Part Number: 66AK2H14
Hi all,
I need to measure GPIO signal from EVMK2H board, what is suggested way to do so?
Thanks a lot.
P.S. I even purchase 120-pin connector, but it is too small to be soldered the wires to the pin.
Hi all,
Thanks a lot.
Chanh,
What are you needing to accomplish? If you want to create a circuit that works with the EVM, then getting the proper mating connector for the Expansion Connector is a reasonable solution. Alternately, if your interest is simply getting a GPIO to a scope display, you can solder a wire onto the board at one of the other components attached to the GPIO like a resistor or one of the SPI GPIO expander chips. Another probing option is to purchase the ZX102-QTH060 Samtec Breakout Adapter from ZEBAX Technologies (zebax.com).
Tom
