TDA2EXEVM: Usecase Semantic Segmenation Input Data
Part Number: TDA2EXEVM
I run the usecase Semantic Segmenation by using your data from  this ref.It works well.
Then, i follow the steps and made my own indata\inHeader.
Although it could display ,but it seems doesn't achieve the function of segmentation .The video is very stuck,only 2 fps/s
[IPU1_0] New data Recv = 2.0 fps
[IPU1_0] Release data Recv = 2.0 fps
[IPU1_0] Driver/Notify Cb = 35.33 fps
My input data is 1024*512  and my display monoitor is 1280*720.
Here is the output:
So What shold we do to make this run?
Best wish!
Z.Y Wang
    Can you share the logs with statistics for working case?
    Can you share the logs with statistics for not working case? & also mention what changes you have done on top of working case
    Gaviraju
  • Hi
    I changed some input size parameters and now usecase works.
    But video stream is still slowly.
    I modify FPS parameters ,but If SEMSEG_FPS_OPPNOM > (12) ,the usecase will stuck.
    Weather if each TIDL EVE'upper limit giving performace of only 3 fps?
    Here is Statistics log.
    [IPU1_0]
    [IPU1_0] CPU [IPU1-0 ] Statistics,
    [IPU1_0] *************************
    [IPU1_0]
    [IPU1_0] LOAD: CPU: 11.3% HWI: 1.2%, SWI:0.8%, Low Power: 84.8%
    [IPU1_0]
    [IPU1_0] LOAD: TSK: SYSTEM              : 0.1%
    [IPU1_0] LOAD: TSK: DUP0                : 0.1%
    [IPU1_0] LOAD: TSK: IPC_IN_0            : 0.1%
    [IPU1_0] LOAD: TSK: IPC_OUT_0           : 0.2%
    [IPU1_0] LOAD: TSK: IPC_OUT_1           : 0.2%
    [IPU1_0] LOAD: TSK: NULL_SRC0           : 2.1%
    [IPU1_0] LOAD: TSK: DISPLAY0            : 0.3%
    [IPU1_0] LOAD: TSK: DEC0                : 0.3%
    [IPU1_0] LOAD: TSK: GrpxSrc0            : 0.2%
    [IPU1_0] LOAD: TSK: STAT_COLL           : 3.5%
    [IPU1_0] LOAD: TSK: DEC_PROCESS_TSK_0   : 0.6%
    [IPU1_0] LOAD: TSK: MISC                : 1.6%
    [IPU1_0]
    [IPU1_0] SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1023
    [IPU1_0]
    [IPU1_0] SYSTEM: Sempahores Objects,  160 of 1050 free
    [IPU1_0] SYSTEM: Task Objects      ,   16 of  100 free
    [IPU1_0] SYSTEM: Clock Objects     ,   93 of  100 free
    [IPU1_0] SYSTEM: Hwi Objects       ,   93 of  100 free
    [IPU1_0]
    [IPU1_0] SYSTEM: Heap = LOCAL_DDR            @ 0x00000000, Total size = 262144 B (256 KB), Free size = 242176 B (236 KB)
    [IPU1_0] SYSTEM: Heap = SR_OCMC              @ 0x00000000, Total size = 0 B (0 KB), Free size = 0 B (0 KB)
    [IPU1_0] SYSTEM: Heap = SR_DDR_CACHED        @ 0x89d03000, Total size = 366989312 B (349 MB), Free size = 133390336 B (127 MB)
    [IPU1_0] SYSTEM: Heap = SR_DDR_NON_CACHED    @ 0xbfb00000, Total size = 127360 B (0 MB), Free size = 92800 B (0 MB)
    [IPU1_0]
    [IPU1_0]
    [IPU1_0] CPU [IPU1-1 ] Statistics,
    [IPU1_0]
    [IPU1_0] LOAD: CPU: 1.3% HWI: 0.8%, SWI:0.4%, Low Power: 84.8%
    [IPU1_0]
    [IPU1_0] LOAD: TSK: MISC                : 0.1%
    [IPU1_0]
    [IPU1_0]
    [IPU1_0] SYSTEM: Sempahores Objects,  435 of 1050 free
    [IPU1_0] SYSTEM: Task Objects      ,   38 of  100 free
    [IPU1_0] SYSTEM: Clock Objects     ,   99 of  100 free
    [IPU1_0] SYSTEM: Hwi Objects       ,   99 of  100 free
    [IPU1_0]
    [IPU1_0] SYSTEM: Heap = LOCAL_DDR            @ 0x00000000, Total size = 655360 B (640 KB), Free size = 639224 B (624 KB)
    [IPU1_0]
    [IPU1_0]
    [IPU1_0] CPU [HOST   ] Statistics,
    [IPU1_0]
    [IPU1_0] LOAD: CPU: 28.4% HWI: 0.1%, SWI:0.1%, Low Power: 70.6%
    [IPU1_0]
    [IPU1_0] LOAD: TSK: MISC                : 28.2%
    [IPU1_0]
    [IPU1_0]
    [IPU1_0] SYSTEM: Sempahores Objects,  423 of 1050 free
    [IPU1_0] SYSTEM: Clock Objects     ,   87 of  100 free
    [IPU1_0]
