I am working with processor sdk 06.01.08 and I am trying to configure QtCreator to use my Yocto toolchain. To generate the Yocto SDK I added
inherit populate_sdk_qt5
and I used the command to generate the SDK.
But when I build my application with the generated yocto g++ compiler, I get this error :
/opt/qtsdk-Guinault-2020.03/sysroots/armv7at2hf-neon-linux-gnueabi/usr/include/QtCore/qglobal.h:45:12: fatal error: type_traits: No such file or directory # include <type_traits> ^~~~~~~~~~~~~
Yet the type_traits header is in sysroots/armv7at2hf-neon-linux-gnueabi/usr/include/c++/8.3.0/type_traits
This is the strace output of the command echo "#include <type_traits>" | strace -f ${CXX} -E -x c++ -o /dev/null - :
execve("/opt/qtsdk-Guinault-2020.03/sysroots/x86_64-guinault-linux/usr/bin/arm-linux-gnueabihf-g++", ["arm-linux-gnueabihf-g++", "-march=armv7-a", "-mthumb", "-mfpu=neon", "-mfloat-abi=hard", "--sysroot=/opt/qtsdk-Guinault-20"..., "-E", "-x", "c++", "-o", "/dev/null", "-"], [/* 99 vars */]) = 0 brk(NULL) = 0x12ad000 access("/etc/ld.so.nohwcap", F_OK) = -1 ENOENT (No such file or directory) access("/etc/ld.so.preload", R_OK) = -1 ENOENT (No such file or directory) open("/etc/ld.so.cache", O_RDONLY|O_CLOEXEC) = 3 fstat(3, {st_mode=S_IFREG|0644, st_size=110392, ...}) = 0 mmap(NULL, 110392, PROT_READ, MAP_PRIVATE, 3, 0) = 0x7f42f79da000 close(3) = 0 access("/etc/ld.so.nohwcap", F_OK) = -1 ENOENT (No such file or directory) open("/lib/x86_64-linux-gnu/libm.so.6", O_RDONLY|O_CLOEXEC) = 3 read(3, "\177ELF\2\1\1\3\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\200V\0\0\0\0\0\0"..., 832) = 832 fstat(3, {st_mode=S_IFREG|0644, st_size=1063328, ...}) = 0 mmap(NULL, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7f42f79d8000 mmap(NULL, 3158248, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f42f74ce000 mprotect(0x7f42f75d1000, 2093056, PROT_NONE) = 0 mmap(0x7f42f77d0000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x102000) = 0x7f42f77d0000 close(3) = 0 access("/etc/ld.so.nohwcap", F_OK) = -1 ENOENT (No such file or directory) open("/lib/x86_64-linux-gnu/libc.so.6", O_RDONLY|O_CLOEXEC) = 3 read(3, "\177ELF\2\1\1\3\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\0\4\2\0\0\0\0\0"..., 832) = 832 fstat(3, {st_mode=S_IFREG|0755, st_size=1689360, ...}) = 0 mmap(NULL, 3795296, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f42f712f000 mprotect(0x7f42f72c4000, 2097152, PROT_NONE) = 0 mmap(0x7f42f74c4000, 24576, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x195000) = 0x7f42f74c4000 mmap(0x7f42f74ca000, 14688, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x7f42f74ca000 close(3) = 0 mmap(NULL, 12288, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7f42f79d5000 arch_prctl(ARCH_SET_FS, 0x7f42f79d5740) = 0 mprotect(0x7f42f74c4000, 16384, PROT_READ) = 0 mprotect(0x7f42f77d0000, 4096, PROT_READ) = 0 mprotect(0x7f42f79f5000, 4096, PROT_READ) = 0 munmap(0x7f42f79da000, 110392) = 0 brk(NULL) = 0x12ad000 brk(0x12ce000) = 0x12ce000 open("/usr/lib/locale/locale-archive", O_RDONLY|O_CLOEXEC) = 3 fstat(3, {st_mode=S_IFREG|0644, st_size=1683408, ...}) = 0 mmap(NULL, 1683408, PROT_READ, MAP_PRIVATE, 3, 0) = 0x7f42f783a000 close(3) = 0 open("/usr/share/locale/locale.alias", O_RDONLY|O_CLOEXEC) = 3 fstat(3, {st_mode=S_IFREG|0644, st_size=2995, ...}) = 0 read(3, "# Locale name alias data base.\n#"..., 4096) = 2995 read(3, "", 4096) = 0 close(3) = 0 open("/share/locale/en_US.UTF-8/LC_MESSAGES/gcc.mo", O_RDONLY) = -1 ENOENT (No such file or directory) open("/share/locale/en_US.utf8/LC_MESSAGES/gcc.mo", O_RDONLY) = -1 ENOENT (No such file or directory) open("/share/locale/en_US/LC_MESSAGES/gcc.mo", O_RDONLY) = -1 ENOENT (No such file or directory) open("/share/locale/en.UTF-8/LC_MESSAGES/gcc.mo", O_RDONLY) = -1 ENOENT (No such file or directory) open("/share/locale/en.utf8/LC_MESSAGES/gcc.mo", O_RDONLY) = -1 ENOENT (No such file or directory) open("/share/locale/en/LC_MESSAGES/gcc.mo", O_RDONLY) = -1 ENOENT (No such file or directory) ioctl(2, TCGETS, {B38400 opost isig icanon echo ...}) = 0 ioctl(0, TIOCGWINSZ, 0x7ffe0029cd80) = -1 ENOTTY (Inappropriate ioctl for device) ioctl(2, TCGETS, {B38400 opost isig icanon echo ...