Part Number: TDA4VMXEVM
We have been working on a new 3MP sensor integration and we are facing some performance drop in the Surround view use case. Event-based scheduling is used in both use-cases. The same events and parameters are being used and currently the only difference between the two use cases is the following:
- Mosaic node is used in the Multi-cam use case | SRV node is used in the Surround view use case
The LDC node is not being used at the moment in the multi-cam use case.
By comparing the performance statistics, it was observed that the DDR's load is higher in the SRV use case. Our assumption is that the SRV node which stitches the four input images is loading the DDR more heavily than the Mosaic node. The performance logs are attached.
Could this be resolved in some way (e.g. by changing the OPP_mode -> OPP_nominal/OPP_high etc. as it was in TDA3)? Or by decreasing the performance of the OpenGL_SRV_node to ~30 000 usec which could decrease the DDR load but not break the pipelining?
Any suggestions or recommendations would be appreciated!
Summary of CPU load, ==================== CPU: mpu1_0: TOTAL LOAD = 0.67 % ( HWI = 0. 8 %, SWI = 0. 0 % ) CPU: mcu2_0: TOTAL LOAD = 23.81 % ( HWI = 0.58 %, SWI = 0.67 % ) CPU: mcu2_1: TOTAL LOAD = 47.51 % ( HWI = 4.21 %, SWI = 0.96 % ) CPU: c6x_1: TOTAL LOAD = 0. 5 % ( HWI = 0. 2 %, SWI = 0. 1 % ) CPU: c6x_2: TOTAL LOAD = 0. 5 % ( HWI = 0. 2 %, SWI = 0. 1 % ) CPU: c7x_1: TOTAL LOAD = 0.10 % ( HWI = 0. 6 %, SWI = 0. 3 % ) HWA performance statistics, =========================== HWA: VISS: LOAD = 64.57 % ( 548 MP/s ) HWA: MSC1: LOAD = 47.95 % ( 740 MP/s ) DDR performance statistics, =========================== DDR: READ BW: AVG = 2275 MB/s, PEAK = 4024 MB/s DDR: WRITE BW: AVG = 1519 MB/s, PEAK = 2680 MB/s DDR: TOTAL BW: AVG = 3794 MB/s, PEAK = 6704 MB/s Detailed CPU performance/memory statistics, =========================================== CPU: mcu2_0: TASK: IPC_RX: 0. 6 % CPU: mcu2_0: TASK: REMOTE_SRV: 0. 0 % CPU: mcu2_0: TASK: TIVX_CPU: 20.77 % CPU: mcu2_0: TASK: IPC_TEST_RX: 0. 0 % CPU: mcu2_0: TASK: IPC_TEST_TX: 0. 0 % CPU: mcu2_0: TASK: IPC_TEST_TX: 0. 0 % CPU: mcu2_0: TASK: IPC_TEST_TX: 0. 0 % CPU: mcu2_0: TASK: IPC_TEST_TX: 0. 0 % CPU: mcu2_0: TASK: IPC_TEST_TX: 0. 0 % CPU: mcu2_0: HEAP: DDR_SHARED_MEM: size = 4194304 B, free = 1616384 B ( 38 % unused) CPU: mcu2_1: TASK: IPC_RX: 0. 7 % CPU: mcu2_1: TASK: REMOTE_SRV: 0.85 % CPU: mcu2_1: TASK: TIVX_CPU: 0. 0 % CPU: mcu2_1: TASK: TIVX_NF: 0. 0 % CPU: mcu2_1: TASK: TIVX_LDC1: 0. 