I have a new am572x board design. I have modified u-boot with the new pinmux and setup the u-boot environment variables. I am working to boot Linux from mmc1.
The Kernel boot messages show various items of concern:
* DMA has problems
* Several traces from "doesn't have mpu register target base"
* Might not be mounting ext4 rootfs (partition 2 of microSD).
* Hangs with "Waiting for root device PARTUUID=41d4c7bc-02". (The PARTUUID is correct)
I have created a dts file based on am572x-idk.dts (see attached)
Also attached is the boot console log.
I would appreciate advice toward successfully booting Linux, and completing the device tree.
Thank you for your help.
Greg.
/* * Copyright (C) 2015-2016 Texas Instruments Incorporated - http://www.ti.com/ * * This program is free software; you can redistribute it and/or modify * it under the terms of the GNU General Public License version 2 as * published by the Free Software Foundation. */ /dts-v1/; #include "dra74x.dtsi" #include <dt-bindings/gpio/gpio.h> #include <dt-bindings/interrupt-controller/irq.h> /*#include "am572x-idk-common.dtsi"*/ #include "am57xx-industrial-grade.dtsi" / { aliases { rtc0 = &tps659038_rtc; rtc1 = &rtc; }; chosen { stdout-path = &uart3; }; vmain: fixedregulator-vmain { compatible = "regulator-fixed"; regulator-name = "VMAIN"; regulator-min-microvolt = <5000000>; regulator-max-microvolt = <5000000>; regulator-always-on; regulator-boot-on; }; v3_3d: fixedregulator-v3_3d { compatible = "regulator-fixed"; regulator-name = "V3_3D"; vin-supply = <&smps9_reg>; regulator-min-microvolt = <3300000>; regulator-max-microvolt = <3300000>; regulator-always-on; regulator-boot-on; }; vtt_fixed: fixedregulator-vtt { /* TPS51200 */ compatible = "regulator-fixed"; regulator-name = "vtt_fixed"; vin-supply = <&v3_3d>; regulator-min-microvolt = <3300000>; regulator-max-microvolt = <3300000>; regulator-always-on; regulator-boot-on; }; // Put leds-iio here (See am57xx-idk-common.dtsi) }; //&dra7_pmx_core { //dcan1_pins_default: dcan1_pins_default { //pinctrl-single,pins = < //DRA7XX_CORE_IOPAD(0x37d0, PIN_OUTPUT_PULLUP | MUX_MODE0) /* dcan1_tx */ //DRA7XX_CORE_IOPAD(0x37d4, PIN_INPUT_PULLUP | MUX_MODE0) /* dcan1_rx */ //>; //}; // //dcan1_pins_sleep: dcan1_pins_sleep { //pinctrl-single,pins = < //DRA7XX_CORE_IOPAD(0x37d0, MUX_MODE15 | PULL_UP) /* dcan1_tx.off */ //DRA7XX_CORE_IOPAD(0x37d4, MUX_MODE15 | PULL_UP) /* dcan1_rx.off */ //>; //}; //}; // &i2c3 { status = "okay"; clock-frequency = <100000>; tps659038: tps659038@58 { compatible = "ti,tps659038"; reg = <0x58>; //interrupts-extended = <&gpio6 16 IRQ_TYPE_LEVEL_HIGH //&dra7_pmx_core 0x418>; //#interrupt-cells = <2>; //interrupt-controller; ti,system-power-controller; ti,palmas-override-powerhold; tps659038_pmic { compatible = "ti,tps659038-pmic"; smps12-in-supply = <&vmain>; smps3-in-supply = <&vmain>; smps45-in-supply = <&vmain>; smps6-in-supply = <&vmain>; smps7-in-supply = <&vmain>; smps8-in-supply = <&vmain>; smps9-in-supply = <&vmain>; ldo1-in-supply = <&vmain>; ldo2-in-supply = <&vmain>; ldo3-in-supply = <&vmain>; ldo4-in-supply = <&vmain>; ldo9-in-supply = <&vmain>; ldoln-in-supply = <&vmain>; ldousb-in-supply = <&vmain>; ldortc-in-supply = <&vmain>; regulators { smps12_reg: smps12 { /* VDD_MPU */ regulator-name = "smps12"; regulator-min-microvolt = <850000>; regulator-max-microvolt = <1250000>; regulator-always-on; regulator-boot-on; }; smps3_reg: smps3 { /* VDD_DDR EMIF1 EMIF2 */ regulator-name = "smps3"; regulator-min-microvolt = <1350000>; regulator-max-microvolt = <1350000>; regulator-always-on; regulator-boot-on; }; smps45_reg: smps45 { /* VDD_DSPEVE on AM572 */ /* VDD_IVA + VDD_DSP on AM571 */ regulator-name = "smps45"; regulator-min-microvolt = <850000>; regulator-max-microvolt = <1250000>; regulator-always-on; regulator-boot-on; }; smps6_reg: smps6 { /* VDD_GPU */ regulator-name = "smps6"; regulator-min-microvolt = <850000>; regulator-max-microvolt = <1250000>; regulator-always-on; regulator-boot-on; }; smps7_reg: smps7 { /* VDD_CORE */ regulator-name = "smps7"; regulator-min-microvolt = <850000>; regulator-max-microvolt = <1150000>; regulator-always-on; regulator-boot-on; }; smps8_reg: smps8 { /* 5728 - VDD_IVAHD */ /* 5718 - N.C. test point */ regulator-name = "smps8"; }; smps9_reg: smps9 { /* VDD_3_3D */ regulator-name = "smps9"; regulator-min-microvolt = <3300000>; regulator-max-microvolt = <3300000>; regulator-always-on; regulator-boot-on; }; ldo1_reg: ldo1 { /* VDDSHV8 - VSDMMC */ /* NOTE: on rev 1.3a, data supply */ regulator-name = "ldo1"; regulator-min-microvolt = <1800000>; regulator-max-microvolt = <3300000>; regulator-boot-on; regulator-always-on; }; ldo2_reg: ldo2 { /* VDDSH18V */ regulator-name = "ldo2"; regulator-min-microvolt = <1800000>; regulator-max-microvolt = <1800000>; regulator-always-on; regulator-boot-on; }; ldo3_reg: ldo3 { /* R1.3a 572x V1_8PHY_LDO3: USB, SATA */ regulator-name = "ldo3"; regulator-min-microvolt = <1800000>; regulator-max-microvolt = <1800000>; regulator-always-on; regulator-boot-on; }; ldo4_reg: ldo4 { /* R1.3a 572x V1_8PHY_LDO4: PCIE, HDMI*/ regulator-name = "ldo4"; regulator-min-microvolt = <1800000>; regulator-max-microvolt = <1800000>; regulator-always-on; regulator-boot-on; }; /* LDO5-8 unused */ ldo9_reg: ldo9 { /* VDD_RTC */ regulator-name = "ldo9"; regulator-min-microvolt = <840000>; regulator-max-microvolt = <1160000>; regulator-always-on; regulator-boot-on; }; ldoln_reg: ldoln { /* VDDA_1V8_PLL */ regulator-name = "ldoln"; regulator-min-microvolt = <1800000>; regulator-max-microvolt = <1800000>; regulator-always-on; regulator-boot-on; }; ldousb_reg: ldousb { /* VDDA_3V_USB: VDDA_USBHS33 */ regulator-name = "ldousb"; regulator-min-microvolt = <3300000>; regulator-max-microvolt = <3300000>; regulator-always-on; regulator-boot-on; }; ldortc_reg: ldortc { /* VDDA_RTC */ regulator-name = "ldortc"; regulator-min-microvolt = <1800000>; regulator-max-microvolt = <1800000>; regulator-always-on; regulator-boot-on; }; regen1: regen1 { /* VDD_3V3_ON */ regulator-name = "regen1"; regulator-boot-on; regulator-always-on; }; regen2: regen2 { /* Needed for PMIC internal resource */ regulator-name = "regen2"; regulator-boot-on; regulator-always-on; }; }; }; tps659038_rtc: tps659038_rtc { compatible = "ti,palmas-rtc"; interrupt-parent = <&tps659038>; interrupts = <8 IRQ_TYPE_EDGE_FALLING>; wakeup-source; }; // //tps659038_pwr_button: tps659038_pwr_button { //compatible = "ti,palmas-pwrbutton"; //interrupt-parent = <&tps659038>; //interrupts = <1 IRQ_TYPE_EDGE_FALLING>; //wakeup-source; //ti,palmas-long-press-seconds = <12>; //}; // tps659038_gpio: tps659038_gpio { compatible = "ti,palmas-gpio"; gpio-controller; #gpio-cells = <2>; }; // //extcon_usb2: tps659038_usb { //compatible = "ti,palmas-usb-vid"; //ti,enable-vbus-detection; //ti,enable-id-detection; /* ID & VBUS GPIOs provided in board dts */ //}; }; }; &uart3 { status = "okay"; interrupts-extended = <&crossbar_mpu GIC_SPI 69 IRQ_TYPE_LEVEL_HIGH &dra7_pmx_core 0x248>; }; &rtc { status = "okay"; ext-clk-src; }; &mac { status = "okay"; dual_emac; }; &cpsw_emac0 { phy_id = <&davinci_mdio>, <0>; phy-mode = "rgmii"; dual_emac_res_vlan = <1>; }; &cpsw_emac1 { phy_id = <&davinci_mdio>, <1>; phy-mode = "rgmii"; dual_emac_res_vlan = <2>; }; &usb2_phy1 { phy-supply = <&ldousb_reg>; }; &usb2_phy2 { phy-supply = <&ldousb_reg>; }; &usb1 { dr_mode = "host"; }; &usb2 { dr_mode = "peripheral"; }; &mmc1 { status = "okay"; vmmc-supply = <&v3_3d>; vqmmc-supply = <&ldo1_reg>; bus-width = <4>; cd-gpios = <&gpio6 27 GPIO_ACTIVE_HIGH>; /* gpio 219 */ //no-1-8-v; }; &mmc2 { status = "okay"; vmmc-supply = <&v3_3d>; bus-width = <8>; ti,non-removable; max-frequency = <96000000>; no-1-8-v; /delete-property/ mmc-hs200-1_8v; }; //&dcan1 { //status = "okay"; //pinctrl-names = "default", "sleep", "active"; //pinctrl-0 = <&dcan1_pins_sleep>; //pinctrl-1 = <&dcan1_pins_sleep>; //pinctrl-2 = <&dcan1_pins_default>; //}; &qspi { status = "okay"; spi-max-frequency = <76800000>; m25p80@0 { compatible = "s25fl256s1", "jedec,spi-nor"; spi-max-frequency = <76800000>; reg = <0>; spi-tx-bus-width = <1>; spi-rx-bus-width = <4>; #address-cells = <1>; #size-cells = <1>; /* MTD partition table. * The ROM checks the first four physical blocks * for a valid file to boot and the flash here is * 64KiB block size. */ partition@0 { label = "QSPI.SPL"; reg = <0x00000000 0x000040000>; }; partition@1 { label = "QSPI.u-boot"; reg = <0x00040000 0x00100000>; }; partition@2 { label = "QSPI.u-boot-spl-os"; reg = <0x00140000 0x00080000>; }; partition@3 { label = "QSPI.u-boot-env"; reg = <0x001c0000 0x00010000>; }; partition@4 { label = "QSPI.u-boot-env.backup1"; reg = <0x001d0000 0x0010000>; }; partition@5 { label = "QSPI.kernel"; reg = <0x001e0000 0x0800000>; }; partition@6 { label = "QSPI.file-system"; reg = <0x009e0000 0x01620000>; }; }; }; /*#include "am57xx-idk-common.dtsi"*/ / { memory@0 { device_type = "memory"; reg = <0x0 0x80000000 0x0 0x80000000>; }; }; //&omap_dwc3_2 { //extcon = <&extcon_usb2>; //}; //&extcon_usb2 { //id-gpio = <&gpio3 16 GPIO_ACTIVE_HIGH>; //vbus-gpio = <&gpio3 26 GPIO_ACTIVE_HIGH>; //}; // //&sn65hvs882 { //load-gpios = <&gpio3 19 GPIO_ACTIVE_LOW>; //}; // //&pcie1_rc { //status = "okay"; //gpios = <&gpio3 23 GPIO_ACTIVE_HIGH>; //}; // //&pcie1_ep { //gpios = <&gpio3 23 GPIO_ACTIVE_HIGH>; //}; &mailbox5 { status = "okay"; mbox_ipu1_ipc3x: mbox_ipu1_ipc3x { status = "okay"; }; mbox_dsp1_ipc3x: mbox_dsp1_ipc3x { status = "okay"; }; }; &mailbox6 { status = "okay"; mbox_ipu2_ipc3x: mbox_ipu2_ipc3x { status = "okay"; }; mbox_dsp2_ipc3x: mbox_dsp2_ipc3x { status = "okay"; }; }; #include "dra7-mmc-iodelay.dtsi" #include "dra74x-mmc-iodelay.dtsi" / { model = "SKF Controller Board"; compatible = "ti,am5728-idk", "ti,am5728", "ti,dra742", "ti,dra74", "ti,dra7"; }; &mmc1 { pinctrl-names = "default", "hs"; //pinctrl-0 = <&mmc1_pins_default_no_clk_pu>; pinctrl-0 = <&mmc1_pins_default>; pinctrl-1 = <&mmc1_pins_hs>; /delete-property/ sd-uhs-sdr104; /delete-property/ sd-uhs-sdr50; /delete-property/ sd-uhs-ddr50; /delete-property/ sd-uhs-sdr25; /delete-property/ sd-uhs-sdr12; }; &mmc2 { pinctrl-names = "default", "hs", "ddr_1_8v"; pinctrl-0 = <&mmc2_pins_default>; pinctrl-1 = <&mmc2_pins_hs>; pinctrl-2 = <&mmc2_pins_ddr_rev20>; };
U-Boot SPL 2019.01-g4fd17df956-dirty (Jun 18 2020 - 20:17:51 -0600) DRA752-GP ES2.0 Trying to boot from MMC1 no pinctrl state for default mode Timed out in wait_for_event: status=0000 Check if pads/pull-ups of bus are properly configured unable to get I2C bus. ret 1 tps65903x: could not set LDO1 voltage. no pinctrl state for default mode Loading Environment from FAT... OK U-Boot 2019.01-g4fd17df956-dirty (Jun 18 2020 - 20:17:47 -0600) CPU : DRA752-GP ES2.0 Model: SKF Controller Board Board: SKF Control Board REV 1a DRAM: 2 GiB MMC: OMAP SD/MMC: 0, OMAP SD/MMC: 1 Loading Environment from FAT... OK Net: Warning: ethernet@48484000 using MAC address from ROM eth0: ethernet@48484000 Hit any key to stop autoboot: 2 1 0 switch to partitions #0, OK mmc0 is current device SD/MMC found on device 0 ** Unable to read file boot.scr ** 1526 bytes read in 2 ms (745.1 KiB/s) Loaded env from uEnv.txt Importing environment from mmc0 ... Running uenvcmd ... 0 bytes read in 0 ms Already setup. switch to partitions #0, OK mmc0 is current device SD/MMC found on device 0 4448768 bytes read in 219 ms (19.4 MiB/s) 130884 bytes read in 12 ms (10.4 MiB/s) ## Flattened Device Tree blob at 88000000 Booting using the fdt blob at 0x88000000 Loading Device Tree to 8ffdd000, end 8fffff43 ... OK Starting kernel ... [ 0.000000] Booting Linux on physical CPU 0x0 [ 0.000000] Linux version 4.19.94-gbe5389fd85 (oe-user@oe-host) (gcc version 8.3.0 (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36))) #1 SMP PREEMPT Fri May 15 22:12:10 UTC 2020 [ 0.000000] CPU: ARMv7 Processor [412fc0f2] revision 2 (ARMv7), cr=30c5387d [ 0.000000] CPU: div instructions available: patching division code [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache [ 0.000000] OF: fdt: Machine model: SKF Controller Board [ 0.000000] Memory policy: Data cache writealloc [ 0.000000] efi: Getting EFI parameters from FDT: [ 0.000000] efi: UEFI not found. [ 0.000000] cma: Reserved 24 MiB at 0x00000000fe400000 [ 0.000000] OMAP4: Map 0x00000000ffd00000 to (ptrval) for dram barrier [ 0.000000] Hit pending asynchronous external abort (FSR=0x00001211) during first unmask, this is most likely caused by a firmware/bootloader bug. [ 0.000000] DRA752 ES2.0 [ 0.000000] random: get_random_bytes called from start_kernel+0xb4/0x470 with crng_init=0 [ 0.000000] percpu: Embedded 15 pages/cpu s32396 r8192 d20852 u61440 [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 521792 [ 0.000000] Kernel command line: console=ttyS2,115200n8 root=PARTUUID=41d4c7bc-02 rw rootfstype=ext4 rootwait [ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes) [ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes) [ 0.000000] Memory: 2032704K/2094080K available (10240K kernel code, 335K rwdata, 2800K rodata, 2048K init, 268K bss, 36800K reserved, 24576K cma-reserved, 1283072K highmem) [ 0.000000] Virtual kernel memory layout: [ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB) [ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB) [ 