TIDL Params  File      : linux-devkit/sysroots/x86_64-arago-linux/usr/share/ti/tidl/utils/test/testvecs/config/import/onnx/tidl_param_zldrobit_yolo_v3_tiny
TIDL limitation: Padding only supported in H and W axis
TIDL limitation: ONNX operator LeakyRelu is not suported.
TIDL limitation: ONNX operator Pad is not suported.
TIDL limitation: Only float and INT64 tensor is suported.
TIDL limitation: ONNX operator Reshape cannot be mapped to a TIDL layer.
TIDL limitation: ONNX operator Slice is not suported.
TIDL limitation: ONNX operator Sigmoid is not suported.
TIDL limitation: ONNX operator Mul is not suported.
TIDL limitation: ONNX operator Exp is not suported.
TIDL limitation: Concat is only supported accross channels
TIDL limitation: ONNX operator Concat cannot be mapped to a TIDL layer.
TIDL limitation: ONNX operator Shape is not suported.
TIDL limitation: ONNX operator Gather is not suported.
TIDL limitation: ONNX operator Cast is not suported.
TIDL limitation: ONNX operator Floor is not suported.
TIDL limitation: ONNX operator Unsqueeze is not suported.
TIDL limitation: ONNX operator Div is not suported.
TIDL limitation: ONNX operator Upsample is not suported.
Import error: This ONNX model has unsupported operators. Please check TIDL User's Guide for supported operators.
Error in sorting layers: matching layer cannot be found!
Import error: This ONNX model's topology is not supported. Please check TIDL User's Guide for supported network topologies.
TIDL limitation: Reshape layer cannot be merged with layers other than InnerProduct or AveragePooling layer!
Import error: Reshape layer cannot be merged.
Num of Layer Detected :  84
  Num|TIDL Layer Name               |Out Data Name                                     |Group |#Ins  |#Outs |Inbuf Ids                       |Outbuf Id |In NCHW                             |Out NCHW                            |MACS       |
    0|TIDL_DataLayer                |input.1                                           |     0|    -1|     1|  x   x   x   x   x   x   x   x |  0       |       0        0        0        0 |       1        3      416      416 |         0 |
    1|TIDL_DataLayer                |154                                               |     0|    -1|     1|  x   x   x   x   x   x   x   x |  1       |       0        0        0        0 |       1        3      416      416 |         0 |
    2|TIDL_ConvolutionLayer         |72                                                |     1|     1|     1|  0   x   x   x   x   x   x   x |  2       |       1        3      416      416 |       1       16      416      416 |  77529088 |
    3|TIDL_PoolingLayer             |74                                                |     1|     1|     1|  3   x   x   x   x   x   x   x |  4       |       1       16      416      416 |       1       16      208      208 |   2768896 |
    4|TIDL_ConvolutionLayer         |76                                                |     1|     1|     1|  4   x   x   x   x   x   x   x |  5       |       1       16      208      208 |       1       32      208      208 | 200744960 |
    5|TIDL_PoolingLayer             |78                                                |     1|     1|     1|  6   x   x   x   x   x   x   x |  7       |       1       32      208      208 |       1       32      104      104 |   1384448 |
    6|TIDL_ConvolutionLayer         |80                                                |     1|     1|     1|  7   x   x   x   x   x   x   x |  8       |       1       32      104      104 |       1       64      104      104 | 200052736 |
    7|TIDL_PoolingLayer             |82                                                |     1|     1|     1|  9   x   x   x   x   x   x   x | 10       |       1       64      104      104 |       1       64       52       52 |    692224 |
    8|TIDL_ConvolutionLayer         |84                                                |     1|     1|     1| 10   x   x   x   x   x   x   x | 11       |       1       64       52       52 |       1      128       52       52 | 199706624 |
    9|TIDL_PoolingLayer             |86                                                |     1|     1|     1| 12   x   x   x   x   x   x   x | 13       |       1      128       52       52 |       1      128       26       26 |    346112 |
   10|TIDL_ConvolutionLayer         |88                                                |     1|     1|     1| 13   x   x   x   x   x   x   x | 14       |       1      128       26       26 |       1      256       26       26 | 199533568 |
   11|TIDL_PoolingLayer             |90                                                |     1|     1|     1| 15   x   x   x   x   x   x   x | 16       |       1      256       26       26 |       1      256       13       13 |    173056 |
