Part Number: AM3354
Hi all
I have one question about falcon mode in u-boot.
I used am335x custom Board.
I read below that uboot doc
- /doc/README.falcon
- /board/ti/am335x/README
I tried to modified uboot source code to use falcon mode FAT SD cards , I have a problem and I'm hoping that someone can help me.
it looks like args and umage are loaded but the process hang in Datei "include/blk.h" , in Function "blk_dread".
can someone tell me what could be the problem
DEBUG:
U-Boot SPL 2020.01-g15255345a (May 15 2020 - 09:34:59 +0000)
Trying to boot from MMC1
clock is disabled (0Hz)
clock is enabled (400000Hz)
clock is enabled (50000000Hz)
in Datei include/blk.h
in Function blk_dread
befor: blks_read = block_dev->block_read(block_dev, start, blkcnt, buffer)
after: blks_read = block_dev->block_read(block_dev, start, blkcnt, buffer)
part_init: try 'DOS': ret=0
spl: mmc boot mode: fs
in Datei fs/fat/fat.c
in Function disk_read
befor: ret = blk_dread(cur_dev, cur_part_info.start + block, nr_blocks, buf)
after: ret = blk_dread(cur_dev, cur_part_info.start + block, nr_blocks, buf)
FAT16, fat_sect: 8, fatlength: 136
Rootdir begins at cluster: 0, sector: 280, offset: 23000
Data begins at: 296
Sector size: 512, cluster size: 8
FAT read(sect=280), clust_size=8, read_size=8, DIRENTSPERBLOCK=d
reading args at pos u
Filesize: u bytes
u bytes
FAT16: entry: 0x0000001f = 31, offset: 0x001f = 31
FAT16: ret: 0x0000008b, entry: 0x0000001f, offset: 0x001f
gc - clustnum: 31, startsect: 544
FAT16: entry: 0x0000008b = 139, offset: 0x008b = 139
FAT16: ret: 0x0000008c, entry: 0x0000008b, offset: 0x008b
FAT16: entry: 0x0000008c = 140, offset: 0x008c = 140
FAT16: ret: 0x0000008d, entry: 0x0000008c, offset: 0x008c
FAT16: entry: 0x0000008d = 141, offset: 0x008d = 141
FAT16: ret: 0x0000008e, entry: 0x0000008d, offset: 0x008d
FAT16: entry: 0x0000008e = 142, offset: 0x008e = 142
FAT16: ret: 0x0000008f, entry: 0x0000008e, offset: 0x008e
FAT16: entry: 0x0000008f = 143, offset: 0x008f = 143
FAT16: ret: 0x00000090, entry: 0x0000008f, offset: 0x008f
FAT16: entry: 0x00000090 = 144, offset: 0x0090 = 144
FAT16: ret: 0x00000091, entry: 0x00000090, offset: 0x0090
FAT16: entry: 0x00000091 = 145, offset: 0x0091 = 145
FAT16: ret: 0x00000092, entry: 0x00000091, offset: 0x0091
FAT16: entry: 0x00000092 = 146, offset: 0x0092 = 146
FAT16: ret: 0x00000093, entry: 0x00000092, offset: 0x0092
FAT16: entry: 0x00000093 = 147, offset: 0x0093 = 147
FAT16: ret: 0x00000094, entry: 0x00000093, offset: 0x0093
FAT16: entry: 0x00000094 = 148, offset: 0x0094 = 148
FAT16: ret: 0x00000095, entry: 0x00000094, offset: 0x0094
FAT16: entry: 0x00000095 = 149, offset: 0x0095 = 149
FAT16: ret: 0x00000096, entry: 0x00000095, offset: 0x0095
FAT16: entry: 0x00000096 = 150, offset: 0x0096 = 150
FAT16: ret: 0x00000097, entry: 0x00000096, offset: 0x0096