0.000000] vmalloc : 0xf0800000 - 0xff800000 ( 240 MB) [ 0.000000] lowmem : 0xc0000000 - 0xf0000000 ( 768 MB) [ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB) [ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB) [ 0.000000] .text : 0x(ptrval) - 0x(ptrval) (12256 kB) [ 0.000000] .init : 0x(ptrval) - 0x(ptrval) (2048 kB) [ 0.000000] .data : 0x(ptrval) - 0x(ptrval) ( 336 kB) [ 0.000000] .bss : 0x(ptrval) - 0x(ptrval) ( 269 kB) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1 [ 0.000000] rcu: Preemptible hierarchical RCU implementation. [ 0.000000] Tasks RCU enabled. [ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16 [ 0.000000] GIC: Using split EOI/Deactivate mode [ 0.000000] ti_dt_clocks_register: missing clkctrl nodes, please update your dts. [ 0.000000] OMAP clockevent source: timer1 at 32786 Hz [ 0.000000] arch_timer: cp15 timer(s) running at 6.14MHz (phys). [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x16af5adb9, max_idle_ns: 440795202250 ns [ 0.000005] sched_clock: 56 bits at 6MHz, resolution 162ns, wraps every 4398046511023ns [ 0.000018] Switching to timer-based delay loop, resolution 162ns [ 0.000343] clocksource: 32k_counter: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 58327039986419 ns [ 0.000353] OMAP clocksource: 32k_counter at 32768 Hz [ 0.000763] Console: colour dummy device 80x30 [ 0.000806] Calibrating delay loop (skipped), value calculated using timer frequency.. 12.29 BogoMIPS (lpj=61475) [ 0.000821] pid_max: default: 32768 minimum: 301 [ 0.000941] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes) [ 0.000956] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes) [ 0.001526] CPU: Testing write buffer coherency: ok [ 0.001561] CPU0: Spectre v2: using ICIALLU workaround [ 0.001775] /cpus/cpu@0 missing clock-frequency property [ 0.001795] /cpus/cpu@1 missing clock-frequency property [ 0.001808] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000 [ 0.059907] Setting up static identity map for 0x80200000 - 0x80200060 [ 0.079920] rcu: Hierarchical SRCU implementation. [ 0.100110] EFI services will not be available. [ 0.119979] smp: Bringing up secondary CPUs ... [ 0.200372] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001 [ 0.200377] CPU1: Spectre v2: using ICIALLU workaround [ 0.200501] smp: Brought up 1 node, 2 CPUs [ 0.200513] SMP: Total of 2 processors activated (24.59 BogoMIPS). [ 0.200522] CPU: All CPU(s) started in HYP mode. [ 0.200530] CPU: Virtualization extensions available. [ 0.201105] devtmpfs: initialized [ 0.219916] VFP support v0.3: implementor 41 architecture 4 part 30 variant f rev 0 [ 0.220200] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns [ 0.220220] futex hash table entries: 512 (order: 3, 32768 bytes) [ 0.220724] pinctrl core: initialized pinctrl subsystem [ 0.221215] DMI not present or invalid. [ 0.221487] NET: Registered protocol family 16 [ 0.222625] DMA: preallocated 256 KiB pool for atomic coherent allocations [ 0.223548] omap_hwmod: l3_main_2 using broken dt data from ocp [ 0.243141] omap_hwmod: dma_system: no dt node [ 0.243152] ------------[ cut here ]------------ [ 0.243172] WARNING: CPU: 0 PID: 1 at arch/arm/mach-omap2/omap_hwmod.c:2409 _init.constprop.22+0x1b0/0x4dc [ 0.243181] omap_hwmod: dma_system: doesn't have mpu register target base [ 0.243190] Modules linked in: [ 0.243205] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 4.19.94-gbe5389fd85 #1 [ 0.243214] Hardware name: Generic DRA74X (Flattened Device Tree) [ 0.243223] Backtrace: [ 0.243242] [<c020ca34>] (dump_backtrace) from [<c020cd6c>] (show_stack+0x18/0x1c) [ 0.243255] r7:c0dcd1d8 r6:60000013 r5:00000000 r4:c12506dc [ 0.243273] [<c020cd54>] (show_stack) from [<c0a15124>] (dump_stack+0x9c/0xb0) [ 0.243288] [<c0a15088>] (dump_stack) from [<c022e100>] (__warn+0xdc/0xf8) [ 0.243300] r7:c0dcd1d8 r6:00000009 r5:00000000 r4:ee89bddc [ 0.243312] [<c022e024>] (__warn) from [<c022dd38>] (warn_slowpath_fmt+0x50/0x6c) [ 0.243325] r9:c104b824 r8:00000000 r7:c12125ec r6:00000000 r5:c0dcd7b4 r4:c1204c48 [ 0.243338] [<c022dcec>] (warn_slowpath_fmt) from [<c100cef4>] (_init.constprop.22+0x1b0/0x4dc) [ 0.243347] r3:c0dcdc58 r2:c0dcd7b4 [ 0.243356] r5:00000000 r4:c12125b4 [ 0.243369] [<c100cd44>] (_init.constprop.22) from [<c100d350>] (__omap_hwmod_setup_all+0x48/0x134) [ 0.243382] r10:c10606e8 r9:c104b824 r8:00000000 r7:c100d308 r6:ffffe000 r5:c120a2e8 [ 0.243390] r4:c12125b4 [ 0.243403] [<c100d308>] (__omap_hwmod_setup_all) from [<c02025b8>] (do_one_initcall+0x84/0x1b0) [ 0.243413] r5:c1204c48 r4:c1253e00 [ 0.243427] [<c0202534>] (do_one_initcall) from [<c1000fe8>] (kernel_init_freeable+0x1c4/0x258) [ 0.243438] r8:c104b844 r7:c10004f0 r6:c1253e00 r5:c1253e00 r4:00000003 [ 0.243452] [<c1000e24>] (kernel_init_freeable) from [<c0a29438>] (kernel_init+0x10/0x11c) [ 0.243463] r10:00000000 r9:00000000 r8:00000000 r7:00000000 r6:00000000 r5:c0a29428 [ 0.243471] r4:00000000 [ 0.243483] [<c0a29428>] (kernel_init) from [<c02010d8>] (ret_from_fork+0x14/0x3c) [ 0.243492] Exception stack(0xee89bfb0 to 0xee89bff8) [ 0.243503] bfa0: 00000000 00000000 00000000 00000000 [ 0.243514] bfc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 0.243525] bfe0: 00000000 00000000 00000000 00000000 00000013 00000000 [ 0.243534] r5:c0a29428 r4:00000000 [ 0.243545] ---[ end trace b11d5f38a71584ec ]--- [ 0.259063] omap_hwmod: gpu: no dt node [ 0.259073] ------------[ cut here ]------------ [ 0.259087] WARNING: CPU: 0 PID: 1 at arch/arm/mach-omap2/omap_hwmod.c:2409 _init.constprop.22+0x1b0/0x4dc [ 0.259096] omap_hwmod: gpu: doesn't have mpu register target base [ 0.259103] Modules linked in: [ 0.259116] CPU: 0 PID: 1 Comm: swapper/0 Tainted: G W 4.19.94-gbe5389fd85 #1 [ 0.259125] Hardware name: Generic DRA74X (Flattened Device Tree) [ 0.259133] Backtrace: [ 0.259148] [<c020ca34>] (dump_backtrace) from [<c020cd6c>] (show_stack+0x18/0x1c) [ 0.259160] r7:c0dcd1d8 r6:60000013 r5:00000000 r4:c12506dc [ 0.259174] [<c020cd54>] (show_stack) from [<c0a15124>] (dump_stack+0x9c/0xb0) [ 0.259187] [<c0a15088>] (dump_stack) from [<c022e100>] (__warn+0xdc/0xf8) [ 0.259198] r7:c0dcd1d8 r6:00000009 r5:00000000 r4:ee89bddc [ 0.259210] [<c022e024>] (__warn) from [<c022dd38>] (warn_slowpath_fmt+0x50/0x6c) [ 0.259222] r9:c104b824 r8:00000000 r7:c1211928 r6:00000000 r5:c0dcd7b4 r4:c1204c48 [ 0.259235] [<c022dcec>] (warn_slowpath_fmt) from [<c100cef4>] (_init.constprop.22+0x1b0/0x4dc) [ 0.259244] r3:c0dcf8d8 r2:c0dcd7b4 [ 0.259253] r5:00000000 r4:c12118f0 [ 0.259266] [<c100cd44>] (_init.constprop.22) from [<c100d350>] (__omap_hwmod_setup_all+0x48/0x134) [ 0.259277] r10:c10606e8 