}) = 0 rt_sigaction(SIGINT, {sa_handler=SIG_IGN, sa_mask=[INT], sa_flags=SA_RESTORER|SA_RESTART, sa_restorer=0x7f42f7162060}, {sa_handler=SIG_DFL, sa_mask=[], sa_flags=0}, 8) = 0 rt_sigaction(SIGINT, {sa_handler=0x4060c0, sa_mask=[INT], sa_flags=SA_RESTORER|SA_RESTART, sa_restorer=0x7f42f7162060}, {sa_handler=SIG_IGN, sa_mask=[INT], sa_flags=SA_RESTORER|SA_RESTART, sa_restorer=0x7f42f7162060}, 8) = 0 rt_sigaction(SIGHUP, {sa_handler=SIG_IGN, sa_mask=[HUP], sa_flags=SA_RESTORER|SA_RESTART, sa_restorer=0x7f42f7162060}, {sa_handler=SIG_DFL, sa_mask=[], sa_flags=0}, 8) = 0 rt_sigaction(SIGHUP, {sa_handler=0x4060c0, sa_mask=[HUP], sa_flags=SA_RESTORER|SA_RESTART, sa_restorer=0x7f42f7162060}, {sa_handler=SIG_IGN, sa_mask=[HUP], sa_flags=SA_RESTORER|SA_RESTART, sa_restorer=0x7f42f7162060}, 8) = 0 rt_sigaction(SIGTERM, {sa_handler=SIG_IGN, sa_mask=[TERM], sa_flags=SA_RESTORER|SA_RESTART, sa_restorer=0x7f42f7162060}, {sa_handler=SIG_DFL, sa_mask=[], sa_flags=0}, 8) = 0 rt_sigaction(SIGTERM, {sa_handler=0x4060c0, sa_mask=[TERM], sa_flags=SA_RESTORER|SA_RESTART, sa_restorer=0x7f42f7162060}, {sa_handler=SIG_IGN, sa_mask=[TERM], sa_flags=SA_RESTORER|SA_RESTART, sa_restorer=0x7f42f7162060}, 8) = 0 rt_sigaction(SIGPIPE, {sa_handler=SIG_IGN, sa_mask=[PIPE], sa_flags=SA_RESTORER|SA_RESTART, sa_restorer=0x7f42f7162060}, {sa_handler=SIG_DFL, sa_mask=[], sa_flags=0}, 8) = 0 rt_sigaction(SIGPIPE, {sa_handler=0x4060c0, sa_mask=[PIPE], sa_flags=SA_RESTORER|SA_RESTART, sa_restorer=0x7f42f7162060}, {sa_handler=SIG_IGN, sa_mask=[PIPE], sa_flags=SA_RESTORER|SA_RESTART, sa_restorer=0x7f42f7162060}, 8) = 0 rt_sigaction(SIGCHLD, {sa_handler=SIG_DFL, sa_mask=[CHLD], sa_flags=SA_RESTORER|SA_RESTART, sa_restorer=0x7f42f7162060}, {sa_handler=SIG_DFL, sa_mask=[], sa_flags=0}, 8) = 0 getrlimit(RLIMIT_STACK, {rlim_cur=8192*1024, rlim_max=RLIM64_INFINITY}) = 0 setrlimit(RLIMIT_STACK, {rlim_cur=65536*1024, rlim_max=RLIM64_INFINITY}) = 0 access("/opt/qtsdk-Guinault-2020.03/sysroots/x86_64-guinault-linux/usr/bin/arm-linux-gnueabihf-g++", X_OK) = 0 stat("/opt/qtsdk-Guinault-2020.03/sysroots/x86_64-guinault-linux/usr/bin/arm-linux-gnueabihf-g++", {st_mode=S_IFREG|0755, st_size=5203128, ...}) = 0 lstat("/opt", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0 lstat("/opt/qtsdk-Guinault-2020.03", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0 lstat("/opt/qtsdk-Guinault-2020.03/sysroots", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0 lstat("/opt/qtsdk-Guinault-2020.03/sysroots/x86_64-guinault-linux", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0 lstat("/opt/qtsdk-Guinault-2020.03/sysroots/x86_64-guinault-linux/usr", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0 lstat("/opt/qtsdk-Guinault-2020.03/sysroots/x86_64-guinault-linux/usr/bin", {st_mode=S_IFDIR|0755, st_size=12288, ...}) = 0 lstat("/opt/qtsdk-Guinault-2020.03/sysroots/x86_64-guinault-linux/usr/bin/arm-linux-gnueabihf-g++", {st_mode=S_IFREG|0755, st_size=5203128, ...}) = 0 access("/opt/qtsdk-Guinault-2020.03/sysroots/x86_64-guinault-linux/usr/bin/arm-linux-gnueabihf-g++", X_OK) = 0 stat("/opt/qtsdk-Guinault-2020.03/sysroots/x86_64-guinault-linux/usr/bin/arm-linux-gnueabihf-g++", {st_mode=S_IFREG|0755, st_size=5203128, ...}) = 0 lstat("/opt", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0 lstat("/opt/qtsdk-Guinault-2020.03", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0 lstat("/opt/qtsdk-Guinault-2020.03/sysroots", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0 lstat("/opt/qtsdk-Guinault-2020.03/sysroots/x86_64-guinault-linux", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0 lstat("/opt/qtsdk-Guinault-2020.03/sysroots/x86_64-guinault-linux/usr", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0 lstat("/opt/qtsdk-Guinault-2020.03/sysroots/x86_64-guinault-linux/usr/bin", {st_mode=S_IFDIR|0755, st_size=12288, ...}) = 0 lstat("/opt/qtsdk-Guinault-2020.03/sysroots/x86_64-guinault-linux/usr/bin/arm-linux-gnueabihf-g++", {st_mode=S_IFREG|0755, st_size=5203128, ...