   12|TIDL_ConvolutionLayer         |92                                                |     1|     1|     1| 16   x   x   x   x   x   x   x | 17       |       1      256       13       13 |       1      512       13       13 | 199447040 |
   13|TIDL_PoolingLayer             |95                                                |     1|     1|     1| 19   x   x   x   x   x   x   x | 20       |       1      512       13       13 |       1      512       12       12 |    294912 |
   14|TIDL_ConvolutionLayer         |97                                                |     1|     1|     1| 20   x   x   x   x   x   x   x | 21       |       1      512       12       12 |       1     1024       12       12 | 679624704 |
   15|TIDL_ConvolutionLayer         |100                                               |     1|     1|     1| 22   x   x   x   x   x   x   x | 23       |       1     1024       12       12 |       1      256       12       12 |  37785600 |
   16|TIDL_ConvolutionLayer         |103                                               |     1|     1|     1| 24   x   x   x   x   x   x   x | 25       |       1      256       12       12 |       1      512       12       12 | 169943040 |
   17|TIDL_ConvolutionLayer         |105                                               |     1|     1|     1| 26   x   x   x   x   x   x   x | 27       |       1      512       12       12 |       1      255       12       12 |  18800640 |
   18|TIDL_FlattenLayer             |107                                               |     1|     1|     1| 27   x   x   x   x   x   x   x | 28       |       1      255       12       12 |       1        1        1    36720 |     36720 |
   19|TIDL_TransposeLayer           |108                                               |     1|     1|     1| 28   x   x   x   x   x   x   x | 29       |       1        1        1    36720 |       1        1        1    36720 |     36720 |
   20|TIDL_ReshapeLayer             |110                                               |     1|     1|     1| 29   x   x   x   x   x   x   x | 30       |       1        1        1    36720 |       1        1        1    36720 |     36720 |
   21|TIDL_ReshapeLayer             |131                                               |     1|     1|     1| 30   x   x   x   x   x   x   x | 41       |       1        1        1    36720 |       1        1        1    36720 |     36720 |
   22|TIDL_ConvolutionLayer         |133                                               |     1|     1|     1| 24   x   x   x   x   x   x   x | 42       |       1      256       12       12 |       1      128       12       12 |   4737024 |
   23|TIDL_ConcatLayer              |153                                               |     1|     2|     1| 56  57   x   x   x   x   x   x | 58       |       1      128       12       12 |       1      256       12       12 |     36864 |
   24|TIDL_ConcatLayer              |160                                               |     1|     2|     1|  1  63   x   x   x   x   x   x | 64       |       1        3      416      416 |       1      259      416      416 |  44821504 |
   25|TIDL_ConcatLayer              |162                                               |     1|     2|     1| 65  15   x   x   x   x   x   x | 66       |       1      128       12       12 |       1      384       12       12 |     55296 |
   26|TIDL_ConvolutionLayer         |164                                               |     1|     1|     1| 66   x   x   x   x   x   x   x | 67       |       1      384       12       12 |       1      256       12       12 | 127438848 |
   27|TIDL_ConvolutionLayer         |166                                               |     1|     1|     1| 68   x   x   x   x   x   x   x | 69       |       1      256       12       12 |       1      255       12       12 |   9400320 |
   28|TIDL_FlattenLayer             |168                                               |     1|     1|     1| 69   x   x   x   x   x   x   x | 70       |       1      255       12       12 |       1        1        1    36720 |     36720 |
   29|TIDL_TransposeLayer           |169                                               |     1|     1|     1| 70   x   x   x   x   x   x   x | 71       |       1        1        1    36720 |       1        1        1    36720 |     36720 |
   30|TIDL_ReshapeLayer             |171                                               |     1|     1|     1| 71   x   x   x   x   x   x   x | 72       |       1        1        1    36720 |       1        1        1    36720 |     36720 |
   31|TIDL_ReshapeLayer             |192                                               |     1|     1|     1| 72   x   x   x   x   x   x   x | 83       |       1        1        1    36720 |       1        1        1    36720 |     36720 |
Total Giga Macs : 2.1756
Transpose Layer is not supported by TIDL and cannot be merged into any TIDL layer.
