Linux/AM5749:Can't load Kernel
Other Parts Discussed in Thread: DRA752, AM5729, CDCE913, AM5748, BEAGLEBOARD-X15, AM5728, TMP102
Hello!!
I use ti-processor-sdk-linux-am57xx-evm-06.03.00.106 on am5749(custom board).
I use 2 Gb RAM without ECC. I no Have eMMC.
For a configuration of RAM I used EMIF Tool.
For a building I use config: am57xx_evm_defconfig.
I made a chenges like was discribed in this document: https://www.ti.com/lit/an/sprac36e/sprac36e.pdf?ts=1598257428040&ref_url=https%253A%252F%252Fwww.google.com%252F
  • My board.c with generated EMIF Tool:
    // SPDX-License-Identifier: GPL-2.0+
     * Copyright (C) 2014 Texas Instruments Incorporated - http://www.ti.com
     * Author: Felipe Balbi <balbi@ti.com>
     * Based on board/ti/dra7xx/evm.c
    #include <common.h>
    #include <palmas.h>
    #include <sata.h>
    #include <usb.h>
    #include <errno.h>
    #include <asm/omap_common.h>
    #include <asm/omap_sec_common.h>
    #include <asm/emif.h>
    #include <asm/gpio.h>
    #include <asm/arch/gpio.h>
    #include <asm/arch/clock.h>
    #include <asm/arch/dra7xx_iodelay.h>
    #include <asm/arch/sys_proto.h>
    #include <asm/arch/mmc_host_def.h>
    #include <asm/arch/sata.h>
    #include <asm/arch/omap.h>
    #include <environment.h>
    #include <usb.h>
    #include <linux/usb/gadget.h>
    #include <dwc3-uboot.h>
    #include <dwc3-omap-uboot.h>
    #include <ti-usb-phy-uboot.h>
    #include <mmc.h>
    #include <dm/uclass.h>
    #include "../common/board_detect.h"
    #include "mux_data.h"
    #ifdef CONFIG_SUPPORT_EMMC_BOOT
    static int board_bootmode_has_emmc(void);
    #endif
    #define board_is_x15()        board_ti_is("BBRDX15_")
    #define board_is_x15_revb1()    (board_ti_is("BBRDX15_") && \
                     !strncmp("B.10", board_ti_get_rev(), 3))
    #define board_is_x15_revc()    (board_ti_is("BBRDX15_") && \
                     !strncmp("C.00", board_ti_get_rev(), 3))
    #define board_is_am572x_evm()    board_ti_is("AM572PM_")
    #define board_is_am572x_evm_reva3()    \
                    (board_ti_is("AM572PM_") && \
                     !strncmp("A.30", board_ti_get_rev(), 3))
    #define board_is_am574x_idk()    board_ti_is("AM574IDK")
    #define board_is_am572x_idk()    board_ti_is("AM572IDK")
    #define board_is_am571x_idk()    board_ti_is("AM571IDK")
    #define board_is_bbai()        board_ti_is("BBONE-AI")
    #ifdef CONFIG_DRIVER_TI_CPSW
    #include <cpsw.h>
    #endif
    DECLARE_GLOBAL_DATA_PTR;
    #define GPIO_ETH_LCD        GPIO_TO_PIN(2, 22)
    /* GPIO 7_11 */
    #define GPIO_DDR_VTT_EN 203
    /* Touch screen controller to identify the LCD */
    #define OSD_TS_FT_BUS_ADDRESS    0
    #define OSD_TS_FT_CHIP_ADDRESS    0x38
    #define OSD_TS_FT_REG_ID    0xA3
     * Touchscreen IDs for various OSD panels
     * Ref: www.osddisplays.com/.../OSD101T2587-53TS_A.1.pdf
    /* Used on newer osd101t2587 Panels */
    #define OSD_TS_FT_ID_5x46    0x54
    /* Used on older osd101t2045 Panels */
    #define OSD_TS_FT_ID_5606    0x08
    #define SYSINFO_BOARD_NAME_MAX_LEN    45
    #define TPS65903X_PRIMARY_SECONDARY_PAD2    0xFB
    #define TPS65903X_PAD2_POWERHOLD_MASK        0x20
    const struct omap_sysinfo sysinfo = {
        "Board: UNKNOWN(BeagleBoard X15?) REV UNKNOWN\n"
    static const struct dmm_lisa_map_regs beagle_x15_lisa_regs = {
        .dmm_lisa_map_3 = 0x80740300,
        .is_ma_present  = 0x1
    static const struct dmm_lisa_map_regs am571x_idk_lisa_regs = {
        .dmm_lisa_map_3 = 0x80640100,
    static const struct dmm_lisa_map_regs am574x_idk_lisa_regs = {
        .dmm_lisa_map_2 = 0xc0600200,
        .dmm_lisa_map_3 = 0x80600100,
    static const struct dmm_lisa_map_regs bbai_lisa_regs = {
    //---------------------------User_settings------------------------
    const struct ctrl_ioregs AM574x_DDR3L_666MHz_TI_AM574x_IDK_ctrl_ioregs = {
        .ctrl_ddr3ch = 0x80808080,
        .ctrl_ddrch = 0x40404040,
        .ctrl_ddrio_0 = 0x00094A40,
        .ctrl_ddrio_1 = 0x00000000,
        .ctrl_lpddr2ch = 0x00404000,
        .ctrl_emif_sdram_config_ext = 0x0000C123
    void get_ioregs(const struct ctrl_ioregs **regs)
        *regs = &AM574x_DDR3L_666MHz_TI_AM574x_IDK_ctrl_ioregs;
    const struct dmm_lisa_map_regs AM574x_DDR3L_666MHz_TI_AM574x_IDK_dmm_regs = {
        .dmm_lisa_map_0 = 0x00000000,
        .dmm_lisa_map_1 = 0x00000000,
        .dmm_lisa_map_2 = 0x80640300,
        .dmm_lisa_map_3 = 0xFF020100,
    const struct emif_regs AM574x_DDR3L_666MHz_TI_AM574x_IDK_emif_regs = {
        .sdram_config_init = 0x61862AB2,
        .sdram_config = 0x61862AB2,
        .sdram_config2 = 0x00000000,
        .ref_ctrl = 0x1000514D,
        .ref_ctrl_final = 0x1000144A,
        .sdram_tim1 = 0xD3337834,
        .sdram_tim2 = 0x30B37FE3,
        .sdram_tim3 = 0x407F8AD8,
        .read_idle_ctrl = 0x00050000,
        .zq_config = 0x5007190B,
        .temp_alert_config = 0x00000000,
        .emif_rd_wr_lvl_rmp_ctl = 0x80000000,
        .emif_rd_wr_lvl_ctl = 0x00000000,
        .emif_ddr_phy_ctlr_1_init = 0x0024400E,
        .emif_ddr_phy_ctlr_1 = 0x0E24400E,
        .emif_rd_wr_exec_thresh = 0x00000305,
        .emif_ecc_ctrl_reg = 0x00000000,
        .emif_ecc_address_range_1 = 0x3FFF0000,
        .emif_ecc_address_range_2 = 0x00000000,
    const unsigned int AM574x_DDR3L_666MHz_TI_AM574x_IDK_emif1_ext_phy_regs [] = {
        0x04040100,    /* EMIF1_EXT_PHY_CTRL_1 */
        0x006B008C,    /* EMIF1_EXT_PHY_CTRL_2 */
        0x006B008D,    /* EMIF1_EXT_PHY_CTRL_3 */
        0x006B006B,    /* EMIF1_EXT_PHY_CTRL_4 */
        0x006B006B,    /* EMIF1_EXT_PHY_CTRL_5 */
        0x006B006B,    /* EMIF1_EXT_PHY_CTRL_6 */
        0x002F002F,    /* EMIF1_EXT_PHY_CTRL_7 */
        0x002F002F,    /* EMIF1_EXT_PHY_CTRL_8 */
        0x002F002F,    /* EMIF1_EXT_PHY_CTRL_9 */
        0x002F002F,    /* EMIF1_EXT_PHY_CTRL_10 */
        0x002F002F,    /* EMIF1_EXT_PHY_CTRL_11 */
        0x00600070,    /* EMIF1_EXT_PHY_CTRL_12 */
        0x0060006F,    /* EMIF1_EXT_PHY_CTRL_13 */
        0x00600060,    /* EMIF1_EXT_PHY_CTRL_14 */
        0x00600060,    /* EMIF1_EXT_PHY_CTRL_15 */
        0x00600060,    /* EMIF1_EXT_PHY_CTRL_16 */
        0x00400050,    /* EMIF1_EXT_PHY_CTRL_17 */
        0x0040004F,    /* EMIF1_EXT_PHY_CTRL_18 */
        0x00400040,    /* EMIF1_EXT_PHY_CTRL_19 */
        0x00400040,    /* EMIF1_EXT_PHY_CTRL_20 */
        0x00400040,    /* EMIF1_EXT_PHY_CTRL_21 */
        0x00800080,    /* EMIF1_EXT_PHY_CTRL_22 */
        0x00800080,    /* EMIF1_EXT_PHY_CTRL_23 */
        0x40010080,    /* EMIF1_EXT_PHY_CTRL_24 */
        0x08102040,    /* EMIF1_EXT_PHY_CTRL_25 */
        0x0000007C,    /* EMIF1_EXT_PHY_CTRL_26 */
        0x0000007D,    /* EMIF1_EXT_PHY_CTRL_27 */
        0x00000000,    /* EMIF1_EXT_PHY_CTRL_28 */
        0x00000000,    /* EMIF1_EXT_PHY_CTRL_29 */
        0x00000000,    /* EMIF1_EXT_PHY_CTRL_30 */
        0x00000040,    /* EMIF1_EXT_PHY_CTRL_31 */
        0x0000003F,    /* EMIF1_EXT_PHY_CTRL_32 */
        0x00000000,    /* EMIF1_EXT_PHY_CTRL_33 */
        0x00000000,    /* EMIF1_EXT_PHY_CTRL_34 */
        0x00000000,    /* EMIF1_EXT_PHY_CTRL_35 */
        0x00000077    /* EMIF1_EXT_PHY_CTRL_36 */
    const unsigned int AM574x_DDR3L_666MHz_TI_AM574x_IDK_emif2_ext_phy_regs [] = {
        0x04040100,    /* EMIF2_EXT_PHY_CTRL_1 */
        0x006B0096,    /* EMIF2_EXT_PHY_CTRL_2 */
        0x006B0095,    /* EMIF2_EXT_PHY_CTRL_3 */
        0x006B006B,    /* EMIF2_EXT_PHY_CTRL_4 */
        0x006B006B,    /* EMIF2_EXT_PHY_CTRL_5 */
        0x006B006B,    /* EMIF2_EXT_PHY_CTRL_6 */
        0x002F002F,    /* EMIF2_EXT_PHY_CTRL_7 */
        0x002F002F,    /* EMIF2_EXT_PHY_CTRL_8 */
        0x002F002F,    /* EMIF2_EXT_PHY_CTRL_9 */
        0x002F002F,    /* EMIF2_EXT_PHY_CTRL_10 */
        0x002F002F,    /* EMIF2_EXT_PHY_CTRL_11 */
        0x0060006F,    /* EMIF2_EXT_PHY_CTRL_12 */
        0x0060006F,    /* EMIF2_EXT_PHY_CTRL_13 */
        0x00600060,    /* EMIF2_EXT_PHY_CTRL_14 */
        0x00600060,    /* EMIF2_EXT_PHY_CTRL_15 */
        0x00600060,    /* EMIF2_EXT_PHY_CTRL_16 */
        0x0040004F,    /* EMIF2_EXT_PHY_CTRL_17 */
        0x0040004F,    /* EMIF2_EXT_PHY_CTRL_18 */
        0x00400040,    /* EMIF2_EXT_PHY_CTRL_19 */
        0x00400040,    /* EMIF2_EXT_PHY_CTRL_20 */
        0x00400040,    /* EMIF2_EXT_PHY_CTRL_21 */
        0x00800080,    /* EMIF2_EXT_PHY_CTRL_22 */
        0x00800080,    /* EMIF2_EXT_PHY_CTRL_23 */
        0x40010080,    /* EMIF2_EXT_PHY_CTRL_24 */
        0x08102040,    /* EMIF2_EXT_PHY_CTRL_25 */
        0x00000086,    /* EMIF2_EXT_PHY_CTRL_26 */
        0x00000085,    /* EMIF2_EXT_PHY_CTRL_27 */
        0x00000000,    /* EMIF2_EXT_PHY_CTRL_28 */
        0x00000000,    /* EMIF2_EXT_PHY_CTRL_29 */
        0x00000000,    /* EMIF2_EXT_PHY_CTRL_30 */
        0x0000003F,    /* EMIF2_EXT_PHY_CTRL_31 */
        0x0000003F,    /* EMIF2_EXT_PHY_CTRL_32 */
        0x00000000,    /* EMIF2_EXT_PHY_CTRL_33 */
        0x00000000,    /* EMIF2_EXT_PHY_CTRL_34 */
        0x00000000,    /* EMIF2_EXT_PHY_CTRL_35 */
        0x00000077    /* EMIF2_EXT_PHY_CTRL_36 */
    void emif_get_dmm_regs(const struct dmm_lisa_map_regs **dmm_lisa_regs)
        if (board_is_am571x_idk())
            *dmm_lisa_regs = &am571x_idk_lisa_regs;
        else if (board_is_am574x_idk())
            *dmm_lisa_regs = &AM574x_DDR3L_666MHz_TI_AM574x_IDK_dmm_regs;
        else if (board_is_bbai())
            *dmm_lisa_regs = &bbai_lisa_regs;
        else
            *dmm_lisa_regs = &beagle_x15_lisa_regs;
    static const struct emif_regs beagle_x15_emif1_ddr3_532mhz_emif_regs = {
        .sdram_config_init        = 0x61851b32,
        .sdram_config            = 0x61851b32,
        .sdram_config2            = 0x08000000,
        .ref_ctrl            = 0x000040F1,
        .ref_ctrl_final            = 0x00001035,
        .sdram_tim1            = 0xcccf36ab,
        .sdram_tim2            = 0x308f7fda,
        .sdram_tim3            = 0x409f88a8,
        .zq_config            = 0x5007190b,
        .emif_ddr_phy_ctlr_1_init     = 0x0024400b,
        .emif_ddr_phy_ctlr_1        = 0x0e24400b,
        .emif_ddr_ext_phy_ctrl_1     = 0x10040100,
        .emif_ddr_ext_phy_ctrl_2     = 0x00910091,
        .emif_ddr_ext_phy_ctrl_3     = 0x00950095,
        .emif_ddr_ext_phy_ctrl_4     = 0x009b009b,
        .emif_ddr_ext_phy_ctrl_5     = 0x009e009e,
        .emif_rd_wr_lvl_rmp_win        = 0x00000000,
    /* Ext phy ctrl regs 1-35 */
    static const u32 beagle_x15_emif1_ddr3_ext_phy_ctrl_const_regs[] = {
        0x10040100,
        0x00910091,
        0x00950095,
        0x009B009B,
        0x009E009E,
        0x00980098,
        0x00340034,
        0x00350035,
        0x00340034,
        0x00310031,
        0x00340034,
        0x007F007F,
        0x007F007F,
        0x007F007F,
        0x007F007F,
        0x007F007F,
        0x00480048,
        0x004A004A,
        0x00520052,
        0x00550055,
        0x00500050,
        0x00000000,
        0x00600020,
        0x40011080,
        0x08102040,
        0x0,
        0x0,
        0x0,
        0x0,
        0x0,
        0x0,
        0x0,
        0x0,
        0x0,
        0x0
    static const struct emif_regs beagle_x15_emif2_ddr3_532mhz_emif_regs = {
        .sdram_tim1            = 0xcccf36b3,
        .sdram_tim3            = 0x407f88a8,
    static const u32 beagle_x15_emif2_ddr3_ext_phy_ctrl_const_regs[] = {
        0x10040100,
        0x00910091,
        0x00950095,
        0x009B009B,
        0x009E009E,
        0x00980098,
        0x00340034,
        0x00350035,
        0x00340034,
        0x00310031,
        0x00340034,
        0x007F007F,
        0x007F007F,
        0x007F007F,
        0x007F007F,
        0x007F007F,
        0x00480048,
        0x004A004A,
        0x00520052,
        0x00550055,
        0x00500050,
        0x00000000,
        0x00600020,
        0x40011080,
        0x08102040,
        0x0,
        0x0,
        0x0,
        0x0,
        0x0,
        0x0,
        0x0,
        0x0,
        0x0,
        0x0
    static const struct emif_regs am571x_emif1_ddr3_666mhz_emif_regs = {
        .sdram_config_init        = 0x61863332,
        .sdram_config            = 0x61863332,
        .ref_ctrl            = 0x0000514d,
        .ref_ctrl_final            = 0x0000144a,
        .sdram_tim1            = 0xd333887c,
        .sdram_tim2            = 0x30b37fe3,
        .sdram_tim3            = 0x409f8ad8,
        .emif_ddr_phy_ctlr_1_init    = 0x0024400f,
        .emif_ddr_phy_ctlr_1        = 0x0e24400f,
    static const struct emif_regs am574x_emif1_ddr3_666mhz_emif_ecc_regs = {
        .emif_ecc_ctrl_reg        = 0xD0000001,
    void emif_get_reg_dump(u32 emif_nr, const struct emif_regs **regs)
        switch (emif_nr) {
        case 1:
                *regs = &am571x_emif1_ddr3_666mhz_emif_regs;
                *regs = &AM574x_DDR3L_666MHz_TI_AM574x_IDK_emif_regs;
            else
                *regs = &beagle_x15_emif1_ddr3_532mhz_emif_regs;
            break;
        case 2:
            else
                *regs = &beagle_x15_emif2_ddr3_532mhz_emif_regs;
            break;
    void emif_get_ext_phy_ctrl_const_regs(u32 emif_nr, const u32 **regs, u32 *size)
        switch (emif_nr) {
        case 1:
            *regs = AM574x_DDR3L_666MHz_TI_AM574x_IDK_emif1_ext_phy_regs;
            *size = ARRAY_SIZE(AM574x_DDR3L_666MHz_TI_AM574x_IDK_emif1_ext_phy_regs);
            break;
        case 2:
            *regs = AM574x_DDR3L_666MHz_TI_AM574x_IDK_emif2_ext_phy_regs;
            *size = ARRAY_SIZE(AM574x_DDR3L_666MHz_TI_AM574x_IDK_emif2_ext_phy_regs);
            break;
    struct vcores_data beagle_x15_volts = {
        .mpu.value[OPP_NOM]    = VDD_MPU_DRA7_NOM,
        .mpu.efuse.reg[OPP_NOM]    = STD_FUSE_OPP_VMIN_MPU_NOM,
        .mpu.efuse.reg_bits     = DRA752_EFUSE_REGBITS,
        .mpu.addr        = TPS659038_REG_ADDR_SMPS12,
        .mpu.pmic        = &tps659038,
        .mpu.abb_tx_done_mask    = OMAP_ABB_MPU_TXDONE_MASK,
        .eve.value[OPP_NOM]    = VDD_EVE_DRA7_NOM,
        .eve.value[OPP_OD]    = VDD_EVE_DRA7_OD,
        .eve.value[OPP_HIGH]    = VDD_EVE_DRA7_HIGH,
        .eve.efuse.reg[OPP_NOM]    = STD_FUSE_OPP_VMIN_DSPEVE_NOM,
        .eve.efuse.reg[OPP_OD]    = STD_FUSE_OPP_VMIN_DSPEVE_OD,
        .eve.efuse.reg[OPP_HIGH]    = STD_FUSE_OPP_VMIN_DSPEVE_HIGH,
        .eve.efuse.reg_bits    = DRA752_EFUSE_REGBITS,
        .eve.addr        = TPS659038_REG_ADDR_SMPS45,
        .eve.pmic        = &tps659038,
        .eve.abb_tx_done_mask    = OMAP_ABB_EVE_TXDONE_MASK,
        .gpu.value[OPP_NOM]    = VDD_GPU_DRA7_NOM,
        .gpu.value[OPP_OD]    = VDD_GPU_DRA7_OD,
        .gpu.value[OPP_HIGH]    = VDD_GPU_DRA7_HIGH,
        .gpu.efuse.reg[OPP_NOM]    = STD_FUSE_OPP_VMIN_GPU_NOM,
        .gpu.efuse.reg[OPP_OD]    = STD_FUSE_OPP_VMIN_GPU_OD,
        .gpu.efuse.reg[OPP_HIGH]    = STD_FUSE_OPP_VMIN_GPU_HIGH,
        .gpu.efuse.reg_bits    = DRA752_EFUSE_REGBITS,
        .gpu.addr        = TPS659038_REG_ADDR_SMPS45,
        .gpu.pmic        = &tps659038,
        .gpu.abb_tx_done_mask    = OMAP_ABB_GPU_TXDONE_MASK,
        .core.value[OPP_NOM]    = VDD_CORE_DRA7_NOM,
        .core.efuse.reg[OPP_NOM]    = STD_FUSE_OPP_VMIN_CORE_NOM,
        .core.efuse.reg_bits    = DRA752_EFUSE_REGBITS,
        .core.addr        = TPS659038_REG_ADDR_SMPS6,
        .core.pmic        = &tps659038,
        .iva.value[OPP_NOM]    = VDD_IVA_DRA7_NOM,
        .iva.value[OPP_OD]    = VDD_IVA_DRA7_OD,
        .iva.value[OPP_HIGH]    = VDD_IVA_DRA7_HIGH,
        .iva.efuse.reg[OPP_NOM]    = STD_FUSE_OPP_VMIN_IVA_NOM,
        .iva.efuse.reg[OPP_OD]    = STD_FUSE_OPP_VMIN_IVA_OD,
        .iva.efuse.reg[OPP_HIGH]    = STD_FUSE_OPP_VMIN_IVA_HIGH,
        .iva.efuse.reg_bits    = DRA752_EFUSE_REGBITS,
        .iva.addr        = TPS659038_REG_ADDR_SMPS45,
        .iva.pmic        = &tps659038,
        .iva.abb_tx_done_mask    = OMAP_ABB_IVA_TXDONE_MASK,
    struct vcores_data am572x_idk_volts = {
        .gpu.addr        = TPS659038_REG_ADDR_SMPS6,
        .core.addr        = TPS659038_REG_ADDR_SMPS7,
        .iva.addr        = TPS659038_REG_ADDR_SMPS8,
    struct vcores_data am571x_idk_volts = {
    int get_voltrail_opp(int rail_offset)
        int opp;
        switch (rail_offset) {
        case VOLT_MPU:
            opp = DRA7_MPU_OPP;
            break;
        case VOLT_CORE:
            opp = DRA7_CORE_OPP;
            break;
        case VOLT_GPU:
            opp = DRA7_GPU_OPP;
            break;
        case VOLT_EVE:
            opp = DRA7_DSPEVE_OPP;
            break;
        case VOLT_IVA:
            opp = DRA7_IVA_OPP;
            break;
        default:
            opp = OPP_NOM;
        return opp;
    #ifdef CONFIG_SPL_BUILD
    /* No env to setup for SPL */
    static inline void setup_board_eeprom_env(void) { }
    /* Override function to read eeprom information */
    void do_board_detect(void)
        int rc;
        rc = ti_i2c_eeprom_am_get(CONFIG_EEPROM_BUS_ADDRESS,
                      CONFIG_EEPROM_CHIP_ADDRESS);
        if (rc)
            printf("ti_i2c_eeprom_init failed %d\n", rc);
        rc = board_bootmode_has_emmc();
        if (!rc)
            rc = ti_emmc_boardid_get();
        if (rc)
            printf("ti_emmc_boardid_get failed %d\n", rc);
    #endif
    #else    /* CONFIG_SPL_BUILD */
    /* Override function to read eeprom information: actual i2c read done by SPL*/
        char *bname = NULL;
        int rc;
        if (rc)
        if (!rc)
        if (rc)
    #endif
        if (board_is_x15())
            bname = "BeagleBoard X15";
        else if (board_is_am572x_evm())
            bname = "AM572x EVM";
            bname = "AM574x IDK";
        else if (board_is_am572x_idk())
            bname = "AM572x IDK";
        else if (board_is_am571x_idk())
            bname = "AM571x IDK";
            bname = "BeagleBone AI";
        if (bname)
            snprintf(sysinfo.board_string, SYSINFO_BOARD_NAME_MAX_LEN,
                 "Board: %s REV %s\n", bname, board_ti_get_rev());
    static void setup_board_eeprom_env(void)
        char *name = "beagle_x15";
        int rc;
        if (rc)
            goto invalid_eeprom;
        if (board_is_x15()) {
            if (board_is_x15_revb1())
                name = "beagle_x15_revb1";
            else if (board_is_x15_revc())
                name = "beagle_x15_revc";
            else
        } else if (board_is_am572x_evm()) {
            if (board_is_am572x_evm_reva3())
                name = "am57xx_evm_reva3";
            else
                name = "am57xx_evm";
        } else if (board_is_am574x_idk()) {
            name = "am574x_idk";
        } else if (board_is_am572x_idk()) {
            name = "am572x_idk";
        } else if (board_is_am571x_idk()) {
            name = "am571x_idk";
        } else if (board_is_bbai()) {
            name = "am5729_beagleboneai";
        } else {
            printf("Unidentified board claims %s in eeprom header\n",
                   board_ti_get_name());
    invalid_eeprom:
        set_board_info_env(name);
    #endif    /* CONFIG_SPL_BUILD */
    void vcores_init(void)
        if (board_is_am572x_idk() || board_is_am574x_idk())
            *omap_vcores = &am572x_idk_volts;
            *omap_vcores = &am571x_idk_volts;
        else
            *omap_vcores = &beagle_x15_volts;
    void hw_data_init(void)
        *prcm = &dra7xx_prcm;
        if (is_dra72x())
            *dplls_data = &dra72x_dplls;
        else if (is_dra76x())
            *dplls_data = &dra76x_dplls;
        else
            *dplls_data = &dra7xx_dplls;
        *ctrl = &dra7xx_ctrl;
    bool am571x_idk_needs_lcd(void)
        bool needs_lcd;
        gpio_request(GPIO_ETH_LCD, "nLCD_Detect");
        if (gpio_get_value(GPIO_ETH_LCD))
            needs_lcd = false;
        else
            needs_lcd = true;
        gpio_free(GPIO_ETH_LCD);
        return needs_lcd;
    int board_init(void)
        gpmc_init();
        gd->bd->bi_boot_params = (CONFIG_SYS_SDRAM_BASE + 0x100);
        return 0;
    void am57x_idk_lcd_detect(void)
        int r = -ENODEV;
        char *idk_lcd = "no";
        struct udevice *dev;
        /* Only valid for IDKs */
        if (board_is_x15() || board_is_am572x_evm() || board_is_bbai())
            return;
        /* Only AM571x IDK has gpio control detect.. so check that */
        if (board_is_am571x_idk() && !am571x_idk_needs_lcd())
            goto out;
        r = i2c_get_chip_for_busnum(OSD_TS_FT_BUS_ADDRESS,
                        OSD_TS_FT_CHIP_ADDRESS, 1, &dev);
        if (r) {
            printf("%s: Failed to get I2C device %d/%d (ret %d)\n",
                   __func__, OSD_TS_FT_BUS_ADDRESS, OSD_TS_FT_CHIP_ADDRESS,
                   r);
            /* AM572x IDK has no explicit settings for optional LCD kit */
                printf("%s: Touch screen detect failed: %d!\n",
                       __func__, r);
            goto out;
        /* Read FT ID */
        r = dm_i2c_reg_read(dev, OSD_TS_FT_REG_ID);
        if (r < 0) {
            printf("%s: Touch screen ID read %d:0x%02x[0x%02x] failed:%d\n",
                   OSD_TS_FT_REG_ID, r);
            goto out;
        switch (r) {
        case OSD_TS_FT_ID_5606:
            idk_lcd = "osd101t2045";
            break;
        case OSD_TS_FT_ID_5x46:
            idk_lcd = "osd101t2587";
            break;
        default:
            printf("%s: Unidentifed Touch screen ID 0x%02x\n",
                   __func__, r);
            /* we will let default be "no lcd" */
    out:
        env_set("idk_lcd", idk_lcd);
         * On AM571x_IDK, no Display with J51 set to LCD is considered as an
         * invalid configuration and we prevent boot to get user attention.
        if (board_is_am571x_idk() && am571x_idk_needs_lcd() &&
            !strncmp(idk_lcd, "no", 2)) {
            printf("%s: Invalid HW configuration: display not detected/supported but J51 is set. Remove J51 to boot without display.\n",
                   __func__);
            hang();
        return;
    #if CONFIG_IS_ENABLED(DM_USB) && CONFIG_IS_ENABLED(OF_CONTROL)
    static int device_okay(const char *path)
        int node;
        node = fdt_path_offset(gd->fdt_blob, path);
        if (node < 0)
            return 0;
        return fdtdec_get_is_enabled(gd->fdt_blob, node);
    #endif
    int board_late_init(void)
        setup_board_eeprom_env();
        u8 val;
         * DEV_CTRL.DEV_ON = 1 please - else palmas switches off in 8 seconds
         * This is the POWERHOLD-in-Low behavior.
        palmas_i2c_write_u8(TPS65903X_CHIP_P1, 0xA0, 0x1);
         * Default FIT boot on HS devices. Non FIT images are not allowed
         * on HS devices.
        if (get_device_type() == HS_DEVICE)
            env_set("boot_fit", "1");
         * Set the GPIO7 Pad to POWERHOLD. This has higher priority
         * over DEV_CTRL.DEV_ON bit. This can be reset in case of
         * PMIC Power off. So to be on the safer side set it back
         * to POWERHOLD mode irrespective of the current state.
        palmas_i2c_read_u8(TPS65903X_CHIP_P1, TPS65903X_PRIMARY_SECONDARY_PAD2,
                   &val);
        val = val | TPS65903X_PAD2_POWERHOLD_MASK;
        palmas_i2c_write_u8(TPS65903X_CHIP_P1, TPS65903X_PRIMARY_SECONDARY_PAD2,
                    val);
        omap_die_id_serial();
        omap_set_fastboot_vars();
        am57x_idk_lcd_detect();
        /* Just probe the potentially supported cdce913 device */
        uclass_get_device(UCLASS_CLK, 0, &dev);
            env_set("console", "ttyS0,115200n8");
    #if !defined(CONFIG_SPL_BUILD)
        board_ti_set_ethaddr(2);
    #endif
        if (device_okay("/ocp/omap_dwc3_1@48880000"))
            enable_usb_clocks(0);
        if (device_okay("/ocp/omap_dwc3_2@488c0000"))
            enable_usb_clocks(1);
    #endif
        return 0;
    void set_muxconf_regs(void)
        do_set_mux32((*ctrl)->control_padconf_core_base,
                 early_padconf, ARRAY_SIZE(early_padconf));
                 emmc_padconf, ARRAY_SIZE(emmc_padconf));
    #endif
    #ifdef CONFIG_IODELAY_RECALIBRATION
    void recalibrate_iodelay(void)
        const struct pad_conf_entry *pconf;
        const struct iodelay_cfg_entry *iod, *delta_iod;
        int pconf_sz, iod_sz, delta_iod_sz = 0;
        int ret;
            pconf = core_padconf_array_essential_am572x_idk;
            pconf_sz = ARRAY_SIZE(core_padconf_array_essential_am572x_idk);
            iod = iodelay_cfg_array_am572x_idk;
            iod_sz = ARRAY_SIZE(iodelay_cfg_array_am572x_idk);
            pconf = core_padconf_array_essential_am574x_idk;
            pconf_sz = ARRAY_SIZE(core_padconf_array_essential_am574x_idk);
            iod = iodelay_cfg_array_am574x_idk;
            iod_sz = ARRAY_SIZE(iodelay_cfg_array_am574x_idk);
            pconf = core_padconf_array_essential_am571x_idk;
            pconf_sz = ARRAY_SIZE(core_padconf_array_essential_am571x_idk);
            iod = iodelay_cfg_array_am571x_idk;
            iod_sz = ARRAY_SIZE(iodelay_cfg_array_am571x_idk);
            pconf = core_padconf_array_essential_bbai;
            pconf_sz = ARRAY_SIZE(core_padconf_array_essential_bbai);
            iod = iodelay_cfg_array_bbai;
            iod_sz = ARRAY_SIZE(iodelay_cfg_array_bbai);
        } else {
            /* Common for X15/GPEVM */
            pconf = core_padconf_array_essential_x15;
            pconf_sz = ARRAY_SIZE(core_padconf_array_essential_x15);
            /* There never was an SR1.0 X15.. So.. */
            if (omap_revision() == DRA752_ES1_1) {
                iod = iodelay_cfg_array_x15_sr1_1;
                iod_sz = ARRAY_SIZE(iodelay_cfg_array_x15_sr1_1);
            } else {
                /* Since full production should switch to SR2.0  */
                iod = iodelay_cfg_array_x15_sr2_0;
                iod_sz = ARRAY_SIZE(iodelay_cfg_array_x15_sr2_0);
        /* Setup I/O isolation */
        ret = __recalibrate_iodelay_start();
        if (ret)
            goto err;
        /* Do the muxing here */
        do_set_mux32((*ctrl)->control_padconf_core_base, pconf, pconf_sz);
        /* Now do the weird minor deltas that should be safe */
        if (board_is_x15() || board_is_am572x_evm()) {
            if (board_is_x15_revb1() || board_is_am572x_evm_reva3() ||
                board_is_x15_revc()) {
                pconf = core_padconf_array_delta_x15_sr2_0;
                pconf_sz = ARRAY_SIZE(core_padconf_array_delta_x15_sr2_0);
            } else {
                pconf = core_padconf_array_delta_x15_sr1_1;
                pconf_sz = ARRAY_SIZE(core_padconf_array_delta_x15_sr1_1);
            if (am571x_idk_needs_lcd()) {
                pconf = core_padconf_array_vout_am571x_idk;
                pconf_sz = ARRAY_SIZE(core_padconf_array_vout_am571x_idk);
                delta_iod = iodelay_cfg_array_am571x_idk_4port;
                delta_iod_sz = ARRAY_SIZE(iodelay_cfg_array_am571x_idk_4port);
            } else {
                pconf = core_padconf_array_icss1eth_am571x_idk;
                pconf_sz = ARRAY_SIZE(core_padconf_array_icss1eth_am571x_idk);
        /* Setup IOdelay configuration */
        ret = do_set_iodelay((*ctrl)->iodelay_config_base, iod, iod_sz);
        if (delta_iod_sz)
            ret = do_set_iodelay((*ctrl)->iodelay_config_base, delta_iod,
                         delta_iod_sz);
    err:
        /* Closeup.. remove isolation */
        __recalibrate_iodelay_end(ret);
    #endif
    #if defined(CONFIG_MMC)
    int board_mmc_init(bd_t *bis)
        omap_mmc_init(0, 0, 0, -1, -1);
        omap_mmc_init(1, 0, 0, -1, -1);
        return 0;
    static const struct mmc_platform_fixups am57x_es1_1_mmc1_fixups = {
        .hw_rev = "rev11",
        .unsupported_caps = MMC_CAP(MMC_HS_200) |
                    MMC_CAP(UHS_SDR104),
        .max_freq = 96000000,
    static const struct mmc_platform_fixups am57x_es1_1_mmc23_fixups = {
        .hw_rev = "rev11",
                    MMC_CAP(UHS_SDR104) |
                    MMC_CAP(UHS_SDR50),
        .max_freq = 48000000,
    const struct mmc_platform_fixups *platform_fixups_mmc(uint32_t addr)
        switch (omap_revision()) {
        case DRA752_ES1_0:
        case DRA752_ES1_1:
            if (addr == OMAP_HSMMC1_BASE)
                return &am57x_es1_1_mmc1_fixups;
            else
                return &am57x_es1_1_mmc23_fixups;
        default:
            return NULL;
    #endif
    #if defined(CONFIG_SPL_BUILD) && defined(CONFIG_SPL_OS_BOOT)
    int spl_start_uboot(void)
        /* break into full u-boot on 'c' */
        if (serial_tstc() && serial_getc() == 'c')
            return 1;
    #ifdef CONFIG_SPL_ENV_SUPPORT
        env_init();
        env_load();
        if (env_get_yesno("boot_os") != 1)
            return 1;
    #endif
        return 0;
    #endif
    /* Delay value to add to calibrated value */
    #define RGMII0_TXCTL_DLY_VAL        ((0x3 << 5) + 0x8)
    #define RGMII0_TXD0_DLY_VAL        ((0x3 << 5) + 0x8)
    #define RGMII0_TXD1_DLY_VAL        ((0x3 << 5) + 0x2)
    #define RGMII0_TXD2_DLY_VAL        ((0x4 << 5) + 0x0)
    #define RGMII0_TXD3_DLY_VAL        ((0x4 << 5) + 0x0)
    #define VIN2A_D13_DLY_VAL        ((0x3 << 5) + 0x8)
    #define VIN2A_D17_DLY_VAL        ((0x3 << 5) + 0x8)
    #define VIN2A_D16_DLY_VAL        ((0x3 << 5) + 0x2)
    #define VIN2A_D15_DLY_VAL        ((0x4 << 5) + 0x0)
    #define VIN2A_D14_DLY_VAL        ((0x4 << 5) + 0x0)
    static void cpsw_control(int enabled)
        /* VTP can be added here */
    static struct cpsw_slave_data cpsw_slaves[] = {
            .slave_reg_ofs    = 0x208,
            .sliver_reg_ofs    = 0xd80,
            .phy_addr    = 1,
            .slave_reg_ofs    = 0x308,
            .sliver_reg_ofs    = 0xdc0,
            .phy_addr    = 2,
    static struct cpsw_platform_data cpsw_data = {
        .mdio_base        = CPSW_MDIO_BASE,
        .cpsw_base        = CPSW_BASE,
        .mdio_div        = 0xff,
        .channels        = 8,
        .cpdma_reg_ofs        = 0x800,
        .slaves            = 1,
        .slave_data        = cpsw_slaves,
        .ale_reg_ofs        = 0xd00,
        .ale_entries        = 1024,
        .host_port_reg_ofs    = 0x108,
        .hw_stats_reg_ofs    = 0x900,
        .bd_ram_ofs        = 0x2000,
        .mac_control        = (1 << 5),
        .control        = cpsw_control,
        .host_port_num        = 0,
        .version        = CPSW_CTRL_VERSION_2,
    static u64 mac_to_u64(u8 mac[6])
        int i;
        u64 addr = 0;
        for (i = 0; i < 6; i++) {
            addr <<= 8;
            addr |= mac[i];
        return addr;
    static void u64_to_mac(u64 addr, u8 mac[6])
        mac[5] = addr;
        mac[4] = addr >> 8;
        mac[3] = addr >> 16;
        mac[2] = addr >> 24;
        mac[1] = addr >> 32;
        mac[0] = addr >> 40;
    int board_eth_init(bd_t *bis)
        int ret;
        uint8_t mac_addr[6];
        uint32_t mac_hi, mac_lo;
        uint32_t ctrl_val;
        int i;
        u64 mac1, mac2;
        u8 mac_addr1[6], mac_addr2[6];
        int num_macs;
        /* try reading mac address from efuse */
        mac_lo = readl((*ctrl)->control_core_mac_id_0_lo);
        mac_hi = readl((*ctrl)->control_core_mac_id_0_hi);
        mac_addr[0] = (mac_hi & 0xFF0000) >> 16;
        mac_addr[1] = (mac_hi & 0xFF00) >> 8;
        mac_addr[2] = mac_hi & 0xFF;
        mac_addr[3] = (mac_lo & 0xFF0000) >> 16;
        mac_addr[4] = (mac_lo & 0xFF00) >> 8;
        mac_addr[5] = mac_lo & 0xFF;
        if (!env_get("ethaddr")) {
            printf("<ethaddr> not set. Validating first E-fuse MAC\n");
            if (is_valid_ethaddr(mac_addr))
                eth_env_set_enetaddr("ethaddr", mac_addr);
        mac_lo = readl((*ctrl)->control_core_mac_id_1_lo);
        mac_hi = readl((*ctrl)->control_core_mac_id_1_hi);
        if (!env_get("eth1addr")) {
                eth_env_set_enetaddr("eth1addr", mac_addr);
        ctrl_val = readl((*ctrl)->control_core_control_io1) & (~0x33);
        ctrl_val |= 0x22;
        writel(ctrl_val, (*ctrl)->control_core_control_io1);
        /* The phy address for the AM57xx IDK are different than x15 */
        if (board_is_am572x_idk() || board_is_am571x_idk() ||
            cpsw_data.slave_data[0].phy_addr = 0;
            cpsw_data.slave_data[1].phy_addr = 1;
        ret = cpsw_register(&cpsw_data);
        if (ret < 0)
            printf("Error %d registering CPSW switch\n", ret);
         * Export any Ethernet MAC addresses from EEPROM.
