66AK2H14: Asynchronous external abort with kexec
Part Number: 66AK2H14
When starting kdump service, the following exeption occurs in Linux kernel.
Help on how to find root cause would be appreciated.
Thanks.
[   19.064011] Unhandled fault: asynchronous external abort (0x1211) at 0x00000000
[   19.071353] pgd = 4eb06506
[   19.074066] [00000000] *pgd=82cac4003, *pmd=00000000
[   19.079058] Internal error: : 1211 [#1] SMP ARM
[   19.083602] Modules linked in: fsp_reset(O)
[   19.087809] CPU: 3 PID: 2987 Comm: kexec Tainted: G           O      4.19.61-yocto-standard #1
[   19.096451] Hardware name: Keystone
[   19.099953] PC is at memcpy+0x44/0x330
[   19.103713] LR is at 0x59530a30
[   19.106863] pc : [<c0bda8e4>]    lr : [<59530a30>]    psr: 20080013
[   19.113150] sp : ec4bff24  ip : 38393030  fp : 00000030
[   19.118392] r10: c12f9028  r9 : 00000000  r8 : 3331633d
[   19.123634] r7 : 2970616d  r6 : 5f6d656d  r5 : 284c4f42  r4 : 4d59530a
[   19.130184] r3 : 38303535  r2 : 000004ca  r1 : eea340e0  r0 : f8de90e0
[   19.136735] Flags: nzCv  IRQs on  FIQs on  Mode SVC_32  ISA ARM  Segment user
[   19.143895] Control: 30c5387d  Table: 2d2f68c0  DAC: 55555555
[   19.149661] Process kexec (pid: 2987, stack limit = 0xbcb4a0ee)
[   19.155600] Stack: (0xec4bff24 to 0xec4c0000)
[   19.159972] ff20:          f8de9000 ec415420 00280001 00000000 f8de9000 c12f9018 c02a7be8
[   19.168181] ff40: c1206508 ec415400 ec415420 c02a8998 0000071f 00c00000 dd279024 77238681
[   19.176391] ff60: 00000000 ec415400 00000003 c02a9624 0000015b 00000001 a7ffffff 00000000
[   19.184599] ff80: 0000015b 00000000 bec479a0 b6e417e8 0000015b c0201204 ec4be000 0000015b
[   19.192807] ffa0: 0044c274 c02011c8 00000000 bec479a0 a0008000 00000003 01525ec0 00280001
[   19.201015] ffc0: 00000000 bec479a0 b6e417e8 0000015b 00000003 bec479a0 00000000 0044c274
[   19.209223] ffe0: bec47970 bec47960 0042aa77 b6eccca2 80080030 a0008000 00000000 00000000
[   19.217442] [<c0bda8e4>] (memcpy) from [<c02a7be8>] (crash_update_vmcoreinfo_safecopy+0x20/0x28)
[   19.226267] [<c02a7be8>] (crash_update_vmcoreinfo_safecopy) from [<c02a8998>] (kimage_crash_copy_vmcoreinfo+0x94/0xc8)
[   19.237008] [<c02a8998>] (kimage_crash_copy_vmcoreinfo) from [<c02a9624>] (sys_kexec_load+0x28c/0x414)
[   19.246353] [<c02a9624>] (sys_kexec_load) from [<c02011c8>] (__sys_trace_return+0x0/0x10)
[   19.254560] Exception stack(0xec4bffa8 to 0xec4bfff0)
[   19.259629] ffa0:                   00000000 bec479a0 a0008000 00000003 01525ec0 00280001
[   19.265551] keystone-netcp 2f00000.netcp: recover_lane_rx sig detcected
[   19.267836] ffc0: 00000000 bec479a0 b6e417e8 0000015b 00000003 bec479a0 00000000 0044c274
[   19.267840] ffe0: bec47970 bec47960 0042aa77 b6eccca2
[   19.267848] Code: f5d1f01c ba000002 f5d1f03c f5d1f05c (f5d1f07c)
[   19.274503] keystone-netcp 2f00000.netcp: recover_lane_rx rx valid
[   19.282682] ---[ end trace 72f5fa19d01e474e ]---
[   19.286267] Unhandled fault: asynchronous external abort (0x1211) at 0x00000000
[   19.312030] pgd = a95ecb6d
[   19.314743] [00000000] *pgd=82d376003, *pmd=00000000
[FAILED] Failed to start Reboot and dump vmcore via kexec.
See 'systemctl status kdump.service' for details.
root@board:~# systemctl status kdump.service
● kdump.service - Reboot and dump vmcore via kexec
   Loaded: loaded (/lib/systemd/system/kdump.service; enabled; vendor preset: enabled)
   Active: failed (Result: signal) since Fri 2020-04-03 09:46:10 UTC; 1h 16min ago
  Process: 2954 ExecStart=/usr/libexec/kdump-helper start (code=killed, signal=BUS)
 Main PID: 2954 (code=killed, signal=BUS)
Apr 03 09:46:09 board systemd[1]: Starting Reboot and dump vmcore via kexec...
Apr 03 09:46:09 board kdump-helper[2954]: syscall kexec_file_load not available.
Apr 03 09:46:10 board systemd[1]: kdump.service: Main process exited, code=killed, status=7/BUS
Apr 03 09:46:10 board systemd[1]: kdump.service: Failed with result 'signal'.
Apr 03 09:46:10 board systemd[1]: Failed to start Reboot and dump vmcore via kexec.
root@board:~# cat /proc/iomem
02004000-020040ff : 2004000.pktdma
02004400-0200451f : 2004000.pktdma
02004800-02004aff : 2004000.pktdma
02004c00-02004d1f : 2004000.pktdma
02005000-020053ff : 2004000.pktdma
02090300-020903ff : mdio@2090300
022f0080-022f00ff : wdt@22f0080
02530000-025303ff : i2c@2530000
02530400-025307ff : i2c@2530400
02530800-02530bff : i2c@2530800
02530c00-02530cff : serial
02531000-025310ff : serial
0260bf00-0260bf0f : 260bf00.gpio
0260bf10-0260bf37 : 260bf00.gpio
02901000-0290101f : 2901000.pktdma
02901400-029015ff : 2901000.pktdma
02901800-029019ff : 2901000.pktdma
02901c00-02901dff : 2901000.pktdma
02902000-0290227f : 2901000.pktdma
02a08000-02a080ff : 2a08000.pktdma
02a08400-02a087ff : 2a08000.pktdma
02a08800-02a08bff : 2a08000.pktdma
02a08c00-02a08c7f : 2a08000.pktdma
02a09000-02a093ff : 2a08000.pktdma
02fa1000-02fa10ff : 2fa1000.pktdma
02fa1400-02fa15ff : 2fa1000.pktdma
02fa1800-02fa19ff : 2fa1000.pktdma
02fa1c00-02fa1dff : 2fa1000.pktdma
02fa2000-02fa23ff : 2fa1000.pktdma
21000400-210005ff : spi@21000400
21000600-210007ff : spi@21000600
21000800-210009ff : spi@21000800
21000a00-21000aff : aemif@21000A00
21010000-210101ff : emif@21010000
30000000-33ffffff : nand@0,0
34000000-37ffffff : nand@1,1
80000000-ffffffff : System RAM (boot alias)
  a0000000-a7ffffff : Crash kernel (boot alias)
800000000-87fffffff : System RAM
  800008000-800ffffff : Kernel code
  801200000-80132279b : Kernel data
  820000000-827ffffff : Crash kernel
root@board:~# cat /proc/cmdline
console=ttyS0,115200n8 rootwait=1 mtdparts=spi0.0:1m(u-boot-spl)ro,-(misc) rootfstype=nfs root=/dev/nfs rw nfsroot=192.169.0.1:/opt/export/board,v3,tcp,rsize=4096,wsize=4096
ip=192.169.2.1:192.169.0.1::255.255.0.0:board:eth0:off crashkernel=128M
root@board:~#
    The obvious cause is "asynchronous external abort" and seems to happen when the following instruction is executed "PC is at memcpy+0x44/0x330". You can back trace the stack to find out where and which function is causing it.
    For more info on the abort, please refer to ARM  Cortex A15 r2p1 TRM,
    For more kernel dump and analyzing the crash dump  please check the folowing pages which provide useful info:
    https://www.thegeekstuff.com/2014/05/kdump/
    https://www.dedoimedo.com/computers/kdump.html
    https://opensource.com/article/17/6/kdump-usage-and-internals
    https://www.dedoimedo.com/computers/crash-analyze.html
    https://www.linuxjournal.com/content/oops-debugging-kernel-panics-0
    Rex
    So it seems that the exception is slave error, unaligned read.
    I dump the memcpy adresses and I don't see unaligned adresses.
    [   22.905900] !!!!! kimage_crash_copy_vmcoreinfo : safecopy=0xf8eb7000
    [   22.912318] !!!!! crash_update_vmcoreinfo_safecopy : ptr=0xf8eb7000 vmcoreinfo_data=0xeea9b000, vmcoreinfo_size=0x62a
    [   22.922986] Unhandled fault: asynchronous external abort (0x1211) at 0x00000000
    [   22.930322] pgd = a1be880e
    [   22.933035] [00000000] *pgd=82d390003, *pmd=00000000
    [   22.938027] Internal error: : 1211 [#1] SMP ARM
    [   22.942570] Modules linked in: fsp_reset(O)
    [   22.946778] CPU: 0 PID: 2969 Comm: kexec Tainted: G           O      4.19.61-yocto-standard #1
    [   22.955420] Hardware name: Keystone
    [   22.958924] PC is at memcpy+0x48/0x330
    [   22.962684] LR is at 0x645f6770
    [   22.965833] pc : [<c0be16e8>]    lr : [<645f6770>]    psr: 20080013
    [   22.972121] sp : ed1bff1c  ip : 5f726570  fp : 00000030
    [   22.977362] r10: c12fa3a8  r9 : 00000000  r8 : 70617773
    [   22.982603] r7 : 284c4f42  r6 : 4d59530a  r5 : 63343936  r4 : 30323163
    [   22.989153] r3 : 3d297061  r2 : 0000052a  r1 : eea9b080  r0 : f8eb7080
    [   22.995705] Flags: nzCv  IRQs on  FIQs on  Mode SVC_32  ISA ARM  Segment user
    [   23.002865] Control: 30c5387d  Table: 2c82b300  DAC: fffffffd
    [   23.008629] Process kexec (pid: 2969, stack limit = 0xb92663e8)
    [   23.014568] Stack: (0xed1bff1c to 0xed1c0000)
    [   23.018938] ff00:        f8eb7000
    [   23.027146] ff20: f8eb7000 00280001 00000000 f8eb7000 c12fa398 c02a7c14 0000062a c02a8a04
    [   23.035354] ff40: c0d6e468 c1206508 ed2d0400 c02a8a10 0000071f 00c00000 dd279024 d67326dd
    [   23.043563] ff60: ed2d0400 00000003 ed2d0420 c02a9684 0000015b 00000001 a7ffffff 00000000
    [   23.051771] ff80: 0000015b 00000000 beab69a0 b6e297e8 0000015b c0201204 ed1be000 0000015b
    [   23.059978] ffa0: 004a8274 c02011c8 00000000 beab69a0 a0008000 00000003 01796ec0 00280001
    [   23.068185] ffc0: 00000000 beab69a0 b6e297e8 0000015b 00000003 beab69a0 00000000 004a8274
    [   23.076393] ffe0: beab6970 beab6960 00486a77 b6eb4ca2 80080030 a0008000 00000000 00000000
    [   23.084613] [<c0be16e8>] (memcpy) from [<c02a7c14>] (crash_update_vmcoreinfo_safecopy+0x4c/0x58)
    [   23.093438] [<c02a7c14>] (crash_update_vmcoreinfo_safecopy) from [<c02a8a10>] (kimage_crash_copy_vmcoreinfo+0xdc/0xf8)
    [   23.104178] [<c02a8a10>] (kimage_crash_copy_vmcoreinfo) from [<c02a9684>] (sys_kexec_load+0x28c/0x414)
    [   23.113524] [<c02a9684>] (sys_kexec_load) from [<c02011c8>] (__sys_trace_return+0x0/0x10)
    [   23.121731] Exception stack(0xed1bffa8 to 0xed1bfff0)
    [   23.126799] ffa0:                   00000000 beab69a0 a0008000 00000003 01796ec0 00280001
    [   23.135007] ffc0: 00000000 beab69a0 b6e297e8 0000015b 00000003 beab69a0 00000000 004a8274
    [   23.143214] ffe0: beab6970 beab6960 00486a77 b6eb4ca2
    [   23.148285] Code: ba000002 f5d1f03c f5d1f05c f5d1f07c (e8b151f8)
    [   23.154403] ---[ end trace 9cc71d3db0f913db ]---
    [   23.159203] Unhandled fault: asynchronous external abort (0x1211) at 0x00000000
    [   23.166539] pgd = dadaaccc
    [   23.169250] [00000000] *pgd=82d079003, *pmd=00000000
    Am I missing something ?