}) = 0 access("/opt/qtsdk-Guinault-2020.03/sysroots/x86_64-guinault-linux/usr/bin/", X_OK) = 0 access("/opt/qtsdk-Guinault-2020.03/sysroots/x86_64-guinault-linux/usr/bin/", X_OK) = 0 access("/opt/qtsdk-Guinault-2020.03/sysroots/x86_64-guinault-linux/usr/bin/", X_OK) = 0 access("/opt/qtsdk-Guinault-2020.03/sysroots/x86_64-guinault-linux/usr/bin/", X_OK) = 0 access("/opt/qtsdk-Guinault-2020.03/sysroots/x86_64-guinault-linux/usr/bin/../lib/gcc/arm-linux-gnueabihf/8.3.0/specs", R_OK) = -1 ENOENT (No such file or directory) access("/opt/qtsdk-Guinault-2020.03/sysroots/x86_64-guinault-linux/usr/bin/../lib/gcc/specs", R_OK) = -1 ENOENT (No such file or directory) access("/opt/qtsdk-Guinault-2020.03/sysroots/x86_64-guinault-linux/usr/bin/../lib/gcc/arm-linux-gnueabihf/8.3.0/../../../../arm-linux-gnueabihf/lib/arm-linux-gnueabihf/8.3.0/specs", R_OK) = -1 ENOENT (No such file or directory) access("/opt/qtsdk-Guinault-2020.03/sysroots/x86_64-guinault-linux/usr/bin/../lib/gcc/arm-linux-gnueabihf/8.3.0/../../../../arm-linux-gnueabihf/lib/specs", R_OK) = -1 ENOENT (No such file or directory) access("/lib/gcc/arm-linux-gnueabihf/specs", R_OK) = -1 ENOENT (No such file or directory) stat("/opt/qtsdk-Guinault-2020.03/sysroots/x86_64-guinault-linux/usr/bin/../libexec/gcc/arm-linux-gnueabihf/8.3.0/cc1plus", {st_mode=S_IFREG|0755, st_size=180509904, ...}) = 0 access("/opt/qtsdk-Guinault-2020.03/sysroots/x86_64-guinault-linux/usr/bin/../libexec/gcc/arm-linux-gnueabihf/8.3.0/cc1plus", X_OK) = 0 vfork(strace: Process 32060 attached <unfinished ...> [pid 32060] execve("/opt/qtsdk-Guinault-2020.03/sysroots/x86_64-guinault-linux/usr/bin/../libexec/gcc/arm-linux-gnueabihf/8.3.0/cc1plus", ["/opt/qtsdk-Guinault-2020.03/sysr"..., "-E", "-quiet", "-iprefix", "/opt/qtsdk-Guinault-2020.03/sysr"..., "-isysroot", "/opt/qtsdk-Guinault-2020.03/sysr"..., "-D_GNU_SOURCE", "-", "-o", "/dev/null", "-mthumb", "-mfpu=neon", "-mfloat-abi=hard", "-mtls-dialect=gnu", "-march=armv7-a+simd"], [/* 102 vars */] <unfinished ...> [pid 32059] <... vfork resumed> ) = 32060 [pid 32059] wait4(32060, <unfinished ...> [pid 32060] <... execve resumed> ) = 0 [pid 32060] brk(NULL) = 0x326c000 [pid 32060] access("/etc/ld.so.nohwcap", F_OK) = -1 ENOENT (No such file or directory) [pid 32060] access("/etc/ld.so.preload", R_OK) = -1 ENOENT (No such file or directory) [pid 32060] open("/etc/ld.so.cache", O_RDONLY|O_CLOEXEC) = 3 [pid 32060] fstat(3, {st_mode=S_IFREG|0644, st_size=110392, ...}) = 0 [pid 32060] mmap(NULL, 110392, PROT_READ, MAP_PRIVATE, 3, 0) = 0x7f38cdda5000 [pid 32060] close(3) = 0 [pid 32060] access("/etc/ld.so.nohwcap", F_OK) = -1 ENOENT (No such file or directory) [pid 32060] open("/lib/x86_64-linux-gnu/libdl.so.2", O_RDONLY|O_CLOEXEC) = 3 [pid 32060] read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\200\r\0\0\0\0\0\0"..., 832) = 832 [pid 32060] fstat(3, {st_mode=S_IFREG|0644, st_size=14640, ...}) = 0 [pid 32060] mmap(NULL, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7f38cdda3000 [pid 32060] mmap(NULL, 2109680, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f38cd999000 [pid 32060] mprotect(0x7f38cd99c000, 2093056, PROT_NONE) = 0 [pid 32060] mmap(0x7f38cdb9b000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x2000) = 0x7f38cdb9b000 [pid 32060] close(3) = 0 [pid 32060] access("/etc/ld.so.nohwcap", F_OK) = -1 ENOENT (No such file or directory) [pid 32060] open("/lib/x86_64-linux-gnu/libm.so.6", O_RDONLY|O_CLOEXEC) = 3 [pid 32060] read(3, "\177ELF\2\1\1\3\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\200V\0\0\0\0\0\0"..., 832) = 832 [pid 32060] fstat(3, {st_mode=S_IFREG|0644, st_size=1063328, ...}) = 0 [pid 32060] mmap(NULL, 3158248, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f38cd695000 [pid 32060] mprotect(0x7f38cd798000, 2093056, PROT_NONE) = 0 [pid 32060] mmap(0x7f38cd997000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x102000) = 0x7f38cd997000 [pid 32060] close(3) = 0 [pid 32060] access("/etc/ld.so.nohwcap", F_OK) = -1 ENOENT (No such file or directory) [pid 32060] open("/lib/x86_64-linux-gnu/libc.so.6", O_RDONLY|O_CLOEXEC) = 3 [pid 32060] read(3, "\177ELF\2\1\1\3\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\0\4\2\0\0\0\0\0"..., 832) = 832 [pid 32060] fstat(3, {st_mode=S_IFREG|0755, st_size=1689360, ...}) = 0 [pid 32060] mmap(NULL, 3795296, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f38cd2f6000 [pid 32060] mprotect(0x7f38cd48b000, 2097152, PROT_NONE) = 0 [pid 32060] mmap(0x7f38cd68b000, 24576, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x195000) = 0x7f38cd68b000 [pid 32060] mmap(0x7f38cd691000, 14688, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x7f38cd691000 [pid 32060] close(3) = 0 [pid 32060] mmap(NULL, 12288, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7f38cdda0000 [pid 32060] arch_prctl(ARCH_SET_FS, 0x7f38cdda0840) = 0 [pid 32060] mprotect(0x7f38cd68b000, 16384, PROT_READ) = 0 [pid 32060] mprotect(0x7f38cd997000, 4096, PROT_READ) = 0 [pid 32060] mprotect(0x7f38cdb9b000, 4096, PROT_READ) = 0 [pid 32060] mprotect(0x7f38cddc0000, 4096, PROT_READ) = 0 [pid 32060] munmap(0x7f38cdda5000, 110392) = 0 [pid 32060] brk(NULL) = 0x326c000 [pid 32060] brk(0x328d000) = 0x328d000 [pid 32060] getrlimit(RLIMIT_STACK, {rlim_cur=65536*1024, rlim_max=RLIM64_INFINITY}) = 0 [pid 32060] open("/usr/lib/locale/locale-archive", O_RDONLY|O_CLOEXEC) = 3 [pid 32060] fstat(3, {st_mode=S_IFREG|0644, st_size=1683408, ...