         * On AM57xx the 2 MAC addresses define the address range
        board_ti_get_eth_mac_addr(0, mac_addr1);
        board_ti_get_eth_mac_addr(1, mac_addr2);
        if (is_valid_ethaddr(mac_addr1) && is_valid_ethaddr(mac_addr2)) {
            mac1 = mac_to_u64(mac_addr1);
            mac2 = mac_to_u64(mac_addr2);
            /* must contain an address range */
            num_macs = mac2 - mac1 + 1;
            /* <= 50 to protect against user programming error */
            if (num_macs > 0 && num_macs <= 50) {
                for (i = 0; i < num_macs; i++) {
                    u64_to_mac(mac1 + i, mac_addr);
                    if (is_valid_ethaddr(mac_addr)) {
                        eth_env_set_enetaddr_by_index("eth",
                                          i + 2,
                                          mac_addr);
        return ret;
    #endif
    #ifdef CONFIG_BOARD_EARLY_INIT_F
    /* VTT regulator enable */
    static inline void vtt_regulator_enable(void)
        if (omap_hw_init_context() == OMAP_INIT_CONTEXT_UBOOT_AFTER_SPL)
            return;
        gpio_request(GPIO_DDR_VTT_EN, "ddr_vtt_en");
        gpio_direction_output(GPIO_DDR_VTT_EN, 1);
    int board_early_init_f(void)
        vtt_regulator_enable();
        return 0;
    #endif
    #if defined(CONFIG_OF_LIBFDT) && defined(CONFIG_OF_BOARD_SETUP)
    int ft_board_setup(void *blob, bd_t *bd)
        ft_cpu_setup(blob, bd);
        return 0;
    #endif
    #ifdef CONFIG_SPL_LOAD_FIT
    int board_fit_config_name_match(const char *name)
            if (board_is_x15_revb1()) {
                if (!strcmp(name, "am57xx-beagle-x15-revb1"))
                    return 0;
            } else if (board_is_x15_revc()) {
                if (!strcmp(name, "am57xx-beagle-x15-revc"))
                    return 0;
            } else if (!strcmp(name, "am57xx-beagle-x15")) {
                return 0;
        } else if (board_is_am572x_evm() &&
            return 0;
        } else if (board_is_am572x_idk() && !strcmp(name, "am572x-idk")) {
            return 0;
        } else if (board_is_am574x_idk() && !strcmp(name, "am574x-idk")) {
            return 0;
        } else if (board_is_am571x_idk() && !strcmp(name, "am571x-idk")) {
            return 0;
        } else if (board_is_bbai() && !strcmp(name, "am5729-beagleboneai")) {
            return 0;
        return -1;
    #endif
        /* Check that boot mode is same as BBAI */
        if (gd->arch.omap_boot_mode != 2)
            return -EIO;
        return 0;
    #endif
    #ifdef CONFIG_TI_SECURE_DEVICE
    void board_fit_image_post_process(void **p_image, size_t *p_size)
        secure_boot_verify_image(p_image, p_size);
    void board_tee_image_process(ulong tee_image, size_t tee_size)
        secure_tee_install((u32)tee_image);
    #if CONFIG_IS_ENABLED(FASTBOOT) && !CONFIG_IS_ENABLED(ENV_IS_NOWHERE)
    int fastboot_set_reboot_flag(void)
        printf("Setting reboot to fastboot flag ...\n");
        env_set("dofastboot", "1");
        env_save();
        return 0;
    #endif
    U_BOOT_FIT_LOADABLE_HANDLER(IH_TYPE_TEE, board_tee_image_process);
    #endif
  • Boot Log:
    U-Boot SPL 2019.01-g54a57c4-dirty (Aug 24 2020 - 09:44:31 +0200)
    DRA762-GP ES1.0 ABZ package
    Trying to boot from MMC1
    Loading Environment from FAT... *** Warning - bad CRC, using default environment
    Loading Environment from MMC... Card did not respond to voltage select!
    *** Warning - No block device, using default environment
    U-Boot 2019.01-g54a57c4-dirty (Aug 24 2020 - 09:44:31 +0200)
    CPU  : DRA762-GP ES1.0 ABZ package
    Model: TI AM5748 IDK
    DRAM:  2 GiB
    MMC:   OMAP SD/MMC: 0, OMAP SD/MMC: 1
    Warning: fastboot.board_rev: unknown board revision
    invalid mmc device
    am57x_idk_lcd_detect: Failed to get I2C device 0/56 (ret 1)
    Net:
    Warning: ethernet@48484000 using MAC address from ROM
    eth0: ethernet@48484000
    Hit any key to stop autoboot:  2  1  0
    switch to partitions #0, OK
    mmc0 is current device
    SD/MMC found on device 0
    ** Unable to read file boot.scr **
    ** Unable to read file uEnv.txt **
    4448768 bytes read in 198 ms (21.4 MiB/s)
    90792 bytes read in 6 ms (14.4 MiB/s)
       Loading Device Tree to 8ffe6000, end 8ffff2a7 ... OK
    Starting kernel ...
    [    0.000000] Booting Linux on physical CPU 0x0
    [    0.000000] Linux version 4.19.94-gbe5389fd85 (oe-user@oe-host) (gcc version 8.3.0 (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36))) #1 SMP PREEMPT Sun Apr 19 02:36:36 UTC 2020
    [    0.000000] CPU: ARMv7 Processor [412fc0f2] revision 2 (ARMv7), cr=30c5387d
    [    0.000000] CPU: div instructions available: patching division code
    [    0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
    [    0.000000] OF: fdt: Machine model: TI AM5728 BeagleBoard-X15
    [    0.000000] Memory policy: Data cache writealloc
    [    0.000000] efi: Getting EFI parameters from FDT:
    [    0.000000] efi: UEFI not found.
    [    0.000000] Reserved memory: created CMA memory pool at 0x0000000095800000, size 56 MiB
    [    0.000000] OF: reserved mem: initialized node ipu2-memory@95800000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created CMA memory pool at 0x0000000099000000, size 64 MiB
    [    0.000000] OF: reserved mem: initialized node dsp1-memory@99000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x000000009d000000, size 32 MiB
    [    0.000000] OF: reserved mem: initialized node ipu1-memory@9d000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created CMA memory pool at 0x000000009f000000, size 8 MiB
    [    0.000000] OF: reserved mem: initialized node dsp2-memory@9f000000, compatible id shared-dma-pool
    [    0.000000] cma: Reserved 24 MiB at 0x00000000fe400000
    [    0.000000] OMAP4: Map 0x00000000ffd00000 to (ptrval) for dram barrier
    [    0.000000] Hit pending asynchronous external abort (FSR=0x00001211) during first unmask, this is most likely caused by a firmware/bootloader bug.
    [    0.000000] DRA762 ES1.0
    [    0.000000] random: get_random_bytes called from start_kernel+0xb4/0x470 with crng_init=0
    [    0.000000] percpu: Embedded 15 pages/cpu s32396 r8192 d20852 u61440
    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 464192
    [    0.000000] Kernel command line: console=ttyS2,115200n8 root=PARTUUID=f402ab8b-02 rw rootfstype=ext4 rootwait
    [    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
    [    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
    [    0.000000] Memory: 1673056K/1863680K available (10240K kernel code, 335K rwdata, 2800K rodata, 2048K init, 268K bss, 34976K reserved, 155648K cma-reserved, 1283072K highmem)
    [    0.000000] Virtual kernel memory layout:
    [    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
    [    0.000000]     fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
    [    0.000000]     vmalloc : 0xf0800000 - 0xff800000   ( 240 MB)
    [    0.000000]     lowmem  : 0xc0000000 - 0xf0000000   ( 768 MB)
    [    0.000000]     pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
    [    0.000000]     modules : 0xbf000000 - 0xbfe00000   (  14 MB)
    [    0.000000]       .text : 0x(ptrval) - 0x(ptrval)   (12256 kB)
    [    0.000000]       .init : 0x(ptrval) - 0x(ptrval)   (2048 kB)
    [    0.000000]       .data : 0x(ptrval) - 0x(ptrval)   ( 336 kB)
    [    0.000000]        .bss : 0x(ptrval) - 0x(ptrval)   ( 269 kB)
    [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
    [    0.000000] rcu: Preemptible hierarchical RCU implementation.
    [    0.000000] Tasks RCU enabled.
    [    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
    [    0.000000] GIC: Using split EOI/Deactivate mode
    [    0.000000] OMAP clockevent source: timer1 at 32786 Hz
    [    0.000000] arch_timer: cp15 timer(s) running at 6.14MHz (phys).
    [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x16af5adb9, max_idle_ns: 440795202250 ns
    [    0.000005] sched_clock: 56 bits at 6MHz, resolution 162ns, wraps every 4398046511023ns
    [    0.000018] Switching to timer-based delay loop, resolution 162ns
    [    0.000293] clocksource: 32k_counter: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 58327039986419 ns
    [    0.000303] OMAP clocksource: 32k_counter at 32768 Hz
    [    0.000727] Console: colour dummy device 80x30
    [    0.000769] Calibrating delay loop (skipped), value calculated using timer frequency.. 12.29 BogoMIPS (lpj=61475)
    [    0.000784] pid_max: default: 32768 minimum: 301
    [    0.000903] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
    [    0.000918] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
    [    0.001468] CPU: Testing write buffer coherency: ok
    [    0.001503] CPU0: Spectre v2: using ICIALLU workaround
    [    0.001707] /cpus/cpu@0 missing clock-frequency property
    [    0.001727] /cpus/cpu@1 missing clock-frequency property
    [    0.001741] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
    [    0.059905] Setting up static identity map for 0x80200000 - 0x80200060
    [    0.079911] rcu: Hierarchical SRCU implementation.
    [    0.100097] EFI services will not be available.
    [    0.119963] smp: Bringing up secondary CPUs ...
    [    0.200327] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
    [    0.200333] CPU1: Spectre v2: using ICIALLU workaround
    [    0.200455] smp: Brought up 1 node, 2 CPUs
    [    0.200468] SMP: Total of 2 processors activated (24.59 BogoMIPS).
    [    0.200477] CPU: All CPU(s) started in HYP mode.
    [    0.200485] CPU: Virtualization extensions available.
    [    0.201036] devtmpfs: initialized
    [    0.217273] VFP support v0.3: implementor 41 architecture 4 part 30 variant f rev 0
    [    0.217529] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
    [    0.217547] futex hash table entries: 512 (order: 3, 32768 bytes)
    [    0.220179] pinctrl core: initialized pinctrl subsystem
    [    0.220705] DMI not present or invalid.
    [    0.220976] NET: Registered protocol family 16
    [    0.222092] DMA: preallocated 256 KiB pool for atomic coherent allocations
    [    0.223009] omap_hwmod: l3_main_2 using broken dt data from ocp
    [    0.415546] cpuidle: using governor ladder
    [    0.415582] cpuidle: using governor menu
    [    0.425957] OMAP GPIO hardware version 0.1
    [    0.450235] No ATAGs?
    [    0.450307] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
    [    0.450322] hw-breakpoint: maximum watchpoint size is 8 bytes.
    [    0.451176] OMAP DMA hardware revision 0.0
    [    0.462547] edma 43300000.edma: memcpy is disabled
    [    0.465962] edma 43300000.edma: TI EDMA DMA engine driver
    [    0.473272] omap-dma-engine 4a056000.dma-controller: OMAP DMA engine driver (LinkedList1/2/3 supported)
    [    0.474053] evm_5v0: supplied by main_12v0
    [    0.477357] omap-iommu 40d01000.mmu: 40d01000.mmu registered
    [    0.477537] omap-iommu 40d02000.mmu: 40d02000.mmu registered
    [    0.477779] omap-iommu 58882000.mmu: 58882000.mmu registered
    [    0.478033] omap-iommu 55082000.mmu: 55082000.mmu registered
    [    0.478402] omap-iommu 41501000.mmu: 41501000.mmu registered
    [    0.478574] omap-iommu 41502000.mmu: 41502000.mmu registered
    [    0.478853] iommu: Adding device 58820000.ipu to group 1
    [    0.478934] iommu: Adding device 55020000.ipu to group 2
    [    0.479059] iommu: Adding device 40800000.dsp to group 0
    [    0.479284] iommu: Adding device 41000000.dsp to group 3
    [    0.480554] SCSI subsystem initialized
    [    0.481584] palmas 0-0058: Irq flag is 0x00000008
    [    0.513678] palmas 0-0058: Muxing GPIO 2b, PWM 0, LED 0
    [    0.520376] SMPS12: supplied by regulator-dummy
    [    0.523157] random: fast init done
    [    0.529039] SMPS3: supplied by regulator-dummy
    [    0.536833] SMPS45: supplied by regulator-dummy
    [    0.546345] SMPS6: supplied by regulator-dummy
    [    0.553282] SMPS7: supplied by regulator-dummy
    [    0.560211] SMPS8: supplied by regulator-dummy
    [    0.561972] smps8: Bringing 1060000uV into 1800000-1800000uV
    [    0.563720] smps8: failed to apply 1800000-1800000uV constraint(-22)
    [    0.563737] palmas-pmic 48070000.i2c:tps659038@58:tps659038_pmic: failed to register 48070000.i2c:tps659038@58:tps659038_pmic regulator
    [    0.564984] palmas-pmic: probe of 48070000.i2c:tps659038@58:tps659038_pmic failed with error -22
    [    0.566977] omap_i2c 48070000.i2c: bus 0 rev0.12 at 400 kHz
    [    0.567777] omap_i2c 48060000.i2c: bus 2 rev0.12 at 400 kHz
    [    0.568145] media: Linux media interface: v0.10
    [    0.568184] videodev: Linux video capture interface: v2.00
    [    0.568282] pps_core: LinuxPPS API ver. 1 registered
    [    0.568310] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [    0.568333] PTP clock support registered
    [    0.568386] EDAC MC: Ver: 3.0.0
    [    0.569440] omap-mailbox 48840000.mailbox: omap mailbox rev 0x400
    [    0.569803] omap-mailbox 48842000.mailbox: omap mailbox rev 0x400
    [    0.570815] Advanced Linux Sound Architecture Driver Initialized.
    [    0.571867] clocksource: Switched to clocksource arch_sys_counter
    [    0.584773] NET: Registered protocol family 2
    [    0.585552] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes)
    [    0.585585] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
    [    0.585668] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
    [    0.585861] TCP: Hash tables configured (established 8192 bind 8192)
    [    0.585953] UDP hash table entries: 512 (order: 2, 16384 bytes)
    [    0.586008] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
    [    0.586182] NET: Registered protocol family 1
    [    0.586770] RPC: Registered named UNIX socket transport module.
    [    0.586782] RPC: Registered udp transport module.
    [    0.586791] RPC: Registered tcp transport module.
    [    0.586824] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    0.588166] hw perfevents: no interrupt-affinity property for /pmu, guessing.
    [    0.588385] hw perfevents: enabled with armv7_cortex_a15 PMU driver, 7 counters available
    [    0.589773] Initialise system trusted keyrings
    [    0.589959] workingset: timestamp_bits=14 max_order=19 bucket_order=5
    [    0.597332] squashfs: version 4.0 (2009/01/31) Phillip Lougher
    [    0.597982] NFS: Registering the id_resolver key type
    [    0.598018] Key type id_resolver registered
    [    0.598046] Key type id_legacy registered
    [    0.598086] ntfs: driver 2.1.32 [Flags: R/O].
    [    0.600420] Key type asymmetric registered
    [    0.600432] Asymmetric key parser 'x509' registered
    [    0.600502] bounce: pool size: 64 pages
    [    0.600540] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
    [    0.600551] io scheduler noop registered
    [    0.600579] io scheduler deadline registered
    [    0.600707] io scheduler cfq registered (default)
    [    0.600718] io scheduler mq-deadline registered
    [    0.600746] io scheduler kyber registered
    [    0.608554] pinctrl-single 4a003400.pinmux: 282 pins, size 1128
    [    0.613834] dra7-pcie 51000000.pcie: Linked as a consumer to phy-4a094000.pciephy.1
    [    0.614402] dra7-pcie 51000000.pcie: host bridge /ocp/axi@0/pcie@51000000 ranges:
    [    0.614469] dra7-pcie 51000000.pcie:    IO 0x20003000..0x20012fff -> 0x00000000
    [    0.614521] dra7-pcie 51000000.pcie:   MEM 0x20013000..0x2fffffff -> 0x20013000
    [    1.157878] random: crng init done
    [    1.612062] dra7-pcie 51000000.pcie: Phy link never came up
    [    1.612268] dra7-pcie 51000000.pcie: PCI host bridge to bus 0000:00
    [    1.612284] pci_bus 0000:00: root bus resource [bus 00-ff]
    [    1.612297] pci_bus 0000:00: root bus resource [io  0x0000-0xffff]
    [    1.612309] pci_bus 0000:00: root bus resource [mem 0x20013000-0x2fffffff]
    [    1.618840] PCI: bus0: Fast back to back transfers disabled
    [    1.624749] PCI: bus1: Fast back to back transfers enabled
    [    1.624808] pci 0000:00:00.0: BAR 0: assigned [mem 0x20100000-0x201fffff 64bit]
    [    1.624829] pci 0000:00:00.0: PCI bridge to [bus 01-ff]
    [    1.625254] pcieport 0000:00:00.0: Signaling PME with IRQ 170
    [    1.625433] pcieport 0000:00:00.0: AER enabled with IRQ 170
    [    1.703858] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
    [    1.709034] console [ttyS2] disabled
    [    1.709108] 48020000.serial: ttyS2 at MMIO 0x48020000 (irq = 45, base_baud = 3000000) is a 8250
    [    2.774955] console [ttyS2] enabled
    [    2.781277] omap_rng 48090000.rng: Random Number Generator ver. 20
    [    2.807072] brd: module loaded
    [    2.818949] loop: module loaded
    [    2.827694] libphy: Fixed MDIO Bus: probed
    [    2.891893] davinci_mdio 48485000.mdio: davinci mdio revision 1.6, bus freq 1000000
    [    2.899606] libphy: 48485000.mdio: probed
    [    2.907302] mdio_bus 48485000.mdio: MDIO device at address 2 is missing.
    [    2.914075] davinci_mdio 48485000.mdio: phy[1]: device 48485000.mdio:01, driver Micrel KSZ9031 Gigabit PHY
    [    2.924538] cpsw 48484000.ethernet: Detected MACID = 90:9a:77:57:03:6c
    [    2.931173] cpsw 48484000.ethernet: initialized cpsw ale version 1.4
    [    2.937598] cpsw 48484000.ethernet: ALE Table size 1024
    [    2.942927] cpsw 48484000.ethernet: cpts: overflow check period 500 (jiffies)
    [    2.951308] cpsw 48484000.ethernet: cpsw: Detected MACID = 90:9a:77:57:03:6d
    [    2.960136] i2c /dev entries driver
    [    2.969634] gpio-fan gpio_fan: GPIO fan initialized
    [    2.976122] tmp102 0-0048: error reading config register
    [    2.981599] tmp102: probe of 0-0048 failed with error -121
    [    2.991472] sdhci: Secure Digital Host Controller Interface driver
    [    2.997723] sdhci: Copyright(c) Pierre Ossman
    [    3.003608] sdhci-pltfm: SDHCI platform and OF driver helper
    [    3.010583] omap_gpio 4805d000.gpio: Could not set line 27 debounce to 200000 microseconds (-22)
    [    3.019475] sdhci-omap 4809c000.mmc: Got CD GPIO
    [    3.024460] sdhci-omap 4809c000.mmc: Linked as a consumer to regulator.12
    [    3.031337] sdhci-omap 4809c000.mmc: 4809c000.mmc supply vqmmc not found, using dummy regulator
    [    3.040164] sdhci-omap 4809c000.mmc: Linked as a consumer to regulator.0
    [    3.047037] sdhci-omap 4809c000.mmc: Dropping the link to regulator.0
    [    3.053677] sdhci-omap 4809c000.mmc: Dropping the link to regulator.12
    [    3.060946] sdhci-omap 480b4000.mmc: failed to set system capabilities
    [    3.069321] ledtrig-cpu: registered to indicate activity on CPUs
    [    3.083952] l4per_cm:clk:0168:0: failed to enable
    [    3.088693] ------------[ cut here ]------------
    [    3.088738] ------------[ cut here ]------------
    [    3.093350] WARNING: CPU: 0 PID: 0 at drivers/bus/omap_l3_noc.c:147 l3_interrupt_handler+0x330/0x380
    [    3.097979] WARNING: CPU: 1 PID: 32 at drivers/clk/clk.c:828 clk_core_disable+0xa4/0xa8
    [    3.107137] 44000000.ocp:L3 Custom Error: MASTER MPU TARGET L4_PER2_P3 (Idle): Data Access in Supervisor mode during Functional access
    [    3.115168] l4per_cm:clk:0168:0 already disabled
    [    3.127299] Modules linked in:
    [    3.131929] Modules linked in:
    [    3.134994] CPU: 0 PID: 0 Comm: swapper/0 Not tainted 4.19.94-gbe5389fd85 #1
    [    3.145124] Hardware name: Generic DRA74X (Flattened Device Tree)
    [    3.151242] Backtrace:
    [    3.153708] [<c020ca34>] (dump_backtrace) from [<c020cd6c>] (show_stack+0x18/0x1c)
    [    3.161313]  r7:c0dfdec4 r6:60000193 r5:00000000 r4:c12506dc
    [    3.167005] [<c020cd54>] (show_stack) from [<c0a15124>] (dump_stack+0x9c/0xb0)
    [    3.174264] [<c0a15088>] (dump_stack) from [<c022e100>] (__warn+0xdc/0xf8)
    [    3.181169]  r7:c0dfdec4 r6:00000009 r5:00000000 r4:c1201cbc
    [    3.186856] [<c022e024>] (__warn) from [<c022dd38>] (warn_slowpath_fmt+0x50/0x6c)
    [    3.194372]  r9:ee9d39c0 r8:f0882564 r7:c0dfddf0 r6:c0dfdd30 r5:c0dfde94 r4:c1204c48
    [    3.202154] [<c022dcec>] (warn_slowpath_fmt) from [<c056711c>] (l3_interrupt_handler+0x330/0x380)
    [    3.211064]  r3:ee9d7f00 r2:c0dfde94
    [    3.214654]  r5:00000000 r4:80080003
    [    3.218252] [<c0566dec>] (l3_interrupt_handler) from [<c02895ec>] (__handle_irq_event_percpu+0x68/0x140)
    [    3.227775]  r10:c12522f8 r9:ee9d9f00 r8:00000017 r7:c1201de8 r6:00000000 r5:ee9d9f68
    [    3.235638]  r4:eea183c0
    [    3.238187] [<c0289584>] (__handle_irq_event_percpu) from [<c02896f8>] (handle_irq_event_percpu+0x34/0x88)
    [    3.247884]  r10:c10684f0 r9:c1200000 r8:ee80c000 r7:00000001 r6:ee9d9f00 r5:ee9d9f68
    [    3.255746]  r4:c1204c48
    [    3.258295] [<c02896c4>] (handle_irq_event_percpu) from [<c028978c>] (handle_irq_event+0x40/0x64)
    [    3.267205]  r6:c120a434 r5:ee9d9f68 r4:ee9d9f00
    [    3.271846] [<c028974c>] (handle_irq_event) from [<c028d4dc>] (handle_fasteoi_irq+0xc0/0x168)
    [    3.280408]  r7:00000001 r6:c120a434 r5:ee9d9f68 r4:ee9d9f00
    [    3.286095] [<c028d41c>] (handle_fasteoi_irq) from [<c02887e8>] (generic_handle_irq+0x2c/0x3c)
    [    3.294744]  r7:00000001 r6:00000000 r5:00000000 r4:c1068cfc
    [    3.300432] [<c02887bc>] (generic_handle_irq) from [<c0288e4c>] (__handle_domain_irq+0x64/0xbc)
    [    3.309171] [<c0288de8>] (__handle_domain_irq) from [<c0565458>] (gic_handle_irq+0x44/0x80)
    [    3.317560]  r9:c1200000 r8:fa213000 r7:c1201eb0 r6:fa212000 r5:fa21200c r4:c1205104
    [    3.325340] [<c0565414>] (gic_handle_irq) from [<c02019f8>] (__irq_svc+0x58/0x8c)
    [    3.332855] Exception stack(0xc1201eb0 to 0xc1201ef8)
    [    3.337929] 1ea0:                                     00000000 0002f8e8 eed5750c c021ab60
    [    3.346143] 1ec0: ffffe000 c1204c7c c1204cc4 00000001 00000000 00000000 c10684f0 c1201f0c
    [    3.354358] 1ee0: c1201f10 c1201f00 c0208ea8 c0208eac 60000113 ffffffff
    [    3.361003]  r9:c1200000 r8:00000000 r7:c1201ee4 r6:ffffffff r5:60000113 r4:c0208eac
    [    3.368786] [<c0208e6c>] (arch_cpu_idle) from [<c0a2f17c>] (default_idle_call+0x30/0x34)
    [    3.376917] [<c0a2f14c>] (default_idle_call) from [<c025a9a8>] (do_idle+0x204/0x2ac)
    [    3.384697] [<c025a7a4>] (do_idle) from [<c025ad3c>] (cpu_startup_entry+0x20/0x24)
    [    3.392301]  r10:c104ba38 r9:c1253e00 r8:ffffffff r7:c1253e00 r6:00000000 r5:00000002
    [    3.400163]  r4:000000c7
    [    3.402710] [<c025ad1c>] (cpu_startup_entry) from [<c0a29424>] (rest_init+0xd0/0xd4)
    [    3.410492] [<c0a29354>] (rest_init) from [<c1000dfc>] (start_kernel+0x448/0x470)
    [    3.418006]  r5:00000000 r4:c1253e58
    [    3.421599] [<c10009b4>] (start_kernel) from [<00000000>] (  (null))
    [    3.427983]  r10:30c5387d r9:412fc0f2 r8:8ffe6000 r7:00000000 r6:30c0387d r5:00000000
    [    3.435846]  r4:c1000330
    [    3.438392] CPU: 1 PID: 32 Comm: kworker/1:1 Not tainted 4.19.94-gbe5389fd85 #1
    [    3.438395] ---[ end trace 200ff3becaf4cb22 ]---
    [    3.438461] davinci-mcasp 48468000.mcasp: ERRATA i868 workaround is enabled
    [    3.445731] Hardware name: Generic DRA74X (Flattened Device Tree)
    [    3.445742] Workqueue: pm pm_runtime_work
    [    3.445747] Backtrace:
    [    3.445760] [<c020ca34>] (dump_backtrace) from [<c020cd6c>] (show_stack+0x18/0x1c)
    [    3.477554]  r7:c0e0a1a8 r6:60000193 r5:00000000 r4:c12506dc
    [    3.483242] [<c020cd54>] (show_stack) from [<c0a15124>] (dump_stack+0x9c/0xb0)
    [    3.490500] [<c0a15088>] (dump_stack) from [<c022e100>] (__warn+0xdc/0xf8)
    [    3.497406]  r7:c0e0a1a8 r6:00000009 r5:00000000 r4:eeb91cfc
    [    3.503093] [<c022e024>] (__warn) from [<c022dd38>] (warn_slowpath_fmt+0x50/0x6c)
    [    3.510611]  r9:eeb91d88 r8:00000000 r7:00000020 r6:c1210b2c r5:c0e0a258 r4:c1204c48
    [    3.518393] [<c022dcec>] (warn_slowpath_fmt) from [<c05d181c>] (clk_core_disable+0xa4/0xa8)
    [    3.526780]  r3:ee83b780 r2:c0e0a258
    [    3.530369]  r5:ee839a80 r4:ee839a80
    [    3.533966] [<c05d1778>] (clk_core_disable) from [<c05d1840>] (clk_core_disable_lock+0x20/0x2c)
    [    3.542701]  r5:ee839a80 r4:80000193
    [    3.546297] [<c05d1820>] (clk_core_disable_lock) from [<c05d1870>] (clk_disable+0x24/0x28)
    [    3.554596]  r5:c125446c r4:c1210b2c
    [    3.558191] [<c05d184c>] (clk_disable) from [<c021d66c>] (_disable_clocks+0x20/0x98)
    [    3.565972] [<c021d64c>] (_disable_clocks) from [<c021e254>] (_idle+0x188/0x248)
    [    3.573401]  r7:00000020 r6:c1204c48 r5:c125446c r4:c1210b2c
    [    3.579088] [<c021e0cc>] (_idle) from [<c021ff08>] (omap_hwmod_idle+0x2c/0x4c)
    [    3.586344]  r9:c1204c48 r8:c0220a94 r7:c1203d00 r6:a0000113 r5:c1210b78 r4:c1210b2c
    [    3.594125] [<c021fedc>] (omap_hwmod_idle) from [<c0220a40>] (omap_device_idle+0x48/0x9c)
    [    3.602337]  r7:c1203d00 r6:00000001 r5:eea79f00 r4:00000000
    [    3.608025] [<c02209f8>] (omap_device_idle) from [<c0220ab8>] (_od_runtime_suspend+0x24/0x28)
    [    3.616586]  r7:c1203d00 r6:eea92688 r5:00000000 r4:eea92610
    [    3.622272] [<c0220a94>] (_od_runtime_suspend) from [<c06d1e2c>] (__rpm_callback+0x14c/0x1e0)
    [    3.630833]  r5:00000000 r4:eea92610
    [    3.634426] [<c06d1ce0>] (__rpm_callback) from [<c06d1ee8>] (rpm_callback+0x28/0x88)