    [IPU1_0] SYSTEM: Heap = LOCAL_DDR            @ 0x00000000, Total size = 6291456 B (6144 KB), Free size = 6215232 B (6069 KB)
    [IPU1_0]
    [IPU1_0]
    [IPU1_0] CPU [DSP1   ] Statistics,
    [IPU1_0]
    [IPU1_0] LOAD: CPU: 0.5% HWI: 0.2%, SWI:0.1%, Low Power: 98.6%
    [IPU1_0]
    [IPU1_0] LOAD: TSK: MISC                : 0.2%
    [IPU1_0]
    [IPU1_0]
    [IPU1_0] SYSTEM: Sempahores Objects,  449 of 1050 free
    [IPU1_0] SYSTEM: Task Objects      ,   91 of  100 free
    [IPU1_0] SYSTEM: Hwi Objects       ,  100 of  100 free
    [IPU1_0]
    [IPU1_0] SYSTEM: Heap = LOCAL_L2             @ 0x00800000, Total size = 227264 B (221 KB), Free size = 227264 B (221 KB)
    [IPU1_0] SYSTEM: Heap = LOCAL_DDR            @ 0x00000000, Total size = 524288 B (512 KB), Free size = 510440 B (498 KB)
    [IPU1_0]
    [IPU1_0]
    [IPU1_0] CPU [DSP2   ] Statistics,
    [IPU1_0]
    [IPU1_0]
    [IPU1_0]
    [IPU1_0]
    [IPU1_0]
    [IPU1_0]
    [IPU1_0]
    [IPU1_0] CPU [EVE1   ] Statistics,
    [IPU1_0]
    [IPU1_0] LOAD: CPU: 97.5% HWI: 0.3%, SWI:0.2%, Low Power: 2.2%
    [IPU1_0]
    [IPU1_0] LOAD: TSK: SYSTEM_TSK_MULTI_MBX: 96.7%
    [IPU1_0] LOAD: TSK: MISC                : 0.3%
    [IPU1_0]
    [IPU1_0]
    [IPU1_0] SYSTEM: Task Objects      ,   92 of  100 free
    [IPU1_0] SYSTEM: Clock Objects     ,   97 of  100 free
    [IPU1_0]
    [IPU1_0] SYSTEM: Heap = LOCAL_L2             @ 0x40020000, Total size = 22528 B (22 KB), Free size = 1280 B (1 KB)
    [IPU1_0] SYSTEM: Heap = LOCAL_DDR            @ 0x00000000, Total size = 262144 B (256 KB), Free size = 231528 B (226 KB)
    [IPU1_0]
    [IPU1_0]
    [IPU1_0] CPU [EVE2   ] Statistics,
    [IPU1_0]
    [IPU1_0] LOAD: CPU: 98.2% HWI: 0.4%, SWI:0.2%, Low Power: 1.4%
    [IPU1_0]
    [IPU1_0] LOAD: TSK: SYSTEM_TSK_MULTI_MBX: 97.5%
    [IPU1_0]
    [IPU1_0]
    [IPU1_0]
    [IPU1_0]
    [IPU1_0]
    [IPU1_0] CPU [EVE3   ] Statistics,
    [IPU1_0]
    [IPU1_0] LOAD: CPU: 97.1% HWI: 0.3%, SWI:0.2%, Low Power: 2.6%
    [IPU1_0]
    [IPU1_0] LOAD: TSK: SYSTEM_TSK_MULTI_MBX: 96.4%
    [IPU1_0]
    [IPU1_0]
    [IPU1_0]
    [IPU1_0]
    [IPU1_0]
    [IPU1_0] CPU [EVE4   ] Statistics,
    [IPU1_0]
    [IPU1_0] LOAD: CPU: 98.0% HWI: 0.4%, SWI:0.2%, Low Power: 1.7%
    [IPU1_0]
    [IPU1_0] LOAD: TSK: SYSTEM_TSK_MULTI_MBX: 97.2%
    [IPU1_0]
    [IPU1_0]
    [IPU1_0]
    [IPU1_0]
    [IPU1_0]
    [IPU1_0] CPU [IPU2   ] Statistics,
    [IPU1_0]
    [IPU1_0] LOAD: CPU: 0.9% HWI: 0.5%, SWI:0.3%, Low Power: 96.2%
    [IPU1_0]
    [IPU1_0]
    [IPU1_0]
    [IPU1_0] SYSTEM: Sempahores Objects,  442 of 1050 free
    [IPU1_0] SYSTEM: Task Objects      ,   39 of  100 free
    [IPU1_0]
    [IPU1_0] SYSTEM: Heap = LOCAL_DDR            @ 0x00000000, Total size = 262144 B (256 KB), Free size = 246000 B (240 KB)
    [IPU1_0]
    [IPU1_0]
    [IPU1_0] UTILS_PRCM_STATS:  Current Temperature,
    [IPU1_0]
    [IPU1_0]  Voltage Rail         ||   Curr Temp Min - Max
    [IPU1_0] ---------------------------------------------------------
    [IPU1_0]     PMHAL_PRCM_VD_MPU ||     [63.600 , 64.  0]
    [IPU1_0]    PMHAL_PRCM_VD_CORE ||     [64.  0 , 64.400]
    [IPU1_0]   PMHAL_PRCM_VD_IVAHD ||     [64.400 , 64.800]
    [IPU1_0]  PMHAL_PRCM_VD_DSPEVE ||     [63.600 , 64.  0]
    [IPU1_0]     PMHAL_PRCM_VD_GPU ||     [63.200 , 63.600]
    [IPU1_0]
    [IPU1_0]============================================================================
    [IPU1_0]Name      | Bus (mV)    | Res (mOhm) | Shunt (uV)  | Current (mA) | Power (mW)
    [IPU1_0]----------------------------------------------------------------------------
    [IPU1_0] UTILS_PRCM_STATS: Reading the regulator data failed
    [IPU1_0] UTILS_PRCM_STATS: PM INA226 Power Read Failed !!
