Compiler/TDA4VM: A fatal error has been detected by the Java Runtime Environment?
Part Number: TDA4VM
HI:
When we used the command line to compile the TDA4EVM SDK, an error occurred, which caused the compilation to stop.
Please help to see the reason:
# A fatal error has been detected by the Java Runtime Environment:
#  SIGSEGV (0xb) at pc=0x00002ae8725e523b, pid=26647, tid=47178179364608
# JRE version: Java(TM) SE Runtime Environment (8.0_66-b17) (build 1.8.0_66-b17)
# Java VM: Java HotSpot(TM) 64-Bit Server VM (25.66-b17 mixed mode linux-amd64 compressed oops)
# Problematic frame:
# V  [libjvm.so+0x63223b]  PhaseChaitin::build_ifg_physical(ResourceArea*)+0x3eb
# Failed to write core dump. Core dumps have been disabled. To enable core dumping, try "ulimit -c unlimited" before starting Java again
# If you would like to submit a bug report, please visit:
#   http://bugreport.java.com/bugreport/crash.jsp
---------------  T H R E A D  ---------------
Current thread (0x0000000000dfe000):  JavaThread "C2 CompilerThread0" daemon [_thread_in_native, id=26658, stack(0x00002ae8868f4000,0x00002ae8869f5000)]
siginfo: si_signo: 11 (SIGSEGV), si_code: 1 (SEGV_MAPERR), si_addr: 0x00002ae799477d20
Registers:
RAX=0x00002ae8b84edee0, RBX=0x00002ae8869f1c90, RCX=0x0000000000000001, RDX=0xffffffffb83e2790
RSP=0x00002ae8869f0170, RBP=0x00002ae8869f0400, RSI=0x000000000000001c, RDI=0x00002ae8c04b3140
R8 =0x0000000000000001, R9 =0x0000000000000004, R10=0x000000000000000d, R11=0x000000000000000c
R12=0x00002ae8b873a1e0, R13=0x000000000000000e, R14=0x0000000000000001, R15=0x00002ae8c04b3b78
RIP=0x00002ae8725e523b, EFLAGS=0x0000000000010287, CSGSFS=0x0000000000000033, ERR=0x0000000000000004
  TRAPNO=0x000000000000000e
Top of Stack: (sp=0x00002ae8869f0170)
0x00002ae8869f0170:   00002ae8869f01d0 0000000000000003
0x00002ae8869f0180:   00002ae8869f0340 00002ae8869f03a0
0x00002ae8869f0190:   00002ae8869f02c0 000000000000000c
0x00002ae8869f01a0:   00002ae8869f0300 00002ae8869f0220
0x00002ae8869f01b0:   00002ae8869f1c90 0000000000000000
0x00002ae8869f01c0:   426d1a94a20065ed 000002df00000004
0x00002ae8869f01d0:   00002ae8b826ed40 0000000c00000010
0x00002ae8869f01e0:   38e3f03c50000000 000000000000000f
0x00002ae8869f01f0:   000f423f0000009d 00002ae8b826ed50
0x00002ae8869f0200:   fffffffe00000001 0000000000000000
0x00002ae8869f0210:   0000000d00000011 ffffffffffffffff
0x00002ae8869f0220:   00002ae800000001 00002ae8869f0230
0x00002ae8869f0230:   00002ae8c01e4c60 00002ae872f54240
0x00002ae8869f0240:   00002ae872f54240 00002ae872f54240
0x00002ae8869f0250:   00002ae872f54240 00002ae872f54240
0x00002ae8869f0260:   00002ae872f54240 00002ae872f54240
0x00002ae8869f0270:   00002ae872f54240 00002ae872f54240
0x00002ae8869f0280:   00002ae872f54240 00002ae8869f02c0
0x00002ae8869f0290:   00002ae8869f03b0 00002ae8b82701f0
0x00002ae8869f02a0:   00002ae8869f0510 00002ae8b84e5c20
0x00002ae8869f02b0:   000000000000000b 000000000000000b
0x00002ae8869f02c0:   0000000500000000 0303030300000008
0x00002ae8869f02d0:   00002ae8c01e4c60 000000000000000b
0x00002ae8869f02e0:   00002ae8869f0230 00002ae80000000b
0x00002ae8869f02f0:   00002ae8869f0220 0000000000000006
0x00002ae8869f0300:   0000098f00000000 0000000000000008
0x00002ae8869f0310:   00002ae8c01e4ca0 00002ae800000001
0x00002ae8869f0320:   00002ae8869f0230 0000000000000001
0x00002ae8869f0330:   00002ae8869f0220 00002ae8727ab40f
0x00002ae8869f0340:   ffffffff3f3fffff ffffffffffffffff
0x00002ae8869f0350:   00000003ffffffff 0000000000000000
0x00002ae8869f0360:   0000000000000000 0000000000000a1f
Instructions: (pc=0x00002ae8725e523b)
0x00002ae8725e521b:   8b 95 14 fe ff ff 48 8b 40 20 4c 8b 3c d0 48 8b
0x00002ae8725e522b:   9d b0 fd ff ff 49 63 57 28 48 8b 83 28 01 00 00
0x00002ae8725e523b:   8b 04 90 85 c0 89 85 ec fd ff ff 0f 85 ec 02 00
0x00002ae8725e524b:   00 83 ad dc fd ff ff 01 48 c7 85 e0 fd ff ff 00
Register to memory mapping:
RAX=0x00002ae8b84edee0 is an unknown value
RBX=0x00002ae8869f1c90 is pointing into the stack for thread: 0x0000000000dfe000
RCX=0x0000000000000001 is an unknown value
RDX=0xffffffffb83e2790 is an unknown value
RSP=0x00002ae8869f0170 is pointing into the stack for thread: 0x0000000000dfe000
RBP=0x00002ae8869f0400 is pointing into the stack for thread: 0x0000000000dfe000
RSI=0x000000000000001c is an unknown value
RDI=0x00002ae8c04b3140 is an unknown value
R8 =0x0000000000000001 is an unknown value
R9 =0x0000000000000004 is an unknown value
R10=0x000000000000000d is an unknown value
R11=0x000000000000000c is an unknown value
R12=0x00002ae8b873a1e0 is an unknown value