    [    3.642205]  r10:ffffe000 r9:c1204c48 r8:00000008 r7:c1203d00 r6:c0220a94 r5:00000000
    [    3.650067]  r4:eea92610
    [    3.652613] [<c06d1ec0>] (rpm_callback) from [<c06d0f40>] (rpm_suspend+0x148/0x518)
    [    3.660303]  r7:c1203d00 r6:c0220a94 r5:00000000 r4:eea92610
    [    3.665988] [<c06d0df8>] (rpm_suspend) from [<c06d149c>] (rpm_idle+0xc8/0x148)
    [    3.673244]  r10:00000000 r9:eea926c8 r8:eea926d4 r7:00000000 r6:00000002 r5:00000000
    [    3.681106]  r4:eea92610
    [    3.683653] [<c06d13d4>] (rpm_idle) from [<c06d26a8>] (pm_runtime_work+0x94/0x98)
    [    3.691169]  r9:eea926c8 r8:00000000 r7:eed6d200 r6:eed68d80 r5:eea92688 r4:eea926c4
    [    3.698949] [<c06d2614>] (pm_runtime_work) from [<c02464d0>] (process_one_work+0x1f4/0x404)
    [    3.707334]  r5:ee9ec880 r4:eea926c4
    [    3.710928] [<c02462dc>] (process_one_work) from [<c02472a4>] (worker_thread+0x58/0x568)
    [    3.719054]  r10:eed68d80 r9:c1203d00 r8:eed68d98 r7:00000008 r6:eed68d80 r5:ee9ec894
    [    3.726917]  r4:ee9ec880
    [    3.729464] [<c024724c>] (worker_thread) from [<c024c7b4>] (kthread+0x160/0x168)
    [    3.736894]  r10:ee8cfe74 r9:c024724c r8:ee9ec880 r7:eeb90000 r6:00000000 r5:ee9ee0c0
    [    3.744755]  r4:eeb68c80
    [    3.747304] [<c024c654>] (kthread) from [<c02010d8>] (ret_from_fork+0x14/0x3c)
    [    3.754556] Exception stack(0xeeb91fb0 to 0xeeb91ff8)
    [    3.759631] 1fa0:                                     00000000 00000000 00000000 00000000
    [    3.767845] 1fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [    3.776058] 1fe0: 00000000 00000000 00000000 00000000 00000013 00000000
    [    3.782702]  r10:00000000 r9:00000000 r8:00000000 r7:00000000 r6:00000000 r5:c024c654
    [    3.790563]  r4:ee9ee0c0
    [    3.793107] ---[ end trace 200ff3becaf4cb23 ]---
    [    3.799848] l4per_cm:clk:0168:0: failed to enable
    [    3.804595] ------------[ cut here ]------------
    [    3.809238] WARNING: CPU: 0 PID: 1 at drivers/bus/omap_l3_noc.c:147 l3_interrupt_handler+0x330/0x380
    [    3.818411] 44000000.ocp:L3 Custom Error: MASTER MPU TARGET L4_PER2_P3 (Idle): Data Access in Supervisor mode during Functional access
    [    3.830546] Modules linked in:
    [    3.833617] CPU: 0 PID: 1 Comm: swapper/0 Tainted: G        W         4.19.94-gbe5389fd85 #1
    [    3.842089] Hardware name: Generic DRA74X (Flattened Device Tree)
    [    3.848206] Backtrace:
    [    3.850668] [<c020ca34>] (dump_backtrace) from [<c020cd6c>] (show_stack+0x18/0x1c)
    [    3.858271]  r7:c0dfdec4 r6:60000193 r5:00000000 r4:c12506dc
    [    3.863959] [<c020cd54>] (show_stack) from [<c0a15124>] (dump_stack+0x9c/0xb0)
    [    3.871217] [<c0a15088>] (dump_stack) from [<c022e100>] (__warn+0xdc/0xf8)
    [    3.878122]  r7:c0dfdec4 r6:00000009 r5:00000000 r4:ee88f86c
    [    3.883807] [<c022e024>] (__warn) from [<c022dd38>] (warn_slowpath_fmt+0x50/0x6c)
    [    3.891323]  r9:ee9d39c0 r8:f0882564 r7:c0dfddf0 r6:c0dfdd30 r5:c0dfde94 r4:c1204c48
    [    3.899104] [<c022dcec>] (warn_slowpath_fmt) from [<c056711c>] (l3_interrupt_handler+0x330/0x380)
    [    3.908014]  r3:ee9d7f00 r2:c0dfde94
    [    3.911603]  r5:00000000 r4:80080003
    [    3.915198] [<c0566dec>] (l3_interrupt_handler) from [<c02895ec>] (__handle_irq_event_percpu+0x68/0x140)
    [    3.924721]  r10:c12522f8 r9:ee9d9f00 r8:00000017 r7:ee88f998 r6:00000000 r5:ee9d9f68
    [    3.932584]  r4:eea183c0
    [    3.935133] [<c0289584>] (__handle_irq_event_percpu) from [<c02896f8>] (handle_irq_event_percpu+0x34/0x88)
    [    3.944831]  r10:ffffe000 r9:ee88e000 r8:ee80c000 r7:00000001 r6:ee9d9f00 r5:ee9d9f68
    [    3.952692]  r4:c1204c48
    [    3.955241] [<c02896c4>] (handle_irq_event_percpu) from [<c028978c>] (handle_irq_event+0x40/0x64)
    [    3.964153]  r6:c120a434 r5:ee9d9f68 r4:ee9d9f00
    [    3.968794] [<c028974c>] (handle_irq_event) from [<c028d4dc>] (handle_fasteoi_irq+0xc0/0x168)
    [    3.977356]  r7:00000001 r6:c120a434 r5:ee9d9f68 r4:ee9d9f00
    [    3.983042] [<c028d41c>] (handle_fasteoi_irq) from [<c02887e8>] (generic_handle_irq+0x2c/0x3c)
    [    3.991691]  r7:00000001 r6:ee88fb70 r5:00000000 r4:c1068cfc
    [    3.997378] [<c02887bc>] (generic_handle_irq) from [<c0288e4c>] (__handle_domain_irq+0x64/0xbc)
    [    4.006119] [<c0288de8>] (__handle_domain_irq) from [<c0565458>] (gic_handle_irq+0x44/0x80)
    [    4.014509]  r9:ee88e000 r8:fa213000 r7:ee88fa60 r6:fa212000 r5:fa21200c r4:c1205104
    [    4.022289] [<c0565414>] (gic_handle_irq) from [<c02019f8>] (__irq_svc+0x58/0x8c)
    [    4.029803] Exception stack(0xee88fa60 to 0xee88faa8)
    [    4.034879] fa60: 2dcf1000 00000000 2dcf1000 c1068d40 00000282 00000000 00000000 00000001
    [    4.043095] fa80: ee80c000 ee88e000 ffffe000 ee88fb0c 00204140 ee88fab0 00204140 c02020e0
    [    4.051307] faa0: 60000113 ffffffff
    [    4.054813]  r9:ee88e000 r8:ee80c000 r7:ee88fa94 r6:ffffffff r5:60000113 r4:c02020e0
    [    4.062595] [<c0202038>] (__do_softirq) from [<c0232f88>] (irq_exit+0xd4/0x110)
    [    4.069938]  r10:ffffe000 r9:ee88e000 r8:ee80c000 r7:00000001 r6:00000000 r5:00000000
    [    4.077800]  r4:c1068cfc
    [    4.080348] [<c0232eb4>] (irq_exit) from [<c0288e50>] (__handle_domain_irq+0x68/0xbc)
    [    4.088216] [<c0288de8>] (__handle_domain_irq) from [<c0565458>] (gic_handle_irq+0x44/0x80)
    [    4.096604]  r9:ee88e000 r8:fa213000 r7:ee88fb70 r6:fa212000 r5:fa21200c r4:c1205104
    [    4.104384] [<c0565414>] (gic_handle_irq) from [<c02019f8>] (__irq_svc+0x58/0x8c)
    [    4.111898] Exception stack(0xee88fb70 to 0xee88fbb8)
    [    4.116971] fb60:                                     c1210b78 a0000113 f7f8e87f 00000004
    [    4.125186] fb80: 00000000 c1210b78 a0000113 c0220964 c0220964 c0272ac0 ffffe000 ee88fbcc
    [    4.133400] fba0: ee88fbd0 ee88fbc0 c021fecc c0a2f61c 60000113 ffffffff
    [    4.140045]  r9:ee88e000 r8:c0220964 r7:ee88fba4 r6:ffffffff r5:60000113 r4:c0a2f61c
    [    4.147828] [<c0a2f5f4>] (_raw_spin_unlock_irqrestore) from [<c021fecc>] (omap_hwmod_enable+0x3c/0x4c)
    [    4.157178] [<c021fe90>] (omap_hwmod_enable) from [<c0220910>] (omap_device_enable+0x48/0x9c)
    [    4.165741]  r7:c0220964 r6:00000001 r5:eea79f00 r4:00000000
    [    4.171429] [<c02208c8>] (omap_device_enable) from [<c022097c>] (_od_runtime_resume+0x18/0x48)
    [    4.180078]  r7:c0220964 r6:eea92688 r5:00000000 r4:eea92610
    [    4.185765] [<c0220964>] (_od_runtime_resume) from [<c06d1e2c>] (__rpm_callback+0x14c/0x1e0)
    [    4.194240]  r5:00000000 r4:eea92610
    [    4.197832] [<c06d1ce0>] (__rpm_callback) from [<c06d1ee8>] (rpm_callback+0x28/0x88)
    [    4.205610]  r10:ffffe000 r9:c0272ac0 r8:00000004 r7:c0220964 r6:c1203d00 r5:eea12e10
    [    4.213472]  r4:eea92610
    [    4.216018] [<c06d1ec0>] (rpm_callback) from [<c06d1ad4>] (rpm_resume+0x4d0/0x670)
    [    4.223619]  r7:c0220964 r6:c1203d00 r5:eea12e10 r4:eea92610
    [    4.229305] [<c06d1604>] (rpm_resume) from [<c06d1cc8>] (__pm_runtime_resume+0x54/0x6c)
    [    4.237345]  r10:00000000 r9:00000000 r8:c1204c48 r7:60000113 r6:00000004 r5:eea92688
    [    4.245207]  r4:eea92610
    [    4.247757] [<c06d1c74>] (__pm_runtime_resume) from [<c08b4820>] (davinci_mcasp_probe+0x4c0/0xd6c)
    [    4.256755]  r7:edc996c0 r6:eea92610 r5:00000000 r4:edc8cc40
    [    4.262445] [<c08b4360>] (davinci_mcasp_probe) from [<c06c8368>] (platform_drv_probe+0x50/0xa0)
    [    4.271183]  r10:00000000 r9:c1248e54 r8:00000000 r7:00000000 r6:c1248e54 r5:00000000
    [    4.279044]  r4:eea92610
    [    4.281592] [<c06c8318>] (platform_drv_probe) from [<c06c63b8>] (really_probe+0x204/0x2c0)
    [    4.289892]  r7:00000000 r6:c128d988 r5:eea92610 r4:c128d984
    [    4.295580] [<c06c61b4>] (really_probe) from [<c06c6618>] (driver_probe_device+0x68/0x180)
    [    4.303883]  r10:c1060e8c r9:c104b834 r8:00000000 r7:c06c6730 r6:eea92644 r5:c1248e54
    [    4.311745]  r4:eea92610 r3:00000000
    [    4.315339] [<c06c65b0>] (driver_probe_device) from [<c06c6824>] (__driver_attach+0xf4/0xf8)
    [    4.323815]  r9:c104b834 r8:00000000 r7:c06c6730 r6:eea92644 r5:c1248e54 r4:eea92610
    [    4.331595] [<c06c6730>] (__driver_attach) from [<c06c4484>] (bus_for_each_dev+0x7c/0xbc)
    [    4.339808]  r7:c06c6730 r6:c1248e54 r5:c1204c48 r4:eea7b1b4
    [    4.345495] [<c06c4408>] (bus_for_each_dev) from [<c06c5cf0>] (driver_attach+0x24/0x28)
    [    4.353534]  r7:00000000 r6:edc99600 r5:c12370f0 r4:c1248e54
    [    4.359220] [<c06c5ccc>] (driver_attach) from [<c06c5768>] (bus_add_driver+0x1c4/0x208)
    [    4.367261] [<c06c55a4>] (bus_add_driver) from [<c06c71f4>] (driver_register+0x7c/0x110)
    [    4.375387]  r7:c1036e6c r6:ffffe000 r5:c1204c48 r4:c1248e54
    [    4.381074] [<c06c7178>] (driver_register) from [<c06c82cc>] (__platform_driver_register+0x48/0x50)
    [    4.390158]  r5:c1204c48 r4:c1253e00
    [    4.393755] [<c06c8284>] (__platform_driver_register) from [<c1036e88>] (davinci_mcasp_driver_init+0x1c/0x20)
    [    4.403716] [<c1036e6c>] (davinci_mcasp_driver_init) from [<c02025b8>] (do_one_initcall+0x84/0x1b0)
    [    4.412805] [<c0202534>] (do_one_initcall) from [<c1000fe8>] (kernel_init_freeable+0x1c4/0x258)
    [    4.421543]  r8:c104b854 r7:c10004f0 r6:c1253e00 r5:c1253e00 r4:00000007
    [    4.428277] [<c1000e24>] (kernel_init_freeable) from [<c0a29438>] (kernel_init+0x10/0x11c)
    [    4.436578]  r10:00000000 r9:00000000 r8:00000000 r7:00000000 r6:00000000 r5:c0a29428
    [    4.444439]  r4:00000000
    [    4.446986] [<c0a29428>] (kernel_init) from [<c02010d8>] (ret_from_fork+0x14/0x3c)
    [    4.454586] Exception stack(0xee88ffb0 to 0xee88fff8)
    [    4.459660] ffa0:                                     00000000 00000000 00000000 00000000
    [    4.467874] ffc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [    4.476088] ffe0: 00000000 00000000 00000000 00000000 00000013 00000000
    [    4.482730]  r5:c0a29428 r4:00000000
    [    4.486319] ---[ end trace 200ff3becaf4cb24 ]---
    [    4.491133] ------------[ cut here ]------------
    [    4.495779] WARNING: CPU: 0 PID: 1 at drivers/bus/omap_l3_noc.c:147 l3_interrupt_handler+0x330/0x380
    [    4.504950] 44000000.ocp:L3 Custom Error: MASTER MPU TARGET L4_PER2_P3 (Idle): Data Access in Supervisor mode during Functional access
    [    4.517085] Modules linked in:
    [    4.520155] CPU: 0 PID: 1 Comm: swapper/0 Tainted: G        W         4.19.94-gbe5389fd85 #1
    [    4.528627] Hardware name: Generic DRA74X (Flattened Device Tree)
    [    4.534745] Backtrace:
    [    4.537208] [<c020ca34>] (dump_backtrace) from [<c020cd6c>] (show_stack+0x18/0x1c)
    [    4.544812]  r7:c0dfdec4 r6:60000193 r5:00000000 r4:c12506dc
    [    4.550500] [<c020cd54>] (show_stack) from [<c0a15124>] (dump_stack+0x9c/0xb0)
    [    4.557758] [<c0a15088>] (dump_stack) from [<c022e100>] (__warn+0xdc/0xf8)
    [    4.564663]  r7:c0dfdec4 r6:00000009 r5:00000000 r4:ee88f9a4
    [    4.570350] [<c022e024>] (__warn) from [<c022dd38>] (warn_slowpath_fmt+0x50/0x6c)
    [    4.577867]  r9:ee9d39c0 r8:f0882564 r7:c0dfddf0 r6:c0dfdd30 r5:c0dfde94 r4:c1204c48
    [    4.585647] [<c022dcec>] (warn_slowpath_fmt) from [<c056711c>] (l3_interrupt_handler+0x330/0x380)
    [    4.594556]  r3:ee9d7f00 r2:c0dfde94
    [    4.598146]  r5:00000000 r4:80080003
    [    4.601742] [<c0566dec>] (l3_interrupt_handler) from [<c02895ec>] (__handle_irq_event_percpu+0x68/0x140)
    [    4.611265]  r10:c12522f8 r9:ee9d9f00 r8:00000017 r7:ee88fad0 r6:00000000 r5:ee9d9f68
    [    4.619127]  r4:eea183c0
    [    4.621676] [<c0289584>] (__handle_irq_event_percpu) from [<c02896f8>] (handle_irq_event_percpu+0x34/0x88)
    [    4.631373]  r10:ffffe000 r9:ee88e000 r8:ee80c000 r7:00000001 r6:ee9d9f00 r5:ee9d9f68
    [    4.639235]  r4:c1204c48
    [    4.641783] [<c02896c4>] (handle_irq_event_percpu) from [<c028978c>] (handle_irq_event+0x40/0x64)
    [    4.650693]  r6:c120a434 r5:ee9d9f68 r4:ee9d9f00
    [    4.655334] [<c028974c>] (handle_irq_event) from [<c028d4dc>] (handle_fasteoi_irq+0xc0/0x168)
    [    4.663896]  r7:00000001 r6:c120a434 r5:ee9d9f68 r4:ee9d9f00
    [    4.669582] [<c028d41c>] (handle_fasteoi_irq) from [<c02887e8>] (generic_handle_irq+0x2c/0x3c)
    [    4.678231]  r7:00000001 r6:00000000 r5:00000000 r4:c1068cfc
    [    4.683918] [<c02887bc>] (generic_handle_irq) from [<c0288e4c>] (__handle_domain_irq+0x64/0xbc)
    [    4.692658] [<c0288de8>] (__handle_domain_irq) from [<c0565458>] (gic_handle_irq+0x44/0x80)
    [    4.701046]  r9:ee88e000 r8:fa213000 r7:ee88fb98 r6:fa212000 r5:fa21200c r4:c1205104
    [    4.708826] [<c0565414>] (gic_handle_irq) from [<c02019f8>] (__irq_svc+0x58/0x8c)
    [    4.716339] Exception stack(0xee88fb98 to 0xee88fbe0)
    [    4.721413] fb80:                                                       edc8cdbc fa468000
    [    4.729627] fba0: c0c97478 fa468010 edc8cc40 00000000 eea92688 c0220964 c0220964 c0272ac0
    [    4.737841] fbc0: ffffe000 ee88fbfc 00000000 ee88fbec c0c97488 c08b1e04 80000113 ffffffff
    [    4.746055]  r9:ee88e000 r8:c0220964 r7:ee88fbcc r6:ffffffff r5:80000113 r4:c08b1e04
    [    4.753840] [<c08b1dd4>] (davinci_mcasp_runtime_resume) from [<c06cf250>] (pm_generic_runtime_resume+0x34/0x40)
    [    4.763970]  r4:eea92610
    [    4.766519] [<c06cf21c>] (pm_generic_runtime_resume) from [<c022098c>] (_od_runtime_resume+0x28/0x48)
    [    4.775782] [<c0220964>] (_od_runtime_resume) from [<c06d1e2c>] (__rpm_callback+0x14c/0x1e0)
    [    4.784256]  r5:00000000 r4:eea92610
    [    4.787848] [<c06d1ce0>] (__rpm_callback) from [<c06d1ee8>] (rpm_callback+0x28/0x88)
    [    4.795627]  r10:ffffe000 r9:c0272ac0 r8:00000004 r7:c0220964 r6:c1203d00 r5:eea12e10
    [    4.803489]  r4:eea92610
    [    4.806035] [<c06d1ec0>] (rpm_callback) from [<c06d1ad4>] (rpm_resume+0x4d0/0x670)
    [    4.813637]  r7:c0220964 r6:c1203d00 r5:eea12e10 r4:eea92610
    [    4.819322] [<c06d1604>] (rpm_resume) from [<c06d1cc8>] (__pm_runtime_resume+0x54/0x6c)
    [    4.827362]  r10:00000000 r9:00000000 r8:c1204c48 r7:60000113 r6:00000004 r5:eea92688
    [    4.835224]  r4:eea92610
    [    4.837771] [<c06d1c74>] (__pm_runtime_resume) from [<c08b4820>] (davinci_mcasp_probe+0x4c0/0xd6c)
    [    4.846770]  r7:edc996c0 r6:eea92610 r5:00000000 r4:edc8cc40
    [    4.852459] [<c08b4360>] (davinci_mcasp_probe) from [<c06c8368>] (platform_drv_probe+0x50/0xa0)
    [    4.861197]  r10:00000000 r9:c1248e54 r8:00000000 r7:00000000 r6:c1248e54 r5:00000000
    [    4.869059]  r4:eea92610
    [    4.871606] [<c06c8318>] (platform_drv_probe) from [<c06c63b8>] (really_probe+0x204/0x2c0)
    [    4.879906]  r7:00000000 r6:c128d988 r5:eea92610 r4:c128d984
    [    4.885594] [<c06c61b4>] (really_probe) from [<c06c6618>] (driver_probe_device+0x68/0x180)
    [    4.893894]  r10:c1060e8c r9:c104b834 r8:00000000 r7:c06c6730 r6:eea92644 r5:c1248e54
    [    4.901757]  r4:eea92610 r3:00000000
    [    4.905351] [<c06c65b0>] (driver_probe_device) from [<c06c6824>] (__driver_attach+0xf4/0xf8)
    [    4.913827]  r9:c104b834 r8:00000000 r7:c06c6730 r6:eea92644 r5:c1248e54 r4:eea92610
    [    4.921607] [<c06c6730>] (__driver_attach) from [<c06c4484>] (bus_for_each_dev+0x7c/0xbc)
    [    4.929821]  r7:c06c6730 r6:c1248e54 r5:c1204c48 r4:eea7b1b4
    [    4.935507] [<c06c4408>] (bus_for_each_dev) from [<c06c5cf0>] (driver_attach+0x24/0x28)
    [    4.943545]  r7:00000000 r6:edc99600 r5:c12370f0 r4:c1248e54
    [    4.949233] [<c06c5ccc>] (driver_attach) from [<c06c5768>] (bus_add_driver+0x1c4/0x208)
    [    4.957274] [<c06c55a4>] (bus_add_driver) from [<c06c71f4>] (driver_register+0x7c/0x110)
    [    4.965400]  r7:c1036e6c r6:ffffe000 r5:c1204c48 r4:c1248e54
    [    4.971087] [<c06c7178>] (driver_register) from [<c06c82cc>] (__platform_driver_register+0x48/0x50)
    [    4.980172]  r5:c1204c48 r4:c1253e00
    [    4.983768] [<c06c8284>] (__platform_driver_register) from [<c1036e88>] (davinci_mcasp_driver_init+0x1c/0x20)
    [    4.993730] [<c1036e6c>] (davinci_mcasp_driver_init) from [<c02025b8>] (do_one_initcall+0x84/0x1b0)
    [    5.002818] [<c0202534>] (do_one_initcall) from [<c1000fe8>] (kernel_init_freeable+0x1c4/0x258)
    [    5.011555]  r8:c104b854 r7:c10004f0 r6:c1253e00 r5:c1253e00 r4:00000007
    [    5.018287] [<c1000e24>] (kernel_init_freeable) from [<c0a29438>] (kernel_init+0x10/0x11c)
    [    5.026589]  r10:00000000 r9:00000000 r8:00000000 r7:00000000 r6:00000000 r5:c0a29428
    [    5.034451]  r4:00000000
    [    5.036997] [<c0a29428>] (kernel_init) from [<c02010d8>] (ret_from_fork+0x14/0x3c)
    [    5.044598] Exception stack(0xee88ffb0 to 0xee88fff8)
    [    5.049672] ffa0:                                     00000000 00000000 00000000 00000000
    [    5.057886] ffc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [    5.066100] ffe0: 00000000 00000000 00000000 00000000 00000013 00000000
    [    5.072743]  r5:c0a29428 r4:00000000
    [    5.076332] ---[ end trace 200ff3becaf4cb25 ]---
    [    5.081051] ------------[ cut here ]------------
    [    5.085695] WARNING: CPU: 0 PID: 1 at drivers/bus/omap_l3_noc.c:147 l3_interrupt_handler+0x330/0x380
    [    5.094868] 44000000.ocp:L3 Custom Error: MASTER MPU TARGET L4_PER2_P3 (Idle): Data Access in Supervisor mode during Functional access
    [    5.107002] Modules linked in:
    [    5.110073] CPU: 0 PID: 1 Comm: swapper/0 Tainted: G        W         4.19.94-gbe5389fd85 #1
    [    5.118545] Hardware name: Generic DRA74X (Flattened Device Tree)
    [    5.124662] Backtrace:
    [    5.127123] [<c020ca34>] (dump_backtrace) from [<c020cd6c>] (show_stack+0x18/0x1c)
    [    5.134728]  r7:c0dfdec4 r6:60000193 r5:00000000 r4:c12506dc
    [    5.140416] [<c020cd54>] (show_stack) from [<c0a15124>] (dump_stack+0x9c/0xb0)
    [    5.147673] [<c0a15088>] (dump_stack) from [<c022e100>] (__warn+0xdc/0xf8)
    [    5.154579]  r7:c0dfdec4 r6:00000009 r5:00000000 r4:ee88f9a4
    [    5.160265] [<c022e024>] (__warn) from [<c022dd38>] (warn_slowpath_fmt+0x50/0x6c)
    [    5.167782]  r9:ee9d39c0 r8:f0882564 r7:c0dfddf0 r6:c0dfdd30 r5:c0dfde94 r4:c1204c48
    [    5.175562] [<c022dcec>] (warn_slowpath_fmt) from [<c056711c>] (l3_interrupt_handler+0x330/0x380)
    [    5.184473]  r3:ee9d7f00 r2:c0dfde94
    [    5.188063]  r5:00000000 r4:80080003
    [    5.191660] [<c0566dec>] (l3_interrupt_handler) from [<c02895ec>] (__handle_irq_event_percpu+0x68/0x140)
    [    5.201184]  r10:c12522f8 r9:ee9d9f00 r8:00000017 r7:ee88fad0 r6:00000000 r5:ee9d9f68
    [    5.209046]  r4:eea183c0
    [    5.211595] [<c0289584>] (__handle_irq_event_percpu) from [<c02896f8>] (handle_irq_event_percpu+0x34/0x88)
    [    5.221292]  r10:ffffe000 r9:ee88e000 r8:ee80c000 r7:00000001 r6:ee9d9f00 r5:ee9d9f68
    [    5.229154]  r4:c1204c48
    [    5.231703] [<c02896c4>] (handle_irq_event_percpu) from [<c028978c>] (handle_irq_event+0x40/0x64)
    [    5.240613]  r6:c120a434 r5:ee9d9f68 r4:ee9d9f00
    [    5.245253] [<c028974c>] (handle_irq_event) from [<c028d4dc>] (handle_fasteoi_irq+0xc0/0x168)
    [    5.253814]  r7:00000001 r6:c120a434 r5:ee9d9f68 r4:ee9d9f00
    [    5.259501] [<c028d41c>] (handle_fasteoi_irq) from [<c02887e8>] (generic_handle_irq+0x2c/0x3c)
    [    5.268151]  r7:00000001 r6:00000000 r5:00000000 r4:c1068cfc
    [    5.273839] [<c02887bc>] (generic_handle_irq) from [<c0288e4c>] (__handle_domain_irq+0x64/0xbc)
    [    5.282580] [<c0288de8>] (__handle_domain_irq) from [<c0565458>] (gic_handle_irq+0x44/0x80)
    [    5.290968]  r9:ee88e000 r8:fa213000 r7:ee88fb98 r6:fa212000 r5:fa21200c r4:c1205104
    [    5.298748] [<c0565414>] (gic_handle_irq) from [<c02019f8>] (__irq_svc+0x58/0x8c)
    [    5.306262] Exception stack(0xee88fb98 to 0xee88fbe0)
    [    5.311335] fb80:                                                       edc8cdc8 fa468000
    [    5.319550] fba0: c0c97480 fa4680a4 edc8cc40 00000000 eea92688 c0220964 c0220964 c0272ac0
    [    5.327765] fbc0: ffffe000 ee88fbfc 00000000 ee88fbec c0c97488 c08b1dfc 80000113 ffffffff
    [    5.335980]  r9:ee88e000 r8:c0220964 r7:ee88fbcc r6:ffffffff r5:80000113 r4:c08b1dfc
    [    5.343762] [<c08b1dd4>] (davinci_mcasp_runtime_resume) from [<c06cf250>] (pm_generic_runtime_resume+0x34/0x40)
    [    5.353894]  r4:eea92610
    [    5.356443] [<c06cf21c>] (pm_generic_runtime_resume) from [<c022098c>] (_od_runtime_resume+0x28/0x48)
    [    5.365706] [<c0220964>] (_od_runtime_resume) from [<c06d1e2c>] (__rpm_callback+0x14c/0x1e0)
    [    5.374179]  r5:00000000 r4:eea92610
    [    5.377771] [<c06d1ce0>] (__rpm_callback) from [<c06d1ee8>] (rpm_callback+0x28/0x88)
    [    5.385550]  r10:ffffe000 r9:c0272ac0 r8:00000004 r7:c0220964 r6:c1203d00 r5:eea12e10
    [    5.393412]  r4:eea92610
    [    5.395958] [<c06d1ec0>] (rpm_callback) from [<c06d1ad4>] (rpm_resume+0x4d0/0x670)
    [    5.403561]  r7:c0220964 r6:c1203d00 r5:eea12e10 r4:eea92610
    [    5.409246] [<c06d1604>] (rpm_resume) from [<c06d1cc8>] (__pm_runtime_resume+0x54/0x6c)
    [    5.417286]  r10:00000000 r9:00000000 r8:c1204c48 r7:60000113 r6:00000004 r5:eea92688
    [    5.425148]  r4:eea92610
    [    5.427696] [<c06d1c74>] (__pm_runtime_resume) from [<c08b4820>] (davinci_mcasp_probe+0x4c0/0xd6c)
    [    5.436695]  r7:edc996c0 r6:eea92610 r5:00000000 r4:edc8cc40
    [    5.442383] [<c08b4360>] (davinci_mcasp_probe) from [<c06c8368>] (platform_drv_probe+0x50/0xa0)
    [    5.451120]  r10:00000000 r9:c1248e54 r8:00000000 r7:00000000 r6:c1248e54 r5:00000000
    [    5.458982]  r4:eea92610
    [    5.461530] [<c06c8318>] (platform_drv_probe) from [<c06c63b8>] (really_probe+0x204/0x2c0)
    [    5.469831]  r7:00000000 r6:c128d988 r5:eea92610 r4:c128d984
    [    5.475519] [<c06c61b4>] (really_probe) from [<c06c6618>] (driver_probe_device+0x68/0x180)
    [    5.483820]  r10:c1060e8c r9:c104b834 r8:00000000 r7:c06c6730 r6:eea92644 r5:c1248e54
    [    5.491683]  r4:eea92610 r3:00000000
    [    5.495278] [<c06c65b0>] (driver_probe_device) from [<c06c6824>] (__driver_attach+0xf4/0xf8)
    [    5.503753]  r9:c104b834 r8:00000000 r7:c06c6730 r6:eea92644 r5:c1248e54 r4:eea92610
    [    5.511533] [<c06c6730>] (__driver_attach) from [<c06c4484>] (bus_for_each_dev+0x7c/0xbc)
    [    5.519746]  r7:c06c6730 r6:c1248e54 r5:c1204c48 r4:eea7b1b4
    [    5.525432] [<c06c4408>] (bus_for_each_dev) from [<c06c5cf0>] (driver_attach+0x24/0x28)
    [    5.533471]  r7:00000000 r6:edc99600 r5:c12370f0 r4:c1248e54
    [    5.539158] [<c06c5ccc>] (driver_attach) from [<c06c5768>] (bus_add_driver+0x1c4/0x208)
    [    5.547200] [<c06c55a4>] (bus_add_driver) from [<c06c71f4>] (driver_register+0x7c/0x110)
    [    5.555326]  r7:c1036e6c r6:ffffe000 r5:c1204c48 r4:c1248e54
    [    5.561014] [<c06c7178>] (driver_register) from [<c06c82cc>] (__platform_driver_register+0x48/0x50)
    [    5.570098]  r5:c1204c48 r4:c1253e00
    [    5.573694] [<c06c8284>] (__platform_driver_register) from [<c1036e88>] (davinci_mcasp_driver_init+0x1c/0x20)
    [    5.583655] [<c1036e6c>] (davinci_mcasp_driver_init) from [<c02025b8>] (do_one_initcall+0x84/0x1b0)
    [    5.592743] [<c0202534>] (do_one_initcall) from [<c1000fe8>] (kernel_init_freeable+0x1c4/0x258)
    [    5.601482]  r8:c104b854 r7:c10004f0 r6:c1253e00 r5:c1253e00 r4:00000007
    [    5.608216] [<c1000e24>] (kernel_init_freeable) from [<c0a29438>] (kernel_init+0x10/0x11c)
    [    5.616517]  r10:00000000 r9:00000000 r8:00000000 r7:00000000 r6:00000000 r5:c0a29428
    [    5.624379]  r4:00000000
    [    5.626926] [<c0a29428>] (kernel_init) from [<c02010d8>] (ret_from_fork+0x14/0x3c)
    [    5.634528] Exception stack(0xee88ffb0 to 0xee88fff8)
    [    5.639602] ffa0:                                     00000000 00000000 00000000 00000000
    [    5.647816] ffc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [    5.656030] ffe0: 00000000 00000000 00000000 00000000 00000013 00000000
    [    5.662672]  r5:c0a29428 r4:00000000
    [    5.666261] ---[ end trace 200ff3becaf4cb26 ]---
    [    5.670965] ------------[ cut here ]------------
    [    5.675608] WARNING: CPU: 0 PID: 1 at drivers/bus/omap_l3_noc.c:147 l3_interrupt_handler+0x330/0x380
    [    5.684781] 44000000.ocp:L3 Custom Error: MASTER MPU TARGET L4_PER2_P3 (Idle): Data Access in Supervisor mode during Functional access
    [    5.696915] Modules linked in:
    [    5.699985] CPU: 0 PID: 1 Comm: swapper/0 Tainted: G        W         4.19.94-gbe5389fd85 #1
    [    5.708457] Hardware name: Generic DRA74X (Flattened Device Tree)
    [    5.714575] Backtrace:
    [    5.717037] [<c020ca34>] (dump_backtrace) from [<c020cd6c>] (show_stack+0x18/0x1c)
    [    5.724640]  r7:c0dfdec4 r6:60000193 r5:00000000 r4:c12506dc
    [    5.730329] [<c020cd54>] (show_stack) from [<c0a15124>] (dump_stack+0x9c/0xb0)
    [    5.737587] [<c0a15088>] (dump_stack) from [<c022e100>] (__warn+0xdc/0xf8)
    [    5.744492]  r7:c0dfdec4 r6:00000009 r5:00000000 r4:ee88f9bc
    [    5.750178] [<c022e024>] (__warn) from [<c022dd38>] (warn_slowpath_fmt+0x50/0x6c)
    [    5.757695]  r9:ee9d39c0 r8:f0882564 r7:c0dfddf0 r6:c0dfdd30 r5:c0dfde94 r4:c1204c48
    [    5.765476] [<c022dcec>] (warn_slowpath_fmt) from [<c056711c>] (l3_interrupt_handler+0x330/0x380)
    [    5.774386]  r3:ee9d7f00 r2:c0dfde94
    [    5.777976]  r5:00000000 r4:80080003
    [    5.781571] [<c0566dec>] (l3_interrupt_handler) from [<c02895ec>] (__handle_irq_event_percpu+0x68/0x140)