    [IPU1_0]
    [IPU1_0] Statistics Collector,
    [IPU1_0]
    [IPU1_0]       STATISTIC          Avg Data        Peak Data
    [IPU1_0]       COLLECTOR          MB/s            MB/s
    [IPU1_0] SCI_EMIF1 RD+WR      |   1366.498411   2229.446160
    [IPU1_0] SCI_EMIF2 RD+WR      |      0.000000      0.000000
    [IPU1_0] SCI_EMIF1 RD ONLY    |    870.669906   1877.536985
    [IPU1_0] SCI_EMIF1 WR ONLY    |    496.213209    965.146019
    [IPU1_0] SCI_EMIF2 RD ONLY    |      0.000000      0.000000
    [IPU1_0] SCI_EMIF2 WR ONLY    |      0.000000      0.000000
    [IPU1_0] SCI_MA_MPU_P1        |     61.442881    457.727796
    [IPU1_0] SCI_MA_MPU_P2        |      0.000000      0.000000
    [IPU1_0] SCI_DSS              |     12.115116     13.252804
    [IPU1_0] SCI_IPU1             |      7.238479     28.136885
    [IPU1_0] SCI_VIP1_P1          |      0.000000      0.000000
    [IPU1_0] SCI_VIP1_P2          |      0.000000      0.000000
    [IPU1_0] SCI_VPE_P1           |      0.000000      0.000000
    [IPU1_0] SCI_VPE_P2           |      0.000000      0.000000
    [IPU1_0] SCI_DSP1_MDMA        |      3.147211      4.313757
    [IPU1_0] SCI_DSP1_EDMA        |      0.000000      0.000000
    [IPU1_0] SCI_DSP2_MDMA        |      3.147026      4.313757
    [IPU1_0] SCI_DSP2_EDMA        |      0.000000      0.000000
    [IPU1_0] SCI_EVE1_TC0         |    308.457890   1415.089164
    [IPU1_0] SCI_EVE1_TC1         |    562.341696   1304.539961
    [IPU1_0] SCI_EVE2_TC0         |    306.353163   1409.814911
    [IPU1_0] SCI_EVE2_TC1         |    567.109771   1289.219932
    [IPU1_0] SCI_EDMA_TC0_RD      |      0.000000      0.000000
    [IPU1_0] SCI_EDMA_TC0_WR      |      0.000000      0.000000
    [IPU1_0] SCI_EDMA_TC1_RD      |      9.577394    160.169450
    [IPU1_0] SCI_EDMA_TC1_WR      |      9.579561    160.169450
    [IPU1_0] SCI_VIP2_P1          |      0.000000      0.000000
    [IPU1_0] SCI_VIP2_P2          |      0.000000      0.000000
    [IPU1_0] SCI_VIP3_P1          |      0.000000      0.000000
    [IPU1_0] SCI_VIP3_P2          |      0.000000      0.000000
    [IPU1_0] SCI_EVE3_TC0         |    305.851167   1451.708916
    [IPU1_0] SCI_EVE3_TC1         |    564.113065   1354.274290
    [IPU1_0] SCI_EVE4_TC0         |    308.140416   1425.485116
    [IPU1_0] SCI_EVE4_TC1         |    563.294643   1339.921158
    [IPU1_0] SCI_IVA              |     70.294801   1208.498821
    [IPU1_0] SCI_GPU_P1           |      0.000000      0.000000
    [IPU1_0] SCI_GPU_P2           |      0.000000      0.000000
    [IPU1_0] SCI_GMAC_SW          |      0.000000      0.000000
    [IPU1_0] SCI_OCMC_RAM1        |    560.004104   1356.609356
    [IPU1_0] SCI_OCMC_RAM2        |    559.140510   1341.366049
    [IPU1_0] SCI_OCMC_RAM3        |   1120.987499   2106.683726
    [IPU1_0]
    [IPU1_0]
    [IPU1_0]
    [IPU1_0] ### CPU [IPU1-0], LinkID [ 57],
    [IPU1_0]
    [IPU1_0] [ NULL_SRC ] Link Statistics,
    [IPU1_0] ******************************
    [IPU1_0]
    [IPU1_0] Elapsed time       = 1632016 msec
    [IPU1_0]
    [IPU1_0] New data Recv      =  12.4 fps
    [IPU1_0] Get Full Buf Cb    =  12.11 fps
    [IPU1_0] Put Empty Buf Cb   =  12.4 fps
    [IPU1_0] Driver/Notify Cb   =  12.4 fps
