CSLR for DM6437 ?
Other Parts Discussed in Thread: CCSTUDIO
Where will i find Chip Support Library Register level (CSLR) files for DM6437 ?
pls help me !!!!!!!!!
  • Hi. Could you please let us know where you obtained the CSLR information?
    Why do you need such files?
    When i try to interconnect the matlab with 6437 via, CCS, i got Error that
    Following file cannot be found :
    $(CSLR_DM6437_installdir)\csl.h
    pls help me !!!!!!!!!!
    Where will i find CSLR file for 6437 ?
  • Refer this page for support libraries available, for C6000:
    http://processors.wiki.ti.com/index.php/Chip_support_library#Chip_Support_Library_for_C6000
    In this - you will find link to DM6437, and also some other packages.
    http://software-dl.ti.com/dsps/dsps_registered_sw/sdo_sb/targetcontent/psp/bios_psp/index.html
    TI supports a lot of demo software developed by TI and third parties.  Can you please let us know what you wish to build, so we can assist you further.
    Also you can search the forums itself, for solutions to many of your Questions/issues.
    Varada
    Dear sir,
    For the video surveillance function, i  added 2 source files , dil_utils_win.c and Frommmfile_ex_win.c  and made run in the CCS.
    While building the program , i am getting following error,
    $(CSLR_DM6437_installdir)\csl. h
    It asking me to search in the the directory   C:\DVSdk_1_01_00_15.
    But it is not found !!!!!!!!!!
    code composer studio 3.3 release.
     Board Board                               Proc Processor                           Processor
     Num  Name                                Num  Name                                Type
     0    EVM-DM6437                          0    cpu_0                               C6400PLUS
     0    EVM-DM6437                          -    IcePick                             ICEPick_C
  • Thank u sir, got some idea from ur guidance.
    Now got one more doubt !!!!!
    I have connected the DM6437 to Ethernet.
    The host has detected the target .
    At target board , i captured  a video , its been passed to the HOST via ETHERNET.
    The problem is :
    After the target finished capturing the video, later HOST receives it.
    I need the HOST to receive the video, while the TARGET CAPTURING video.
    IS it possible ?
  • Please submit this question, as a separate post. Then appropriate team will assist you.
    Varada
  • hi, i have the same problem, I´m using the same target too, so, I´d like how do you solved this problem,
    ´cuz I seek the file in the all the folders posible, and I can´t found!!!
    Please help me!!!
  • Emmanuel - can you please specify which software package you are using and which files are missing, so I can assist/direct you.
    I am working on image processing, My target is DVDP DM6437, I using DM6437 EVM CCStudio v.3.3, today appear this error:
    the following ile cannot be found:      &(CSLR_DM6437_INSTALLDIR)\csl.h,   and it suggested to me a direction to find it.
    Look in the direction and not find a file called that, but if one called CSLR, select that and I did the whole process, I think it is now ready.
    when you compile the CCStudio and the bottom bar, I get zero errors, zero warnings,I suppose that the programming is ready, but as I can see that since the DSP has this information,
    hopefully I have explained clearly, thank you very much!!!!
  • hi
    i also struggled with csl.h file.
    but i cured that one.
    Now struggling wit following errors : kindly help me.
