TDA4VMXEVM: PDK does not rebuild libs when sourcecode changed
Part Number: TDA4VMXEVM
I observed an interesting bug during (re)building the pdk of psdk_rtos_auto_j7_06_02_00_21.
It seems, that binaries will not get rebuild after modifying the corrensponding source file when using the "CORE" flag:
This won't rebuild affected/outdated binaries:
thomas@ubuntu:~/tda4vmx/psdk/pdk/packages/ti/build$ make -s BUILD_PROFILE=debug CORE=MCU1_0 pdk_libs
This will rebuild affected/outdated binaries as expected:
thomas@ubuntu:~/tda4vmx/psdk/pdk/packages/ti/build$ make -s BUILD_PROFILE=debug pdk_libs
Can you explain why and how to fix it? I would like to keep building time of PDK to an minimum, and want to only rebuild outdated binaries, and only for specific CORE.
I give you a full example which you can use to reproduce on your system:
thomas@ubuntu:~/tda4vmx/psdk/pdk/packages/ti/build$ clear
Nothing to be done for j721e MCU1_0 csl_init
Nothing to be done for j721e MCU1_0 csl_intc
Nothing to be done for j721e MCU1_0 csl_utils_common
Nothing to be done for j721e MCU1_0 csl_uart_console
Nothing to be done for j721e MCU1_0 board
Nothing to be done for j721e pm_hal
Nothing to be done for j721e pm_hal_optimized
Nothing to be done for j721e MCU1_0 pm_lib
Nothing to be done for j721e MCU1_0 pm_lib_optimized
Nothing to be done for j721e MCU1_0 pm_rtos
Nothing to be done for j721e MCU1_0 udma
Nothing to be done for j721e MCU1_0 dmautils
Nothing to be done for j721e MCU1_0 udma_apputils
Nothing to be done for j721e MCU1_0 cpsw
Nothing to be done for j721e MCU1_0 nimucpsw
Nothing to be done for j721e MCU1_0 cpsw_cfgserver
Nothing to be done for j721e MCU1_0 cpsw_apputils
Nothing to be done for j721e MCU1_0 cpswsoc
Nothing to be done for j721e MCU1_0 csirx
Nothing to be done for j721e MCU1_0 csitx
Nothing to be done for j721e MCU1_0 fvid2
Nothing to be done for j721e MCU1_0 dss
Nothing to be done for j721e MCU1_0 sciclient
Nothing to be done for j721e MCU1_0 vhwa
Nothing to be done for j721e MCU1_0 ipc
Nothing to be done for j721e MCU1_0 ipc_baremetal
Nothing to be done for j721e MCU1_0 osal_nonos
Nothing to be done for j721e MCU1_0 osal_nonos_indp
Nothing to be done for j721e MCU1_0 osal_tirtos
Nothing to be done for j721e MCU1_0 osal_tirtos_indp
Nothing to be done for j721e MCU1_0 i2c
Nothing to be done for j721e i2c_indp
Nothing to be done for j721e i2c_profile
Nothing to be done for j721e i2c_profile_indp
Nothing to be done for j721e i2c_icss0
Nothing to be done for j721e MCU1_0 uart
Nothing to be done for j721e MCU1_0 uart_dma
Nothing to be done for j721e uart_profile
Nothing to be done for j721e uart_dma_profile
Nothing to be done for j721e uart_indp
Nothing to be done for j721e uart_profile_indp
Nothing to be done for j721e MCU1_0 uart_console
Nothing to be done for j721e MCU1_0 usb
Nothing to be done for j721e MCU1_0 gpio
Nothing to be done for j721e MCU1_0 gpio_indp
Nothing to be done for j721e gpio_profile
Nothing to be done for j721e gpio_profile_indp
Nothing to be done for j721e MCU1_0 profiling
Nothing to be done for j721e MCU1_0 nimu_profile
Nothing to be done for j721e MCU1_0 emac
Nothing to be done for j721e nimu_icssg
Nothing to be done for j721e nimu_icssg_profile
Nothing to be done for j721e MCU1_0 fatfs_indp
Nothing to be done for j721e fatfs_multi_indp
Nothing to be done for j721e fatfs_profile_indp
Nothing to be done for j721e MCU1_0 mmcsd
Nothing to be done for j721e MCU1_0 mmcsd_dma
Nothing to be done for j721e MCU1_0 mmcsd_profile
Nothing to be done for j721e MCU1_0 mmcsd_dma_profile
Nothing to be done for j721e MCU1_0 mmcsd_indp
Nothing to be done for j721e MCU1_0 mmcsd_profile_indp
Nothing to be done for j721e MCU1_0 pcie
Nothing to be done for j721e MCU1_0 pcie_profile
Nothing to be done for j721e MCU1_0 pcie_indp
Nothing to be done for j721e MCU1_0 pcie_profile_indp
Nothing to be done for j721e MCU1_0 mcasp
Nothing to be done for j721e mcasp_indp
Nothing to be done for j721e mcasp_profile
Nothing to be done for j721e mcasp_profile_indp
Nothing to be done for j721e MCU1_0 emac_indp
Nothing to be done for j721e MCU1_0 emac_profile
Nothing to be done for j721e MCU1_0 emac_profile_indp
Nothing to be done for j721e MCU1_0 pruss
Nothing to be done for j721e MCU1_0 pruss_indp
Nothing to be done for j721e MCU1_0 pruss_profile
Nothing to be done for j721e MCU1_0 pruss_profile_indp
Nothing to be done for j721e MCU1_0 spi
Nothing to be done for j721e MCU1_0 spi_dma
Nothing to be done for j721e spi_profile
Nothing to be done for j721e spi_dma_profile
Nothing to be done for j721e MCU1_0 spi_indp
Nothing to be done for j721e spi_profile_indp
Nothing to be done for j721e mcu1_0 csl_intc
Nothing to be done for j721e mcu1_0 dmautils
Nothing to be done for j721e mcu1_0 csirx
Nothing to be done for j721e mcu1_0 csitx
Nothing to be done for j721e mcu1_0 dss
Nothing to be done for j721e mcu1_0 vhwa
thomas@ubuntu:~/tda4vmx/psdk/pdk/packages/ti/build$ touch ../drv/ipc/src/ipc_virtio.c
# Compiling j721e:mcu1_0:debug:ipc: src/ipc_virtio.c
# Archiving j721e:mcu1_0:debug:ipc into /home/thomas/tda4vmx/psdk_rtos_j721e/psdk_rtos_auto_j7_06_02_00_21/pdk/packages/ti/drv/ipc/lib/j721e/mcu1_0/debug/ipc.aer5f ...
# Compiling j721e:mcu1_0:debug:ipc_baremetal: src/ipc_virtio.c
# Archiving j721e:mcu1_0:debug:ipc_baremetal into /home/thomas/tda4vmx/psdk_rtos_j721e/psdk_rtos_auto_j7_06_02_00_21/pdk/packages/ti/drv/ipc/lib/j721e/mcu1_0/debug/ipc_baremetal.aer5f ...
As you can see, the first two make commands verify that source and binaries are in "sync".
Then I "change" the source file of ipc_virtio.c
I expect now, that the according libs are getting rebuild.
Limiting CORE to MCU1_0 won't rebuild that library.
Without specifying CORE the affected library getting rebuild.
Any help would be highly appreciated.
Thomas