    [IPU1_0]
    [IPU1_0] Input Statistics,
    [IPU1_0]
    [IPU1_0] CH | In Recv | In Drop | In User Drop | In Process
    [IPU1_0]    | FPS     | FPS     | FPS          | FPS
    [IPU1_0]  0 |  12. 4      0. 0      0. 0          12. 4
    [IPU1_0]
    [IPU1_0] Output Statistics,
    [IPU1_0]
    [IPU1_0] CH | Out | Out     | Out Drop | Out User Drop
    [IPU1_0]    | ID  | FPS     | FPS      | FPS
    [IPU1_0]  0 |  0     12. 4     0. 0      0. 0
    [IPU1_0]
    [IPU1_0] [ NULL_SRC ] LATENCY,
    [IPU1_0]
    [IPU1_0]
    [IPU1_0] ### CPU [IPU1-0], LinkID [ 82],
    [IPU1_0]
    [IPU1_0] [ DECODE ] Link Statistics,
    [IPU1_0]
    [IPU1_0] Elapsed time       = 1632087 msec
    [IPU1_0]
    [IPU1_0] New data Recv      =  12.11 fps
    [IPU1_0] Release data Recv  =  12.4 fps
    [IPU1_0] Get Full Buf Cb    =  24.9 fps
    [IPU1_0]
    [IPU1_0]
    [IPU1_0]
    [IPU1_0]
    [IPU1_0]
    [IPU1_0] [ DECODE ] LATENCY,
    [IPU1_0] Local Link Latency     : Avg =   6369 us, Min =   4361 us, Max =   9303 us,
    [IPU1_0] Source to Link Latency : Avg =   6512 us, Min =   4453 us, Max =   9425 us,
    [IPU1_0]
    [IPU1_0] CPU [  IPU1-0], LinkID [ 25], Link Statistics not available !
    [IPU1_0]
    [IPU1_0] ### CPU [IPU1-0], LinkID [  1],
    [IPU1_0]
    [IPU1_0] [ IPC_OUT_1 ] Link Statistics,
    [IPU1_0]
    [IPU1_0] Elapsed time       = 1632206 msec
    [IPU1_0]
    [IPU1_0] Release data Recv  =  12.5 fps
    [IPU1_0] Driver/Notify Cb   =  45.38 fps
    [IPU1_0]
    [IPU1_0]
    [IPU1_0]
    [IPU1_0]
    [IPU1_0]
    [IPU1_0] [ IPC_OUT_1 ] LATENCY,
    [IPU1_0] Local Link Latency     : Avg =      6 us, Min =      0 us, Max =    122 us,
    [IPU1_0] Source to Link Latency : Avg =   6882 us, Min =   4758 us, Max =   9791 us,
    [IPU1_0]
    [IPU1_0]
    [IPU1_0] ### CPU [  HOST], LinkID [ 11],
    [IPU1_0]
    [IPU1_0] [ IPC_IN_1 ] Link Statistics,
    [IPU1_0]
    [IPU1_0] Elapsed time       = 1632821 msec
    [IPU1_0]
    [IPU1_0] Get Full Buf Cb    =  12.4 fps
    [IPU1_0] Driver/Notify Cb   =  45.37 fps
    [IPU1_0]
    [IPU1_0]
    [IPU1_0]
    [IPU1_0]
    [IPU1_0]
    [IPU1_0] [ IPC_IN_1 ] LATENCY,
    [IPU1_0] Local Link Latency     : Avg =      6 us, Min =      0 us, Max =     31 us,
    [IPU1_0] Source to Link Latency : Avg =   6952 us, Min =   4819 us, Max =   9852 us,
    [IPU1_0]
    [IPU1_0]
    [IPU1_0] ### CPU [  HOST], LinkID [ 49],
    [IPU1_0]
    [IPU1_0] [ ALG_TIDLPREPROC ] Link Statistics,
    [IPU1_0]
    [IPU1_0] Elapsed time       = 1632936 msec
    [IPU1_0]
    [IPU1_0]
    [IPU1_0]
    [IPU1_0]
    [IPU1_0]
    [IPU1_0]
    [IPU1_0] [ ALG_TIDLPREPROC ] LATENCY,
    [IPU1_0] Local Link Latency     : Avg =    473 us, Min =    335 us, Max =    732 us,
    [IPU1_0] Source to Link Latency : Avg =  29174 us, Min =  26810 us, Max =  35868 us,
    [IPU1_0]
    [IPU1_0]
    [IPU1_0] ### CPU [  HOST], LinkID [  3],
    [IPU1_0]
    [IPU1_0] [ IPC_OUT_3 ] Link Statistics,
    [IPU1_0]
    [IPU1_0] Elapsed time       = 1632804 msec
    [IPU1_0]
    [IPU1_0] New data Recv      =   3.1 fps
    [IPU1_0] Release data Recv  =   3.1 fps
    [IPU1_0] Driver/Notify Cb   =  36.34 fps
    [IPU1_0]
    [IPU1_0]
    [IPU1_0]  0 |   3. 1      0. 0      0. 0           3. 1
    [IPU1_0]