R13=0x000000000000000e is an unknown value
R14=0x0000000000000001 is an unknown value
R15=0x00002ae8c04b3b78 is an unknown value
Stack: [0x00002ae8868f4000,0x00002ae8869f5000],  sp=0x00002ae8869f0170,  free space=1008k
Native frames: (J=compiled Java code, j=interpreted, Vv=VM code, C=native code)
V  [libjvm.so+0x40cdc6]  PhaseChaitin::Register_Allocate()+0x8e6
V  [libjvm.so+0x49fb50]  Compile::Code_Gen()+0x260
V  [libjvm.so+0x4a2fa2]  Compile::Compile(ciEnv*, C2Compiler*, ciMethod*, int, bool, bool, bool)+0x14b2
V  [libjvm.so+0x3f0748]  C2Compiler::compile_method(ciEnv*, ciMethod*, int)+0x198
V  [libjvm.so+0x4ad3aa]  CompileBroker::invoke_compiler_on_method(CompileTask*)+0xc9a
V  [libjvm.so+0x4ae356]  CompileBroker::compiler_thread_loop()+0x5d6
V  [libjvm.so+0xa68fff]  JavaThread::thread_main_inner()+0xdf
V  [libjvm.so+0xa6912c]  JavaThread::run()+0x11c
V  [libjvm.so+0x91cc68]  java_start(Thread*)+0x108
C  [libpthread.so.0+0x8184]  start_thread+0xc4
Current CompileTask:
C2:    405  978       4       org.mozilla.javascript.NodeTransformer::transformCompilationUnit_r (1766 bytes)
---------------  P R O C E S S  ---------------
Java Threads: ( => current thread )
  0x0000000000e08000 JavaThread "Service Thread" daemon [_thread_blocked, id=26661, stack(0x00002ae886bf7000,0x00002ae886cf8000)]
  0x0000000000e03000 JavaThread "C1 CompilerThread2" daemon [_thread_in_native, id=26660, stack(0x00002ae886af6000,0x00002ae886bf7000)]
  0x0000000000e01000 JavaThread "C2 CompilerThread1" daemon [_thread_in_native, id=26659, stack(0x00002ae8869f5000,0x00002ae886af6000)]
=>0x0000000000dfe000 JavaThread "C2 CompilerThread0" daemon [_thread_in_native, id=26658, stack(0x00002ae8868f4000,0x00002ae8869f5000)]
  0x0000000000dfd000 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=26657, stack(0x00002ae8867f3000,0x00002ae8868f4000)]
  0x0000000000dc4000 JavaThread "Finalizer" daemon [_thread_blocked, id=26656, stack(0x00002ae886010000,0x00002ae886111000)]
  0x0000000000dc1800 JavaThread "Reference Handler" daemon [_thread_blocked, id=26655, stack(0x00002ae885f0f000,0x00002ae886010000)]
  0x0000000000d4e800 JavaThread "main" [_thread_in_vm, id=26647, stack(0x00007fff7e704000,0x00007fff7e804000)]
Other Threads:
  0x0000000000dbc800 VMThread [stack: 0x00002ae885e0e000,0x00002ae885f0f000] [id=26654]
  0x0000000000e0b000 WatcherThread [stack: 0x00002ae886cf8000,0x00002ae886df9000] [id=26662]
VM state:not at safepoint (normal execution)
VM Mutex/Monitor currently owned by a thread: None
Heap:
 PSYoungGen      total 74240K, used 27059K [0x000000076df80000, 0x0000000773200000, 0x00000007c0000000)
  eden space 64000K, 42% used [0x000000076df80000,0x000000076f9ecc20,0x0000000771e00000)
  from space 10240K, 0% used [0x0000000772800000,0x0000000772800000,0x0000000773200000)
  to   space 10240K, 0% used [0x0000000771e00000,0x0000000771e00000,0x0000000772800000)
 ParOldGen       total 169472K, used 0K [0x00000006c9e00000, 0x00000006d4380000, 0x000000076df80000)
  object space 169472K, 0% used [0x00000006c9e00000,0x00000006c9e00000,0x00000006d4380000)
 Metaspace       used 8562K, capacity 8880K, committed 8960K, reserved 1056768K
  class space    used 889K, capacity 951K, committed 1024K, reserved 1048576K
Card table byte_map: [0x00002ae8833e6000,0x00002ae883b98000] byte_map_base: 0x00002ae87fd97000
Marking Bits: (ParMarkBitMap*) 0x00002ae872f62020
 Begin Bits: [0x00002ae89c3bc000, 0x00002ae8a0144000)
 End Bits:   [0x00002ae8a0144000, 0x00002ae8a3ecc000)
Polling page: 0x00002ae870d97000
CodeCache: size=245760Kb used=4717Kb max_used=4717Kb free=241042Kb
 bounds [0x00002ae874026000, 0x00002ae8744c6000, 0x00002ae883026000]
 total_blobs=1378 nmethods=1047 adapters=244
 compilation: enabled
Compilation events (10 events):
Event: 0.390 Thread 0x0000000000e03000 nmethod 977 0x00002ae8744c17d0 code [0x00002ae8744c1920, 0x00002ae8744c1a30]
Event: 0.390 Thread 0x0000000000e03000  945       1       org.mozilla.javascript.ScriptableObject$Slot::getAttributes (5 bytes)
Event: 0.390 Thread 0x0000000000e03000 nmethod 945 0x00002ae8744c1a90 code [0x00002ae8744c1be0, 0x00002ae8744c1cf0]
Event: 0.390 Thread 0x0000000000e03000 1043       1       java.io.ExpiringCache::access$000 (5 bytes)
Event: 0.390 Thread 0x0000000000e03000 nmethod 1043 0x00002ae8744c1d50 code [0x00002ae8744c1ea0, 0x00002ae8744c1f90]
Event: 0.390 Thread 0x0000000000e03000  975       1       org.mozilla.javascript.ast.NewExpression::getInitializer (5 bytes)
Event: 0.390 Thread 0x0000000000e03000 nmethod 975 0x00002ae8744c2010 code [0x00002ae8744c2160, 0x00002ae8744c2270]
