TDA2x, SD card error message output from custom TDA2x board
Other Parts Discussed in Thread: DRA752
Hi!
We are using a TDA2x custom board.
In use with VisionSDK 3.07 in Linux + BIOS mode.
For Linux booting, we modified the file "dra7.dtsi" and confirmed that it was booting successfully.
However, SD card-related error messages continue to appear.
omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xbbc60020 follows the erroneous one
mmcblk0: error -84 transferring data, sector 13855624, nr 256, cmd response 0x900, card status 0xb00
mmc0: tried to reset card
Due to the difference between EVM and hardware, "oppdm_mpu" was modified to 'disabled' in the "dra7.dtsi" file.
I want to find the cause of this problem and solve it.
Attach the boot log message.
U-Boot SPL 2016.05-00016-gcc5b418-dirty (Jun 30 2020 - 16:09:22)
DRA752-GP ES1.1
no pinctrl for ddr_1_8v
*** Warning - bad CRC, using default environment
Trying to boot from MMC1
reading dra7-ipu2-fw.lzop
spl_load_file_fat: error reading file dra7-ipu2-fw.lzop, err - -1
spl: error reading image dra7-ipu2-fw.lzop, err - -1
Error loading remotecore IPU2!,Continuing with boot ...
reading dra7-dsp1-fw.lzop
spl_load_file_fat: error reading file dra7-dsp1-fw.lzop, err - -1
spl: error reading image dra7-dsp1-fw.lzop, err - -1
Error loading remotecore DSP1!,Continuing with boot ...
reading dra7-dsp2-fw.lzop
spl_load_file_fat: error reading file dra7-dsp2-fw.lzop, err - -1
spl: error reading image dra7-dsp2-fw.lzop, err - -1
Error loading remotecore DSP2!,Continuing with boot ...
reading dra7-ipu1-fw.lzop
spl_load_file_fat: error reading file dra7-ipu1-fw.lzop, err - -1
spl: error reading image dra7-ipu1-fw.lzop, err - -1
Error loading remotecore IPU1!,Continuing with boot ...
reading u-boot.img
reading u-boot.img
reading u-boot.img
reading u-boot.img
U-Boot 2016.05-00016-gcc5b418-dirty (Jun 30 2020 - 16:09:22 +0900)
CPU  : DRA752-GP ES1.1
Model: TI DRA742
Board: DRA74x EVM REV
DRAM:  1.5 GiB
MMC:   mmc@4809c000: fail to find hs-rev11 mode FDT_ERR_NOTFOUND
mmc@4809c000: fail to find sdr25-rev11 mode FDT_ERR_NOTFOUND
mmc@4809c000: fail to find sdr12-rev11 mode FDT_ERR_NOTFOUND
OMAP SD/MMC: 0
Warning: fastboot.board_rev: unknown board revision
MMC Device 1 not found
ERROR: invalid mmc device
at arch/arm/cpu/armv7/omap-common/utils.c:193/mmc_get_part_size()
Warning: fastboot.userdata_size: unable to calc
SCSI:  SATA link 0 timeout.
AHCI 0001.0300 32 slots 1 ports 3 Gbps 0x1 impl SATA mode
flags: 64bit ncq stag pm led clo only pmp pio slum part ccc apst
scanning bus for devices...
Found 0 device(s).
Net:
Warning: ethernet@48484000 using MAC address from ROM
eth0: ethernet@48484000
Hit any key to stop autoboot:  0
## Error: "board_findfdt" not defined
switch to partitions #0, OK
mmc0 is current device
SD/MMC found on device 0
reading boot.scr
** Unable to read file boot.scr **
reading uEnv.txt
173 bytes read in 3 ms (55.7 KiB/s)
Loaded env from uEnv.txt
Importing environment from mmc0 ...
3576800 bytes read in 181 ms (18.8 MiB/s)
107035 bytes read in 24 ms (4.3 MiB/s)
Booting from mmc0 ...
Kernel image @ 0x82000000 [ 0x000000 - 0x3693e0 ]
   Loading Device Tree to 8ffe2000, end 8ffff21a ... OK
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Initializing cgroup subsys cpuset
[    0.000000] Initializing cgroup subsys cpuacct
[    0.000000] Linux version 4.4.84-00038-g0af2ab5-dirty (vadas@vadas-TDA2x) (gcc version 5.3.1 20160113 (Linaro GCC 5.3-2016.02) ) #6 SMP PREEMPT Tue Jun 30 16:10:32 KST 2020
[    0.000000] CPU: ARMv7 Processor [412fc0f2] revision 2 (ARMv7), cr=30c5387d
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
[    0.000000] Machine model: TI DRA742
[    0.000000] Reserved memory: created DMA memory pool at 0x0000000040300000, size 3 MiB
[    0.000000] Reserved memory: initialized node cmem@40300000, compatible id shared-dma-pool
[    0.000000] Reserved memory: regions without no-map are not yet supported
[    0.000000] Reserved memory: created CMA memory pool at 0x0000000099000000, size 80 MiB
[    0.000000] Reserved memory: initialized node ipu2_cma@95800000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created CMA memory pool at 0x000000009e000000, size 32 MiB
[    0.000000] Reserved memory: initialized node ipu1_cma@9d000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created CMA memory pool at 0x00000000a1000000, size 32 MiB
[    0.000000] Reserved memory: initialized node dsp1_cma@99000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created CMA memory pool at 0x00000000a3000000, size 32 MiB
[    0.000000] Reserved memory: initialized node dsp2_cma@9f000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a9000000, size 32 MiB
[    0.000000] Reserved memory: initialized node cmem@A9000000, compatible id shared-dma-pool
[    0.000000] cma: Reserved 64 MiB at 0x00000000bbc00000
[    0.000000] Forcing write-allocate cache policy for SMP
[    0.000000] Memory policy: Data cache writealloc
[    0.000000] OMAP4: Map 0x00000000bfd00000 to fe600000 for dram barrier
[    0.000000] DRA752 ES1.1
[    0.000000] PERCPU: Embedded 11 pages/cpu @ef62a000 s14912 r8192 d21952 u45056
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 251456
[    0.000000] Kernel command line: console=ttyO0,115200n8 vram=16M root=PARTUUID=485bad7a-02 rw rootwait ip=none mem=1024M cma=64M
[    0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Memory: 353148K/1012736K available (6671K kernel code, 320K rwdata, 2396K rodata, 336K init, 290K bss, 413828K reserved, 245760K cma-reserved, 193536K highmem)
[    0.000000] Virtual kernel memory layout:
[    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
[    0.000000]     fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
[    0.000000]     vmalloc : 0xf0800000 - 0xff800000   ( 240 MB)
[    0.000000]     lowmem  : 0xc0000000 - 0xf0000000   ( 768 MB)
[    0.000000]     pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
[    0.000000]     modules : 0xbf000000 - 0xbfe00000   (  14 MB)
[    0.000000]       .text : 0xc0008000 - 0xc08e302c   (9069 kB)
[    0.000000]       .init : 0xc08e4000 - 0xc0938000   ( 336 kB)
[    0.000000]       .data : 0xc0938000 - 0xc0988220   ( 321 kB)
[    0.000000]        .bss : 0xc098a000 - 0xc09d2880   ( 291 kB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[    0.000000] Preemptible hierarchical RCU implementation.
