Part Number: PROCESSOR-SDK-DRA8X-TDA4X
Hi Champs,
* SDK : ti-processor-sdk-linux-automotive-j7-evm-07_00_01
* Build guide : https://software-dl.ti.com/jacinto7/esd/processor-sdk-linux-jacinto7/latest/exports/docs/linux/Overview_Building_the_SDK.html
* Host : Ubuntu (20.04) on Virtual Box
When doing yocto build ($ TOOLCHAIN_BASE=/home/user/toolchains MACHINE=j7-evm bitbake -k tisdk-default-image), it takes too long time.
As below attached build log, it almost stopped at 25% progress.
Can you provide guide how to finish the build?
* build log file -
user@ubuntu20:~$ export INSTALL_DIR=${HOME}/ti-processor-sdk-linux-automotive-j7-evm-07_00_01
user@ubuntu20:~$ cd $INSTALL_DIR
user@ubuntu20:~/ti-processor-sdk-linux-automotive-j7-evm-07_00_01$ cd ./yocto-build
user@ubuntu20:~/ti-processor-sdk-linux-automotive-j7-evm-07_00_01/yocto-build$ ./oe-layertool-setup.sh -f configs/psdkla/psdkla-07_00_01.txt
/home/user/ti-processor-sdk-linux-automotive-j7-evm-07_00_01/yocto-build
cloning repo bitbake
Fetching origin
Previous HEAD position was 6cc09fa3 toaster-requirements.txt: require Django 2.2
Switched to branch '1.46'
Your branch is up to date with 'origin/1.46'.
Already up to date.
Note: switching to '6cc09fa33131f71a3fd0e336ff07a4186b41bf8f'.
You are in 'detached HEAD' state. You can look around, make experimental
changes and commit them, and you can discard any commits you make in this
state without impacting any branches by switching back to a branch.
If you want to create a new branch to retain commits you create, you may
do so (now or later) by using -c with the switch command. Example:
git switch -c <new-branch-name>
Or undo this operation with:
git switch -
Turn off this advice by setting config variable advice.detachedHead to false
HEAD is now at 6cc09fa3 toaster-requirements.txt: require Django 2.2
cloning repo meta-arago
Fetching origin
Previous HEAD position was 41cfd83e voxelsdk: deprecated, remove
Switched to branch 'dunfell'
Your branch is up to date with 'origin/dunfell'.
Already up to date.
Note: switching to '07.00.00.005'.
git switch -
HEAD is now at 41cfd83e voxelsdk: deprecated, remove
cloning repo meta-qt5
Fetching origin
Previous HEAD position was fdd1951 qt5-ptest: give rwx permission to user for all the test files
Already up to date.
Note: switching to 'fdd19517e17240b0b61765bd02fc483a1bde986f'.
git switch -
HEAD is now at fdd1951 qt5-ptest: give rwx permission to user for all the test files
cloning repo meta-virtualization
Fetching origin
Previous HEAD position was 237879d libvirt: fix patch fuzz warning
Already up to date.
Note: switching to '237879d59e11187a49216a88b73a057408e4b3f7'.
git switch -
HEAD is now at 237879d libvirt: fix patch fuzz warning
cloning repo meta-openembedded
Fetching origin
remote: Counting objects: 159, done.
remote: Compressing objects: 100% (95/95), done.
remote: Total 159 (delta 105), reused 105 (delta 63)
Receiving objects: 100% (159/159), 29.53 KiB | 132.00 KiB/s, done.
Resolving deltas: 100% (105/105), completed with 9 local objects.
From git://git.openembedded.org/meta-openembedded
cc6fc6b16..654ad8bea dunfell -> origin/dunfell
f6438269e..2dc11218e master -> origin/master
+ 04aba46dd...20e1134fc master-next -> origin/master-next (forced update)
Previous HEAD position was e413c1ef6 samba: upgrade 4.10.13 -> 4.10.15
Your branch is behind 'origin/dunfell' by 21 commits, and can be fast-forwarded.