Event: 0.390 Thread 0x0000000000e03000 1055       3       org.mozilla.javascript.ScriptableObject::getObjectPrototype (11 bytes)
Event: 0.390 Thread 0x0000000000e03000 nmethod 1055 0x00002ae8744c22d0 code [0x00002ae8744c2460, 0x00002ae8744c2798]
Event: 0.390 Thread 0x0000000000e03000 1057 % !   3       org.mozilla.javascript.Interpreter::interpretLoop @ 228 (6314 bytes)
GC Heap History (0 events):
No events
Deoptimization events (10 events):
Event: 0.329 Thread 0x0000000000d4e800 Uncommon trap: reason=unstable_if action=reinterpret pc=0x00002ae8741a5160 method=java.lang.CharacterData.of(I)Ljava/lang/CharacterData; @ 4
Event: 0.341 Thread 0x0000000000d4e800 Uncommon trap: reason=class_check action=maybe_recompile pc=0x00002ae8741a2d8c method=java.lang.String.equals(Ljava/lang/Object;)Z @ 8
Event: 0.341 Thread 0x0000000000d4e800 Uncommon trap: reason=unstable_if action=reinterpret pc=0x00002ae87441970c method=org.mozilla.javascript.ScriptRuntime.isJSWhitespaceOrLineTerminator(I)Z @ 4
Event: 0.349 Thread 0x0000000000d4e800 Uncommon trap: reason=unstable_if action=reinterpret pc=0x00002ae8741c0c00 method=org.mozilla.javascript.TokenStream.addToString(I)V @ 11
Event: 0.353 Thread 0x0000000000d4e800 Uncommon trap: reason=unstable_if action=reinterpret pc=0x00002ae874301de8 method=java.util.HashMap.putVal(ILjava/lang/Object;Ljava/lang/Object;ZZ)Ljava/lang/Object; @ 162
Event: 0.353 Thread 0x0000000000d4e800 Uncommon trap: reason=unstable_if action=reinterpret pc=0x00002ae87443c520 method=java.util.HashMap.getNode(ILjava/lang/Object;)Ljava/util/HashMap$Node; @ 84
Event: 0.353 Thread 0x0000000000d4e800 Uncommon trap: reason=unstable_if action=reinterpret pc=0x00002ae87441c554 method=java.util.HashMap.resize()[Ljava/util/HashMap$Node; @ 206
Internal exceptions (7 events):
Event: 0.018 Thread 0x0000000000d4e800 Exception <a 'java/lang/NoSuchMethodError': Method sun.misc.Unsafe.defineClass(Ljava/lang/String;[BII)Ljava/lang/Class; name or signature does not match> (0x000000076df92b98) thrown at [/HUDSON/workspace/8-2-build-linux-amd64/jdk8u66/4988/hotspot/src/shar
Event: 0.018 Thread 0x0000000000d4e800 Exception <a 'java/lang/NoSuchMethodError': Method sun.misc.Unsafe.prefetchRead(Ljava/lang/Object;J)V name or signature does not match> (0x000000076df92e80) thrown at [/HUDSON/workspace/8-2-build-linux-amd64/jdk8u66/4988/hotspot/src/share/vm/prims/jni.cpp
Event: 0.056 Thread 0x0000000000d4e800 Exception <a 'java/security/PrivilegedActionException'> (0x000000076e06beb8) thrown at [/HUDSON/workspace/8-2-build-linux-amd64/jdk8u66/4988/hotspot/src/share/vm/prims/jvm.cpp, line 1386]
Event: 0.056 Thread 0x0000000000d4e800 Exception <a 'java/security/PrivilegedActionException'> (0x000000076e06c2b0) thrown at [/HUDSON/workspace/8-2-build-linux-amd64/jdk8u66/4988/hotspot/src/share/vm/prims/jvm.cpp, line 1386]
Event: 0.056 Thread 0x0000000000d4e800 Exception <a 'java/security/PrivilegedActionException'> (0x000000076e06f938) thrown at [/HUDSON/workspace/8-2-build-linux-amd64/jdk8u66/4988/hotspot/src/share/vm/prims/jvm.cpp, line 1386]
Event: 0.056 Thread 0x0000000000d4e800 Exception <a 'java/security/PrivilegedActionException'> (0x000000076e06fd30) thrown at [/HUDSON/workspace/8-2-build-linux-amd64/jdk8u66/4988/hotspot/src/share/vm/prims/jvm.cpp, line 1386]
Event: 0.291 Thread 0x0000000000d4e800 Exception <a 'java/lang/NoSuchMethodError': <clinit>> (0x000000076f17c150) thrown at [/HUDSON/workspace/8-2-build-linux-amd64/jdk8u66/4988/hotspot/src/share/vm/prims/jni.cpp, line 1591]
Events (10 events):
Event: 0.401 loading class java/lang/invoke/LambdaForm$BasicType
Event: 0.401 loading class java/lang/invoke/LambdaForm$BasicType done
Event: 0.401 loading class java/lang/invoke/LambdaForm$Name
Event: 0.401 loading class java/lang/invoke/LambdaForm$Name done
Event: 0.402 loading class java/lang/invoke/LambdaForm$NamedFunction
Event: 0.402 loading class java/lang/invoke/LambdaForm$NamedFunction done
Event: 0.402 loading class java/lang/invoke/SimpleMethodHandle
Event: 0.402 loading class java/lang/invoke/BoundMethodHandle
Event: 0.402 loading class java/lang/invoke/BoundMethodHandle done
Event: 0.402 loading class java/lang/invoke/SimpleMethodHandle done
Dynamic libraries:
00400000-0040d000 r-xp 00000000 103:04 142237                            /opt/ti_build/psdk_rtos_auto_j7_06_02_00_21/xdctools_3_55_02_22_core/xs.x86_64U
0060d000-0060e000 rw-p 0000d000 103:04 142237                            /opt/ti_build/psdk_rtos_auto_j7_06_02_00_21/xdctools_3_55_02_22_core/xs.x86_64U
0060e000-00612000 rw-p 00000000 00:00 0
00d31000-01147000 rw-p 00000000 00:00 0                                  [heap]