r9:c104b824 r8:00000000 r7:c100d308 r6:ffffe000 r5:c120a2e8 [ 0.259285] r4:c12118f0 [ 0.259298] [<c100d308>] (__omap_hwmod_setup_all) from [<c02025b8>] (do_one_initcall+0x84/0x1b0) [ 0.259308] r5:c1204c48 r4:c1253e00 [ 0.259321] [<c0202534>] (do_one_initcall) from [<c1000fe8>] (kernel_init_freeable+0x1c4/0x258) [ 0.259332] r8:c104b844 r7:c10004f0 r6:c1253e00 r5:c1253e00 r4:00000003 [ 0.259345] [<c1000e24>] (kernel_init_freeable) from [<c0a29438>] (kernel_init+0x10/0x11c) [ 0.259357] r10:00000000 r9:00000000 r8:00000000 r7:00000000 r6:00000000 r5:c0a29428 [ 0.259365] r4:00000000 [ 0.259376] [<c0a29428>] (kernel_init) from [<c02010d8>] (ret_from_fork+0x14/0x3c) [ 0.259385] Exception stack(0xee89bfb0 to 0xee89bff8) [ 0.259396] bfa0: 00000000 00000000 00000000 00000000 [ 0.259407] bfc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 0.259418] bfe0: 00000000 00000000 00000000 00000000 00000013 00000000 [ 0.259427] r5:c0a29428 r4:00000000 [ 0.259435] ---[ end trace b11d5f38a71584ed ]--- [ 0.260366] omap_hwmod: hdq1w: no dt node [ 0.260375] ------------[ cut here ]------------ [ 0.260389] WARNING: CPU: 0 PID: 1 at arch/arm/mach-omap2/omap_hwmod.c:2409 _init.constprop.22+0x1b0/0x4dc [ 0.260398] omap_hwmod: hdq1w: doesn't have mpu register target base [ 0.260405] Modules linked in: [ 0.260419] CPU: 0 PID: 1 Comm: swapper/0 Tainted: G W 4.19.94-gbe5389fd85 #1 [ 0.260428] Hardware name: Generic DRA74X (Flattened Device Tree) [ 0.260435] Backtrace: [ 0.260450] [<c020ca34>] (dump_backtrace) from [<c020cd6c>] (show_stack+0x18/0x1c) [ 0.260462] r7:c0dcd1d8 r6:60000013 r5:00000000 r4:c12506dc [ 0.260476] [<c020cd54>] (show_stack) from [<c0a15124>] (dump_stack+0x9c/0xb0) [ 0.260489] [<c0a15088>] (dump_stack) from [<c022e100>] (__warn+0xdc/0xf8) [ 0.260499] r7:c0dcd1d8 r6:00000009 r5:00000000 r4:ee89bddc [ 0.260511] [<c022e024>] (__warn) from [<c022dd38>] (warn_slowpath_fmt+0x50/0x6c) [ 0.260523] r9:c104b824 r8:00000000 r7:c1211880 r6:00000000 r5:c0dcd7b4 r4:c1204c48 [ 0.260535] [<c022dcec>] (warn_slowpath_fmt) from [<c100cef4>] (_init.constprop.22+0x1b0/0x4dc) [ 0.260544] r3:c0dcf8c0 r2:c0dcd7b4 [ 0.260553] r5:00000000 r4:c1211848 [ 0.260565] [<c100cd44>] (_init.constprop.22) from [<c100d350>] (__omap_hwmod_setup_all+0x48/0x134) [ 0.260577] r10:c10606e8 r9:c104b824 r8:00000000 r7:c100d308 r6:ffffe000 r5:c120a2e8 [ 0.260585] r4:c1211848 [ 0.260598] [<c100d308>] (__omap_hwmod_setup_all) from [<c02025b8>] (do_one_initcall+0x84/0x1b0) [ 0.260607] r5:c1204c48 r4:c1253e00 [ 0.260620] [<c0202534>] (do_one_initcall) from [<c1000fe8>] (kernel_init_freeable+0x1c4/0x258) [ 0.260632] r8:c104b844 r7:c10004f0 r6:c1253e00 r5:c1253e00 r4:00000003 [ 0.260644] [<c1000e24>] (kernel_init_freeable) from [<c0a29438>] (kernel_init+0x10/0x11c) [ 0.260656] r10:00000000 r9:00000000 r8:00000000 r7:00000000 r6:00000000 r5:c0a29428 [ 0.260663] r4:00000000 [ 0.260675] [<c0a29428>] (kernel_init) from [<c02010d8>] (ret_from_fork+0x14/0x3c) [ 0.260683] Exception stack(0xee89bfb0 to 0xee89bff8) [ 0.260694] bfa0: 00000000 00000000 00000000 00000000 [ 0.260705] bfc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 0.260716] bfe0: 00000000 00000000 00000000 00000000 00000013 00000000 [ 0.260725] r5:c0a29428 r4:00000000 [ 0.260734] ---[ end trace b11d5f38a71584ee ]--- [ 0.290920] omap_hwmod: smartreflex_core: no dt node [ 0.290930] ------------[ cut here ]------------ [ 0.290944] WARNING: CPU: 0 PID: 1 at arch/arm/mach-omap2/omap_hwmod.c:2409 _init.constprop.22+0x1b0/0x4dc [ 0.290953] omap_hwmod: smartreflex_core: doesn't have mpu register target base [ 0.290960] Modules linked in: [ 0.290974] CPU: 0 PID: 1 Comm: swapper/0 Tainted: G W 4.19.94-gbe5389fd85 #1 [ 0.290983] Hardware name: Generic DRA74X (Flattened Device Tree) [ 0.290990] Backtrace: [ 0.291004] [<c020ca34>] (dump_backtrace) from [<c020cd6c>] (show_stack+0x18/0x1c) [ 0.291016] r7:c0dcd1d8 r6:60000013 r5:00000000 r4:c12506dc [ 0.291031] [<c020cd54>] (show_stack) from [<c0a15124>] (dump_stack+0x9c/0xb0) [ 0.291044] [<c0a15088>] (dump_stack) from [<c022e100>] (__warn+0xdc/0xf8) [ 0.291055] r7:c0dcd1d8 r6:00000009 r5:00000000 r4:ee89bddc [ 0.291066] [<c022e024>] (__warn) from [<c022dd38>] (warn_slowpath_fmt+0x50/0x6c) [ 0.291078] r9:c104b824 r8:00000000 r7:c120fd88 r6:00000000 r5:c0dcd7b4 r4:c1204c48 [ 0.291091] [<c022dcec>] (warn_slowpath_fmt) from [<c100cef4>] (_init.constprop.22+0x1b0/0x4dc) [ 0.291100] r3:c0dcf40c r2:c0dcd7b4 [ 0.291109] r5:00000000 r4:c120fd50 [ 0.291122] [<c100cd44>] (_init.constprop.22) from [<c100d350>] (__omap_hwmod_setup_all+0x48/0x134) [ 0.291134] r10:c10606e8 r9:c104b824 r8:00000000 r7:c100d308 r6:ffffe000 r5:c120a2e8 [ 0.291142] r4:c120fd50 [ 0.291155] [<c100d308>] (__omap_hwmod_setup_all) from [<c02025b8>] (do_one_initcall+0x84/0x1b0) [ 0.291164] r5:c1204c48 r4:c1253e00 [ 0.291177] [<c0202534>] (do_one_initcall) from [<c1000fe8>] (kernel_init_freeable+0x1c4/0x258) [ 0.291188] r8:c104b844 r7:c10004f0 r6:c1253e00 r5:c1253e00 r4:00000003 [ 0.291200] [<c1000e24>] (kernel_init_freeable) from [<c0a29438>] (kernel_init+0x10/0x11c) [ 0.291212] r10:00000000 r9:00000000 r8:00000000 r7:00000000 r6:00000000 r5:c0a29428 [ 0.291220] r4:00000000 [ 0.291231] [<c0a29428>] (kernel_init) from [<c02010d8>] (ret_from_fork+0x14/0x3c) [ 0.291239] Exception stack(0xee89bfb0 to 0xee89bff8) [ 0.291249] bfa0: 00000000 00000000 00000000 00000000 [ 0.291261] bfc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 0.291272] bfe0: 00000000 00000000 00000000 00000000 00000013 00000000 [ 0.291281] r5:c0a29428 r4:00000000 [ 0.291289] ---[ end trace b11d5f38a71584ef ]--- [ 0.292190] omap_hwmod: smartreflex_mpu: no dt node [ 0.292198] ------------[ cut here ]------------ [ 0.292211] WARNING: CPU: 0 PID: 1 at arch/arm/mach-omap2/omap_hwmod.c:2409 _init.constprop.22+0x1b0/0x4dc [ 0.292219] omap_hwmod: smartreflex_mpu: doesn't have mpu register target base [ 0.292226] Modules linked in: [ 0.292239] CPU: 0 PID: 1 Comm: swapper/0 Tainted: G W 4.19.94-gbe5389fd85 #1 [ 0.292248] Hardware name: Generic DRA74X (Flattened Device Tree) [ 0.292255] Backtrace: [ 0.292269] [<c020ca34>] (dump_backtrace) from [<c020cd6c>] (show_stack+0x18/0x1c) [ 0.292279] r7:c0dcd1d8 r6:60000013 r5:00000000 r4:c12506dc [ 0.292293] [<c020cd54>] (show_stack) from [<c0a15124>] (dump_stack+0x9c/0xb0) [ 0.292306] [<c0a15088>] (dump_stack) from [<c022e100>] (__warn+0xdc/0xf8) [ 0.292317] r7:c0dcd1d8 r6:00000009 r5:00000000 r4:ee89bddc [ 0.292329] [<c022e024>] (__warn) from [<c022dd38>] (warn_slowpath_fmt+0x50/0x6c) [ 0.292340] r9:c104b824 r8:00000000 r7:c120fd14 r6:00000000 r5:c0dcd7b4 r4:c1204c48 [ 0.292353] [<c022dcec>] (warn_slowpath_fmt) from [<c100cef4>] (_init.constprop.22+0x1b0/0x4dc) [ 0.292362] r3:c0dcf3fc r2:c0dcd7b4 [ 0.292371] r5:00000000 r4:c120fcdc [ 0.292384] [<c100cd44>] (_init.constprop.22) from [<c100d350>] (__omap_hwmod_setup_all+0x48/0x134) [ 0.292396] r10:c10606e8 r9:c104b824 r8:00000000 r7:c100d308 r6:ffffe000 r5:c120a2e8 [ 0.292404] r4:c120fcdc [ 0.292416] [<c100d308>] (__omap_hwmod_setup_all) from [<c02025b8>] (do_one_initcall+0x84/0x1b0) [ 0.292425] r5:c1204c48 r4:c1253e00 [ 0.292439] [<c0202534>] (do_one_initcall) from [<c1000fe8>] (kernel_init_freeable+0x1c4/0x258) [ 0.292450] r8:c104b844 r7:c10004f0 r6:c1253e00 r5:c1253e00 r4:00000003 [ 0.292462] [<c1000e24>] (kernel_init_freeable) from [<c0a29438>] (kernel_init+0x10/0x11c) [ 0.292473] r10:00000000 r9:00000000 r8:00000000 r7:00000000 r6:00000000 r5:c0a29428 [ 0.292481] r4:00000000 [ 0.292492] [<c0a29428>] (kernel_init) from [<c02010d8>] (ret_from_fork+0x14/0x3c) [ 0.292501] Exception stack(0xee89bfb0 to 0xee89bff8) [ 0.292511] bfa0: 00000000 00000000 00000000 00000000 [ 0.292523] bfc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 0.292534] bfe0: 00000000 00000000 00000000 00000000 00000013 00000000 [ 0.292542] r5:c0a29428 r4:00000000 [ 0.292551] ---[ end trace b11d5f38a71584f0 ]--- [ 0.314943] omap_hwmod: vpe: no dt node [ 0.314953] ------------[ cut here ]------------ [ 0.314967] WARNING: CPU: 0 PID: 1 at arch/arm/mach-omap2/omap_hwmod.c:2409 _init.constprop.22+0x1b0/0x4dc [ 0.314976] omap_hwmod: vpe: doesn't have mpu register target base [ 0.314984] Modules linked in: [ 0.314997] CPU: 0 PID: 1 Comm: swapper/0 Tainted: G W 4.19.94-gbe5389fd85 #1 [ 0.315006] Hardware name: Generic DRA74X (Flattened Device Tree) [ 0.315014] Backtrace: [ 0.315029] [<c020ca34>] (dump_backtrace) from [<c020cd6c>] (show_stack+0x18/0x1c) [ 0.315041] r7:c0dcd1d8 r6:60000013 r5:00000000 r4:c12506dc [ 0.315054] [<c020cd54>] (show_stack) from [<c0a15124>] (dump_stack+0x9c/0xb0) [ 0.315068] [<c0a15088>] (dump_stack) from [<c022e100>] (__warn+0xdc/0xf8) [ 0.315079] r7:c0dcd1d8 r6:00000009 r5:00000000 r4:ee89bddc [ 0.315091] [<c022e024>] (__warn) from [<c022dd38>] (warn_slowpath_fmt+0x50/0x6c) [ 0.315103] r9:c104b824 r8:00000000 r7:c1212e34 r6:00000000 r5:c0dcd7b4 r4:c1204c48 [ 0.315115] [<c022dcec>] (warn_slowpath_fmt) from [<c100cef4>] (_init.constprop.22+0x1b0/0x4dc) [ 0.315125] r3:c0dcfb68 r2:c0dcd7b4 [ 0.315133] r5:00000000 r4:c1212dfc [ 0.315146] [<c100cd44>] (_init.constprop.22) from [<c100d350>] (__omap_hwmod_setup_all+0x48/0x134) [ 0.315157] r10:c10606e8 r9:c104b824 r8:00000000 r7:c100d308 r6:ffffe000 r5:c120a2e8 [ 0.315165] r4:c1212dfc [ 0.315178] [<c100d308>] (__omap_hwmod_setup_all) from [<c02025b8>] (do_one_initcall+0x84/0x1b0) [ 0.315187] r5:c1204c48 r4:c1253e00 [ 0.315200] [<c0202534>] (do_one_initcall) from [<c1000fe8>] (kernel_init_freeable+0x1c4/0x258) [ 0.315211] r8:c104b844 r7:c10004f0 r6:c1253e00 r5:c1253e00 r4:00000003 [ 0.315224] [<c1000e24>] (kernel_init_freeable) from [<c0a29438>] (kernel_init+0x10/0x11c) [ 0.315236] r10:00000000 r9:00000000 r8:00000000 r7:00000000 r6:00000000 r5:c0a29428 [ 0.315243] r4:00000000 [ 0.315255] [<c0a29428>] (kernel_init) from [<c02010d8>] (ret_from_fork+0x14/0x3c) [ 0.315263] Exception stack(0xee89bfb0 to 0xee89bff8) [ 0.315273] bfa0: 00000000 00000000 00000000 00000000 [ 0.315285] bfc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 0.315296] bfe0: 00000000 00000000 00000000 00000000 00000013 00000000 [ 0.315305] r5:c0a29428 r4:00000000 [ 0.315313] ---[ end trace b11d5f38a71584f1 ]--- [ 0.316209] omap_hwmod: vip1: no dt node [ 0.316217] ------------[ cut here ]------------ [ 0.316230] WARNING: CPU: 0 PID: 1 at arch/arm/mach-omap2/omap_hwmod.c:2409 _init.constprop.22+0x1b0/0x4dc [ 0.316239] omap_hwmod: vip1: doesn't have mpu register target base [ 0.316246] Modules linked in: [ 0.316257] CPU: 0 PID: 1 Comm: swapper/0 Tainted: G W 4.19.94-gbe5389fd85 #1 [ 0.316266] Hardware name: Generic DRA74X (Flattened Device Tree) [ 0.316273] Backtrace: [ 0.316288] [<c020ca34>] (dump_backtrace) from [<c020cd6c>] (show_stack+0x18/0x1c) [ 0.316299] r7:c0dcd1d8 r6:60000013 r5:00000000 r4:c12506dc [ 0.316312] [<c020cd54>] (show_stack) from [<c0a15124>] (dump_stack+0x9c/0xb0) [ 0.316325] [<c0a15088>] (dump_stack) from [<c022e100>] (__warn+0xdc/0xf8) [ 0.316335] r7:c0dcd1d8 r6:00000009 r5:00000000 r4:ee89bddc [ 0.316347] [<c022e024>] (__warn) from [<c022dd38>] (warn_slowpath_fmt+0x50/0x6c) [ 0.316359] r9:c104b824 r8:00000000 r7:c1212d8c r6:00000000 r5:c0dcd7b4 r4:c1204c48 [ 0.316371] [<c022dcec>] (warn_slowpath_fmt) from [<c100cef4>] (_init.constprop.22+0x1b0/0x4dc) [ 0.316380] r3:c0dcfb4c r2:c0dcd7b4 [ 0.316388] r5:00000000 r4:c1212d54 [ 0.316401] [<c100cd44>] (_init.constprop.22) from [<c100d350>] (__omap_hwmod_setup_all+0x48/0x134) [ 0.316413] r10:c10606e8 r9:c104b824 r8:00000000 r7:c100d308 r6:ffffe000 r5:c120a2e8 [ 0.316421] r4:c1212d54 [ 0.316434] [<c100d308>] (__omap_hwmod_setup_all) from [<c02025b8>] (do_one_initcall+0x84/0x1b0) [ 0.316443] r5:c1204c48 r4:c1253e00 [ 0.316456] [<c0202534>] (do_one_initcall) from [<c1000fe8>] (kernel_init_freeable+0x1c4/0x258) [ 0.316467] r8:c104b844 r7:c10004f0 r6:c1253e00 r5:c1253e00 r4:00000003 [ 0.316479] [<c1000e24>] (kernel_init_freeable) from [<c0a29438>] (kernel_init+0x10/0x11c) [ 0.316490] r10:00000000 r9:00000000 r8:00000000 r7:00000000 r6:00000000 r5:c0a29428 [ 0.316497] r4:00000000 [ 0.316508] [<c0a29428>] (kernel_init) from [<c02010d8>] (ret_from_fork+0x14/0x3c) [ 0.316517] Exception stack(0xee89bfb0 to 0xee89bff8) [ 0.316527] bfa0: 00000000 00000000 00000000 00000000 [ 0.316539] bfc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 0.316549] bfe0: 00000000 00000000 00000000 00000000 00000013 00000000 [ 0.316558] r5:c0a29428 r4:00000000 [ 0.316566] ---[ end trace b11d5f38a71584f2 ]--- [ 0.324515] omap_hwmod: vip2: no dt node [ 0.324527] ------------[ cut here ]------------ [ 0.324541] WARNING: CPU: 0 PID: 1 at arch/arm/mach-omap2/omap_hwmod.c:2409 _init.constprop.22+0x1b0/0x4dc [ 0.324550] omap_hwmod: vip2: doesn't have mpu register target base [ 0.324557] Modules linked in: [ 0.324570] CPU: 0 PID: 1 Comm: swapper/0 Tainted: G W 4.19.94-gbe5389fd85 #1 [ 0.324578] Hardware name: Generic DRA74X (Flattened Device Tree) [ 0.324586] Backtrace: [ 0.324600] [<c020ca34>] (dump_backtrace) from [<c020cd6c>] (show_stack+0x18/0x1c) [ 0.324613] r7:c0dcd1d8 r6:60000013 r5:00000000 r4:c12506dc [ 0.324627] [<c020cd54>] (show_stack) from [<c0a15124>] (dump_stack+0x9c/0xb0) [ 0.324640] [<c0a15088>] (dump_stack) from [<c022e100>] (__warn+0xdc/0xf8) [ 0.324651] r7:c0dcd1d8 r6:00000009 r5:00000000 r4:ee89bddc [ 