    What does asynchronous means ?
    What does slave error means ?
     I could not understand this when reading the ARM technical manual.
    Thanks for answers.
  • Hi, dr,
    According to "Understanding a kernel Oops", https://opensourceforu.com/2011/01/understanding-a-kernel-oops/,
    This is the error code value in hex. Each bit has a significance of its own:
    • bit 0 == 0 means no page found, 1 means a protection fault
    • bit 1 == 0 means read, 1 means write
    • bit 2 == 0 means kernel, 1 means user-mode
    the error code 1211, means b0:1 - a protection fault, bit 1:0 - a read action, bit 2:0 - kernel.
    So, I interpret it as reading the value at an illegal address which may be protected by MMU, or not in data area. Since it seems to happen in memcpy (kernel), it may step over some memory and causes some address became illegal. This is my guess and it will need further debugging.
    We are not proficient in ARM technical questions. I won't be able to help much in that area.
    Rex
    After examining kernel source code, 0x1211 is DFSR register value from the ARM Cortex 15.
  • Hi, dr,
    Yes, that's pretty much what the Oops message shows
    DFSR: 0x1211
    b 0001 0010 0001 0001
              |     |        |______|
              |     |             Asynchronous external abort
           Ext     Long description translation table
    Rex
    My understanding of documentation is that when an external abort fires the stack shown does not correspond to the true instruction which is the root cause of the exception.
    Is that correct ?
    And how to go further with this ?
    Another question.
    In the dump below Link Register (LR) does not point to Kernel code like PC register. The LR value is not something like 0xc0xxxxxx.
    I tried to dump the area pointed to by LR but is is unmapped.
    My understanding is that LR register points to the instruction to return to when exception is taken.
    Is that correct ?
    Any comment on LR value shown below ?
    [   22.476709] Unhandled fault: asynchronous external abort (0x1211) at 0x00000000
    [   22.484043] pgd = 399a11e0
    [   22.486756] [00000000] *pgd=82d3cf003, *pmd=00000000
    [   22.491748] Internal error: : 1211 [#1] SMP ARM
    [   22.496292] Modules linked in: fsp_reset(O)
    [   22.500499] CPU: 0 PID: 2965 Comm: kexec Tainted: G           O      4.19.61-yocto-standard #1
    [   22.509142] Hardware name: Keystone
    [   22.512645] PC is at memcpy+0x48/0x330
    [   22.516406] LR is at 0xa306334
    [   22.519468] pc : [<c0bdfee8>]    lr : [<0a306334>]    psr: 20080013
    [   22.525756] sp : ed3dff24  ip : 64393231  fp : 00000030
    [   22.530997] r10: c12fa368  r9 : 00000000  r8 : 633d2961
    [   22.536239] r7 : 7461645f  r6 : 65676170  r5 : 5f676974  r4 : 6e6f6328
    [   22.542788] r3 : 4c4f424d  r2 : 000004aa  r1 : eeab2100  r0 : f8eb7100
    [   22.549338] Flags: nzCv  IRQs on  FIQs on  Mode SVC_32  ISA ARM  Segment user
    [   22.556499] Control: 30c5387d  Table: 2d3ce380  DAC: fffffffd
    [   22.562264] Process kexec (pid: 2965, stack limit = 0xe1eb33f4)
    [   22.568205] Stack: (0xed3dff24 to 0xed3e0000)
    [   22.572577] ff20:          f8eb7000 ed2e9420 00280001 00000000 f8eb7000 c12fa358 c02a7d08
    [   22.580785] ff40: c1206508 ed2e9400 ed2e9420 c02a8ab8 0000071f 00c00000 dd279024 d67326dd
    [   22.588993] ff60: 00000000 ed2e9400 00000003 c02a9744 0000015b 00000001 a7ffffff 00000000
    [   22.597201] ff80: 0000015b 00000000 bee7f9a0 b6e897e8 0000015b c0201204 ed3de000 0000015b
    [   22.605409] ffa0: 004d4274 c02011c8 00000000 bee7f9a0 a0008000 00000003 0237bec0 00280001
    [   22.613616] ffc0: 00000000 bee7f9a0 b6e897e8 0000015b 00000003 bee7f9a0 00000000 004d4274
    [   22.621824] ffe0: bee7f970 bee7f960 004b2a77 b6f14ca2 80080030 a0008000 00000000 00000000
    [   22.630041] [<c0bdfee8>] (memcpy) from [<c02a7d08>] (crash_update_vmcoreinfo_safecopy+0x20/0x28)
    [   22.638866] [<c02a7d08>] (crash_update_vmcoreinfo_safecopy) from [<c02a8ab8>] (kimage_crash_copy_vmcoreinfo+0x94/0xc8)
    [   22.649607] [<c02a8ab8>] (kimage_crash_copy_vmcoreinfo) from [<c02a9744>] (sys_kexec_load+0x28c/0x414)
    [   22.658953] [<c02a9744>] (sys_kexec_load) from [<c02011c8>] (__sys_trace_return+0x0/0x10)
    [   22.667158] Exception stack(0xed3dffa8 to 0xed3dfff0)
    [   22.672227] ffa0:                   00000000 bee7f9a0 a0008000 00000003 0237bec0 00280001
    [   22.680434] ffc0: 00000000 bee7f9a0 b6e897e8 0000015b 00000003 bee7f9a0 00000000 004d4274
    [   22.688641] ffe0: bee7f970 bee7f960 004b2a77 b6f14ca2
    [   22.693712] Code: ba000002 f5d1f03c f5d1f05c f5d1f07c (e8b151f8)
    [   22.699829] ---[ end trace ee8b9900c5b0338e ]---
  • Hi, dr,
    Kernel is loaded at 0x82000000 and uses space beyond that. The LR register doesn't look legal. None of your 3 dumps has legal LR address. It looks to me is typical memory overwritten issue. I won't be able to help you in debugging the code. The questions you asked are generic Kernel debugging and can be found on internet. This forum supports TI specific issues. For your issue, I suggest that you start with TI prebuilt kernel image and adding your change one at a time, or check what were changed since last working version and see what could possible cause the crash.
    Rex
  • Hi Rex,
    OK, thanks.
    Can you tell if Kernel crash dumping is validated on K2HK EVM ?
  • K2HK_CRASHDUMP.LOGHi,
    Abort is reproduced on K2HK EVM. See log file.
  • Hi, dr,
    Is the crash dump on TI EVM using prebuilt images? If it is running the images with your applications, could you try using the prebuilt images and see if kernel boots up?
    Rex
  • Hi Rex,
    Everything comes from http://software-dl.ti.com/processor-sdk-linux/esd/K2HK/latest/exports/k2hk-evm-linux-sdk-bin-06.03.00.106.tar.xz
    The log I posted yesterday should confirm that.
    One executable was missing in the pre-built filesystem : /usr/bin/makedumpfile
    I copied it from Yocto build. I think that this executable is used only when creating the crash dump file and not when starting kdump.
    I also modified kdump.conf so that start of kdump service goes on.
    Yesterday test was done with u-boot not coming from pre-built binaries.
    I just did the test again with pre-built u-boot and kernel crashes the same way.
    dr.
  • Hi, dr,
    Let me download 6.3 release and give it a try later today.
    Rex
  • Hi, dr,
    I just tried with PLSDK 6.3 release on the kexec. I don't know if we are talking about the same thing, but I can't reproduce the issue. It boots to the kernel prompt. Is it what you intend to do? Please see my console logs.
    root@k2hk-evm:/# kexec -l /zImage
    root@k2hk-evm:/# kexec -e
    [  382.187690] netcp-1.0 2620110.netcp eth0: Link is Down
    [  382.497158] kexec_core: Starting new kernel
    [  382.501439] Disabling non-boot CPUs ...
    [  382.753793] Bye!
    [    0.000000] Booting Linux on physical CPU 0x0
    [    0.000000] Linux version 4.19.94-ge9a2c0b99b (oe-user@oe-host) (gcc version 8.3.0 (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36))) #1 SMP PREEMPT Thu Feb 6 03:33:41 UTC 2020
    [    0.000000] CPU: ARMv7 Processor [412fc0f4] revision 4 (ARMv7), cr=30c5387d
    [    0.000000] CPU: div instructions available: patching division code
    [    0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
    [    0.000000] OF: fdt: Machine model: Texas Instruments Keystone 2 Kepler/Hawking EVM
    [    0.000000] Memory policy: Data cache writealloc
    [    0.000000] Switching physical address space to 0x800000000
    [    0.000000] efi: Getting EFI parameters from FDT:
    [    0.000000] Reserved memory: created CMA memory pool at 0x000000081f800000, size 8 MiB
    [    0.000000] OF: reserved mem: initialized node dsp-common-memory@81f800000, compatible id shared-dma-pool
    [    0.000000] cma: Reserved 24 MiB at 0x000000087e400000
    [    0.000000] psci: probing for conduit method from DT.
    [    0.000000] psci: Using PSCI v0.1 Function IDs from DT
    [    0.000000] random: get_random_bytes called from start_kernel+0xb4/0x470 with crng_init=0
    [    0.000000] percpu: Embedded 15 pages/cpu s32396 r8192 d20852 u61440
    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 359296
    [    0.000000] Kernel command line: console=ttyS0,115200n8 rootwait=1 mtdparts=spi0.0:1m(u-boot-spl)ro,-(misc) rootfstype=nfs root=/dev/nfs rw nfsroot=158.218.116.223:/nfs/k2h_fs,v3,tcp,rsize=4096,wsize=4096 ip=dhcp
    [    0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
    [    0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
    [    0.000000] Memory: 1378520K/1441792K available (10240K kernel code, 289K rwdata, 2728K rodata, 2048K init, 266K bss, 30504K reserved, 32768K cma-reserved, 892928K highmem)
    [    0.000000] Virtual kernel memory layout:
    [    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
    [    0.000000]     fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
    [    0.000000]     vmalloc : 0xe0800000 - 0xff800000   ( 496 MB)
    [    0.000000]     lowmem  : 0xc0000000 - 0xe0000000   ( 512 MB)
    [    0.000000]     pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
    [    0.000000]     modules : 0xbf000000 - 0xbfe00000   (  14 MB)
    [    0.000000]       .text : 0x(ptrval) - 0x(ptrval)   (12256 kB)
    [    0.000000]       .init : 0x(ptrval) - 0x(ptrval)   (2048 kB)
    [    0.000000]       .data : 0x(ptrval) - 0x(ptrval)   ( 290 kB)
    [    0.000000]        .bss : 0x(ptrval) - 0x(ptrval)   ( 267 kB)
    [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
    [    0.000000] rcu: Preemptible hierarchical RCU implementation.
    [    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
    [    0.000000]  Tasks RCU enabled.
    [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
    [    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
    [    0.000000] GIC: Using split EOI/Deactivate mode
    [    0.000000] arch_timer: cp15 timer(s) running at 133.12MHz (phys).