6c9e00000-6d4380000 rw-p 00000000 00:00 0
6d4380000-76df80000 ---p 00000000 00:00 0
76df80000-773200000 rw-p 00000000 00:00 0
773200000-7c0000000 ---p 00000000 00:00 0
7c0000000-7c0100000 rw-p 00000000 00:00 0
7c0100000-800000000 ---p 00000000 00:00 0
2ae870d73000-2ae870d96000 r-xp 00000000 103:04 9050917                   /lib/x86_64-linux-gnu/ld-2.19.so
2ae870d96000-2ae870d97000 rw-p 00000000 00:00 0
2ae870d97000-2ae870d98000 r--p 00000000 00:00 0
2ae870d98000-2ae870d99000 rw-p 00000000 00:00 0
2ae870d99000-2ae870da1000 rw-s 00000000 00:19 51                         /tmp/hsperfdata_dji/26647
2ae870da1000-2ae870dc9000 rw-p 00000000 00:00 0
2ae870dc9000-2ae870dca000 r--s 0000d000 103:04 140322                    /opt/ti_build/psdk_rtos_auto_j7_06_02_00_21/xdctools_3_55_02_22_core/config.jar
2ae870dca000-2ae870dcb000 r--s 0000f000 103:04 141406                    /opt/ti_build/psdk_rtos_auto_j7_06_02_00_21/xdctools_3_55_02_22_core/packages/xdc/services/global/java/package.jar
2ae870dcb000-2ae870dd1000 rw-p 00000000 00:00 0
2ae870dd1000-2ae870dd2000 ---p 00000000 00:00 0
2ae870dd2000-2ae870f7a000 rw-p 00000000 00:00 0
2ae870f7a000-2ae870f8d000 r--s 00520000 103:04 140838                    /opt/ti_build/psdk_rtos_auto_j7_06_02_00_21/xdctools_3_55_02_22_core/packages/xdc/shelf/java/js.jar
2ae870f8d000-2ae870f90000 r--s 00035000 103:04 140839                    /opt/ti_build/psdk_rtos_auto_j7_06_02_00_21/xdctools_3_55_02_22_core/packages/xdc/shelf/java/antlr.jar
2ae870f90000-2ae870f92000 r--s 0001f000 103:04 141421                    /opt/ti_build/psdk_rtos_auto_j7_06_02_00_21/xdctools_3_55_02_22_core/packages/xdc/services/intern/xsr/java/package.jar
2ae870f92000-2ae870f93000 r--s 00004000 103:04 141437                    /opt/ti_build/psdk_rtos_auto_j7_06_02_00_21/xdctools_3_55_02_22_core/packages/xdc/services/intern/cmd/java/package.jar
2ae870f93000-2ae870f95000 r--s 00049000 103:04 141452                    /opt/ti_build/psdk_rtos_auto_j7_06_02_00_21/xdctools_3_55_02_22_core/packages/xdc/services/intern/gen/java/package.jar
2ae870f95000-2ae870f96000 r--p 00022000 103:04 9050917                   /lib/x86_64-linux-gnu/ld-2.19.so
2ae870f96000-2ae870f97000 rw-p 00023000 103:04 9050917                   /lib/x86_64-linux-gnu/ld-2.19.so
2ae870f97000-2ae870f98000 rw-p 00000000 00:00 0
2ae870f98000-2ae87109d000 r-xp 00000000 103:04 9050958                   /lib/x86_64-linux-gnu/libm-2.19.so
2ae87109d000-2ae87129c000 ---p 00105000 103:04 9050958                   /lib/x86_64-linux-gnu/libm-2.19.so
2ae87129c000-2ae87129d000 r--p 00104000 103:04 9050958                   /lib/x86_64-linux-gnu/libm-2.19.so
2ae87129d000-2ae87129e000 rw-p 00105000 103:04 9050958                   /lib/x86_64-linux-gnu/libm-2.19.so
2ae87129e000-2ae8712a1000 r-xp 00000000 103:04 9050940                   /lib/x86_64-linux-gnu/libdl-2.19.so
2ae8712a1000-2ae8714a0000 ---p 00003000 103:04 9050940                   /lib/x86_64-linux-gnu/libdl-2.19.so
2ae8714a0000-2ae8714a1000 r--p 00002000 103:04 9050940                   /lib/x86_64-linux-gnu/libdl-2.19.so
2ae8714a1000-2ae8714a2000 rw-p 00003000 103:04 9050940                   /lib/x86_64-linux-gnu/libdl-2.19.so
2ae8714a2000-2ae8714bb000 r-xp 00000000 103:04 9050999                   /lib/x86_64-linux-gnu/libpthread-2.19.so
2ae8714bb000-2ae8716ba000 ---p 00019000 103:04 9050999                   /lib/x86_64-linux-gnu/libpthread-2.19.so
2ae8716ba000-2ae8716bb000 r--p 00018000 103:04 9050999                   /lib/x86_64-linux-gnu/libpthread-2.19.so
2ae8716bb000-2ae8716bc000 rw-p 00019000 103:04 9050999                   /lib/x86_64-linux-gnu/libpthread-2.19.so
2ae8716bc000-2ae8716c0000 rw-p 00000000 00:00 0
2ae8716c0000-2ae8717c7000 r-xp 00000000 103:04 8796573                   /usr/lib/x86_64-linux-gnu/libstdc++.so.6.0.24
2ae8717c7000-2ae8719c6000 ---p 00107000 103:04 8796573                   /usr/lib/x86_64-linux-gnu/libstdc++.so.6.0.24
2ae8719c6000-2ae8719ce000 r--p 00106000 103:04 8796573                   /usr/lib/x86_64-linux-gnu/libstdc++.so.6.0.24
2ae8719ce000-2ae8719d0000 rw-p 0010e000 103:04 8796573                   /usr/lib/x86_64-linux-gnu/libstdc++.so.6.0.24
2ae8719d0000-2ae8719d3000 rw-p 00000000 00:00 0
2ae8719d3000-2ae871b91000 r-xp 00000000 103:04 9050931                   /lib/x86_64-linux-gnu/libc-2.19.so
2ae871b91000-2ae871d91000 ---p 001be000 103:04 9050931                   /lib/x86_64-linux-gnu/libc-2.19.so
2ae871d91000-2ae871d95000 r--p 001be000 103:04 9050931                   /lib/x86_64-linux-gnu/libc-2.19.so
