Part Number: TDA4VM
Hi TI Support Team
Do you know if we can use TDA4 CAN TX direct connect to MCU CAN RX; TDA4 CAN RX direct connect to MCU CAN TX without CAN PHY (Transceiver IC).
I dont know if it have any risk from CAN protocol ? Because from CAN protocol the TX transmitting each bit into the bus and the RX pin need to check the data from CAN PHY(Transceiver IC) loop back.
If we dont have CAN PHY is it still working?
Yutai