(use "git pull" to update your local branch)
Updating cc6fc6b16..654ad8bea
Fast-forward
meta-gnome/recipes-gnome/tracker/tracker-miners_2.3.3.bb | 4 +
meta-gnome/recipes-support/ibus/ibus.inc | 4 +-
.../recipes-connectivity/blueman/{blueman_2.1.1.bb => blueman_2.1.3.bb} | 3 +-
.../recipes-filter/nftables/{nftables_0.9.5.bb => nftables_0.9.6.bb} | 2 +-
.../freediameter/files/0001-Fix-testcnx-expired-CA-data.patch | 746 ++++++++++++++++++++++++++++++++++
meta-networking/recipes-protocols/freediameter/freediameter_1.3.2.bb | 1 +
meta-networking/recipes-protocols/net-snmp/net-snmp/CVE-2019-20892.patch | 118 ++++++
meta-networking/recipes-protocols/net-snmp/net-snmp_5.8.bb | 1 +
meta-networking/recipes-support/drbd/drbd-utils_9.12.0.bb | 2 +
.../recipes-support/wireshark/{wireshark_3.2.4.bb => wireshark_3.2.5.bb} | 3 +-
.../modemmanager/{modemmanager_1.12.10.bb => modemmanager_1.12.12.bb} | 7 +-
meta-oe/recipes-connectivity/paho-mqtt-c/paho-mqtt-c_1.3.2.bb | 4 +
meta-oe/recipes-crypto/libmcrypt/libmcrypt_2.5.8.bb | 2 +
meta-oe/recipes-devtools/jsoncpp/{jsoncpp_1.9.3.bb => jsoncpp_1.9.2.bb} | 4 +-
meta-oe/recipes-extended/mraa/mraa_git.bb | 2 +-
meta-oe/recipes-extended/upm/upm_git.bb | 4 +
meta-oe/recipes-kernel/minicoredumper/minicoredumper_2.0.1.bb | 2 +-
meta-oe/recipes-support/multipath-tools/multipath-tools_0.8.4.bb | 1 +
.../nss/0001-Bug-1631576-Force-a-fixed-length-for-DSA-exponentiat.patch | 110 +++++
meta-oe/recipes-support/nss/nss_3.51.1.bb | 5 +
meta-oe/recipes-support/openldap/openldap_2.4.50.bb | 4 +-
meta-python/recipes-devtools/python/python3-redis_2.10.6.bb | 1 +
22 files changed, 1013 insertions(+), 17 deletions(-)
rename meta-networking/recipes-connectivity/blueman/{blueman_2.1.1.bb => blueman_2.1.3.bb} (94%)
rename meta-networking/recipes-filter/nftables/{nftables_0.9.5.bb => nftables_0.9.6.bb} (93%)
create mode 100644 meta-networking/recipes-protocols/freediameter/files/0001-Fix-testcnx-expired-CA-data.patch
create mode 100644 meta-networking/recipes-protocols/net-snmp/net-snmp/CVE-2019-20892.patch
rename meta-networking/recipes-support/wireshark/{wireshark_3.2.4.bb => wireshark_3.2.5.bb} (95%)
rename meta-oe/recipes-connectivity/modemmanager/{modemmanager_1.12.10.bb => modemmanager_1.12.12.bb} (93%)
rename meta-oe/recipes-devtools/jsoncpp/{jsoncpp_1.9.3.bb => jsoncpp_1.9.2.bb} (92%)
create mode 100644 meta-oe/recipes-support/nss/nss/0001-Bug-1631576-Force-a-fixed-length-for-DSA-exponentiat.patch
Note: switching to 'e413c1ef621688e69bb7830bb3151ed23b30b73e'.
git switch -
HEAD is now at e413c1ef6 samba: upgrade 4.10.13 -> 4.10.15
cloning repo meta-ti
Fetching origin
Previous HEAD position was f2b2b209 common-csl-ip: update to 07.00.00.34
Already up to date.
git switch -
HEAD is now at f2b2b209 common-csl-ip: update to 07.00.00.34
cloning repo meta-arm
Fetching origin
remote: Enumerating objects: 50, done.
remote: Counting objects: 100% (50/50), done.
remote: Compressing objects: 100% (32/32), done.
remote: Total 33 (delta 23), reused 0 (delta 0)
Unpacking objects: 100% (33/33), 3.68 KiB | 163.00 KiB/s, done.
From git://git.yoctoproject.org/meta-arm
1c125f2..5ac42f2 master -> origin/master
Previous HEAD position was f8ea9ac arm-toolchain: set CVE_VERSION to fix cve-check warnings
Already up to date.
Note: switching to 'f8ea9ac3a06f543bd3dc259ffc1b60eb197a132d'.
git switch -
Fetching origin
Already up to date.
git switch -
HEAD is now at f8ea9ac arm-toolchain: set CVE_VERSION to fix cve-check warnings
cloning repo oe-core
Fetching origin
remote: Counting objects: 52, done.
remote: Compressing objects: 100% (47/47), done.
remote: Total 52 (delta 38), reused 4 (delta 3)
Unpacking objects: 100% (52/52), 8.08 KiB | 129.00 KiB/s, done.
From git://git.openembedded.org/openembedded-core
fe3d5136ef..e0657ff134 master -> origin/master
+ dca821768c...a12290bb5b master-next -> origin/master-next (forced update)
error: Your local changes to the following files would be overwritten by checkout:
meta/recipes-support/iso-codes/iso-codes_4.4.bb
Please commit your changes or stash them before you switch branches.
Aborting
Updating c88cf750f2..257758f175
error: Your local changes to the following files would be overwritten by merge:
Please commit your changes or stash them before you merge.
