AM3358: RMII ping fails in U-boot
Genius 13655 points
Part Number: AM3358
Hello Champions,
Customer used AM3358 MII2 + KSZ8041 PHY, it can linkup successfully, but it can't ping in uboot.
The uboot version is 2018.07.
Can the MII2 be used in uboot?
Below are the circuit, pinmux, dts and log information.
Pinmux in uboot:
static struct module_pin_mux rmii2_pin_mux[] = {
{OFFSET(mdio_clk), MODE(0) | PULLUP_EN}, /* MDIO_CLK */
{OFFSET(mdio_data), MODE(0) | RXACTIVE | PULLUP_EN}, /* MDIO_DATA */
{OFFSET(gpmc_csn3), MODE(2) | RXACTIVE}, /* MII2_CRS *//* gpmc_csn3.rmmii2_crs_dv */
{OFFSET(gpmc_wpn), MODE(3) | RXACTIVE}, /* MII2_RXERR *//* gpmc_wpn.rmmii2_rxer */
{OFFSET(gpmc_a0), MODE(3)}, /* MII2_TXEN */ /* gpmc_a0.rmmii2_txen */
{OFFSET(gpmc_a4), MODE(3)}, /* MII1_TXD1 */ /* gpmc_a4.rmmii2_txd1 */
{OFFSET(gpmc_a5), MODE(3)}, /* MII1_TXD0 */ /* gpmc_a5.rmmii2_txd0 */
{OFFSET(gpmc_a10), MODE(3) | RXACTIVE}, /* MII1_RXD1 *//* gpmc_a10.rmmii2_rxd1 */
{OFFSET(gpmc_a11), MODE(3) | RXACTIVE}, /* MII1_RXD0 *//* gpmc_a11.rmmii2_rxd0 */
{OFFSET(mii1_col), MODE(1) | RXACTIVE}, /* RMII1_REFCLK *//* gpmc_a11.rmmii2_REFCLK */
{-1},
DTS:
/*net*/
cpsw_default: cpsw_default {
pinctrl-single,pins = <
AM33XX_IOPAD(0x840, PIN_OUTPUT_PULLDOWN | MUX_MODE3) /* gpmc_a0.rmmii2_txen */
AM33XX_IOPAD(0x854, PIN_OUTPUT_PULLDOWN | MUX_MODE3) /* gpmc_a5.rmmii2_txd0 */
AM33XX_IOPAD(0x850, PIN_OUTPUT_PULLDOWN | MUX_MODE3) /* gpmc_a4.rmmii2_txd1 */
AM33XX_IOPAD(0x874, PIN_INPUT_PULLDOWN | MUX_MODE3) /* gpmc_wpn.rmmii2_rxer */
AM33XX_IOPAD(0x888, PIN_INPUT_PULLDOWN | MUX_MODE2) /* gpmc_csn3.rmmii2_crs_dv */
AM33XX_IOPAD(0x86c, PIN_INPUT_PULLDOWN | MUX_MODE3) /* gpmc_a11.rmmii2_rxd0 */
AM33XX_IOPAD(0x868, PIN_INPUT_PULLDOWN | MUX_MODE3) /* gpmc_a11.rmmii2_rxd1 */
AM33XX_IOPAD(0x908, PIN_INPUT_PULLDOWN | MUX_MODE1) /* gpmc_a11.rmmii2_REFCLK */
davinci_mdio_default: davinci_mdio_default {
/* MDIO */
AM33XX_IOPAD(0x948, PIN_INPUT_PULLUP | SLEWCTRL_FAST | MUX_MODE0) /* mdio_data.mdio_data */
AM33XX_IOPAD(0x94c, PIN_OUTPUT_PULLUP | MUX_MODE0) /* mdio_clk.mdio_clk */
gpio_mdio_default: gpio_mdio_default {
/* MDIO via GPIO*/
AM33XX_IOPAD(0x948, PIN_INPUT | MUX_MODE7) /* mdio_data.mdio_data GPIO0_0*/
AM33XX_IOPAD(0x94c, PIN_OUTPUT| MUX_MODE7) /* mdio_clk.mdio_clk GPIO0_1 */
&mac {
pinctrl-names = "default";
pinctrl-0 = <&cpsw_default>;
slaves = <1>; /* use only one emac if */
status = "okay";
mdio0: gpio {
compatible = "mdio-gpio";
pinctrl-0 = <&gpio_mdio_default>;
#address-cells = <1>;
#size-cells = <0>;
gpios = <&gpio0 1 GPIO_ACTIVE_HIGH /* MDIO-CLK */
&gpio0 0 GPIO_ACTIVE_HIGH>; /* MDIO-DATA */
phy0: ethernet-phy@1 {
reg = <0>;
&davinci_mdio {
pinctrl-0 = <&davinci_mdio_default>;
status = "disabled";
};&cpsw_emac1 {
phy_id = <&mdio0>,<2>;
phy-mode = "rmii";
&phy_sel {
rmii-clock-ext;
The log:
P:lib/initcall.c,L:25, F:initcall_run_list, i:37...