    [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x1eb398c371, max_idle_ns: 440795206302 ns
    [    0.000017] sched_clock: 56 bits at 133MHz, resolution 7ns, wraps every 2199023255549ns
    [    0.000038] Switching to timer-based delay loop, resolution 7ns
    [    0.000430] keystone timer clock @133120000 Hz
    [    0.001010] Console: colour dummy device 80x30
    [    0.001197] Calibrating delay loop (skipped), value calculated using timer frequency.. 266.24 BogoMIPS (lpj=1331200)
    [    0.001223] pid_max: default: 32768 minimum: 301
    [    0.001516] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
    [    0.001554] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
    [    0.003499] CPU: Testing write buffer coherency: ok
    [    0.003584] CPU0: Spectre v2: firmware did not set auxiliary control register IBE bit, system vulnerable
    [    0.004754] /cpus/cpu@0 missing clock-frequency property
    [    0.004794] /cpus/cpu@1 missing clock-frequency property
    [    0.004834] /cpus/cpu@2 missing clock-frequency property
    [    0.004876] /cpus/cpu@3 missing clock-frequency property
    [    0.004903] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
    [    0.060186] Setting up static identity map for 0x80200000 - 0x80200138
    [    0.080111] rcu: Hierarchical SRCU implementation.
    [    0.100468] EFI services will not be available.
    [    0.120182] smp: Bringing up secondary CPUs ...
    [    0.211174] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
    [    0.211213] CPU1: Spectre v2: firmware did not set auxiliary control register IBE bit, system vulnerable
    [    0.301645] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
    [    0.301685] CPU2: Spectre v2: firmware did not set auxiliary control register IBE bit, system vulnerable
    [    0.392318] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
    [    0.392368] CPU3: Spectre v2: firmware did not set auxiliary control register IBE bit, system vulnerable
    [    0.393378] smp: Brought up 1 node, 4 CPUs
    [    0.393426] SMP: Total of 4 processors activated (1064.96 BogoMIPS).
    [    0.393461] CPU: All CPU(s) started in HYP mode.
    [    0.393473] CPU: Virtualization extensions available.
    [    0.395950] devtmpfs: initialized
    [    0.411477] VFP support v0.3: implementor 41 architecture 4 part 30 variant f rev 0
    [    0.412295] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
    [    0.412347] futex hash table entries: 1024 (order: 4, 65536 bytes)
    [    0.417320] pinctrl core: initialized pinctrl subsystem
    [    0.418561] DMI not present or invalid.
    [    0.419469] NET: Registered protocol family 16
    [    0.423199] DMA: preallocated 256 KiB pool for atomic coherent allocations
    [    0.424793] cpuidle: using governor ladder
    [    0.424846] cpuidle: using governor menu
    [    0.425090] No ATAGs?
    [    0.425330] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
    [    0.425352] hw-breakpoint: maximum watchpoint size is 8 bytes.
    [    0.457325] SCSI subsystem initialized
    [    0.459325] media: Linux media interface: v0.10
    [    0.459383] videodev: Linux video capture interface: v2.00
    [    0.459497] pps_core: LinuxPPS API ver. 1 registered
    [    0.459510] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [    0.459538] PTP clock support registered
    [    0.459628] EDAC MC: Ver: 3.0.0
    [    0.460773] Advanced Linux Sound Architecture Driver Initialized.
    [    0.462561] clocksource: Switched to clocksource arch_sys_counter
    [    0.474848] NET: Registered protocol family 2
    [    0.476296] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes)
    [    0.476366] TCP established hash table entries: 4096 (order: 2, 16384 bytes)
    [    0.476504] TCP bind hash table entries: 4096 (order: 3, 32768 bytes)
    [    0.476731] TCP: Hash tables configured (established 4096 bind 4096)
    [    0.477342] UDP hash table entries: 256 (order: 1, 8192 bytes)
    [    0.477409] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
    [    0.477737] NET: Registered protocol family 1
    [    0.478845] RPC: Registered named UNIX socket transport module.
    [    0.478863] RPC: Registered udp transport module.
    [    0.478877] RPC: Registered tcp transport module.
    [    0.478888] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    0.479357] Trying to unpack rootfs image as initramfs...
    [    0.479833] rootfs image is not initramfs (junk in compressed archive); looks like an initrd
    [    0.481177] Freeing initrd memory: 52K
    [    0.481573] hw perfevents: no interrupt-affinity property for /pmu, guessing.
    [    0.482101] hw perfevents: enabled with armv7_cortex_a15 PMU driver, 7 counters available
    [    0.483243] platform alarmtimer: set dma_pfn_offset00780000
    [    0.484352] Initialise system trusted keyrings
    [    0.484690] workingset: timestamp_bits=14 max_order=19 bucket_order=5
    [    0.493096] squashfs: version 4.0 (2009/01/31) Phillip Lougher
    [    0.493979] NFS: Registering the id_resolver key type
    [    0.494019] Key type id_resolver registered
    [    0.494032] Key type id_legacy registered
    [    0.494109] ntfs: driver 2.1.32 [Flags: R/O].
    [    0.497890] Key type asymmetric registered
    [    0.497915] Asymmetric key parser 'x509' registered
    [    0.497999] bounce: pool size: 64 pages
    [    0.498054] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
    [    0.498075] io scheduler noop registered
    [    0.498088] io scheduler deadline registered
    [    0.498256] io scheduler cfq registered (default)
    [    0.498273] io scheduler mq-deadline registered
    [    0.498285] io scheduler kyber registered
    [    0.499013] keystone_irq 26202a0.keystone_irq: irqchip registered, nr_irqs 28
    [    0.500417] ti,keystone-serdes 232a000.phy: Direct firmware load for ks2_gbe_serdes.bin failed with error -2
    [    0.500444] ti,keystone-serdes 232a000.phy: can't get any serdes init fw
    [    0.500458] ti,keystone-serdes 232a000.phy: serdes procider init failed -19
    [    0.508348] keystone-navigator-qmss soc@0:qmss@2a40000: qmgr start queue 0, number of queues 8192
    [    0.508685] keystone-navigator-qmss soc@0:qmss@2a40000: added qmgr start queue 0, num of queues 8192, reg_peek (ptrval), reg_status (ptrval), reg_config (ptrval), reg_region (ptrval), reg_push (ptrval), reg_pop (ptrval)
    [    0.508712] keystone-navigator-qmss soc@0:qmss@2a40000: qmgr start queue 8192, number of queues 8192
    [    0.508908] keystone-navigator-qmss soc@0:qmss@2a40000: added qmgr start queue 8192, num of queues 8192, reg_peek (ptrval), reg_status (ptrval), reg_config (ptrval), reg_region (ptrval), reg_push (ptrval), reg_pop (ptrval)
    [    0.509147] keystone-navigator-qmss soc@0:qmss@2a40000: failed to get firmware for pdsp
    [    0.512370] keystone-navigator-qmss soc@0:qmss@2a40000: pdsp id 0 not started for range acc-low-0
    [    0.517676] keystone-navigator-dma soc@0:knav_dmas@0: DMA dma_gbe registered 41 logical channels, flows 32, tx chans: 9, rx chans: 24
    [    0.591622] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
    [    0.591779] platform serial8250: set dma_pfn_offset00780000
    [    0.597739] console [ttyS0] disabled
    [    0.597874] 2530c00.serial: ttyS0 at MMIO 0x2530c00 (irq = 27, base_baud = 8320000) is a TI DA8xx/66AK2x
    [    1.506609] console [ttyS0] enabled
    [    1.511459] 2531000.serial: ttyS1 at MMIO 0x2531000 (irq = 28, base_baud = 8320000) is a TI DA8xx/66AK2x
    [    1.539767] brd: module loaded
    [    1.565135] loop: module loaded
    [    1.573122] spi_davinci 21000400.spi: DMA is not supported (-19)
    [    1.580958] m25p80 spi0.0: n25q128a11 (16384 Kbytes)
    [    1.586012] 2 cmdlinepart partitions found on MTD device spi0.0
    [    1.591916] Creating 2 MTD partitions on "spi0.0":
    [    1.596747] 0x000000000000-0x000000100000 : "u-boot-spl"
    [    1.603416] 0x000000100000-0x000001000000 : "misc"
    [    1.609525] spi_davinci 21000400.spi: Controller at 0x(ptrval)
    [    1.616005] spi_davinci 21000600.spi: DMA is not supported (-19)
    [    1.622500] spi_davinci 21000600.spi: Controller at 0x(ptrval)
    [    1.628886] spi_davinci 21000800.spi: DMA is not supported (-19)
    [    1.635433] spi_davinci 21000800.spi: Controller at 0x(ptrval)
    [    1.641857] platform Fixed MDIO bus.0: set dma_pfn_offset00780000
    [    1.648364] libphy: Fixed MDIO Bus: probed
    [    1.712597] davinci_mdio 2090300.mdio: davinci mdio revision 1.5, bus freq 2500000
    [    1.720146] libphy: 2090300.mdio: probed
    [    1.727079] davinci_mdio 2090300.mdio: phy[0]: device 2090300.mdio:00, driver Marvell 88E1111
    [    1.735614] davinci_mdio 2090300.mdio: phy[1]: device 2090300.mdio:01, driver Marvell 88E1111
    [    1.745480] ti,keystone-serdes 232a000.phy: Requested PHY is disabled
    [    2.273201] ti,keystone-serdes 232a000.phy: Requested PHY is disabled
    [    2.800817] netcp-1.0 2620110.netcp: initialized cpsw ale version 1.3
    [    2.807270] netcp-1.0 2620110.netcp: ALE Table size 1024
    [    2.812661] netcp-1.0 2620110.netcp: cpts: overflow check period 500 (jiffies)
    [    2.819874] netcp-1.0 2620110.netcp: CPTS: ref_clk_freq:399360000 calc_mult:2688656410 calc_shift:30 error:-1 nsec/sec
    [    2.832346] netcp-1.0 2620110.netcp: module(netcp-xgbe) not used for device
    [    2.839835] i2c /dev entries driver
    [    2.846548] sdhci: Secure Digital Host Controller Interface driver
    [    2.852753] sdhci: Copyright(c) Pierre Ossman
    [    2.857507] sdhci-pltfm: SDHCI platform and OF driver helper
    [    2.865172] ledtrig-cpu: registered to indicate activity on CPUs
    [    2.875906] nand: device found, Manufacturer ID: 0x2c, Chip ID: 0xac
    [    2.882248] nand: Micron MT29F4G08ABBDAHC
    [    2.886294] nand: 512 MiB, SLC, erase size: 128 KiB, page size: 2048, OOB size: 64
    [    2.894343] Bad block table found at page 262080, version 0x01
    [    2.900764] Bad block table found at page 262016, version 0x01
    [    2.907092] 3 fixed-partitions partitions found on MTD device 30000000.nand
    [    2.914066] Creating 3 MTD partitions on "30000000.nand":
    [    2.919463] 0x000000000000-0x000000100000 : "u-boot"
    [    2.925950] 0x000000100000-0x000000180000 : "params"
    [    2.932267] 0x000000180000-0x000020000000 : "ubifs"
    [    2.943849] davinci_nand 30000000.nand: controller rev. 2.5
    [    2.950719] platform snd-soc-dummy: set dma_pfn_offset00780000
    [    2.958701] NET: Registered protocol family 10
    [    2.965512] Segment Routing with IPv6
    [    2.969301] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
    [    2.976138] NET: Registered protocol family 17
    [    2.980905] Key type dns_resolver registered
    [    2.985570] Registering SWP/SWPB emulation handler
    [    2.991264] Loading compiled-in X.509 certificates
    [    3.011987] hctosys: unable to open rtc device (rtc0)
    [    3.223075] netcp-1.0 2620110.netcp eth0: Link is Down
    [    3.231993] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
    [    3.332545] (NULL net_device): Link is Down
    [    3.336726] (NULL net_device): Link is Down
    [    3.443059] netcp-1.0 2620110.netcp eth1: Link is Down
    [    3.449817] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
    [    6.473687] netcp-1.0 2620110.netcp eth0: Link is Up - 1Gbps/Full - flow control rx/tx
    [    6.482598] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
    [    6.512924] Sending DHCP requests ., OK
    [    7.596442] IP-Config: Got DHCP answer from 158.218.116.4, my address is 158.218.117.18
    [    7.604459] IP-Config: Complete:
    [    7.607684]      device=eth0, hwaddr=c4:ed:ba:9a:67:6e, ipaddr=158.218.117.18, mask=255.255.254.0, gw=158.218.116.1
    [    7.618109]      host=dhcp-158-218-117-18, domain=dhcp.ti.com, nis-domain=(none)
    [    7.625506]      bootserver=0.0.0.0, rootserver=158.218.116.223, rootpath=
    [    7.625513]      nameserver0=192.0.2.2, nameserver1=192.0.2.3
    [    7.657149] ALSA device list:
    [    7.660109]   No soundcards found.