    [IPU1_0]
    [IPU1_0]  0 |  0      3. 1     0. 0      0. 0
    [IPU1_0]
    [IPU1_0] [ IPC_OUT_3 ] LATENCY,
    [IPU1_0] Local Link Latency     : Avg =      1 us, Min =      0 us, Max =     31 us,
    [IPU1_0] Source to Link Latency : Avg =  28655 us, Min =  27054 us, Max =  35899 us,
    [IPU1_0]
    [IPU1_0]
    [IPU1_0] ### CPU [  EVE4], LinkID [ 10],
    [IPU1_0]
    [IPU1_0] [ IPC_IN_0 ] Link Statistics,
    [IPU1_0]
    [IPU1_0] Elapsed time       = 1633417 msec
    [IPU1_0]
    [IPU1_0] Get Full Buf Cb    =   5.95 fps
    [IPU1_0] Put Empty Buf Cb   =   3.1 fps
    [IPU1_0] Driver/Notify Cb   =   6.34 fps
    [IPU1_0]
    [IPU1_0]
    [IPU1_0]
    [IPU1_0]
    [IPU1_0]
    [IPU1_0] [ IPC_IN_0 ] LATENCY,
    [IPU1_0] Local Link Latency     : Avg =     43 us, Min =     30 us, Max =    153 us,
    [IPU1_0] Source to Link Latency : Avg =  29073 us, Min =  27329 us, Max =  39254 us,
    [IPU1_0]
    [IPU1_0]
    [IPU1_0] ### CPU [  EVE4], LinkID [ 49],
    [IPU1_0]
    [IPU1_0] [ ALG_TIDL ] Link Statistics,
    [IPU1_0]
    [IPU1_0] Elapsed time       = 1633529 msec
    [IPU1_0]
    [IPU1_0] New data Recv      =   5.95 fps
    [IPU1_0]
    [IPU1_0]
    [IPU1_0]
    [IPU1_0]
    [IPU1_0]
    [IPU1_0] [ ALG_TIDL ] LATENCY,
    [IPU1_0] Local Link Latency     : Avg = 324024 us, Min = 316690 us, Max = 329104 us,
    [IPU1_0] Source to Link Latency : Avg = 353320 us, Min = 345117 us, Max = 365247 us,
    [IPU1_0]
    [IPU1_0]
    [IPU1_0] ### CPU [  EVE4], LinkID [  0],
    [IPU1_0]
    [IPU1_0] [ IPC_OUT_0 ] Link Statistics,
    [IPU1_0]
    [IPU1_0] Elapsed time       = 1633315 msec
    [IPU1_0]
    [IPU1_0]
    [IPU1_0]
    [IPU1_0]
    [IPU1_0]
    [IPU1_0]
    [IPU1_0] [ IPC_OUT_0 ] LATENCY,
    [IPU1_0] Local Link Latency     : Avg =     29 us, Min =      0 us, Max =    275 us,
    [IPU1_0] Source to Link Latency : Avg = 353688 us, Min = 345483 us, Max = 365613 us,
    [IPU1_0]
    [IPU1_0]
    [IPU1_0] ### CPU [  HOST], LinkID [ 15],
    [IPU1_0]
    [IPU1_0] [ IPC_IN_5 ] Link Statistics,
    [IPU1_0]
    [IPU1_0] Elapsed time       = 1633930 msec
    [IPU1_0]
    [IPU1_0]
    [IPU1_0]
    [IPU1_0]
    [IPU1_0]
    [IPU1_0]
    [IPU1_0] [ IPC_IN_5 ] LATENCY,
    [IPU1_0] Source to Link Latency : Avg = 353818 us, Min = 345605 us, Max = 365735 us,
    [IPU1_0]
    [IPU1_0]
    [IPU1_0] ### CPU [  HOST], LinkID [  2],
    [IPU1_0]
    [IPU1_0] [ IPC_OUT_2 ] Link Statistics,
    [IPU1_0]
    [IPU1_0] Elapsed time       = 1634440 msec
    [IPU1_0]
    [IPU1_0]
    [IPU1_0]
    [IPU1_0]
    [IPU1_0]
    [IPU1_0]
    [IPU1_0] [ IPC_OUT_2 ] LATENCY,
    [IPU1_0] Source to Link Latency : Avg =  29787 us, Min =  26871 us, Max =  31630 us,
    [IPU1_0]
    [IPU1_0]
    [IPU1_0] ### CPU [  EVE3], LinkID [ 10],
    [IPU1_0]
    [IPU1_0]
    [IPU1_0] Elapsed time       = 1635054 msec
    [IPU1_0]
    [IPU1_0] Get Full Buf Cb    =   5.93 fps
    [IPU1_0]
    [IPU1_0]
    [IPU1_0]
    [IPU1_0]
    [IPU1_0]
    [IPU1_0] Local Link Latency     : Avg =     41 us, Min =     30 us, Max =    153 us,
    [IPU1_0] Source to Link Latency : Avg =  30912 us, Min =  27145 us, Max =  91045 us,
    [IPU1_0]
    [IPU1_0]
    [IPU1_0] ### CPU [  EVE3], LinkID [ 49],
    [IPU1_0]
    [IPU1_0]
