Part Number: AM5708
I am using am5708 and ti-processor-sdk-linux-am57xx-evm-04.03.00.05.
I want to use gstreamer to capture an OV5640 usb camera, which is support for mjpeg 1080P@15fps, 720P@30fps
Here is my command, use jpegdec and avdec_mjpeg, which is successfully, but cpu load is 93%
root# gst-launch-1.0 v4l2src device=/dev/video1 num-buffers=1000 ! 'image/jpeg,width=1280,height=720,framerate=30/1' ! jpegdec ! videoconvert ! kmssink sync=false scale=false
root# gst-launch-1.0 v4l2src device=/dev/video1 num-buffers=-1 io-mode=4 ! 'image/jpeg,width=1280,height=720,framerate=30/1' ! queue ! avdec_mjpeg ! videoconvert ! kmssink sync=false scale=false
Use dec hardware codec to reduce CPU load, ducatijpegdec:
root# gst-launch-1.0 --gst-debug=4 v4l2src device=/dev/video1 num-buffers=1000 ! 'image/jpeg,width=1280,height=720,framerate=30/1' ! queue ! ducatijpegdec ! videoconvert ! kmssink sync=false scale=false
The program works abnormally and gets stuck in a loop "ducati gstducatividdec.c:1309:gst_ducati_viddec_do_qos:<ducatijpegdec0> skipping until the next keyframe"
at gst-plugin-ducati/src/gstducatividdec.c, the "self->wait_keyframe" is always true, and cannot be modified by parameter passing
In order to confirm whether it is a key frame problem, I used an encode -> decode command, which is successfully.
root# gst-launch-1.0 v4l2src device=/dev/video1 num-buffers=-1 io-mode=4 ! 'image/jpeg,width=1280,height=720,framerate=30/1' ! queue ! avdec_mjpeg ! videoconvert ! "video/x-raw,width=1280,height=720,format=NV12" ! queue ! ducatijpegenc ! ducatijpegdec ! kmssink sync=false scale=false
Here is my questions:
1. why ducatijpegdec design to always wait for keyframe? which is useful for .mov files, but do not useful for v4l2src mjpeg video stream?
2. How to rebuild the gst-plugin-ducati?
If you have any idea, please let me know it.
Thanks.