[    0.000000]  Build-time adjustment of leaf fanout to 32.
[    0.000000] NR_IRQS:16 nr_irqs:16 16
[    0.000000] ti_dt_clocks_register: failed to lookup clock node gmac_gmii_ref_clk_div
[    0.000000] OMAP clockevent source: timer1 at 32786 Hz
[    0.000000] Architected cp15 timer(s) running at 6.14MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x16af5adb9, max_idle_ns: 440795202250 ns
[    0.000005] sched_clock: 56 bits at 6MHz, resolution 162ns, wraps every 4398046511023ns
[    0.000015] Switching to timer-based delay loop, resolution 162ns
[    0.000330] clocksource: 32k_counter: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 58327039986419 ns
[    0.000338] OMAP clocksource: 32k_counter at 32768 Hz
[    0.000775] Console: colour dummy device 80x30
[    0.000791] WARNING: Your 'console=ttyO0' has been replaced by 'ttyS0'
[    0.000797] This ensures that you still see kernel messages. Please
[    0.000803] update your kernel commandline.
[    0.000817] Calibrating delay loop (skipped), value calculated using timer frequency.. 12.29 BogoMIPS (lpj=61475)
[    0.000829] pid_max: default: 32768 minimum: 301
[    0.000927] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.000936] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.001477] Initializing cgroup subsys io
[    0.001493] Initializing cgroup subsys memory
[    0.001518] Initializing cgroup subsys devices
[    0.001530] Initializing cgroup subsys freezer
[    0.001541] Initializing cgroup subsys perf_event
[    0.001552] Initializing cgroup subsys pids
[    0.001578] CPU: Testing write buffer coherency: ok
[    0.001778] /cpus/cpu@0 missing clock-frequency property
[    0.001794] /cpus/cpu@1 missing clock-frequency property
[    0.001804] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.001838] Setting up static identity map for 0x80008380 - 0x800083e0
[    0.080058] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[    0.080128] Brought up 2 CPUs
[    0.080141] SMP: Total of 2 processors activated (24.59 BogoMIPS).
[    0.080147] CPU: All CPU(s) started in HYP mode.
[    0.080153] CPU: Virtualization extensions available.
[    0.080526] devtmpfs: initialized
[    0.109401] VFP support v0.3: implementor 41 architecture 4 part 30 variant f rev 0
[    0.110362] omap_hwmod: l3_main_2 using broken dt data from ocp
[    0.316211] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.316232] futex hash table entries: 512 (order: 3, 32768 bytes)
[    0.321298] pinctrl core: initialized pinctrl subsystem
[    0.322158] NET: Registered protocol family 16
[    0.323102] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.350233] cpuidle: using governor ladder
[    0.380256] cpuidle: using governor menu
[    0.388806] OMAP GPIO hardware version 0.1
[    0.395277] irq: no irq domain found for /ocp/l4@4a000000/scm@2000/pinmux@1400 !
[    0.418469] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.418480] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.418947] omap4_sram_init:Unable to allocate sram needed to handle errata I688
[    0.418957] omap4_sram_init:Unable to get sram pool needed to handle errata I688
[    0.419544] OMAP DMA hardware revision 0.0
[    0.461454] omap-dma-engine 4a056000.dma-controller: OMAP DMA engine driver (LinkedList1/2/3 supported)
[    0.462569] edma 43300000.edma: memcpy is disabled
[    0.467298] edma 43300000.edma: TI EDMA DMA engine driver
[    0.471621] omap-iommu 40d01000.mmu: 40d01000.mmu registered
[    0.471799] omap-iommu 40d02000.mmu: 40d02000.mmu registered
[    0.471963] omap-iommu 58882000.mmu: 58882000.mmu registered
[    0.472122] omap-iommu 55082000.mmu: 55082000.mmu registered
[    0.472408] omap-iommu 41501000.mmu: 41501000.mmu registered
[    0.472595] omap-iommu 41502000.mmu: 41502000.mmu registered
[    0.475562] palmas 0-0058: IRQ missing: skipping irq request
[    0.490999] palmas 0-0058: Muxing GPIO 2e, PWM 0, LED 0
[    0.552533] omap_i2c 48070000.i2c: bus 0 rev0.12 at 400 kHz
[    0.552953] omap_i2c 48060000.i2c: bus 2 rev0.12 at 400 kHz
[    0.553140] media: Linux media interface: v0.10
[    0.553202] Linux video capture interface: v2.00
[    0.553244] pps_core: LinuxPPS API ver. 1 registered
[    0.553252] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.553277] PTP clock support registered
[    0.553326] EDAC MC: Ver: 3.0.0
[    0.554078] omap-mailbox 48840000.mailbox: omap mailbox rev 0x400
[    0.554372] omap-mailbox 48842000.mailbox: omap mailbox rev 0x400
[    0.554695] Advanced Linux Sound Architecture Driver Initialized.
[    0.555553] clocksource: Switched to clocksource arch_sys_counter
[    0.565997] NET: Registered protocol family 2
[    0.566496] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[    0.566560] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[    0.566686] TCP: Hash tables configured (established 8192 bind 8192)
[    0.566732] UDP hash table entries: 512 (order: 2, 16384 bytes)
[    0.566764] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[    0.566970] NET: Registered protocol family 1
[    0.567233] RPC: Registered named UNIX socket transport module.
[    0.567242] RPC: Registered udp transport module.
[    0.567249] RPC: Registered tcp transport module.
[    0.567254] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.568249] hw perfevents: enabled with armv7_cortex_a15 PMU driver, 7 counters available
[    0.578229] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.578876] NFS: Registering the id_resolver key type
[    0.578909] Key type id_resolver registered
[    0.578916] Key type id_legacy registered
[    0.578974] ntfs: driver 2.1.32 [Flags: R/O].