    [    7.674419] RAMDISK: Couldn't find valid RAM disk image starting at 0.
    [    7.686740] VFS: Mounted root (nfs filesystem) on device 0:14.
    [    7.692977] devtmpfs: mounted
    [    7.697639] Freeing unused kernel memory: 2048K
    [    7.702354] Run /sbin/init as init process
    [    7.717333] random: fast init done
    [    7.873177] systemd[1]: System time before build time, advancing clock.
    [    7.901911] systemd[1]: systemd 239 running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR +SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN2 -IDN -PCRE2 default-hierarchy=hybrid)
    [    7.923685] systemd[1]: Detected architecture arm.
    Welcome to Arago 2019.11!
    [    7.963730] systemd[1]: Set hostname to <k2hk-evm>.
    [    8.208178] systemd[1]: File /lib/systemd/system/systemd-journald.service:36 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
    [    8.225230] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
    [    8.611724] random: systemd: uninitialized urandom read (16 bytes read)
    [    8.619611] systemd[1]: Listening on Journal Socket.
    [  OK  ] Listening on Journal Socket.
    [    8.652710] random: systemd: uninitialized urandom read (16 bytes read)
    [    8.659588] systemd[1]: Listening on initctl Compatibility Named Pipe.
    [  OK  ] Listening on initctl Compatibility Named Pipe.
    [    8.692848] random: systemd: uninitialized urandom read (16 bytes read)
    [    8.700083] systemd[1]: Listening on Network Service Netlink Socket.
    [  OK  ] Listening on Network Service Netlink Socket.
    [    8.743159] systemd[1]: Listening on Journal Socket (/dev/log).
    [  OK  ] Listening on Journal Socket (/dev/log).
    [    8.782706] systemd[1]: Reached target Swap.
    [  OK  ] Reached target Swap.
    [  OK  ] Listening on Process Core Dump Socket.
             Mounting Kernel Debug File System...
    [  OK  ] Started Hardware RNG Entropy Gatherer Daemon.
    [    8.937524] random: crng init done
    [    8.940951] random: 5 urandom warning(s) missed due to ratelimiting
    [  OK  ] Created slice system-getty.slice.
             Starting Remount Root and Kernel File Systems...
    [  OK  ] Created slice User and Session Slice.
    [  OK  ] Started Dispatch Password Requests to Console Directory Watch.
             Starting Load Kernel Modules...
    [  OK  ] Created slice system-serial\x2dgetty.slice.
    [    9.150131] cmemk: loading out-of-tree module taints kernel.
    [    9.157344] CMEMK module: reference Linux version 4.19.94
    [    9.163235] allocated heap buffer 0xc100000 of size 0x480000
    [    9.168939] cmemk initialized
             Mounting Temporary Directory (/tmp)...
    [    9.179522] cryptodev: driver 1.9 loaded.
    [    9.200217] NET: Registered protocol family 45
    [  OK  ] Started Forward Password Requests to Wall Directory Watch.
    [  OK  ] Listening on udev Kernel Socket.
    [  OK  ] Reached target Paths.
    [  OK  ] Created slice system-syslog\x2dng.slice.
             Starting Journal Service...
    [  OK  ] Reached target Remote File Systems.
    [  OK  ] Reached target Slices.
             Mounting POSIX Message Queue File System...
    [  OK  ] Listening on udev Control Socket.
             Starting udev Coldplug all Devices...
    [  OK  ] Started Journal Service.
    [  OK  ] Mounted Kernel Debug File System.
    [  OK  ] Started Remount Root and Kernel File Systems.
    [  OK  ] Started Load Kernel Modules.
    [  OK  ] Mounted Temporary Directory (/tmp).
    [  OK  ] Mounted POSIX Message Queue File System.
             Mounting Kernel Configuration File System...
             Starting Apply Kernel Variables...
             Starting Create Static Device Nodes in /dev...
             Starting Flush Journal to Persistent Storage...
    [  OK  ] Mounted Kernel Configuration File System.
    [  OK  ] Started Apply Kernel Variables.
    [  OK  ] Started Create Static Device Nodes in /dev.
    [  OK  ] Reached target Local File Systems (Pre).
             Mounting /var/volatile...
             Mounting /media/ram...
    [  OK  ] Reached target Containers.
             Starting udev Kernel Device Manager...
    [  OK  ] Mounted /var/volatile.
    [  OK  ] Mounted /media/ram.
    [   10.234256] systemd-journald[106]: Received request to flush runtime journal from PID 1
             Starting Load/Save Random Seed...
    [  OK  ] Reached target Local File Systems.
    [  OK  ] Started udev Kernel Device Manager.
    [  OK  ] Started Flush Journal to Persistent Storage.
    [  OK  ] Started Load/Save Random Seed.
    [  OK  ] Started udev Coldplug all Devices.
    [   10.540428] keystone-rproc 10800000.dsp: assigned reserved memory node dsp-common-memory@81f800000
    [   10.551588] remoteproc remoteproc0: 10800000.dsp is available
    [   10.562286] keystone-rproc 11800000.dsp: assigned reserved memory node dsp-common-memory@81f800000
    [   10.580322] remoteproc remoteproc1: 11800000.dsp is available
    [   10.591235] keystone-rproc 12800000.dsp: assigned reserved memory node dsp-common-memory@81f800000
    [   10.602656] remoteproc remoteproc2: 12800000.dsp is available
    [   10.611313] keystone-rproc 13800000.dsp: assigned reserved memory node dsp-common-memory@81f800000
    [   10.623745] remoteproc remoteproc3: 13800000.dsp is available
    [   10.632473] keystone-rproc 14800000.dsp: assigned reserved memory node dsp-common-memory@81f800000
    [   10.645106] remoteproc remoteproc4: 14800000.dsp is available
    [   10.655065] keystone-rproc 15800000.dsp: assigned reserved memory node dsp-common-memory@81f800000
    [   10.666404] remoteproc remoteproc5: 15800000.dsp is available
    [   10.676383] keystone-rproc 16800000.dsp: assigned reserved memory node dsp-common-memory@81f800000
    [   10.687152] remoteproc remoteproc6: 16800000.dsp is available
    [   10.699565] keystone-rproc 17800000.dsp: assigned reserved memory node dsp-common-memory@81f800000
    [   10.710687] remoteproc remoteproc7: 17800000.dsp is available
    [   10.826977] davinci-wdt 22f0080.wdt: heartbeat 60 sec
    [   10.974310] at24 0-0050: 131072 byte 24c1024 EEPROM, writable, 1 bytes/write
    [   11.095016] keystone-usbphy 2620738.usb_phy: 2620738.usb_phy supply vcc not found, using dummy regulator
    [   11.113289] keystone-usbphy 2620738.usb_phy: Linked as a consumer to regulator.0
    [  OK  ] Found device /dev/ttyS0.
    [   12.866934] dwc3 2690000.dwc3: Failed to get clk 'ref': -2
    [   12.874303] platform xhci-hcd.0.auto: set dma_pfn_offset00780000
    [   12.924713] usbcore: registered new interface driver usbfs
    [   12.931404] usbcore: registered new interface driver hub
    [   12.938043] usbcore: registered new device driver usb
    [   12.961029] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
    [   12.966621] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
    [   12.976815] xhci-hcd xhci-hcd.0.auto: hcc params 0x0298f06d hci version 0x100 quirks 0x0000000002010010
    [   12.986270] xhci-hcd xhci-hcd.0.auto: irq 35, io mem 0x02690000
    [   12.992739] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
    [   13.000983] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [   13.008255] usb usb1: Product: xHCI Host Controller
    [   13.013245] usb usb1: Manufacturer: Linux 4.19.94-ge9a2c0b99b xhci-hcd
    [   13.019756] usb usb1: SerialNumber: xhci-hcd.0.auto
    [   13.027178] hub 1-0:1.0: USB hub found
    [   13.031034] hub 1-0:1.0: 1 port detected
    [   13.035780] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
    [   13.041332] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
    [   13.049069] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
    [   13.055800] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
    [   13.064145] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 4.19
    [   13.072447] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [   13.079766] usb usb2: Product: xHCI Host Controller
    [   13.084717] usb usb2: Manufacturer: Linux 4.19.94-ge9a2c0b99b xhci-hcd
    [   13.091281] usb usb2: SerialNumber: xhci-hcd.0.auto
    [   13.096882] hub 2-0:1.0: USB hub found
    [   13.100728] hub 2-0:1.0: 1 port detected
    [  OK  ] Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
             Starting Create Volatile Files and Directories...
    [  OK  ] Started Create Volatile Files and Directories.
             Starting Network Time Synchronization...
             Starting Network Service...
             Starting Update UTMP about System Boot/Shutdown...
    [  OK  ] Started Update UTMP about System Boot/Shutdown.
    [  OK  ] Started Network Service.
             Starting Wait for Network to be Configured...
             Starting Network Name Resolution...
    [  OK  ] Started Wait for Network to be Configured.
    [  OK  ] Started Network Time Synchronization.
    [  OK  ] Reached target System Time Synchronized.
    [  OK  ] Reached target System Initialization.
    [  OK  ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
    [  OK  ] Started Daily rotation of log files.
    [  OK  ] Started Daily Cleanup of Temporary Directories.
    [  OK  ] Reached target Timers.
    [  OK  ] Listening on dropbear.socket.
    [  OK  ] Listening on D-Bus System Message Bus Socket.
    [  OK  ] Listening on RPCbind Server Activation Socket.
    [  OK  ] Reached target Sockets.
    [  OK  ] Reached target Basic System.
             Starting Login Service...
             Starting Ethernet Bridge Filtering Tables...
    [  OK  ] Started Periodic Command Scheduler.
    [  OK  ] Started D-Bus System Message Bus.
             Starting TI Multiproc Manager...
             Starting run_srss_tc.service...
             Starting softhsm-daemon.service...
             Starting TI IPC Daemon...
    [  OK  ] Started Job spooling tools.
             Starting telnetd.service...
             Starting Print notice about GPLv3 packages...
             Starting RPC Bind Service...
             Starting Matrix GUI...
             Starting System Logger Daemon "default" instance...
    [  OK  ] Started Network Name Resolution.
    [  OK  ] Started Reboot and dump vmcore via kexec.
    [  OK  ] Started Ethernet Bridge Filtering Tables.
    [  OK  ] Started run_srss_tc.service.
    [  OK  ] Started softhsm-daemon.service.
    [  OK  ] Started TI IPC Daemon.
    [  OK  ] Started telnetd.service.
    [  OK  ] Started RPC Bind Service.
    [  OK  ] Started Matrix GUI.
    [   20.942206] registered dspmem misc device
             Starting thttpd.service...
             Starting syslog.service...
             Starting Avahi mDNS/DNS-SD Stack...
    [  OK  ] Reached target Network.
             Starting Lightning Fast Webserver With Light System Requirements...
             Starting Simple Network Management Protocol (SNMP) Daemon....
             Starting Permit User Sessions...
    [  OK  ] Reached target Network is Online.
    [  OK  ] Started strongSwan IPsec IKEv1/IKEv2 daemon using ipsec.conf.
    [  OK  ] Started Vsftpd ftp daemon.
    [  OK  ] Reached target Host and Network Name Lookups.
    [  OK  ] Started NFS status monitor for NFSv2/3 locking..
             Starting LSB: network benchmark...
    [  OK  ] Started Lightning Fast Webserver With Light System Requirements.
    [  OK  ] Started Permit User Sessions.
    [  OK  ] Started Getty on tty1.
    [  OK  ] Started Serial Getty on ttyS0.
    [  OK  ] Reached target Login Prompts.
             Starting Synchronize System and HW clocks...
    [  OK  ] Started Login Service.
    [  OK  ] Started thttpd.service.
    [FAILED] Failed to start Synchronize System and HW clocks.
    See 'systemctl status sync-clocks.service' for details.
    [  OK  ] Started Avahi mDNS/DNS-SD Stack.
    [  OK  ] Started LSB: network benchmark.
    [  OK  ] Started TI Multiproc Manager.
             Starting TI MultiCore Tools Daemon...