Aborting
M meta/recipes-support/iso-codes/iso-codes_4.4.bb
HEAD is now at c88cf750f2 avahi: Don't advertise example services by default
cloning repo meta-psdkla
Fetching origin
Previous HEAD position was d81cf4a images: arago-core-psdkla-bundle: Fix errors with am65xx-evm build
Switched to branch 'master'
Your branch is up to date with 'origin/master'.
Already up to date.
Note: switching to 'd81cf4a3dc12d918086cdec9b5833b24e6afd9d6'.
git switch -
HEAD is now at d81cf4a images: arago-core-psdkla-bundle: Fix errors with am65xx-evm build
cloning repo meta-aws
Fetching origin
Already up to date.
Note: switching to '481c8793caf861b97415156c69dc4767f92e9c8f'.
git switch -
HEAD is now at 481c879 remove optional components from the greengrass recipes that cause large footprint
The bblayers.conf configuration file has been created for you with some
default values. Please verify the contents of your conf/bblayers.conf
file for correctness.
NOTE: Any additional entries to this file will be lost if the ./oe-layertool-setup.sh
script is run again. To add entries permanently to this file
please add them to the config file used and rerun the
./oe-layertool-setup.sh script.
The local.conf configuration file has been created for you with some
default values. Please verify the contents of your conf/local.conf
By default the number of threads used by the build is set to the number
of CPUs found on your system.
NOTE: You will probably want to change the default MACHINE setting in the
local.conf file to the machine you are trying to build.
WARNING: Found existing /home/user/ti-processor-sdk-linux-automotive-j7-evm-07_00_01/yocto-build/build/conf/local.conf
Saving a backup to /home/user/ti-processor-sdk-linux-automotive-j7-evm-07_00_01/yocto-build/build/conf/local.conf.bak
A setenv file has been created for you in the conf directory. Please verify
The contents of this file. Once you have verified the contents please source
this file to configure your environment for building:
. conf/setenv
You can then start building using the bitbake command. You will likely want
to set the MACHINE option if you have not done so in your local.conf file.
For example:
MACHINE=xxxxx bitbake <target>
Common targets are:
core-image-minimal
core-image-sato
meta-toolchain
meta-toolchain-sdk
adt-installer
meta-ide-support
user@ubuntu20:~/ti-processor-sdk-linux-automotive-j7-evm-07_00_01/yocto-build$ cd build
user@ubuntu20:~/ti-processor-sdk-linux-automotive-j7-evm-07_00_01/yocto-build/build$ echo "INHERIT += \"own-mirrors\"" >> conf/local.conf
user@ubuntu20:~/ti-processor-sdk-linux-automotive-j7-evm-07_00_01/yocto-build/build$ echo "SOURCE_MIRROR_URL = \"https://software-dl.ti.com/processor-sdk-mirror/sources/\"" >> conf/local.conf
user@ubuntu20:~/ti-processor-sdk-linux-automotive-j7-evm-07_00_01/yocto-build/build$ echo "ARAGO_BRAND = \"psdkla\"" >> conf/local.conf
user@ubuntu20:~/ti-processor-sdk-linux-automotive-j7-evm-07_00_01/yocto-build/build$ echo "DISTRO_FEATURES_append = \" virtualization\"" >> conf/local.conf
user@ubuntu20:~/ti-processor-sdk-linux-automotive-j7-evm-07_00_01/yocto-build/build$ echo "IMAGE_INSTALL_append = \" docker\"" >> conf/local.conf
user@ubuntu20:~/ti-processor-sdk-linux-automotive-j7-evm-07_00_01/yocto-build/build$ . conf/setenv
user@ubuntu20:~/ti-processor-sdk-linux-automotive-j7-evm-07_00_01/yocto-build/build$ TOOLCHAIN_BASE=/home/user/toolchains MACHINE=j7-evm bitbake -k tisdk-default-image
WARNING: Layer meta-psdkla should set LAYERSERIES_COMPAT_meta-psdkla in its conf/layer.conf file to list the core layer names it is compatible with.
NOTE: Your conf/bblayers.conf has been automatically updated.
NOTE: Started PRServer with DBfile: /home/user/ti-processor-sdk-linux-automotive-j7-evm-07_00_01/yocto-build/build/cache/prserv.sqlite3, IP: 127.0.0.1, PORT: 45839, PID: 2769
Loading cache: 100% |###############################################################################| Time: 0:00:03
Loaded 8134 entries from dependency cache.
WARNING: /home/user/ti-processor-sdk-linux-automotive-j7-evm-07_00_01/yocto-build/sources/meta-arago/meta-arago-distro/recipes-graphics/wayland/wayland-ivi-extension_2.2.0.bb: Unable to get checksum for wayland-ivi-extension SRC_URI entry 03-ivi-id-agent-update-dependencies-to-build-on-weston-7.patch: file could not be found
Parsing recipes: 100% |#############################################################################| Time: 0:00:15
Parsing of 2885 .bb files complete (2758 cached, 127 parsed). 8136 targets, 1176 skipped, 0 masked, 0 errors.