initcall: 8080f0f9 (relocated to bff480f9)
Net: F:net/eth-uclass.c, L:402, F:eth_initialize, start:
F:common/miiphyutil.c, L:66, F:miiphy_init, start:
F:drivers/net/phy/phy.c, L:474, F:phy_init, PHY USE Start:
F:drivers/net/phy/phy.c, L:512, F:phy_init, PHY USE CONFIG_PHY_MICREL_KSZ8XXX:
P:drivers/core/uclass.c,L:214, F:uclass_find_first_device, ...
F:drivers/core/uclass.c, L:36, F:uclass_find name:usb_dev_generic
F:drivers/core/uclass.c, L:36, F:uclass_find name:eth
F:drivers/core/uclass.c, L:151, F:uclass_get
F:drivers/core/uclass.c, L:156, F:uclass_get
F:drivers/core/uclass.c, L:219, F:uclass_find_first_device ret:0
F:drivers/core/uclass.c, L:228, F:uclass_find_first_device
F:drivers/core/uclass.c, L:569, F:uclass_first_device_check ret:0
P:drivers/core/device.c,L:322, F:device_probe, ...
F:drivers/core/device.c, L:354, F:device_probe
F:drivers/core/device.c, L:382, F:device_probe
uclass_find_device_by_seq: 0 -1
uclass_find_device_by_seq: 0 0
- -1 -1 'ethernet@4a100000'
- not found
F:drivers/net/cpsw.c, L:1360, F:cpsw_eth_ofdata_to_platdata
OF: ** translation for device ethernet@4a100000 **
OF: bus is default (na=1, ns=1) on ocp
OF: translating address: 0000104a
OF: parent bus is default (na=1, ns=1) on
OF: no ranges, 1:1 translation
OF: parent translation for: 00000000
OF: with offset: 1242562560
OF: one level translation: 0000104a
OF: reached root node
fdtdec_get_int: cpdma_channels: 0x8 (8)
fdtdec_get_int: slaves: 0x1 (1)
fdtdec_get_int: ale_entries: 0x400 (1024)
fdtdec_get_int: bd_ram_size: 0x2000 (8192)
fdtdec_get_int: mac_control: 0x20 (32)
gpio_get_list_count: Node 'ethernet@4a100000', property 'mode-gpios', GPIO count failed: -2
fdtdec_get_int: active_slave: 0x0 (0)
F:drivers/net/cpsw.c, L:1419, F:cpsw_eth_ofdata_to_platdata active_slave:0
fdtdec_get_addr_size_auto_noparent: fdtdec_get_addr_size_auto_parent: na=1, ns=1, fdtdec_get_addr_size_fixed: reg: addr=4a101000
fdtdec_lookup_phandle: phy-handle
fdtdec_get_int_array: phy_id
get_prop_check_min_len: phy_id
F:lib/fdtdec.c, L:676, F:fdtdec_get_int_array,prop_name:phy_id, array[0]:58
F:lib/fdtdec.c, L:676, F:fdtdec_get_int_array,prop_name:phy_id, array[1]:2
fdtdec_get_addr_size_auto_noparent: fdtdec_get_addr_size_auto_parent: na=1, ns=1, fdtdec_get_addr_size_fixed: reg: addr=44e10650
F:drivers/net/cpsw.c, L:1487, F:cpsw_eth_ofdata_to_platdata
fdtdec_lookup_phandle: syscon
OF: ** translation for device scm_conf@0 **
OF: bus is default (na=1, ns=1) on scm@210000
OF: translating address: 00000000
OF: parent bus is default (na=1, ns=1) on l4_wkup@44c00000
OF: walking ranges...