    [   21.525593] NET: Registered protocol family 15
    [   21.684881] Initializing XFRM netlink socket
    [  OK  ] Started Simple Network Management Protocol (SNMP) Daemon..
    [   22.841232] remoteproc remoteproc0: powering up 10800000.dsp
    [   22.846989] remoteproc remoteproc0: Booting unspecified pre-loaded fw image
    [   22.857915] remoteproc remoteproc0: registered virtio0 (type 7)
    [   22.864716] remoteproc remoteproc0: remote processor 10800000.dsp is now up
    [   22.877680] virtio_rpmsg_bus virtio0: rpmsg host is online
    [   22.877840] virtio_rpmsg_bus virtio0: creating channel rpmsg-proto addr 0x3d
    [   22.894670] remoteproc remoteproc1: powering up 11800000.dsp
    [   22.900323] remoteproc remoteproc1: Booting unspecified pre-loaded fw image
    [   22.914402] virtio_rpmsg_bus virtio1: rpmsg host is online
    [   22.920048] virtio_rpmsg_bus virtio1: creating channel rpmsg-proto addr 0x3d
    [   22.928135] remoteproc remoteproc1: registered virtio1 (type 7)
    [   22.934804] remoteproc remoteproc1: remote processor 11800000.dsp is now up
    [   22.964229] remoteproc remoteproc2: powering up 12800000.dsp
    [   22.970108] remoteproc remoteproc2: Booting unspecified pre-loaded fw image
    [   22.984713] virtio_rpmsg_bus virtio2: rpmsg host is online
    [   22.990362] virtio_rpmsg_bus virtio2: creating channel rpmsg-proto addr 0x3d
    [   22.998004] remoteproc remoteproc2: registered virtio2 (type 7)
    [   23.008678] remoteproc remoteproc2: remote processor 12800000.dsp is now up
    [   23.039939] remoteproc remoteproc3: powering up 13800000.dsp
    [   23.045743] remoteproc remoteproc3: Booting unspecified pre-loaded fw image
    [   23.058465] virtio_rpmsg_bus virtio3: rpmsg host is online
    [   23.058731] virtio_rpmsg_bus virtio3: creating channel rpmsg-proto addr 0x3d
    [   23.066718] remoteproc remoteproc3: registered virtio3 (type 7)
    [   23.078555] remoteproc remoteproc3: remote processor 13800000.dsp is now up
    [   23.108893] remoteproc remoteproc4: powering up 14800000.dsp
    [   23.116083] remoteproc remoteproc4: Booting unspecified pre-loaded fw image
    [   23.130835] virtio_rpmsg_bus virtio4: rpmsg host is online
    [   23.131135] virtio_rpmsg_bus virtio4: creating channel rpmsg-proto addr 0x3d
    [   23.139466] remoteproc remoteproc4: registered virtio4 (type 7)
    [   23.150843] remoteproc remoteproc4: remote processor 14800000.dsp is now up
    [   23.183845] remoteproc remoteproc5: powering up 15800000.dsp
    [   23.189505] remoteproc remoteproc5: Booting unspecified pre-loaded fw image
    [   23.203143] virtio_rpmsg_bus virtio5: rpmsg host is online
    [   23.203480] virtio_rpmsg_bus virtio5: creating channel rpmsg-proto addr 0x3d
    [   23.208821] remoteproc remoteproc5: registered virtio5 (type 7)
    [   23.222630] remoteproc remoteproc5: remote processor 15800000.dsp is now up
    [   23.253090] remoteproc remoteproc6: powering up 16800000.dsp
    [   23.258855] remoteproc remoteproc6: Booting unspecified pre-loaded fw image
    [   23.277533] virtio_rpmsg_bus virtio6: rpmsg host is online
    [   23.283339] virtio_rpmsg_bus virtio6: creating channel rpmsg-proto addr 0x3d
    [   23.291141] remoteproc remoteproc6: registered virtio6 (type 7)
    [   23.297490] remoteproc remoteproc6: remote processor 16800000.dsp is now up
    [   23.329205] remoteproc remoteproc7: powering up 17800000.dsp
    [   23.335067] remoteproc remoteproc7: Booting unspecified pre-loaded fw image
    [   23.356166] virtio_rpmsg_bus virtio7: rpmsg host is online
    [   23.356544] virtio_rpmsg_bus virtio7: creating channel rpmsg-proto addr 0x3d
    [   23.361826] remoteproc remoteproc7: registered virtio7 (type 7)
    [   23.374807] remoteproc remoteproc7: remote processor 17800000.dsp is now up
    [  OK  ] Started TI MultiCore Tools Daemon.
    NOTICE: This file system contains the following GPLv3 packages:
            autoconf
            bash-dev
            bash
            bc
            binutils-dev
            binutils
            bison-dev
            bison
            cifs-utils
            cpio
            cpp-symlinks
            cpp
            dosfstools
            elfutils-dev
            elfutils
            g++-symlinks
            g++
            gawk
            gcc-symlinks
            gcc
            gdb
            gdbc6x
            gdbserver
            gettext
            gstreamer1.0-libav
            gzip
            hidapi
            libasm1
            libbfd
            libcairo-perf-utils
            libdw1
            libelf1
            libgdbm-compat4
            libgdbm-dev
            libgdbm6
            libgettextlib
            libgettextsrc
            libgmp10
            libidn2-0
            libmpc3
            libmpfr6
            libreadline-dev
            libreadline7
            libunistring2
            m4-dev
            m4
            make
            nettle
            swig-dev
            swig
            which
    If you do not wish to distribute GPLv3 components please remove
    the above packages prior to distribution.  This can be done using
    the opkg remove command.  i.e.:
        opkg remove <package>
    Where <package> is the name printed in the list above
    NOTE: If the package is a dependency of another package you
          will be notified of the dependent packages.  You should
          use the --force-removal-of-dependent-packages option to
          also remove the dependent packages as well
    [  OK  ] Started Print notice about GPLv3 packages.
     _____                    _____           _         _
    |  _  |___ ___ ___ ___   |  _  |___ ___  |_|___ ___| |_
    |     |  _| .'| . | . |  |   __|  _| . | | | -_|  _|  _|
    |__|__|_| |__,|_  |___|  |__|  |_| |___|_| |___|___|_|
                  |___|                    |___|
    Arago Project http://arago-project.org k2hk-evm ttyS0
    Arago 2019.11 k2hk-evm ttyS0
    k2hk-evm login:
    #>>>>> LCD 12
    IP Address:
    158.218.117.18
    root
    root@k2hk-evm:~# uname -a
    Linux k2hk-evm 4.19.94-ge9a2c0b99b #1 SMP PREEMPT Thu Feb 6 03:33:41 UTC 2020 armv7l GNU/Linux
    root@k2hk-evm:~#
    Rex
  • Hi Rex,
    You don't do the same thing as I did.
    You run kexec from a booted Linux.
    What I did is booting Linux from u-boot and the crash of kernel thread appears when the kernel starts. See the log I posted.
    I used pre-built binaries with some modifications I described in previous post.
    dr.
  • Hi, dr,
    So the crash is caused by your modification.  It seems to me that there is some illegal address accessed as I previously indicated. It will need to debug or code review to see where it could cause the crash.
    Rex
  • Hi Rex,
    What do you mean with "It will need to debug or code review to see where it could cause the crash." ? Who will do that ? TI or me ?
    To be more precise, I only tried to setup kdump service.
    With prebuilt image and filesystem it does not start correctly and I had to modified kdump.conf and copy missing makedumpfile executable.
    All that is in user space, and not in kernel, so why does this make a kernel thread crash ?
    The kernel is the pre-built one from TI not some kernel compiled by myself.
    Did you reproduce the crash ?
    Can you say how to configure that kdump service ?
    DR.
    Any news about this ?
    A simple "kexec -p /zImage" command should reproduce the pb.
    DR.
  • Hi, DR,
    Sorry for the slow response. No, I have had time to look at the issue. I tried with your '-p' option, but it gave me error saying memory not reserved. I modified the cmdline to reserve 512M for crashkernel, but same error. How did you get "kexe -p /zImage" to execute?
    TI system test tested the kexec using "kexec -l /zImage; kexec -e" command.
    Rex
    Here is a complete log file.
    This is done with pre-built binaries and filesystem.
    So check that your kernel is the same as the one I use.
    EVM is booted via TFTP/NFS.
    kexec -l + kexec -e works correctly for me too.
    We use kexec -p because we want this capture kernel to be executed when the system kernel panics.
    Best regards.
    Didier.
    U-Boot 2019.01-g333c3e72d3 (Apr 19 2020 - 06:33:45 +0000)
    CPU: 66AK2Hx SR2.0
    Model: Texas Instruments Keystone 2 Kepler/Hawking EVM
    DRAM:  DDR3A Speed will be configured for 1600 Operation.
    Detected SO-DIMM [78.B2GCT.4010C    ]
    DDR3 speed 1600
    DRAM: 4 GiB (includes reported below)
    Clear entire DDR3 memory to enable ECC
    2 GiB
    NAND:  512 MiB
    Loading Environment from NAND... OK
    Net:   eth0: netcp@2000000
    Warning: netcp@slave-1 (eth1) using random MAC address - 46:8e:bf:23:42:51
    , eth1: netcp@slave-1
    Warning: netcp@slave-2 (eth2) using random MAC address - 92:90:f6:7f:10:41
    , eth2: netcp@slave-2
    Warning: netcp@slave-3 (eth3) using random MAC address - 62:be:08:7d:7e:21
    , eth3: netcp@slave-3
    Hit any key to stop autoboot: 10  9  8  0
    => setenv tftp_root /opt/tftpboot/k2hk ; setenv serverip 192.169.0.1; setenv ipaddr 192.169.2.1; setenv netmask 255.255.0.0;setenv gatewayip
    => setenv name_mon skern-k2hk.bin ; setenv name_kern zImage-k2hk-evm.bin ; setenv name_fw_rd k2-fw-initrd.cpio.gz ; setenv name_fdt keystone-k2hk-evm.dtb
    => setenv boot net ; setenv nfs_root /opt/export/k2hk ; run init_${boot}; run get_mon_${boot} run_mon; run get_kern_${boot}; run init_fw_rd_${boot}; run get_fdt_${boot}; setenv bootargs "${bootargs} crashkernel=128M" ; run run_kern
    netcp@2000000 Waiting for SGMII auto negotiation to complete. done
    BOOTP broadcast 1
    DHCP client bound to address 192.169.1.1 (51 ms)
    Using netcp@2000000 device
    TFTP from server 192.169.0.1; our IP address is 192.169.1.1
    Filename '/opt/tftpboot/k2hk/skern-k2hk.bin'.
    Load address: 0x87000000
    Loading: *#######
    	 1.7 MiB/s
    done
    Bytes transferred = 32832 (8040 hex)
    K2_BM_15.07-53-ge1f885a SoC:k2hk built:04:33:22, Apr 19 2020
    ## installed monitor @ 0xc5f0000, freq [200000000], status 207552512
    BOOTP broadcast 1
    DHCP client bound to address 192.169.1.1 (3 ms)
    Filename '/opt/tftpboot/k2hk/zImage-k2hk-evm.bin'.
    Load address: 0x82000000
    Loading: *#################################################################
    	 2.1 MiB/s
    done
    Bytes transferred = 4346368 (425200 hex)
    BOOTP broadcast 1
    DHCP client bound to address 192.169.1.1 (2 ms)
    Filename '/opt/tftpboot/k2hk/k2-fw-initrd.cpio.gz'.
    Load address: 0x88080000
    	 1.8 MiB/s
    done
    Bytes transferred = 50364 (c4bc hex)
    BOOTP broadcast 1
    Filename '/opt/tftpboot/k2hk/keystone-k2hk-evm.dtb'.
    Load address: 0x88000000
    Loading: *########
    	 1.8 MiB/s
    done
    Bytes transferred = 39532 (9a6c hex)
       Loading Ramdisk to 8fff3000, end 8ffff4bc ... OK
       Loading Device Tree to 8ffe6000, end 8fff2a6b ... OK
    Starting kernel ...