WARNING: No recipes available for:
/home/user/ti-processor-sdk-linux-automotive-j7-evm-07_00_01/yocto-build/sources/meta-arago/meta-arago-distro/recipes-browser/chromium/chromium-ozone-wayland_%.bbappend
/home/user/ti-processor-sdk-linux-automotive-j7-evm-07_00_01/yocto-build/sources/meta-arago/meta-arago-distro/recipes-connectivity/iproute2/iproute2_4.19.0.bbappend
/home/user/ti-processor-sdk-linux-automotive-j7-evm-07_00_01/yocto-build/sources/meta-arago/meta-arago-distro/recipes-support/opencv/opencv_3.1.bbappend
NOTE: Resolving any missing task queue dependencies
Build Configuration:
BB_VERSION = "1.46.0"
BUILD_SYS = "x86_64-linux"
NATIVELSBSTRING = "ubuntu-20.04"
TARGET_SYS = "aarch64-linux"
MACHINE = "j7-evm"
DISTRO = "arago"
DISTRO_VERSION = "2020.05"
TUNE_FEATURES = "aarch64"
TARGET_FPU = ""
meta-arago-distro
meta-arago-extras = "HEAD:41cfd83e13955178bffae84ebbe5a915b79181fd"
meta-qt5 = "HEAD:fdd19517e17240b0b61765bd02fc483a1bde986f"
meta-virtualization = "HEAD:237879d59e11187a49216a88b73a057408e4b3f7"
meta-networking
meta-python
meta-oe
meta-gnome
meta-filesystems = "HEAD:e413c1ef621688e69bb7830bb3151ed23b30b73e"
meta-ti = "HEAD:f2b2b2095f1a9d3ef705f7518d9db1e3141da2fb"
meta-arm
meta-arm-toolchain = "HEAD:f8ea9ac3a06f543bd3dc259ffc1b60eb197a132d"
meta = "HEAD:c88cf750f26f6786d6ba5b4f1f7e5d4f0c800e6e"
meta-psdkla = "HEAD:d81cf4a3dc12d918086cdec9b5833b24e6afd9d6"
meta-aws = "HEAD:481c8793caf861b97415156c69dc4767f92e9c8f"
TARGET_SYS = "arm-linux-gnueabi"
MACHINE = "j7-evm-k3r5"
DISTRO = "arago"
TUNE_FEATURES = "arm armv7a vfp thumb callconvention-hard"
TARGET_FPU = "hard"
meta-arago-distro
meta-networking
meta-python
meta-oe
meta-gnome
meta-arm
Initialising tasks: 100% |##########################################################################| Time: 0:00:08
Sstate summary: Wanted 2891 Found 0 Missed 2891 Current 0 (0% match, 0% complete)
NOTE: Deferring mc:k3r5:/home/user/ti-processor-sdk-linux-automotive-j7-evm-07_00_01/yocto-build/sources/oe-core/meta/recipes-core/gettext/gettext-minimal-native_0.20.1.bb:do_populate_lic after /home/user/ti-processor-sdk-linux-automotive-j7-evm-07_00_01/yocto-build/sources/oe-core/meta/recipes-core/gettext/gettext-minimal-native_0.20.1.bb:do_populate_lic
NOTE: Deferring mc:k3r5:/home/user/ti-processor-sdk-linux-automotive-j7-evm-07_00_01/yocto-build/sources/oe-core/meta/recipes-core/gettext/gettext-minimal-native_0.20.1.bb:do_populate_sysroot after /home/user/ti-processor-sdk-linux-automotive-j7-evm-07_00_01/yocto-build/sources/oe-core/meta/recipes-core/gettext/gettext-minimal-native_0.20.1.bb:do_populate_sysroot
NOTE: Deferring mc:k3r5:/home/user/ti-processor-sdk-linux-automotive-j7-evm-07_00_01/yocto-build/sources/oe-core/meta/recipes-devtools/libtool/libtool-native_2.4.6.bb:do_populate_lic after /home/user/ti-processor-sdk-linux-automotive-j7-evm-07_00_01/yocto-build/sources/oe-core/meta/recipes-devtools/libtool/libtool-native_2.4.6.bb:do_populate_lic
NOTE: Deferring mc:k3r5:/home/user/ti-processor-sdk-linux-automotive-j7-evm-07_00_01/yocto-build/sources/oe-core/meta/recipes-devtools/libtool/libtool-native_2.4.6.bb:do_populate_sysroot after /home/user/ti-processor-sdk-linux-automotive-j7-evm-07_00_01/yocto-build/sources/oe-core/meta/recipes-devtools/libtool/libtool-native_2.4.6.bb:do_populate_sysroot
NOTE: Deferring mc:k3r5:/home/user/ti-processor-sdk-linux-automotive-j7-evm-07_00_01/yocto-build/sources/oe-core/meta/recipes-devtools/m4/m4-native_1.4.18.bb:do_populate_lic after /home/user/ti-processor-sdk-linux-automotive-j7-evm-07_00_01/yocto-build/sources/oe-core/meta/recipes-devtools/m4/m4-native_1.4.18.bb:do_populate_lic