    "C:/Documents and Settings/Administrator/Desktop/basetsd.h", line 109: error: identifier "__int64" is undefined
    "C:/Documents and Settings/Administrator/Desktop/basetsd.h", line 110: error: identifier "__int64" is undefined
    "C:/Documents and Settings/Administrator/Desktop/basetsd.h", line 111: error: expected a ";"
    "C:/Documents and Settings/Administrator/Desktop/basetsd.h", line 112: warning: typedef name has already been declared (with same type)
    "C:/Documents and Settings/Administrator/Desktop/basetsd.h", line 112: error: expected a ";"
    "C:/Documents and Settings/Administrator/Desktop/basetsd.h", line 113: warning: typedef name has already been declared (with same type)
    "C:/Documents and Settings/Administrator/Desktop/basetsd.h", line 113: error: expected a ";"
    "C:/Documents and Settings/Administrator/Desktop/winnt.h", line 1346: warning: unrecognized preprocessing directive
    "C:/Documents and Settings/Administrator/Desktop/winnt.h", line 1969: fatal error: #error "undefined processor type"
    "C:/Documents and Settings/Administrator/Desktop/stddef.h", line 6: warning: nonstandard preprocessing directive
    "C:/Documents and Settings/Administrator/Desktop/stdarg.h", line 6: warning: nonstandard preprocessing directive
    "C:/Documents and Settings/Administrator/Desktop/string.h", line 36: error: a declaration here must declare a parameter
    "C:/Documents and Settings/Administrator/Desktop/string.h", line 36: error: expected a ";"
    "C:/Documents and Settings/Administrator/Desktop/string.h", line 37: error: expected a declaration
    "C:/Documents and Settings/Administrator/Desktop/string.h", line 38: error: expected a declaration
    "C:/Documents and Settings/Administrator/Desktop/string.h", line 39: error: expected a declaration
    "C:/Documents and Settings/Administrator/Desktop/string.h", line 40: error: expected a declaration
    "C:/Documents and Settings/Administrator/Desktop/string.h", line 41: error: expected a declaration
    "C:/Documents and Settings/Administrator/Desktop/string.h", line 42: error: expected a declaration
    "C:/Documents and Settings/Administrator/Desktop/string.h", line 43: error: expected a declaration
    "C:/Documents and Settings/Administrator/Desktop/string.h", line 44: error: expected a declaration
    "C:/Documents and Settings/Administrator/Desktop/string.h", line 45: error: expected a declaration
    "C:/Documents and Settings/Administrator/Desktop/string.h", line 46: error: expected a declaration
    "C:/Documents and Settings/Administrator/Desktop/string.h", line 47: error: expected a declaration
    "C:/Documents and Settings/Administrator/Desktop/string.h", line 49: error: expected a declaration
    "C:/Documents and Settings/Administrator/Desktop/string.h", line 50: error: expected a declaration
    "C:/Documents and Settings/Administrator/Desktop/string.h", line 51: error: expected a declaration
    "C:/Documents and Settings/Administrator/Desktop/string.h", line 52: error: expected a declaration
    "C:/Documents and Settings/Administrator/Desktop/string.h", line 53: error: expected a declaration
    "C:/Documents and Settings/Administrator/Desktop/string.h", line 54: error: expected a declaration
    "C:/Documents and Settings/Administrator/Desktop/string.h", line 55: error: expected a declaration
    "C:/Documents and Settings/Administrator/Desktop/string.h", line 56: error: expected a declaration
    "C:/Documents and Settings/Administrator/Desktop/string.h", line 57: error: expected a declaration
    "C:/Documents and Settings/Administrator/Desktop/string.h", line 58: error: expected a declaration
    "C:/Documents and Settings/Administrator/Desktop/string.h", line 64: error: expected a declaration
    "C:/Documents and Settings/Administrator/Desktop/string.h", line 65: error: expected a declaration
    "C:/Documents and Settings/Administrator/Desktop/string.h", line 66: error: expected a declaration
    "C:/Documents and Settings/Administrator/Desktop/string.h", line 67: error: expected a declaration
    "C:/Documents and Settings/Administrator/Desktop/string.h", line 68: error: expected a declaration
    "C:/Documents and Settings/Administrator/Desktop/string.h", line 69: error: expected a declaration
    "C:/Documents and Settings/Administrator/Desktop/string.h", line 70: error: expected a declaration
    "C:/Documents and Settings/Administrator/Desktop/string.h", line 71: error: expected a declaration
    "C:/Documents and Settings/Administrator/Desktop/string.h", line 72: error: expected a declaration