OF: default map, cp=0, s=8192, da=0
OF: parent translation for: 00002100
OF: with offset: 0
OF: one level translation: 00002100
OF: parent bus is default (na=1, ns=1) on ocp
OF: default map, cp=0, s=2621440, da=2162688
OF: parent translation for: 0000c044
OF: with offset: 2162688
OF: one level translation: 0000e144
OF: with offset: 1155596288
F:drivers/net/cpsw.c, L:1066, F:_cpsw_register, 0
F:drivers/net/cpsw.c, L:1005, F:cpsw_slave_setup slave_num:0
F:drivers/net/cpsw.c, L:1020, F:cpsw_phy_init. phy_addr:2
ethernet@4a100000 connected to Micrel KSZ804
F:drivers/net/phy/phy.c, L:393, F:genphy_config
F:net/eth-uclass.c, L:420, F:eth_initialize
eth0: ethernet@4a100000
=> mii info
MII_PHYSID2 @ 0x0 = 0x1513
PHY_PHYIDR[1,2] @ 0x0 = 0x00221513
PHY 0x00: OUI = 0x0885, Model = 0x11, Rev = 0x03, 10baseT, HDX
PHY ID register 2 read failed
MII_PHYSID2 @ 0x2 = 0x1513
PHY_PHYIDR[1,2] @ 0x2 = 0x00221513
PHY 0x02: OUI = 0x0885, Model = 0x11, Rev = 0x03, 10baseT, HDX
=> setenv ipaddr 172.30.131.108
Initial value for argc=3
Final value for argc=3
=> ping 172.30.131.73
F:net/net.c, L:412, F:net_loop protocol:5
--- net_loop Entry
--- net_loop UDP handler set (00000000)
--- net_loop ARP handler set (00000000)
--- net_loop timeout handler cancelled
F:net/eth-uclass.c, L:68, F:eth_get_dev, start:
P:drivers/core/uclass.c,L:408, F:uclass_get_device_tail, ...
F:net/net.c, L:359, F:net_init_loop net_ethaddr:0x a8.10.87.b4.3f.5f
F:drivers/net/cpsw.c, L:783, F:cpdma_process start
Trying ethernet@4a100000
F:drivers/net/cpsw.c, L:823, F:_cpsw_init
F:drivers/net/cpsw.c, L:669, F:cpsw_update_link
F:drivers/net/cpsw.c, L:623, F:cpsw_slave_update_link
F:drivers/net/phy/phy.c, L:226, F:genphy_update_link
F:drivers/net/phy/phy.c, L:234, F:genphy_update_link. mii_reg: 0x786d
link up on port 0, speed 100, full duplex
F:drivers/net/cpsw.c, L:867, F:_cpsw_init
F:drivers/net/cpsw.c, L:734, F:cpdma_submit
--- NetState set to 0
--- net_loop Init
Using ethernet@4a100000 device
--- net_loop timeout handler set (bff891e1)
sending ARP for 172.30.131.73
ARP broadcast 1
F:net/eth-uclass.c, L:337, F:eth_send, start:
F:drivers/net/cpsw.c, L:1174, F:cpsw_eth_send
F:drivers/net/cpsw.c, L:966, F:_cpsw_send
F:net/eth-uclass.c, L:363, F:eth_rx, start:
F:drivers/net/cpsw.c, L:1184, F:cpsw_eth_recv
F:drivers/net/cpsw.c, L:986, F:_cpsw_recv
F:drivers/net/cpsw.c, L:790, F:cpdma_process status:-536869390
F:drivers/net/cpsw.c, L:794, F:cpdma_process start
F:net/eth-uclass.c, L:377, F:eth_rx eth_get_ops:-16
eth_rx: recv() returned error -16
F:drivers/net/cpsw.c, L:790, F:cpdma_process status:-805306308
Abort
--- net_loop Abort!
ping failed; host 172.30.131.73 is not alive
Command failed, result=1
=> mdio list
ethernet@4a100000:
2 - Micrel KSZ804 <--> ethernet@4a100000
Thanks.
Rgds
Shine
