Part Number: AM3352
Hi team,
Customer would like to use UART (19200 baud-rate :Error rate 0%). According to Table 19-6 on TRM, Error rate is 0.16% for this baud-rate. Is it possible to change the frequency so that the error here becomes zero by setting the PLL registers?
Customer tried to check "Figure 8-14. Peripheral PLL Structure" on TRM, they were not able to find good solution for it. would you consider that it is possible to achieve 19200 baud-rate (Error 0%) by changing 24HMz Crystal?
It is appreciate if you will share Expert's any advice/solution/comments on this.
Miyazaki