Reshape Layer is not supported by TIDL and cannot be merged into any TIDL layer.
Import error: This ONNX model has operators that are supported by TIDL only if they can be merged with TIDL layers. But these operators cannot be merged with any TIDL layer.
Please check TIDL User's Guide for supported ONNX operators.
TIDL import failed. Please check error messages.
[linux-devkit]:~/ti-processor-sdk-linux-am57xx-evm-06.02.00.81> ./linux-devkit/sysroots/x86_64-arago-linux/usr/bin/tidl_model_import.out ./linux-devkit/sysroots/x86_64-arago-linux/usr/share/ti/tidl/utils/test/testvecs/config/import/tflite/popo_tidl_import_yolo_v3_tiny_coco.txt
TFLite Model (Flatbuf) File  : linux-devkit/sysroots/armv7at2hf-neon-linux-gnueabi/usr/share/arm/armnn/models/zldrobit_yolo_v3_tiny_quant.tflite
TIDL Network File      : linux-devkit/sysroots/armv7at2hf-neon-linux-gnueabi/usr/share/arm/armnn/models/tidl_bin_zldrobit_yolo_v3_tiny_quant.bin
TIDL IO Info File      : linux-devkit/sysroots/armv7at2hf-neon-linux-gnueabi/usr/share/arm/armnn/models/tidl_param_zldrobit_yolo_v3_tiny_quant.bin
TFLite node size: 157
  • Hi Prashant, as the logs show there are some layers/nodes in YOLO which are not supported in TIDL. We are currently working on enabling heterogenous xNN compute. So, the nodes that cannot run on TIDL would run on ARM. In other words, it will be possible to create subgraphs that can run on TIDL accelerators and the rest on ARM. AM57x heterogenous support uses TVM (Relay-IR).
    Current PSDK6.2 has already the option to do full offload to ARM or TIDL by using DLR-TVM.. So, if a model is completely supported by TIDL it would run in TIDL. But, If there is any unsupported layer(s), then the model would be compiled for ARM only.
    DLR-AI-TVM:
    However, above steps require some setup effort and a board...
    Alternatively, If you are familiar with AWS, it is possible to create a compilation job in SageMaker to use AM57x as a target. In the case of YOLO, which has some unsupported layers, current AWS implementation compiles the whole model to ARM only (same as we are doing in PSDK6.2). In a near future (1 or 2 months) heterogenous (subgraphs support in ARM +TIDL) will be added in TI's Linux PSDK and in AWS SageMaker DLR-AI.
    thank you,
    Paula
  • Also, maybe easier, you can give a try to TensorFlow lite .. as I believe you also have YOLO for TFLite
    If you can run YOLO TFLite in you x86, then cross-compilation for ARM shouldn't be an issue. TFLite has some scripts to rebuild tflite lib for ARM already there.
    Just FYI, our PSDK6.2 OOB TFlite ARM only demos:
    http://software-dl.ti.com/processor-sdk-linux/esd/docs/latest/linux/Foundational_Components/Machine_Learning/tflite.html
    thank you,
    Paula
  • Hey , Thank you for the suggestions. I am trying to import using TFLite as well (just like you guessed). I can't understand why the segmentation fault occurs.
    Also, if I use only the ARM for inference, wouldn't it mean that the on-board EVEs + DSPs can't be leveraged ?
  • Hi Prashant, to your question: "if I use only the ARM for inference, wouldn't it mean that the on-board EVEs + DSPs can't be leveraged ?" yes, this is correct. Proposed is a temporary solution while heterogenous execution is release (ARM + EVE/DSP)
    thank you,
    Paula
