Part Number: TDA2PXEVM
Why metadata to DSP link is to be passed from NullSRC link?Can we read SD card directly in DSP core?
I got an error like this
SYSTEM: IPC: [DSP1] Notify recvfrom failed (Link has been severed, 67) !!!
[HOST] [HOST ] 148.767004 s: SYSTEM: IPC: [DSP1] Notify recvfrom failed (Link has been severed, 67) !!!
[HOST] [HOST ] 148.767034 s: SYSTEM: IPC: [DSP1] Notify recvfrom failed (Link has been severed, 67) !!!
[HOST] [HOST ] 148.767065 s: SYSTEM: IPC: [DSP1] Notify recvfrom failed (Link has been severed, 67) !!!
The SurroundView application is running in DSP core. In the algorithm an xml file has to read from the SD card.
Everything was working fine before having this xml read in DSP core. Got this error when tried to read xml file from SD card for the code running in DSP core.
Below one is the usecase:
UseCase: chains_nullSrc_Display
NullSource (A15) -> Decode -> VPE -> Sync (A15) -> Alg_SurroundView3d (DSP1) -> SgxCarDisplay (A15)
SgxCarDisplay -> Display_M4 (IPU1_0)
In "Alg_SurroundView3d" xml read is to be done.
SDK version 03.07.00.00
GrpxSrc -> Display_Grpx
I'm closing this thread because it's duplicated
https://e2e.ti.com/support/processors/f/791/t/927163
Gaviraju