    [    0.000000] Linux version 4.19.94-gbe5389fd85 (oe-user@oe-host) (gcc version 8.3.0 (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36))) #1 SMP PREEMPT Sun Apr 19 02:59:01 UTC 2020
    [    0.000000] Reserving 128MB of memory at 33024MB for crashkernel (System RAM: 512MB)
    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 883584
    [    0.000000] Kernel command line: console=ttyS0,115200n8 rootwait=1 mtdparts=spi0.0:1m(u-boot-spl)ro,-(misc) rootfstype=nfs root=/dev/nfs rw nfsroot=192.169.0.1:/opt/export/k2hk,v3,tcp,rsize=4096,wsize=4096 ip=dhcp crashkernel=128M
    [    0.000000] Memory: 3326168K/3538944K available (10240K kernel code, 289K rwdata, 2728K rodata, 2048K init, 266K bss, 180008K reserved, 32768K cma-reserved, 2990080K highmem)
    [    0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
    [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
    [    0.000003] sched_clock: 56 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
    [    0.000012] Switching to timer-based delay loop, resolution 5ns
    [    0.000194] keystone timer clock @200000000 Hz
    [    0.000358] Console: colour dummy device 80x30
    [    0.000396] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=2000000)
    [    0.000407] pid_max: default: 32768 minimum: 301
    [    0.000496] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
    [    0.000506] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
    [    0.000968] CPU: Testing write buffer coherency: ok
    [    0.000991] CPU0: Spectre v2: firmware did not set auxiliary control register IBE bit, system vulnerable
    [    0.001188] /cpus/cpu@0 missing clock-frequency property
    [    0.001210] /cpus/cpu@1 missing clock-frequency property
    [    0.001232] /cpus/cpu@2 missing clock-frequency property
    [    0.001253] /cpus/cpu@3 missing clock-frequency property
    [    0.001262] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
    [    0.060015] Setting up static identity map for 0x80200000 - 0x80200138
    [    0.080017] rcu: Hierarchical SRCU implementation.
    [    0.100159] EFI services will not be available.
    [    0.120061] smp: Bringing up secondary CPUs ...
    [    0.204587] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
    [    0.204593] CPU1: Spectre v2: firmware did not set auxiliary control register IBE bit, system vulnerable
    [    0.284684] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
    [    0.284689] CPU2: Spectre v2: firmware did not set auxiliary control register IBE bit, system vulnerable
    [    0.364777] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
    [    0.364784] CPU3: Spectre v2: firmware did not set auxiliary control register IBE bit, system vulnerable
    [    0.364917] smp: Brought up 1 node, 4 CPUs
    [    0.364928] SMP: Total of 4 processors activated (1600.00 BogoMIPS).
    [    0.364935] CPU: All CPU(s) started in HYP mode.
    [    0.364940] CPU: Virtualization extensions available.
    [    0.365376] devtmpfs: initialized
    [    0.371242] VFP support v0.3: implementor 41 architecture 4 part 30 variant f rev 0
    [    0.371446] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
    [    0.371460] futex hash table entries: 1024 (order: 4, 65536 bytes)
    [    0.371911] pinctrl core: initialized pinctrl subsystem
    [    0.372267] DMI not present or invalid.
    [    0.372470] NET: Registered protocol family 16
    [    0.373295] DMA: preallocated 256 KiB pool for atomic coherent allocations
    [    0.373973] cpuidle: using governor ladder
    [    0.374001] cpuidle: using governor menu
    [    0.374124] No ATAGs?
    [    0.374213] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
    [    0.374223] hw-breakpoint: maximum watchpoint size is 8 bytes.
    [    0.389938] SCSI subsystem initialized
    [    0.390880] media: Linux media interface: v0.10
    [    0.390909] videodev: Linux video capture interface: v2.00
    [    0.390965] pps_core: LinuxPPS API ver. 1 registered
    [    0.390972] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [    0.390987] PTP clock support registered
    [    0.391014] EDAC MC: Ver: 3.0.0
    [    0.391474] Advanced Linux Sound Architecture Driver Initialized.
    [    0.392054] clocksource: Switched to clocksource arch_sys_counter
    [    0.397486] NET: Registered protocol family 2
    [    0.397862] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes)
    [    0.397882] TCP established hash table entries: 4096 (order: 2, 16384 bytes)
    [    0.397911] TCP bind hash table entries: 4096 (order: 3, 32768 bytes)
    [    0.397960] TCP: Hash tables configured (established 4096 bind 4096)
    [    0.398016] UDP hash table entries: 256 (order: 1, 8192 bytes)
    [    0.398034] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
    [    0.398173] NET: Registered protocol family 1
    [    0.418492] RPC: Registered named UNIX socket transport module.
    [    0.418500] RPC: Registered udp transport module.
    [    0.418506] RPC: Registered tcp transport module.
    [    0.418512] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    0.418642] Trying to unpack rootfs image as initramfs...
    [    0.421195] Freeing initrd memory: 52K
    [    0.421405] hw perfevents: no interrupt-affinity property for /pmu, guessing.
    [    0.421650] hw perfevents: enabled with armv7_cortex_a15 PMU driver, 7 counters available
    [    0.422038] platform alarmtimer: set dma_pfn_offset00780000
    [    0.422567] Initialise system trusted keyrings
    [    0.422666] workingset: timestamp_bits=14 max_order=20 bucket_order=6
    [    0.426385] squashfs: version 4.0 (2009/01/31) Phillip Lougher
    [    0.426746] NFS: Registering the id_resolver key type
    [    0.426761] Key type id_resolver registered
    [    0.426767] Key type id_legacy registered
    [    0.426796] ntfs: driver 2.1.32 [Flags: R/O].
    [    0.428062] Key type asymmetric registered
    [    0.428071] Asymmetric key parser 'x509' registered
    [    0.428108] bounce: pool size: 64 pages
    [    0.428132] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
    [    0.428140] io scheduler noop registered
    [    0.428147] io scheduler deadline registered
    [    0.428219] io scheduler cfq registered (default)
    [    0.428227] io scheduler mq-deadline registered
    [    0.428234] io scheduler kyber registered
    [    0.428512] keystone_irq 26202a0.keystone_irq: irqchip registered, nr_irqs 28
    [    0.429187] ti,keystone-serdes 232a000.phy: init fw ks2_gbe_serdes.bin: version 3.3.0.2c
    [    0.433568] keystone-navigator-qmss soc@0:qmss@2a40000: qmgr start queue 0, number of queues 8192
    [    0.433694] keystone-navigator-qmss soc@0:qmss@2a40000: added qmgr start queue 0, num of queues 8192, reg_peek (ptrval), reg_status (ptrval), reg_config (ptrval), reg_region (ptrval), reg_push (ptrval), reg_pop (ptrval)
    [    0.433706] keystone-navigator-qmss soc@0:qmss@2a40000: qmgr start queue 8192, number of queues 8192
    [    0.433816] keystone-navigator-qmss soc@0:qmss@2a40000: added qmgr start queue 8192, num of queues 8192, reg_peek (ptrval), reg_status (ptrval), reg_config (ptrval), reg_region (ptrval), reg_push (ptrval), reg_pop (ptrval)
    [    0.433962] keystone-navigator-qmss soc@0:qmss@2a40000: firmware file ks2_qmss_pdsp_acc48.bin downloaded for PDSP
    [    0.436282] keystone-navigator-dma soc@0:knav_dmas@0: DMA dma_gbe registered 41 logical channels, flows 32, tx chans: 9, rx chans: 24
    [    0.469800] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
    [    0.469861] platform serial8250: set dma_pfn_offset00780000
    [    0.472440] console [ttyS0] disabled
    [    0.472485] 2530c00.serial: ttyS0 at MMIO 0x2530c00 (irq = 27, base_baud = 12500000) is a TI DA8xx/66AK2x
    [    1.366296] console [ttyS0] enabled
    [    1.370488] 2531000.serial: ttyS1 at MMIO 0x2531000 (irq = 28, base_baud = 12500000) is a TI DA8xx/66AK2x
    [    1.388337] brd: module loaded
    [    1.397015] loop: module loaded
    [    1.401885] spi_davinci 21000400.spi: DMA is not supported (-19)
    [    1.408632] m25p80 spi0.0: n25q128a11 (16384 Kbytes)
    [    1.413660] 2 cmdlinepart partitions found on MTD device spi0.0
    [    1.419601] Creating 2 MTD partitions on "spi0.0":
    [    1.424431] 0x000000000000-0x000000100000 : "u-boot-spl"
    [    1.430294] 0x000000100000-0x000001000000 : "misc"
    [    1.435680] spi_davinci 21000400.spi: Controller at 0x(ptrval)
    [    1.441785] spi_davinci 21000600.spi: DMA is not supported (-19)
    [    1.448099] spi_davinci 21000600.spi: Controller at 0x(ptrval)
    [    1.454193] spi_davinci 21000800.spi: DMA is not supported (-19)
    [    1.460482] spi_davinci 21000800.spi: Controller at 0x(ptrval)
    [    1.466593] platform Fixed MDIO bus.0: set dma_pfn_offset00780000
    [    1.472864] libphy: Fixed MDIO Bus: probed
    [    1.532078] davinci_mdio 2090300.mdio: davinci mdio revision 1.5, bus freq 2500000
    [    1.539676] libphy: 2090300.mdio: probed
    [    1.545106] davinci_mdio 2090300.mdio: phy[0]: device 2090300.mdio:00, driver Marvell 88E1111
    [    1.553682] davinci_mdio 2090300.mdio: phy[1]: device 2090300.mdio:01, driver Marvell 88E1111
    [    1.562740] ti,keystone-serdes 232a000.phy: Requested PHY is disabled
    [    2.080043] ti,keystone-serdes 232a000.phy: Requested PHY is disabled
    [    2.599604] netcp-1.0 2620110.netcp: initialized cpsw ale version 1.3
    [    2.606086] netcp-1.0 2620110.netcp: ALE Table size 1024
    [    2.611436] netcp-1.0 2620110.netcp: cpts: overflow check period 350 (jiffies)
    [    2.618704] netcp-1.0 2620110.netcp: CPTS: ref_clk_freq:600000000 calc_mult:3579139413 calc_shift:31 error:-1 nsec/sec
    [    2.630125] netcp-1.0 2620110.netcp: module(netcp-xgbe) not used for device
    [    2.637305] i2c /dev entries driver
    [    2.642255] sdhci: Secure Digital Host Controller Interface driver
    [    2.648456] sdhci: Copyright(c) Pierre Ossman
    [    2.653064] sdhci-pltfm: SDHCI platform and OF driver helper
    [    2.659667] ledtrig-cpu: registered to indicate activity on CPUs
    [    2.667174] nand: device found, Manufacturer ID: 0x2c, Chip ID: 0xac
    [    2.673571] nand: Micron MT29F4G08ABBDAHC
    [    2.677594] nand: 512 MiB, SLC, erase size: 128 KiB, page size: 2048, OOB size: 64
    [    2.685480] Bad block table found at page 262080, version 0x01
    [    2.691812] Bad block table found at page 262016, version 0x01
    [    2.697921] nand_read_bbt: bad block at 0x000000c80000
    [    2.703089] nand_read_bbt: bad block at 0x000000ca0000
    [    2.708303] 3 fixed-partitions partitions found on MTD device 30000000.nand
    [    2.715302] Creating 3 MTD partitions on "30000000.nand":
    [    2.720720] 0x000000000000-0x000000100000 : "u-boot"
    [    2.726290] 0x000000100000-0x000000180000 : "params"
    [    2.731789] 0x000000180000-0x000020000000 : "ubifs"
    [    2.740398] davinci_nand 30000000.nand: controller rev. 2.5
    [    2.746486] platform snd-soc-dummy: set dma_pfn_offset00780000
    [    2.753187] NET: Registered protocol family 10
    [    2.758380] Segment Routing with IPv6
    [    2.762120] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
    [    2.768422] NET: Registered protocol family 17
    [    2.772998] Key type dns_resolver registered
    [    2.777415] Registering SWP/SWPB emulation handler
    [    2.782602] Loading compiled-in X.509 certificates
    [    2.792609] hctosys: unable to open rtc device (rtc0)
    [    3.002531] netcp-1.0 2620110.netcp eth0: Link is Down
    [    3.009702] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
    [    3.132056] (NULL net_device): Link is Down
    [    3.136253] (NULL net_device): Link is Down
    [    3.222522] netcp-1.0 2620110.netcp eth1: Link is Down
    [    3.228465] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
    [    6.233150] netcp-1.0 2620110.netcp eth0: Link is Up - 1Gbps/Full - flow control rx/tx
    [    6.262084] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
    [    6.292140] Sending DHCP requests ., OK
    [    6.335937] IP-Config: Got DHCP answer from 192.169.0.1, my address is 192.169.1.1
    [    6.343552] IP-Config: Complete:
    [    6.346791]      device=eth0, hwaddr=b4:99:4c:b3:78:15, ipaddr=192.169.1.1, mask=255.255.0.0, gw=255.255.255.255
    [    6.357019]      host=EVM1, domain=private.net, nis-domain=(none)
    [    6.363147]      bootserver=192.169.0.1, rootserver=192.169.0.1, rootpath=
    [    6.363150]      nameserver0=192.169.0.1
    [    6.385905] ALSA device list:
    [    6.388882]   No soundcards found.