[    0.580263] bounce: pool size: 64 pages
[    0.580413] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[    0.580428] io scheduler noop registered
[    0.580441] io scheduler deadline registered
[    0.580474] io scheduler cfq registered (default)
[    0.584190] pinctrl-single 4a003400.pinmux: 282 pins at pa fc003400 size 1128
[    0.587334] PCI host bridge /ocp/axi@0/pcie_rc@51000000 ranges:
[    0.587347]   No bus range found for /ocp/axi@0/pcie_rc@51000000, using [bus 00-ff]
[    0.587379]    IO 0x20003000..0x20012fff -> 0x00000000
[    0.587400]   MEM 0x20013000..0x2fffffff -> 0x20013000
[    0.617204] dra7-pcie 51000000.pcie_rc: link is not up
[    0.617372] dra7-pcie 51000000.pcie_rc: PCI host bridge to bus 0000:00
[    0.617384] pci_bus 0000:00: root bus resource [bus 00-ff]
[    0.617394] pci_bus 0000:00: root bus resource [io  0x0000-0xffff]
[    0.617404] pci_bus 0000:00: root bus resource [mem 0x20013000-0x2fffffff]
[    0.617812] PCI: bus0: Fast back to back transfers disabled
[    0.617937] PCI: bus1: Fast back to back transfers enabled
[    0.618018] pci 0000:00:00.0: BAR 0: assigned [mem 0x20100000-0x201fffff]
[    0.618034] pci 0000:00:00.0: BAR 1: assigned [mem 0x20020000-0x2002ffff]
[    0.618047] pci 0000:00:00.0: PCI bridge to [bus 01]
[    0.618271] pcieport 0000:00:00.0: Signaling PME through PCIe PME interrupt
[    0.677475] Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled
[    0.680835] 4806a000.serial: ttyS0 at MMIO 0x4806a000 (irq = 301, base_baud = 3000000) is a 8250
[    1.672954] console [ttyS0] enabled
[    1.677363] 4806c000.serial: ttyS1 at MMIO 0x4806c000 (irq = 302, base_baud = 3000000) is a 8250
[    1.687059] 48020000.serial: ttyS2 at MMIO 0x48020000 (irq = 303, base_baud = 3000000) is a 8250
[    1.697026] [drm] Initialized drm 1.1.0 20060810
[    1.702524] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    1.709212] [drm] No driver support for vblank timestamp query.
[    1.715339] [drm] Initialized vdrm 1.0.0 20110917 on minor 0
[    1.728198] loop: module loaded
[    1.731689] vmemexp device MAJOR num = 245
[    1.735835] vmemexp class registered
[    1.739548] /dev/vmemexp device registered
[    1.743660] ioctl DBUFIOC_EXPORT_VIRTMEM = -1072899120
[    1.752230] m25p80 spi32766.0: s25fl256s1 (32768 Kbytes)
[    1.757652] 7 ofpart partitions found on MTD device spi32766.0
[    1.763511] Creating 7 MTD partitions on "spi32766.0":
[    1.768689] 0x000000000000-0x000000040000 : "QSPI.SPL"
[    1.774815] 0x000000040000-0x000000140000 : "QSPI.u-boot"
[    1.781194] 0x000000140000-0x0000001c0000 : "QSPI.u-boot-spl-os"
[    1.788143] 0x0000001c0000-0x0000001d0000 : "QSPI.u-boot-env"
[    1.794804] 0x0000001d0000-0x0000001e0000 : "QSPI.u-boot-env.backup1"
[    1.802204] 0x0000001e0000-0x0000009e0000 : "QSPI.kernel"
[    1.808548] 0x0000009e0000-0x000002000000 : "QSPI.file-system"
[    1.816331] libphy: Fixed MDIO Bus: probed
[    1.865588] davinci_mdio 48485000.mdio: davinci mdio revision 1.6
[    1.871714] davinci_mdio 48485000.mdio: detected phy mask fffffffb
[    1.879963] libphy: 48485000.mdio: probed
[    1.883995] davinci_mdio 48485000.mdio: phy[2]: device 48485000.mdio:02, driver unknown
[    1.892680] cpsw 48484000.ethernet: Detected MACID = 7c:66:9d:ee:81:8c
[    1.899354] cpsw 48484000.ethernet: cpts: overflow check period 800
[    1.906343] cpsw 48484000.ethernet: cpsw: Detected MACID = 7c:66:9d:ee:81:8d
[    1.914923] mousedev: PS/2 mouse device common for all mice
[    1.921084] i2c /dev entries driver
[    1.929681] omap_hsmmc 4809c000.mmc: Got CD GPIO
[    1.934706] evm_3v3_sw: supplied by sysen1
[    1.986339] ledtrig-cpu: registered to indicate activity on CPUs
[    1.997367] davinci-mcasp 48468000.mcasp: ERRATA i868 workaround is enabled
[    2.004557] davinci-mcasp 4847c000.mcasp: invalid tdm slots: 0
[    2.012064] NET: Registered protocol family 10
[    2.017435] sit: IPv6 over IPv4 tunneling driver
[    2.022624] NET: Registered protocol family 17
[    2.027350] Key type dns_resolver registered
[    2.031762] omap_voltage_late_init: Voltage driver support not added
[    2.038809] Power Management for TI OMAP4+ devices.
[    2.043921] Registering SWP/SWPB emulation handler
[    2.050025] dmm 4e000000.dmm: workaround for errata i878 in use
[    2.057582] dmm 4e000000.dmm: initialized all PAT entries
[    2.063987] [drm] Initialized omapdrm 1.0.0 20110917 on minor 1
[    2.081761] hctosys: unable to open rtc device (rtc0)
[    2.098840] evm_1v8: disabling
[    2.101917] aic_dvdd: disabling
[    2.102746] mmc0: host does not support reading read-only switch, assuming write-enable
[    2.104694] mmc0: new high speed SDHC card at address 59b4
[    2.115239] mmcblk0: mmc0:59b4 NCard 15.1 GiB
[    2.119391]  mmcblk0: p1 p2
[    2.125952] vmmcwl_fixed: disabling
[    2.129650] ldousb: disabling
[    2.133134] ALSA device list:
[    2.136136]   No soundcards found.
[    2.141127] EXT4-fs (mmcblk0p2): couldn't mount as ext3 due to feature incompatibilities
[    2.149776] EXT4-fs (mmcblk0p2): couldn't mount as ext2 due to feature incompatibilities
[    2.398804] EXT4-fs (mmcblk0p2): recovery complete
[    2.406894] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[    2.415052] VFS: Mounted root (ext4 filesystem) on device 179:2.
[    2.422995] devtmpfs: mounted
[    2.426273] Freeing unused kernel memory: 336K
[    2.430738] This architecture does not have kernel memory protection.
[    2.518115] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xbbc60008 follows the erroneous one
[    2.527276] mmcblk0: error -84 transferring data, sector 6162216, nr 120, cmd response 0x900, card status 0xb00
[    2.599233] mmc0: tried to reset card
[    2.672974] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xbbc60008 follows the erroneous one
[    2.682158] mmcblk0: error -84 transferring data, sector 805696, nr 176, cmd response 0x900, card status 0xb00
[    2.749228] mmc0: tried to reset card
[    2.784640] systemd[1]: System time before build time, advancing clock.
[    2.827454] random: systemd: uninitialized urandom read (16 bytes read, 15 bits of entropy available)
[    2.840275] random: systemd: uninitialized urandom read (16 bytes read, 15 bits of entropy available)
[    2.852071] systemd[1]: systemd 229 running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR +SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT +GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN)
[    2.870606] systemd[1]: Detected architecture arm.
Welcome to Arago 2016.12!
[    2.896432] systemd[1]: Set hostname to <dra7xx-evm>.
[    2.969617] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read, 16 bits of entropy available)
[    2.977217] random: systemd-gpt-aut: uninitialized urandom read (16 bytes read, 17 bits of entropy available)
[    2.977391] random: systemd-gpt-aut: uninitialized urandom read (16 bytes read, 17 bits of entropy available)
[    3.028331] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read, 18 bits of entropy available)
[    3.049773] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read, 19 bits of entropy available)
[    3.080700] random: systemd: uninitialized urandom read (16 bytes read, 20 bits of entropy available)
[    3.090261] random: systemd: uninitialized urandom read (16 bytes read, 20 bits of entropy available)
[    3.100296] random: systemd: uninitialized urandom read (16 bytes read, 20 bits of entropy available)
[    3.459500] systemd[1]: alignment.service: Found ordering cycle on alignment.service/start
[    3.467871] systemd[1]: alignment.service: Found dependency on sysinit.target/start
[    3.475655] systemd[1]: alignment.service: Found dependency on alignment.service/start
[    3.483616] systemd[1]: alignment.service: Breaking ordering cycle by deleting job alignment.service/start
[    3.493360] systemd[1]: alignment.service: Job alignment.service/start deleted to break ordering cycle starting with alignment.service/start
[ SKIP ] Ordering cycle found, skipping alignment.service
[    3.528249] systemd[1]: Listening on Network Service Netlink Socket.
[  OK  ] Listening on Network Service Netlink Socket.
[    3.555792] systemd[1]: Reached target Swap.
[  OK  ] Reached target Swap.
[    3.575863] systemd[1]: Listening on Syslog Socket.
[  OK  ] Listening on Syslog Socket.
[    3.595760] systemd[1]: Reached target Remote File Systems.
[  OK  ] Reached target Remote File Systems.
[    3.625872] systemd[1]: Listening on udev Control Socket.
[  OK  ] Listening on udev Control Socket.
[    3.655882] systemd[1]: Listening on Journal Socket.
[  OK  ] Listening on Journal Socket.
[    3.685843] systemd[1]: Listening on udev Kernel Socket.
[  OK  ] Listening on udev Kernel Socket.
[    3.715977] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[  OK  ] Started Dispatch Password Requests to Console Directory Watch.
[    3.745873] systemd[1]: Listening on Journal Socket (/dev/log).
[  OK  ] Listening on Journal Socket (/dev/log).
[    3.777205] systemd[1]: Created slice System Slice.
[  OK  ] Created slice System Slice.
[    3.835824] systemd[1]: Mounting Temporary Directory...
[    3.868229] systemd[1]: Mounting Debug File System...
[    3.896649] systemd[1]: Created slice system-getty.slice.
[  OK  ] Created slice system-getty.slice.
[    3.955992] systemd[1]: Starting Setup Virtual Console...
[    3.990968] systemd[1]: Starting Load Kernel Modules...
         Starting Load Kernel Modules...[    3.997660] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xbbc60020 follows the erroneous one
[    4.010110] mmcblk0: error -84 transferring data, sector 9292528, nr 32, cmd response 0x900, card status 0xb00
[    4.045838] systemd[1]: Mounting POSIX Message Queue File System...
[    4.078426] systemd[1]: Starting Create list of required static device nodes for the current kernel...
[    4.079302] mmc0: tried to reset card
         Starting Create list of required st... nodes for the current kernel...
[    4.105972] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[  OK  ] Listening on /dev/initctl Compatibility Named Pipe.
[    4.136527] systemd[1]: Created slice system-serial\x2dgetty.slice.
[  OK  ] Created slice system-serial\x2dgetty.slice.
[    4.166408] systemd[1]: Created slice User and Session Slice.
[  OK  ] Created slice User and Session Slice.
[    4.195789] systemd[1]: Reached target Slices.
[  OK  ] Reached target Slices.
[    4.245912] systemd[1]: Starting Remount Root and Kernel File Systems...
[    4.268550] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[    4.281225] systemd[1]: Starting Journal Service...
[    4.306192] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[  OK  ] Started Forward Password Requests to Wall Directory Watch.
[    4.335851] systemd[1]: Reached target Paths.
[  OK  ] Reached target Paths.
[    4.391207] systemd[1]: Mounted Debug File System.
[  OK  ] Mounted Debug File System.
[    4.415896] systemd[1]: Mounted POSIX Message Queue File System.
[  OK  ] Mounted POSIX Message Queue File System.
[    4.445848] systemd[1]: Mounted Temporary Directory.
[  OK  ] Mounted Temporary Directory.
[    4.476029] systemd[1]: Started Journal Service.
[  OK  ] Started Journal Service.
[  OK  ] Started Setup Virtual Console.
[FAILED] Failed to start Load Kernel Modules.
See 'systemctl status systemd-modules-load.service' for details.
[  OK  ] Started Create list of required sta...ce nodes for the current kernel.
[  OK  ] Started Remount Root and Kernel File Systems.
         Starting udev Coldplug all Devices...
         Starting Create Static Device Nodes in /dev...
         Starting Apply Kernel Variables...
         Starting Flush Journal to Persistent Storage...[    4.994295] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xbbc60020 follows the erroneous one
[    5.004660] mmcblk0: error -84 transferring data, sector 4983808, nr 224, cmd response 0x900, card status 0xb00
[    5.089346] mmc0: tried to reset card
[  OK  ] Started Create Static Device Nodes in /dev.
[  OK  ] Started Apply Kernel Variables.
[    5.261367] systemd-journald[148]: Received request to flush runtime journal from PID 1
[  OK  ] Reached target Local File Systems (Pre).
         Mounting /media/ram...
         Mounting /var/volatile...
         Starting udev Kernel Device Manager...
[  OK  ] Mounted /var/volatile.
[  OK  ] Mounted /media/ram.
[  OK  ] Started Flush Journal to Persistent Storage.
[  OK  ] Started udev Kernel Device Manager.
         Starting Load/Save Random Seed...
[  OK  ] Reached target Local File Systems.
[    5.767322] omap-rproc 58820000.ipu: assigned reserved memory node ipu1_cma@9d000000
[    5.782537]  remoteproc0: 58820000.ipu is available
[    5.796862]  remoteproc0: Note: remoteproc is still under development and considered experimental.
         Starting Create Volatile Files and Directories...
[    5.822031]  remoteproc0: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
[  OK  ] Started udev Coldplug all Devices.
[    5.861459] omap-rproc 55020000.ipu: assigned reserved memory node ipu2_cma@95800000
[    5.869677]  remoteproc1: 55020000.ipu is available
[    5.881828] omap_hsmmc 4809c000.mmc: ADMA err: ST_STOP, desc at 0xbbc600e0 follows the erroneous one
[    5.883952]  remoteproc1: Note: remoteproc is still under development and considered experimental.
[    5.883957]  remoteproc1: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
[    5.884075]  remoteproc1: Direct firmware load for dra7-ipu2-fw.xem4 failed with error -2
[    5.884082]  remoteproc1: failed to load dra7-ipu2-fw.xem4
[    5.886031] omap-rproc 40800000.dsp: assigned reserved memory node dsp1_cma@99000000
[    5.886089]  remoteproc2: 40800000.dsp is available
[    5.886092]  remoteproc2: Note: remoteproc is still under development and considered experimental.
[  OK  [    5.886095]  remoteproc2: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
[    5.888325] omap-rproc 41000000.dsp: assigned reserved memory node dsp2_cma@9f000000
[    5.888374]  remoteproc3: 41000000.dsp is available
[    5.888378]  remoteproc3: Note: remoteproc is still under development and considered experimental.
[    5.888381]  remoteproc3: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
 ]Started Load/Save Random Seed.
[    5.993140] mmcblk0: error -84 transferring data, sector 821248, nr 512, cmd response 0x900, card status 0xb00
[    6.115373] mmc0: tried to reset card
[    6.123214] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xbbc60060 follows the erroneous one
[    6.133652] mmcblk0: error -84 transferring data, sector 821248, nr 512, cmd response 0x900, card status 0xb00
[    6.185685] mmcblk0: retrying using single block read
[[;32m  OK   ]Found device /dev/ttyS0.
[[;32m  OK   ]Started Create Volatile Files and Directories
[    6.450615] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xbbc60048 follows the erroneous one
[    6.459847] mmcblk0: error -84 transferring data, sector 822272, nr 512, cmd response 0x900, card status 0xb00
         Starting Network Time Synchronization...
         Starting Update UTMP about System Boot/Shutdown...[    6.540182] mmc0: tried to reset card
[    6.705705] omap_rng 48090000.rng: OMAP Random Number Generator ver. 20
[    6.723653] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xbbc60080 follows the erroneous one
[    6.733509] mmcblk0: error -84 transferring data, sector 6112840, nr 512, cmd response 0x900, card status 0xb00
[    6.809244] mmc0: tried to reset card
[    6.815484] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xbbc60060 follows the erroneous one
[    6.825350] mmcblk0: error -84 transferring data, sector 6112840, nr 512, cmd response 0x900, card status 0xb00
[    6.835699] mmcblk0: retrying using single block read
[  OK  ] Started Update UTMP about System Boot/Shutdown.
[    7.106738] omap-des 480a5000.des: OMAP DES hw accel rev: 2.2
[  OK  ] Started Network Time Synchronization.
[    7.131892] omap_hsmmc 4809c000.mmc: ADMA err: ST_STOP, desc at 0xbbc60040 follows the erroneous one
[    7.142056] mmcblk0: error -84 transferring data, sector 4993648, nr 512, cmd response 0x900, card status 0xb00
         Starting Synchronize System and HW clocks...
[    7.229242] mmc0: tried to reset card
[  OK  ] Reached target System Time Synchronized.
[    7.246127] omap_hsmmc 4809c000.mmc: ADMA err: ST_STOP, desc at 0xbbc60030 follows the erroneous one
[    7.255388] mmcblk0: error -84 transferring data, sector 5000264, nr 256, cmd response 0x900, card status 0xb00
[    7.349242] mmc0: tried to reset card
[    7.355652] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xbbc60060 follows the erroneous one
[    7.364831] mmcblk0: error -84 transferring data, sector 5000264, nr 256, cmd response 0x900, card status 0xb00
[    7.375783] mmcblk0: retrying using single block read
[    7.469706] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xbbc60080 follows the erroneous one
[    7.479510] mmcblk0: error -84 transferring data, sector 825600, nr 512, cmd response 0x900, card status 0xb00
[    7.549245] mmc0: tried to reset card
[    7.568391]  remoteproc2: registered virtio0 (type 7)
[    7.571993] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xbbc60010 follows the erroneous one
[    7.572097] mmcblk0: error -84 transferring data, sector 826112, nr 512, cmd response 0x900, card status 0xb00
[    7.592856]  remoteproc3: registered virtio1 (type 7)
[    7.649258] mmc0: tried to reset card
[    7.710076] CAN device driver interface
[    7.741974] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xbbc60040 follows the erroneous one
[    7.751222] mmcblk0: error -84 transferring data, sector 6113352, nr 512, cmd response 0x900, card status 0xb00
[    7.819260] mmc0: tried to reset card
[    7.830311] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xbbc60078 follows the erroneous one
[    7.845580] mmcblk0: error -84 transferring data, sector 6113352, nr 512, cmd response 0x900, card status 0xb00
[    7.855760] mmcblk0: retrying using single block read
[    8.047729] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xbbc60008 follows the erroneous one
[    8.057567] mmcblk0: error -84 transferring data, sector 829184, nr 256, cmd response 0x900, card status 0xb00
[    8.129243] mmc0: tried to reset card
[    8.133580] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xbbc60008 follows the erroneous one
[    8.142773] mmcblk0: error -84 transferring data, sector 829184, nr 256, cmd response 0x900, card status 0xb00
[    8.152867] mmcblk0: retrying using single block read
[    8.199232] random: nonblocking pool is initialized
[    8.290555] omap-sham 4b101000.sham: hw accel on OMAP rev 4.3
[    8.324514] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xbbc60088 follows the erroneous one
[    8.334316] mmcblk0: error -84 transferring data, sector 6161152, nr 256, cmd response 0x900, card status 0xb00
[    8.409257] mmc0: tried to reset card
[    8.423472] omap_rtc 48838000.rtc: already running
[    8.428664] omap_rtc 48838000.rtc: rtc core: registered 48838000.rtc as rtc0
[    8.447641] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xbbc60008 follows the erroneous one
[    8.457408] mmcblk0: error -84 transferring data, sector 9181488, nr 152, cmd response 0x900, card status 0xb00
[    8.539240] mmc0: tried to reset card
[    8.548586] c_can_platform 4ae3c000.can: c_can_platform device registered (regs=fce3c000, irq=353)
[    8.581307] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xbbc60078 follows the erroneous one
[    8.590584] mmcblk0: error -84 transferring data, sector 6115400, nr 512, cmd response 0x900, card status 0xb00
[    8.659232] mmc0: tried to reset card
[    8.731116]  remoteproc0: registered virtio2 (type 7)
[    8.739736] SCSI subsystem initialized
[  OK  ] Started Synchronize System and HW clocks.
[    8.784495] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xbbc60010 follows the erroneous one
[    8.793731] mmcblk0: error -84 transferring data, sector 6197664, nr 512, cmd response 0x900, card status 0xb00
[    8.813630] omap-aes 4b500000.aes: OMAP AES hw accel rev: 3.3
[    8.826800] omap-aes 4b700000.aes: OMAP AES hw accel rev: 3.3
[  OK  ] Reached target System Initialization.
[  OK  ] Listening on D-Bus System Message Bus Socket.
[  OK  ] Started Daily Cleanup of Temporary Directories.
[    8.889254] mmc0: tried to reset card
[  OK  ] Reached target Timers.
[    8.916349] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xbbc60070 follows the erroneous one
[    8.925525] mmcblk0: error -84 transferring data, sector 6198176, nr 256, cmd response 0x900, card status 0xb00
[    8.999230] mmc0: tried to reset card
[    9.010466] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xbbc60008 follows the erroneous one
[    9.020179] mmcblk0: error -84 transferring data, sector 6198432, nr 256, cmd response 0x900, card status 0xb00
[    9.089231] mmc0: tried to reset card
[    9.096132] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xbbc60010 follows the erroneous one
[    9.105300] mmcblk0: error -84 transferring data, sector 6198432, nr 256, cmd response 0x900, card status 0xb00
[    9.116090] mmcblk0: retrying using single block read
[    9.253449] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xbbc60008 follows the erroneous one
[    9.263264] mmcblk0: error -84 transferring data, sector 6200480, nr 256, cmd response 0x900, card status 0xb00
[    9.339240] mmc0: tried to reset card
[    9.347989] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xbbc60010 follows the erroneous one
[    9.357655] mmcblk0: error -84 transferring data, sector 6200480, nr 256, cmd response 0x900, card status 0xb00
[    9.367842] mmcblk0: retrying using single block read
[  OK  ] Listening on dropbear.socket.
[    9.480073] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xbbc60018 follows the erroneous one
[    9.490474] mmcblk0: error -84 transferring data, sector 1084128, nr 512, cmd response 0x900, card status 0xb00
[  OK  ] Reached target Sockets.
[  OK  ] Reached target Basic System.
[    9.559242] mmc0: tried to reset card
[    9.568268] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xbbc60010 follows the erroneous one
[    9.578397] mmcblk0: error -84 transferring data, sector 1084128, nr 512, cmd response 0x900, card status 0xb00
         Starting Login Service...[    9.590674] mmcblk0: retrying using single block read
[  OK  ] Started Kernel Logging Service.
[    9.800693] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xbbc60008 follows the erroneous one
[    9.809960] mmcblk0: error -84 transferring data, sector 9293904, nr 144, cmd response 0x900, card status 0xb00
[  OK  ] Started System Logging Service.
[    9.879391] mmc0: tried to reset card
         Starting rc.pvr.service...
[    9.919920] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xbbc60018 follows the erroneous one
[   9.929206] mmcblk0: error -84 transferring data, sector 1085152, nr 512, cmd response 0x900, card status 0xb00
[  OK  ] Started D-Bus System Message Bus.
[   10.009427] mmc0: tried to reset card
[   10.021410] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xbbc600d0 follows the erroneous one
[   10.030621] mmcblk0: error -84 transferring data, sector 1085152, nr 512, cmd response 0x900, card status 0xb00
[   10.048452] mmcblk0: retrying using single block read
[   10.210259] omap_hsmmc 4809c000.mmc: ADMA err: ST_STOP, desc at 0xbbc60018 follows the erroneous one
[   10.228886] mmcblk0: error -84 transferring data, sector 6196760, nr 136, cmd response 0x900, card status 0xb00
[   10.329316] mmc0: tried to reset card
[   10.337834] ahci 4a140000.sata: SSS flag set, parallel bus scan disabled
[   10.344619] ahci 4a140000.sata: AHCI 0001.0300 32 slots 1 ports 3 Gbps 0x1 impl platform mode
[   10.359275] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xbbc60080 follows the erroneous one
[   10.368527] mmcblk0: error -84 transferring data, sector 1085664, nr 512, cmd response 0x900, card status 0xb00
[   10.394681] ahci 4a140000.sata: flags: 64bit ncq sntf stag pm led clo only pmp pio slum part ccc apst
[   10.419705] scsi host0: ahci
[   10.422952] ata1: SATA max UDMA/133 mmio [mem 0x4a140000-0x4a1410ff] port 0x100 irq 340
[   10.469292] mmc0: tried to reset card
[   10.477496] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xbbc60080 follows the erroneous one
[   10.492635] mmcblk0: error -84 transferring data, sector 1085664, nr 512, cmd response 0x900, card status 0xb00
[   10.508807] mmcblk0: retrying using single block read
[   10.708960] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xbbc60038 follows the erroneous one
[   10.718397] mmcblk0: error -84 transferring data, sector 1086176, nr 512, cmd response 0x900, card status 0xb00
[   10.795596] ata1: SATA link down (SStatus 0 SControl 300)
[   10.809376] mmc0: tried to reset card
[   10.838316] omap_hsmmc 4809c000.mmc: ADMA err: ST_STOP, desc at 0xbbc600d8 follows the erroneous one
[   10.849153] mmcblk0: error -84 transferring data, sector 1086688, nr 512, cmd response 0x900, card status 0xb00
[   10.932357] mmc0: tried to reset card
[   10.939458] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xbbc60088 follows the erroneous one
[   10.953353] mmcblk0: error -84 transferring data, sector 1086688, nr 512, cmd response 0x900, card status 0xb00
[   10.963611] mmcblk0: retrying using single block read
[   11.441470] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xbbc60008 follows the erroneous one
[   11.450941] mmcblk0: error -84 transferring data, sector 1161136, nr 480, cmd response 0x900, card status 0xb00
[   11.529294] mmc0: tried to reset card
[   11.541061] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xbbc60090 follows the erroneous one
[   11.550298] mmcblk0: error -84 transferring data, sector 1161136, nr 480, cmd response 0x900, card status 0xb00
[   11.560519] mmcblk0: retrying using single block read
[   11.713592] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xbbc60188 follows the erroneous one
[   11.722890] mmcblk0: error -84 transferring data, sector 1161616, nr 512, cmd response 0x900, card status 0xb00
[   11.799248] mmc0: tried to reset card
[   11.818727] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xbbc60070 follows the erroneous one
[   11.827967] mmcblk0: error -84 transferring data, sector 9221648, nr 320, cmd response 0x900, card status 0xb00
[   11.899252] mmc0: tried to reset card
[   11.913356]  remoteproc2: powering up 40800000.dsp
[   11.920420]  remoteproc2: Booting fw image dra7-dsp1-fw.xe66, size 854528
[   11.935646] omap_hwmod: mmu0_dsp1: _wait_target_disable failed
[   11.941543] omap-iommu 40d01000.mmu: 40d01000.mmu: version 3.0
[   11.947517] omap-iommu 40d02000.mmu: 40d02000.mmu: version 3.0
[   11.964438] [drm] Initialized pvr 1.14.3699939 20110701 on minor 2
[   11.990673]  remoteproc2: remote processor 40800000.dsp is now up
[   11.997919] virtio_rpmsg_bus virtio0: rpmsg host is online
[   12.007305]  remoteproc3: powering up 41000000.dsp
[   12.013765]  remoteproc3: Booting fw image dra7-dsp2-fw.xe66, size 854528
[   12.028055] omap_hwmod: mmu0_dsp2: _wait_target_disable failed
[   12.033952] omap-iommu 41501000.mmu: 41501000.mmu: version 3.0
[   12.039911] omap-iommu 41502000.mmu: 41502000.mmu: version 3.0
[   12.052252] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xbbc60008 follows the erroneous one
[   12.061489] mmcblk0: error -84 transferring data, sector 4984800, nr 136, cmd response 0x900, card status 0xb00
[   12.071250]  remoteproc3: remote processor 41000000.dsp is now up
[   12.078271] virtio_rpmsg_bus virtio1: rpmsg host is online
[   12.086592]  remoteproc0: powering up 58820000.ipu
[   12.098355]  remoteproc0: Booting fw image dra7-ipu1-fw.xem4, size 5824980
[   12.105359] omap-iommu 58882000.mmu: 58882000.mmu: version 2.1
[   12.139428] mmc0: tried to reset card
[   12.139754]  remoteproc0: remote processor 58820000.ipu is now up
[   12.149443] virtio_rpmsg_bus virtio2: rpmsg host is online
[   12.164206] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xbbc60020 follows the erroneous one
[   12.174175] mmcblk0: error -84 transferring data, sector 4984752, nr 48, cmd response 0x900, card status 0xb00
[   12.249236] mmc0: tried to reset card
[   12.277257] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[   12.294047] PVR_K: UM DDK-(3699939) and KM DDK-(3699939) match. [ OK ]
         Starting Network Service...
         Starting Permit User Sessions...
[   12.344497] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xbbc60010 follows the erroneous one
[   12.353771] mmcblk0: error -84 transferring data, sector 9288800, nr 256, cmd response 0x900, card status 0xb00
[   12.399154] virtio_rpmsg_bus virtio2: creating channel rpmsg-proto addr 0x50
[   12.410698] virtio_rpmsg_bus virtio0: creating channel rpmsg-proto addr 0x50
[   12.421984] virtio_rpmsg_bus virtio1: creating channel rpmsg-proto addr 0x50
[   12.439350] mmc0: tried to reset card
[  OK  ] Started Permit User Sessions.
[   12.487675] NET: Registered protocol family 41
[   12.548742] net eth1: initializing cpsw version 1.15 (0)
[  OK  ] Started Network Service.
[   12.559853] net eth0: initialized cpsw ale version 1.4
[   12.569986] net eth0: ALE Table size 1024
[   12.577128] libphy: PHY 48485000.mdio:03 not found
[   12582018] net eth1: phy "48485000.mdio:03" not found on slave 1, err -19
[  OK  ] Started rc.pvr.service.[   12.596077] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
[   12.605469] net eth0: initializing cpsw version 1.15 (0)
[   12.621360] net eth0: phy found : id is : 0x20005c7a
[   12.631715] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[  OK  ] Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
         Starting weston.service...
[  OK  ] Reached target Network.
[   13.372859] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xbbc60018 follows the erroneous one
[   13.382871] mmcblk0: error -84 transferring data, sector 13682744, nr 136, cmd response 0x900, card status 0xb00
         Starting Network Name Resolution...
[  OK  ] Started Serial Getty on ttyS0.
[  OK  ] Started Getty on tty1.
[   13.459379] mmc0: tried to reset card
[   13.470129] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xbbc60010 follows the erroneous one
[   13.480571] mmcblk0: error -84 transferring data, sector 9291168, nr 136, cmd response 0x900, card status 0xb00
[  OK  ] Started weston.service.
[  OK  ] Started Login Service.
[   13.549253] mmc0: tried to reset card
[   13.567146] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xbbc60018 follows the erroneous one
[   13.576488] mmcblk0: error -84 transferring data, sector 13866488, nr 256, cmd response 0x900, card status 0xb00
         Starting tiipclad-daemon.service...
         Starting telnetd.service...
[   13.649308] mmc0: tried to reset card
[  OK  ] Started telnetd.service.
[   13.701527] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xbbc60078 follows the erroneous one
[   13.710844] mmcblk0: error -84 transferring data, sector 13682528, nr 216, cmd response 0x900, card status 0xb00
[   13.799233] mmc0: tried to reset card
[  OK  ] Started Network Name Resolution.
[  OK  ] Started tiipclad-daemon.service.
[   13.880381] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xbbc60020 follows the erroneous one
[   13.889783] mmcblk0: error -84 transferring data, sector 13855624, nr 256, cmd response 0x900, card status 0xb00
[   13.959211] mmc0: tried to reset card
[   13.978813] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xbbc60058 follows the erroneous one
[   13.988042] mmcblk0: error -84 transferring data, sector 13672360, nr 208, cmd response 0x900, card status 0xb00
[   14.059228] mmc0: tried to reset card
[   14.157569] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xbbc60010 follows the erroneous one
[   14.166870] mmcblk0: error -84 transferring data, sector 13666328, nr 144, cmd response 0x900, card status 0xb00
[   14.239250] mmc0: tried to reset card
[   14.315488] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xbbc60008 follows the erroneous one
[   14.324984] mmcblk0: error -84 transferring data, sector 13866296, nr 136, cmd response 0x900, card status 0xb00
[   14.399224] mmc0: tried to reset card
[   14.454141] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xbbc60010 follows the erroneous one
[   14.463411] mmcblk0: error -84 transferring data, sector 13861520, nr 104, cmd response 0x900, card status 0xb00
[   14.539213] mmc0: tried to reset card
[   14.551333] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xbbc60028 follows the erroneous one
[   14.560577] mmcblk0: error -84 transferring data, sector 13862184, nr 152, cmd response 0x900, card status 0xb00
[   14.629224] mmc0: tried to reset card
[   14.716706] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xbbc60008 follows the erroneous one
[   14.726027] mmcblk0: error -84 transferring data, sector 14035344, nr 256, cmd response 0x900, card status 0xb00
[   14.799224] mmc0: tried to reset card
 _____                    _____           _         _
|  _  |___ ___ ___ ___   |  _  |___ ___  |_|___ ___| |_
|     |  _| .'| . | . |  |   __|  _| . | | | -_|  _|  _|
|__|__|_| |__,|_  |___|  |__|  |_| |___|_| |___|___|_|
              |___|                    |___|
Arago Project http://arago-project.org dra7xx-evm ttyS0
Arago 2016.12 dra7xx-evm ttyS0
dra7xx-evm login: root
[   43.967877] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xbbc60038 follows the erroneous one
[   43.977158] mmcblk0: error -84 transferring data, sector 9283288, nr 136, cmd response 0x900, card status 0xb00
[   44.049219] mmc0: tried to reset card
^[[56;237Rroot@dra7xx-evm:~# cd /opt/vision_sdk/
root@dra7xx-evm:/opt/vision_sdk# source vision_sdk_load.sh
[   49.628590] DMA: Module install successful, device major num = 241
[   49.634896] DRV: Module install successful
insmod: ERROR: could not load module ./bin/cmemk.ko: No such file or directory
./disableDssInterruptsOnA15.sh: line 11: COMMANDS: command not found
./disableDssInterruptsOnA15.sh: line 12: COMMANDS: command not found
./disableDssInterruptsOnA15.sh: line 13: COMMANDS: command not found
./disableDssInterruptsOnA15.sh: line 14: COMMANDS: command not found
./disableDssInterruptsOnA15.sh: line 15: COMMANDS: command not found
./disableDssInterruptsOnA15.sh: line 16: COMMANDS: command not found
./disableDssInterruptsOnA15.sh: line 17: COMMANDS: command not found
./disableDssInterruptsOnA15.sh: line 18: COMMANDS: command not found
./disableDssInterruptsOnA15.sh: line 19: COMMANDS: command not found
updated  value is
COMMANDS
        ### WARNING ###: use the following [read | write | set bit | clear bit | dump] commands at your own risk!
        No address check done, may generate:
          - bus error (invalid or not accessible <physical address>,
          - platform crash/hang (bad <value>).
            Read any OMAP memory address (register), given its <physical address> or <name> as listed in TRM.
            Write <value> at any OMAP memory address (register), given its <physical address> or <name> as listed in TRM.
            Set bit at <position> into any OMAP memory address (register), given its <physical address> or <name> as listed in TRM.
            Clear bit at <position> into any OMAP memory address (register), given its <physical address> or <name> as listed in TRM.
            Dump a range of OMAP memory addresses, from <start address> to <end address>.
            Note all addresses within given range must be valid and accessible.
        ### WARNING ###: use the following I2C [read | write] commands at your own risk!
          - I2C bus error (invalid or not accessible <physical address>,
            Read I2C register at address <addr> from I2C chip at <chip-addr> on I2C <bus>.
            Write <value> in I2C register at address <addr> from I2C chip at <chip-addr> on I2C <bus>.
Lee.
  • Hi Lee,
    Few questions,
    -1-
    Your custom board has silicon revision 1.1?
    -2-
    Is the issue seen with all SD cards?
    -3-
    Could you share the kernel dts for mmc?
    Vishal
  • Hi, Vishal!
    1. Humm.... I don't know exactly. The circuit diagram shows XC5777XGIABC.
    2. Yes. all SD cards.
    3. 8154.dra7.zip
    Lee.
  • Hi Lee,
    Please attach the dts changes you have done for your board. What you shared (dra7.dtsi) is the base dtsi file.
    You would have done some changes similar to dra7-evm.dts.
    or
    You can generate dts out of your final built dtb and share it. Use below command in kernel folder to generate dts out of dtb file.
     ./scripts/dtc/dtc -I dtb -O dts -o converted.dts <your board tb file>
    Vishal
  • Hi, Vishal.
    There was a mistake in the attached file. sorry.
    Attached is the dr7-evm.dts file modified for our board.
    dra7-evm.zip
    Lee.
  • Hi Lee,
    Can you make sure the kernel dts for mmc1 has correct values for these two properties?
    vmmc-supply: The Vdd voltage supply for the card
    vmmc_aux-supply: The Vio voltage supply for IO lines
    Vishal
  • Hi, Vishal.
    Yes. We modified it because of the difference between EVM and our board.
    Lee.
  • Is there anything special about this address on your system? - 0xbbc600xx
    Line 310: [    2.518115] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xbbc60008 follows the erroneous one
    Line 313: [    2.672974] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xbbc60008 follows the erroneous one
    Line 368:          Starting Load Kernel Modules...[    3.997660] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xbbc60020 follows the erroneous one
    Line 409:          Starting Flush Journal to Persistent Storage...[    4.994295] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xbbc60020 follows the erroneous one
    Line 434: [    5.881828] omap_hsmmc 4809c000.mmc: ADMA err: ST_STOP, desc at 0xbbc600e0 follows the erroneous one
    Line 450: [    6.123214] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xbbc60060 follows the erroneous one
    Line 455: [    6.450615] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xbbc60048 follows the erroneous one
    Line 461: [    6.723653] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xbbc60080 follows the erroneous one
    Line 464: [    6.815484] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xbbc60060 follows the erroneous one
    Line 470: [    7.131892] omap_hsmmc 4809c000.mmc: ADMA err: ST_STOP, desc at 0xbbc60040 follows the erroneous one
    Line 475: [    7.246127] omap_hsmmc 4809c000.mmc: ADMA err: ST_STOP, desc at 0xbbc60030 follows the erroneous one
    Line 478: [    7.355652] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xbbc60060 follows the erroneous one
    Line 481: [    7.469706] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xbbc60080 follows the erroneous one
    Line 485: [    7.571993] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xbbc60010 follows the erroneous one
    Line 490: [    7.741974] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xbbc60040 follows the erroneous one
    Line 493: [    7.830311] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xbbc60078 follows the erroneous one
    Line 496: [    8.047729] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xbbc60008 follows the erroneous one
    Line 499: [    8.133580] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xbbc60008 follows the erroneous one
    Line 504: [    8.324514] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xbbc60088 follows the erroneous one
    Line 509: [    8.447641] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xbbc60008 follows the erroneous one
    Line 513: [    8.581307] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xbbc60078 follows the erroneous one
    Line 519: [    8.784495] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xbbc60010 follows the erroneous one
    Line 528: [    8.916349] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xbbc60070 follows the erroneous one
    Line 531: [    9.010466] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xbbc60008 follows the erroneous one
    Line 534: [    9.096132] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xbbc60010 follows the erroneous one
    Line 537: [    9.253449] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xbbc60008 follows the erroneous one
    Line 540: [    9.347989] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xbbc60010 follows the erroneous one
    Line 544: [    9.480073] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xbbc60018 follows the erroneous one
    Line 549: [    9.568268] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xbbc60010 follows the erroneous one
    Line 554: [    9.800693] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xbbc60008 follows the erroneous one
    Line 559: [    9.919920] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xbbc60018 follows the erroneous one
    Line 563: [   10.021410] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xbbc600d0 follows the erroneous one
    Line 566: [   10.210259] omap_hsmmc 4809c000.mmc: ADMA err: ST_STOP, desc at 0xbbc60018 follows the erroneous one
    Line 571: [   10.359275] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xbbc60080 follows the erroneous one
    Line 577: [   10.477496] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xbbc60080 follows the erroneous one
    Line 580: [   10.708960] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xbbc60038 follows the erroneous one
    Line 584: [   10.838316] omap_hsmmc 4809c000.mmc: ADMA err: ST_STOP, desc at 0xbbc600d8 follows the erroneous one
    Line 587: [   10.939458] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xbbc60088 follows the erroneous one
    Line 590: [   11.441470] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xbbc60008 follows the erroneous one
    Line 593: [   11.541061] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xbbc60090 follows the erroneous one
    Line 596: [   11.713592] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xbbc60188 follows the erroneous one
    Line 599: [   11.818727] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xbbc60070 follows the erroneous one
    Line 615: [   12.052252] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xbbc60008 follows the erroneous one
    Line 625: [   12.164206] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xbbc60020 follows the erroneous one
    Line 632: [   12.344497] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xbbc60010 follows the erroneous one
    Line 654: [   13.372859] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xbbc60018 follows the erroneous one
    Line 660: [   13.470129] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xbbc60010 follows the erroneous one
    Line 665: [   13.567146] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xbbc60018 follows the erroneous one
    Line 671: [   13.701527] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xbbc60078 follows the erroneous one
    Line 676: [   13.880381] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xbbc60020 follows the erroneous one
    Line 679: [   13.978813] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xbbc60058 follows the erroneous one
    Line 682: [   14.157569] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xbbc60010 follows the erroneous one
    Line 685: [   14.315488] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xbbc60008 follows the erroneous one
    Line 688: [   14.454141] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xbbc60010 follows the erroneous one
    Line 691: [   14.551333] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xbbc60028 follows the erroneous one
    Line 694: [   14.716706] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xbbc60008 follows the erroneous one
    Line 709: [   43.967877] omap_hsmmc 4809c000.mmc: ADMA err: ST_TFR, desc at 0xbbc60038 follows the erroneous one