NOTE: Deferring mc:k3r5:/home/user/ti-processor-sdk-linux-automotive-j7-evm-07_00_01/yocto-build/sources/oe-core/meta/recipes-devtools/m4/m4-native_1.4.18.bb:do_populate_sysroot after /home/user/ti-processor-sdk-linux-automotive-j7-evm-07_00_01/yocto-build/sources/oe-core/meta/recipes-devtools/m4/m4-native_1.4.18.bb:do_populate_sysroot
NOTE: Deferring mc:k3r5:/home/user/ti-processor-sdk-linux-automotive-j7-evm-07_00_01/yocto-build/sources/oe-core/meta/recipes-devtools/quilt/quilt-native_0.66.bb:do_populate_lic after /home/user/ti-processor-sdk-linux-automotive-j7-evm-07_00_01/yocto-build/sources/oe-core/meta/recipes-devtools/quilt/quilt-native_0.66.bb:do_populate_lic
NOTE: Deferring mc:k3r5:/home/user/ti-processor-sdk-linux-automotive-j7-evm-07_00_01/yocto-build/sources/oe-core/meta/recipes-devtools/quilt/quilt-native_0.66.bb:do_populate_sysroot after /home/user/ti-processor-sdk-linux-automotive-j7-evm-07_00_01/yocto-build/sources/oe-core/meta/recipes-devtools/quilt/quilt-native_0.66.bb:do_populate_sysroot
NOTE: Deferring mc:k3r5:/home/user/ti-processor-sdk-linux-automotive-j7-evm-07_00_01/yocto-build/sources/oe-core/meta/recipes-extended/texinfo-dummy-native/texinfo-dummy-native.bb:do_populate_lic after /home/user/ti-processor-sdk-linux-automotive-j7-evm-07_00_01/yocto-build/sources/oe-core/meta/recipes-extended/texinfo-dummy-native/texinfo-dummy-native.bb:do_populate_lic
NOTE: Deferring mc:k3r5:/home/user/ti-processor-sdk-linux-automotive-j7-evm-07_00_01/yocto-build/sources/oe-core/meta/recipes-extended/texinfo-dummy-native/texinfo-dummy-native.bb:do_populate_sysroot after /home/user/ti-processor-sdk-linux-automotive-j7-evm-07_00_01/yocto-build/sources/oe-core/meta/recipes-extended/texinfo-dummy-native/texinfo-dummy-native.bb:do_populate_sysroot
NOTE: Deferring mc:k3r5:/home/user/ti-processor-sdk-linux-automotive-j7-evm-07_00_01/yocto-build/sources/oe-core/meta/recipes-kernel/kern-tools/kern-tools-native_git.bb:do_populate_lic after /home/user/ti-processor-sdk-linux-automotive-j7-evm-07_00_01/yocto-build/sources/oe-core/meta/recipes-kernel/kern-tools/kern-tools-native_git.bb:do_populate_lic
NOTE: Deferring mc:k3r5:/home/user/ti-processor-sdk-linux-automotive-j7-evm-07_00_01/yocto-build/sources/oe-core/meta/recipes-kernel/kern-tools/kern-tools-native_git.bb:do_populate_sysroot after /home/user/ti-processor-sdk-linux-automotive-j7-evm-07_00_01/yocto-build/sources/oe-core/meta/recipes-kernel/kern-tools/kern-tools-native_git.bb:do_populate_sysroot
NOTE: Deferring mc:k3r5:virtual:native:/home/user/ti-processor-sdk-linux-automotive-j7-evm-07_00_01/yocto-build/sources/oe-core/meta/recipes-connectivity/openssl/openssl_1.1.1g.bb:do_populate_lic after virtual:native:/home/user/ti-processor-sdk-linux-automotive-j7-evm-07_00_01/yocto-build/sources/oe-core/meta/recipes-connectivity/openssl/openssl_1.1.1g.bb:do_populate_lic
NOTE: Deferring mc:k3r5:virtual:native:/home/user/ti-processor-sdk-linux-automotive-j7-evm-07_00_01/yocto-build/sources/oe-core/meta/recipes-connectivity/openssl/openssl_1.1.1g.bb:do_populate_sysroot after virtual:native:/home/user/ti-processor-sdk-linux-automotive-j7-evm-07_00_01/yocto-build/sources/oe-core/meta/recipes-connectivity/openssl/openssl_1.1.1g.bb:do_populate_sysroot