}) = 0 [pid 32060] mmap(NULL, 1683408, PROT_READ, MAP_PRIVATE, 3, 0) = 0x7f38cdc05000 [pid 32060] close(3) = 0 [pid 32060] open("/usr/share/locale/locale.alias", O_RDONLY|O_CLOEXEC) = 3 [pid 32060] fstat(3, {st_mode=S_IFREG|0644, st_size=2995, ...}) = 0 [pid 32060] read(3, "# Locale name alias data base.\n#"..., 4096) = 2995 [pid 32060] read(3, "", 4096) = 0 [pid 32060] close(3) = 0 [pid 32060] open("/share/locale/en_US.UTF-8/LC_MESSAGES/gcc.mo", O_RDONLY) = -1 ENOENT (No such file or directory) [pid 32060] open("/share/locale/en_US.utf8/LC_MESSAGES/gcc.mo", O_RDONLY) = -1 ENOENT (No such file or directory) [pid 32060] open("/share/locale/en_US/LC_MESSAGES/gcc.mo", O_RDONLY) = -1 ENOENT (No such file or directory) [pid 32060] open("/share/locale/en.UTF-8/LC_MESSAGES/gcc.mo", O_RDONLY) = -1 ENOENT (No such file or directory) [pid 32060] open("/share/locale/en.utf8/LC_MESSAGES/gcc.mo", O_RDONLY) = -1 ENOENT (No such file or directory) [pid 32060] open("/share/locale/en/LC_MESSAGES/gcc.mo", O_RDONLY) = -1 ENOENT (No such file or directory) [pid 32060] ioctl(2, TCGETS, {B38400 opost isig icanon echo ...}) = 0 [pid 32060] ioctl(0, TIOCGWINSZ, 0x7fffdee6e740) = -1 ENOTTY (Inappropriate ioctl for device) [pid 32060] rt_sigaction(SIGSEGV, {sa_handler=0xb4cc50, sa_mask=[SEGV], sa_flags=SA_RESTORER|SA_RESTART, sa_restorer=0x7f38cd329060}, {sa_handler=SIG_DFL, sa_mask=[], sa_flags=0}, 8) = 0 [pid 32060] rt_sigaction(SIGILL, {sa_handler=0xb4cc50, sa_mask=[ILL], sa_flags=SA_RESTORER|SA_RESTART, sa_restorer=0x7f38cd329060}, {sa_handler=SIG_DFL, sa_mask=[], sa_flags=0}, 8) = 0 [pid 32060] rt_sigaction(SIGBUS, {sa_handler=0xb4cc50, sa_mask=[BUS], sa_flags=SA_RESTORER|SA_RESTART, sa_restorer=0x7f38cd329060}, {sa_handler=SIG_DFL, sa_mask=[], sa_flags=0}, 8) = 0 [pid 32060] rt_sigaction(SIGABRT, {sa_handler=0xb4cc50, sa_mask=[ABRT], sa_flags=SA_RESTORER|SA_RESTART, sa_restorer=0x7f38cd329060}, {sa_handler=SIG_DFL, sa_mask=[], sa_flags=0}, 8) = 0 [pid 32060] rt_sigaction(SIGFPE, {sa_handler=0xb4cc50, sa_mask=[FPE], sa_flags=SA_RESTORER|SA_RESTART, sa_restorer=0x7f38cd329060}, {sa_handler=SIG_DFL, sa_mask=[], sa_flags=0}, 8) = 0 [pid 32060] mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7f38cddbf000 [pid 32060] mmap(NULL, 135168, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7f38cdbe4000 [pid 32060] mmap(NULL, 2097152, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7f38cd0f6000 [pid 32060] mmap(NULL, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7f38cddbd000 [pid 32060] mmap(NULL, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7f38cddbb000 [pid 32060] mmap(NULL, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7f38cddb9000 [pid 32060] mmap(NULL, 16384, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7f38cddb5000 [pid 32060] mmap(NULL, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7f38cddb3000 [pid 32060] sysinfo({uptime=12102, loads=[2144, 768, 32], totalram=10322219008, freeram=138964992, sharedram=13680640, bufferram=427089920, totalswap=7338979328, freeswap=7275479040, procs=313, totalhigh=0, freehigh=0, mem_unit=1}) = 0 [pid 32060] getrlimit(RLIMIT_AS, {rlim_cur=RLIM64_INFINITY, rlim_max=RLIM64_INFINITY}) = 0 [pid 32060] sysinfo({uptime=12102, loads=[2144, 768, 32], totalram=10322219008, freeram=138964992, sharedram=13680640, bufferram=427089920, totalswap=7338979328, freeswap=7275479040, procs=313, totalhigh=0, freehigh=0, mem_unit=1}) = 0 [pid 32060] getrlimit(RLIMIT_AS, {rlim_cur=RLIM64_INFINITY, rlim_max=RLIM64_INFINITY}) = 0 [pid 32060] getrlimit(RLIMIT_RSS, {rlim_cur=RLIM64_INFINITY, rlim_max=RLIM64_INFINITY}) = 0 [pid 32060] sysinfo({uptime=12102, loads=[2144, 768, 32], totalram=10322219008, freeram=138964992, sharedram=13680640, bufferram=427089920, totalswap=7338979328, freeswap=7275479040, procs=313, totalhigh=0, freehigh=0, mem_unit=1}) = 0 [pid 32060] getrlimit(RLIMIT_AS, {rlim_cur=RLIM64_INFINITY, rlim_max=RLIM64_INFINITY}) = 0 [pid 32060] brk(0x32b8000) = 0x32b8000 [pid 32060] ioctl(2, TCGETS, {B38400 opost isig icanon echo ...