2ae871d95000-2ae871d97000 rw-p 001c2000 103:04 9050931                   /lib/x86_64-linux-gnu/libc-2.19.so
2ae871d97000-2ae871d9c000 rw-p 00000000 00:00 0
2ae871d9c000-2ae871db2000 r-xp 00000000 103:04 9050945                   /lib/x86_64-linux-gnu/libgcc_s.so.1
2ae871db2000-2ae871fb1000 ---p 00016000 103:04 9050945                   /lib/x86_64-linux-gnu/libgcc_s.so.1
2ae871fb1000-2ae871fb2000 r--p 00015000 103:04 9050945                   /lib/x86_64-linux-gnu/libgcc_s.so.1
2ae871fb2000-2ae871fb3000 rw-p 00016000 103:04 9050945                   /lib/x86_64-linux-gnu/libgcc_s.so.1
2ae871fb3000-2ae872c71000 r-xp 00000000 103:04 144199                    /opt/ti_build/psdk_rtos_auto_j7_06_02_00_21/xdctools_3_55_02_22_core/jre/lib/amd64/server/libjvm.so
2ae872c71000-2ae872e70000 ---p 00cbe000 103:04 144199                    /opt/ti_build/psdk_rtos_auto_j7_06_02_00_21/xdctools_3_55_02_22_core/jre/lib/amd64/server/libjvm.so
2ae872e70000-2ae872f49000 rw-p 00cbd000 103:04 144199                    /opt/ti_build/psdk_rtos_auto_j7_06_02_00_21/xdctools_3_55_02_22_core/jre/lib/amd64/server/libjvm.so
2ae872f49000-2ae872f8d000 rw-p 00000000 00:00 0
2ae872f8d000-2ae872f94000 r-xp 00000000 103:04 9051003                   /lib/x86_64-linux-gnu/librt-2.19.so
2ae872f94000-2ae873193000 ---p 00007000 103:04 9051003                   /lib/x86_64-linux-gnu/librt-2.19.so
2ae873193000-2ae873194000 r--p 00006000 103:04 9051003                   /lib/x86_64-linux-gnu/librt-2.19.so
2ae873194000-2ae873195000 rw-p 00007000 103:04 9051003                   /lib/x86_64-linux-gnu/librt-2.19.so
2ae873195000-2ae8731a2000 r-xp 00000000 103:04 144210                    /opt/ti_build/psdk_rtos_auto_j7_06_02_00_21/xdctools_3_55_02_22_core/jre/lib/amd64/libverify.so
2ae8731a2000-2ae8733a2000 ---p 0000d000 103:04 144210                    /opt/ti_build/psdk_rtos_auto_j7_06_02_00_21/xdctools_3_55_02_22_core/jre/lib/amd64/libverify.so
2ae8733a2000-2ae8733a4000 rw-p 0000d000 103:04 144210                    /opt/ti_build/psdk_rtos_auto_j7_06_02_00_21/xdctools_3_55_02_22_core/jre/lib/amd64/libverify.so
2ae8733a4000-2ae8733ce000 r-xp 00000000 103:04 144193                    /opt/ti_build/psdk_rtos_auto_j7_06_02_00_21/xdctools_3_55_02_22_core/jre/lib/amd64/libjava.so
2ae8733ce000-2ae8735ce000 ---p 0002a000 103:04 144193                    /opt/ti_build/psdk_rtos_auto_j7_06_02_00_21/xdctools_3_55_02_22_core/jre/lib/amd64/libjava.so
2ae8735ce000-2ae8735d0000 rw-p 0002a000 103:04 144193                    /opt/ti_build/psdk_rtos_auto_j7_06_02_00_21/xdctools_3_55_02_22_core/jre/lib/amd64/libjava.so
2ae8735d0000-2ae8735d9000 r-xp 00000000 103:04 9050969                   /lib/x86_64-linux-gnu/libnss_compat-2.19.so
2ae8735d9000-2ae8737d8000 ---p 00009000 103:04 9050969                   /lib/x86_64-linux-gnu/libnss_compat-2.19.so
2ae8737d8000-2ae8737d9000 r--p 00008000 103:04 9050969                   /lib/x86_64-linux-gnu/libnss_compat-2.19.so
2ae8737d9000-2ae8737da000 rw-p 00009000 103:04 9050969                   /lib/x86_64-linux-gnu/libnss_compat-2.19.so
2ae8737da000-2ae8737f1000 r-xp 00000000 103:04 9050968                   /lib/x86_64-linux-gnu/libnsl-2.19.so
2ae8737f1000-2ae8739f0000 ---p 00017000 103:04 9050968                   /lib/x86_64-linux-gnu/libnsl-2.19.so
2ae8739f0000-2ae8739f1000 r--p 00016000 103:04 9050968                   /lib/x86_64-linux-gnu/libnsl-2.19.so
2ae8739f1000-2ae8739f2000 rw-p 00017000 103:04 9050968                   /lib/x86_64-linux-gnu/libnsl-2.19.so
2ae8739f2000-2ae8739f4000 rw-p 00000000 00:00 0
2ae8739f4000-2ae8739ff000 r-xp 00000000 103:04 9050979                   /lib/x86_64-linux-gnu/libnss_nis-2.19.so
2ae8739ff000-2ae873bfe000 ---p 0000b000 103:04 9050979                   /lib/x86_64-linux-gnu/libnss_nis-2.19.so
2ae873bfe000-2ae873bff000 r--p 0000a000 103:04 9050979                   /lib/x86_64-linux-gnu/libnss_nis-2.19.so
2ae873bff000-2ae873c00000 rw-p 0000b000 103:04 9050979                   /lib/x86_64-linux-gnu/libnss_nis-2.19.so
2ae873c00000-2ae873c0a000 r-xp 00000000 103:04 9050971                   /lib/x86_64-linux-gnu/libnss_files-2.19.so
2ae873c0a000-2ae873e09000 ---p 0000a000 103:04 9050971                   /lib/x86_64-linux-gnu/libnss_files-2.19.so
2ae873e09000-2ae873e0a000 r--p 00009000 103:04 9050971                   /lib/x86_64-linux-gnu/libnss_files-2.19.so
2ae873e0a000-2ae873e0b000 rw-p 0000a000 103:04 9050971                   /lib/x86_64-linux-gnu/libnss_files-2.19.so
2ae873e0b000-2ae873e25000 r-xp 00000000 103:04 144174                    /opt/ti_build/psdk_rtos_auto_j7_06_02_00_21/xdctools_3_55_02_22_core/jre/lib/amd64/libzip.so
