I am using the dvsdk_2_10_01_18 with DM365 resize test. But when excute error occured(See source and output) .
What is the problem?
#source
Int main(Int argc, Char *argv[])
BufferGfx_Attrs gfxAttrs = BufferGfx_Attrs_DEFAULT;
Resize_Attrs rszAttrs = Resize_Attrs_DEFAULT;
Buffer_Handle hInBuf, hOutBuf;
Resize_Handle hResize;
Int32 bufSize;
ColorSpace_Type IncolorSpace = ColorSpace_YUV420PSEMI
ColorSpace_Type OutcolorSpace = ColorSpace_YUV420PSEMI
CERuntime_init();
Dmai_init();
Dmai_setLogLevel(Dmai_LogLevel_All);
//in buffer
gfxAttrs.dim.x = 0;
gfxAttrs.dim.y = 0;
gfxAttrs.dim.width = 640;
gfxAttrs.dim.height = 352;
gfxAttrs.dim.lineLength = ((Int32)((BufferGfx_calcLineLength(gfxAttrs.dim.width, IncolorSpace)+31)/32))*32;
if (IncolorSpace == ColorSpace_YUV420PSEMI)
bufSize = gfxAttrs.dim.lineLength * gfxAttrs.dim.height * 3 / 2;
else
bufSize = gfxAttrs.dim.lineLength * gfxAttrs.dim.height * 2;
gfxAttrs.colorSpace = IncolorSpace;
hInBuf = Buffer_create(bufSize, BufferGfx_getBufferAttrs(&gfxAttrs));
//out buffer
gfxAttrs.dim.x = 0;
gfxAttrs.dim.y = 0;
gfxAttrs.dim.width = 1280;
gfxAttrs.dim.height = 720;
gfxAttrs.dim.lineLength = ((Int32)((BufferGfx_calcLineLength(gfxAttrs.dim.width, OutcolorSpace)+31)/32))*32;
if (OutcolorSpace == ColorSpace_YUV420PSEMI)
else
gfxAttrs.colorSpace = OutcolorSpace;
hOutBuf = Buffer_create(bufSize, BufferGfx_getBufferAttrs(&gfxAttrs));
hResize = Resize_create(&rszAttrs);
if (hResize==NULL)
printf("Resize_create failed\n");
return -1;
if (Resize_config(hResize, hInBuf, hOutBuf)!=Dmai_EOK)
printf("Resize_config failed\n");
return -1;
// Fill hInBuf with video data
if (Resize_execute(hResize, hInBuf, hOutBuf)!=Dmai_EOK)
printf("Resize_execute failed\n");
return -1;
Resize_delete(hResize);
Buffer_delete(hInBuf);
Buffer_delete(hOutBuf);
#output
[ipipe_set_resize_config()] oper_mode = 1
@0x000aa35f:[T:0davinci_resizer davinci_resizer.2: RSZ_G_CONFIG:1:0:176
x40020af0] ti.sd[ipipe_set_resize_config()] oper_mode = 1
o.dmai - [Dmai] davinci_resizer davinci_resizer.2: rsz_validate_out_pix_formatspix format not supported, 9
Log level set todavinci_resizer davinci_resizer.2: set resizer config failed
2.
@0x000aaac1:[T:0x40020af0] ti.sdo.dmai - [Buffer] Alloc Buffer of size 1382400 at 0x403ca000 (0x871d6000 phys)
@0x000aacf8:[T:0x40020af0] ti.sdo.dmai - [Buffer] Alloc Buffer of size 1382400 at 0x40544000 (0x8705c000 phys)
@0x000aaf07:[T:0x40020af0] ti.sdo.dmai - [Buffer] Alloc Buffer of size 1382400 at 0x406be000 (0x86ee2000 phys)
@0x000b2db6:[T:0x40020af0] ti.sdo.dmai - [Resize] Error in setting default configuration for single shot mode 2nd