    [    5.791094]  r10:c12522f8 r9:ee9d9f00 r8:00000017 r7:ee88fae8 r6:00000000 r5:ee9d9f68
    [    5.798955]  r4:eea183c0
    [    5.801504] [<c0289584>] (__handle_irq_event_percpu) from [<c02896f8>] (handle_irq_event_percpu+0x34/0x88)
    [    5.811201]  r10:ffffe000 r9:ee88e000 r8:ee80c000 r7:00000001 r6:ee9d9f00 r5:ee9d9f68
    [    5.819063]  r4:c1204c48
    [    5.821611] [<c02896c4>] (handle_irq_event_percpu) from [<c028978c>] (handle_irq_event+0x40/0x64)
    [    5.830521]  r6:c120a434 r5:ee9d9f68 r4:ee9d9f00
    [    5.835161] [<c028974c>] (handle_irq_event) from [<c028d4dc>] (handle_fasteoi_irq+0xc0/0x168)
    [    5.843723]  r7:00000001 r6:c120a434 r5:ee9d9f68 r4:ee9d9f00
    [    5.849409] [<c028d41c>] (handle_fasteoi_irq) from [<c02887e8>] (generic_handle_irq+0x2c/0x3c)
    [    5.858059]  r7:00000001 r6:00000000 r5:00000000 r4:c1068cfc
    [    5.863746] [<c02887bc>] (generic_handle_irq) from [<c0288e4c>] (__handle_domain_irq+0x64/0xbc)
    [    5.872486] [<c0288de8>] (__handle_domain_irq) from [<c0565458>] (gic_handle_irq+0x44/0x80)
    [    5.880874]  r9:ee88e000 r8:fa213000 r7:ee88fbb0 r6:fa212000 r5:fa21200c r4:c1205104
    [    5.888654] [<c0565414>] (gic_handle_irq) from [<c02019f8>] (__irq_svc+0x58/0x8c)
    [    5.896169] Exception stack(0xee88fbb0 to 0xee88fbf8)
    [    5.901242] fba0:                                     00000000 00000000 edc998cc fa468190
    [    5.909457] fbc0: eea92610 00000000 eea92688 c0220964 c0220964 c0272ac0 ffffe000 ee88fc0c
    [    5.917671] fbe0: 00000000 ee88fc00 c0c97488 c06cf250 60000113 ffffffff
    [    5.924316]  r9:ee88e000 r8:c0220964 r7:ee88fbe4 r6:ffffffff r5:60000113 r4:c06cf250
    [    5.932099] [<c06cf21c>] (pm_generic_runtime_resume) from [<c022098c>] (_od_runtime_resume+0x28/0x48)
    [    5.941362] [<c0220964>] (_od_runtime_resume) from [<c06d1e2c>] (__rpm_callback+0x14c/0x1e0)
    [    5.949835]  r5:00000000 r4:eea92610
    [    5.953427] [<c06d1ce0>] (__rpm_callback) from [<c06d1ee8>] (rpm_callback+0x28/0x88)
    [    5.961206]  r10:ffffe000 r9:c0272ac0 r8:00000004 r7:c0220964 r6:c1203d00 r5:eea12e10
    [    5.969067]  r4:eea92610
    [    5.971612] [<c06d1ec0>] (rpm_callback) from [<c06d1ad4>] (rpm_resume+0x4d0/0x670)
    [    5.979215]  r7:c0220964 r6:c1203d00 r5:eea12e10 r4:eea92610
    [    5.984900] [<c06d1604>] (rpm_resume) from [<c06d1cc8>] (__pm_runtime_resume+0x54/0x6c)
    [    5.992941]  r10:00000000 r9:00000000 r8:c1204c48 r7:60000113 r6:00000004 r5:eea92688
    [    6.000802]  r4:eea92610
    [    6.003350] [<c06d1c74>] (__pm_runtime_resume) from [<c08b4820>] (davinci_mcasp_probe+0x4c0/0xd6c)
    [    6.012348]  r7:edc996c0 r6:eea92610 r5:00000000 r4:edc8cc40
    [    6.018037] [<c08b4360>] (davinci_mcasp_probe) from [<c06c8368>] (platform_drv_probe+0x50/0xa0)
    [    6.026774]  r10:00000000 r9:c1248e54 r8:00000000 r7:00000000 r6:c1248e54 r5:00000000
    [    6.034636]  r4:eea92610
    [    6.037184] [<c06c8318>] (platform_drv_probe) from [<c06c63b8>] (really_probe+0x204/0x2c0)
    [    6.045484]  r7:00000000 r6:c128d988 r5:eea92610 r4:c128d984
    [    6.051171] [<c06c61b4>] (really_probe) from [<c06c6618>] (driver_probe_device+0x68/0x180)
    [    6.059473]  r10:c1060e8c r9:c104b834 r8:00000000 r7:c06c6730 r6:eea92644 r5:c1248e54
    [    6.067337]  r4:eea92610 r3:00000000
    [    6.070931] [<c06c65b0>] (driver_probe_device) from [<c06c6824>] (__driver_attach+0xf4/0xf8)
    [    6.079408]  r9:c104b834 r8:00000000 r7:c06c6730 r6:eea92644 r5:c1248e54 r4:eea92610
    [    6.081899] omap_i2c 48070000.i2c: controller timed out
    [    6.087189] [<c06c6730>] (__driver_attach) from [<c06c4484>] (bus_for_each_dev+0x7c/0xbc)
    [    6.100635]  r7:c06c6730 r6:c1248e54 r5:c1204c48 r4:eea7b1b4
    [    6.106321] [<c06c4408>] (bus_for_each_dev) from [<c06c5cf0>] (driver_attach+0x24/0x28)
    [    6.111902] dummy 0-0059: Failed to read IRQ status: -110
    [    6.114359]  r7:00000000 r6:edc99600 r5:c12370f0 r4:c1248e54
    [    6.125462] [<c06c5ccc>] (driver_attach) from [<c06c5768>] (bus_add_driver+0x1c4/0x208)
    [    6.133504] [<c06c55a4>] (bus_add_driver) from [<c06c71f4>] (driver_register+0x7c/0x110)
    [    6.141630]  r7:c1036e6c r6:ffffe000 r5:c1204c48 r4:c1248e54
    [    6.147317] [<c06c7178>] (driver_register) from [<c06c82cc>] (__platform_driver_register+0x48/0x50)
    [    6.156401]  r5:c1204c48 r4:c1253e00
    [    6.159997] [<c06c8284>] (__platform_driver_register) from [<c1036e88>] (davinci_mcasp_driver_init+0x1c/0x20)
    [    6.169959] [<c1036e6c>] (davinci_mcasp_driver_init) from [<c02025b8>] (do_one_initcall+0x84/0x1b0)
    [    6.179047] [<c0202534>] (do_one_initcall) from [<c1000fe8>] (kernel_init_freeable+0x1c4/0x258)
    [    6.187784]  r8:c104b854 r7:c10004f0 r6:c1253e00 r5:c1253e00 r4:00000007
    [    6.194518] [<c1000e24>] (kernel_init_freeable) from [<c0a29438>] (kernel_init+0x10/0x11c)
    [    6.202820]  r10:00000000 r9:00000000 r8:00000000 r7:00000000 r6:00000000 r5:c0a29428
    [    6.210682]  r4:00000000
    [    6.213227] [<c0a29428>] (kernel_init) from [<c02010d8>] (ret_from_fork+0x14/0x3c)
    [    6.220829] Exception stack(0xee88ffb0 to 0xee88fff8)
    [    6.225903] ffa0:                                     00000000 00000000 00000000 00000000
    [    6.234118] ffc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [    6.242331] ffe0: 00000000 00000000 00000000 00000000 00000013 00000000
    [    6.248973]  r5:c0a29428 r4:00000000
    [    6.252563] ---[ end trace 200ff3becaf4cb27 ]---
    [    6.257311] ------------[ cut here ]------------
    [    6.261955] WARNING: CPU: 0 PID: 1 at drivers/bus/omap_l3_noc.c:147 l3_interrupt_handler+0x330/0x380
    [    6.271127] 44000000.ocp:L3 Custom Error: MASTER MPU TARGET L4_PER2_P3 (Idle): Data Access in Supervisor mode during Functional access
    [    6.283262] Modules linked in:
    [    6.286332] CPU: 0 PID: 1 Comm: swapper/0 Tainted: G        W         4.19.94-gbe5389fd85 #1
    [    6.294804] Hardware name: Generic DRA74X (Flattened Device Tree)
    [    6.300921] Backtrace:
    [    6.303383] [<c020ca34>] (dump_backtrace) from [<c020cd6c>] (show_stack+0x18/0x1c)
    [    6.310987]  r7:c0dfdec4 r6:60000193 r5:00000000 r4:c12506dc
    [    6.316675] [<c020cd54>] (show_stack) from [<c0a15124>] (dump_stack+0x9c/0xb0)
    [    6.323932] [<c0a15088>] (dump_stack) from [<c022e100>] (__warn+0xdc/0xf8)
    [    6.330838]  r7:c0dfdec4 r6:00000009 r5:00000000 r4:ee88fa7c
    [    6.336524] [<c022e024>] (__warn) from [<c022dd38>] (warn_slowpath_fmt+0x50/0x6c)
    [    6.344041]  r9:ee9d39c0 r8:f0882564 r7:c0dfddf0 r6:c0dfdd30 r5:c0dfde94 r4:c1204c48
    [    6.351821] [<c022dcec>] (warn_slowpath_fmt) from [<c056711c>] (l3_interrupt_handler+0x330/0x380)
    [    6.360732]  r3:ee9d7f00 r2:c0dfde94
    [    6.364321]  r5:00000000 r4:80080003
    [    6.367916] [<c0566dec>] (l3_interrupt_handler) from [<c02895ec>] (__handle_irq_event_percpu+0x68/0x140)
    [    6.377439]  r10:c12522f8 r9:ee9d9f00 r8:00000017 r7:ee88fba8 r6:00000000 r5:ee9d9f68
    [    6.385301]  r4:eea183c0
    [    6.387850] [<c0289584>] (__handle_irq_event_percpu) from [<c02896f8>] (handle_irq_event_percpu+0x34/0x88)
    [    6.397546]  r10:00000000 r9:ee88e000 r8:ee80c000 r7:00000001 r6:ee9d9f00 r5:ee9d9f68
    [    6.405408]  r4:c1204c48
    [    6.407956] [<c02896c4>] (handle_irq_event_percpu) from [<c028978c>] (handle_irq_event+0x40/0x64)
    [    6.416866]  r6:c120a434 r5:ee9d9f68 r4:ee9d9f00
    [    6.421506] [<c028974c>] (handle_irq_event) from [<c028d4dc>] (handle_fasteoi_irq+0xc0/0x168)
    [    6.430068]  r7:00000001 r6:c120a434 r5:ee9d9f68 r4:ee9d9f00
    [    6.435754] [<c028d41c>] (handle_fasteoi_irq) from [<c02887e8>] (generic_handle_irq+0x2c/0x3c)
    [    6.444402]  r7:00000001 r6:00000000 r5:00000000 r4:c1068cfc
    [    6.450090] [<c02887bc>] (generic_handle_irq) from [<c0288e4c>] (__handle_domain_irq+0x64/0xbc)
    [    6.458830] [<c0288de8>] (__handle_domain_irq) from [<c0565458>] (gic_handle_irq+0x44/0x80)
    [    6.467220]  r9:ee88e000 r8:fa213000 r7:ee88fc70 r6:fa212000 r5:fa21200c r4:c1205104
    [    6.475000] [<c0565414>] (gic_handle_irq) from [<c02019f8>] (__irq_svc+0x58/0x8c)
    [    6.482514] Exception stack(0xee88fc70 to 0xee88fcb8)
    [    6.487588] fc60:                                     eea92688 60000113 00000001 00000013
    [    6.495803] fc80: 00000000 00000005 eea92688 60000113 c1204c48 00000000 00000000 ee88fccc
    [    6.504016] fca0: ee88fcd0 ee88fcc0 c06d1590 c0a2f61c 20000113 ffffffff
    [    6.510661]  r9:ee88e000 r8:c1204c48 r7:ee88fca4 r6:ffffffff r5:20000113 r4:c0a2f61c
    [    6.518441] [<c0a2f5f4>] (_raw_spin_unlock_irqrestore) from [<c06d1590>] (__pm_runtime_idle+0x74/0x88)
    [    6.527791] [<c06d151c>] (__pm_runtime_idle) from [<c08b4834>] (davinci_mcasp_probe+0x4d4/0xd6c)
    [    6.536615]  r7:edc996c0 r6:eea92610 r5:00000000 r4:edc8cc40
    [    6.542304] [<c08b4360>] (davinci_mcasp_probe) from [<c06c8368>] (platform_drv_probe+0x50/0xa0)
    [    6.551041]  r10:00000000 r9:c1248e54 r8:00000000 r7:00000000 r6:c1248e54 r5:00000000
    [    6.558904]  r4:eea92610
    [    6.561452] [<c06c8318>] (platform_drv_probe) from [<c06c63b8>] (really_probe+0x204/0x2c0)
    [    6.569752]  r7:00000000 r6:c128d988 r5:eea92610 r4:c128d984
    [    6.575439] [<c06c61b4>] (really_probe) from [<c06c6618>] (driver_probe_device+0x68/0x180)
    [    6.583742]  r10:c1060e8c r9:c104b834 r8:00000000 r7:c06c6730 r6:eea92644 r5:c1248e54
    [    6.591604]  r4:eea92610 r3:00000000
    [    6.595197] [<c06c65b0>] (driver_probe_device) from [<c06c6824>] (__driver_attach+0xf4/0xf8)
    [    6.603673]  r9:c104b834 r8:00000000 r7:c06c6730 r6:eea92644 r5:c1248e54 r4:eea92610
    [    6.611453] [<c06c6730>] (__driver_attach) from [<c06c4484>] (bus_for_each_dev+0x7c/0xbc)
    [    6.619666]  r7:c06c6730 r6:c1248e54 r5:c1204c48 r4:eea7b1b4
    [    6.625352] [<c06c4408>] (bus_for_each_dev) from [<c06c5cf0>] (driver_attach+0x24/0x28)
    [    6.633391]  r7:00000000 r6:edc99600 r5:c12370f0 r4:c1248e54
    [    6.639077] [<c06c5ccc>] (driver_attach) from [<c06c5768>] (bus_add_driver+0x1c4/0x208)
    [    6.647119] [<c06c55a4>] (bus_add_driver) from [<c06c71f4>] (driver_register+0x7c/0x110)
    [    6.655244]  r7:c1036e6c r6:ffffe000 r5:c1204c48 r4:c1248e54
    [    6.660933] [<c06c7178>] (driver_register) from [<c06c82cc>] (__platform_driver_register+0x48/0x50)
    [    6.670017]  r5:c1204c48 r4:c1253e00
    [    6.673613] [<c06c8284>] (__platform_driver_register) from [<c1036e88>] (davinci_mcasp_driver_init+0x1c/0x20)
    [    6.683574] [<c1036e6c>] (davinci_mcasp_driver_init) from [<c02025b8>] (do_one_initcall+0x84/0x1b0)
    [    6.692662] [<c0202534>] (do_one_initcall) from [<c1000fe8>] (kernel_init_freeable+0x1c4/0x258)
    [    6.701400]  r8:c104b854 r7:c10004f0 r6:c1253e00 r5:c1253e00 r4:00000007
    [    6.708133] [<c1000e24>] (kernel_init_freeable) from [<c0a29438>] (kernel_init+0x10/0x11c)
    [    6.716434]  r10:00000000 r9:00000000 r8:00000000 r7:00000000 r6:00000000 r5:c0a29428
    [    6.724296]  r4:00000000
    [    6.726842] [<c0a29428>] (kernel_init) from [<c02010d8>] (ret_from_fork+0x14/0x3c)
    [    6.734443] Exception stack(0xee88ffb0 to 0xee88fff8)
    [    6.739516] ffa0:                                     00000000 00000000 00000000 00000000
    [    6.747730] ffc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [    6.755944] ffe0: 00000000 00000000 00000000 00000000 00000013 00000000
    [    6.762586]  r5:c0a29428 r4:00000000
    [    6.766175] ---[ end trace 200ff3becaf4cb28 ]---
    [    6.770898] ------------[ cut here ]------------
    [    6.771820] NET: Registered protocol family 10
    [    6.775543] WARNING: CPU: 0 PID: 23 at drivers/bus/omap_l3_noc.c:147 l3_interrupt_handler+0x330/0x380
    [    6.775549] 44000000.ocp:L3 Custom Error: MASTER MPU TARGET L4_PER2_P3 (Read): Data Access in User mode during Functional access
    [    6.775557] Modules linked in:
    [    6.790999] Segment Routing with IPv6
    [    6.800877] CPU: 0 PID: 23 Comm: kworker/0:1 Tainted: G        W         4.19.94-gbe5389fd85 #1
    [    6.800882] Hardware name: Generic DRA74X (Flattened Device Tree)
    [    6.800890] Workqueue: pm pm_runtime_work
    [    6.804054] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
    [    6.807631] Backtrace:
    [    6.816867] NET: Registered protocol family 17
    [    6.822479] [<c020ca34>] (dump_backtrace) from [<c020cd6c>] (show_stack+0x18/0x1c)
    [    6.822491]  r7:c0dfdec4 r6:60000193 r5:00000000 r4:c12506dc
    [    6.826726] Key type dns_resolver registered
    [    6.832457] [<c020cd54>] (show_stack) from [<c0a15124>] (dump_stack+0x9c/0xb0)
    [    6.832467] [<c0a15088>] (dump_stack) from [<c022e100>] (__warn+0xdc/0xf8)
    [    6.832473]  r7:c0dfdec4 r6:00000009 r5:00000000 r4:eea15b94
    [    6.835053] Registering SWP/SWPB emulation handler
    [    6.839386] [<c022e024>] (__warn) from [<c022dd38>] (warn_slowpath_fmt+0x50/0x6c)
    [    6.846991] omap_voltage_late_init: Voltage driver support not added
    [    6.852657]  r9:ee9d39c0 r8:f0882564 r7:c0dfddf0 r6:c0dfdd30 r5:c0dfde94 r4:c1204c48
    [    6.852669] [<c022dcec>] (warn_slowpath_fmt) from [<c056711c>] (l3_interrupt_handler+0x330/0x380)
    [    6.856947] Power Management for TI OMAP4+ devices.
    [    6.864193]  r3:ee9d7f00 r2:c0dfde94
    [    6.864198]  r5:00000002 r4:80080003
    [    6.864210] [<c0566dec>] (l3_interrupt_handler) from [<c02895ec>] (__handle_irq_event_percpu+0x68/0x140)
    [    6.933719]  r10:c12522f8 r9:ee9d9f00 r8:00000017 r7:eea15cc0 r6:00000000 r5:ee9d9f68
    [    6.941581]  r4:eea183c0
    [    6.944130] [<c0289584>] (__handle_irq_event_percpu) from [<c02896f8>] (handle_irq_event_percpu+0x34/0x88)
    [    6.953829]  r10:ffffe000 r9:eea14000 r8:ee80c000 r7:00000001 r6:ee9d9f00 r5:ee9d9f68
    [    6.961691]  r4:c1204c48
    [    6.964239] [<c02896c4>] (handle_irq_event_percpu) from [<c028978c>] (handle_irq_event+0x40/0x64)
    [    6.973150]  r6:c120a434 r5:ee9d9f68 r4:ee9d9f00
    [    6.977791] [<c028974c>] (handle_irq_event) from [<c028d4dc>] (handle_fasteoi_irq+0xc0/0x168)
    [    6.986353]  r7:00000001 r6:c120a434 r5:ee9d9f68 r4:ee9d9f00
    [    6.992039] [<c028d41c>] (handle_fasteoi_irq) from [<c02887e8>] (generic_handle_irq+0x2c/0x3c)
    [    7.000689]  r7:00000001 r6:00000000 r5:00000000 r4:c1068cfc
    [    7.006376] [<c02887bc>] (generic_handle_irq) from [<c0288e4c>] (__handle_domain_irq+0x64/0xbc)
    [    7.015115] [<c0288de8>] (__handle_domain_irq) from [<c0565458>] (gic_handle_irq+0x44/0x80)
    [    7.023503]  r9:eea14000 r8:fa213000 r7:eea15d88 r6:fa212000 r5:fa21200c r4:c1205104
    [    7.031283] [<c0565414>] (gic_handle_irq) from [<c02019f8>] (__irq_svc+0x58/0x8c)
    [    7.038797] Exception stack(0xeea15d88 to 0xeea15dd0)
    [    7.043872] 5d80:                   fa468000 edc8cc40 c0c97458 fa46806c eea92610 00000000
    [    7.052088] 5da0: eea92688 c1203d00 c0220a94 c1204c48 ffffe000 eea15de4 edc8cd9c eea15dd8
    [    7.060301] 5dc0: c0c97488 c08b1d38 80000113 ffffffff
    [    7.065376]  r9:eea14000 r8:c0220a94 r7:eea15dbc r6:ffffffff r5:80000113 r4:c08b1d38
    [    7.073160] [<c08b1d08>] (davinci_mcasp_runtime_suspend) from [<c06cf210>] (pm_generic_runtime_suspend+0x34/0x40)
    [    7.083473] [<c06cf1dc>] (pm_generic_runtime_suspend) from [<c0220aa8>] (_od_runtime_suspend+0x14/0x28)
    [    7.092910] [<c0220a94>] (_od_runtime_suspend) from [<c06d1e2c>] (__rpm_callback+0x14c/0x1e0)
    [    7.101471]  r5:00000000 r4:eea92610
    [    7.105063] [<c06d1ce0>] (__rpm_callback) from [<c06d1ee8>] (rpm_callback+0x28/0x88)
    [    7.112842]  r10:ffffe000 r9:c1204c48 r8:00000008 r7:c1203d00 r6:c0220a94 r5:00000000
    [    7.120703]  r4:eea92610
    [    7.123250] [<c06d1ec0>] (rpm_callback) from [<c06d0f40>] (rpm_suspend+0x148/0x518)
    [    7.130940]  r7:c1203d00 r6:c0220a94 r5:00000000 r4:eea92610
    [    7.136626] [<c06d0df8>] (rpm_suspend) from [<c06d149c>] (rpm_idle+0xc8/0x148)
    [    7.143881]  r10:00000000 r9:eea926c8 r8:eea926d4 r7:00000000 r6:00000002 r5:00000000
    [    7.151744]  r4:eea92610
    [    7.154291] [<c06d13d4>] (rpm_idle) from [<c06d26a8>] (pm_runtime_work+0x94/0x98)
    [    7.161807]  r9:eea926c8 r8:00000000 r7:eed5e200 r6:eed59d80 r5:eea92688 r4:eea926c4
    [    7.169587] [<c06d2614>] (pm_runtime_work) from [<c02464d0>] (process_one_work+0x1f4/0x404)
    [    7.177973]  r5:ee9d3180 r4:eea926c4
    [    7.181566] [<c02462dc>] (process_one_work) from [<c02472a4>] (worker_thread+0x58/0x568)
    [    7.189695]  r10:eed59d80 r9:c1203d00 r8:eed59d98 r7:00000008 r6:eed59d80 r5:ee9d3194
    [    7.197557]  r4:ee9d3180
    [    7.200106] [<c024724c>] (worker_thread) from [<c024c7b4>] (kthread+0x160/0x168)
    [    7.207535]  r10:ee8ade74 r9:c024724c r8:ee9d3180 r7:eea14000 r6:00000000 r5:ee9d2600
    [    7.215397]  r4:ee9e4080
    [    7.217945] [<c024c654>] (kthread) from [<c02010d8>] (ret_from_fork+0x14/0x3c)
    [    7.225198] Exception stack(0xeea15fb0 to 0xeea15ff8)
    [    7.230272] 5fa0:                                     00000000 00000000 00000000 00000000
    [    7.238487] 5fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [    7.246700] 5fe0: 00000000 00000000 00000000 00000000 00000013 00000000
    [    7.253345]  r10:00000000 r9:00000000 r8:00000000 r7:00000000 r6:00000000 r5:c024c654
    [    7.261207]  r4:ee9d2600
    [    7.263751] ---[ end trace 200ff3becaf4cb2a ]---
    [    7.268532] ------------[ cut here ]------------
    [    7.273177] WARNING: CPU: 0 PID: 23 at drivers/bus/omap_l3_noc.c:147 l3_interrupt_handler+0x330/0x380
    [    7.282436] 44000000.ocp:L3 Custom Error: MASTER MPU TARGET L4_PER2_P3 (Read): Data Access in User mode during Functional access
    [    7.294049] Modules linked in:
    [    7.297119] CPU: 0 PID: 23 Comm: kworker/0:1 Tainted: G        W         4.19.94-gbe5389fd85 #1
    [    7.305854] Hardware name: Generic DRA74X (Flattened Device Tree)
    [    7.311976] Workqueue: pm pm_runtime_work
    [    7.316003] Backtrace:
    [    7.318465] [<c020ca34>] (dump_backtrace) from [<c020cd6c>] (show_stack+0x18/0x1c)
    [    7.326068]  r7:c0dfdec4 r6:60000193 r5:00000000 r4:c12506dc
    [    7.331757] [<c020cd54>] (show_stack) from [<c0a15124>] (dump_stack+0x9c/0xb0)
    [    7.339014] [<c0a15088>] (dump_stack) from [<c022e100>] (__warn+0xdc/0xf8)
    [    7.345920]  r7:c0dfdec4 r6:00000009 r5:00000000 r4:eea15b94
    [    7.351606] [<c022e024>] (__warn) from [<c022dd38>] (warn_slowpath_fmt+0x50/0x6c)
    [    7.359123]  r9:ee9d39c0 r8:f0882564 r7:c0dfddf0 r6:c0dfdd30 r5:c0dfde94 r4:c1204c48
    [    7.366905] [<c022dcec>] (warn_slowpath_fmt) from [<c056711c>] (l3_interrupt_handler+0x330/0x380)
    [    7.375815]  r3:ee9d7f00 r2:c0dfde94
    [    7.379405]  r5:00000002 r4:80080003
    [    7.383001] [<c0566dec>] (l3_interrupt_handler) from [<c02895ec>] (__handle_irq_event_percpu+0x68/0x140)
    [    7.392524]  r10:c12522f8 r9:ee9d9f00 r8:00000017 r7:eea15cc0 r6:00000000 r5:ee9d9f68
    [    7.400386]  r4:eea183c0
    [    7.402935] [<c0289584>] (__handle_irq_event_percpu) from [<c02896f8>] (handle_irq_event_percpu+0x34/0x88)
    [    7.412632]  r10:ffffe000 r9:eea14000 r8:ee80c000 r7:00000001 r6:ee9d9f00 r5:ee9d9f68
    [    7.420494]  r4:c1204c48
    [    7.423043] [<c02896c4>] (handle_irq_event_percpu) from [<c028978c>] (handle_irq_event+0x40/0x64)
    [    7.431954]  r6:c120a434 r5:ee9d9f68 r4:ee9d9f00
    [    7.436594] [<c028974c>] (handle_irq_event) from [<c028d4dc>] (handle_fasteoi_irq+0xc0/0x168)
    [    7.445156]  r7:00000001 r6:c120a434 r5:ee9d9f68 r4:ee9d9f00
    [    7.450843] [<c028d41c>] (handle_fasteoi_irq) from [<c02887e8>] (generic_handle_irq+0x2c/0x3c)
    [    7.459491]  r7:00000001 r6:00000000 r5:00000000 r4:c1068cfc
    [    7.465179] [<c02887bc>] (generic_handle_irq) from [<c0288e4c>] (__handle_domain_irq+0x64/0xbc)
    [    7.473919] [<c0288de8>] (__handle_domain_irq) from [<c0565458>] (gic_handle_irq+0x44/0x80)
    [    7.482308]  r9:eea14000 r8:fa213000 r7:eea15d88 r6:fa212000 r5:fa21200c r4:c1205104
    [    7.490089] [<c0565414>] (gic_handle_irq) from [<c02019f8>] (__irq_svc+0x58/0x8c)
    [    7.497604] Exception stack(0xeea15d88 to 0xeea15dd0)
    [    7.502679] 5d80:                   fa468000 edc8cc40 c0c9745c fa4680a8 eea92610 00000000
    [    7.510894] 5da0: eea92688 c1203d00 c0220a94 c1204c48 ffffe000 eea15de4 edc8cda0 eea15dd8
    [    7.519106] 5dc0: c0c97488 c08b1d38 80000113 ffffffff
    [    7.524181]  r9:eea14000 r8:c0220a94 r7:eea15dbc r6:ffffffff r5:80000113 r4:c08b1d38
    [    7.531963] [<c08b1d08>] (davinci_mcasp_runtime_suspend) from [<c06cf210>] (pm_generic_runtime_suspend+0x34/0x40)
    [    7.542275] [<c06cf1dc>] (pm_generic_runtime_suspend) from [<c0220aa8>] (_od_runtime_suspend+0x14/0x28)
    [    7.551711] [<c0220a94>] (_od_runtime_suspend) from [<c06d1e2c>] (__rpm_callback+0x14c/0x1e0)
    [    7.560273]  r5:00000000 r4:eea92610
    [    7.563865] [<c06d1ce0>] (__rpm_callback) from [<c06d1ee8>] (rpm_callback+0x28/0x88)
    [    7.571644]  r10:ffffe000 r9:c1204c48 r8:00000008 r7:c1203d00 r6:c0220a94 r5:00000000
    [    7.579506]  r4:eea92610
    [    7.582051] [<c06d1ec0>] (rpm_callback) from [<c06d0f40>] (rpm_suspend+0x148/0x518)
    [    7.589741]  r7:c1203d00 r6:c0220a94 r5:00000000 r4:eea92610
    [    7.595426] [<c06d0df8>] (rpm_suspend) from [<c06d149c>] (rpm_idle+0xc8/0x148)
    [    7.602681]  r10:00000000 r9:eea926c8 r8:eea926d4 r7:00000000 r6:00000002 r5:00000000
    [    7.610543]  r4:eea92610
    [    7.613089] [<c06d13d4>] (rpm_idle) from [<c06d26a8>] (pm_runtime_work+0x94/0x98)
    [    7.620606]  r9:eea926c8 r8:00000000 r7:eed5e200 r6:eed59d80 r5:eea92688 r4:eea926c4
    [    7.628384] [<c06d2614>] (pm_runtime_work) from [<c02464d0>] (process_one_work+0x1f4/0x404)
    [    7.636770]  r5:ee9d3180 r4:eea926c4
    [    7.640363] [<c02462dc>] (process_one_work) from [<c02472a4>] (worker_thread+0x58/0x568)
    [    7.648490]  r10:eed59d80 r9:c1203d00 r8:eed59d98 r7:00000008 r6:eed59d80 r5:ee9d3194
    [    7.656353]  r4:ee9d3180
    [    7.658900] [<c024724c>] (worker_thread) from [<c024c7b4>] (kthread+0x160/0x168)
    [    7.666329]  r10:ee8ade74 r9:c024724c r8:ee9d3180 r7:eea14000 r6:00000000 r5:ee9d2600
    [    7.674191]  r4:ee9e4080
    [    7.676739] [<c024c654>] (kthread) from [<c02010d8>] (ret_from_fork+0x14/0x3c)
    [    7.683991] Exception stack(0xeea15fb0 to 0xeea15ff8)
    [    7.689063] 5fa0:                                     00000000 00000000 00000000 00000000
    [    7.697277] 5fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [    7.705492] 5fe0: 00000000 00000000 00000000 00000000 00000013 00000000
    [    7.712138]  r10:00000000 r9:00000000 r8:00000000 r7:00000000 r6:00000000 r5:c024c654
    [    7.720001]  r4:ee9d2600
    [    7.722544] ---[ end trace 200ff3becaf4cb2b ]---
    [    7.727319] ------------[ cut here ]------------
    [    7.731965] WARNING: CPU: 0 PID: 23 at drivers/bus/omap_l3_noc.c:147 l3_interrupt_handler+0x330/0x380
    [    7.741227] 44000000.ocp:L3 Custom Error: MASTER MPU TARGET L4_PER2_P3 (Read): Data Access in User mode during Functional access
    [    7.752839] Modules linked in:
    [    7.755909] CPU: 0 PID: 23 Comm: kworker/0:1 Tainted: G        W         4.19.94-gbe5389fd85 #1
    [    7.764643] Hardware name: Generic DRA74X (Flattened Device Tree)
    [    7.770765] Workqueue: pm pm_runtime_work
    [    7.774791] Backtrace:
    [    7.777252] [<c020ca34>] (dump_backtrace) from [<c020cd6c>] (show_stack+0x18/0x1c)
    [    7.784855]  r7:c0dfdec4 r6:60000193 r5:00000000 r4:c12506dc
    [    7.790542] [<c020cd54>] (show_stack) from [<c0a15124>] (dump_stack+0x9c/0xb0)
    [    7.797799] [<c0a15088>] (dump_stack) from [<c022e100>] (__warn+0xdc/0xf8)
    [    7.804704]  r7:c0dfdec4 r6:00000009 r5:00000000 r4:eea15b94
    [    7.810390] [<c022e024>] (__warn) from [<c022dd38>] (warn_slowpath_fmt+0x50/0x6c)
    [    7.817907]  r9:ee9d39c0 r8:f0882564 r7:c0dfddf0 r6:c0dfdd30 r5:c0dfde94 r4:c1204c48
    [    7.825688] [<c022dcec>] (warn_slowpath_fmt) from [<c056711c>] (l3_interrupt_handler+0x330/0x380)
    [    7.834598]  r3:ee9d7f00 r2:c0dfde94
    [    7.838187]  r5:00000002 r4:80080003
    [    7.841784] [<c0566dec>] (l3_interrupt_handler) from [<c02895ec>] (__handle_irq_event_percpu+0x68/0x140)
    [    7.851306]  r10:c12522f8 r9:ee9d9f00 r8:00000017 r7:eea15cc0 r6:00000000 r5:ee9d9f68
    [    7.859167]  r4:eea183c0
    [    7.861717] [<c0289584>] (__handle_irq_event_percpu) from [<c02896f8>] (handle_irq_event_percpu+0x34/0x88)
    [    7.871414]  r10:ffffe000 r9:eea14000 r8:ee80c000 r7:00000001 r6:ee9d9f00 r5:ee9d9f68
    [    7.879275]  r4:c1204c48
    [    7.881824] [<c02896c4>] (handle_irq_event_percpu) from [<c028978c>] (handle_irq_event+0x40/0x64)
    [    7.890734]  r6:c120a434 r5:ee9d9f68 r4:ee9d9f00
    [    7.895375] [<c028974c>] (handle_irq_event) from [<c028d4dc>] (handle_fasteoi_irq+0xc0/0x168)
    [    7.903936]  r7:00000001 r6:c120a434 r5:ee9d9f68 r4:ee9d9f00
    [    7.909623] [<c028d41c>] (handle_fasteoi_irq) from [<c02887e8>] (generic_handle_irq+0x2c/0x3c)
    [    7.918273]  r7:00000001 r6:00000000 r5:00000000 r4:c1068cfc
    [    7.923961] [<c02887bc>] (generic_handle_irq) from [<c0288e4c>] (__handle_domain_irq+0x64/0xbc)
    [    7.932701] [<c0288de8>] (__handle_domain_irq) from [<c0565458>] (gic_handle_irq+0x44/0x80)