    [IPU1_0] Elapsed time       = 1635167 msec
    [IPU1_0]
    [IPU1_0] New data Recv      =   5.93 fps
    [IPU1_0]
    [IPU1_0]
    [IPU1_0]
    [IPU1_0]
    [IPU1_0]
    [IPU1_0] Local Link Latency     : Avg = 321041 us, Min = 315440 us, Max = 325657 us,
    [IPU1_0] Source to Link Latency : Avg = 352171 us, Min = 342890 us, Max = 413194 us,
    [IPU1_0]
    [IPU1_0]
    [IPU1_0] ### CPU [  EVE3], LinkID [  0],
    [IPU1_0]
    [IPU1_0]
    [IPU1_0] Elapsed time       = 1634957 msec
    [IPU1_0]
    [IPU1_0]
    [IPU1_0]
    [IPU1_0]
    [IPU1_0]
    [IPU1_0]
    [IPU1_0] Local Link Latency     : Avg =     29 us, Min =      0 us, Max =    122 us,
    [IPU1_0] Source to Link Latency : Avg = 352536 us, Min = 343226 us, Max = 413530 us,
    [IPU1_0]
    [IPU1_0]
    [IPU1_0] ### CPU [  HOST], LinkID [ 14],
    [IPU1_0]
    [IPU1_0] [ IPC_IN_4 ] Link Statistics,
    [IPU1_0]
    [IPU1_0] Elapsed time       = 1635573 msec
    [IPU1_0]
    [IPU1_0]
    [IPU1_0]
    [IPU1_0]
    [IPU1_0]
    [IPU1_0]
    [IPU1_0] [ IPC_IN_4 ] LATENCY,
    [IPU1_0] Source to Link Latency : Avg = 352665 us, Min = 343348 us, Max = 413682 us,
    [IPU1_0]
    [IPU1_0]
    [IPU1_0] ### CPU [  HOST], LinkID [  1],
    [IPU1_0]
    [IPU1_0]
    [IPU1_0] Elapsed time       = 1636097 msec
    [IPU1_0]
    [IPU1_0]
    [IPU1_0]
    [IPU1_0]
    [IPU1_0]
    [IPU1_0]
    [IPU1_0] Local Link Latency     : Avg =      2 us, Min =      0 us, Max =     31 us,
    [IPU1_0] Source to Link Latency : Avg =  28652 us, Min =  26810 us, Max =  35838 us,
    [IPU1_0]
    [IPU1_0]
    [IPU1_0] ### CPU [  EVE2], LinkID [ 10],
    [IPU1_0]
    [IPU1_0]
    [IPU1_0] Elapsed time       = 1636715 msec
    [IPU1_0]
    [IPU1_0]
    [IPU1_0]
    [IPU1_0]
    [IPU1_0]
    [IPU1_0]
    [IPU1_0] Local Link Latency     : Avg =     43 us, Min =     30 us, Max =    458 us,
    [IPU1_0] Source to Link Latency : Avg =  29096 us, Min =  27146 us, Max =  40444 us,
    [IPU1_0]
    [IPU1_0]
    [IPU1_0] ### CPU [  EVE2], LinkID [ 49],
    [IPU1_0]
    [IPU1_0]
    [IPU1_0] Elapsed time       = 1636831 msec
    [IPU1_0]
    [IPU1_0]
    [IPU1_0]
    [IPU1_0]
    [IPU1_0]
    [IPU1_0]
    [IPU1_0] Local Link Latency     : Avg = 325015 us, Min = 314219 us, Max = 329988 us,
    [IPU1_0] Source to Link Latency : Avg = 354336 us, Min = 341579 us, Max = 365553 us,
    [IPU1_0]
    [IPU1_0]
    [IPU1_0] ### CPU [  EVE2], LinkID [  0],
    [IPU1_0]
    [IPU1_0]
    [IPU1_0] Elapsed time       = 1636621 msec
    [IPU1_0]
    [IPU1_0]
    [IPU1_0]
    [IPU1_0]
    [IPU1_0]
    [IPU1_0]
    [IPU1_0] Local Link Latency     : Avg =     29 us, Min =      0 us, Max =    152 us,
    [IPU1_0] Source to Link Latency : Avg = 354710 us, Min = 341884 us, Max = 365919 us,
    [IPU1_0]
    [IPU1_0]
    [IPU1_0] ### CPU [  HOST], LinkID [ 13],
    [IPU1_0]
    [IPU1_0] [ IPC_IN_3 ] Link Statistics,
    [IPU1_0]
    [IPU1_0] Elapsed time       = 1637236 msec
    [IPU1_0]
    [IPU1_0]
    [IPU1_0]
    [IPU1_0]
    [IPU1_0]
    [IPU1_0]
    [IPU1_0] [ IPC_IN_3 ] LATENCY,
    [IPU1_0] Source to Link Latency : Avg = 354843 us, Min = 342006 us, Max = 366041 us,
    [IPU1_0]
    [IPU1_0]
    [IPU1_0] ### CPU [  HOST], LinkID [  0],
    [IPU1_0]
    [IPU1_0]
    [IPU1_0] Elapsed time       = 1637715 msec
