HI
Can I make a connection between two C6455s with PCI interface directly? I am not sure about the electrical connection. Does it will works if i link the two devices with each pins of PCI modules. Morevoer, I noticed some terminations are input or output including PIDEL, PCLK, PREQ.ect. How to deal with these pins?
Brance
Brance,
The C6455 is a very old device that no longer has support for new designs. We recommend that you use a newer DSP like the C665x which support PCIe that can be easily connected as they can be configured as either a root complex or an endpoint. Alternately, the line of Sitara devices (https://www.ti.com/processors/sitara-arm/overview.html) containing both an ARM and DSP have robust software and design support.
Tom