NOTE: Deferring mc:k3r5:virtual:native:/home/user/ti-processor-sdk-linux-automotive-j7-evm-07_00_01/yocto-build/sources/oe-core/meta/recipes-core/dbus/dbus_1.12.16.bb:do_populate_lic after virtual:native:/home/user/ti-processor-sdk-linux-automotive-j7-evm-07_00_01/yocto-build/sources/oe-core/meta/recipes-core/dbus/dbus_1.12.16.bb:do_populate_lic
NOTE: Deferring mc:k3r5:virtual:native:/home/user/ti-processor-sdk-linux-automotive-j7-evm-07_00_01/yocto-build/sources/oe-core/meta/recipes-core/dbus/dbus_1.12.16.bb:do_populate_sysroot after virtual:native:/home/user/ti-processor-sdk-linux-automotive-j7-evm-07_00_01/yocto-build/sources/oe-core/meta/recipes-core/dbus/dbus_1.12.16.bb:do_populate_sysroot
NOTE: Deferring mc:k3r5:virtual:native:/home/user/ti-processor-sdk-linux-automotive-j7-evm-07_00_01/yocto-build/sources/oe-core/meta/recipes-core/expat/expat_2.2.9.bb:do_populate_lic after virtual:native:/home/user/ti-processor-sdk-linux-automotive-j7-evm-07_00_01/yocto-build/sources/oe-core/meta/recipes-core/expat/expat_2.2.9.bb:do_populate_lic
NOTE: Deferring mc:k3r5:virtual:native:/home/user/ti-processor-sdk-linux-automotive-j7-evm-07_00_01/yocto-build/sources/oe-core/meta/recipes-core/expat/expat_2.2.9.bb:do_populate_sysroot after virtual:native:/home/user/ti-processor-sdk-linux-automotive-j7-evm-07_00_01/yocto-build/sources/oe-core/meta/recipes-core/expat/expat_2.2.9.bb:do_populate_sysroot
NOTE: Deferring mc:k3r5:virtual:native:/home/user/ti-processor-sdk-linux-automotive-j7-evm-07_00_01/yocto-build/sources/oe-core/meta/recipes-core/ncurses/ncurses_6.2.bb:do_populate_lic after virtual:native:/home/user/ti-processor-sdk-linux-automotive-j7-evm-07_00_01/yocto-build/sources/oe-core/meta/recipes-core/ncurses/ncurses_6.2.bb:do_populate_lic
NOTE: Deferring mc:k3r5:virtual:native:/home/user/ti-processor-sdk-linux-automotive-j7-evm-07_00_01/yocto-build/sources/oe-core/meta/recipes-core/ncurses/ncurses_6.2.bb:do_populate_sysroot after virtual:native:/home/user/ti-processor-sdk-linux-automotive-j7-evm-07_00_01/yocto-build/sources/oe-core/meta/recipes-core/ncurses/ncurses_6.2.bb:do_populate_sysroot
NOTE: Deferring mc:k3r5:virtual:native:/home/user/ti-processor-sdk-linux-automotive-j7-evm-07_00_01/yocto-build/sources/oe-core/meta/recipes-core/readline/readline_8.0.bb:do_populate_lic after virtual:native:/home/user/ti-processor-sdk-linux-automotive-j7-evm-07_00_01/yocto-build/sources/oe-core/meta/recipes-core/readline/readline_8.0.bb:do_populate_lic
NOTE: Deferring mc:k3r5:virtual:native:/home/user/ti-processor-sdk-linux-automotive-j7-evm-07_00_01/yocto-build/sources/oe-core/meta/recipes-core/readline/readline_8.0.bb:do_populate_sysroot after virtual:native:/home/user/ti-processor-sdk-linux-automotive-j7-evm-07_00_01/yocto-build/sources/oe-core/meta/recipes-core/readline/readline_8.0.bb:do_populate_sysroot
NOTE: Deferring mc:k3r5:virtual:native:/home/user/ti-processor-sdk-linux-automotive-j7-evm-07_00_01/yocto-build/sources/oe-core/meta/recipes-core/util-linux/util-linux_2.35.1.bb:do_populate_lic after virtual:native:/home/user/ti-processor-sdk-linux-automotive-j7-evm-07_00_01/yocto-build/sources/oe-core/meta/recipes-core/util-linux/util-linux_2.35.1.bb:do_populate_lic
NOTE: Deferring mc:k3r5:virtual:native:/home/user/ti-processor-sdk-linux-automotive-j7-evm-07_00_01/yocto-build/sources/oe-core/meta/recipes-core/util-linux/util-linux_2.35.1.bb:do_populate_sysroot after virtual:native:/home/user/ti-processor-sdk-linux-automotive-j7-evm-07_00_01/yocto-build/sources/oe-core/meta/recipes-core/util-linux/util-linux_2.35.1.bb:do_populate_sysroot