2ae873e25000-2ae874025000 ---p 0001a000 103:04 144174                    /opt/ti_build/psdk_rtos_auto_j7_06_02_00_21/xdctools_3_55_02_22_core/jre/lib/amd64/libzip.so
2ae874025000-2ae874026000 rw-p 0001a000 103:04 144174                    /opt/ti_build/psdk_rtos_auto_j7_06_02_00_21/xdctools_3_55_02_22_core/jre/lib/amd64/libzip.so
2ae874026000-2ae8744c6000 rwxp 00000000 00:00 0
2ae8744c6000-2ae883026000 ---p 00000000 00:00 0
2ae883026000-2ae883039000 rw-p 00000000 00:00 0
2ae883039000-2ae8833e6000 ---p 00000000 00:00 0
2ae8833e6000-2ae883439000 rw-p 00000000 00:00 0
2ae883439000-2ae883906000 ---p 00000000 00:00 0
2ae883906000-2ae883930000 rw-p 00000000 00:00 0
2ae883930000-2ae883b97000 ---p 00000000 00:00 0
2ae883b97000-2ae883beb000 rw-p 00000000 00:00 0
2ae883beb000-2ae8840b9000 ---p 00000000 00:00 0
2ae8840b9000-2ae8840ba000 ---p 00000000 00:00 0
2ae8840ba000-2ae8841ba000 rw-p 00000000 00:00 0
2ae8841ba000-2ae8841bb000 ---p 00000000 00:00 0
2ae8841bb000-2ae8842bb000 rw-p 00000000 00:00 0
2ae8842bb000-2ae8842bc000 ---p 00000000 00:00 0
2ae8842bc000-2ae884b7c000 rw-p 00000000 00:00 0
2ae884b7c000-2ae884bbc000 ---p 00000000 00:00 0
2ae884bbc000-2ae884c32000 rw-p 00000000 00:00 0
2ae884c32000-2ae884e0b000 r--s 03d20000 103:04 144273                    /opt/ti_build/psdk_rtos_auto_j7_06_02_00_21/xdctools_3_55_02_22_core/jre/lib/rt.jar
2ae884e0b000-2ae885e0e000 rw-p 00000000 00:00 0
2ae885e0e000-2ae885e0f000 ---p 00000000 00:00 0
2ae885e0f000-2ae885f0f000 rw-p 00000000 00:00 0
2ae885f0f000-2ae885f12000 ---p 00000000 00:00 0
2ae885f12000-2ae886010000 rw-p 00000000 00:00 0
2ae886010000-2ae886013000 ---p 00000000 00:00 0
2ae886013000-2ae886111000 rw-p 00000000 00:00 0
2ae886111000-2ae8867f3000 r--p 00000000 103:04 8793132                   /usr/lib/locale/locale-archive
2ae8867f3000-2ae8867f6000 ---p 00000000 00:00 0
2ae8867f6000-2ae8868f4000 rw-p 00000000 00:00 0
2ae8868f4000-2ae8868f7000 ---p 00000000 00:00 0
2ae8868f7000-2ae8869f5000 rw-p 00000000 00:00 0
2ae8869f5000-2ae8869f8000 ---p 00000000 00:00 0
2ae8869f8000-2ae886af6000 rw-p 00000000 00:00 0
2ae886af6000-2ae886af9000 ---p 00000000 00:00 0
2ae886af9000-2ae886bf7000 rw-p 00000000 00:00 0
2ae886bf7000-2ae886bfa000 ---p 00000000 00:00 0
2ae886bfa000-2ae886cf8000 rw-p 00000000 00:00 0
2ae886cf8000-2ae886cf9000 ---p 00000000 00:00 0
2ae886cf9000-2ae886df9000 rw-p 00000000 00:00 0
2ae886df9000-2ae886dfc000 r--s 00065000 103:04 141366                    /opt/ti_build/psdk_rtos_auto_j7_06_02_00_21/xdctools_3_55_02_22_core/packages/xdc/services/spec/java/package.jar
2ae886dfc000-2ae886dfe000 r--s 0000f000 103:04 140837                    /opt/ti_build/psdk_rtos_auto_j7_06_02_00_21/xdctools_3_55_02_22_core/packages/xdc/shelf/java/tar.jar
2ae886dfe000-2ae886e16000 r--s 00294000 103:04 140840                    /opt/ti_build/psdk_rtos_auto_j7_06_02_00_21/xdctools_3_55_02_22_core/packages/xdc/shelf/java/ecj.jar
2ae886e16000-2ae886e1b000 r--s 00096000 103:04 144240                    /opt/ti_build/psdk_rtos_auto_j7_06_02_00_21/xdctools_3_55_02_22_core/jre/lib/jsse.jar
2ae886e1b000-2ae886e1d000 rw-p 00000000 00:00 0
2ae888000000-2ae888021000 rw-p 00000000 00:00 0
2ae888021000-2ae88c000000 ---p 00000000 00:00 0
2ae88c3bc000-2ae88cb6d000 rw-p 00000000 00:00 0
2ae890000000-2ae890021000 rw-p 00000000 00:00 0
2ae890021000-2ae894000000 ---p 00000000 00:00 0
2ae898000000-2ae898021000 rw-p 00000000 00:00 0
2ae898021000-2ae89c000000 ---p 00000000 00:00 0
2ae89c3bc000-2ae8a3ecc000 rw-p 00000000 00:00 0
2ae8a4000000-2ae8a4021000 rw-p 00000000 00:00 0
2ae8a4021000-2ae8a8000000 ---p 00000000 00:00 0
2ae8a8000000-2ae8a8021000 rw-p 00000000 00:00 0
2ae8a8021000-2ae8ac000000 ---p 00000000 00:00 0
2ae8ac000000-2ae8ac021000 rw-p 00000000 00:00 0
2ae8ac021000-2ae8b0000000 ---p 00000000 00:00 0
2ae8b0000000-2ae8b0021000 rw-p 00000000 00:00 0
2ae8b0021000-2ae8b4000000 ---p 00000000 00:00 0
2ae8b4000000-2ae8b4021000 rw-p 00000000 00:00 0
2ae8b4021000-2ae8b8000000 ---p 00000000 00:00 0
2ae8b8000000-2ae8b89ea000 rw-p 00000000 00:00 0
2ae8b89ea000-2ae8bc000000 ---p 00000000 00:00 0
2ae8bc000000-2ae8bc8b5000 rw-p 00000000 00:00 0
2ae8bc8b5000-2ae8c0000000 ---p 00000000 00:00 0
2ae8c0000000-2ae8c0968000 rw-p 00000000 00:00 0
2ae8c0968000-2ae8c4000000 ---p 00000000 00:00 0
2ae8c4000000-2ae8c4021000 rw-p 00000000 00:00 0
2ae8c4021000-2ae8c8000000 ---p 00000000 00:00 0
2ae8c8000000-2ae8c8021000 rw-p 00000000 00:00 0
2ae8c8021000-2ae8cc000000 ---p 00000000 00:00 0
7fff7e704000-7fff7e707000 ---p 00000000 00:00 0
7fff7e707000-7fff7e804000 rw-p 00000000 00:00 0                          [stack]