0 % CPU: mcu2_1: TASK: TIVX_MSC1: 19.30 % CPU: mcu2_1: TASK: TIVX_MSC2: 0. 0 % CPU: mcu2_1: TASK: TIVX_SDE: 0. 0 % CPU: mcu2_1: TASK: TIVX_DOF: 0. 0 % CPU: mcu2_1: TASK: TIVX_VISS1: 17.67 % CPU: mcu2_1: TASK: TIVX_CAPT1: 3.25 % CPU: mcu2_1: TASK: TIVX_CAPT2: 0. 0 % CPU: mcu2_1: TASK: TIVX_DISP1: 1.14 % CPU: mcu2_1: TASK: TIVX_DISP2: 0. 0 % CPU: mcu2_1: TASK: TIVX_VDEC1: 0. 0 % CPU: mcu2_1: TASK: TIVX_VDEC2: 0. 0 % CPU: mcu2_1: HEAP: DDR_SHARED_MEM: size = 16777216 B, free = 16633088 B ( 99 % unused) CPU: mcu2_1: HEAP: DDR_NON_CACHE_M: size = 67108864 B, free = 47210496 B ( 6 % unused) CPU: c6x_1: TASK: IPC_RX: 0. 0 % CPU: c6x_1: TASK: REMOTE_SRV: 0. 0 % CPU: c6x_1: TASK: TIVX_CPU: 0. 0 % CPU: c6x_1: TASK: IPC_TEST_RX: 0. 0 % CPU: c6x_1: TASK: IPC_TEST_TX: 0. 0 % CPU: c6x_1: TASK: IPC_TEST_TX: 0. 0 % CPU: c6x_1: TASK: IPC_TEST_TX: 0. 0 % CPU: c6x_1: TASK: IPC_TEST_TX: 0. 0 % CPU: c6x_1: TASK: IPC_TEST_TX: 0. 0 % CPU: c6x_1: HEAP: DDR_SHARED_MEM: size = 16777216 B, free = 16775168 B ( 99 % unused) CPU: c6x_1: HEAP: L2_MEM: size = 229376 B, free = 229376 B (100 % unused) CPU: c6x_1: HEAP: DDR_SCRATCH_MEM: size = 50331648 B, free = 50331648 B ( 14 % unused) CPU: c6x_2: TASK: IPC_RX: 0. 0 % CPU: c6x_2: TASK: REMOTE_SRV: 0. 0 % CPU: c6x_2: TASK: TIVX_CPU: 0. 0 % CPU: c6x_2: TASK: IPC_TEST_RX: 0. 0 % CPU: c6x_2: TASK: IPC_TEST_TX: 0. 0 % CPU: c6x_2: TASK: IPC_TEST_TX: 0. 0 % CPU: c6x_2: TASK: IPC_TEST_TX: 0. 0 % CPU: c6x_2: TASK: IPC_TEST_TX: 0. 0 % CPU: c6x_2: TASK: IPC_TEST_TX: 0. 0 % CPU: c6x_2: HEAP: DDR_SHARED_MEM: size = 16777216 B, free = 16775168 B ( 99 % unused) CPU: c6x_2: HEAP: L2_MEM: size = 229376 B, free = 229376 B (100 % unused) CPU: c6x_2: HEAP: DDR_SCRATCH_MEM: size = 50331648 B, free = 50331648 B ( 14 % unused) CPU: c7x_1: TASK: IPC_RX: 0. 0 % CPU: c7x_1: TASK: REMOTE_SRV: 0. 0 % CPU: c7x_1: TASK: TIVX_CPU: 0. 0 % CPU: c7x_1: TASK: IPC_TEST_RX: 0. 0 % CPU: c7x_1: TASK: IPC_TEST_TX: 0. 0 % CPU: c7x_1: TASK: IPC_TEST_TX: 0. 0 % CPU: c7x_1: TASK: IPC_TEST_TX: 0. 0 % CPU: c7x_1: TASK: IPC_TEST_TX: 0. 0 % CPU: c7x_1: TASK: IPC_TEST_TX: 0. 0 % CPU: c7x_1: HEAP: DDR_SHARED_MEM: size = 469762048 B, free = 469762048 B ( 8 % unused) CPU: c7x_1: HEAP: L3_MEM: size = 8159232 B, free = 8159232 B (100 % unused) CPU: c7x_1: HEAP: L2_MEM: size = 491520 B, free = 491520 B (100 % unused) CPU: c7x_1: HEAP: L1_MEM: size = 16384 B, free = 16384 B (100 % unused) CPU: c7x_1: HEAP: DDR_SCRATCH_MEM: size = 67108864 B, free = 67108864 B ( 36 % unused) GRAPH: graph_85 (#nodes = 5, #executions = 3976) NODE: CAPTURE1: Capture_node: avg = 33262 usecs, min/max = 