    [    7.941091]  r9:eea14000 r8:fa213000 r7:eea15d88 r6:fa212000 r5:fa21200c r4:c1205104
    [    7.948871] [<c0565414>] (gic_handle_irq) from [<c02019f8>] (__irq_svc+0x58/0x8c)
    [    7.956384] Exception stack(0xeea15d88 to 0xeea15dd0)
    [    7.961459] 5d80:                   fa468000 edc8cc40 c0c97460 fa468068 eea92610 00000000
    [    7.969673] 5da0: eea92688 c1203d00 c0220a94 c1204c48 ffffe000 eea15de4 edc8cda4 eea15dd8
    [    7.977886] 5dc0: c0c97488 c08b1d38 80000113 ffffffff
    [    7.982961]  r9:eea14000 r8:c0220a94 r7:eea15dbc r6:ffffffff r5:80000113 r4:c08b1d38
    [    7.990743] [<c08b1d08>] (davinci_mcasp_runtime_suspend) from [<c06cf210>] (pm_generic_runtime_suspend+0x34/0x40)
    [    8.001053] [<c06cf1dc>] (pm_generic_runtime_suspend) from [<c0220aa8>] (_od_runtime_suspend+0x14/0x28)
    [    8.010492] [<c0220a94>] (_od_runtime_suspend) from [<c06d1e2c>] (__rpm_callback+0x14c/0x1e0)
    [    8.019052]  r5:00000000 r4:eea92610
    [    8.022644] [<c06d1ce0>] (__rpm_callback) from [<c06d1ee8>] (rpm_callback+0x28/0x88)
    [    8.030422]  r10:ffffe000 r9:c1204c48 r8:00000008 r7:c1203d00 r6:c0220a94 r5:00000000
    [    8.038285]  r4:eea92610
    [    8.040831] [<c06d1ec0>] (rpm_callback) from [<c06d0f40>] (rpm_suspend+0x148/0x518)
    [    8.048521]  r7:c1203d00 r6:c0220a94 r5:00000000 r4:eea92610
    [    8.054205] [<c06d0df8>] (rpm_suspend) from [<c06d149c>] (rpm_idle+0xc8/0x148)
    [    8.061460]  r10:00000000 r9:eea926c8 r8:eea926d4 r7:00000000 r6:00000002 r5:00000000
    [    8.069322]  r4:eea92610
    [    8.071868] [<c06d13d4>] (rpm_idle) from [<c06d26a8>] (pm_runtime_work+0x94/0x98)
    [    8.079384]  r9:eea926c8 r8:00000000 r7:eed5e200 r6:eed59d80 r5:eea92688 r4:eea926c4
    [    8.087163] [<c06d2614>] (pm_runtime_work) from [<c02464d0>] (process_one_work+0x1f4/0x404)
    [    8.095549]  r5:ee9d3180 r4:eea926c4
    [    8.099141] [<c02462dc>] (process_one_work) from [<c02472a4>] (worker_thread+0x58/0x568)
    [    8.107269]  r10:eed59d80 r9:c1203d00 r8:eed59d98 r7:00000008 r6:eed59d80 r5:ee9d3194
    [    8.115132]  r4:ee9d3180
    [    8.117679] [<c024724c>] (worker_thread) from [<c024c7b4>] (kthread+0x160/0x168)
    [    8.125109]  r10:ee8ade74 r9:c024724c r8:ee9d3180 r7:eea14000 r6:00000000 r5:ee9d2600
    [    8.132971]  r4:ee9e4080
    [    8.135518] [<c024c654>] (kthread) from [<c02010d8>] (ret_from_fork+0x14/0x3c)
    [    8.142770] Exception stack(0xeea15fb0 to 0xeea15ff8)
    [    8.147844] 5fa0:                                     00000000 00000000 00000000 00000000
    [    8.156058] 5fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [    8.164271] 5fe0: 00000000 00000000 00000000 00000000 00000013 00000000
    [    8.170916]  r10:00000000 r9:00000000 r8:00000000 r7:00000000 r6:00000000 r5:c024c654
    [    8.178777]  r4:ee9d2600
    [    8.181320] ---[ end trace 200ff3becaf4cb2c ]---
    [    8.186024] ------------[ cut here ]------------
    [    8.186207] Loading compiled-in X.509 certificates
    [    8.190670] WARNING: CPU: 0 PID: 23 at drivers/bus/omap_l3_noc.c:147 l3_interrupt_handler+0x330/0x380
    [    8.204727] 44000000.ocp:L3 Custom Error: MASTER MPU TARGET L4_PER2_P3 (Read): Data Access in User mode during Functional access
    [    8.216340] Modules linked in:
    [    8.219415] CPU: 0 PID: 23 Comm: kworker/0:1 Tainted: G        W         4.19.94-gbe5389fd85 #1
    [    8.228151] Hardware name: Generic DRA74X (Flattened Device Tree)
    [    8.234276] Workqueue: pm pm_runtime_work
    [    8.238302] Backtrace:
    [    8.240765] [<c020ca34>] (dump_backtrace) from [<c020cd6c>] (show_stack+0x18/0x1c)
    [    8.248369]  r7:c0dfdec4 r6:60000193 r5:00000000 r4:c12506dc
    [    8.254060] [<c020cd54>] (show_stack) from [<c0a15124>] (dump_stack+0x9c/0xb0)
    [    8.261319] [<c0a15088>] (dump_stack) from [<c022e100>] (__warn+0xdc/0xf8)
    [    8.268224]  r7:c0dfdec4 r6:00000009 r5:00000000 r4:eea15b94
    [    8.273910] [<c022e024>] (__warn) from [<c022dd38>] (warn_slowpath_fmt+0x50/0x6c)
    [    8.281427]  r9:ee9d39c0 r8:f0882564 r7:c0dfddf0 r6:c0dfdd30 r5:c0dfde94 r4:c1204c48
    [    8.289207] [<c022dcec>] (warn_slowpath_fmt) from [<c056711c>] (l3_interrupt_handler+0x330/0x380)
    [    8.298116]  r3:ee9d7f00 r2:c0dfde94
    [    8.301705]  r5:00000002 r4:80080003
    [    8.305303] [<c0566dec>] (l3_interrupt_handler) from [<c02895ec>] (__handle_irq_event_percpu+0x68/0x140)
    [    8.314826]  r10:c12522f8 r9:ee9d9f00 r8:00000017 r7:eea15cc0 r6:00000000 r5:ee9d9f68
    [    8.322689]  r4:eea183c0
    [    8.325237] [<c0289584>] (__handle_irq_event_percpu) from [<c02896f8>] (handle_irq_event_percpu+0x34/0x88)
    [    8.334934]  r10:ffffe000 r9:eea14000 r8:ee80c000 r7:00000001 r6:ee9d9f00 r5:ee9d9f68
    [    8.342796]  r4:c1204c48
    [    8.345345] [<c02896c4>] (handle_irq_event_percpu) from [<c028978c>] (handle_irq_event+0x40/0x64)
    [    8.354254]  r6:c120a434 r5:ee9d9f68 r4:ee9d9f00
    [    8.358895] [<c028974c>] (handle_irq_event) from [<c028d4dc>] (handle_fasteoi_irq+0xc0/0x168)
    [    8.367457]  r7:00000001 r6:c120a434 r5:ee9d9f68 r4:ee9d9f00
    [    8.373143] [<c028d41c>] (handle_fasteoi_irq) from [<c02887e8>] (generic_handle_irq+0x2c/0x3c)
    [    8.381793]  r7:00000001 r6:00000000 r5:00000000 r4:c1068cfc
    [    8.387480] [<c02887bc>] (generic_handle_irq) from [<c0288e4c>] (__handle_domain_irq+0x64/0xbc)
    [    8.396221] [<c0288de8>] (__handle_domain_irq) from [<c0565458>] (gic_handle_irq+0x44/0x80)
    [    8.404609]  r9:eea14000 r8:fa213000 r7:eea15d88 r6:fa212000 r5:fa21200c r4:c1205104
    [    8.412390] [<c0565414>] (gic_handle_irq) from [<c02019f8>] (__irq_svc+0x58/0x8c)
    [    8.419904] Exception stack(0xeea15d88 to 0xeea15dd0)
    [    8.424979] 5d80:                   fa468000 edc8cc40 c0c97464 fa4680b0 eea92610 00000000
    [    8.433194] 5da0: eea92688 c1203d00 c0220a94 c1204c48 ffffe000 eea15de4 edc8cda8 eea15dd8
    [    8.441407] 5dc0: c0c97488 c08b1d38 80000113 ffffffff
    [    8.446483]  r9:eea14000 r8:c0220a94 r7:eea15dbc r6:ffffffff r5:80000113 r4:c08b1d38
    [    8.454270] [<c08b1d08>] (davinci_mcasp_runtime_suspend) from [<c06cf210>] (pm_generic_runtime_suspend+0x34/0x40)
    [    8.464582] [<c06cf1dc>] (pm_generic_runtime_suspend) from [<c0220aa8>] (_od_runtime_suspend+0x14/0x28)
    [    8.474019] [<c0220a94>] (_od_runtime_suspend) from [<c06d1e2c>] (__rpm_callback+0x14c/0x1e0)
    [    8.482581]  r5:00000000 r4:eea92610
    [    8.486173] [<c06d1ce0>] (__rpm_callback) from [<c06d1ee8>] (rpm_callback+0x28/0x88)
    [    8.493951]  r10:ffffe000 r9:c1204c48 r8:00000008 r7:c1203d00 r6:c0220a94 r5:00000000
    [    8.501812]  r4:eea92610
    [    8.504358] [<c06d1ec0>] (rpm_callback) from [<c06d0f40>] (rpm_suspend+0x148/0x518)
    [    8.512048]  r7:c1203d00 r6:c0220a94 r5:00000000 r4:eea92610
    [    8.517733] [<c06d0df8>] (rpm_suspend) from [<c06d149c>] (rpm_idle+0xc8/0x148)
    [    8.524989]  r10:00000000 r9:eea926c8 r8:eea926d4 r7:00000000 r6:00000002 r5:00000000
    [    8.532851]  r4:eea92610
    [    8.535397] [<c06d13d4>] (rpm_idle) from [<c06d26a8>] (pm_runtime_work+0x94/0x98)
    [    8.542915]  r9:eea926c8 r8:00000000 r7:eed5e200 r6:eed59d80 r5:eea92688 r4:eea926c4
    [    8.550694] [<c06d2614>] (pm_runtime_work) from [<c02464d0>] (process_one_work+0x1f4/0x404)
    [    8.559080]  r5:ee9d3180 r4:eea926c4
    [    8.562673] [<c02462dc>] (process_one_work) from [<c02472a4>] (worker_thread+0x58/0x568)
    [    8.570800]  r10:eed59d80 r9:c1203d00 r8:eed59d98 r7:00000008 r6:eed59d80 r5:ee9d3194
    [    8.578662]  r4:ee9d3180
    [    8.581211] [<c024724c>] (worker_thread) from [<c024c7b4>] (kthread+0x160/0x168)
    [    8.588640]  r10:ee8ade74 r9:c024724c r8:ee9d3180 r7:eea14000 r6:00000000 r5:ee9d2600
    [    8.596502]  r4:ee9e4080
    [    8.599050] [<c024c654>] (kthread) from [<c02010d8>] (ret_from_fork+0x14/0x3c)
    [    8.606302] Exception stack(0xeea15fb0 to 0xeea15ff8)
    [    8.611376] 5fa0:                                     00000000 00000000 00000000 00000000
    [    8.619591] 5fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [    8.627805] 5fe0: 00000000 00000000 00000000 00000000 00000013 00000000
    [    8.634451]  r10:00000000 r9:00000000 r8:00000000 r7:00000000 r6:00000000 r5:c024c654
    [    8.642313]  r4:ee9d2600
    [    8.644856] ---[ end trace 200ff3becaf4cb2d ]---
    [    8.649587] ------------[ cut here ]------------
    [    8.654235] WARNING: CPU: 0 PID: 23 at drivers/bus/omap_l3_noc.c:147 l3_interrupt_handler+0x330/0x380
    [    8.663496] 44000000.ocp:L3 Custom Error: MASTER MPU TARGET L4_PER2_P3 (Read): Data Access in User mode during Functional access
    [    8.675108] Modules linked in:
    [    8.678178] CPU: 0 PID: 23 Comm: kworker/0:1 Tainted: G        W         4.19.94-gbe5389fd85 #1
    [    8.686912] Hardware name: Generic DRA74X (Flattened Device Tree)
    [    8.693033] Workqueue: pm pm_runtime_work
    [    8.697059] Backtrace:
    [    8.699521] [<c020ca34>] (dump_backtrace) from [<c020cd6c>] (show_stack+0x18/0x1c)
    [    8.707124]  r7:c0dfdec4 r6:60000193 r5:00000000 r4:c12506dc
    [    8.712812] [<c020cd54>] (show_stack) from [<c0a15124>] (dump_stack+0x9c/0xb0)
    [    8.720070] [<c0a15088>] (dump_stack) from [<c022e100>] (__warn+0xdc/0xf8)
    [    8.726975]  r7:c0dfdec4 r6:00000009 r5:00000000 r4:eea15b94
    [    8.732660] [<c022e024>] (__warn) from [<c022dd38>] (warn_slowpath_fmt+0x50/0x6c)
    [    8.740177]  r9:ee9d39c0 r8:f0882564 r7:c0dfddf0 r6:c0dfdd30 r5:c0dfde94 r4:c1204c48
    [    8.747957] [<c022dcec>] (warn_slowpath_fmt) from [<c056711c>] (l3_interrupt_handler+0x330/0x380)
    [    8.756867]  r3:ee9d7f00 r2:c0dfde94
    [    8.760458]  r5:00000002 r4:80080003
    [    8.764053] [<c0566dec>] (l3_interrupt_handler) from [<c02895ec>] (__handle_irq_event_percpu+0x68/0x140)
    [    8.773575]  r10:c12522f8 r9:ee9d9f00 r8:00000017 r7:eea15cc0 r6:00000000 r5:ee9d9f68
    [    8.781437]  r4:eea183c0
    [    8.783985] [<c0289584>] (__handle_irq_event_percpu) from [<c02896f8>] (handle_irq_event_percpu+0x34/0x88)
    [    8.793683]  r10:ffffe000 r9:eea14000 r8:ee80c000 r7:00000001 r6:ee9d9f00 r5:ee9d9f68
    [    8.801545]  r4:c1204c48
    [    8.804094] [<c02896c4>] (handle_irq_event_percpu) from [<c028978c>] (handle_irq_event+0x40/0x64)
    [    8.813004]  r6:c120a434 r5:ee9d9f68 r4:ee9d9f00
    [    8.817644] [<c028974c>] (handle_irq_event) from [<c028d4dc>] (handle_fasteoi_irq+0xc0/0x168)
    [    8.826207]  r7:00000001 r6:c120a434 r5:ee9d9f68 r4:ee9d9f00
    [    8.831894] [<c028d41c>] (handle_fasteoi_irq) from [<c02887e8>] (generic_handle_irq+0x2c/0x3c)
    [    8.840544]  r7:00000001 r6:00000000 r5:00000000 r4:c1068cfc
    [    8.846231] [<c02887bc>] (generic_handle_irq) from [<c0288e4c>] (__handle_domain_irq+0x64/0xbc)
    [    8.854970] [<c0288de8>] (__handle_domain_irq) from [<c0565458>] (gic_handle_irq+0x44/0x80)
    [    8.863361]  r9:eea14000 r8:fa213000 r7:eea15d88 r6:fa212000 r5:fa21200c r4:c1205104
    [    8.871141] [<c0565414>] (gic_handle_irq) from [<c02019f8>] (__irq_svc+0x58/0x8c)
    [    8.878655] Exception stack(0xeea15d88 to 0xeea15dd0)
    [    8.883730] 5d80:                   fa468000 edc8cc40 c0c97468 fa468070 eea92610 00000000
    [    8.891945] 5da0: eea92688 c1203d00 c0220a94 c1204c48 ffffe000 eea15de4 edc8cdac eea15dd8
    [    8.900158] 5dc0: c0c97488 c08b1d38 80000113 ffffffff
    [    8.905232]  r9:eea14000 r8:c0220a94 r7:eea15dbc r6:ffffffff r5:80000113 r4:c08b1d38
    [    8.913015] [<c08b1d08>] (davinci_mcasp_runtime_suspend) from [<c06cf210>] (pm_generic_runtime_suspend+0x34/0x40)
    [    8.923326] [<c06cf1dc>] (pm_generic_runtime_suspend) from [<c0220aa8>] (_od_runtime_suspend+0x14/0x28)
    [    8.932763] [<c0220a94>] (_od_runtime_suspend) from [<c06d1e2c>] (__rpm_callback+0x14c/0x1e0)
    [    8.941324]  r5:00000000 r4:eea92610
    [    8.944917] [<c06d1ce0>] (__rpm_callback) from [<c06d1ee8>] (rpm_callback+0x28/0x88)
    [    8.952696]  r10:ffffe000 r9:c1204c48 r8:00000008 r7:c1203d00 r6:c0220a94 r5:00000000
    [    8.960558]  r4:eea92610
    [    8.963104] [<c06d1ec0>] (rpm_callback) from [<c06d0f40>] (rpm_suspend+0x148/0x518)
    [    8.970795]  r7:c1203d00 r6:c0220a94 r5:00000000 r4:eea92610
    [    8.976481] [<c06d0df8>] (rpm_suspend) from [<c06d149c>] (rpm_idle+0xc8/0x148)
    [    8.983736]  r10:00000000 r9:eea926c8 r8:eea926d4 r7:00000000 r6:00000002 r5:00000000
    [    8.991598]  r4:eea92610
    [    8.994144] [<c06d13d4>] (rpm_idle) from [<c06d26a8>] (pm_runtime_work+0x94/0x98)
    [    9.001661]  r9:eea926c8 r8:00000000 r7:eed5e200 r6:eed59d80 r5:eea92688 r4:eea926c4
    [    9.009440] [<c06d2614>] (pm_runtime_work) from [<c02464d0>] (process_one_work+0x1f4/0x404)
    [    9.017826]  r5:ee9d3180 r4:eea926c4
    [    9.021418] [<c02462dc>] (process_one_work) from [<c02472a4>] (worker_thread+0x58/0x568)
    [    9.029546]  r10:eed59d80 r9:c1203d00 r8:eed59d98 r7:00000008 r6:eed59d80 r5:ee9d3194
    [    9.037408]  r4:ee9d3180
    [    9.039955] [<c024724c>] (worker_thread) from [<c024c7b4>] (kthread+0x160/0x168)
    [    9.047386]  r10:ee8ade74 r9:c024724c r8:ee9d3180 r7:eea14000 r6:00000000 r5:ee9d2600
    [    9.055248]  r4:ee9e4080
    [    9.057794] [<c024c654>] (kthread) from [<c02010d8>] (ret_from_fork+0x14/0x3c)
    [    9.065046] Exception stack(0xeea15fb0 to 0xeea15ff8)
    [    9.070120] 5fa0:                                     00000000 00000000 00000000 00000000
    [    9.078335] 5fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [    9.086548] 5fe0: 00000000 00000000 00000000 00000000 00000013 00000000
    [    9.093193]  r10:00000000 r9:00000000 r8:00000000 r7:00000000 r6:00000000 r5:c024c654
    [    9.101055]  r4:ee9d2600
    [    9.103597] ---[ end trace 200ff3becaf4cb2e ]---
    [    9.108291] ------------[ cut here ]------------
    [    9.112936] WARNING: CPU: 0 PID: 23 at drivers/bus/omap_l3_noc.c:147 l3_interrupt_handler+0x330/0x380
    [    9.122198] 44000000.ocp:L3 Custom Error: MASTER MPU TARGET L4_PER2_P3 (Read): Data Access in User mode during Functional access
    [    9.133809] Modules linked in:
    [    9.136880] CPU: 0 PID: 23 Comm: kworker/0:1 Tainted: G        W         4.19.94-gbe5389fd85 #1
    [    9.145613] Hardware name: Generic DRA74X (Flattened Device Tree)
    [    9.151734] Workqueue: pm pm_runtime_work
    [    9.155760] Backtrace:
    [    9.158221] [<c020ca34>] (dump_backtrace) from [<c020cd6c>] (show_stack+0x18/0x1c)
    [    9.165825]  r7:c0dfdec4 r6:60000193 r5:00000000 r4:c12506dc
    [    9.171512] [<c020cd54>] (show_stack) from [<c0a15124>] (dump_stack+0x9c/0xb0)
    [    9.178769] [<c0a15088>] (dump_stack) from [<c022e100>] (__warn+0xdc/0xf8)
    [    9.185673]  r7:c0dfdec4 r6:00000009 r5:00000000 r4:eea15b94
    [    9.191359] [<c022e024>] (__warn) from [<c022dd38>] (warn_slowpath_fmt+0x50/0x6c)
    [    9.198876]  r9:ee9d39c0 r8:f0882564 r7:c0dfddf0 r6:c0dfdd30 r5:c0dfde94 r4:c1204c48
    [    9.206656] [<c022dcec>] (warn_slowpath_fmt) from [<c056711c>] (l3_interrupt_handler+0x330/0x380)
    [    9.215566]  r3:ee9d7f00 r2:c0dfde94
    [    9.219155]  r5:00000002 r4:80080003
    [    9.222752] [<c0566dec>] (l3_interrupt_handler) from [<c02895ec>] (__handle_irq_event_percpu+0x68/0x140)
    [    9.232276]  r10:c12522f8 r9:ee9d9f00 r8:00000017 r7:eea15cc0 r6:00000000 r5:ee9d9f68
    [    9.240139]  r4:eea183c0
    [    9.242689] [<c0289584>] (__handle_irq_event_percpu) from [<c02896f8>] (handle_irq_event_percpu+0x34/0x88)
    [    9.252386]  r10:ffffe000 r9:eea14000 r8:ee80c000 r7:00000001 r6:ee9d9f00 r5:ee9d9f68
    [    9.260247]  r4:c1204c48
    [    9.262795] [<c02896c4>] (handle_irq_event_percpu) from [<c028978c>] (handle_irq_event+0x40/0x64)
    [    9.271706]  r6:c120a434 r5:ee9d9f68 r4:ee9d9f00
    [    9.276346] [<c028974c>] (handle_irq_event) from [<c028d4dc>] (handle_fasteoi_irq+0xc0/0x168)
    [    9.284908]  r7:00000001 r6:c120a434 r5:ee9d9f68 r4:ee9d9f00
    [    9.290595] [<c028d41c>] (handle_fasteoi_irq) from [<c02887e8>] (generic_handle_irq+0x2c/0x3c)
    [    9.299243]  r7:00000001 r6:00000000 r5:00000000 r4:c1068cfc
    [    9.304932] [<c02887bc>] (generic_handle_irq) from [<c0288e4c>] (__handle_domain_irq+0x64/0xbc)
    [    9.313671] [<c0288de8>] (__handle_domain_irq) from [<c0565458>] (gic_handle_irq+0x44/0x80)
    [    9.322061]  r9:eea14000 r8:fa213000 r7:eea15d88 r6:fa212000 r5:fa21200c r4:c1205104
    [    9.329841] [<c0565414>] (gic_handle_irq) from [<c02019f8>] (__irq_svc+0x58/0x8c)
    [    9.337354] Exception stack(0xeea15d88 to 0xeea15dd0)
    [    9.342429] 5d80:                   fa468000 edc8cc40 c0c9746c fa4680b4 eea92610 00000000
    [    9.350644] 5da0: eea92688 c1203d00 c0220a94 c1204c48 ffffe000 eea15de4 edc8cdb0 eea15dd8
    [    9.358857] 5dc0: c0c97488 c08b1d38 80000113 ffffffff
    [    9.363932]  r9:eea14000 r8:c0220a94 r7:eea15dbc r6:ffffffff r5:80000113 r4:c08b1d38
    [    9.371714] [<c08b1d08>] (davinci_mcasp_runtime_suspend) from [<c06cf210>] (pm_generic_runtime_suspend+0x34/0x40)
    [    9.382025] [<c06cf1dc>] (pm_generic_runtime_suspend) from [<c0220aa8>] (_od_runtime_suspend+0x14/0x28)
    [    9.391461] [<c0220a94>] (_od_runtime_suspend) from [<c06d1e2c>] (__rpm_callback+0x14c/0x1e0)
    [    9.400022]  r5:00000000 r4:eea92610
    [    9.403613] [<c06d1ce0>] (__rpm_callback) from [<c06d1ee8>] (rpm_callback+0x28/0x88)
    [    9.411392]  r10:ffffe000 r9:c1204c48 r8:00000008 r7:c1203d00 r6:c0220a94 r5:00000000
    [    9.419255]  r4:eea92610
    [    9.421801] [<c06d1ec0>] (rpm_callback) from [<c06d0f40>] (rpm_suspend+0x148/0x518)
    [    9.429490]  r7:c1203d00 r6:c0220a94 r5:00000000 r4:eea92610
    [    9.435176] [<c06d0df8>] (rpm_suspend) from [<c06d149c>] (rpm_idle+0xc8/0x148)
    [    9.442430]  r10:00000000 r9:eea926c8 r8:eea926d4 r7:00000000 r6:00000002 r5:00000000
    [    9.450292]  r4:eea92610
    [    9.452838] [<c06d13d4>] (rpm_idle) from [<c06d26a8>] (pm_runtime_work+0x94/0x98)
    [    9.460354]  r9:eea926c8 r8:00000000 r7:eed5e200 r6:eed59d80 r5:eea92688 r4:eea926c4
    [    9.468133] [<c06d2614>] (pm_runtime_work) from [<c02464d0>] (process_one_work+0x1f4/0x404)
    [    9.476520]  r5:ee9d3180 r4:eea926c4
    [    9.480113] [<c02462dc>] (process_one_work) from [<c02472a4>] (worker_thread+0x58/0x568)
    [    9.488241]  r10:eed59d80 r9:c1203d00 r8:eed59d98 r7:00000008 r6:eed59d80 r5:ee9d3194
    [    9.496104]  r4:ee9d3180
    [    9.498650] [<c024724c>] (worker_thread) from [<c024c7b4>] (kthread+0x160/0x168)
    [    9.506080]  r10:ee8ade74 r9:c024724c r8:ee9d3180 r7:eea14000 r6:00000000 r5:ee9d2600
    [    9.513943]  r4:ee9e4080
    [    9.516490] [<c024c654>] (kthread) from [<c02010d8>] (ret_from_fork+0x14/0x3c)
    [    9.523743] Exception stack(0xeea15fb0 to 0xeea15ff8)
    [    9.528816] 5fa0:                                     00000000 00000000 00000000 00000000
    [    9.537031] 5fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [    9.545245] 5fe0: 00000000 00000000 00000000 00000000 00000013 00000000
    [    9.551889]  r10:00000000 r9:00000000 r8:00000000 r7:00000000 r6:00000000 r5:c024c654
    [    9.559752]  r4:ee9d2600
    [    9.562295] ---[ end trace 200ff3becaf4cb2f ]---
    [    9.566997] ------------[ cut here ]------------
    [    9.571641] WARNING: CPU: 0 PID: 23 at drivers/bus/omap_l3_noc.c:147 l3_interrupt_handler+0x330/0x380
    [    9.580901] 44000000.ocp:L3 Custom Error: MASTER MPU TARGET L4_PER2_P3 (Read): Data Access in User mode during Functional access
    [    9.592513] Modules linked in:
    [    9.595582] CPU: 0 PID: 23 Comm: kworker/0:1 Tainted: G        W         4.19.94-gbe5389fd85 #1
    [    9.604316] Hardware name: Generic DRA74X (Flattened Device Tree)
    [    9.610438] Workqueue: pm pm_runtime_work
    [    9.614463] Backtrace:
    [    9.616925] [<c020ca34>] (dump_backtrace) from [<c020cd6c>] (show_stack+0x18/0x1c)
    [    9.624529]  r7:c0dfdec4 r6:60000193 r5:00000000 r4:c12506dc
    [    9.630217] [<c020cd54>] (show_stack) from [<c0a15124>] (dump_stack+0x9c/0xb0)
    [    9.637475] [<c0a15088>] (dump_stack) from [<c022e100>] (__warn+0xdc/0xf8)
    [    9.644380]  r7:c0dfdec4 r6:00000009 r5:00000000 r4:eea15b94
    [    9.650066] [<c022e024>] (__warn) from [<c022dd38>] (warn_slowpath_fmt+0x50/0x6c)
    [    9.657583]  r9:ee9d39c0 r8:f0882564 r7:c0dfddf0 r6:c0dfdd30 r5:c0dfde94 r4:c1204c48
    [    9.665364] [<c022dcec>] (warn_slowpath_fmt) from [<c056711c>] (l3_interrupt_handler+0x330/0x380)
    [    9.674274]  r3:ee9d7f00 r2:c0dfde94
    [    9.677865]  r5:00000002 r4:80080003
    [    9.681461] [<c0566dec>] (l3_interrupt_handler) from [<c02895ec>] (__handle_irq_event_percpu+0x68/0x140)
    [    9.690984]  r10:c12522f8 r9:ee9d9f00 r8:00000017 r7:eea15cc0 r6:00000000 r5:ee9d9f68
    [    9.698845]  r4:eea183c0
    [    9.701393] [<c0289584>] (__handle_irq_event_percpu) from [<c02896f8>] (handle_irq_event_percpu+0x34/0x88)
    [    9.711090]  r10:ffffe000 r9:eea14000 r8:ee80c000 r7:00000001 r6:ee9d9f00 r5:ee9d9f68
    [    9.718954]  r4:c1204c48
    [    9.721501] [<c02896c4>] (handle_irq_event_percpu) from [<c028978c>] (handle_irq_event+0x40/0x64)
    [    9.730411]  r6:c120a434 r5:ee9d9f68 r4:ee9d9f00
    [    9.735052] [<c028974c>] (handle_irq_event) from [<c028d4dc>] (handle_fasteoi_irq+0xc0/0x168)
    [    9.743614]  r7:00000001 r6:c120a434 r5:ee9d9f68 r4:ee9d9f00
    [    9.749301] [<c028d41c>] (handle_fasteoi_irq) from [<c02887e8>] (generic_handle_irq+0x2c/0x3c)
    [    9.757950]  r7:00000001 r6:00000000 r5:00000000 r4:c1068cfc
    [    9.763637] [<c02887bc>] (generic_handle_irq) from [<c0288e4c>] (__handle_domain_irq+0x64/0xbc)
    [    9.772376] [<c0288de8>] (__handle_domain_irq) from [<c0565458>] (gic_handle_irq+0x44/0x80)
    [    9.780765]  r9:eea14000 r8:fa213000 r7:eea15d88 r6:fa212000 r5:fa21200c r4:c1205104
    [    9.788545] [<c0565414>] (gic_handle_irq) from [<c02019f8>] (__irq_svc+0x58/0x8c)
    [    9.796058] Exception stack(0xeea15d88 to 0xeea15dd0)
    [    9.801133] 5d80:                   fa468000 edc8cc40 c0c97470 fa468074 eea92610 00000000
    [    9.809348] 5da0: eea92688 c1203d00 c0220a94 c1204c48 ffffe000 eea15de4 edc8cdb4 eea15dd8
    [    9.817560] 5dc0: c0c97488 c08b1d38 80000113 ffffffff
    [    9.822636]  r9:eea14000 r8:c0220a94 r7:eea15dbc r6:ffffffff r5:80000113 r4:c08b1d38
    [    9.830419] [<c08b1d08>] (davinci_mcasp_runtime_suspend) from [<c06cf210>] (pm_generic_runtime_suspend+0x34/0x40)
    [    9.840729] [<c06cf1dc>] (pm_generic_runtime_suspend) from [<c0220aa8>] (_od_runtime_suspend+0x14/0x28)
    [    9.850166] [<c0220a94>] (_od_runtime_suspend) from [<c06d1e2c>] (__rpm_callback+0x14c/0x1e0)
    [    9.858728]  r5:00000000 r4:eea92610
    [    9.862321] [<c06d1ce0>] (__rpm_callback) from [<c06d1ee8>] (rpm_callback+0x28/0x88)
    [    9.870099]  r10:ffffe000 r9:c1204c48 r8:00000008 r7:c1203d00 r6:c0220a94 r5:00000000
    [    9.877961]  r4:eea92610
    [    9.880506] [<c06d1ec0>] (rpm_callback) from [<c06d0f40>] (rpm_suspend+0x148/0x518)
    [    9.888196]  r7:c1203d00 r6:c0220a94 r5:00000000 r4:eea92610
    [    9.893881] [<c06d0df8>] (rpm_suspend) from [<c06d149c>] (rpm_idle+0xc8/0x148)
    [    9.901136]  r10:00000000 r9:eea926c8 r8:eea926d4 r7:00000000 r6:00000002 r5:00000000
    [    9.908998]  r4:eea92610
    [    9.911544] [<c06d13d4>] (rpm_idle) from [<c06d26a8>] (pm_runtime_work+0x94/0x98)
    [    9.919061]  r9:eea926c8 r8:00000000 r7:eed5e200 r6:eed59d80 r5:eea92688 r4:eea926c4
    [    9.926840] [<c06d2614>] (pm_runtime_work) from [<c02464d0>] (process_one_work+0x1f4/0x404)
    [    9.935226]  r5:ee9d3180 r4:eea926c4
    [    9.938819] [<c02462dc>] (process_one_work) from [<c02472a4>] (worker_thread+0x58/0x568)
    [    9.946946]  r10:eed59d80 r9:c1203d00 r8:eed59d98 r7:00000008 r6:eed59d80 r5:ee9d3194
    [    9.954808]  r4:ee9d3180
    [    9.957355] [<c024724c>] (worker_thread) from [<c024c7b4>] (kthread+0x160/0x168)
    [    9.964784]  r10:ee8ade74 r9:c024724c r8:ee9d3180 r7:eea14000 r6:00000000 r5:ee9d2600
    [    9.972646]  r4:ee9e4080
    [    9.975192] [<c024c654>] (kthread) from [<c02010d8>] (ret_from_fork+0x14/0x3c)
    [    9.982444] Exception stack(0xeea15fb0 to 0xeea15ff8)
    [    9.987517] 5fa0:                                     00000000 00000000 00000000 00000000
    [    9.995731] 5fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [   10.003945] 5fe0: 00000000 00000000 00000000 00000000 00000013 00000000
    [   10.010590]  r10:00000000 r9:00000000 r8:00000000 r7:00000000 r6:00000000 r5:c024c654
    [   10.018453]  r4:ee9d2600
    [   10.020995] ---[ end trace 200ff3becaf4cb30 ]---
    [   10.025693] ------------[ cut here ]------------
    [   10.030335] WARNING: CPU: 0 PID: 23 at drivers/bus/omap_l3_noc.c:147 l3_interrupt_handler+0x330/0x380
    [   10.039594] 44000000.ocp:L3 Custom Error: MASTER MPU TARGET L4_PER2_P3 (Read): Data Access in User mode during Functional access
    [   10.051205] Modules linked in:
    [   10.054275] CPU: 0 PID: 23 Comm: kworker/0:1 Tainted: G        W         4.19.94-gbe5389fd85 #1
    [   10.063009] Hardware name: Generic DRA74X (Flattened Device Tree)
    [   10.069131] Workqueue: pm pm_runtime_work
    [   10.073157] Backtrace:
    [   10.075619] [<c020ca34>] (dump_backtrace) from [<c020cd6c>] (show_stack+0x18/0x1c)