}) = 0 [pid 32060] brk(0x32e0000) = 0x32e0000 [pid 32060] lstat("/opt", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0 [pid 32060] lstat("/opt/qtsdk-Guinault-2020.03", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0 [pid 32060] lstat("/opt/qtsdk-Guinault-2020.03/sysroots", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0 [pid 32060] lstat("/opt/qtsdk-Guinault-2020.03/sysroots/x86_64-guinault-linux", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0 [pid 32060] lstat("/opt/qtsdk-Guinault-2020.03/sysroots/x86_64-guinault-linux/usr", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0 [pid 32060] lstat("/opt/qtsdk-Guinault-2020.03/sysroots/x86_64-guinault-linux/usr/bin", {st_mode=S_IFDIR|0755, st_size=12288, ...}) = 0 [pid 32060] lstat("/opt/qtsdk-Guinault-2020.03/sysroots/x86_64-guinault-linux/usr/lib", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0 [pid 32060] lstat("/opt/qtsdk-Guinault-2020.03/sysroots/x86_64-guinault-linux/usr/lib/gcc", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0 [pid 32060] lstat("/opt/qtsdk-Guinault-2020.03/sysroots/x86_64-guinault-linux/usr/lib/gcc/dummy", 0x7fffdee6d510) = -1 ENOENT (No such file or directory) [pid 32060] access("/opt/qtsdk-Guinault-2020.03/sysroots/x86_64-guinault-linux/usr/bin/", X_OK) = 0 [pid 32060] access("/opt/qtsdk-Guinault-2020.03/sysroots/x86_64-guinault-linux/usr/bin/", X_OK) = 0 [pid 32060] access("/opt/qtsdk-Guinault-2020.03/sysroots/x86_64-guinault-linux/usr/bin/", X_OK) = 0 [pid 32060] access("/opt/qtsdk-Guinault-2020.03/sysroots/x86_64-guinault-linux/usr/bin/", X_OK) = 0 [pid 32060] access("/opt/qtsdk-Guinault-2020.03/sysroots/x86_64-guinault-linux/usr/bin/", X_OK) = 0 [pid 32060] access("/opt/qtsdk-Guinault-2020.03/sysroots/x86_64-guinault-linux/usr/bin/", X_OK) = 0 [pid 32060] stat("/opt/qtsdk-Guinault-2020.03/sysroots/x86_64-guinault-linux/usr/bin/../lib/gcc/arm-linux-gnueabihf/8.3.0/../../../../arm-linux-gnueabihf/include/c++/8.3.0", 0x7fffdee6e620) = -1 ENOENT (No such file or directory) [pid 32060] stat("/opt/qtsdk-Guinault-2020.03/sysroots/x86_64-guinault-linux/usr/bin/../lib/gcc/arm-linux-gnueabihf/8.3.0/../../../../arm-linux-gnueabihf/include/c++/8.3.0/arm-linux-gnueabihf", 0x7fffdee6e620) = -1 ENOENT (No such file or directory) [pid 32060] stat("/opt/qtsdk-Guinault-2020.03/sysroots/x86_64-guinault-linux/usr/bin/../lib/gcc/arm-linux-gnueabihf/8.3.0/../../../../arm-linux-gnueabihf/include/c++/8.3.0/backward", 0x7fffdee6e620) = -1 ENOENT (No such file or directory) [pid 32060] stat("/opt/qtsdk-Guinault-2020.03/sysroots/x86_64-guinault-linux/usr/bin/../lib/gcc/arm-linux-gnueabihf/8.3.0/include", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0 [pid 32060] stat("/opt/qtsdk-Guinault-2020.03/sysroots/x86_64-guinault-linux/usr/bin/../lib/gcc/arm-linux-gnueabihf/8.3.0/include-fixed", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0 [pid 32060] stat("/opt/qtsdk-Guinault-2020.03/sysroots/x86_64-guinault-linux/usr/bin/../lib/gcc/arm-linux-gnueabihf/8.3.0/../../../../arm-linux-gnueabihf/include", 0x7fffdee6e620) = -1 ENOENT (No such file or directory) [pid 32060] stat("/opt/qtsdk-Guinault-2020.03/sysroots/x86_64-guinault-linux/usr/bin/../lib/gcc/../../lib/gcc/arm-linux-gnueabihf/8.3.0/../../../../arm-linux-gnueabihf/include/c++/8.3.0", 0x7fffdee6e620) = -1 ENOENT (No such file or directory) [pid 32060] stat("/opt/qtsdk-Guinault-2020.03/sysroots/x86_64-guinault-linux/usr/bin/../lib/gcc/../../lib/gcc/arm-linux-gnueabihf/8.3.0/../../../../arm-linux-gnueabihf/include/c++/8.3.0/arm-linux-gnueabihf", 0x7fffdee6e620) = -1 ENOENT (No such file or directory) [pid 32060] stat("/opt/qtsdk-Guinault-2020.03/sysroots/x86_64-guinault-linux/usr/bin/../lib/gcc/../../lib/gcc/arm-linux-gnueabihf/8.3.0/../../../../arm-linux-gnueabihf/include/c++/8.3.0/backward", 0x7fffdee6e620) = -1 ENOENT (No such file or directory) [pid 32060] stat("/opt/qtsdk-Guinault-2020.03/sysroots/x86_64-guinault-linux/usr/bin/../lib/gcc/../../lib/gcc/arm-linux-gnueabihf/8.3.0/include", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0 [pid 32060] stat("/opt/qtsdk-Guinault-2020.03/sysroots/armv7at2hf-neon-linux-gnueabi/usr/local/include", 0x7fffdee6e620) = -1 ENOENT (No such file or directory) [pid 32060] stat("/opt/qtsdk-Guinault-2020.03/sysroots/x86_64-guinault-linux/usr/bin/../lib/gcc/../../lib/gcc/arm-linux-gnueabihf/8.3.0/include-fixed", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0 [pid 32060] stat("/opt/qtsdk-Guinault-2020.03/sysroots/x86_64-guinault-linux/usr/bin/../lib/gcc/../../lib/gcc/arm-linux-gnueabihf/8.3.0/../../../../arm-linux-gnueabihf/include", 0x7fffdee6e620) = -1 ENOENT (No such file or directory) [pid 32060] stat("/opt/qtsdk-Guinault-2020.03/sysroots/armv7at2hf-neon-linux-gnueabi/usr/include", {st_mode=S_IFDIR|0755, st_size=16384, ...