290 / 74632 usecs, #executions = 3976 NODE: VPAC_VISS1: VISS_Processing: avg = 29665 usecs, min/max = 22944 / 52935 usecs, #executions = 3976 NODE: IPU1-1: 2A_AlgNode: avg = 7794 usecs, min/max = 6641 / 16933 usecs, #executions = 3976 NODE: VPAC_MSC1: MosaicNode: avg = 21721 usecs, min/max = 20448 / 56443 usecs, #executions = 3976 NODE: DISPLAY1: Display_node: avg = 15301 usecs, min/max = 129 / 29845 usecs, #executions = 3976 PERF: TOTAL: avg = 33343 usecs, min/max = 27706 / 80106 usecs, #executions = 3977 PERF: TOTAL: 29.99 FPS
Summary of CPU load, ==================== CPU: mpu1_0: TOTAL LOAD = 5.47 % ( HWI = 0.23 %, SWI = 0.21 % ) CPU: mcu2_0: TOTAL LOAD = 60.96 % ( HWI = 2.80 %, SWI = 2. 0 % ) CPU: mcu2_1: TOTAL LOAD = 43.74 % ( HWI = 6.78 %, SWI = 2.15 % ) CPU: c6x_1: TOTAL LOAD = 0. 6 % ( HWI = 0. 2 %, SWI = 0. 2 % ) CPU: c6x_2: TOTAL LOAD = 0. 6 % ( HWI = 0. 2 %, SWI = 0. 2 % ) CPU: c7x_1: TOTAL LOAD = 0.12 % ( HWI = 0. 6 %, SWI = 0. 3 % ) HWA performance statistics, =========================== HWA: VISS: LOAD = 69.37 % ( 482 MP/s ) HWA: GPU : LOAD = 62.94 % ( 93 MP/s ) DDR performance statistics, =========================== DDR: READ BW: AVG = 3045 MB/s, PEAK = 3199 MB/s DDR: WRITE BW: AVG = 2272 MB/s, PEAK = 2378 MB/s DDR: TOTAL BW: AVG = 5317 MB/s, PEAK = 5577 MB/s Detailed CPU performance/memory statistics, =========================================== CPU: mcu2_0: TASK: IPC_RX: 0. 7 % CPU: mcu2_0: TASK: REMOTE_SRV: 0. 3 % CPU: mcu2_0: TASK: TIVX_CPU: 54.39 % CPU: mcu2_0: TASK: IPC_TEST_RX: 0. 0 % CPU: mcu2_0: TASK: IPC_TEST_TX: 0. 0 % CPU: mcu2_0: TASK: IPC_TEST_TX: 0. 0 % CPU: mcu2_0: TASK: IPC_TEST_TX: 0. 0 % CPU: mcu2_0: TASK: IPC_TEST_TX: 0. 0 % CPU: mcu2_0: TASK: IPC_TEST_TX: 0. 0 % CPU: mcu2_0: HEAP: DDR_SHARED_MEM: size = 4194304 B, free = 1616384 B ( 38 % unused) CPU: mcu2_1: TASK: IPC_RX: 0.17 % CPU: mcu2_1: TASK: REMOTE_SRV: 2.41 % CPU: mcu2_1: TASK: TIVX_CPU: 0. 0 % CPU: mcu2_1: TASK: TIVX_NF: 0. 0 % CPU: mcu2_1: TASK: TIVX_LDC1: 0. 0 % CPU: mcu2_1: TASK: TIVX_MSC1: 0. 0 % CPU: mcu2_1: TASK: TIVX_MSC2: 0. 0 % CPU: mcu2_1: TASK: TIVX_SDE: 0. 0 % CPU: mcu2_1: TASK: TIVX_DOF: 0. 0 % CPU: mcu2_1: TASK: TIVX_VISS1: 26.84 % CPU: mcu2_1: TASK: TIVX_CAPT1: 4.21 % CPU: mcu2_1: TASK: TIVX_CAPT2: 0. 0 % CPU: mcu2_1: TASK: TIVX_DISP1: 1. 9 % CPU: mcu2_1: TASK: TIVX_DISP2: 0. 0 % CPU: mcu2_1: TASK: TIVX_VDEC1: 0. 0 % CPU: mcu2_1: TASK: TIVX_VDEC2: 0. 0 % CPU: mcu2_1: HEAP: DDR_SHARED_MEM: size = 16777216 B, free = 16631808 B ( 99 % unused) CPU: mcu2_1: HEAP: DDR_NON_CACHE_M: size = 67108864 B, free = 47210496 B ( 6 % unused) CPU: c6x_1: TASK: IPC_RX: 0. 