    "C:/Documents and Settings/Administrator/Desktop/string.h", line 73: error: expected a declaration
    "C:/Documents and Settings/Administrator/Desktop/string.h", line 74: error: expected a declaration
    "C:/Documents and Settings/Administrator/Desktop/string.h", line 75: error: expected a declaration
    "C:/Documents and Settings/Administrator/Desktop/string.h", line 76: error: expected a declaration
    "C:/Documents and Settings/Administrator/Desktop/string.h", line 77: error: expected a declaration
    "C:/Documents and Settings/Administrator/Desktop/string.h", line 90: error: expected a declaration
    "C:/Documents and Settings/Administrator/Desktop/string.h", line 91: error: expected a declaration
    "C:/Documents and Settings/Administrator/Desktop/string.h", line 92: error: expected a declaration
    "C:/Documents and Settings/Administrator/Desktop/string.h", line 93: error: expected a declaration
    "C:/Documents and Settings/Administrator/Desktop/string.h", line 94: error: expected a declaration
    "C:/Documents and Settings/Administrator/Desktop/string.h", line 95: error: invalid storage class for a parameter
    "C:/Documents and Settings/Administrator/Desktop/string.h", line 95: error: a declaration here must declare a parameter
    "C:/Documents and Settings/Administrator/Desktop/string.h", line 95: warning: explicit type is missing ("int" assumed)
    "C:/Documents and Settings/Administrator/Desktop/string.h", line 95: error: expected a ";"
    "C:/Documents and Settings/Administrator/Desktop/string.h", line 98: warning: parsing restarts here after previous syntax error
    "C:/Documents and Settings/Administrator/Desktop/string.h", line 99: error: expected a declaration
    "C:/Documents and Settings/Administrator/Desktop/string.h", line 100: error: expected a declaration
    "C:/Documents and Settings/Administrator/Desktop/string.h", line 101: error: invalid storage class for a parameter
    "C:/Documents and Settings/Administrator/Desktop/string.h", line 101: error: a declaration here must declare a parameter
    "C:/Documents and Settings/Administrator/Desktop/string.h", line 101: warning: explicit type is missing ("int" assumed)
    "C:/Documents and Settings/Administrator/Desktop/string.h", line 101: error: "__inline__" has already been declared in the current scope
    "C:/Documents and Settings/Administrator/Desktop/string.h", line 101: error: expected a ";"
    "C:/Documents and Settings/Administrator/Desktop/string.h", line 104: warning: parsing restarts here after previous syntax error
    "C:/Documents and Settings/Administrator/Desktop/string.h", line 105: error: expected a declaration
    "C:/Documents and Settings/Administrator/Desktop/string.h", line 106: error: expected a declaration
    "C:/Documents and Settings/Administrator/Desktop/string.h", line 107: error: expected a declaration
    "C:/Documents and Settings/Administrator/Desktop/string.h", line 109: error: expected a declaration
    "C:/Documents and Settings/Administrator/Desktop/string.h", line 120: error: expected a declaration
    "C:/Documents and Settings/Administrator/Desktop/string.h", line 121: error: expected a declaration
    "C:/Documents and Settings/Administrator/Desktop/string.h", line 122: error: expected a declaration
    "C:/Documents and Settings/Administrator/Desktop/string.h", line 123: error: expected a declaration
    "C:/Documents and Settings/Administrator/Desktop/string.h", line 124: error: expected a declaration
    "C:/Documents and Settings/Administrator/Desktop/string.h", line 125: error: expected a declaration
    "C:/Documents and Settings/Administrator/Desktop/string.h", line 127: error: expected a declaration
    "C:/Documents and Settings/Administrator/Desktop/string.h", line 128: error: expected a declaration
    "C:/Documents and Settings/Administrator/Desktop/string.h", line 129: error: expected a declaration
    "C:/Documents and Settings/Administrator/Desktop/string.h", line 130: error: expected a declaration
    "C:/Documents and Settings/Administrator/Desktop/string.h", line 131: error: expected a declaration
    "C:/Documents and Settings/Administrator/Desktop/string.h", line 132: error: expected a declaration
    "C:/Documents and Settings/Administrator/Desktop/string.h", line 133: error: expected a declaration
    "C:/Documents and Settings/Administrator/Desktop/string.h", line 134: error: expected a declaration
    "C:/Documents and Settings/Administrator/Desktop/string.h", line 135: error: expected a declaration
    "C:/Documents and Settings/Administrator/Desktop/string.h", line 136: error: expected a declaration