}) = 0 [pid 32060] open("/dev/null", O_WRONLY|O_CREAT|O_TRUNC, 0666) = 3 [pid 32060] fstat(0, {st_mode=S_IFIFO|0600, st_size=0, ...}) = 0 [pid 32060] read(0, "#include <type_traits>\n", 8192) = 23 [pid 32060] read(0, "", 8169) = 0 [pid 32060] close(0) = 0 [pid 32060] mmap(NULL, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7f38cddb1000 [pid 32060] fstat(3, {st_mode=S_IFCHR|0666, st_rdev=makedev(1, 3), ...}) = 0 [pid 32060] ioctl(3, TCGETS, 0x7fffdee6ddf0) = -1 ENOTTY (Inappropriate ioctl for device) [pid 32060] brk(0x330b000) = 0x330b000 [pid 32060] lstat("/opt", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0 [pid 32060] lstat("/opt/qtsdk-Guinault-2020.03", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0 [pid 32060] lstat("/opt/qtsdk-Guinault-2020.03/sysroots", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0 [pid 32060] lstat("/opt/qtsdk-Guinault-2020.03/sysroots/x86_64-guinault-linux", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0 [pid 32060] lstat("/opt/qtsdk-Guinault-2020.03/sysroots/x86_64-guinault-linux/usr", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0 [pid 32060] lstat("/opt/qtsdk-Guinault-2020.03/sysroots/x86_64-guinault-linux/usr/bin", {st_mode=S_IFDIR|0755, st_size=12288, ...}) = 0 [pid 32060] lstat("/opt/qtsdk-Guinault-2020.03/sysroots/x86_64-guinault-linux/usr/lib", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0 [pid 32060] lstat("/opt/qtsdk-Guinault-2020.03/sysroots/x86_64-guinault-linux/usr/lib/gcc", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0 [pid 32060] lstat("/opt/qtsdk-Guinault-2020.03/sysroots/x86_64-guinault-linux/usr/lib/gcc/arm-linux-gnueabihf", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0 [pid 32060] lstat("/opt/qtsdk-Guinault-2020.03/sysroots/x86_64-guinault-linux/usr/lib/gcc/arm-linux-gnueabihf/8.3.0", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0 [pid 32060] lstat("/opt/qtsdk-Guinault-2020.03/sysroots/x86_64-guinault-linux/usr/lib/gcc/arm-linux-gnueabihf/8.3.0/include", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0 [pid 32060] lstat("/opt/qtsdk-Guinault-2020.03/sysroots/x86_64-guinault-linux/usr/lib/gcc/arm-linux-gnueabihf/8.3.0/include/stdc-predef.h", 0x7fffdee6d4b0) = -1 ENOENT (No such file or directory) [pid 32060] open("/opt/qtsdk-Guinault-2020.03/sysroots/x86_64-guinault-linux/usr/bin/../lib/gcc/arm-linux-gnueabihf/8.3.0/include/stdc-predef.h", O_RDONLY|O_NOCTTY) = -1 ENOENT (No such file or directory) [pid 32060] lstat("/opt", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0 [pid 32060] lstat("/opt/qtsdk-Guinault-2020.03", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0 [pid 32060] lstat("/opt/qtsdk-Guinault-2020.03/sysroots", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0 [pid 32060] lstat("/opt/qtsdk-Guinault-2020.03/sysroots/x86_64-guinault-linux", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0 [pid 32060] lstat("/opt/qtsdk-Guinault-2020.03/sysroots/x86_64-guinault-linux/usr", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0 [pid 32060] lstat("/opt/qtsdk-Guinault-2020.03/sysroots/x86_64-guinault-linux/usr/bin", {st_mode=S_IFDIR|0755, st_size=12288, ...}) = 0 [pid 32060] lstat("/opt/qtsdk-Guinault-2020.03/sysroots/x86_64-guinault-linux/usr/lib", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0 [pid 32060] lstat("/opt/qtsdk-Guinault-2020.03/sysroots/x86_64-guinault-linux/usr/lib/gcc", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0 [pid 32060] lstat("/opt/qtsdk-Guinault-2020.03/sysroots/x86_64-guinault-linux/usr/lib/gcc/arm-linux-gnueabihf", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0 [pid 32060] lstat("/opt/qtsdk-Guinault-2020.03/sysroots/x86_64-guinault-linux/usr/lib/gcc/arm-linux-gnueabihf/8.3.0", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0 [pid 32060] lstat("/opt/qtsdk-Guinault-2020.03/sysroots/x86_64-guinault-linux/usr/lib/gcc/arm-linux-gnueabihf/8.3.0/include-fixed", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0 [pid 32060] lstat("/opt/qtsdk-Guinault-2020.03/sysroots/x86_64-guinault-linux/usr/lib/gcc/arm-linux-gnueabihf/8.3.0/include-fixed/stdc-predef.h", 