    [    6.474863] VFS: Mounted root (nfs filesystem) on device 0:14.
    [    6.480891] devtmpfs: mounted
    [    6.484856] Freeing unused kernel memory: 2048K
    [    6.489513] Run /sbin/init as init process
    [    6.500604] random: fast init done
    [    6.597945] systemd[1]: System time before build time, advancing clock.
    [    6.617516] systemd[1]: systemd 239 running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR +SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN2 -IDN -PCRE2 default-hierarchy=hybrid)
    [    6.639220] systemd[1]: Detected architecture arm.
    [    6.682787] systemd[1]: Set hostname to <k2hk-evm>.
    [    6.819436] systemd[1]: File /lib/systemd/system/systemd-journald.service:36 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
    [    6.836570] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
    [    7.053791] random: systemd: uninitialized urandom read (16 bytes read)
    [    7.063213] systemd[1]: Created slice system-getty.slice.
    [    7.102153] random: systemd: uninitialized urandom read (16 bytes read)
    [    7.108977] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
    [    7.152140] random: systemd: uninitialized urandom read (16 bytes read)
    [    7.158957] systemd[1]: Listening on initctl Compatibility Named Pipe.
    [    7.212550] systemd[1]: Listening on Process Core Dump Socket.
    [    7.253062] systemd[1]: Listening on Journal Socket (/dev/log).
    [    7.752952] cmemk: loading out-of-tree module taints kernel.
    [    7.759541] CMEMK module: reference Linux version 4.19.94
    [    7.765354] allocated heap buffer 0xc100000 of size 0x480000
    [    7.771085] cmemk initialized
    [    7.788281] cryptodev: driver 1.9 loaded.
    [    7.802277] NET: Registered protocol family 45
    [    7.871514] random: crng init done
    [    7.875200] random: 7 urandom warning(s) missed due to ratelimiting
    [    8.370159] systemd-journald[109]: Received request to flush runtime journal from PID 1
    [    8.594464] keystone-rproc 10800000.dsp: assigned reserved memory node dsp-common-memory@81f800000
    [  OK      8.605407] remoteproc remoteproc0: 10800000.dsp is available
    m] Mounted /media/ram.
    [    8.633722] davinci-wdt 22f0080.wdt: heartbeat 60 sec
    [    8.639188] keystone-rproc 11800000.dsp: assigned reserved memory node dsp-common-memory@81f800000
    [    8.648394] remoteproc remoteproc1: 11800000.dsp is available
    [  OK  ] Mounted /var/[    8.656706] keystone-rproc 12800000.dsp: assigned reserved memory node dsp-common-memory@81f800000
    volatile.
    [    8.667079] remoteproc remoteproc2: 12800000.dsp is available
    [    8.681784] keystone-rproc 13800000.dsp: assigned reserved memory node dsp-common-memory@81f800000
    [    8.692040] remoteproc remoteproc3: 13800000.dsp is available
    [    8.703292] keystone-rproc 14800000.dsp: assigned reserved memory node dsp-common-memory@81f800000
    [    8.714024] remoteproc remoteproc4: 14800000.dsp is available
    [    8.723512] keystone-rproc 15800000.dsp: assigned reserved memory node dsp-common-memory@81f800000
    [    8.733403] remoteproc remoteproc5: 15800000.dsp is available
    [    8.743211] keystone-rproc 16800000.dsp: assigned reserved memory node dsp-common-memory@81f800000
    [    8.752645] remoteproc remoteproc6: 16800000.dsp is available
    [    8.761184] keystone-rproc 17800000.dsp: assigned reserved memory node dsp-common-memory@81f800000
    [    8.770774] remoteproc remoteproc7: 17800000.dsp is available
    [    8.873663] at24 0-0050: 131072 byte 24c1024 EEPROM, writable, 1 bytes/write
    [    8.908116] keystone-usbphy 2620738.usb_phy: 2620738.usb_phy supply vcc not found, using dummy regulator
    [    8.919779] keystone-usbphy 2620738.usb_phy: Linked as a consumer to regulator.0
    [   10.020326] dwc3 2690000.dwc3: Failed to get clk 'ref': -2
    [   10.026416] platform xhci-hcd.0.auto: set dma_pfn_offset00780000
    [   10.055102] usbcore: registered new interface driver usbfs
    [   10.061140] usbcore: registered new interface driver hub
    [   10.067446] usbcore: registered new device driver usb
    [   10.084052] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
    [   10.089612] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
    [   10.099010] xhci-hcd xhci-hcd.0.auto: hcc params 0x0298f06d hci version 0x100 quirks 0x0000000002010010
    [   10.108514] xhci-hcd xhci-hcd.0.auto: irq 35, io mem 0x02690000
    [   10.114832] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
    [   10.123149] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [   10.130399] usb usb1: Product: xHCI Host Controller
    [   10.135319] usb usb1: Manufacturer: Linux 4.19.94-gbe5389fd85 xhci-hcd
    [   10.141871] usb usb1: SerialNumber: xhci-hcd.0.auto
    [   10.147204] hub 1-0:1.0: USB hub found
    [   10.150997] hub 1-0:1.0: 1 port detected
    [   10.155301] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
    [   10.160815] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
    [   10.168534] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
    [   10.175164] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
    [   10.183412] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 4.19
    [   10.191710] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [   10.198980] usb usb2: Product: xHCI Host Controller
    [   10.203892] usb usb2: Manufacturer: Linux 4.19.94-gbe5389fd85 xhci-hcd
    [   10.210442] usb usb2: SerialNumber: xhci-hcd.0.auto
    [   10.215759] hub 2-0:1.0: USB hub found
    [   10.219544] hub 2-0:1.0: 1 port detected
    [  OK  ] Started System Logger Daemon "default" instance.
             Starting Simple Network[   15.230181] registered dspmem misc device
    [  OK  ] Started syslog.service.
             Starting gdbserverproxy.service...
    [   15.550478] NET: Registered protocol family 15
    [   15.656478] Initializing XFRM netlink socket
    [  OK  ] Started gdbserverproxy.service.
             Starting thermal-zone-init.service...
             Starting parse-ip.service...
    [  OK  ] Started thermal-zone-init.service.
    #>>>>> LCD 12
    IP Address:
    192.169.1.1
    	autoconf
    	bash-dev
    	bash
    	bc
    	binutils-dev
    	binutils
    	bison-dev
    	bison
    	cifs-utils
    	cpio
    	cpp-symlinks
    	cpp
    	dosfstools
    	elfutils-dev
    	elfutils
    	g++-symlinks
    	g++
    	gawk
    	gcc-symlinks
    	gcc
    	gdb
    	gdbc6x
    	gdbserver
    	gettext
    	gstreamer1.0-libav
    	gzip
    	hidapi
    	libasm1
    	libbfd
    	libcairo-perf-utils
    	libdw1
    	libelf1
    	libgdbm-compat4
    	libgdbm-dev
    	libgdbm6
    	libgettextlib
    	libgettextsrc
    	libgmp10
    	libidn2-0
    	libmpc3
    	libmpfr6
    	libreadline-dev
    	libreadline7
    	libunistring2
    	m4-dev
    	m4
    	make
    	nettle
    	swig-dev
    	swig
    	which
    [  OK  ] Started parse-ip.service.
    [  OK  ] Reached target Multi-User System.
             Starting Update UTMP about System Runlevel Changes...
    [  OK  ] Started Update UTMP about System Runlevel Changes.
     _____                    _____           _         _
    [   21.331281] remoteproc remoteproc0: powering up 10800000.dsp
    |__|__|_| |__,|_[   21.338223] remoteproc remoteproc0: Booting unspecified pre-loaded fw image
      |___|  |__|  |_| |___|_| |___|[   21.349190] remoteproc remoteproc0: registered virtio0 (type 7)
    ___|_|
          [   21.356231] remoteproc remoteproc0: remote processor 10800000.dsp is now up
            |___|                    |___|          [   21.366962] virtio_rpmsg_bus virtio0: rpmsg host is online
    Arago Proj[   21.367040] virtio_rpmsg_bus virtio0: creating channel rpmsg-proto addr 0x3d
    [   21.393068] remoteproc remoteproc1: powering up 11800000.dsp
    [   21.398822] remoteproc remoteproc1: Booting unspecified pre-loaded fw image
    [   21.407924] virtio_rpmsg_bus virtio1: rpmsg host is online
    [   21.413552] virtio_rpmsg_bus virtio1: creating channel rpmsg-proto addr 0x3d
    k2hk-evm[   21.420909] remoteproc remoteproc1: registered virtio1 (type 7)
     login: [   21.427395] remoteproc remoteproc1: remote processor 11800000.dsp is now up
    [   21.456217] remoteproc remoteproc2: powering up 12800000.dsp
    [   21.461903] remoteproc remoteproc2: Booting unspecified pre-loaded fw image
    [   21.471346] virtio_rpmsg_bus virtio2: rpmsg host is online
    [   21.471597] virtio_rpmsg_bus virtio2: creating channel rpmsg-proto addr 0x3d
    [   21.477483] remoteproc remoteproc2: registered virtio2 (type 7)
    [   21.490435] remoteproc remoteproc2: remote processor 12800000.dsp is now up
    [   21.518577] remoteproc remoteproc3: powering up 13800000.dsp
    [   21.524289] remoteproc remoteproc3: Booting unspecified pre-loaded fw image
    [   21.533635] virtio_rpmsg_bus virtio3: rpmsg host is online
    [   21.533769] virtio_rpmsg_bus virtio3: creating channel rpmsg-proto addr 0x3d
    [   21.539230] remoteproc remoteproc3: registered virtio3 (type 7)
    [   21.552464] remoteproc remoteproc3: remote processor 13800000.dsp is now up
    [   21.580836] remoteproc remoteproc4: powering up 14800000.dsp
    [   21.586543] remoteproc remoteproc4: Booting unspecified pre-loaded fw image
    [   21.596417] virtio_rpmsg_bus virtio4: rpmsg host is online
    [   21.596563] virtio_rpmsg_bus virtio4: creating channel rpmsg-proto addr 0x3d
    [   21.601996] remoteproc remoteproc4: registered virtio4 (type 7)
    [   21.615242] remoteproc remoteproc4: remote processor 14800000.dsp is now up
    [   21.645456] remoteproc remoteproc5: powering up 15800000.dsp
    [   21.651146] remoteproc remoteproc5: Booting unspecified pre-loaded fw image
    [   21.661257] virtio_rpmsg_bus virtio5: rpmsg host is online
    [   21.661422] virtio_rpmsg_bus virtio5: creating channel rpmsg-proto addr 0x3d