    [IPU1_0]
    [IPU1_0]
    [IPU1_0]
    [IPU1_0]
    [IPU1_0]
    [IPU1_0]
    [IPU1_0] Source to Link Latency : Avg =  29668 us, Min =  26871 us, Max =  31995 us,
    [IPU1_0]
    [IPU1_0]
    [IPU1_0] ### CPU [  EVE1], LinkID [ 10],
    [IPU1_0]
    [IPU1_0]
    [IPU1_0] Elapsed time       = 1638327 msec
    [IPU1_0]
    [IPU1_0] Get Full Buf Cb    =   5.90 fps
    [IPU1_0]
    [IPU1_0]
    [IPU1_0]
    [IPU1_0]
    [IPU1_0]
    [IPU1_0] Local Link Latency     : Avg =     41 us, Min =     30 us, Max =    183 us,
    [IPU1_0] Source to Link Latency : Avg =  31024 us, Min =  27146 us, Max =  92265 us,
    [IPU1_0]
    [IPU1_0]
    [IPU1_0] ### CPU [  EVE1], LinkID [ 49],
    [IPU1_0]
    [IPU1_0]
    [IPU1_0] Elapsed time       = 1638441 msec
    [IPU1_0]
    [IPU1_0] New data Recv      =   5.91 fps
    [IPU1_0]
    [IPU1_0]
    [IPU1_0]
    [IPU1_0]
    [IPU1_0]
    [IPU1_0] Local Link Latency     : Avg = 322423 us, Min = 309766 us, Max = 327243 us,
    [IPU1_0] Source to Link Latency : Avg = 353664 us, Min = 338712 us, Max = 417282 us,
    [IPU1_0]
    [IPU1_0]
    [IPU1_0] ### CPU [  EVE1], LinkID [  0],
    [IPU1_0]
    [IPU1_0]
    [IPU1_0] Elapsed time       = 1638238 msec
    [IPU1_0]
    [IPU1_0]
    [IPU1_0]
    [IPU1_0]
    [IPU1_0]
    [IPU1_0]
    [IPU1_0] Local Link Latency     : Avg =     29 us, Min =      0 us, Max =    153 us,
    [IPU1_0] Source to Link Latency : Avg = 354030 us, Min = 339230 us, Max = 418014 us,
    [IPU1_0]
    [IPU1_0]
    [IPU1_0] ### CPU [  HOST], LinkID [ 12],
    [IPU1_0]
    [IPU1_0] [ IPC_IN_2 ] Link Statistics,
    [IPU1_0]
    [IPU1_0] Elapsed time       = 1638853 msec
    [IPU1_0]
    [IPU1_0]
    [IPU1_0]
    [IPU1_0]
    [IPU1_0]
    [IPU1_0]
    [IPU1_0] [ IPC_IN_2 ] LATENCY,
    [IPU1_0] Local Link Latency     : Avg =      5 us, Min =      0 us, Max =     31 us,
    [IPU1_0] Source to Link Latency : Avg = 354159 us, Min = 339383 us, Max = 418167 us,
    [IPU1_0]
    [IPU1_0]
    [IPU1_0] ### CPU [  HOST], LinkID [ 50],
    [IPU1_0]
    [IPU1_0] [ ALG_TIDLPOSTPROC ] Link Statistics,
    [IPU1_0]
    [IPU1_0] Elapsed time       = 1638966 msec
    [IPU1_0]
    [IPU1_0]
    [IPU1_0]
    [IPU1_0]
    [IPU1_0]
    [IPU1_0]
    [IPU1_0] [ ALG_TIDLPOSTPROC ] LATENCY,
    [IPU1_0] Local Link Latency     : Avg =    846 us, Min =    793 us, Max =    976 us,
    [IPU1_0] Source to Link Latency : Avg = 362280 us, Min = 340237 us, Max = 419051 us,
    [IPU1_0]
    [IPU1_0]
    [IPU1_0] ### CPU [IPU1-0], LinkID [  0],
    [IPU1_0]
    [IPU1_0]
    [IPU1_0] Elapsed time       = 1639905 msec
    [IPU1_0]
    [IPU1_0]
    [IPU1_0]
    [IPU1_0]
    [IPU1_0]
    [IPU1_0]
    [IPU1_0] Local Link Latency     : Avg =      7 us, Min =      0 us, Max =    214 us,
    [IPU1_0] Source to Link Latency : Avg =   6733 us, Min =   4636 us, Max =   9608 us,
    [IPU1_0]
    [IPU1_0]
    [IPU1_0] ### CPU [  HOST], LinkID [ 10],
    [IPU1_0]
    [IPU1_0]
    [IPU1_0] Elapsed time       = 1640520 msec
    [IPU1_0]
    [IPU1_0]
    [IPU1_0]
    [IPU1_0]
    [IPU1_0]
    [IPU1_0]
    [IPU1_0] Source to Link Latency : Avg =   6847 us, Min =   4728 us, Max =   9730 us,
    [IPU1_0]
    [IPU1_0] CPU [    HOST], LinkID [ 38], Link Statistics not available !