    "C:/Documents and Settings/Administrator/Desktop/string.h", line 146: error: expected a declaration
    "C:/Documents and Settings/Administrator/Desktop/string.h", line 147: error: expected a declaration
    "C:/Documents and Settings/Administrator/Desktop/string.h", line 148: error: expected a declaration
    "C:/Documents and Settings/Administrator/Desktop/string.h", line 149: error: expected a declaration
    "C:/Documents and Settings/Administrator/Desktop/string.h", line 150: error: expected a declaration
    "C:/Documents and Settings/Administrator/Desktop/string.h", line 151: error: expected a declaration
    "C:/Documents and Settings/Administrator/Desktop/string.h", line 152: error: expected a declaration
    "C:/Documents and Settings/Administrator/Desktop/string.h", line 153: error: expected a declaration
    "C:/Documents and Settings/Administrator/Desktop/string.h", line 154: error: expected a declaration
    "C:/Documents and Settings/Administrator/Desktop/string.h", line 167: error: a declaration here must declare a parameter
    "C:/Documents and Settings/Administrator/Desktop/string.h", line 167: error: "__cdecl" has already been declared in the current scope
    "C:/Documents and Settings/Administrator/Desktop/string.h", line 167: error: expected a ";"
    "C:/Documents and Settings/Administrator/Desktop/string.h", line 168: error: invalid storage class for a parameter
    "C:/Documents and Settings/Administrator/Desktop/string.h", line 168: error: a declaration here must declare a parameter
    "C:/Documents and Settings/Administrator/Desktop/string.h", line 168: warning: explicit type is missing ("int" assumed)
    "C:/Documents and Settings/Administrator/Desktop/string.h", line 168: error: "__inline__" has already been declared in the current scope
    "C:/Documents and Settings/Administrator/Desktop/string.h", line 168: error: expected a ";"
    "C:/Documents and Settings/Administrator/Desktop/string.h", line 171: warning: parsing restarts here after previous syntax error
    "C:/Documents and Settings/Administrator/Desktop/string.h", line 172: error: expected a declaration
    "C:/Documents and Settings/Administrator/Desktop/string.h", line 173: error: expected a declaration
    "C:/Documents and Settings/Administrator/Desktop/string.h", line 174: error: expected a declaration
    "C:/Documents and Settings/Administrator/Desktop/string.h", line 175: error: expected a declaration
    "C:/Documents and Settings/Administrator/Desktop/string.h", line 176: error: expected a declaration
    "C:/Documents and Settings/Administrator/Desktop/string.h", line 177: error: expected a declaration
    "C:/Documents and Settings/Administrator/Desktop/string.h", line 178: error: expected a declaration
    "C:/Documents and Settings/Administrator/Desktop/string.h", line 179: error: expected a declaration
    "C:/CCStudio_v3.3/bios_5_31_02/packages/ti/bios/include/que.h", line 41: warning: declaration is not visible outside of function
    "C:/CCStudio_v3.3/bios_5_31_02/packages/ti/bios/include/que.h", line 41: warning: a declaration here must declare a parameter
    "C:/CCStudio_v3.3/bios_5_31_02/packages/ti/bios/include/que.h", line 44: warning: declaration is not visible outside of function
    "C:/CCStudio_v3.3/bios_5_31_02/packages/ti/bios/include/que.h", line 46: warning: a declaration here must declare a parameter
    "C:/CCStudio_v3.3/bios_5_31_02/packages/ti/bios/include/que.h", line 46: warning: declaration is not visible outside of function
    "C:/CCStudio_v3.3/bios_5_31_02/packages/ti/bios/include/que.h", line 48: warning: declaration is not visible outside of function
    "C:/CCStudio_v3.3/bios_5_31_02/packages/ti/bios/include/que.h", line 48: warning: a declaration here must declare a parameter
    "C:/CCStudio_v3.3/bios_5_31_02/packages/ti/bios/include/que.h", line 50: warning: declaration is not visible outside of function
    "C:/CCStudio_v3.3/bios_5_31_02/packages/ti/bios/include/que.h", line 52: error: invalid storage class for a parameter
    "C:/CCStudio_v3.3/bios_5_31_02/packages/ti/bios/include/que.h", line 52: error: a declaration here must declare a parameter
    "C:/CCStudio_v3.3/bios_5_31_02/packages/ti/bios/include/que.h", line 57: error: invalid storage class for a parameter
    "C:/CCStudio_v3.3/bios_5_31_02/packages/ti/bios/include/que.h", line 57: error: a declaration here must declare a parameter
    "C:/CCStudio_v3.3/bios_5_31_02/packages/ti/bios/include/que.h", line 87: error: invalid storage class for a paramete