    [   10.083223]  r7:c0dfdec4 r6:60000193 r5:00000000 r4:c12506dc
    [   10.088910] [<c020cd54>] (show_stack) from [<c0a15124>] (dump_stack+0x9c/0xb0)
    [   10.096169] [<c0a15088>] (dump_stack) from [<c022e100>] (__warn+0xdc/0xf8)
    [   10.103075]  r7:c0dfdec4 r6:00000009 r5:00000000 r4:eea15b94
    [   10.108761] [<c022e024>] (__warn) from [<c022dd38>] (warn_slowpath_fmt+0x50/0x6c)
    [   10.116278]  r9:ee9d39c0 r8:f0882564 r7:c0dfddf0 r6:c0dfdd30 r5:c0dfde94 r4:c1204c48
    [   10.124059] [<c022dcec>] (warn_slowpath_fmt) from [<c056711c>] (l3_interrupt_handler+0x330/0x380)
    [   10.132969]  r3:ee9d7f00 r2:c0dfde94
    [   10.136560]  r5:00000002 r4:80080003
    [   10.140156] [<c0566dec>] (l3_interrupt_handler) from [<c02895ec>] (__handle_irq_event_percpu+0x68/0x140)
    [   10.149680]  r10:c12522f8 r9:ee9d9f00 r8:00000017 r7:eea15cc0 r6:00000000 r5:ee9d9f68
    [   10.157542]  r4:eea183c0
    [   10.160091] [<c0289584>] (__handle_irq_event_percpu) from [<c02896f8>] (handle_irq_event_percpu+0x34/0x88)
    [   10.169788]  r10:ffffe000 r9:eea14000 r8:ee80c000 r7:00000001 r6:ee9d9f00 r5:ee9d9f68
    [   10.177651]  r4:c1204c48
    [   10.180200] [<c02896c4>] (handle_irq_event_percpu) from [<c028978c>] (handle_irq_event+0x40/0x64)
    [   10.189110]  r6:c120a434 r5:ee9d9f68 r4:ee9d9f00
    [   10.193750] [<c028974c>] (handle_irq_event) from [<c028d4dc>] (handle_fasteoi_irq+0xc0/0x168)
    [   10.202313]  r7:00000001 r6:c120a434 r5:ee9d9f68 r4:ee9d9f00
    [   10.207999] [<c028d41c>] (handle_fasteoi_irq) from [<c02887e8>] (generic_handle_irq+0x2c/0x3c)
    [   10.216648]  r7:00000001 r6:00000000 r5:00000000 r4:c1068cfc
    [   10.222336] [<c02887bc>] (generic_handle_irq) from [<c0288e4c>] (__handle_domain_irq+0x64/0xbc)
    [   10.231077] [<c0288de8>] (__handle_domain_irq) from [<c0565458>] (gic_handle_irq+0x44/0x80)
    [   10.239465]  r9:eea14000 r8:fa213000 r7:eea15d88 r6:fa212000 r5:fa21200c r4:c1205104
    [   10.247246] [<c0565414>] (gic_handle_irq) from [<c02019f8>] (__irq_svc+0x58/0x8c)
    [   10.254760] Exception stack(0xeea15d88 to 0xeea15dd0)
    [   10.259835] 5d80:                   fa468000 edc8cc40 c0c97474 fa468014 eea92610 00000000
    [   10.268050] 5da0: eea92688 c1203d00 c0220a94 c1204c48 ffffe000 eea15de4 edc8cdb8 eea15dd8
    [   10.276263] 5dc0: c0c97488 c08b1d38 80000113 ffffffff
    [   10.281338]  r9:eea14000 r8:c0220a94 r7:eea15dbc r6:ffffffff r5:80000113 r4:c08b1d38
    [   10.289121] [<c08b1d08>] (davinci_mcasp_runtime_suspend) from [<c06cf210>] (pm_generic_runtime_suspend+0x34/0x40)
    [   10.299431] [<c06cf1dc>] (pm_generic_runtime_suspend) from [<c0220aa8>] (_od_runtime_suspend+0x14/0x28)
    [   10.308868] [<c0220a94>] (_od_runtime_suspend) from [<c06d1e2c>] (__rpm_callback+0x14c/0x1e0)
    [   10.317428]  r5:00000000 r4:eea92610
    [   10.321021] [<c06d1ce0>] (__rpm_callback) from [<c06d1ee8>] (rpm_callback+0x28/0x88)
    [   10.328801]  r10:ffffe000 r9:c1204c48 r8:00000008 r7:c1203d00 r6:c0220a94 r5:00000000
    [   10.336662]  r4:eea92610
    [   10.339207] [<c06d1ec0>] (rpm_callback) from [<c06d0f40>] (rpm_suspend+0x148/0x518)
    [   10.346897]  r7:c1203d00 r6:c0220a94 r5:00000000 r4:eea92610
    [   10.352582] [<c06d0df8>] (rpm_suspend) from [<c06d149c>] (rpm_idle+0xc8/0x148)
    [   10.359838]  r10:00000000 r9:eea926c8 r8:eea926d4 r7:00000000 r6:00000002 r5:00000000
    [   10.367701]  r4:eea92610
    [   10.370246] [<c06d13d4>] (rpm_idle) from [<c06d26a8>] (pm_runtime_work+0x94/0x98)
    [   10.377764]  r9:eea926c8 r8:00000000 r7:eed5e200 r6:eed59d80 r5:eea92688 r4:eea926c4
    [   10.385543] [<c06d2614>] (pm_runtime_work) from [<c02464d0>] (process_one_work+0x1f4/0x404)
    [   10.393929]  r5:ee9d3180 r4:eea926c4
    [   10.397522] [<c02462dc>] (process_one_work) from [<c02472a4>] (worker_thread+0x58/0x568)
    [   10.405650]  r10:eed59d80 r9:c1203d00 r8:eed59d98 r7:00000008 r6:eed59d80 r5:ee9d3194
    [   10.413512]  r4:ee9d3180
    [   10.416060] [<c024724c>] (worker_thread) from [<c024c7b4>] (kthread+0x160/0x168)
    [   10.423491]  r10:ee8ade74 r9:c024724c r8:ee9d3180 r7:eea14000 r6:00000000 r5:ee9d2600
    [   10.431353]  r4:ee9e4080
    [   10.433901] [<c024c654>] (kthread) from [<c02010d8>] (ret_from_fork+0x14/0x3c)
    [   10.441154] Exception stack(0xeea15fb0 to 0xeea15ff8)
    [   10.446228] 5fa0:                                     00000000 00000000 00000000 00000000
    [   10.454443] 5fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [   10.462656] 5fe0: 00000000 00000000 00000000 00000000 00000013 00000000
    [   10.469302]  r10:00000000 r9:00000000 r8:00000000 r7:00000000 r6:00000000 r5:c024c654
    [   10.477163]  r4:ee9d2600
    [   10.479705] ---[ end trace 200ff3becaf4cb31 ]---
    [   10.484401] ------------[ cut here ]------------
    [   10.489045] WARNING: CPU: 0 PID: 23 at drivers/bus/omap_l3_noc.c:147 l3_interrupt_handler+0x330/0x380
    [   10.498305] 44000000.ocp:L3 Custom Error: MASTER MPU TARGET L4_PER2_P3 (Read): Data Access in User mode during Functional access
    [   10.509916] Modules linked in:
    [   10.512987] CPU: 0 PID: 23 Comm: kworker/0:1 Tainted: G        W         4.19.94-gbe5389fd85 #1
    [   10.521721] Hardware name: Generic DRA74X (Flattened Device Tree)
    [   10.527843] Workqueue: pm pm_runtime_work
    [   10.531869] Backtrace:
    [   10.534330] [<c020ca34>] (dump_backtrace) from [<c020cd6c>] (show_stack+0x18/0x1c)
    [   10.541934]  r7:c0dfdec4 r6:60000193 r5:00000000 r4:c12506dc
    [   10.547621] [<c020cd54>] (show_stack) from [<c0a15124>] (dump_stack+0x9c/0xb0)
    [   10.554879] [<c0a15088>] (dump_stack) from [<c022e100>] (__warn+0xdc/0xf8)
    [   10.561784]  r7:c0dfdec4 r6:00000009 r5:00000000 r4:eea15b94
    [   10.567471] [<c022e024>] (__warn) from [<c022dd38>] (warn_slowpath_fmt+0x50/0x6c)
    [   10.574989]  r9:ee9d39c0 r8:f0882564 r7:c0dfddf0 r6:c0dfdd30 r5:c0dfde94 r4:c1204c48
    [   10.582770] [<c022dcec>] (warn_slowpath_fmt) from [<c056711c>] (l3_interrupt_handler+0x330/0x380)
    [   10.591680]  r3:ee9d7f00 r2:c0dfde94
    [   10.595270]  r5:00000002 r4:80080003
    [   10.598865] [<c0566dec>] (l3_interrupt_handler) from [<c02895ec>] (__handle_irq_event_percpu+0x68/0x140)
    [   10.608388]  r10:c12522f8 r9:ee9d9f00 r8:00000017 r7:eea15cc0 r6:00000000 r5:ee9d9f68
    [   10.616250]  r4:eea183c0
    [   10.618800] [<c0289584>] (__handle_irq_event_percpu) from [<c02896f8>] (handle_irq_event_percpu+0x34/0x88)
    [   10.628497]  r10:ffffe000 r9:eea14000 r8:ee80c000 r7:00000001 r6:ee9d9f00 r5:ee9d9f68
    [   10.636359]  r4:c1204c48
    [   10.638908] [<c02896c4>] (handle_irq_event_percpu) from [<c028978c>] (handle_irq_event+0x40/0x64)
    [   10.647819]  r6:c120a434 r5:ee9d9f68 r4:ee9d9f00
    [   10.652459] [<c028974c>] (handle_irq_event) from [<c028d4dc>] (handle_fasteoi_irq+0xc0/0x168)
    [   10.661020]  r7:00000001 r6:c120a434 r5:ee9d9f68 r4:ee9d9f00
    [   10.666708] [<c028d41c>] (handle_fasteoi_irq) from [<c02887e8>] (generic_handle_irq+0x2c/0x3c)
    [   10.675358]  r7:00000001 r6:00000000 r5:00000000 r4:c1068cfc
    [   10.681046] [<c02887bc>] (generic_handle_irq) from [<c0288e4c>] (__handle_domain_irq+0x64/0xbc)
    [   10.689787] [<c0288de8>] (__handle_domain_irq) from [<c0565458>] (gic_handle_irq+0x44/0x80)
    [   10.698177]  r9:eea14000 r8:fa213000 r7:eea15d88 r6:fa212000 r5:fa21200c r4:c1205104
    [   10.705958] [<c0565414>] (gic_handle_irq) from [<c02019f8>] (__irq_svc+0x58/0x8c)
    [   10.713472] Exception stack(0xeea15d88 to 0xeea15dd0)
    [   10.718547] 5d80:                   fa468000 edc8cc40 c0c97478 fa468010 eea92610 00000000
    [   10.726761] 5da0: eea92688 c1203d00 c0220a94 c1204c48 ffffe000 eea15de4 edc8cdbc eea15dd8
    [   10.734974] 5dc0: c0c97488 c08b1d38 80000113 ffffffff
    [   10.740049]  r9:eea14000 r8:c0220a94 r7:eea15dbc r6:ffffffff r5:80000113 r4:c08b1d38
    [   10.747832] [<c08b1d08>] (davinci_mcasp_runtime_suspend) from [<c06cf210>] (pm_generic_runtime_suspend+0x34/0x40)
    [   10.758143] [<c06cf1dc>] (pm_generic_runtime_suspend) from [<c0220aa8>] (_od_runtime_suspend+0x14/0x28)
    [   10.767580] [<c0220a94>] (_od_runtime_suspend) from [<c06d1e2c>] (__rpm_callback+0x14c/0x1e0)
    [   10.776142]  r5:00000000 r4:eea92610
    [   10.779734] [<c06d1ce0>] (__rpm_callback) from [<c06d1ee8>] (rpm_callback+0x28/0x88)
    [   10.787513]  r10:ffffe000 r9:c1204c48 r8:00000008 r7:c1203d00 r6:c0220a94 r5:00000000
    [   10.795376]  r4:eea92610
    [   10.797921] [<c06d1ec0>] (rpm_callback) from [<c06d0f40>] (rpm_suspend+0x148/0x518)
    [   10.805611]  r7:c1203d00 r6:c0220a94 r5:00000000 r4:eea92610
    [   10.811297] [<c06d0df8>] (rpm_suspend) from [<c06d149c>] (rpm_idle+0xc8/0x148)
    [   10.818552]  r10:00000000 r9:eea926c8 r8:eea926d4 r7:00000000 r6:00000002 r5:00000000
    [   10.826414]  r4:eea92610
    [   10.828961] [<c06d13d4>] (rpm_idle) from [<c06d26a8>] (pm_runtime_work+0x94/0x98)
    [   10.836477]  r9:eea926c8 r8:00000000 r7:eed5e200 r6:eed59d80 r5:eea92688 r4:eea926c4
    [   10.844257] [<c06d2614>] (pm_runtime_work) from [<c02464d0>] (process_one_work+0x1f4/0x404)
    [   10.852644]  r5:ee9d3180 r4:eea926c4
    [   10.856235] [<c02462dc>] (process_one_work) from [<c02472a4>] (worker_thread+0x58/0x568)
    [   10.864363]  r10:eed59d80 r9:c1203d00 r8:eed59d98 r7:00000008 r6:eed59d80 r5:ee9d3194
    [   10.872225]  r4:ee9d3180
    [   10.874771] [<c024724c>] (worker_thread) from [<c024c7b4>] (kthread+0x160/0x168)
    [   10.882201]  r10:ee8ade74 r9:c024724c r8:ee9d3180 r7:eea14000 r6:00000000 r5:ee9d2600
    [   10.890064]  r4:ee9e4080
    [   10.892610] [<c024c654>] (kthread) from [<c02010d8>] (ret_from_fork+0x14/0x3c)
    [   10.899864] Exception stack(0xeea15fb0 to 0xeea15ff8)
    [   10.904937] 5fa0:                                     00000000 00000000 00000000 00000000
    [   10.913152] 5fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [   10.921365] 5fe0: 00000000 00000000 00000000 00000000 00000013 00000000
    [   10.928010]  r10:00000000 r9:00000000 r8:00000000 r7:00000000 r6:00000000 r5:c024c654
    [   10.935872]  r4:ee9d2600
    [   10.938414] ---[ end trace 200ff3becaf4cb32 ]---
    [   10.943115] ------------[ cut here ]------------
    [   10.947759] WARNING: CPU: 0 PID: 23 at drivers/bus/omap_l3_noc.c:147 l3_interrupt_handler+0x330/0x380
    [   10.957019] 44000000.ocp:L3 Custom Error: MASTER MPU TARGET L4_PER2_P3 (Read): Data Access in User mode during Functional access
    [   10.968631] Modules linked in:
    [   10.971701] CPU: 0 PID: 23 Comm: kworker/0:1 Tainted: G        W         4.19.94-gbe5389fd85 #1
    [   10.980436] Hardware name: Generic DRA74X (Flattened Device Tree)
    [   10.986557] Workqueue: pm pm_runtime_work
    [   10.990584] Backtrace:
    [   10.993045] [<c020ca34>] (dump_backtrace) from [<c020cd6c>] (show_stack+0x18/0x1c)
    [   11.000648]  r7:c0dfdec4 r6:60000193 r5:00000000 r4:c12506dc
    [   11.006337] [<c020cd54>] (show_stack) from [<c0a15124>] (dump_stack+0x9c/0xb0)
    [   11.013594] [<c0a15088>] (dump_stack) from [<c022e100>] (__warn+0xdc/0xf8)
    [   11.020499]  r7:c0dfdec4 r6:00000009 r5:00000000 r4:eea15b94
    [   11.026185] [<c022e024>] (__warn) from [<c022dd38>] (warn_slowpath_fmt+0x50/0x6c)
    [   11.033702]  r9:ee9d39c0 r8:f0882564 r7:c0dfddf0 r6:c0dfdd30 r5:c0dfde94 r4:c1204c48
    [   11.041482] [<c022dcec>] (warn_slowpath_fmt) from [<c056711c>] (l3_interrupt_handler+0x330/0x380)
    [   11.050392]  r3:ee9d7f00 r2:c0dfde94
    [   11.053982]  r5:00000002 r4:80080003
    [   11.057577] [<c0566dec>] (l3_interrupt_handler) from [<c02895ec>] (__handle_irq_event_percpu+0x68/0x140)
    [   11.067101]  r10:c12522f8 r9:ee9d9f00 r8:00000017 r7:eea15cc0 r6:00000000 r5:ee9d9f68
    [   11.074963]  r4:eea183c0
    [   11.077512] [<c0289584>] (__handle_irq_event_percpu) from [<c02896f8>] (handle_irq_event_percpu+0x34/0x88)
    [   11.087209]  r10:ffffe000 r9:eea14000 r8:ee80c000 r7:00000001 r6:ee9d9f00 r5:ee9d9f68
    [   11.095071]  r4:c1204c48
    [   11.097619] [<c02896c4>] (handle_irq_event_percpu) from [<c028978c>] (handle_irq_event+0x40/0x64)
    [   11.106530]  r6:c120a434 r5:ee9d9f68 r4:ee9d9f00
    [   11.111171] [<c028974c>] (handle_irq_event) from [<c028d4dc>] (handle_fasteoi_irq+0xc0/0x168)
    [   11.119734]  r7:00000001 r6:c120a434 r5:ee9d9f68 r4:ee9d9f00
    [   11.125420] [<c028d41c>] (handle_fasteoi_irq) from [<c02887e8>] (generic_handle_irq+0x2c/0x3c)
    [   11.134069]  r7:00000001 r6:00000000 r5:00000000 r4:c1068cfc
    [   11.139757] [<c02887bc>] (generic_handle_irq) from [<c0288e4c>] (__handle_domain_irq+0x64/0xbc)
    [   11.148497] [<c0288de8>] (__handle_domain_irq) from [<c0565458>] (gic_handle_irq+0x44/0x80)
    [   11.156885]  r9:eea14000 r8:fa213000 r7:eea15d88 r6:fa212000 r5:fa21200c r4:c1205104
    [   11.164665] [<c0565414>] (gic_handle_irq) from [<c02019f8>] (__irq_svc+0x58/0x8c)
    [   11.172178] Exception stack(0xeea15d88 to 0xeea15dd0)
    [   11.177253] 5d80:                   fa468000 edc8cc40 c0c9747c fa468064 eea92610 00000000
    [   11.185468] 5da0: eea92688 c1203d00 c0220a94 c1204c48 ffffe000 eea15de4 edc8cdc0 eea15dd8
    [   11.193681] 5dc0: c0c97488 c08b1d38 80000113 ffffffff
    [   11.198757]  r9:eea14000 r8:c0220a94 r7:eea15dbc r6:ffffffff r5:80000113 r4:c08b1d38
    [   11.206538] [<c08b1d08>] (davinci_mcasp_runtime_suspend) from [<c06cf210>] (pm_generic_runtime_suspend+0x34/0x40)
    [   11.216848] [<c06cf1dc>] (pm_generic_runtime_suspend) from [<c0220aa8>] (_od_runtime_suspend+0x14/0x28)
    [   11.226286] [<c0220a94>] (_od_runtime_suspend) from [<c06d1e2c>] (__rpm_callback+0x14c/0x1e0)
    [   11.234847]  r5:00000000 r4:eea92610
    [   11.238440] [<c06d1ce0>] (__rpm_callback) from [<c06d1ee8>] (rpm_callback+0x28/0x88)
    [   11.246217]  r10:ffffe000 r9:c1204c48 r8:00000008 r7:c1203d00 r6:c0220a94 r5:00000000
    [   11.254079]  r4:eea92610
    [   11.256626] [<c06d1ec0>] (rpm_callback) from [<c06d0f40>] (rpm_suspend+0x148/0x518)
    [   11.264316]  r7:c1203d00 r6:c0220a94 r5:00000000 r4:eea92610
    [   11.270002] [<c06d0df8>] (rpm_suspend) from [<c06d149c>] (rpm_idle+0xc8/0x148)
    [   11.277257]  r10:00000000 r9:eea926c8 r8:eea926d4 r7:00000000 r6:00000002 r5:00000000
    [   11.285120]  r4:eea92610
    [   11.287666] [<c06d13d4>] (rpm_idle) from [<c06d26a8>] (pm_runtime_work+0x94/0x98)
    [   11.295183]  r9:eea926c8 r8:00000000 r7:eed5e200 r6:eed59d80 r5:eea92688 r4:eea926c4
    [   11.302962] [<c06d2614>] (pm_runtime_work) from [<c02464d0>] (process_one_work+0x1f4/0x404)
    [   11.311349]  r5:ee9d3180 r4:eea926c4
    [   11.314941] [<c02462dc>] (process_one_work) from [<c02472a4>] (worker_thread+0x58/0x568)
    [   11.323069]  r10:eed59d80 r9:c1203d00 r8:eed59d98 r7:00000008 r6:eed59d80 r5:ee9d3194
    [   11.330932]  r4:ee9d3180
    [   11.333480] [<c024724c>] (worker_thread) from [<c024c7b4>] (kthread+0x160/0x168)
    [   11.340910]  r10:ee8ade74 r9:c024724c r8:ee9d3180 r7:eea14000 r6:00000000 r5:ee9d2600
    [   11.348772]  r4:ee9e4080
    [   11.351319] [<c024c654>] (kthread) from [<c02010d8>] (ret_from_fork+0x14/0x3c)
    [   11.358572] Exception stack(0xeea15fb0 to 0xeea15ff8)
    [   11.363645] 5fa0:                                     00000000 00000000 00000000 00000000
    [   11.371859] 5fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [   11.380072] 5fe0: 00000000 00000000 00000000 00000000 00000013 00000000
    [   11.386718]  r10:00000000 r9:00000000 r8:00000000 r7:00000000 r6:00000000 r5:c024c654
    [   11.394580]  r4:ee9d2600
    [   11.397123] ---[ end trace 200ff3becaf4cb33 ]---
    [   11.401815] ------------[ cut here ]------------
    [   11.406463] WARNING: CPU: 0 PID: 23 at drivers/bus/omap_l3_noc.c:147 l3_interrupt_handler+0x330/0x380
    [   11.415723] 44000000.ocp:L3 Custom Error: MASTER MPU TARGET L4_PER2_P3 (Read): Data Access in User mode during Functional access
    [   11.427335] Modules linked in:
    [   11.430405] CPU: 0 PID: 23 Comm: kworker/0:1 Tainted: G        W         4.19.94-gbe5389fd85 #1
    [   11.439140] Hardware name: Generic DRA74X (Flattened Device Tree)
    [   11.445261] Workqueue: pm pm_runtime_work
    [   11.449286] Backtrace:
    [   11.451747] [<c020ca34>] (dump_backtrace) from [<c020cd6c>] (show_stack+0x18/0x1c)
    [   11.459351]  r7:c0dfdec4 r6:60000193 r5:00000000 r4:c12506dc
    [   11.465039] [<c020cd54>] (show_stack) from [<c0a15124>] (dump_stack+0x9c/0xb0)
    [   11.472296] [<c0a15088>] (dump_stack) from [<c022e100>] (__warn+0xdc/0xf8)
    [   11.479201]  r7:c0dfdec4 r6:00000009 r5:00000000 r4:eea15b94
    [   11.484887] [<c022e024>] (__warn) from [<c022dd38>] (warn_slowpath_fmt+0x50/0x6c)
    [   11.492404]  r9:ee9d39c0 r8:f0882564 r7:c0dfddf0 r6:c0dfdd30 r5:c0dfde94 r4:c1204c48
    [   11.500185] [<c022dcec>] (warn_slowpath_fmt) from [<c056711c>] (l3_interrupt_handler+0x330/0x380)
    [   11.509095]  r3:ee9d7f00 r2:c0dfde94
    [   11.512684]  r5:00000002 r4:80080003
    [   11.516279] [<c0566dec>] (l3_interrupt_handler) from [<c02895ec>] (__handle_irq_event_percpu+0x68/0x140)
    [   11.525802]  r10:c12522f8 r9:ee9d9f00 r8:00000017 r7:eea15cc0 r6:00000000 r5:ee9d9f68
    [   11.533665]  r4:eea183c0
    [   11.536214] [<c0289584>] (__handle_irq_event_percpu) from [<c02896f8>] (handle_irq_event_percpu+0x34/0x88)
    [   11.545910]  r10:ffffe000 r9:eea14000 r8:ee80c000 r7:00000001 r6:ee9d9f00 r5:ee9d9f68
    [   11.553773]  r4:c1204c48
    [   11.556322] [<c02896c4>] (handle_irq_event_percpu) from [<c028978c>] (handle_irq_event+0x40/0x64)
    [   11.565231]  r6:c120a434 r5:ee9d9f68 r4:ee9d9f00
    [   11.569872] [<c028974c>] (handle_irq_event) from [<c028d4dc>] (handle_fasteoi_irq+0xc0/0x168)
    [   11.578435]  r7:00000001 r6:c120a434 r5:ee9d9f68 r4:ee9d9f00
    [   11.584121] [<c028d41c>] (handle_fasteoi_irq) from [<c02887e8>] (generic_handle_irq+0x2c/0x3c)
    [   11.592771]  r7:00000001 r6:00000000 r5:00000000 r4:c1068cfc
    [   11.598458] [<c02887bc>] (generic_handle_irq) from [<c0288e4c>] (__handle_domain_irq+0x64/0xbc)
    [   11.607198] [<c0288de8>] (__handle_domain_irq) from [<c0565458>] (gic_handle_irq+0x44/0x80)
    [   11.615588]  r9:eea14000 r8:fa213000 r7:eea15d88 r6:fa212000 r5:fa21200c r4:c1205104
    [   11.623367] [<c0565414>] (gic_handle_irq) from [<c02019f8>] (__irq_svc+0x58/0x8c)
    [   11.630882] Exception stack(0xeea15d88 to 0xeea15dd0)
    [   11.635958] 5d80:                   fa468000 edc8cc40 c0c97480 fa4680a4 eea92610 00000000
    [   11.644173] 5da0: eea92688 c1203d00 c0220a94 c1204c48 ffffe000 eea15de4 edc8cdc4 eea15dd8
    [   11.652385] 5dc0: c0c97488 c08b1d38 80000113 ffffffff
    [   11.657460]  r9:eea14000 r8:c0220a94 r7:eea15dbc r6:ffffffff r5:80000113 r4:c08b1d38
    [   11.665243] [<c08b1d08>] (davinci_mcasp_runtime_suspend) from [<c06cf210>] (pm_generic_runtime_suspend+0x34/0x40)
    [   11.675554] [<c06cf1dc>] (pm_generic_runtime_suspend) from [<c0220aa8>] (_od_runtime_suspend+0x14/0x28)
    [   11.684990] [<c0220a94>] (_od_runtime_suspend) from [<c06d1e2c>] (__rpm_callback+0x14c/0x1e0)
    [   11.693551]  r5:00000000 r4:eea92610
    [   11.697144] [<c06d1ce0>] (__rpm_callback) from [<c06d1ee8>] (rpm_callback+0x28/0x88)
    [   11.704923]  r10:ffffe000 r9:c1204c48 r8:00000008 r7:c1203d00 r6:c0220a94 r5:00000000
    [   11.712786]  r4:eea92610
    [   11.715332] [<c06d1ec0>] (rpm_callback) from [<c06d0f40>] (rpm_suspend+0x148/0x518)
    [   11.723022]  r7:c1203d00 r6:c0220a94 r5:00000000 r4:eea92610
    [   11.728708] [<c06d0df8>] (rpm_suspend) from [<c06d149c>] (rpm_idle+0xc8/0x148)
    [   11.735964]  r10:00000000 r9:eea926c8 r8:eea926d4 r7:00000000 r6:00000002 r5:00000000
    [   11.743827]  r4:eea92610
    [   11.746373] [<c06d13d4>] (rpm_idle) from [<c06d26a8>] (pm_runtime_work+0x94/0x98)
    [   11.753890]  r9:eea926c8 r8:00000000 r7:eed5e200 r6:eed59d80 r5:eea92688 r4:eea926c4
    [   11.761669] [<c06d2614>] (pm_runtime_work) from [<c02464d0>] (process_one_work+0x1f4/0x404)
    [   11.770055]  r5:ee9d3180 r4:eea926c4
    [   11.773648] [<c02462dc>] (process_one_work) from [<c02472a4>] (worker_thread+0x58/0x568)
    [   11.781775]  r10:eed59d80 r9:c1203d00 r8:eed59d98 r7:00000008 r6:eed59d80 r5:ee9d3194
    [   11.789636]  r4:ee9d3180
    [   11.792182] [<c024724c>] (worker_thread) from [<c024c7b4>] (kthread+0x160/0x168)
    [   11.799613]  r10:ee8ade74 r9:c024724c r8:ee9d3180 r7:eea14000 r6:00000000 r5:ee9d2600
    [   11.807476]  r4:ee9e4080
    [   11.810023] [<c024c654>] (kthread) from [<c02010d8>] (ret_from_fork+0x14/0x3c)
    [   11.817274] Exception stack(0xeea15fb0 to 0xeea15ff8)
    [   11.822348] 5fa0:                                     00000000 00000000 00000000 00000000
    [   11.830563] 5fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [   11.838776] 5fe0: 00000000 00000000 00000000 00000000 00000013 00000000
    [   11.845422]  r10:00000000 r9:00000000 r8:00000000 r7:00000000 r6:00000000 r5:c024c654
    [   11.853284]  r4:ee9d2600
    [   11.855826] ---[ end trace 200ff3becaf4cb34 ]---
    [   11.860525] ------------[ cut here ]------------
    [   11.865168] WARNING: CPU: 0 PID: 23 at drivers/bus/omap_l3_noc.c:147 l3_interrupt_handler+0x330/0x380
    [   11.874428] 44000000.ocp:L3 Custom Error: MASTER MPU TARGET L4_PER2_P3 (Read): Data Access in User mode during Functional access
    [   11.886040] Modules linked in:
    [   11.889110] CPU: 0 PID: 23 Comm: kworker/0:1 Tainted: G        W         4.19.94-gbe5389fd85 #1
    [   11.897845] Hardware name: Generic DRA74X (Flattened Device Tree)
    [   11.903966] Workqueue: pm pm_runtime_work
    [   11.907993] Backtrace:
    [   11.910455] [<c020ca34>] (dump_backtrace) from [<c020cd6c>] (show_stack+0x18/0x1c)
    [   11.918058]  r7:c0dfdec4 r6:60000193 r5:00000000 r4:c12506dc
    [   11.923746] [<c020cd54>] (show_stack) from [<c0a15124>] (dump_stack+0x9c/0xb0)
    [   11.931003] [<c0a15088>] (dump_stack) from [<c022e100>] (__warn+0xdc/0xf8)
    [   11.937908]  r7:c0dfdec4 r6:00000009 r5:00000000 r4:eea15b94
    [   11.943595] [<c022e024>] (__warn) from [<c022dd38>] (warn_slowpath_fmt+0x50/0x6c)
    [   11.951112]  r9:ee9d39c0 r8:f0882564 r7:c0dfddf0 r6:c0dfdd30 r5:c0dfde94 r4:c1204c48
    [   11.958893] [<c022dcec>] (warn_slowpath_fmt) from [<c056711c>] (l3_interrupt_handler+0x330/0x380)
    [   11.967804]  r3:ee9d7f00 r2:c0dfde94
    [   11.971394]  r5:00000002 r4:80080003
    [   11.974991] [<c0566dec>] (l3_interrupt_handler) from [<c02895ec>] (__handle_irq_event_percpu+0x68/0x140)
    [   11.984515]  r10:c12522f8 r9:ee9d9f00 r8:00000017 r7:eea15cc0 r6:00000000 r5:ee9d9f68
    [   11.992377]  r4:eea183c0
    [   11.994926] [<c0289584>] (__handle_irq_event_percpu) from [<c02896f8>] (handle_irq_event_percpu+0x34/0x88)
    [   12.004623]  r10:ffffe000 r9:eea14000 r8:ee80c000 r7:00000001 r6:ee9d9f00 r5:ee9d9f68
    [   12.012485]  r4:c1204c48
    [   12.015034] [<c02896c4>] (handle_irq_event_percpu) from [<c028978c>] (handle_irq_event+0x40/0x64)
    [   12.023945]  r6:c120a434 r5:ee9d9f68 r4:ee9d9f00
    [   12.028586] [<c028974c>] (handle_irq_event) from [<c028d4dc>] (handle_fasteoi_irq+0xc0/0x168)
    [   12.037148]  r7:00000001 r6:c120a434 r5:ee9d9f68 r4:ee9d9f00
    [   12.042834] [<c028d41c>] (handle_fasteoi_irq) from [<c02887e8>] (generic_handle_irq+0x2c/0x3c)
    [   12.051484]  r7:00000001 r6:00000000 r5:00000000 r4:c1068cfc
    [   12.057171] [<c02887bc>] (generic_handle_irq) from [<c0288e4c>] (__handle_domain_irq+0x64/0xbc)
    [   12.065912] [<c0288de8>] (__handle_domain_irq) from [<c0565458>] (gic_handle_irq+0x44/0x80)
    [   12.074300]  r9:eea14000 r8:fa213000 r7:eea15d88 r6:fa212000 r5:fa21200c r4:c1205104
    [   12.082081] [<c0565414>] (gic_handle_irq) from [<c02019f8>] (__irq_svc+0x58/0x8c)
    [   12.089596] Exception stack(0xeea15d88 to 0xeea15dd0)
    [   12.094671] 5d80:                   fa468000 edc8cc40 c0c97484 fa468078 eea92610 00000000
    [   12.102886] 5da0: eea92688 c1203d00 c0220a94 c1204c48 ffffe000 eea15de4 edc8cdc8 eea15dd8
    [   12.111099] 5dc0: c0c97488 c08b1d38 80000113 ffffffff
    [   12.116175]  r9:eea14000 r8:c0220a94 r7:eea15dbc r6:ffffffff r5:80000113 r4:c08b1d38
    [   12.123958] [<c08b1d08>] (davinci_mcasp_runtime_suspend) from [<c06cf210>] (pm_generic_runtime_suspend+0x34/0x40)
    [   12.134269] [<c06cf1dc>] (pm_generic_runtime_suspend) from [<c0220aa8>] (_od_runtime_suspend+0x14/0x28)
    [   12.143707] [<c0220a94>] (_od_runtime_suspend) from [<c06d1e2c>] (__rpm_callback+0x14c/0x1e0)
    [   12.152268]  r5:00000000 r4:eea92610
    [   12.155860] [<c06d1ce0>] (__rpm_callback) from [<c06d1ee8>] (rpm_callback+0x28/0x88)
    [   12.163639]  r10:ffffe000 r9:c1204c48 r8:00000008 r7:c1203d00 r6:c0220a94 r5:00000000
    [   12.171501]  r4:eea92610
    [   12.174048] [<c06d1ec0>] (rpm_callback) from [<c06d0f40>] (rpm_suspend+0x148/0x518)
    [   12.181739]  r7:c1203d00 r6:c0220a94 r5:00000000 r4:eea92610
    [   12.187424] [<c06d0df8>] (rpm_suspend) from [<c06d149c>] (rpm_idle+0xc8/0x148)
    [   12.194680]  r10:00000000 r9:eea926c8 r8:eea926d4 r7:00000000 r6:00000002 r5:00000000
    [   12.202542]  r4:eea92610
    [   12.205089] [<c06d13d4>] (rpm_idle) from [<c06d26a8>] (pm_runtime_work+0x94/0x98)
    [   12.212607]  r9:eea926c8 r8:00000000 r7:eed5e200 r6:eed59d80 r5:eea92688 r4:eea926c4
    [   12.220386] [<c06d2614>] (pm_runtime_work) from [<c02464d0>] (process_one_work+0x1f4/0x404)
