Hello Support Team,
I am recently switched to psdk_rtos_auto_j7_07_00_00_11. When I am building and executing the ipc_echo_test demo, I find the following output in the trace buffer:
IPC_echo_test (core : C66X_1) .....
IPC Driver Revision: 01.00.00.01
Failed to register irq through sciclient...ffffffff
Virtio_create : Failed to register mailbox
I used the following command to build the image:
make -s ipc_echo_test DISABLE_RECURSE_DEPS=no OS=linux BOARD=j721e_evm CORE=c66xdsp_1
The C7x image reports the same error.
How can I fix this error.
Thanks in advance and best regards,
Marco