NOTE: Deferring mc:k3r5:virtual:native:/home/user/ti-processor-sdk-linux-automotive-j7-evm-07_00_01/yocto-build/sources/oe-core/meta/recipes-core/zlib/zlib_1.2.11.bb:do_populate_lic after virtual:native:/home/user/ti-processor-sdk-linux-automotive-j7-evm-07_00_01/yocto-build/sources/oe-core/meta/recipes-core/zlib/zlib_1.2.11.bb:do_populate_lic
NOTE: Deferring mc:k3r5:virtual:native:/home/user/ti-processor-sdk-linux-automotive-j7-evm-07_00_01/yocto-build/sources/oe-core/meta/recipes-core/zlib/zlib_1.2.11.bb:do_populate_sysroot after virtual:native:/home/user/ti-processor-sdk-linux-automotive-j7-evm-07_00_01/yocto-build/sources/oe-core/meta/recipes-core/zlib/zlib_1.2.11.bb:do_populate_sysroot
NOTE: Deferring mc:k3r5:virtual:native:/home/user/ti-processor-sdk-linux-automotive-j7-evm-07_00_01/yocto-build/sources/oe-core/meta/recipes-devtools/autoconf-archive/autoconf-archive_2019.01.06.bb:do_populate_lic after virtual:native:/home/user/ti-processor-sdk-linux-automotive-j7-evm-07_00_01/yocto-build/sources/oe-core/meta/recipes-devtools/autoconf-archive/autoconf-archive_2019.01.06.bb:do_populate_lic
NOTE: Deferring mc:k3r5:virtual:native:/home/user/ti-processor-sdk-linux-automotive-j7-evm-07_00_01/yocto-build/sources/oe-core/meta/recipes-devtools/autoconf-archive/autoconf-archive_2019.01.06.bb:do_populate_sysroot after virtual:native:/home/user/ti-processor-sdk-linux-automotive-j7-evm-07_00_01/yocto-build/sources/oe-core/meta/recipes-devtools/autoconf-archive/autoconf-archive_2019.01.06.bb:do_populate_sysroot
NOTE: Deferring mc:k3r5:virtual:native:/home/user/ti-processor-sdk-linux-automotive-j7-evm-07_00_01/yocto-build/sources/oe-core/meta/recipes-devtools/autoconf/autoconf_2.69.bb:do_populate_lic after virtual:native:/home/user/ti-processor-sdk-linux-automotive-j7-evm-07_00_01/yocto-build/sources/oe-core/meta/recipes-devtools/autoconf/autoconf_2.69.bb:do_populate_lic
NOTE: Deferring mc:k3r5:virtual:native:/home/user/ti-processor-sdk-linux-automotive-j7-evm-07_00_01/yocto-build/sources/oe-core/meta/recipes-devtools/autoconf/autoconf_2.69.bb:do_populate_sysroot after virtual:native:/home/user/ti-processor-sdk-linux-automotive-j7-evm-07_00_01/yocto-build/sources/oe-core/meta/recipes-devtools/autoconf/autoconf_2.69.bb:do_populate_sysroot
NOTE: Deferring mc:k3r5:virtual:native:/home/user/ti-processor-sdk-linux-automotive-j7-evm-07_00_01/yocto-build/sources/oe-core/meta/recipes-devtools/automake/automake_1.16.1.bb:do_populate_lic after virtual:native:/home/user/ti-processor-sdk-linux-automotive-j7-evm-07_00_01/yocto-build/sources/oe-core/meta/recipes-devtools/automake/automake_1.16.1.bb:do_populate_lic
NOTE: Deferring mc:k3r5:virtual:native:/home/user/ti-processor-sdk-linux-automotive-j7-evm-07_00_01/yocto-build/sources/oe-core/meta/recipes-devtools/automake/automake_1.16.1.bb:do_populate_sysroot after virtual:native:/home/user/ti-processor-sdk-linux-automotive-j7-evm-07_00_01/yocto-build/sources/oe-core/meta/recipes-devtools/automake/automake_1.16.1.bb:do_populate_sysroot
NOTE: Deferring mc:k3r5:virtual:native:/home/user/ti-processor-sdk-linux-automotive-j7-evm-07_00_01/yocto-build/sources/oe-core/meta/recipes-devtools/bison/bison_3.5.3.bb:do_populate_lic after virtual:native:/home/user/ti-processor-sdk-linux-automotive-j7-evm-07_00_01/yocto-build/sources/oe-core/meta/recipes-devtools/bison/bison_3.5.3.bb:do_populate_lic
NOTE: Deferring mc:k3r5:virtual:native:/home/user/ti-processor-sdk-linux-automotive-j7-evm-07_00_01/yocto-build/sources/oe-core/meta/recipes-devtools/bison/bison_3.5.3.bb:do_populate_sysroot after virtual:native:/home/user/ti-processor-sdk-linux-automotive-j7-evm-07_00_01/yocto-build/sources/oe-core/meta/recipes-devtools/bison/bison_3.5.3.bb:do_populate_sysroot