    [IPU1_0]
    [IPU1_0] ### CPU [  HOST], LinkID [ 34],
    [IPU1_0]
    [IPU1_0] [ SYNC_0 ] Link Statistics,
    [IPU1_0]
    [IPU1_0] Elapsed time       = 1640734 msec
    [IPU1_0]
    [IPU1_0] New data Recv      =  54.38 fps
    [IPU1_0] Driver/Notify Cb   =  30.30 fps
    [IPU1_0]
    [IPU1_0]
    [IPU1_0]  1 |  12. 4      0. 0      0. 0          12. 4
    [IPU1_0]
    [IPU1_0]
    [IPU1_0]
    [IPU1_0] [ SYNC_0 ] LATENCY,
    [IPU1_0] Local Link Latency     : Avg = 177725 us, Min =      0 us, Max = 412921 us,
    [IPU1_0] Source to Link Latency : Avg = 362319 us, Min = 340267 us, Max = 419112 us,
    [IPU1_0]
    [IPU1_0]
    [IPU1_0] ### CPU [  HOST], LinkID [ 51],
    [IPU1_0]
    [IPU1_0]
    [IPU1_0] Elapsed time       = 1640432 msec
    [IPU1_0]
    [IPU1_0]
    [IPU1_0]
    [IPU1_0]
    [IPU1_0]
    [IPU1_0]
    [IPU1_0] Local Link Latency     : Avg =    981 us, Min =    671 us, Max =  22845 us,
    [IPU1_0] Source to Link Latency : Avg = 363342 us, Min = 341182 us, Max = 421095 us,
    [IPU1_0]
    [IPU1_0]
    [IPU1_0] ### CPU [  HOST], LinkID [  4],
    [IPU1_0]
    [IPU1_0] [ IPC_OUT_4 ] Link Statistics,
    [IPU1_0]
    [IPU1_0] Elapsed time       = 1640540 msec
    [IPU1_0]
    [IPU1_0]
    [IPU1_0]
    [IPU1_0]
    [IPU1_0]
    [IPU1_0]
    [IPU1_0] [ IPC_OUT_4 ] LATENCY,
    [IPU1_0] Source to Link Latency : Avg = 363361 us, Min = 341213 us, Max = 421095 us,
    [IPU1_0]
    [IPU1_0]
    [IPU1_0] ### CPU [IPU1-0], LinkID [ 10],
    [IPU1_0]
    [IPU1_0]
    [IPU1_0] Elapsed time       = 1641152 msec
    [IPU1_0]
    [IPU1_0]
    [IPU1_0]
    [IPU1_0]
    [IPU1_0]
    [IPU1_0]
    [IPU1_0] Local Link Latency     : Avg =     29 us, Min =      0 us, Max =    274 us,
    [IPU1_0] Source to Link Latency : Avg = 363559 us, Min = 341426 us, Max = 421491 us,
    [IPU1_0]
    [IPU1_0]
    [IPU1_0] ### CPU [IPU1-0], LinkID [ 73],
    [IPU1_0]
    [IPU1_0] [ DISPLAY ] Link Statistics,
    [IPU1_0]
    [IPU1_0] Elapsed time       = 1641267 msec
    [IPU1_0]
    [IPU1_0] Driver/Notify Cb   =  15.38 fps
    [IPU1_0]
    [IPU1_0]
    [IPU1_0]
    [IPU1_0] [ DISPLAY ] LATENCY,
    [IPU1_0] Local Link Latency     : Avg =     53 us, Min =     30 us, Max =    305 us,
    [IPU1_0] Source to Link Latency : Avg = 363820 us, Min = 341670 us, Max = 421827 us,
    [IPU1_0]
    [IPU1_0] Display UnderFlow Count = 0
    [IPU1_0]
    [IPU1_0] CPU [  IPU1-0], LinkID [ 23], Link Statistics not available !
    [IPU1_0]
    [IPU1_0] ### CPU [IPU1-0], LinkID [ 74],
    [IPU1_0]
    [IPU1_0]
    [IPU1_0] Elapsed time       = 1641837 msec
    [IPU1_0]
    [IPU1_0]
    [IPU1_0]
    [IPU1_0]  0 |   0. 0      0. 0      0. 0           0. 0
    [IPU1_0]
    [IPU1_0] Local Link Latency     : Avg =     30 us, Min =     30 us, Max =     30 us,
    [IPU1_0] Source to Link Latency : Avg = 323675 us, Min = 323675 us, Max = 323675 us,
    [IPU1_0]
    [IPU1_0]
    [IPU1_0]
     Chains Run-time Menu
     0: Stop Chain
     1: Pause Chain
     2: Resume Chain
     3: Show ALL palettes
     4: Show only ROAD palette
     5: Show only PEDESTRIAN palette
     6: Show only ROAD SIGN palette
     7: Show only VEHICLE palette
     p: Print Statistics
     g: show cpu load info
     Enter Choice:
    Wang
    Yes because it taking 320 ms to process one frame. So
    FPS = 1000 ms / 320 ms
    FPS = 3
    Total FPS = FPS * Total number of EVE core running parallel
    Total FPS = 3 * 4
    Total FPS = 12
    Conclusion: This use-case can support up to 12 FPS only.
    Gaviraju
  • Thanks for your  reply.
    Best wishes!
    Wang