FAT16: entry: 0x00000097 = 151, offset: 0x0097 = 151
FAT16: ret: 0x00000098, entry: 0x00000097, offset: 0x0097
FAT16: entry: 0x00000098 = 152, offset: 0x0098 = 152
FAT16: ret: 0x00000099, entry: 0x00000098, offset: 0x0098
FAT16: entry: 0x00000099 = 153, offset: 0x0099 = 153
FAT16: ret: 0x0000009a, entry: 0x00000099, offset: 0x0099
FAT16: entry: 0x0000009a = 154, offset: 0x009a = 154
FAT16: ret: 0x0000009b, entry: 0x0000009a, offset: 0x009a
FAT16: entry: 0x0000009b = 155, offset: 0x009b = 155
FAT16: ret: 0x0000009c, entry: 0x0000009b, offset: 0x009b
FAT16: entry: 0x0000009c = 156, offset: 0x009c = 156
FAT16: ret: 0x0000009d, entry: 0x0000009c, offset: 0x009c
FAT16: entry: 0x0000009d = 157, offset: 0x009d = 157
FAT16: ret: 0x0000009e, entry: 0x0000009d, offset: 0x009d
FAT16: entry: 0x0000009e = 158, offset: 0x009e = 158
FAT16: ret: 0x0000009f, entry: 0x0000009e, offset: 0x009e
FAT16: entry: 0x0000009f = 159, offset: 0x009f = 159
FAT16: ret: 0x000000a0, entry: 0x0000009f, offset: 0x009f
FAT16: entry: 0x000000a0 = 160, offset: 0x00a0 = 160
FAT16: ret: 0x000000a1, entry: 0x000000a0, offset: 0x00a0
gc - clustnum: 139, startsect: 1408
Data begins at: 296
reading uImage at pos u
Filesize: u bytes
u bytes
gc - clustnum: 1653, startsect: 13520
SPL: payload image: Linux-5.4.17-ge0fb72763f load addr: 0x80007fc0 size: 5759664
Data begins at: 296
Filesize: u bytes
u bytes
FAT16: entry: 0x00000675 = 1653, offset: 0x0075 = 117
FAT16: ret: 0x00000676, entry: 0x00000675, offset: 0x0075
FAT16: entry: 0x00000676 = 1654, offset: 0x0076 = 118
FAT16: ret: 0x00000677, entry: 0x00000676, offset: 0x0076
FAT16: entry: 0x00000677 = 1655, offset: 0x0077 = 119
FAT16: ret: 0x00000678, entry: 0x00000677, offset: 0x0077
FAT16: entry: 0x00000678 = 1656, offset: 0x0078 = 120
FAT16: ret: 0x00000679, entry: 0x00000678, offset: 0x0078
FAT16: entry: 0x00000679 = 1657, offset: 0x0079 = 121
FAT16: ret: 0x0000067a, entry: 0x00000679, offset: 0x0079
FAT16: entry: 0x0000067a = 1658, offset: 0x007a = 122
FAT16: ret: 0x0000067b, entry: 0x0000067a, offset: 0x007a
FAT16: entry: 0x0000067b = 1659, offset: 0x007b = 123
FAT16: ret: 0x0000067c, entry: 0x0000067b, offset: 0x007b
FAT16: entry: 0x0000067c = 1660, offset: 0x007c = 124
FAT16: ret: 0x0000067d, entry: 0x0000067c, offset: 0x007c
FAT16: entry: 0x0000067d = 1661, offset: 0x007d = 125
FAT16: ret: 0x0000067e, entry: 0x0000067d, offset: 0x007d
FAT16: entry: 0x0000067e = 1662, offset: 0x007e = 126
FAT16: ret: 0x0000067f, entry: 0x0000067e, offset: 0x007e
FAT16: ret: 0x00000bf1, entry: 0x00000bf0, offset: 0x05f0
FAT16: entry: 0x00000bf1 = 3057, offset: 0x05f1 = 1521
FAT16: ret: 0x00000bf2, entry: 0x00000bf1, offset: 0x05f1
FAT16: entry: 0x00000bf2 = 3058, offset: 0x05f2 = 1522
FAT16: ret: 0x00000bf3, entry: 0x00000bf2, offset: 0x05f2