    [   12.228774]  r5:ee9d3180 r4:eea926c4
    [   12.232368] [<c02462dc>] (process_one_work) from [<c02472a4>] (worker_thread+0x58/0x568)
    [   12.240496]  r10:eed59d80 r9:c1203d00 r8:eed59d98 r7:00000008 r6:eed59d80 r5:ee9d3194
    [   12.248358]  r4:ee9d3180
    [   12.250907] [<c024724c>] (worker_thread) from [<c024c7b4>] (kthread+0x160/0x168)
    [   12.258336]  r10:ee8ade74 r9:c024724c r8:ee9d3180 r7:eea14000 r6:00000000 r5:ee9d2600
    [   12.266198]  r4:ee9e4080
    [   12.268745] [<c024c654>] (kthread) from [<c02010d8>] (ret_from_fork+0x14/0x3c)
    [   12.275998] Exception stack(0xeea15fb0 to 0xeea15ff8)
    [   12.281072] 5fa0:                                     00000000 00000000 00000000 00000000
    [   12.289288] 5fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [   12.297502] 5fe0: 00000000 00000000 00000000 00000000 00000013 00000000
    [   12.304148]  r10:00000000 r9:00000000 r8:00000000 r7:00000000 r6:00000000 r5:c024c654
    [   12.312010]  r4:ee9d2600
    [   12.314552] ---[ end trace 200ff3becaf4cb35 ]---
    [   12.319242] ------------[ cut here ]------------
    [   12.323885] WARNING: CPU: 0 PID: 23 at drivers/bus/omap_l3_noc.c:147 l3_interrupt_handler+0x330/0x380
    [   12.333146] 44000000.ocp:L3 Custom Error: MASTER MPU TARGET L4_PER2_P3 (Read): Data Access in User mode during Functional access
    [   12.344757] Modules linked in:
    [   12.347828] CPU: 0 PID: 23 Comm: kworker/0:1 Tainted: G        W         4.19.94-gbe5389fd85 #1
    [   12.356563] Hardware name: Generic DRA74X (Flattened Device Tree)
    [   12.362684] Workqueue: pm pm_runtime_work
    [   12.366711] Backtrace:
    [   12.369173] [<c020ca34>] (dump_backtrace) from [<c020cd6c>] (show_stack+0x18/0x1c)
    [   12.376776]  r7:c0dfdec4 r6:60000193 r5:00000000 r4:c12506dc
    [   12.382465] [<c020cd54>] (show_stack) from [<c0a15124>] (dump_stack+0x9c/0xb0)
    [   12.389723] [<c0a15088>] (dump_stack) from [<c022e100>] (__warn+0xdc/0xf8)
    [   12.396628]  r7:c0dfdec4 r6:00000009 r5:00000000 r4:eea15b94
    [   12.402314] [<c022e024>] (__warn) from [<c022dd38>] (warn_slowpath_fmt+0x50/0x6c)
    [   12.409832]  r9:ee9d39c0 r8:f0882564 r7:c0dfddf0 r6:c0dfdd30 r5:c0dfde94 r4:c1204c48
    [   12.417612] [<c022dcec>] (warn_slowpath_fmt) from [<c056711c>] (l3_interrupt_handler+0x330/0x380)
    [   12.426523]  r3:ee9d7f00 r2:c0dfde94
    [   12.430113]  r5:00000002 r4:80080003
    [   12.433709] [<c0566dec>] (l3_interrupt_handler) from [<c02895ec>] (__handle_irq_event_percpu+0x68/0x140)
    [   12.443232]  r10:c12522f8 r9:ee9d9f00 r8:00000017 r7:eea15cc0 r6:00000000 r5:ee9d9f68
    [   12.451095]  r4:eea183c0
    [   12.453644] [<c0289584>] (__handle_irq_event_percpu) from [<c02896f8>] (handle_irq_event_percpu+0x34/0x88)
    [   12.463341]  r10:ffffe000 r9:eea14000 r8:ee80c000 r7:00000001 r6:ee9d9f00 r5:ee9d9f68
    [   12.471204]  r4:c1204c48
    [   12.473753] [<c02896c4>] (handle_irq_event_percpu) from [<c028978c>] (handle_irq_event+0x40/0x64)
    [   12.482663]  r6:c120a434 r5:ee9d9f68 r4:ee9d9f00
    [   12.487304] [<c028974c>] (handle_irq_event) from [<c028d4dc>] (handle_fasteoi_irq+0xc0/0x168)
    [   12.495866]  r7:00000001 r6:c120a434 r5:ee9d9f68 r4:ee9d9f00
    [   12.501554] [<c028d41c>] (handle_fasteoi_irq) from [<c02887e8>] (generic_handle_irq+0x2c/0x3c)
    [   12.510204]  r7:00000001 r6:00000000 r5:00000000 r4:c1068cfc
    [   12.515891] [<c02887bc>] (generic_handle_irq) from [<c0288e4c>] (__handle_domain_irq+0x64/0xbc)
    [   12.524633] [<c0288de8>] (__handle_domain_irq) from [<c0565458>] (gic_handle_irq+0x44/0x80)
    [   12.533021]  r9:eea14000 r8:fa213000 r7:eea15d88 r6:fa212000 r5:fa21200c r4:c1205104
    [   12.540801] [<c0565414>] (gic_handle_irq) from [<c02019f8>] (__irq_svc+0x58/0x8c)
    [   12.548316] Exception stack(0xeea15d88 to 0xeea15dd0)
    [   12.553391] 5d80:                   fa468000 edc8cc40 c0c97488 fa4680b8 eea92610 00000000
    [   12.561607] 5da0: eea92688 c1203d00 c0220a94 c1204c48 ffffe000 eea15de4 edc8cdcc eea15dd8
    [   12.569819] 5dc0: c0c97488 c08b1d38 80000113 ffffffff
    [   12.574895]  r9:eea14000 r8:c0220a94 r7:eea15dbc r6:ffffffff r5:80000113 r4:c08b1d38
    [   12.582678] [<c08b1d08>] (davinci_mcasp_runtime_suspend) from [<c06cf210>] (pm_generic_runtime_suspend+0x34/0x40)
    [   12.592989] [<c06cf1dc>] (pm_generic_runtime_suspend) from [<c0220aa8>] (_od_runtime_suspend+0x14/0x28)
    [   12.602426] [<c0220a94>] (_od_runtime_suspend) from [<c06d1e2c>] (__rpm_callback+0x14c/0x1e0)
    [   12.610987]  r5:00000000 r4:eea92610
    [   12.614579] [<c06d1ce0>] (__rpm_callback) from [<c06d1ee8>] (rpm_callback+0x28/0x88)
    [   12.622359]  r10:ffffe000 r9:c1204c48 r8:00000008 r7:c1203d00 r6:c0220a94 r5:00000000
    [   12.630220]  r4:eea92610
    [   12.632767] [<c06d1ec0>] (rpm_callback) from [<c06d0f40>] (rpm_suspend+0x148/0x518)
    [   12.640457]  r7:c1203d00 r6:c0220a94 r5:00000000 r4:eea92610
    [   12.646143] [<c06d0df8>] (rpm_suspend) from [<c06d149c>] (rpm_idle+0xc8/0x148)
    [   12.653399]  r10:00000000 r9:eea926c8 r8:eea926d4 r7:00000000 r6:00000002 r5:00000000
    [   12.661262]  r4:eea92610
    [   12.663809] [<c06d13d4>] (rpm_idle) from [<c06d26a8>] (pm_runtime_work+0x94/0x98)
    [   12.671326]  r9:eea926c8 r8:00000000 r7:eed5e200 r6:eed59d80 r5:eea92688 r4:eea926c4
    [   12.679105] [<c06d2614>] (pm_runtime_work) from [<c02464d0>] (process_one_work+0x1f4/0x404)
    [   12.687492]  r5:ee9d3180 r4:eea926c4
    [   12.691086] [<c02462dc>] (process_one_work) from [<c02472a4>] (worker_thread+0x58/0x568)
    [   12.699215]  r10:eed59d80 r9:c1203d00 r8:eed59d98 r7:00000008 r6:eed59d80 r5:ee9d3194
    [   12.707077]  r4:ee9d3180
    [   12.709625] [<c024724c>] (worker_thread) from [<c024c7b4>] (kthread+0x160/0x168)
    [   12.717055]  r10:ee8ade74 r9:c024724c r8:ee9d3180 r7:eea14000 r6:00000000 r5:ee9d2600
    [   12.724917]  r4:ee9e4080
    [   12.727465] [<c024c654>] (kthread) from [<c02010d8>] (ret_from_fork+0x14/0x3c)
    [   12.734717] Exception stack(0xeea15fb0 to 0xeea15ff8)
    [   12.739790] 5fa0:                                     00000000 00000000 00000000 00000000
    [   12.748005] 5fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [   12.756220] 5fe0: 00000000 00000000 00000000 00000000 00000013 00000000
    [   12.762864]  r10:00000000 r9:00000000 r8:00000000 r7:00000000 r6:00000000 r5:c024c654
    [   12.770726]  r4:ee9d2600
    [   12.773268] ---[ end trace 200ff3becaf4cb36 ]---
    [   12.777963] ------------[ cut here ]------------
    [   12.782607] WARNING: CPU: 0 PID: 23 at drivers/bus/omap_l3_noc.c:147 l3_interrupt_handler+0x330/0x380
    [   12.791867] 44000000.ocp:L3 Custom Error: MASTER MPU TARGET L4_PER2_P3 (Read): Data Access in User mode during Functional access
    [   12.803478] Modules linked in:
    [   12.806550] CPU: 0 PID: 23 Comm: kworker/0:1 Tainted: G        W         4.19.94-gbe5389fd85 #1
    [   12.815284] Hardware name: Generic DRA74X (Flattened Device Tree)
    [   12.821406] Workqueue: pm pm_runtime_work
    [   12.825433] Backtrace:
    [   12.827894] [<c020ca34>] (dump_backtrace) from [<c020cd6c>] (show_stack+0x18/0x1c)
    [   12.835497]  r7:c0dfdec4 r6:60000193 r5:00000000 r4:c12506dc
    [   12.841186] [<c020cd54>] (show_stack) from [<c0a15124>] (dump_stack+0x9c/0xb0)
    [   12.848443] [<c0a15088>] (dump_stack) from [<c022e100>] (__warn+0xdc/0xf8)
    [   12.855349]  r7:c0dfdec4 r6:00000009 r5:00000000 r4:eea15b94
    [   12.861036] [<c022e024>] (__warn) from [<c022dd38>] (warn_slowpath_fmt+0x50/0x6c)
    [   12.868553]  r9:ee9d39c0 r8:f0882564 r7:c0dfddf0 r6:c0dfdd30 r5:c0dfde94 r4:c1204c48
    [   12.876333] [<c022dcec>] (warn_slowpath_fmt) from [<c056711c>] (l3_interrupt_handler+0x330/0x380)
    [   12.885243]  r3:ee9d7f00 r2:c0dfde94
    [   12.888833]  r5:00000002 r4:80080003
    [   12.892428] [<c0566dec>] (l3_interrupt_handler) from [<c02895ec>] (__handle_irq_event_percpu+0x68/0x140)
    [   12.901952]  r10:c12522f8 r9:ee9d9f00 r8:00000017 r7:eea15cc0 r6:00000000 r5:ee9d9f68
    [   12.909814]  r4:eea183c0
    [   12.912362] [<c0289584>] (__handle_irq_event_percpu) from [<c02896f8>] (handle_irq_event_percpu+0x34/0x88)
    [   12.922061]  r10:ffffe000 r9:eea14000 r8:ee80c000 r7:00000001 r6:ee9d9f00 r5:ee9d9f68
    [   12.929922]  r4:c1204c48
    [   12.932470] [<c02896c4>] (handle_irq_event_percpu) from [<c028978c>] (handle_irq_event+0x40/0x64)
    [   12.941380]  r6:c120a434 r5:ee9d9f68 r4:ee9d9f00
    [   12.946020] [<c028974c>] (handle_irq_event) from [<c028d4dc>] (handle_fasteoi_irq+0xc0/0x168)
    [   12.954583]  r7:00000001 r6:c120a434 r5:ee9d9f68 r4:ee9d9f00
    [   12.960270] [<c028d41c>] (handle_fasteoi_irq) from [<c02887e8>] (generic_handle_irq+0x2c/0x3c)
    [   12.968919]  r7:00000001 r6:00000000 r5:00000000 r4:c1068cfc
    [   12.974607] [<c02887bc>] (generic_handle_irq) from [<c0288e4c>] (__handle_domain_irq+0x64/0xbc)
    [   12.983347] [<c0288de8>] (__handle_domain_irq) from [<c0565458>] (gic_handle_irq+0x44/0x80)
    [   12.991736]  r9:eea14000 r8:fa213000 r7:eea15d88 r6:fa212000 r5:fa21200c r4:c1205104
    [   12.999515] [<c0565414>] (gic_handle_irq) from [<c02019f8>] (__irq_svc+0x58/0x8c)
    [   13.007029] Exception stack(0xeea15d88 to 0xeea15dd0)
    [   13.012105] 5d80:                   fa468000 edc8cc40 c0c97488 fa469000 eea92610 00000000
    [   13.020320] 5da0: eea92688 c1203d00 c0220a94 c1204c48 ffffe000 eea15de4 edc8cdd0 eea15dd8
    [   13.028534] 5dc0: c0c97488 c08b1d5c 20000113 ffffffff
    [   13.033609]  r9:eea14000 r8:c0220a94 r7:eea15dbc r6:ffffffff r5:20000113 r4:c08b1d5c
    [   13.041392] [<c08b1d08>] (davinci_mcasp_runtime_suspend) from [<c06cf210>] (pm_generic_runtime_suspend+0x34/0x40)
    [   13.051704] [<c06cf1dc>] (pm_generic_runtime_suspend) from [<c0220aa8>] (_od_runtime_suspend+0x14/0x28)
    [   13.061141] [<c0220a94>] (_od_runtime_suspend) from [<c06d1e2c>] (__rpm_callback+0x14c/0x1e0)
    [   13.069703]  r5:00000000 r4:eea92610
    [   13.073295] [<c06d1ce0>] (__rpm_callback) from [<c06d1ee8>] (rpm_callback+0x28/0x88)
    [   13.081075]  r10:ffffe000 r9:c1204c48 r8:00000008 r7:c1203d00 r6:c0220a94 r5:00000000
    [   13.088936]  r4:eea92610
    [   13.091483] [<c06d1ec0>] (rpm_callback) from [<c06d0f40>] (rpm_suspend+0x148/0x518)
    [   13.099172]  r7:c1203d00 r6:c0220a94 r5:00000000 r4:eea92610
    [   13.104858] [<c06d0df8>] (rpm_suspend) from [<c06d149c>] (rpm_idle+0xc8/0x148)
    [   13.112113]  r10:00000000 r9:eea926c8 r8:eea926d4 r7:00000000 r6:00000002 r5:00000000
    [   13.119976]  r4:eea92610
    [   13.122521] [<c06d13d4>] (rpm_idle) from [<c06d26a8>] (pm_runtime_work+0x94/0x98)
    [   13.130037]  r9:eea926c8 r8:00000000 r7:eed5e200 r6:eed59d80 r5:eea92688 r4:eea926c4
    [   13.137815] [<c06d2614>] (pm_runtime_work) from [<c02464d0>] (process_one_work+0x1f4/0x404)
    [   13.146202]  r5:ee9d3180 r4:eea926c4
    [   13.149795] [<c02462dc>] (process_one_work) from [<c02472a4>] (worker_thread+0x58/0x568)
    [   13.157922]  r10:eed59d80 r9:c1203d00 r8:eed59d98 r7:00000008 r6:eed59d80 r5:ee9d3194
    [   13.165784]  r4:ee9d3180
    [   13.168331] [<c024724c>] (worker_thread) from [<c024c7b4>] (kthread+0x160/0x168)
    [   13.175763]  r10:ee8ade74 r9:c024724c r8:ee9d3180 r7:eea14000 r6:00000000 r5:ee9d2600
    [   13.183626]  r4:ee9e4080
    [   13.186173] [<c024c654>] (kthread) from [<c02010d8>] (ret_from_fork+0x14/0x3c)
    [   13.193426] Exception stack(0xeea15fb0 to 0xeea15ff8)
    [   13.198500] 5fa0:                                     00000000 00000000 00000000 00000000
    [   13.206714] 5fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [   13.214927] 5fe0: 00000000 00000000 00000000 00000000 00000013 00000000
    [   13.221572]  r10:00000000 r9:00000000 r8:00000000 r7:00000000 r6:00000000 r5:c024c654
    [   13.229435]  r4:ee9d2600
    [   13.231977] ---[ end trace 200ff3becaf4cb37 ]---
    [   13.236669] ------------[ cut here ]------------
    [   13.241313] WARNING: CPU: 0 PID: 23 at drivers/bus/omap_l3_noc.c:147 l3_interrupt_handler+0x330/0x380
    [   13.250573] 44000000.ocp:L3 Custom Error: MASTER MPU TARGET L4_PER2_P3 (Read): Data Access in User mode during Functional access
    [   13.262186] Modules linked in:
    [   13.265257] CPU: 0 PID: 23 Comm: kworker/0:1 Tainted: G        W         4.19.94-gbe5389fd85 #1
    [   13.273990] Hardware name: Generic DRA74X (Flattened Device Tree)
    [   13.280112] Workqueue: pm pm_runtime_work
    [   13.284139] Backtrace:
    [   13.286601] [<c020ca34>] (dump_backtrace) from [<c020cd6c>] (show_stack+0x18/0x1c)
    [   13.294205]  r7:c0dfdec4 r6:60000193 r5:00000000 r4:c12506dc
    [   13.299892] [<c020cd54>] (show_stack) from [<c0a15124>] (dump_stack+0x9c/0xb0)
    [   13.307150] [<c0a15088>] (dump_stack) from [<c022e100>] (__warn+0xdc/0xf8)
    [   13.314055]  r7:c0dfdec4 r6:00000009 r5:00000000 r4:eea15b94
    [   13.319742] [<c022e024>] (__warn) from [<c022dd38>] (warn_slowpath_fmt+0x50/0x6c)
    [   13.327259]  r9:ee9d39c0 r8:f0882564 r7:c0dfddf0 r6:c0dfdd30 r5:c0dfde94 r4:c1204c48
    [   13.335039] [<c022dcec>] (warn_slowpath_fmt) from [<c056711c>] (l3_interrupt_handler+0x330/0x380)
    [   13.343949]  r3:ee9d7f00 r2:c0dfde94
    [   13.347537]  r5:00000002 r4:80080003
    [   13.351132] [<c0566dec>] (l3_interrupt_handler) from [<c02895ec>] (__handle_irq_event_percpu+0x68/0x140)
    [   13.360656]  r10:c12522f8 r9:ee9d9f00 r8:00000017 r7:eea15cc0 r6:00000000 r5:ee9d9f68
    [   13.368519]  r4:eea183c0
    [   13.371068] [<c0289584>] (__handle_irq_event_percpu) from [<c02896f8>] (handle_irq_event_percpu+0x34/0x88)
    [   13.380766]  r10:ffffe000 r9:eea14000 r8:ee80c000 r7:00000001 r6:ee9d9f00 r5:ee9d9f68
    [   13.388628]  r4:c1204c48
    [   13.391177] [<c02896c4>] (handle_irq_event_percpu) from [<c028978c>] (handle_irq_event+0x40/0x64)
    [   13.400088]  r6:c120a434 r5:ee9d9f68 r4:ee9d9f00
    [   13.404729] [<c028974c>] (handle_irq_event) from [<c028d4dc>] (handle_fasteoi_irq+0xc0/0x168)
    [   13.413292]  r7:00000001 r6:c120a434 r5:ee9d9f68 r4:ee9d9f00
    [   13.418978] [<c028d41c>] (handle_fasteoi_irq) from [<c02887e8>] (generic_handle_irq+0x2c/0x3c)
    [   13.427627]  r7:00000001 r6:00000000 r5:00000000 r4:c1068cfc
    [   13.433314] [<c02887bc>] (generic_handle_irq) from [<c0288e4c>] (__handle_domain_irq+0x64/0xbc)
    [   13.442054] [<c0288de8>] (__handle_domain_irq) from [<c0565458>] (gic_handle_irq+0x44/0x80)
    [   13.450443]  r9:eea14000 r8:fa213000 r7:eea15d88 r6:fa212000 r5:fa21200c r4:c1205104
    [   13.458223] [<c0565414>] (gic_handle_irq) from [<c02019f8>] (__irq_svc+0x58/0x8c)
    [   13.465737] Exception stack(0xeea15d88 to 0xeea15dd0)
    [   13.470813] 5d80:                   fa468000 edc8cc40 c0c97488 fa469008 eea92610 00000000
    [   13.479028] 5da0: eea92688 c1203d00 c0220a94 c1204c48 ffffe000 eea15de4 edc8cdd0 eea15dd8
    [   13.487241] 5dc0: c0c97488 c08b1d7c 20000113 ffffffff
    [   13.492317]  r9:eea14000 r8:c0220a94 r7:eea15dbc r6:ffffffff r5:20000113 r4:c08b1d7c
    [   13.500100] [<c08b1d08>] (davinci_mcasp_runtime_suspend) from [<c06cf210>] (pm_generic_runtime_suspend+0x34/0x40)
    [   13.510411] [<c06cf1dc>] (pm_generic_runtime_suspend) from [<c0220aa8>] (_od_runtime_suspend+0x14/0x28)
    [   13.519848] [<c0220a94>] (_od_runtime_suspend) from [<c06d1e2c>] (__rpm_callback+0x14c/0x1e0)
    [   13.528409]  r5:00000000 r4:eea92610
    [   13.532001] [<c06d1ce0>] (__rpm_callback) from [<c06d1ee8>] (rpm_callback+0x28/0x88)
    [   13.539779]  r10:ffffe000 r9:c1204c48 r8:00000008 r7:c1203d00 r6:c0220a94 r5:00000000
    [   13.547642]  r4:eea92610
    [   13.550187] [<c06d1ec0>] (rpm_callback) from [<c06d0f40>] (rpm_suspend+0x148/0x518)
    [   13.557878]  r7:c1203d00 r6:c0220a94 r5:00000000 r4:eea92610
    [   13.563564] [<c06d0df8>] (rpm_suspend) from [<c06d149c>] (rpm_idle+0xc8/0x148)
    [   13.570820]  r10:00000000 r9:eea926c8 r8:eea926d4 r7:00000000 r6:00000002 r5:00000000
    [   13.578682]  r4:eea92610
    [   13.581228] [<c06d13d4>] (rpm_idle) from [<c06d26a8>] (pm_runtime_work+0x94/0x98)
    [   13.588746]  r9:eea926c8 r8:00000000 r7:eed5e200 r6:eed59d80 r5:eea92688 r4:eea926c4
    [   13.596525] [<c06d2614>] (pm_runtime_work) from [<c02464d0>] (process_one_work+0x1f4/0x404)
    [   13.604911]  r5:ee9d3180 r4:eea926c4
    [   13.608504] [<c02462dc>] (process_one_work) from [<c02472a4>] (worker_thread+0x58/0x568)
    [   13.616632]  r10:eed59d80 r9:c1203d00 r8:eed59d98 r7:00000008 r6:eed59d80 r5:ee9d3194
    [   13.624494]  r4:ee9d3180
    [   13.627041] [<c024724c>] (worker_thread) from [<c024c7b4>] (kthread+0x160/0x168)
    [   13.634471]  r10:ee8ade74 r9:c024724c r8:ee9d3180 r7:eea14000 r6:00000000 r5:ee9d2600
    [   13.642334]  r4:ee9e4080
    [   13.644881] [<c024c654>] (kthread) from [<c02010d8>] (ret_from_fork+0x14/0x3c)
    [   13.652134] Exception stack(0xeea15fb0 to 0xeea15ff8)
    [   13.657207] 5fa0:                                     00000000 00000000 00000000 00000000
    [   13.665421] 5fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [   13.673636] 5fe0: 00000000 00000000 00000000 00000000 00000013 00000000
    [   13.680281]  r10:00000000 r9:00000000 r8:00000000 r7:00000000 r6:00000000 r5:c024c654
    [   13.688143]  r4:ee9d2600
    [   13.690686] ---[ end trace 200ff3becaf4cb38 ]---
    [   13.695383] ------------[ cut here ]------------
    [   13.700026] WARNING: CPU: 0 PID: 23 at drivers/bus/omap_l3_noc.c:147 l3_interrupt_handler+0x330/0x380
    [   13.709286] 44000000.ocp:L3 Custom Error: MASTER MPU TARGET L4_PER2_P3 (Read): Data Access in User mode during Functional access
    [   13.720897] Modules linked in:
    [   13.723968] CPU: 0 PID: 23 Comm: kworker/0:1 Tainted: G        W         4.19.94-gbe5389fd85 #1
    [   13.732702] Hardware name: Generic DRA74X (Flattened Device Tree)
    [   13.738823] Workqueue: pm pm_runtime_work
    [   13.742851] Backtrace:
    [   13.745314] [<c020ca34>] (dump_backtrace) from [<c020cd6c>] (show_stack+0x18/0x1c)
    [   13.752917]  r7:c0dfdec4 r6:60000193 r5:00000000 r4:c12506dc
    [   13.758606] [<c020cd54>] (show_stack) from [<c0a15124>] (dump_stack+0x9c/0xb0)
    [   13.765864] [<c0a15088>] (dump_stack) from [<c022e100>] (__warn+0xdc/0xf8)
    [   13.772770]  r7:c0dfdec4 r6:00000009 r5:00000000 r4:eea15b94
    [   13.778457] [<c022e024>] (__warn) from [<c022dd38>] (warn_slowpath_fmt+0x50/0x6c)
    [   13.785974]  r9:ee9d39c0 r8:f0882564 r7:c0dfddf0 r6:c0dfdd30 r5:c0dfde94 r4:c1204c48
    [   13.793755] [<c022dcec>] (warn_slowpath_fmt) from [<c056711c>] (l3_interrupt_handler+0x330/0x380)
    [   13.802665]  r3:ee9d7f00 r2:c0dfde94
    [   13.806256]  r5:00000002 r4:80080003
    [   13.809851] [<c0566dec>] (l3_interrupt_handler) from [<c02895ec>] (__handle_irq_event_percpu+0x68/0x140)
    [   13.819375]  r10:c12522f8 r9:ee9d9f00 r8:00000017 r7:eea15cc0 r6:00000000 r5:ee9d9f68
    [   13.827238]  r4:eea183c0
    [   13.829787] [<c0289584>] (__handle_irq_event_percpu) from [<c02896f8>] (handle_irq_event_percpu+0x34/0x88)
    [   13.839484]  r10:ffffe000 r9:eea14000 r8:ee80c000 r7:00000001 r6:ee9d9f00 r5:ee9d9f68
    [   13.847346]  r4:c1204c48
    [   13.849895] [<c02896c4>] (handle_irq_event_percpu) from [<c028978c>] (handle_irq_event+0x40/0x64)
    [   13.858805]  r6:c120a434 r5:ee9d9f68 r4:ee9d9f00
    [   13.863446] [<c028974c>] (handle_irq_event) from [<c028d4dc>] (handle_fasteoi_irq+0xc0/0x168)
    [   13.872008]  r7:00000001 r6:c120a434 r5:ee9d9f68 r4:ee9d9f00
    [   13.877695] [<c028d41c>] (handle_fasteoi_irq) from [<c02887e8>] (generic_handle_irq+0x2c/0x3c)
    [   13.886344]  r7:00000001 r6:00000000 r5:00000000 r4:c1068cfc
    [   13.892031] [<c02887bc>] (generic_handle_irq) from [<c0288e4c>] (__handle_domain_irq+0x64/0xbc)
    [   13.900770] [<c0288de8>] (__handle_domain_irq) from [<c0565458>] (gic_handle_irq+0x44/0x80)
    [   13.909161]  r9:eea14000 r8:fa213000 r7:eea15d88 r6:fa212000 r5:fa21200c r4:c1205104
    [   13.916940] [<c0565414>] (gic_handle_irq) from [<c02019f8>] (__irq_svc+0x58/0x8c)
    [   13.924454] Exception stack(0xeea15d88 to 0xeea15dd0)
    [   13.929530] 5d80:                   fa468000 edc8cc40 fa468180 00000000 eea92610 00000000
    [   13.937745] 5da0: eea92688 c1203d00 c0220a94 c1204c48 ffffe000 eea15de4 00000000 eea15dd8
    [   13.945957] 5dc0: c0c97488 c08b1da8 20000113 ffffffff
    [   13.951033]  r9:eea14000 r8:c0220a94 r7:eea15dbc r6:ffffffff r5:20000113 r4:c08b1da8
    [   13.958815] [<c08b1d08>] (davinci_mcasp_runtime_suspend) from [<c06cf210>] (pm_generic_runtime_suspend+0x34/0x40)
    [   13.969127] [<c06cf1dc>] (pm_generic_runtime_suspend) from [<c0220aa8>] (_od_runtime_suspend+0x14/0x28)
    [   13.978563] [<c0220a94>] (_od_runtime_suspend) from [<c06d1e2c>] (__rpm_callback+0x14c/0x1e0)
    [   13.987124]  r5:00000000 r4:eea92610
    [   13.990716] [<c06d1ce0>] (__rpm_callback) from [<c06d1ee8>] (rpm_callback+0x28/0x88)
    [   13.998496]  r10:ffffe000 r9:c1204c48 r8:00000008 r7:c1203d00 r6:c0220a94 r5:00000000
    [   14.006359]  r4:eea92610
    [   14.008906] [<c06d1ec0>] (rpm_callback) from [<c06d0f40>] (rpm_suspend+0x148/0x518)
    [   14.016596]  r7:c1203d00 r6:c0220a94 r5:00000000 r4:eea92610
    [   14.022281] [<c06d0df8>] (rpm_suspend) from [<c06d149c>] (rpm_idle+0xc8/0x148)
    [   14.029536]  r10:00000000 r9:eea926c8 r8:eea926d4 r7:00000000 r6:00000002 r5:00000000
    [   14.037399]  r4:eea92610
    [   14.039946] [<c06d13d4>] (rpm_idle) from [<c06d26a8>] (pm_runtime_work+0x94/0x98)
    [   14.047463]  r9:eea926c8 r8:00000000 r7:eed5e200 r6:eed59d80 r5:eea92688 r4:eea926c4
    [   14.055242] [<c06d2614>] (pm_runtime_work) from [<c02464d0>] (process_one_work+0x1f4/0x404)
    [   14.063628]  r5:ee9d3180 r4:eea926c4
    [   14.067220] [<c02462dc>] (process_one_work) from [<c02472a4>] (worker_thread+0x58/0x568)
    [   14.075349]  r10:eed59d80 r9:c1203d00 r8:eed59d98 r7:00000008 r6:eed59d80 r5:ee9d3194
    [   14.083211]  r4:ee9d3180
    [   14.085759] [<c024724c>] (worker_thread) from [<c024c7b4>] (kthread+0x160/0x168)
    [   14.093189]  r10:ee8ade74 r9:c024724c r8:ee9d3180 r7:eea14000 r6:00000000 r5:ee9d2600
    [   14.101051]  r4:ee9e4080
    [   14.103599] [<c024c654>] (kthread) from [<c02010d8>] (ret_from_fork+0x14/0x3c)
    [   14.110852] Exception stack(0xeea15fb0 to 0xeea15ff8)
    [   14.115926] 5fa0:                                     00000000 00000000 00000000 00000000
    [   14.124141] 5fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [   14.132355] 5fe0: 00000000 00000000 00000000 00000000 00000013 00000000
    [   14.138999]  r10:00000000 r9:00000000 r8:00000000 r7:00000000 r6:00000000 r5:c024c654
    [   14.146861]  r4:ee9d2600
    [   14.149405] ---[ end trace 200ff3becaf4cb39 ]---
    [   14.154098] ------------[ cut here ]------------
    [   14.158741] WARNING: CPU: 0 PID: 23 at drivers/bus/omap_l3_noc.c:147 l3_interrupt_handler+0x330/0x380
    [   14.168001] 44000000.ocp:L3 Custom Error: MASTER MPU TARGET L4_PER2_P3 (Read): Data Access in User mode during Functional access
    [   14.179613] Modules linked in:
    [   14.182684] CPU: 0 PID: 23 Comm: kworker/0:1 Tainted: G        W         4.19.94-gbe5389fd85 #1
    [   14.191418] Hardware name: Generic DRA74X (Flattened Device Tree)
    [   14.197540] Workqueue: pm pm_runtime_work
    [   14.201565] Backtrace:
    [   14.204027] [<c020ca34>] (dump_backtrace) from [<c020cd6c>] (show_stack+0x18/0x1c)
    [   14.211631]  r7:c0dfdec4 r6:60000193 r5:00000000 r4:c12506dc
    [   14.217319] [<c020cd54>] (show_stack) from [<c0a15124>] (dump_stack+0x9c/0xb0)
    [   14.224577] [<c0a15088>] (dump_stack) from [<c022e100>] (__warn+0xdc/0xf8)
    [   14.231483]  r7:c0dfdec4 r6:00000009 r5:00000000 r4:eea15b94
    [   14.237169] [<c022e024>] (__warn) from [<c022dd38>] (warn_slowpath_fmt+0x50/0x6c)
    [   14.244686]  r9:ee9d39c0 r8:f0882564 r7:c0dfddf0 r6:c0dfdd30 r5:c0dfde94 r4:c1204c48
    [   14.252468] [<c022dcec>] (warn_slowpath_fmt) from [<c056711c>] (l3_interrupt_handler+0x330/0x380)
    [   14.261379]  r3:ee9d7f00 r2:c0dfde94
    [   14.264968]  r5:00000002 r4:80080003
    [   14.268564] [<c0566dec>] (l3_interrupt_handler) from [<c02895ec>] (__handle_irq_event_percpu+0x68/0x140)
    [   14.278088]  r10:c12522f8 r9:ee9d9f00 r8:00000017 r7:eea15cc0 r6:00000000 r5:ee9d9f68
    [   14.285951]  r4:eea183c0
    [   14.288499] [<c0289584>] (__handle_irq_event_percpu) from [<c02896f8>] (handle_irq_event_percpu+0x34/0x88)
    [   14.298198]  r10:ffffe000 r9:eea14000 r8:ee80c000 r7:00000001 r6:ee9d9f00 r5:ee9d9f68
    [   14.306060]  r4:c1204c48
    [   14.308609] [<c02896c4>] (handle_irq_event_percpu) from [<c028978c>] (handle_irq_event+0x40/0x64)
    [   14.317519]  r6:c120a434 r5:ee9d9f68 r4:ee9d9f00
    [   14.322160] [<c028974c>] (handle_irq_event) from [<c028d4dc>] (handle_fasteoi_irq+0xc0/0x168)
    [   14.330723]  r7:00000001 r6:c120a434 r5:ee9d9f68 r4:ee9d9f00
    [   14.336410] [<c028d41c>] (handle_fasteoi_irq) from [<c02887e8>] (generic_handle_irq+0x2c/0x3c)
    [   14.345059]  r7:00000001 r6:00000000 r5:00000000 r4:c1068cfc
    [   14.350747] [<c02887bc>] (generic_handle_irq) from [<c0288e4c>] (__handle_domain_irq+0x64/0xbc)
    [   14.359487] [<c0288de8>] (__handle_domain_irq) from [<c0565458>] (gic_handle_irq+0x44/0x80)
    [   14.367877]  r9:eea14000 r8:fa213000 r7:eea15d88 r6:fa212000 r5:fa21200c r4:c1205104