0x7fffdee6d4b0) = -1 ENOENT (No such file or directory) [pid 32060] open("/opt/qtsdk-Guinault-2020.03/sysroots/x86_64-guinault-linux/usr/bin/../lib/gcc/arm-linux-gnueabihf/8.3.0/include-fixed/stdc-predef.h", O_RDONLY|O_NOCTTY) = -1 ENOENT (No such file or directory) [pid 32060] lstat("/opt", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0 [pid 32060] lstat("/opt/qtsdk-Guinault-2020.03", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0 [pid 32060] lstat("/opt/qtsdk-Guinault-2020.03/sysroots", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0 [pid 32060] lstat("/opt/qtsdk-Guinault-2020.03/sysroots/armv7at2hf-neon-linux-gnueabi", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0 [pid 32060] lstat("/opt/qtsdk-Guinault-2020.03/sysroots/armv7at2hf-neon-linux-gnueabi/usr", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0 [pid 32060] lstat("/opt/qtsdk-Guinault-2020.03/sysroots/armv7at2hf-neon-linux-gnueabi/usr/include", {st_mode=S_IFDIR|0755, st_size=16384, ...}) = 0 [pid 32060] lstat("/opt/qtsdk-Guinault-2020.03/sysroots/armv7at2hf-neon-linux-gnueabi/usr/include/stdc-predef.h", {st_mode=S_IFREG|0644, st_size=2289, ...}) = 0 [pid 32060] open("/opt/qtsdk-Guinault-2020.03/sysroots/armv7at2hf-neon-linux-gnueabi/usr/include/stdc-predef.h", O_RDONLY|O_NOCTTY) = 0 [pid 32060] fstat(0, {st_mode=S_IFREG|0644, st_size=2289, ...}) = 0 [pid 32060] read(0, "/* Copyright (C) 1991-2018 Free "..., 2289) = 2289 [pid 32060] close(0) = 0 [pid 32060] mmap(NULL, 16384, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7f38cddad000 [pid 32060] lstat("/opt", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0 [pid 32060] lstat("/opt/qtsdk-Guinault-2020.03", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0 [pid 32060] lstat("/opt/qtsdk-Guinault-2020.03/sysroots", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0 [pid 32060] lstat("/opt/qtsdk-Guinault-2020.03/sysroots/x86_64-guinault-linux", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0 [pid 32060] lstat("/opt/qtsdk-Guinault-2020.03/sysroots/x86_64-guinault-linux/usr", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0 [pid 32060] lstat("/opt/qtsdk-Guinault-2020.03/sysroots/x86_64-guinault-linux/usr/bin", {st_mode=S_IFDIR|0755, st_size=12288, ...}) = 0 [pid 32060] lstat("/opt/qtsdk-Guinault-2020.03/sysroots/x86_64-guinault-linux/usr/lib", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0 [pid 32060] lstat("/opt/qtsdk-Guinault-2020.03/sysroots/x86_64-guinault-linux/usr/lib/gcc", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0 [pid 32060] lstat("/opt/qtsdk-Guinault-2020.03/sysroots/x86_64-guinault-linux/usr/lib/gcc/arm-linux-gnueabihf", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0 [pid 32060] lstat("/opt/qtsdk-Guinault-2020.03/sysroots/x86_64-guinault-linux/usr/lib/gcc/arm-linux-gnueabihf/8.3.0", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0 [pid 32060] lstat("/opt/qtsdk-Guinault-2020.03/sysroots/x86_64-guinault-linux/usr/lib/gcc/arm-linux-gnueabihf/8.3.0/include", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0 [pid 32060] lstat("/opt/qtsdk-Guinault-2020.03/sysroots/x86_64-guinault-linux/usr/lib/gcc/arm-linux-gnueabihf/8.3.0/include/type_traits", 0x7fffdee6d2d0) = -1 ENOENT (No such file or directory) [pid 32060] open("/opt/qtsdk-Guinault-2020.03/sysroots/x86_64-guinault-linux/usr/bin/../lib/gcc/arm-linux-gnueabihf/8.3.0/include/type_traits", O_RDONLY|O_NOCTTY) = -1 ENOENT (No such file or directory) [pid 32060] lstat("/opt", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0 [pid 32060] lstat("/opt/qtsdk-Guinault-2020.03", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0 [pid 32060] lstat("/opt/qtsdk-Guinault-2020.03/sysroots", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0 [pid 32060] lstat("/opt/qtsdk-Guinault-2020.03/sysroots/x86_64-guinault-linux", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0 [pid 32060] lstat("/opt/qtsdk-Guinault-2020.03/sysroots/x86_64-guinault-linux/usr", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0 [pid 32060] lstat("/opt/qtsdk-Guinault-2020.03/sysroots/x86_64-guinault-linux/usr/bin", {st_mode=S_IFDIR|0755, st_size=12288, ...