AM3352: Pinmux configuration file for AM335xGP-EVM
Part Number: AM3352
Hello team,
Our customer is developing their system with PROCESSOR-SDK-LINUX-AM335X and they are looking for Pinmux configuration files for AM335xGP-EVM and AM437xEVM
Could you elaborate them, please?
I tried to look into them in the following URL, but, I'm not sure if it is correct/enough or not. There is possibility that dts file also configures pinmux configuration.
https://software-dl.ti.com/processor-sdk-linux/esd/docs/06_03_00_106/linux/Foundational_Components/Tools/Pin_Mux_Tools.html?highlight=pinmux
https://software-dl.ti.com/processor-sdk-linux/esd/docs/06_03_00_106/linux/Foundational_Components_U-Boot.html#u-boot-user-s-guide
u-boot-2019.01xxx\board\ti\am335x
u-boot-2019.01xxx\board\ti\am43xx
it will be really appreciated if you share Expert's comments.
best regards,
Miyazaki
  • Hello Miyazaki,
    The pinmux header and C files can be found in this starterware folder of PDK:
    ${PDK_INSTALL_DIR}\packages\ti\starterware\board\${SOC}\
    The .pinmux configuration files are found in another starterware folder here:
    ${PDK_INSTALL_DIR}\packages\ti\starterware\tools\pinmux_config\${SOC}\
    Upon loading the .pinmux file to SysConfig, the necessary .h, .c, and .dtsi files will generated by the SysConfig Tool.
    Let us know if you or customer have any further questions.
  • Hello Zackary,
    Thanks for your comments. I’m not sure the current Linux-SDK includes STARTERWARE-AM335X, however, I will share this information with customer. I’d like to wait for customer’s feedback for a while.
    Best regards, Miyazaki
  • Hello Miyazaki,
    You are correct, the answers I gave above are for the RTOS-SDK.
    For the Linux SDK, the .pinmux files can be found here:
    ${PDK_INSTALL_DIR}\packages\ti\board\src\${SOC}\
    Hope this helps.
  • Hi Zackary,
    Thank you for your comments. Since customer is using Linux SDK, I share this correct path information with customer. I believe customer already noticed it.
    best regards, Miyazaki