    [   14.375657] [<c0565414>] (gic_handle_irq) from [<c02019f8>] (__irq_svc+0x58/0x8c)
    [   14.383171] Exception stack(0xeea15d88 to 0xeea15dd0)
    [   14.388247] 5d80:                   fa468000 edc8cc40 fa468184 00000004 eea92610 00000000
    [   14.396461] 5da0: eea92688 c1203d00 c0220a94 c1204c48 ffffe000 eea15de4 00000001 eea15dd8
    [   14.404674] 5dc0: c0c97488 c08b1da8 20000113 ffffffff
    [   14.409749]  r9:eea14000 r8:c0220a94 r7:eea15dbc r6:ffffffff r5:20000113 r4:c08b1da8
    [   14.417532] [<c08b1d08>] (davinci_mcasp_runtime_suspend) from [<c06cf210>] (pm_generic_runtime_suspend+0x34/0x40)
    [   14.427843] [<c06cf1dc>] (pm_generic_runtime_suspend) from [<c0220aa8>] (_od_runtime_suspend+0x14/0x28)
    [   14.437280] [<c0220a94>] (_od_runtime_suspend) from [<c06d1e2c>] (__rpm_callback+0x14c/0x1e0)
    [   14.445842]  r5:00000000 r4:eea92610
    [   14.449434] [<c06d1ce0>] (__rpm_callback) from [<c06d1ee8>] (rpm_callback+0x28/0x88)
    [   14.457214]  r10:ffffe000 r9:c1204c48 r8:00000008 r7:c1203d00 r6:c0220a94 r5:00000000
    [   14.465076]  r4:eea92610
    [   14.467622] [<c06d1ec0>] (rpm_callback) from [<c06d0f40>] (rpm_suspend+0x148/0x518)
    [   14.475312]  r7:c1203d00 r6:c0220a94 r5:00000000 r4:eea92610
    [   14.480997] [<c06d0df8>] (rpm_suspend) from [<c06d149c>] (rpm_idle+0xc8/0x148)
    [   14.488252]  r10:00000000 r9:eea926c8 r8:eea926d4 r7:00000000 r6:00000002 r5:00000000
    [   14.496115]  r4:eea92610
    [   14.498661] [<c06d13d4>] (rpm_idle) from [<c06d26a8>] (pm_runtime_work+0x94/0x98)
    [   14.506178]  r9:eea926c8 r8:00000000 r7:eed5e200 r6:eed59d80 r5:eea92688 r4:eea926c4
    [   14.513958] [<c06d2614>] (pm_runtime_work) from [<c02464d0>] (process_one_work+0x1f4/0x404)
    [   14.522344]  r5:ee9d3180 r4:eea926c4
    [   14.525938] [<c02462dc>] (process_one_work) from [<c02472a4>] (worker_thread+0x58/0x568)
    [   14.534065]  r10:eed59d80 r9:c1203d00 r8:eed59d98 r7:00000008 r6:eed59d80 r5:ee9d3194
    [   14.541926]  r4:ee9d3180
    [   14.544474] [<c024724c>] (worker_thread) from [<c024c7b4>] (kthread+0x160/0x168)
    [   14.551905]  r10:ee8ade74 r9:c024724c r8:ee9d3180 r7:eea14000 r6:00000000 r5:ee9d2600
    [   14.559766]  r4:ee9e4080
    [   14.562314] [<c024c654>] (kthread) from [<c02010d8>] (ret_from_fork+0x14/0x3c)
    [   14.569566] Exception stack(0xeea15fb0 to 0xeea15ff8)
    [   14.574640] 5fa0:                                     00000000 00000000 00000000 00000000
    [   14.582854] 5fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [   14.591067] 5fe0: 00000000 00000000 00000000 00000000 00000013 00000000
    [   14.597712]  r10:00000000 r9:00000000 r8:00000000 r7:00000000 r6:00000000 r5:c024c654
    [   14.605574]  r4:ee9d2600
    [   14.608118] ---[ end trace 200ff3becaf4cb3a ]---
    [   14.612818] ------------[ cut here ]------------
    [   14.617461] WARNING: CPU: 0 PID: 23 at drivers/bus/omap_l3_noc.c:147 l3_interrupt_handler+0x330/0x380
    [   14.626722] 44000000.ocp:L3 Custom Error: MASTER MPU TARGET L4_PER2_P3 (Read): Data Access in User mode during Functional access
    [   14.638333] Modules linked in:
    [   14.641404] CPU: 0 PID: 23 Comm: kworker/0:1 Tainted: G        W         4.19.94-gbe5389fd85 #1
    [   14.650139] Hardware name: Generic DRA74X (Flattened Device Tree)
    [   14.656260] Workqueue: pm pm_runtime_work
    [   14.660286] Backtrace:
    [   14.662748] [<c020ca34>] (dump_backtrace) from [<c020cd6c>] (show_stack+0x18/0x1c)
    [   14.670351]  r7:c0dfdec4 r6:60000193 r5:00000000 r4:c12506dc
    [   14.676039] [<c020cd54>] (show_stack) from [<c0a15124>] (dump_stack+0x9c/0xb0)
    [   14.683297] [<c0a15088>] (dump_stack) from [<c022e100>] (__warn+0xdc/0xf8)
    [   14.690201]  r7:c0dfdec4 r6:00000009 r5:00000000 r4:eea15b94
    [   14.695888] [<c022e024>] (__warn) from [<c022dd38>] (warn_slowpath_fmt+0x50/0x6c)
    [   14.703405]  r9:ee9d39c0 r8:f0882564 r7:c0dfddf0 r6:c0dfdd30 r5:c0dfde94 r4:c1204c48
    [   14.711186] [<c022dcec>] (warn_slowpath_fmt) from [<c056711c>] (l3_interrupt_handler+0x330/0x380)
    [   14.720096]  r3:ee9d7f00 r2:c0dfde94
    [   14.723686]  r5:00000002 r4:80080003
    [   14.727281] [<c0566dec>] (l3_interrupt_handler) from [<c02895ec>] (__handle_irq_event_percpu+0x68/0x140)
    [   14.736805]  r10:c12522f8 r9:ee9d9f00 r8:00000017 r7:eea15cc0 r6:00000000 r5:ee9d9f68
    [   14.744667]  r4:eea183c0
    [   14.747215] [<c0289584>] (__handle_irq_event_percpu) from [<c02896f8>] (handle_irq_event_percpu+0x34/0x88)
    [   14.756913]  r10:ffffe000 r9:eea14000 r8:ee80c000 r7:00000001 r6:ee9d9f00 r5:ee9d9f68
    [   14.764775]  r4:c1204c48
    [   14.767324] [<c02896c4>] (handle_irq_event_percpu) from [<c028978c>] (handle_irq_event+0x40/0x64)
    [   14.776234]  r6:c120a434 r5:ee9d9f68 r4:ee9d9f00
    [   14.780875] [<c028974c>] (handle_irq_event) from [<c028d4dc>] (handle_fasteoi_irq+0xc0/0x168)
    [   14.789437]  r7:00000001 r6:c120a434 r5:ee9d9f68 r4:ee9d9f00
    [   14.795124] [<c028d41c>] (handle_fasteoi_irq) from [<c02887e8>] (generic_handle_irq+0x2c/0x3c)
    [   14.803773]  r7:00000001 r6:00000000 r5:00000000 r4:c1068cfc
    [   14.809462] [<c02887bc>] (generic_handle_irq) from [<c0288e4c>] (__handle_domain_irq+0x64/0xbc)
    [   14.818203] [<c0288de8>] (__handle_domain_irq) from [<c0565458>] (gic_handle_irq+0x44/0x80)
    [   14.826592]  r9:eea14000 r8:fa213000 r7:eea15d88 r6:fa212000 r5:fa21200c r4:c1205104
    [   14.834373] [<c0565414>] (gic_handle_irq) from [<c02019f8>] (__irq_svc+0x58/0x8c)
    [   14.841888] Exception stack(0xeea15d88 to 0xeea15dd0)
    [   14.846962] 5d80:                   fa468000 edc8cc40 fa468188 00000008 eea92610 00000000
    [   14.855177] 5da0: eea92688 c1203d00 c0220a94 c1204c48 ffffe000 eea15de4 00000002 eea15dd8
    [   14.863390] 5dc0: c0c97488 c08b1da8 20000113 ffffffff
    [   14.868465]  r9:eea14000 r8:c0220a94 r7:eea15dbc r6:ffffffff r5:20000113 r4:c08b1da8
    [   14.876247] [<c08b1d08>] (davinci_mcasp_runtime_suspend) from [<c06cf210>] (pm_generic_runtime_suspend+0x34/0x40)
    [   14.886558] [<c06cf1dc>] (pm_generic_runtime_suspend) from [<c0220aa8>] (_od_runtime_suspend+0x14/0x28)
    [   14.895994] [<c0220a94>] (_od_runtime_suspend) from [<c06d1e2c>] (__rpm_callback+0x14c/0x1e0)
    [   14.904556]  r5:00000000 r4:eea92610
    [   14.908148] [<c06d1ce0>] (__rpm_callback) from [<c06d1ee8>] (rpm_callback+0x28/0x88)
    [   14.915927]  r10:ffffe000 r9:c1204c48 r8:00000008 r7:c1203d00 r6:c0220a94 r5:00000000
    [   14.923789]  r4:eea92610
    [   14.926335] [<c06d1ec0>] (rpm_callback) from [<c06d0f40>] (rpm_suspend+0x148/0x518)
    [   14.934025]  r7:c1203d00 r6:c0220a94 r5:00000000 r4:eea92610
    [   14.939711] [<c06d0df8>] (rpm_suspend) from [<c06d149c>] (rpm_idle+0xc8/0x148)
    [   14.946967]  r10:00000000 r9:eea926c8 r8:eea926d4 r7:00000000 r6:00000002 r5:00000000
    [   14.954830]  r4:eea92610
    [   14.957375] [<c06d13d4>] (rpm_idle) from [<c06d26a8>] (pm_runtime_work+0x94/0x98)
    [   14.964892]  r9:eea926c8 r8:00000000 r7:eed5e200 r6:eed59d80 r5:eea92688 r4:eea926c4
    [   14.972672] [<c06d2614>] (pm_runtime_work) from [<c02464d0>] (process_one_work+0x1f4/0x404)
    [   14.981059]  r5:ee9d3180 r4:eea926c4
    [   14.984651] [<c02462dc>] (process_one_work) from [<c02472a4>] (worker_thread+0x58/0x568)
    [   14.992779]  r10:eed59d80 r9:c1203d00 r8:eed59d98 r7:00000008 r6:eed59d80 r5:ee9d3194
    [   15.000641]  r4:ee9d3180
    [   15.003187] [<c024724c>] (worker_thread) from [<c024c7b4>] (kthread+0x160/0x168)
    [   15.010618]  r10:ee8ade74 r9:c024724c r8:ee9d3180 r7:eea14000 r6:00000000 r5:ee9d2600
    [   15.018480]  r4:ee9e4080
    [   15.021027] [<c024c654>] (kthread) from [<c02010d8>] (ret_from_fork+0x14/0x3c)
    [   15.028280] Exception stack(0xeea15fb0 to 0xeea15ff8)
    [   15.033353] 5fa0:                                     00000000 00000000 00000000 00000000
    [   15.041569] 5fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [   15.049783] 5fe0: 00000000 00000000 00000000 00000000 00000013 00000000
    [   15.056428]  r10:00000000 r9:00000000 r8:00000000 r7:00000000 r6:00000000 r5:c024c654
    [   15.064291]  r4:ee9d2600
    [   15.066834] ---[ end trace 200ff3becaf4cb3b ]---
    [   15.071522] ------------[ cut here ]------------
    [   15.076166] WARNING: CPU: 0 PID: 23 at drivers/bus/omap_l3_noc.c:147 l3_interrupt_handler+0x330/0x380
    [   15.085425] 44000000.ocp:L3 Custom Error: MASTER MPU TARGET L4_PER2_P3 (Read): Data Access in User mode during Functional access
    [   15.097037] Modules linked in:
    [   15.100106] CPU: 0 PID: 23 Comm: kworker/0:1 Tainted: G        W         4.19.94-gbe5389fd85 #1
    [   15.108841] Hardware name: Generic DRA74X (Flattened Device Tree)
    [   15.114963] Workqueue: pm pm_runtime_work
    [   15.118989] Backtrace:
    [   15.121451] [<c020ca34>] (dump_backtrace) from [<c020cd6c>] (show_stack+0x18/0x1c)
    [   15.129054]  r7:c0dfdec4 r6:60000193 r5:00000000 r4:c12506dc
    [   15.134742] [<c020cd54>] (show_stack) from [<c0a15124>] (dump_stack+0x9c/0xb0)
    [   15.142000] [<c0a15088>] (dump_stack) from [<c022e100>] (__warn+0xdc/0xf8)
    [   15.148906]  r7:c0dfdec4 r6:00000009 r5:00000000 r4:eea15b94
    [   15.154593] [<c022e024>] (__warn) from [<c022dd38>] (warn_slowpath_fmt+0x50/0x6c)
    [   15.162110]  r9:ee9d39c0 r8:f0882564 r7:c0dfddf0 r6:c0dfdd30 r5:c0dfde94 r4:c1204c48
    [   15.169890] [<c022dcec>] (warn_slowpath_fmt) from [<c056711c>] (l3_interrupt_handler+0x330/0x380)
    [   15.178800]  r3:ee9d7f00 r2:c0dfde94
    [   15.182391]  r5:00000002 r4:80080003
    [   15.185987] [<c0566dec>] (l3_interrupt_handler) from [<c02895ec>] (__handle_irq_event_percpu+0x68/0x140)
    [   15.195511]  r10:c12522f8 r9:ee9d9f00 r8:00000017 r7:eea15cc0 r6:00000000 r5:ee9d9f68
    [   15.203373]  r4:eea183c0
    [   15.205923] [<c0289584>] (__handle_irq_event_percpu) from [<c02896f8>] (handle_irq_event_percpu+0x34/0x88)
    [   15.215621]  r10:ffffe000 r9:eea14000 r8:ee80c000 r7:00000001 r6:ee9d9f00 r5:ee9d9f68
    [   15.223483]  r4:c1204c48
    [   15.226032] [<c02896c4>] (handle_irq_event_percpu) from [<c028978c>] (handle_irq_event+0x40/0x64)
    [   15.234943]  r6:c120a434 r5:ee9d9f68 r4:ee9d9f00
    [   15.239584] [<c028974c>] (handle_irq_event) from [<c028d4dc>] (handle_fasteoi_irq+0xc0/0x168)
    [   15.248146]  r7:00000001 r6:c120a434 r5:ee9d9f68 r4:ee9d9f00
    [   15.253833] [<c028d41c>] (handle_fasteoi_irq) from [<c02887e8>] (generic_handle_irq+0x2c/0x3c)
    [   15.262483]  r7:00000001 r6:00000000 r5:00000000 r4:c1068cfc
    [   15.268170] [<c02887bc>] (generic_handle_irq) from [<c0288e4c>] (__handle_domain_irq+0x64/0xbc)
    [   15.276911] [<c0288de8>] (__handle_domain_irq) from [<c0565458>] (gic_handle_irq+0x44/0x80)
    [   15.285300]  r9:eea14000 r8:fa213000 r7:eea15d88 r6:fa212000 r5:fa21200c r4:c1205104
    [   15.293080] [<c0565414>] (gic_handle_irq) from [<c02019f8>] (__irq_svc+0x58/0x8c)
    [   15.300595] Exception stack(0xeea15d88 to 0xeea15dd0)
    [   15.305669] 5d80:                   fa468000 edc8cc40 fa46818c 0000000c eea92610 00000000
    [   15.313884] 5da0: eea92688 c1203d00 c0220a94 c1204c48 ffffe000 eea15de4 00000003 eea15dd8
    [   15.322097] 5dc0: c0c97488 c08b1da8 20000113 ffffffff
    [   15.327173]  r9:eea14000 r8:c0220a94 r7:eea15dbc r6:ffffffff r5:20000113 r4:c08b1da8
    [   15.334955] [<c08b1d08>] (davinci_mcasp_runtime_suspend) from [<c06cf210>] (pm_generic_runtime_suspend+0x34/0x40)
    [   15.345266] [<c06cf1dc>] (pm_generic_runtime_suspend) from [<c0220aa8>] (_od_runtime_suspend+0x14/0x28)
    [   15.354702] [<c0220a94>] (_od_runtime_suspend) from [<c06d1e2c>] (__rpm_callback+0x14c/0x1e0)
    [   15.363263]  r5:00000000 r4:eea92610
    [   15.366855] [<c06d1ce0>] (__rpm_callback) from [<c06d1ee8>] (rpm_callback+0x28/0x88)
    [   15.374634]  r10:ffffe000 r9:c1204c48 r8:00000008 r7:c1203d00 r6:c0220a94 r5:00000000
    [   15.382497]  r4:eea92610
    [   15.385044] [<c06d1ec0>] (rpm_callback) from [<c06d0f40>] (rpm_suspend+0x148/0x518)
    [   15.392734]  r7:c1203d00 r6:c0220a94 r5:00000000 r4:eea92610
    [   15.398418] [<c06d0df8>] (rpm_suspend) from [<c06d149c>] (rpm_idle+0xc8/0x148)
    [   15.405674]  r10:00000000 r9:eea926c8 r8:eea926d4 r7:00000000 r6:00000002 r5:00000000
    [   15.413535]  r4:eea92610
    [   15.416081] [<c06d13d4>] (rpm_idle) from [<c06d26a8>] (pm_runtime_work+0x94/0x98)
    [   15.423598]  r9:eea926c8 r8:00000000 r7:eed5e200 r6:eed59d80 r5:eea92688 r4:eea926c4
    [   15.431376] [<c06d2614>] (pm_runtime_work) from [<c02464d0>] (process_one_work+0x1f4/0x404)
    [   15.439763]  r5:ee9d3180 r4:eea926c4
    [   15.443355] [<c02462dc>] (process_one_work) from [<c02472a4>] (worker_thread+0x58/0x568)
    [   15.451483]  r10:eed59d80 r9:c1203d00 r8:eed59d98 r7:00000008 r6:eed59d80 r5:ee9d3194
    [   15.459346]  r4:ee9d3180
    [   15.461894] [<c024724c>] (worker_thread) from [<c024c7b4>] (kthread+0x160/0x168)
    [   15.469324]  r10:ee8ade74 r9:c024724c r8:ee9d3180 r7:eea14000 r6:00000000 r5:ee9d2600
    [   15.477187]  r4:ee9e4080
    [   15.479734] [<c024c654>] (kthread) from [<c02010d8>] (ret_from_fork+0x14/0x3c)
    [   15.486988] Exception stack(0xeea15fb0 to 0xeea15ff8)
    [   15.492061] 5fa0:                                     00000000 00000000 00000000 00000000
    [   15.500275] 5fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [   15.508490] 5fe0: 00000000 00000000 00000000 00000000 00000013 00000000
    [   15.515135]  r10:00000000 r9:00000000 r8:00000000 r7:00000000 r6:00000000 r5:c024c654
    [   15.522998]  r4:ee9d2600
    [   15.525541] ---[ end trace 200ff3becaf4cb3c ]---
    [   15.530240] ------------[ cut here ]------------
    [   15.534885] WARNING: CPU: 0 PID: 23 at drivers/bus/omap_l3_noc.c:147 l3_interrupt_handler+0x330/0x380
    [   15.544145] 44000000.ocp:L3 Custom Error: MASTER MPU TARGET L4_PER2_P3 (Read): Data Access in User mode during Functional access
    [   15.555756] Modules linked in:
    [   15.558827] CPU: 0 PID: 23 Comm: kworker/0:1 Tainted: G        W         4.19.94-gbe5389fd85 #1
    [   15.567562] Hardware name: Generic DRA74X (Flattened Device Tree)
    [   15.573684] Workqueue: pm pm_runtime_work
    [   15.577710] Backtrace:
    [   15.580171] [<c020ca34>] (dump_backtrace) from [<c020cd6c>] (show_stack+0x18/0x1c)
    [   15.587775]  r7:c0dfdec4 r6:60000193 r5:00000000 r4:c12506dc
    [   15.593462] [<c020cd54>] (show_stack) from [<c0a15124>] (dump_stack+0x9c/0xb0)
    [   15.600720] [<c0a15088>] (dump_stack) from [<c022e100>] (__warn+0xdc/0xf8)
    [   15.607625]  r7:c0dfdec4 r6:00000009 r5:00000000 r4:eea15bb4
    [   15.613311] [<c022e024>] (__warn) from [<c022dd38>] (warn_slowpath_fmt+0x50/0x6c)
    [   15.620830]  r9:ee9d39c0 r8:f0882564 r7:c0dfddf0 r6:c0dfdd30 r5:c0dfde94 r4:c1204c48
    [   15.628609] [<c022dcec>] (warn_slowpath_fmt) from [<c056711c>] (l3_interrupt_handler+0x330/0x380)
    [   15.637520]  r3:ee9d7f00 r2:c0dfde94
    [   15.641109]  r5:00000002 r4:80080003
    [   15.644705] [<c0566dec>] (l3_interrupt_handler) from [<c02895ec>] (__handle_irq_event_percpu+0x68/0x140)
    [   15.654229]  r10:c12522f8 r9:ee9d9f00 r8:00000017 r7:eea15ce0 r6:00000000 r5:ee9d9f68
    [   15.662091]  r4:eea183c0
    [   15.664640] [<c0289584>] (__handle_irq_event_percpu) from [<c02896f8>] (handle_irq_event_percpu+0x34/0x88)
    [   15.674338]  r10:ffffe000 r9:eea14000 r8:ee80c000 r7:00000001 r6:ee9d9f00 r5:ee9d9f68
    [   15.682199]  r4:c1204c48
    [   15.684748] [<c02896c4>] (handle_irq_event_percpu) from [<c028978c>] (handle_irq_event+0x40/0x64)
    [   15.693658]  r6:c120a434 r5:ee9d9f68 r4:ee9d9f00
    [   15.698299] [<c028974c>] (handle_irq_event) from [<c028d4dc>] (handle_fasteoi_irq+0xc0/0x168)
    [   15.706861]  r7:00000001 r6:c120a434 r5:ee9d9f68 r4:ee9d9f00
    [   15.712548] [<c028d41c>] (handle_fasteoi_irq) from [<c02887e8>] (generic_handle_irq+0x2c/0x3c)
    [   15.721199]  r7:00000001 r6:00000000 r5:00000000 r4:c1068cfc
    [   15.726886] [<c02887bc>] (generic_handle_irq) from [<c0288e4c>] (__handle_domain_irq+0x64/0xbc)
    [   15.735625] [<c0288de8>] (__handle_domain_irq) from [<c0565458>] (gic_handle_irq+0x44/0x80)
    [   15.744014]  r9:eea14000 r8:fa213000 r7:eea15da8 r6:fa212000 r5:fa21200c r4:c1205104
    [   15.751793] [<c0565414>] (gic_handle_irq) from [<c02019f8>] (__irq_svc+0x58/0x8c)
    [   15.759308] Exception stack(0xeea15da8 to 0xeea15df0)
    [   15.764383] 5da0:                   00000000 edc8cc40 00000004 00000010 eea92610 00000000
    [   15.772598] 5dc0: eea92688 c1203d00 c0220a94 c1204c48 ffffe000 eea15e0c 00000004 eea15df8
    [   15.780812] 5de0: c0c97488 c0220aa8 60000113 ffffffff
    [   15.785886]  r9:eea14000 r8:c0220a94 r7:eea15ddc r6:ffffffff r5:60000113 r4:c0220aa8
    [   15.793668] [<c0220a94>] (_od_runtime_suspend) from [<c06d1e2c>] (__rpm_callback+0x14c/0x1e0)
    [   15.802229]  r5:00000000 r4:eea92610
    [   15.805821] [<c06d1ce0>] (__rpm_callback) from [<c06d1ee8>] (rpm_callback+0x28/0x88)
    [   15.813600]  r10:ffffe000 r9:c1204c48 r8:00000008 r7:c1203d00 r6:c0220a94 r5:00000000
    [   15.821461]  r4:eea92610
    [   15.824006] [<c06d1ec0>] (rpm_callback) from [<c06d0f40>] (rpm_suspend+0x148/0x518)
    [   15.831697]  r7:c1203d00 r6:c0220a94 r5:00000000 r4:eea92610
    [   15.837382] [<c06d0df8>] (rpm_suspend) from [<c06d149c>] (rpm_idle+0xc8/0x148)
    [   15.844637]  r10:00000000 r9:eea926c8 r8:eea926d4 r7:00000000 r6:00000002 r5:00000000
    [   15.852499]  r4:eea92610
    [   15.855044] [<c06d13d4>] (rpm_idle) from [<c06d26a8>] (pm_runtime_work+0x94/0x98)
    [   15.862562]  r9:eea926c8 r8:00000000 r7:eed5e200 r6:eed59d80 r5:eea92688 r4:eea926c4
    [   15.870340] [<c06d2614>] (pm_runtime_work) from [<c02464d0>] (process_one_work+0x1f4/0x404)
    [   15.878726]  r5:ee9d3180 r4:eea926c4
    [   15.882320] [<c02462dc>] (process_one_work) from [<c02472a4>] (worker_thread+0x58/0x568)
    [   15.890448]  r10:eed59d80 r9:c1203d00 r8:eed59d98 r7:00000008 r6:eed59d80 r5:ee9d3194
    [   15.898310]  r4:ee9d3180
    [   15.900856] [<c024724c>] (worker_thread) from [<c024c7b4>] (kthread+0x160/0x168)
    [   15.908286]  r10:ee8ade74 r9:c024724c r8:ee9d3180 r7:eea14000 r6:00000000 r5:ee9d2600
    [   15.916149]  r4:ee9e4080
    [   15.918696] [<c024c654>] (kthread) from [<c02010d8>] (ret_from_fork+0x14/0x3c)
    [   15.925949] Exception stack(0xeea15fb0 to 0xeea15ff8)
    [   15.931022] 5fa0:                                     00000000 00000000 00000000 00000000
    [   15.939238] 5fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [   15.947452] 5fe0: 00000000 00000000 00000000 00000000 00000013 00000000
    [   15.954098]  r10:00000000 r9:00000000 r8:00000000 r7:00000000 r6:00000000 r5:c024c654
    [   15.961960]  r4:ee9d2600
    [   15.964502] ---[ end trace 200ff3becaf4cb3d ]---
    [   15.969200] ------------[ cut here ]------------
    [   15.973849] WARNING: CPU: 0 PID: 23 at drivers/clk/clk.c:828 clk_core_disable+0xa4/0xa8
    [   15.981886] l4per_cm:clk:0168:0 already disabled
    [   15.986521] Modules linked in:
    [   15.989591] CPU: 0 PID: 23 Comm: kworker/0:1 Tainted: G        W         4.19.94-gbe5389fd85 #1
    [   15.998326] Hardware name: Generic DRA74X (Flattened Device Tree)
    [   16.004448] Workqueue: pm pm_runtime_work
    [   16.008474] Backtrace:
    [   16.010937] [<c020ca34>] (dump_backtrace) from [<c020cd6c>] (show_stack+0x18/0x1c)
    [   16.018542]  r7:c0e0a1a8 r6:60000193 r5:00000000 r4:c12506dc
    [   16.024230] [<c020cd54>] (show_stack) from [<c0a15124>] (dump_stack+0x9c/0xb0)
    [   16.031487] [<c0a15088>] (dump_stack) from [<c022e100>] (__warn+0xdc/0xf8)
    [   16.038393]  r7:c0e0a1a8 r6:00000009 r5:00000000 r4:eea15cfc
    [   16.044078] [<c022e024>] (__warn) from [<c022dd38>] (warn_slowpath_fmt+0x50/0x6c)
    [   16.051595]  r9:eea15d88 r8:00000000 r7:00000020 r6:c1210b2c r5:c0e0a258 r4:c1204c48
    [   16.059377] [<c022dcec>] (warn_slowpath_fmt) from [<c05d181c>] (clk_core_disable+0xa4/0xa8)
    [   16.067763]  r3:ee83b780 r2:c0e0a258
    [   16.071352]  r5:ee839a80 r4:ee839a80
    [   16.074949] [<c05d1778>] (clk_core_disable) from [<c05d1840>] (clk_core_disable_lock+0x20/0x2c)
    [   16.083685]  r5:ee839a80 r4:80000193
    [   16.087280] [<c05d1820>] (clk_core_disable_lock) from [<c05d1870>] (clk_disable+0x24/0x28)
    [   16.095580]  r5:c125446c r4:c1210b2c
    [   16.099175] [<c05d184c>] (clk_disable) from [<c021d66c>] (_disable_clocks+0x20/0x98)
    [   16.106955] [<c021d64c>] (_disable_clocks) from [<c021e254>] (_idle+0x188/0x248)
    [   16.114383]  r7:00000020 r6:c1204c48 r5:c125446c r4:c1210b2c
    [   16.120071] [<c021e0cc>] (_idle) from [<c021ff08>] (omap_hwmod_idle+0x2c/0x4c)
    [   16.127326]  r9:c1204c48 r8:c0220a94 r7:c1203d00 r6:a0000113 r5:c1210b78 r4:c1210b2c
    [   16.135107] [<c021fedc>] (omap_hwmod_idle) from [<c0220a40>] (omap_device_idle+0x48/0x9c)
    [   16.143321]  r7:c1203d00 r6:00000001 r5:eea79f00 r4:00000000
    [   16.149009] [<c02209f8>] (omap_device_idle) from [<c0220ab8>] (_od_runtime_suspend+0x24/0x28)
    [   16.157572]  r7:c1203d00 r6:eea92688 r5:00000000 r4:eea92610
    [   16.163259] [<c0220a94>] (_od_runtime_suspend) from [<c06d1e2c>] (__rpm_callback+0x14c/0x1e0)
    [   16.171820]  r5:00000000 r4:eea92610
    [   16.175412] [<c06d1ce0>] (__rpm_callback) from [<c06d1ee8>] (rpm_callback+0x28/0x88)
    [   16.183191]  r10:ffffe000 r9:c1204c48 r8:00000008 r7:c1203d00 r6:c0220a94 r5:00000000
    [   16.191054]  r4:eea92610
    [   16.193599] [<c06d1ec0>] (rpm_callback) from [<c06d0f40>] (rpm_suspend+0x148/0x518)
    [   16.201289]  r7:c1203d00 r6:c0220a94 r5:00000000 r4:eea92610
    [   16.206976] [<c06d0df8>] (rpm_suspend) from [<c06d149c>] (rpm_idle+0xc8/0x148)
    [   16.214231]  r10:00000000 r9:eea926c8 r8:eea926d4 r7:00000000 r6:00000002 r5:00000000
    [   16.222093]  r4:eea92610
    [   16.224638] [<c06d13d4>] (rpm_idle) from [<c06d26a8>] (pm_runtime_work+0x94/0x98)
    [   16.232155]  r9:eea926c8 r8:00000000 r7:eed5e200 r6:eed59d80 r5:eea92688 r4:eea926c4
    [   16.239934] [<c06d2614>] (pm_runtime_work) from [<c02464d0>] (process_one_work+0x1f4/0x404)
    [   16.248321]  r5:ee9d3180 r4:eea926c4
    [   16.251914] [<c02462dc>] (process_one_work) from [<c02472a4>] (worker_thread+0x58/0x568)
    [   16.260041]  r10:eed59d80 r9:c1203d00 r8:eed59d98 r7:00000008 r6:eed59d80 r5:ee9d3194
    [   16.267904]  r4:ee9d3180
    [   16.270451] [<c024724c>] (worker_thread) from [<c024c7b4>] (kthread+0x160/0x168)
    [   16.277881]  r10:ee8ade74 r9:c024724c r8:ee9d3180 r7:eea14000 r6:00000000 r5:ee9d2600
    [   16.285743]  r4:ee9e4080
    [   16.288290] [<c024c654>] (kthread) from [<c02010d8>] (ret_from_fork+0x14/0x3c)
    [   16.295543] Exception stack(0xeea15fb0 to 0xeea15ff8)
    [   16.300616] 5fa0:                                     00000000 00000000 00000000 00000000
    [   16.308830] 5fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [   16.317045] 5fe0: 00000000 00000000 00000000 00000000 00000013 00000000
    [   16.323690]  r10:00000000 r9:00000000 r8:00000000 r7:00000000 r6:00000000 r5:c024c654
    [   16.331551]  r4:ee9d2600
    [   16.334093] ---[ end trace 200ff3becaf4cb3e ]---
    [   16.339023] dmm 4e000000.dmm: workaround for errata i878 in use
    [   16.346969] dmm 4e000000.dmm: initialized all PAT entries
    [   16.355292] omap_gpio 4805d000.gpio: Could not set line 27 debounce to 200000 microseconds (-22)
    [   16.364169] sdhci-omap 4809c000.mmc: Got CD GPIO
    [   16.369149] sdhci-omap 4809c000.mmc: Linked as a consumer to regulator.12
    [   16.376053] sdhci-omap 4809c000.mmc: 4809c000.mmc supply vqmmc not found, using dummy regulator
    [   16.384895] sdhci-omap 4809c000.mmc: Linked as a consumer to regulator.0
    [   16.391726] sdhci-omap 4809c000.mmc: Dropping the link to regulator.0
    [   16.398392] sdhci-omap 4809c000.mmc: Dropping the link to regulator.12
    [   16.406001] sdhci-omap 480b4000.mmc: failed to set system capabilities
    [   16.413994] omap_gpio 4805d000.gpio: Could not set line 27 debounce to 200000 microseconds (-22)
    [   16.422862] sdhci-omap 4809c000.mmc: Got CD GPIO
    [   16.427748] sdhci-omap 4809c000.mmc: Linked as a consumer to regulator.12
    [   16.434670] sdhci-omap 4809c000.mmc: 4809c000.mmc supply vqmmc not found, using dummy regulator
    [   16.443499] sdhci-omap 4809c000.mmc: Linked as a consumer to regulator.0
    [   16.450337] sdhci-omap 4809c000.mmc: Dropping the link to regulator.0
    [   16.456985] sdhci-omap 4809c000.mmc: Dropping the link to regulator.12
    [   16.464511] sdhci-omap 480b4000.mmc: failed to set system capabilities
    [   16.472298] hctosys: unable to open rtc device (rtc0)
    [   16.478339] ALSA device list:
    [   16.481343]   No soundcards found.
    [   16.485905] Waiting for root device PARTUUID=f402ab8b-02...
    [   46.561960] vdd_3v3: disabling
    [   46.565051] aic_dvdd_fixed: disabling
    [   46.568754] pbias_mmc_omap5: disabling
    For MMC, I see below error which indicates vqmmc-supply property has not been set in the kernel dts MMC nodes correctly.
    Error is reported for both SD card and eMMC.
    SD card is not enumerated, so rootfs is not mounted.
    I am focusing only on the mmc enumeration issue in this thread. There are a lot of l3_noc_error in the boot log, please track them separately.
    Vishal
