Compiler/TDA4VM: Where can I download the gcc related toolchains?
Part Number: TDA4VM
ti experts:
I tred to compile vision_apps for linux+rtos,I got error below.Could you pls show me a website which lists all the toolchains needed?
BUILD_DEFS = CUSTOM_KERNEL_PATH BUILD_TUTORIAL BUILD_CONFORMANCE_TEST
J7_LINUX_A72_1_release_GCC_LINUX_ARM_DEFS = LINUX J7 A72="A72" TARGET_NUM_CORES=1 TARGET_ARCH=64 ARCH_64 ARM TARGET_BUILD=1
J7_LINUX_A72_1_release_GCC_LINUX_ARM_LDIRS =
SCM_ROOT=
SCM_VERSION=
Build Skipped for kernels.stereo.target.bam.J7.LINUX.A72.release:vx_target_kernels_stereo_bam
ERROR: /home/tommy/J7/ra_7_0/sdk/psdk_rtos_auto_j7_07_00_00_11/gcc-arm-9.2-2019.12-x86_64-aarch64-none-elf not found !!!
makerules/makefile_check_paths.mak:7: recipe for target 'sdk_check_paths' failed
make: *** [sdk_check_paths] Error 1