Common targets are:
core-image-minimal
core-image-sato
meta-toolchain
meta-toolchain-sdk
adt-installer
meta-ide-support
NOTE: Deferring mc:k3r5:virtual:native:/home/user/ti-processor-sdk-linux-automotive-j7-evm-07_00_01/yocto-build/sources/oe-core/meta/recipes-support/popt/popt_1.16.bb:do_populate_sysroot after virtual:native:/home/user/ti-processor-sdk-linux-automotive-j7-evm-07_00_01/yocto-build/sources/oe-core/meta/recipes-support/popt/popt_1.16.bb:do_populate_sysroot
NOTE: Deferring mc:k3r5:virtual:native:/home/user/ti-processor-sdk-linux-automotive-j7-evm-07_00_01/yocto-build/sources/oe-core/meta/recipes-support/sqlite/sqlite3_3.31.1.bb:do_populate_lic after virtual:native:/home/user/ti-processor-sdk-linux-automotive-j7-evm-07_00_01/yocto-build/sources/oe-core/meta/recipes-support/sqlite/sqlite3_3.31.1.bb:do_populate_lic
NOTE: Deferring mc:k3r5:virtual:native:/home/user/ti-processor-sdk-linux-automotive-j7-evm-07_00_01/yocto-build/sources/oe-core/meta/recipes-support/sqlite/sqlite3_3.31.1.bb:do_populate_sysroot after virtual:native:/home/user/ti-processor-sdk-linux-automotive-j7-evm-07_00_01/yocto-build/sources/oe-core/meta/recipes-support/sqlite/sqlite3_3.31.1.bb:do_populate_sysroot
NOTE: Executing Tasks
WARNING: external-arm-toolchain-2019.12-r0 do_package: QA Issue: external-arm-toolchain: Files/directories were installed but not shipped in any package:
/usr/lib/gcc/aarch64-linux/9.2.1/include/arm_acle.h
/usr/lib/gcc/aarch64-linux/9.2.1/include/stdbool.h
/usr/lib/gcc/aarch64-linux/9.2.1/include/arm_fp16.h
/usr/lib/gcc/aarch64-linux/9.2.1/include/arm_neon.h
/usr/lib/gcc/aarch64-linux/9.2.1/include/stdnoreturn.h
/usr/lib/gcc/aarch64-linux/9.2.1/include/stdfix.h
/usr/lib/gcc/aarch64-linux/9.2.1/include/stdint.h
/usr/lib/gcc/aarch64-linux/9.2.1/include/stdatomic.h
/usr/lib/gcc/aarch64-linux/9.2.1/include/openacc.h
/usr/lib/gcc/aarch64-linux/9.2.1/include/unwind.h
/usr/lib/gcc/aarch64-linux/9.2.1/include/stdalign.h
/usr/lib/gcc/aarch64-linux/9.2.1/include/stdint-gcc.h
/usr/lib/gcc/aarch64-linux/9.2.1/include/ISO_Fortran_binding.h
/usr/lib/gcc/aarch64-linux/9.2.1/include/gcov.h
/usr/lib/gcc/aarch64-linux/9.2.1/include/iso646.h
/usr/lib/gcc/aarch64-linux/9.2.1/include/stddef.h
/usr/lib/gcc/aarch64-linux/9.2.1/include/stdarg.h
/usr/lib/gcc/aarch64-linux/9.2.1/include/float.h
/usr/lib/gcc/aarch64-linux/9.2.1/include/varargs.h
Please set FILES such that these items are packaged. Alternatively if they are unneeded, avoid installing them or delete them within do_install.
external-arm-toolchain: 19 installed and not shipped files. [installed-vs-shipped]
WARNING: ti-img-rogue-umlibs-1.10.5371573-r8 do_package: QA Issue: ti-img-rogue-umlibs: Files/directories were installed but not shipped in any package:
/usr/etc
/usr/local
/usr/etc/drirc
/usr/local/share
/usr/local/share/util-macros
/usr/local/share/pkgconfig
/usr/local/share/aclocal
/usr/local/share/util-macros/INSTALL
/usr/local/share/pkgconfig/xorg-macros.pc
/usr/local/share/aclocal/xorg-macros.m4
ti-img-rogue-umlibs: 10 installed and not shipped files. [installed-vs-shipped]
Currently 3 running tasks (2195 of 8518) 25% |################ |
0: qtbase-5.14.2+gitAUTOINC+3a6d8df521-r0.arago16 do_compile - 20h34m17s (pid 1139150)
1: boost-1.72.0-r0 do_compile - 20h10m0s (pid 1204495)
2: gdk-pixbuf-native-2.40.0-r0 do_compile (pid 1308125) 25% |############# |
Hayden