7fff7e9c4000-7fff7e9c7000 r--p 00000000 00:00 0                          [vvar]
7fff7e9c7000-7fff7e9c9000 r-xp 00000000 00:00 0                          [vdso]
ffffffffff600000-ffffffffff601000 r-xp 00000000 00:00 0                  [vsyscall]
VM Arguments:
jvm_args: -Xverify:none -DXDCPATH=/home/dji/catkin_ws/src/bsp_tda/psdk_rtos_auto_j7_06_02_00_21/bios_6_76_03_01/packages;/home/dji/catkin_ws/src/bsp_tda/psdk_rtos_auto_j7_06_02_00_21/vision_apps/bsp/app_tirtos/tirtos_linux/c66x_1/../../bios_cfg/ -Dxdc.root=/opt/ti_build/psdk_rtos_auto_j7_06_01_00_15/xdctools_3_55_02_22_core -Dconfig.rootDir=/opt/ti_build/psdk_rtos_auto_j7_06_01_00_15/xdctools_3_55_02_22_core -Dconfig.gopts= vfprintf exit abort
java_command: <unknown>
java_class_path (initial): /opt/ti_build/psdk_rtos_auto_j7_06_01_00_15/xdctools_3_55_02_22_core/packages/xdc/shelf/java/js.jar:/opt/ti_build/psdk_rtos_auto_j7_06_01_00_15/xdctools_3_55_02_22_core/config.jar:/opt/ti_build/psdk_rtos_auto_j7_06_01_00_15/xdctools_3_55_02_22_core/packages/xdc/shelf/java/antlr.jar:
Launcher Type: generic
Environment Variables:
PATH=/home/dji/anaconda2/bin:/opt/ros/indigo/bin:/usr/local/bin/dji/bag/:/usr/local/bin/dji/dlog/:/usr/local/bin/dji/dcos/dcos_test:/usr/local/bin/dji/dcos:/usr/local/bin/dcos:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games
LD_LIBRARY_PATH=/opt/ti_build/psdk_rtos_auto_j7_06_01_00_15/xdctools_3_55_02_22_core:/opt/ti_build/psdk_rtos_auto_j7_06_01_00_15/xdctools_3_55_02_22_core/jre/lib/amd64/server:/opt/ti_build/psdk_rtos_auto_j7_06_01_00_15/xdctools_3_55_02_22_core/jre/lib/amd64:/home/dji/catkin_ws/devel/lib:/opt/ros/indigo/lib
SHELL=/bin/bash
DISPLAY=:0
Signal Handlers:
SIGSEGV: [libjvm.so+0xaba2a0], sa_mask[0]=11111111011111111101111111111110, sa_flags=SA_RESTART|SA_SIGINFO
SIGBUS: [libjvm.so+0xaba2a0], sa_mask[0]=11111111011111111101111111111110, sa_flags=SA_RESTART|SA_SIGINFO
SIGFPE: [libjvm.so+0x917710], sa_mask[0]=11111111011111111101111111111110, sa_flags=SA_RESTART|SA_SIGINFO
SIGPIPE: [libjvm.so+0x917710], sa_mask[0]=11111111011111111101111111111110, sa_flags=SA_RESTART|SA_SIGINFO
SIGXFSZ: [libjvm.so+0x917710], sa_mask[0]=11111111011111111101111111111110, sa_flags=SA_RESTART|SA_SIGINFO
SIGILL: [libjvm.so+0x917710], sa_mask[0]=11111111011111111101111111111110, sa_flags=SA_RESTART|SA_SIGINFO
SIGUSR1: SIG_DFL, sa_mask[0]=00000000000000000000000000000000, sa_flags=none
SIGUSR2: [libjvm.so+0x918d40], sa_mask[0]=00000000000000000000000000000000, sa_flags=SA_RESTART|SA_SIGINFO
SIGHUP: [libjvm.so+0x91a140], sa_mask[0]=11111111011111111101111111111110, sa_flags=SA_RESTART|SA_SIGINFO
SIGINT: [libjvm.so+0x91a140], sa_mask[0]=11111111011111111101111111111110, sa_flags=SA_RESTART|SA_SIGINFO
SIGTERM: [libjvm.so+0x91a140], sa_mask[0]=11111111011111111101111111111110, sa_flags=SA_RESTART|SA_SIGINFO
SIGQUIT: [libjvm.so+0x91a140], sa_mask[0]=11111111011111111101111111111110, sa_flags=SA_RESTART|SA_SIGINFO
---------------  S Y S T E M  ---------------
OS:DISTRIB_ID=Ubuntu
DISTRIB_RELEASE=14.04
DISTRIB_CODENAME=trusty
DISTRIB_DESCRIPTION="Ubuntu 14.04.5 LTS"
uname:Linux 4.4.0-119-generic #143~14.04.1-Ubuntu SMP Mon Apr 2 18:04:36 UTC 2018 x86_64
libc:glibc 2.19 NPTL 2.19
rlimit: STACK infinity, CORE 0k, NPROC 62469, NOFILE 4096, AS infinity
load average:5.36 2.10 4.48
/proc/meminfo:
MemTotal:       16128604 kB
MemFree:         4073420 kB
MemAvailable:   13485568 kB
Buffers:          170504 kB
Cached:          9447036 kB
SwapCached:       153804 kB
Active:          5863668 kB
Inactive:        5367548 kB
Active(anon):     710452 kB
Inactive(anon):  1397300 kB
Active(file):    5153216 kB
Inactive(file):  3970248 kB
Unevictable:          64 kB
Mlocked:              64 kB
SwapTotal:       8000508 kB
SwapFree:        4991856 kB
Dirty:               640 kB
Writeback:             0 kB
AnonPages:       1460104 kB
Mapped:           492932 kB
Shmem:            494064 kB
Slab:             675516 kB
SReclaimable:     630016 kB
SUnreclaim:        45500 kB
KernelStack:        9232 kB
PageTables:        46016 kB
NFS_Unstable:          0 kB
Bounce:                0 kB
WritebackTmp:          0 kB
CommitLimit:    16064808 kB
Committed_AS:    9370396 kB
VmallocTotal:   34359738367 kB
VmallocUsed:           0 kB
VmallocChunk:          0 kB
HardwareCorrupted:     0 kB
AnonHugePages:         0 kB
CmaTotal:              0 kB
CmaFree:               0 kB
HugePages_Total:       0
HugePages_Free:        0
HugePages_Rsvd:        0
HugePages_Surp:        0
Hugepagesize:       2048 kB
DirectMap4k:      144588 kB
DirectMap2M:     8984576 kB