0 % CPU: c6x_1: TASK: REMOTE_SRV: 0. 0 % CPU: c6x_1: TASK: TIVX_CPU: 0. 0 % CPU: c6x_1: TASK: IPC_TEST_RX: 0. 0 % CPU: c6x_1: TASK: IPC_TEST_TX: 0. 0 % CPU: c6x_1: TASK: IPC_TEST_TX: 0. 0 % CPU: c6x_1: TASK: IPC_TEST_TX: 0. 0 % CPU: c6x_1: TASK: IPC_TEST_TX: 0. 0 % CPU: c6x_1: TASK: IPC_TEST_TX: 0. 0 % CPU: c6x_1: HEAP: DDR_SHARED_MEM: size = 16777216 B, free = 16772608 B ( 99 % unused) CPU: c6x_1: HEAP: L2_MEM: size = 229376 B, free = 229376 B (100 % unused) CPU: c6x_1: HEAP: DDR_SCRATCH_MEM: size = 50331648 B, free = 50331648 B ( 14 % unused) CPU: c6x_2: TASK: IPC_RX: 0. 0 % CPU: c6x_2: TASK: REMOTE_SRV: 0. 0 % CPU: c6x_2: TASK: TIVX_CPU: 0. 0 % CPU: c6x_2: TASK: IPC_TEST_RX: 0. 0 % CPU: c6x_2: TASK: IPC_TEST_TX: 0. 0 % CPU: c6x_2: TASK: IPC_TEST_TX: 0. 0 % CPU: c6x_2: TASK: IPC_TEST_TX: 0. 0 % CPU: c6x_2: TASK: IPC_TEST_TX: 0. 0 % CPU: c6x_2: TASK: IPC_TEST_TX: 0. 0 % CPU: c6x_2: HEAP: DDR_SHARED_MEM: size = 16777216 B, free = 16775168 B ( 99 % unused) CPU: c6x_2: HEAP: L2_MEM: size = 229376 B, free = 229376 B (100 % unused) CPU: c6x_2: HEAP: DDR_SCRATCH_MEM: size = 50331648 B, free = 50331648 B ( 14 % unused) CPU: c7x_1: TASK: IPC_RX: 0. 0 % CPU: c7x_1: TASK: REMOTE_SRV: 0. 0 % CPU: c7x_1: TASK: TIVX_CPU: 0. 0 % CPU: c7x_1: TASK: IPC_TEST_RX: 0. 0 % CPU: c7x_1: TASK: IPC_TEST_TX: 0. 0 % CPU: c7x_1: TASK: IPC_TEST_TX: 0. 0 % CPU: c7x_1: TASK: IPC_TEST_TX: 0. 0 % CPU: c7x_1: TASK: IPC_TEST_TX: 0. 0 % CPU: c7x_1: TASK: IPC_TEST_TX: 0. 0 % CPU: c7x_1: HEAP: DDR_SHARED_MEM: size = 469762048 B, free = 469762048 B ( 8 % unused) CPU: c7x_1: HEAP: L3_MEM: size = 8159232 B, free = 8159232 B (100 % unused) CPU: c7x_1: HEAP: L2_MEM: size = 491520 B, free = 491520 B (100 % unused) CPU: c7x_1: HEAP: L1_MEM: size = 16384 B, free = 16384 B (100 % unused) CPU: c7x_1: HEAP: DDR_SCRATCH_MEM: size = 67108864 B, free = 67108864 B ( 36 % unused) GRAPH: 3DSRV (#nodes = 5, #executions = 3235) NODE: CAPTURE1: Capture_node: avg = 12745 usecs, min/max = 278 / 51708 usecs, #executions = 3235 NODE: VPAC_VISS1: VISS_Processing: avg = 34664 usecs, min/max = 27130 / 46695 usecs, #executions = 3235 NODE: IPU1-1: 2A_AlgNode: avg = 22100 usecs, min/max = 10769 / 26049 usecs, #executions = 3235 NODE: A72-0: OpenGL_SRV_Node: avg = 22262 usecs, min/max = 18238 / 41672 usecs, #executions = 3235 NODE: DISPLAY1: Display_node: avg = 9175 usecs, min/max = 83 / 34132 usecs, #executions = 3235 PERF: TOTAL: avg = 34914 usecs, min/max = 29351 / 79836 usecs, #executions = 3236 PERF: TOTAL: 28.64 FPS
Todor