}) = 0 [pid 32060] lstat("/opt/qtsdk-Guinault-2020.03/sysroots/x86_64-guinault-linux/usr/lib", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0 [pid 32060] lstat("/opt/qtsdk-Guinault-2020.03/sysroots/x86_64-guinault-linux/usr/lib/gcc", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0 [pid 32060] lstat("/opt/qtsdk-Guinault-2020.03/sysroots/x86_64-guinault-linux/usr/lib/gcc/arm-linux-gnueabihf", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0 [pid 32060] lstat("/opt/qtsdk-Guinault-2020.03/sysroots/x86_64-guinault-linux/usr/lib/gcc/arm-linux-gnueabihf/8.3.0", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0 [pid 32060] lstat("/opt/qtsdk-Guinault-2020.03/sysroots/x86_64-guinault-linux/usr/lib/gcc/arm-linux-gnueabihf/8.3.0/include-fixed", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0 [pid 32060] lstat("/opt/qtsdk-Guinault-2020.03/sysroots/x86_64-guinault-linux/usr/lib/gcc/arm-linux-gnueabihf/8.3.0/include-fixed/type_traits", 0x7fffdee6d2d0) = -1 ENOENT (No such file or directory) [pid 32060] open("/opt/qtsdk-Guinault-2020.03/sysroots/x86_64-guinault-linux/usr/bin/../lib/gcc/arm-linux-gnueabihf/8.3.0/include-fixed/type_traits", O_RDONLY|O_NOCTTY) = -1 ENOENT (No such file or directory) [pid 32060] lstat("/opt", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0 [pid 32060] lstat("/opt/qtsdk-Guinault-2020.03", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0 [pid 32060] lstat("/opt/qtsdk-Guinault-2020.03/sysroots", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0 [pid 32060] lstat("/opt/qtsdk-Guinault-2020.03/sysroots/armv7at2hf-neon-linux-gnueabi", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0 [pid 32060] lstat("/opt/qtsdk-Guinault-2020.03/sysroots/armv7at2hf-neon-linux-gnueabi/usr", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0 [pid 32060] lstat("/opt/qtsdk-Guinault-2020.03/sysroots/armv7at2hf-neon-linux-gnueabi/usr/include", {st_mode=S_IFDIR|0755, st_size=16384, ...}) = 0 [pid 32060] lstat("/opt/qtsdk-Guinault-2020.03/sysroots/armv7at2hf-neon-linux-gnueabi/usr/include/type_traits", 0x7fffdee6d2d0) = -1 ENOENT (No such file or directory) [pid 32060] open("/opt/qtsdk-Guinault-2020.03/sysroots/armv7at2hf-neon-linux-gnueabi/usr/include/type_traits", O_RDONLY|O_NOCTTY) = -1 ENOENT (No such file or directory) [pid 32060] open("/usr/share/locale/en_US.UTF-8/LC_MESSAGES/libc.mo", O_RDONLY) = -1 ENOENT (No such file or directory) [pid 32060] open("/usr/share/locale/en_US.utf8/LC_MESSAGES/libc.mo", O_RDONLY) = -1 ENOENT (No such file or directory) [pid 32060] open("/usr/share/locale/en_US/LC_MESSAGES/libc.mo", O_RDONLY) = -1 ENOENT (No such file or directory) [pid 32060] open("/usr/share/locale/en.UTF-8/LC_MESSAGES/libc.mo", O_RDONLY) = -1 ENOENT (No such file or directory) [pid 32060] open("/usr/share/locale/en.utf8/LC_MESSAGES/libc.mo", O_RDONLY) = -1 ENOENT (No such file or directory) [pid 32060] open("/usr/share/locale/en/LC_MESSAGES/libc.mo", O_RDONLY) = -1 ENOENT (No such file or directory) [pid 32060] open("/share/locale/en_US.UTF-8/LC_MESSAGES/cpplib.mo", O_RDONLY) = -1 ENOENT (No such file or directory) [pid 32060] open("/share/locale/en_US.utf8/LC_MESSAGES/cpplib.mo", O_RDONLY) = -1 ENOENT (No such file or directory) [pid 32060] open("/share/locale/en_US/LC_MESSAGES/cpplib.mo", O_RDONLY) = -1 ENOENT (No such file or directory) [pid 32060] open("/share/locale/en.UTF-8/LC_MESSAGES/cpplib.mo", O_RDONLY) = -1 ENOENT (No such file or directory) [pid 32060] open("/share/locale/en.utf8/LC_MESSAGES/cpplib.mo", O_RDONLY) = -1 ENOENT (No such file or directory) [pid 32060] open("/share/locale/en/LC_MESSAGES/cpplib.mo", O_RDONLY) = -1 ENOENT (No such file or directory) [pid 32060] open("<stdin>", O_RDONLY) = -1 ENOENT (No such file or directory) [pid 32060] open("<stdin>", O_RDONLY) = -1 ENOENT (No such file or directory) [pid 32060] write(2, "\33[01m\33[K<stdin>:1:10:\33[m\33[K \33[01"..., 97<stdin>:1:10: fatal error: type_traits: No such file or directory ) = 97 [pid 32060] write(2, "compilation terminated.\n", 24compilation terminated. ) = 24 [pid 32060] write(3, "# 1 \"<stdin>\"\n# 1 \"<built-in>\"\n#"..., 194) = 194 [pid 32060] exit_group(1) = ? [pid 32060] +++ exited with 1 +++ <... wait4 resumed> [{WIFEXITED(s) && WEXITSTATUS(s) == 1}], 0, NULL) = 32060 --- SIGCHLD {si_signo=SIGCHLD, si_code=CLD_EXITED, si_pid=32060, si_uid=0, si_status=1, si_utime=0, si_stime=0} --- stat("/dev/null", {st_mode=S_IFCHR|0666, st_rdev=makedev(1, 3), ...}) = 0 exit_group(1) = ? +++ exited with 1 +++
I would like to point out that I sourced the environment script before the build.
Any clues on my issue ?
Thank you
Sébastien C