0.324663] [<c022e024>] (__warn) from [<c022dd38>] (warn_slowpath_fmt+0x50/0x6c) [ 0.324674] r9:c104b824 r8:00000000 r7:c1212d1c r6:00000000 r5:c0dcd7b4 r4:c1204c48 [ 0.324688] [<c022dcec>] (warn_slowpath_fmt) from [<c100cef4>] (_init.constprop.22+0x1b0/0x4dc) [ 0.324697] r3:c0dcfb44 r2:c0dcd7b4 [ 0.324706] r5:00000000 r4:c1212ce4 [ 0.324718] [<c100cd44>] (_init.constprop.22) from [<c100d350>] (__omap_hwmod_setup_all+0x48/0x134) [ 0.324730] r10:c10606e8 r9:c104b824 r8:00000000 r7:c100d308 r6:ffffe000 r5:c120a2e8 [ 0.324739] r4:c1212ce4 [ 0.324751] [<c100d308>] (__omap_hwmod_setup_all) from [<c02025b8>] (do_one_initcall+0x84/0x1b0) [ 0.324761] r5:c1204c48 r4:c1253e00 [ 0.324774] [<c0202534>] (do_one_initcall) from [<c1000fe8>] (kernel_init_freeable+0x1c4/0x258) [ 0.324784] r8:c104b844 r7:c10004f0 r6:c1253e00 r5:c1253e00 r4:00000003 [ 0.324797] [<c1000e24>] (kernel_init_freeable) from [<c0a29438>] (kernel_init+0x10/0x11c) [ 0.324808] r10:00000000 r9:00000000 r8:00000000 r7:00000000 r6:00000000 r5:c0a29428 [ 0.324815] r4:00000000 [ 0.324827] [<c0a29428>] (kernel_init) from [<c02010d8>] (ret_from_fork+0x14/0x3c) [ 0.324835] Exception stack(0xee89bfb0 to 0xee89bff8) [ 0.324846] bfa0: 00000000 00000000 00000000 00000000 [ 0.324858] bfc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 0.324869] bfe0: 00000000 00000000 00000000 00000000 00000013 00000000 [ 0.324877] r5:c0a29428 r4:00000000 [ 0.324886] ---[ end trace b11d5f38a71584f3 ]--- [ 0.325781] omap_hwmod: vip3: no dt node [ 0.325788] ------------[ cut here ]------------ [ 0.325802] WARNING: CPU: 0 PID: 1 at arch/arm/mach-omap2/omap_hwmod.c:2409 _init.constprop.22+0x1b0/0x4dc [ 0.325810] omap_hwmod: vip3: doesn't have mpu register target base [ 0.325816] Modules linked in: [ 0.325829] CPU: 0 PID: 1 Comm: swapper/0 Tainted: G W 4.19.94-gbe5389fd85 #1 [ 0.325837] Hardware name: Generic DRA74X (Flattened Device Tree) [ 0.325844] Backtrace: [ 0.325859] [<c020ca34>] (dump_backtrace) from [<c020cd6c>] (show_stack+0x18/0x1c) [ 0.325870] r7:c0dcd1d8 r6:60000013 r5:00000000 r4:c12506dc [ 0.325884] [<c020cd54>] (show_stack) from [<c0a15124>] (dump_stack+0x9c/0xb0) [ 0.325896] [<c0a15088>] (dump_stack) from [<c022e100>] (__warn+0xdc/0xf8) [ 0.325907] r7:c0dcd1d8 r6:00000009 r5:00000000 r4:ee89bddc [ 0.325919] [<c022e024>] (__warn) from [<c022dd38>] (warn_slowpath_fmt+0x50/0x6c) [ 0.325930] r9:c104b824 r8:00000000 r7:c1212cac r6:00000000 r5:c0dcd7b4 r4:c1204c48 [ 0.325942] [<c022dcec>] (warn_slowpath_fmt) from [<c100cef4>] (_init.constprop.22+0x1b0/0x4dc) [ 0.325951] r3:c0dcfb3c r2:c0dcd7b4 [ 0.325959] r5:00000000 r4:c1212c74 [ 0.325972] [<c100cd44>] (_init.constprop.22) from [<c100d350>] (__omap_hwmod_setup_all+0x48/0x134) [ 0.325984] r10:c10606e8 r9:c104b824 r8:00000000 r7:c100d308 r6:ffffe000 r5:c120a2e8 [ 0.325991] r4:c1212c74 [ 0.326004] [<c100d308>] (__omap_hwmod_setup_all) from [<c02025b8>] (do_one_initcall+0x84/0x1b0) [ 0.326013] r5:c1204c48 r4:c1253e00 [ 0.326026] [<c0202534>] (do_one_initcall) from [<c1000fe8>] (kernel_init_freeable+0x1c4/0x258) [ 0.326037] r8:c104b844 r7:c10004f0 r6:c1253e00 r5:c1253e00 r4:00000003 [ 0.326050] [<c1000e24>] (kernel_init_freeable) from [<c0a29438>] (kernel_init+0x10/0x11c) [ 0.326061] r10:00000000 r9:00000000 r8:00000000 r7:00000000 r6:00000000 r5:c0a29428 [ 0.326069] r4:00000000 [ 0.326080] [<c0a29428>] (kernel_init) from [<c02010d8>] (ret_from_fork+0x14/0x3c) [ 0.326089] Exception stack(0xee89bfb0 to 0xee89bff8) [ 0.326099] bfa0: 00000000 00000000 00000000 00000000 [ 0.326111] bfc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 0.326121] bfe0: 00000000 00000000 00000000 00000000 00000013 00000000 [ 0.326130] r5:c0a29428 r4:00000000 [ 0.326138] ---[ end trace b11d5f38a71584f4 ]--- [ 0.416765] cpuidle: using governor ladder [ 0.416801] cpuidle: using governor menu [ 0.418129] ------------[ cut here ]------------ [ 0.418150] WARNING: CPU: 0 PID: 1 at drivers/bus/omap_l3_noc.c:147 l3_interrupt_handler+0x330/0x380 [ 0.418161] 44000000.ocp:L3 Custom Error: MASTER MPU TARGET L4_PER1_P3 (Read): Data Access in User mode during Functional access [ 0.418169] Modules linked in: [ 0.418182] CPU: 0 PID: 1 Comm: swapper/0 Tainted: G W 4.19.94-gbe5389fd85 #1 [ 0.418191] Hardware name: Generic DRA74X (Flattened Device Tree) [ 0.418199] Backtrace: [ 0.418215] [<c020ca34>] (dump_backtrace) from [<c020cd6c>] (show_stack+0x18/0x1c) [ 0.418228] r7:c0dfdec4 r6:60000193 r5:00000000 r4:c12506dc [ 0.418243] [<c020cd54>] (show_stack) from [<c0a15124>] (dump_stack+0x9c/0xb0) [ 0.418256] [<c0a15088>] (dump_stack) from [<c022e100>] (__warn+0xdc/0xf8) [ 0.418267] r7:c0dfdec4 r6:00000009 r5:00000000 r4:ee89b8ec [ 0.418279] [<c022e024>] (__warn) from [<c022dd38>] (warn_slowpath_fmt+0x50/0x6c) [ 0.418291] r9:ee9e0bc0 r8:f0882164 r7:c0dfddf0 r6:c0dfdd30 r5:c0dfde94 r4:c1204c48 [ 0.418305] [<c022dcec>] (warn_slowpath_fmt) from [<c056711c>] (l3_interrupt_handler+0x330/0x380) [ 0.418314] r3:eea466c0 r2:c0dfde94 [ 0.418322] r5:00000002 r4:80080003 [ 0.418339] [<c0566dec>] (l3_interrupt_handler) from [<c02895ec>] (__handle_irq_event_percpu+0x68/0x140) [ 0.418352] r10:c12522f8 r9:ee9ebe00 r8:00000017 r7:ee89ba18 r6:00000000 r5:ee9ebe68 [ 0.418360] r4:eea46ac0 [ 0.418374] [<c0289584>] (__handle_irq_event_percpu) from [<c02896f8>] (handle_irq_event_percpu+0x34/0x88) [ 0.418386] r10:60000013 r9:ee89a000 r8:ee80c000 r7:00000001 r6:ee9ebe00 r5:ee9ebe68 [ 0.418394] r4:c1204c48 [ 0.418408] [<c02896c4>] (handle_irq_event_percpu) from [<c028978c>] (handle_irq_event+0x40/0x64) [ 0.418418] r6:c120a434 r5:ee9ebe68 r4:ee9ebe00 [ 0.418431] [<c028974c>] (handle_irq_event) from [<c028d4dc>] (handle_fasteoi_irq+0xc0/0x168) [ 0.418441] r7:00000001 r6:c120a434 r5:ee9ebe68 r4:ee9ebe00 [ 0.418454] [<c028d41c>] (handle_fasteoi_irq) from [<c02887e8>] (generic_handle_irq+0x2c/0x3c) [ 0.418464] r7:00000001 r6:00000000 r5:00000000 r4:c1068cfc [ 0.418478] [<c02887bc>] (generic_handle_irq) from [<c0288e4c>] (__handle_domain_irq+0x64/0xbc) [ 0.418491] [<c0288de8>] (__handle_domain_irq) from [<c0565458>] (gic_handle_irq+0x44/0x80) [ 0.418503] r9:ee89a000 r8:fa213000 r7:ee89bae0 r6:fa212000 r5:fa21200c r4:c1205104 [ 0.418516] [<c0565414>] (gic_handle_irq) from [<c02019f8>] (__irq_svc+0x58/0x8c) [ 0.418525] Exception stack(0xee89bae0 to 0xee89bb28) [ 0.418538] bae0: ee9ebe68 60000013 00000004 00000005 ee9ebe00 eea46ac0 00000000 00000017 [ 0.418550] bb00: ee9ebed0 ee9ebe68 60000013 ee89bb3c ee89bb40 ee89bb30 c028b9ec c0a2f61c [ 0.418559] bb20: 60000013 ffffffff [ 0.418570] r9:ee89a000 r8:ee9ebed0 r7:ee89bb14 r6:ffffffff r5:60000013 r4:c0a2f61c [ 0.418586] [<c0a2f5f4>] (_raw_spin_unlock_irqrestore) from [<c028b9ec>] (__setup_irq+0x3bc/0x718) [ 0.418601] [<c028b630>] (__setup_irq) from [<c028beb8>] (request_threaded_irq+0xe0/0x154) [ 0.418612] r10:ee9ebe14 r9:00000000 r8:00000017 r7:00000000 r6:ee9ebe00 r5:00000000 [ 0.418620] r4:eea46ac0 [ 0.418634] [<c028bdd8>] (request_threaded_irq) from [<c028e7d4>] (devm_request_threaded_irq+0x70/0xc4) [ 0.418646] r10:00000000 r9:c0566dec r8:eea40e10 r7:00000017 r6:ee9e0bc0 r5:ee9e0ec0 [ 0.418654] r4:c0dfdc60 r3:00000000 [ 0.418668] [<c028e764>] (devm_request_threaded_irq) from [<c0567340>] (omap_l3_probe+0x1d4/0x27c) [ 0.418679] r10:00000002 r9:ee9e0bc0 r8:eea40e10 r7:c1288aec r6:00000008 r5:ee9e0bc0 [ 0.418687] r4:00000000 [ 0.418704] [<c056716c>] (omap_l3_probe) from [<c06c8368>] (platform_drv_probe+0x50/0xa0) [ 0.418715] r10:00000000 r9:c122425c r8:00000000 r7:00000000 r6:c122425c r5:00000000 [ 0.418723] r4:eea40e10 [ 0.418736] [<c06c8318>] (platform_drv_probe) from [<c06c63b8>] (really_probe+0x204/0x2c0) [ 0.418746] r7:00000000 r6:c128d988 r5:eea40e10 r4:c128d984 [ 0.418759] [<c06c61b4>] (really_probe) from [<c06c6618>] (driver_probe_device+0x68/0x180) [ 0.418771] r10:00000000 r9:c128d960 r8:00000001 r7:c06c6828 r6:eea40e10 r5:c122425c [ 0.418779] r4:eea40e10 r3:00000000 [ 0.418792] [<c06c65b0>] (driver_probe_device) from [<c06c68cc>] (__device_attach_driver+0xa4/0xc8) [ 0.418804] r9:c128d960 r8:00000001 r7:c06c6828 r6:eea40e10 r5:ee89bd04 r4:c122425c [ 0.418816] [<c06c6828>] (__device_attach_driver) from [<c06c4570>] (bus_for_each_drv+0x88/0xcc) [ 0.418827] r7:c06c6828 r6:ee89bd04 r5:c1204c48 r4:00000000 [ 0.418839] [<c06c44e8>] (bus_for_each_drv) from [<c06c6134>] (__device_attach+0xd8/0x140) [ 0.418849] r7:c1236f48 r6:eea40e44 r5:c1204c48 r4:eea40e10 [ 0.418862] [<c06c605c>] (__device_attach) from [<c06c693c>] (device_initial_probe+0x14/0x18) [ 0.418872] r8:eea40e10 r7:c1236f48 r6:c12370f0 r5:eea40e10 r4:eea40e18 [ 0.418885] [<c06c6928>] (device_initial_probe) from [<c06c549c>] (bus_probe_device+0x8c/0x94) [ 0.418898] [<c06c5410>] (bus_probe_device) from [<c06c2000>] (device_add+0x37c/0x620) [ 0.418908] r7:c1236f48 r6:00000000 r5:c1204c48 r4:eea40e18 [ 0.418924] [<c06c1c84>] (device_add) from [<c0859c78>] (of_device_add+0x3c/0x44) [ 0.418935] r10:00000000 r9:c1213418 r8:00000000 r7:eedadd68 r6:00000000 r5:00000000 [ 0.418943] r4:eea40e00 [ 0.418958] [<c0859c3c>] (of_device_add) from [<c085a1fc>] (of_platform_device_create_pdata+0x98/0xc0) [ 0.418973] [<c085a164>] (of_platform_device_create_pdata) from [<c085a424>] (of_platform_bus_create+0x1a4/0x248) [ 0.418984] r9:c1213418 r8:c1213418 r7:00000000 r6:00000000 r5:c1204c48 r4:eedadd18 [ 0.418999] [<c085a280>] (of_platform_bus_create) from [<c085a640>] (of_platform_populate+0x74/0xd4) [ 0.419011] r10:00000001 r9:00000000 r8:c1213418 r7:c1053ccc r6:00000000 r5:eedac500 [ 0.419018] r4:eedadd18 [ 0.419033] [<c085a5cc>] (of_platform_populate) from [<c100f5c8>] (pdata_quirks_init+0x78/0x88) [ 0.419045] r10:c1060768 r9:c104b828 r8:00000000 r7:c1003ca0 r6:ffffe000 r5:c1204c48 [ 0.419052] r4:c1053ccc [ 0.419066] [<c100f550>] (pdata_quirks_init) from [<c100f4d4>] (omap_generic_init+0x18/0x20) [ 0.419075] r5:c1204c48 r4:c1253e00 [ 0.419089] [<c100f4bc>] (omap_generic_init) from [<c1003cc8>] (customize_machine+0x28/0x30) [ 0.419103] [<c1003ca0>] (customize_machine) from [<c02025b8>] (do_one_initcall+0x84/0x1b0) [ 0.419117] [<c0202534>] (do_one_initcall) from [<c1000fe8>] (kernel_init_freeable+0x1c4/0x258) [ 0.419127] r8:c104b848 r7:c10004f0 r6:c1253e00 r5:c1253e00 r4:00000004 [ 0.419140] [<c1000e24>] (kernel_init_freeable) from [<c0a29438>] (kernel_init+0x10/0x11c) [ 0.419151] r10:00000000 r9:00000000 r8:00000000 r7:00000000 r6:00000000 r5:c0a29428 [ 0.419159] r4:00000000 [ 0.419170] [<c0a29428>] (kernel_init) from [<c02010d8>] (ret_from_fork+0x14/0x3c) [ 0.419178] Exception stack(0xee89bfb0 to 0xee89bff8) [ 0.419189] bfa0: 00000000 00000000 00000000 00000000 [ 0.419200] bfc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 0.419210] bfe0: 00000000 00000000 00000000 00000000 00000013 00000000 [ 0.419219] r5:c0a29428 r4:00000000 [ 0.419227] ---[ end trace b11d5f38a71584f5 ]--- [ 0.425085] OMAP GPIO hardware version 0.1 [ 0.443799] No ATAGs? [ 0.443871] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers. [ 0.443887] hw-breakpoint: maximum watchpoint size is 8 bytes. [ 0.443919] omap_device: omap_dma_system: build failed (-22) [ 0.443929] omap2_system_dma_init_dev: Can't build omap_device for omap_dma_system:dma_system. [ 0.455363] edma 43300000.edma: memcpy is disabled [ 0.458746] edma 43300000.edma: TI EDMA DMA engine driver [ 0.462088] ------------[ cut here ]------------ [ 0.462110] WARNING: CPU: 0 PID: 1 at drivers/iommu/omap-iommu.c:1750 omap_iommu_add_device+0xcc/0x188 [ 0.462119] Modules linked in: [ 0.462134] CPU: 0 PID: 1 Comm: swapper/0 Tainted: G W 4.19.94-gbe5389fd85 #1 [ 0.462143] Hardware name: Generic DRA74X (Flattened Device Tree) [ 0.462152] Backtrace: [ 0.462169] [<c020ca34>] (dump_backtrace) from [<c020cd6c>] (show_stack+0x18/0x1c) [ 0.462182] r7:c0e13a8c r6:60000013 r5:00000000 r4:c12506dc [ 0.462199] [<c020cd54>] (show_stack) from [<c0a15124>] (dump_stack+0x9c/0xb0) [ 0.462214] [<c0a15088>] (dump_stack) from [<c022e100>] (__warn+0xdc/0xf8) [ 0.462225] r7:c0e13a8c r6:00000009 r5:00000000 r4:00000000 [ 0.462238] [<c022e024>] (__warn) from [<c022e164>] (warn_slowpath_null+0x48/0x50) [ 0.462250] r9:00000001 r8:c0e13a84 r7:eeac4210 r6:c063fd6c r5:000006d6 r4:c0e13a8c [ 0.462263] [<c022e11c>] (warn_slowpath_null) from [<c063fd6c>] (omap_iommu_add_device+0xcc/0x188) [ 0.462273] r6:eeaecf80 r5:eeddedcc r4:ffffffea [ 0.462290] [<c063fca0>] (omap_iommu_add_device) from [<c063d824>] (add_iommu_group+0x34/0x5c) [ 0.462303] r10:c1060884 r9:c104b82c r8:00000000 r7:c063d7f0 r6:ee89be88 r5:c0c4c3bc [ 0.462312] r4:eeac4210 r3:c063fca0 [ 0.462328] [<c063d7f0>] (add_iommu_group) from [<c06c4484>] (bus_for_each_dev+0x7c/0xbc) [ 0.462338] r5:c1204c48 r4:eea96bb4 [ 0.462352] [<c06c4408>] (bus_for_each_dev) from [<c063d910>] (bus_set_iommu+0xc4/0x100) [ 0.462362] r7:00000000 r6:eeaecf40 r5:c1204c48 r4:c12370f0 [ 0.462378] [<c063d84c>] (bus_set_iommu) from [<c10299c4>] (omap_iommu_init+0xac/0xe0) [ 0.462389] r8:00000000 r7:c1029918 r6:ffffe000 r5:00000000 r4:c128d5c8 [ 0.462403] [<c1029918>] (omap_iommu_init) from [<c02025b8>] (do_one_initcall+0x84/0x1b0) [ 0.462412] r5:c1204c48 r4:c1253e00 [ 0.462428] [<c0202534>] (do_one_initcall) from [<c1000fe8>] (kernel_init_freeable+0x1c4/0x258) [ 0.462440] r8:c104b84c r7:c10004f0 r6:c1253e00 r5:c1253e00 r4:00000005 [ 0.462453] [<c1000e24>] (kernel_init_freeable) from [<c0a29438>] (kernel_init+0x10/0x11c) [ 0.462465] r10:00000000 r9:00000000 r8:00000000 r7:00000000 r6:00000000 r5:c0a29428 [ 0.462472] r4:00000000 [ 0.462485] [<c0a29428>] (kernel_init) from [<c02010d8>] (ret_from_fork+0x14/0x3c) [ 0.462494] Exception stack(0xee89bfb0 to 0xee89bff8) [ 0.462505] bfa0: 00000000 00000000 00000000 00000000 [ 0.462517] bfc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 0.462528] bfe0: 00000000 00000000 00000000 00000000 00000013 00000000 [ 0.462537] r5:c0a29428 r4:00000000 [ 0.462545] ---[ end trace b11d5f38a71584f6 ]--- [ 0.463724] SCSI subsystem initialized [ 0.464897] palmas 2-0058: IRQ missing: skipping irq request [ 0.491459] palmas 2-0058: Muxing GPIO 2b, PWM 0, LED 0 [ 0.495115] SMPS12: supplied by regulator-dummy [ 0.499662] SMPS3: supplied by VMAIN [ 0.503869] SMPS45: supplied by regulator-dummy [ 0.508878] SMPS6: supplied by VMAIN [ 0.513415] SMPS7: supplied by VMAIN [ 0.518425] SMPS8: supplied by VMAIN [ 0.521715] SMPS9: supplied by VMAIN [ 0.523102] random: fast init done [ 0.524121] LDO1: supplied by VMAIN [ 0.532417] LDO2: supplied by VMAIN [ 0.541979] LDO3: supplied by VMAIN [ 0.551997] LDO4: supplied by VMAIN [ 0.562028] LDO5: supplied by regulator-dummy [ 0.563628] LDO6: supplied by regulator-dummy [ 0.565216] LDO7: supplied by regulator-dummy [ 0.566815] LDO8: supplied by regulator-dummy [ 0.568394] LDO9: supplied by VMAIN [ 0.572948] LDOLN: supplied by VMAIN [ 0.582045] LDOUSB: supplied by VMAIN [ 0.595492] omap_i2c 48060000.i2c: bus 2 rev0.12 at 100 kHz [ 0.595655] media: Linux media interface: v0.10 [ 0.595699] videodev: Linux video capture interface: v2.00 [ 0.595773] pps_core: LinuxPPS API ver. 1 registered [ 0.595783] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [ 0.595804] PTP clock support registered [ 0.595834] EDAC MC: Ver: 3.0.0 [ 0.601195] omap-mailbox 48840000.mailbox: omap mailbox rev 0x400 [ 0.601447] omap-mailbox 48842000.mailbox: omap mailbox rev 0x400 [ 0.601906] Advanced Linux Sound Architecture Driver Initialized. [ 0.602701] clocksource: Switched to clocksource arch_sys_counter [ 0.610857] NET: Registered protocol family 2 [ 0.611424] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes) [ 0.611454] TCP established hash table entries: 8192 (order: 3, 32768 bytes) [ 0.611517] TCP bind hash table entries: 8192 (order: 4, 65536 bytes) [ 0.611644] TCP: Hash tables configured (established 8192 bind 8192) [ 0.611719] UDP hash table entries: 512 (order: 2, 16384 bytes) [ 0.611753] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes) [ 0.611885] NET: Registered protocol family 1 [ 0.612313] RPC: Registered named UNIX socket transport module. [ 0.612324] RPC: Registered udp transport module. [ 0.612332] RPC: Registered tcp transport module. [ 0.612341] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 0.613237] hw perfevents: no interrupt-affinity property for /pmu, guessing. [ 0.613423] hw perfevents: enabled with armv7_cortex_a15 PMU driver, 7 counters available [ 0.614329] Initialise system trusted keyrings [ 0.614456] workingset: timestamp_bits=14 max_order=19 bucket_order=5 [ 0.619418] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 0.619880] NFS: Registering the id_resolver key type [ 0.619904] Key type id_resolver registered [ 0.619914] Key type id_legacy registered [ 0.619952] ntfs: driver 2.1.32 [Flags: R/O]. [ 0.621687] Key type asymmetric registered [ 0.621699] Asymmetric key parser 'x509' registered [ 0.621747] bounce: pool size: 64 pages [ 0.621780] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245) [ 0.621791] io scheduler noop registered [ 0.621801] io scheduler deadline registered [ 0.621896] io scheduler cfq registered (default) [ 0.621907] io scheduler mq-deadline registered [ 0.621916] io scheduler kyber registered [ 0.625473] pinctrl-single 4a003400.pinmux: 282 pins, size 1128 [ 0.630992] V3_3D: supplied by smps9 [ 0.631525] vtt_fixed: supplied by V3_3D [ 0.676519] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled [ 0.679973] console [ttyS2] disabled [ 0.680027] 48020000.serial: ttyS2 at MMIO 0x48020000 (irq = 43, base_baud = 3000000) is a 8250 [ 4.410266] console [ttyS2] enabled [ 4.415502] omap_rng 48090000.rng: Random Number Generator ver. 20 [ 4.416057] random: crng init done [ 4.433366] brd: module loaded [ 4.442688] loop: module loaded [ 4.448728] ti-qspi 4b300000.qspi: No Rx DMA available, trying mmap mode [ 4.456713] libphy: Fixed MDIO Bus: probed [ 4.522734] davinci_mdio 48485000.mdio: davinci mdio revision 1.6, bus freq 1000000 [ 4.530429] davinci_mdio 48485000.mdio: detected phy mask fffffffc [ 4.541501] libphy: 48485000.mdio: probed [ 4.545559] davinci_mdio 48485000.mdio: phy[0]: device 48485000.mdio:00, driver Marvell 88E1510 [ 4.554317] davinci_mdio 48485000.mdio: phy[1]: device 48485000.mdio:01, driver Marvell 88E1510 [ 4.563722] cpsw 48484000.ethernet: Detected MACID = 88:3f:4a:5e:e6:8a [ 4.570332] cpsw 48484000.ethernet: initialized cpsw ale version 1.4 [ 4.576739] cpsw 48484000.ethernet: ALE Table size 1024 [ 4.582018] cpsw 48484000.ethernet: cpts: overflow check period 500 (jiffies) [ 4.590038] cpsw 48484000.ethernet: cpsw: Detected MACID = 88:3f:4a:5e:e6:8b [ 4.598334] i2c /dev entries driver [ 4.605851] cpu cpu0: dev_pm_opp_set_regulators: no regulator (vdd) found: -19 [ 4.613556] sdhci: Secure Digital Host Controller Interface driver [ 4.619767] sdhci: Copyright(c) Pierre Ossman [ 4.624963] omap_gpio 4805d000.gpio: Could not set line 27 debounce to 200000 microseconds (-22) [ 4.633813] omap_hsmmc 4809c000.mmc: Got CD GPIO [ 4.638695] omap_hsmmc 4809c000.mmc: RX DMA channel request failed [ 4.645732] omap_hsmmc 480b4000.mmc: RX DMA channel request failed [ 4.652152] sdhci-pltfm: SDHCI platform and OF driver helper [ 4.658836] ledtrig-cpu: registered to indicate activity on CPUs [ 4.669486] NET: Registered protocol family 10 [ 4.674917] Segment Routing with IPv6 [ 4.678665] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver [ 4.685108] NET: Registered protocol family 17 [ 4.689733] Key type dns_resolver registered [ 4.694179] Registering SWP/SWPB emulation handler [ 4.698996] omap_voltage_late_init: Voltage driver support not added [ 4.705398] Power Management for TI OMAP4+ devices. [ 4.711004] Loading compiled-in X.509 certificates [ 4.733904] dmm 4e000000.dmm: failed to initialize work-around for i878 [ 4.742066] dmm 4e000000.dmm: initialized all PAT entries [ 4.748860] hctosys: unable to open rtc device (rtc0) [ 4.754613] ALSA device list: [ 4.757595] No soundcards found. [ 4.761835] Waiting for root device PARTUUID=41d4c7bc-02... [ 35.033301] pbias_mmc_omap5: disabling