    [   21.668296] remoteproc remoteproc5: registered virtio5 (type 7)
    [   21.679952] remoteproc remoteproc5: remote processor 15800000.dsp is now up
    [   21.708890] remoteproc remoteproc6: powering up 16800000.dsp
    [   21.714678] remoteproc remoteproc6: Booting unspecified pre-loaded fw image
    [   21.725200] virtio_rpmsg_bus virtio6: rpmsg host is online
    [   21.725351] virtio_rpmsg_bus virtio6: creating channel rpmsg-proto addr 0x3d
    [   21.730826] remoteproc remoteproc6: registered virtio6 (type 7)
    [   21.743917] remoteproc remoteproc6: remote processor 16800000.dsp is now up
    [   21.773037] remoteproc remoteproc7: powering up 17800000.dsp
    [   21.778722] remoteproc remoteproc7: Booting unspecified pre-loaded fw image
    [   21.790591] virtio_rpmsg_bus virtio7: rpmsg host is online
    [   21.790764] virtio_rpmsg_bus virtio7: creating channel rpmsg-proto addr 0x3d
    [   21.804051] remoteproc remoteproc7: registered virtio7 (type 7)
    [   21.810457] remoteproc remoteproc7: remote processor 17800000.dsp is now up
     _____                    _____           _         _
                  |___|                    |___|
    k2hk-evm login: root
    r^[[42;173Rroot@k2hk-evm:~# 2;173Root
    -sh: 2: command not found
    -sh: 173Root: command not found
    root@k2hk-evm:~#
    root@k2hk-evm:~#
    root@k2hk-evm:~#
    Linux k2hk-evm 4.19.94-gbe5389fd85 #1 SMP PREEMPT Sun Apr 19 02:59:01 UTC 2020 armv7l GNU/Linux
    root@k2hk-evm:~# cat /proc/cmdline
    root@k2hk-evm:~# ls /
    bin      etc      init     linuxrc  opt      sbin     tmp      www
    boot     home     ipaddr   media    proc     srv      usr
    dev      include  lib      mnt      run      sys      var
    root@k2hk-evm:~# ls /boot
    k2-fw-initrd.cpio.gz         vmlinux-4.19.94-gbe5389fd85
    keystone-k2hk-evm.dtb        zImage
    skern-k2hk.bin               zImage-4.19.94-gbe5389fd85
    root@k2hk-evm:~# kexec -p /boot/zImage
    [   80.147427] Unhandled fault: asynchronous external abort (0x211) at 0x00000000
    [   80.154704] pgd = 260426fe
    [   80.157419] [00000000] *pgd=81a8af003, *pmd=8fc8dc003
    [   80.162503] Internal error: : 211 [#1] PREEMPT SMP ARM
    [   80.167660] Modules linked in: virtio_rpmsg_bus xfrm_user xfrm4_tunnel ipcomp xfrm_ipcomp esp4 ah4 af_key xfrm_algo keystone_dsp_mem xhci_plat_hcd xhci_hcd usbcore dwc3 udc_core usb_common phy_keystone phy_generic dwc3_keystone at24 davinci_wdt keystone_remoteproc sch_fq_codel uio_module_drv(O) uio rpmsg_proto remoteproc gdbserverproxy(O) cryptodev(O) cmemk(O)
    [   80.199745] CPU: 0 PID: 814 Comm: kexec Tainted: G           O      4.19.94-gbe5389fd85 #1
    [   80.208042] Hardware name: Keystone
    [   80.211555] PC is at memcpy+0x48/0x330
    [   80.215317] LR is at 0x29726964
    [   80.218466] pc : [<c09f0168>]    lr : [<29726964>]    psr: 200d0013
    [   80.224754] sp : da431efc  ip : 5f67705f  fp : da431f2c
    [   80.229995] r10: c12701e0  r9 : 00000000  r8 : 72657070
    [   80.235236] r7 : 61777328  r6 : 4c4f424d  r5 : 59530a34  r4 : 31653430
    [   80.241786] r3 : 3231633d  r2 : 00000527  r1 : dcdbc080  r0 : e592d080
    [   80.248338] Flags: nzCv  IRQs on  FIQs on  Mode SVC_32  ISA ARM  Segment user
    [   80.255499] Control: 30c5387d  Table: 1a9f2940  DAC: fffffffd
    [   80.261266] Process kexec (pid: 814, stack limit = 0x528850f4)
    [   80.267121] Stack: (0xda431efc to 0xda432000)
    [   80.271494] 1ee0:        e592d000
    [   80.279703] 1f00: 00280001 00000000 dbf40e20 e592d000 c12701d0 c02b35dc c1204c48 dbf40e00
    [   80.287911] 1f20: da431f54 da431f30 c02b44e4 c02b35c0 0000061f 00c00000 cb635024 0879468c
    [   80.296119] 1f40: dbf40e00 00000003 da431fa4 da431f58 c02b5124 c02b4454 90000000 00000000
    [   80.304328] 1f60: 97ffffff 00000000 c0201204 00000001 00000030 fffffff8 da430000 00000000
    [   80.312536] 1f80: bec719e0 bec719cc 0000015b c0201204 da430000 0000015b 00000000 da431fa8
    [   80.320743] 1fa0: c0201000 c02b4fb0 00000000 bec719e0 90008000 00000003 00058ed0 00280001
    [   80.328952] 1fc0: 00000000 bec719e0 bec719cc 0000015b 00000003 00000000 00000003 00034298
    [   80.337159] 1fe0: bec71930 bec71920 000134f1 b6edc1b0 600d0010 90008000 00000000 00000000
    [   80.345364] Backtrace:
    [   80.347834] [<c02b35b4>] (crash_update_vmcoreinfo_safecopy) from [<c02b44e4>] (kimage_crash_copy_vmcoreinfo+0x9c/0xd0)
    [   80.358571]  r5:dbf40e00 r4:c1204c48
    [   80.362160] [<c02b4448>] (kimage_crash_copy_vmcoreinfo) from [<c02b5124>] (sys_kexec_load+0x180/0x434)
    [   80.371500]  r5:00000003 r4:dbf40e00
    [   80.375095] [<c02b4fa4>] (sys_kexec_load) from [<c0201000>] (ret_fast_syscall+0x0/0x4c)
    [   80.383127] Exception stack(0xda431fa8 to 0xda431ff0)
    [   80.388196] 1fa0:                   00000000 bec719e0 90008000 00000003 00058ed0 00280001
    [   80.396404] 1fc0: 00000000 bec719e0 bec719cc 0000015b 00000003 00000000 00000003 00034298
    [   80.404611] 1fe0: bec71930 bec71920 000134f1 b6edc1b0
    [   80.409680]  r10:0000015b r9:da430000 r8:c0201204 r7:0000015b r6:bec719cc r5:bec719e0
    [   80.417537]  r4:00000000
    [   80.420078] Code: ba000002 f5d1f03c f5d1f05c f5d1f07c (e8b151f8)
    [   80.426199] ---[ end trace d213ebdde3c05fb2 ]---
    [   80.433741] Unhandled fault: asynchronous external abort (0x211) at 0x00000000
    [   80.441003] pgd = 4934c2d5
    [   80.441009] [00000000] *pgd=81a496003, *pmd=8fc887003
    2020 Apr 19 02:43:03 k2hk-evm [   80.147427] Unhandled fault: asynchronous external abort (0x211) at 0x00000000
    2020 Apr 19 02:43:03 k2hk-evm [   80.154704] pgd = 260426fe
    2020 Apr 19 02:43:03 k2hk-evm [   80.157419] [00000000] *pgd=81a8af003, *pmd=8fc8dc003
    2020 Apr 19 02:43:03 k2hk-evm [   80.162503] Internal error: : 211 [#1] PREEMPT SMP ARM
    2020 Apr 19 02:43:03 k2hk-evm [   80.261266] Process kexec (pid: 814, stack limit = 0x528850f4)
    2020 Apr 19 02:43:03 k2hk-evm [   80.267121] Stack: (0xda431efc to 0xda432000)
    2020 Apr 19 02:43:03 k2hk-evm [   80.271494] 1ee0:        e592d000
    2020 Apr 19 02:43:03 k2hk-evm [   80.279703] 1f00: 00280001 00000000 dbf40e20 e592d000 c12701d0 c02b35dc c1204c48 dbf40e00
    2020 Apr 19 02:43:03 k2hk-evm [   80.287911] 1f20: da431f54 da431f30 c02b44e4 c02b35c0 0000061f 00c00000 cb635024 0879468c
    2020 Apr 19 02:43:03 k2hk-evm [   80.296119] 1f40: dbf40e00 00000003 da431fa4 da431f58 c02b5124 c02b4454 90000000 00000000
    2020 Apr 19 02:43:03 k2hk-evm [   80.304328] 1f60: 97ffffff 00000000 c0201204 00000001 00000030 fffffff8 da430000 00000000
    2020 Apr 19 02:43:03 k2hk-evm [   80.312536] 1f80: bec719e0 bec719cc 0000015b c0201204 da430000 0000015b 00000000 da431fa8
    2020 Apr 19 02:43:03 k2hk-evm [   80.320743] 1fa0: c0201000 c02b4fb0 00000000 bec719e0 90008000 00000003 00058ed0 00280001
    2020 Apr 19 02:43:03 k2hk-evm [   80.328952] 1fc0: 00000000 bec719e0 bec719cc 0000015b 00000003 00000000 00000003 00034298
    2020 Apr 19 02:43:03 k2hk-evm [   80.337159] 1fe0: bec71930 bec71920 000134f1 b6edc1b0 600d0010 90008000 00000000 00000000
    2020 Apr 19 02:43:03 k2hk-evm [   80.420078] Code: ba000002 f5d1f03c f5d1f05c f5d1f07c (e8b151f8)
    2020 Apr 19 02:43:03 k2hk-evm [   80.433741] Unhandled fault: asynchronous external abort (0x211) at 0x00000000
    2020 Apr 19 02:43:03 k2hk-evm [   80.441003] pgd = 4934c2d5
    2020 Apr 19 02:43:03 k2hk-evm [   80.441009] [00000000] *pgd=81a496003, *pmd=8fc887003
    2020 Apr 19 02:43:03 k2hk-evm Unhandled fault: asynchronous exter202020 Apr 19 02:42020 Apr 19 02:43:03 k2hk-evm Stack: (0xda431efc to 0xda432000)
    2020 Apr 19 02:43:03 k2hk-evm 1ee0:        e592d000
    2020 Apr 19 02:43:03 k2hk-evm 1f00: 00280001 00000000 dbf40e20 e592d000 c12701d0 c02b35dc c1204c48 dbf40e00
    2020 Apr 19 02:43:03 k2hk-evm 1f20: da431f54 da431f30 c02b44e4 c02b35c0 0000061f 00c00000 cb635024 0879468c
    2020 Apr 19 02:43:03 k2hk-evm 1f40: dbf40e00 00000003 da431fa4 da431f58 c02b5124 c02b4454 90000000 00000000
    2020 Apr 19 02:43:03 k2hk-evm 1f60: 97ffffff 00000000 c0201204 00000001 00000030 fffffff8 da430000 00000000
    202020 Apr 19 02:42020 Apr 19 02:43:03 k2hk-evm 1fc0: 00000000 bec719e0 bec719cc 0000015b 00000003 00000000 00000003 00034298
     _____                    _____           _         _
                  |___|                    |___|
    k2hk-evm login:
  • Hi, DR,
    A lot of internet pages mentioned -p option, but I have not seen any example about it. All examples refer to "-l" and "-e". I am chekcing internally if "-p" is supported but have not heard back. I'll post back once I get the internal response.
    Rex
  • Hi Rex,
    So if -p is not supported, what would be the way to have kernel dump on kernel panic or crash ?
    DR.
  • Hi, DR,
    Sorry, I don't have answer for it.
    Rex
  • Hi Rex,
    So the definitive answer is that kernel crash dump is not supported. Correct ?
    DR.
  • Hi, DR,
    Probably not, I haven't gotten any answer from development team. I recall a long while back when this was discussed, the suggestion to verify kexec was -l and -e options. I pinged several times, and still not getting any answers. My guess is -p is not supported.
    Rex
  • Hi, DR,
    I saw the following context in PLSDK migration guide, http://software-dl.ti.com/processor-sdk-linux/esd/docs/latest/linux/Release_Specific_Migration_Guide.html
    Roadmap
    Following features supported in MCSDK are not supported in Processor SDK 02.00.02 Release, and will get added in future Processor SDK releases
    • Drivers: UDMA, 10G-KR firmware, IPSec inflow, kexec, network bonding
    In MCSDK, there was a keystone2_recovery_defconfig which is the configuration for crashkernel without any hardware modules, networking, etc. This file doesn't exist in the PLSDK. So, the implementation of -p hasn't migrated to PLSDK, and hence isn't supported in current Linux Proc SDK.
    Sorry for not being able to spotted this earlier.
    Rex