DirectMap1G:     7340032 kB
CPU:total 4 (4 cores per cpu, 1 threads per core) family 6 model 158 stepping 9, cmov, cx8, fxsr, mmx, sse, sse2, sse3, ssse3, sse4.1, sse4.2, popcnt, avx, avx2, aes, clmul, erms, rtm, 3dnowpref, lzcnt, tsc, tscinvbit, bmi1, bmi2, adx
/proc/cpuinfo:
processor	: 0
vendor_id	: GenuineIntel
cpu family	: 6
model		: 158
model name	: Intel(R) Core(TM) i5-7500 CPU @ 3.40GHz
stepping	: 9
microcode	: 0x5e
cpu MHz		: 3611.437
cache size	: 6144 KB
physical id	: 0
siblings	: 4
core id		: 0
cpu cores	: 4
apicid		: 0
initial apicid	: 0
fpu		: yes
fpu_exception	: yes
cpuid level	: 22
wp		: yes
flags		: fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx pdpe1gb rdtscp lm constant_tsc art arch_perfmon pebs bts rep_good nopl xtopology nonstop_tsc aperfmperf eagerfpu pni pclmulqdq dtes64 monitor ds_cpl vmx smx est tm2 ssse3 sdbg fma cx16 xtpr pdcm pcid sse4_1 sse4_2 x2apic movbe popcnt tsc_deadline_timer aes xsave avx f16c rdrand lahf_lm abm 3dnowprefetch epb invpcid_single intel_pt rsb_ctxsw retpoline kaiser tpr_shadow vnmi flexpriority ept vpid fsgsbase tsc_adjust bmi1 hle avx2 smep bmi2 erms invpcid rtm mpx rdseed adx smap clflushopt xsaveopt xsavec xgetbv1 dtherm ida arat pln pts hwp hwp_notify hwp_act_window hwp_epp
bugs		: cpu_meltdown spectre_v1 spectre_v2
bogomips	: 6815.86
clflush size	: 64
cache_alignment	: 64
address sizes	: 39 bits physical, 48 bits virtual
power management:
processor	: 1
cpu family	: 6
model		: 158
stepping	: 9
microcode	: 0x5e
cpu MHz		: 3609.976
physical id	: 0
siblings	: 4
core id		: 1
cpu cores	: 4
apicid		: 2
initial apicid	: 2
fpu		: yes
fpu_exception	: yes
cpuid level	: 22
wp		: yes
bogomips	: 6815.86
clflush size	: 64
power management:
processor	: 2
cpu family	: 6
model		: 158
stepping	: 9
microcode	: 0x5e
cpu MHz		: 3605.726
physical id	: 0
siblings	: 4
core id		: 2
cpu cores	: 4
apicid		: 4
initial apicid	: 4
fpu		: yes
fpu_exception	: yes
cpuid level	: 22
wp		: yes
bogomips	: 6815.86
clflush size	: 64
power management:
processor	: 3
cpu family	: 6
model		: 158
stepping	: 9
microcode	: 0x5e
cpu MHz		: 3619.007
physical id	: 0
siblings	: 4
core id		: 3
cpu cores	: 4
apicid		: 6
initial apicid	: 6
fpu		: yes
fpu_exception	: yes
cpuid level	: 22
wp		: yes
bogomips	: 6815.86
clflush size	: 64
power management:
Memory: 4k page, physical 16128604k(4072480k free), swap 8000508k(4991856k free)
vm_info: Java HotSpot(TM) 64-Bit Server VM (25.66-b17) for linux-amd64 JRE (1.8.0_66-b17), built on Oct  6 2015 17:28:34 by "java_re" with gcc 4.3.0 20080428 (Red Hat 4.3.0-8)
time: Fri May  8 11:33:55 2020
elapsed time: 0 seconds (0d 0h 0m 0s)
Registers:
Other Threads:
Heap:
No events
Events (10 events):
Dynamic libraries:
VM Arguments:
SHELL=/bin/bash
DISPLAY=:0
Signal Handlers:
/proc/meminfo:
MemFree:         4073420 kB
Buffers:          170504 kB
Cached:          9447036 kB
Active:          5863668 kB
Unevictable:          64 kB
Mlocked:              64 kB
Dirty:               640 kB
Writeback:             0 kB
Mapped:           492932 kB
Shmem:            494064 kB
Slab:             675516 kB
NFS_Unstable:          0 kB
Bounce:                0 kB
WritebackTmp:          0 kB
VmallocUsed:           0 kB
VmallocChunk:          0 kB
AnonHugePages:         0 kB
CmaTotal:              0 kB
CmaFree:               0 kB
HugePages_Total:       0
HugePages_Free:        0
HugePages_Rsvd:        0
HugePages_Surp:        0
/proc/cpuinfo:
processor	: 0
cpu family	: 6
model		: 158
stepping	: 9
microcode	: 0x5e
cpu MHz		: 3611.437
physical id	: 0
siblings	: 4
core id		: 0
cpu cores	: 4
apicid		: 0
initial apicid	: 0
fpu		: yes
fpu_exception	: yes
cpuid level	: 22
wp		: yes
bogomips	: 6815.86
clflush size	: 64
power management:
processor	: 1
cpu family	: 6
model		: 158
stepping	: 9
microcode	: 0x5e
cpu MHz		: 3609.976
physical id	: 0
siblings	: 4
core id		: 1
cpu cores	: 4
apicid		: 2
initial apicid	: 2
fpu		: yes
fpu_exception	: yes
cpuid level	: 22
wp		: yes
bogomips	: 6815.86
clflush size	: 64
power management:
processor	: 2
cpu family	: 6
model		: 158
stepping	: 9
microcode	: 0x5e
cpu MHz		: 3605.726
physical id	: 0
siblings	: 4
core id		: 2
cpu cores	: 4
apicid		: 4
initial apicid	: 4
fpu		: yes
fpu_exception	: yes
cpuid level	: 22
wp		: yes
bogomips	: 6815.86
clflush size	: 64
power management:
processor	: 3
cpu family	: 6
model		: 158
stepping	: 9
microcode	: 0x5e
cpu MHz		: 3619.007
physical id	: 0
siblings	: 4
core id		: 3
cpu cores	: 4
apicid		: 6
initial apicid	: 6
fpu		: yes
fpu_exception	: yes
cpuid level	: 22
wp		: yes
bogomips	: 6815.86
clflush size	: 64
power management:
