AM5728: About Board_Init() for DSP
Part Number: AM5728
Hi experts,
Does the DSP need to call Board_Init?
I believe that if ARM calls Board_Init and does the necessary initialization, the DSP does not need to call Board_Init.
I have tested the following two projects with EVM.
  • GPIO_LedBlink_evmAM572x_armTestProject
  • GPIO_LedBlink_evmAM572x_c66xTestProject
In the default project, both ARM and DSP call Board_Init. And if I use this default project, the ARM and DSP can control the GPIO.
I figured the DSP didn't need Board_Init, so I commented out the Board_Init for this default DSP project and tested it again.
But I can't control the GPIOs from the DSP. The two projects I used in this case are as follows.
  • GPIO_LedBlink_evmAM572x_armTestProject  → default setting
  • GPIO_LedBlink_evmAM572x_c66xTestProject → commented out the Board_Init()
Do I need Board_Init for the DSP to control the GPIOs? If this is necessary, I would like to know why it is necessary.
Sasaki
  • Hi Sasaki,
    AM572 board lib has C6x specific pinmuxes and pad delays
    See the log below
    :~/ti/pdk/packages/ti/board/src/idkAM572x$ grep C6X . -Isr
    ./iodelay_config.h:#if defined(_TMS320C6X) || defined(__TI_ARM_V7M4__)
    ./iodelay_config.c:#if defined(_TMS320C6X) || defined(__TI_ARM_V7M4__)
    ./boardPadDelay.h:#if defined(_TMS320C6X) || defined(__TI_ARM_V7M4__)
    ./boardPadDelayInit.c:#if defined(_TMS320C6X) || defined(__TI_ARM_V7M4__)
    ./boardPadDelayDevice.c:#if defined(_TMS320C6X) || defined(__TI_ARM_V7M4__)
    ./idkAM572x_pinmux.c:#if defined(_TMS320C6X)
    ./idkAM572x_lld_init.c:#if defined (_TMS320C6X)
    It's probably why you need to call Board_init() from DSP.
    Vineet
  • Hi Vineet-san,
    Thank you for your reply.
    The problem was Uart_Printf().
    When I commented out the Uart_Printf() line in the DSP side, it worked fine without calling Boart_Init().
    Sasaki
