Compiler/TDA2PXEVM: mailbox problem
Part Number: TDA2PXEVM
Other Parts Discussed in Thread: PMP
I am using tda2p for linux in vsdk3.4.
Recently,i changed power management chip from TPS659039 to TPS65917.
After i changed the dts in uboot and linux kernel,uboot and linux kernel run well.
But when i running the apps.out,it shows that i can not attach to ipu2.
By reading the log,i think it is a mailbox problem.Please tell me how to solve the problem.
Here is the log:
U-Boot SPL 2016.05 (Aug 26 2020 - 19:24:04)
DRA762-GP ES1.0
no pinctrl for hs200_1_8v
no pinctrl for ddr_1_8v
*** Warning - MMC init failed, using default environment
i2c_write: error waiting for data ACK (status=0x116)
Trying to boot from MMC1
reading dra7-ipu2-fw.lzop
spl_load_file_fat: error reading file dra7-ipu2-fw.lzop, err - -1
spl: error reading image dra7-ipu2-fw.lzop, err - -1
Error loading remotecore IPU2!,Continuing with boot ...
reading dra7-dsp1-fw.lzop
spl_load_file_fat: error reading file dra7-dsp1-fw.lzop, err - -1
spl: error reading image dra7-dsp1-fw.lzop, err - -1
Error loading remotecore DSP1!,Continuing with boot ...
reading dra7-dsp2-fw.lzop
spl_load_file_fat: error reading file dra7-dsp2-fw.lzop, err - -1
spl: error reading image dra7-dsp2-fw.lzop, err - -1
Error loading remotecore DSP2!,Continuing with boot ...
reading dra7-ipu1-fw.lzop
spl_load_file_fat: error reading file dra7-ipu1-fw.lzop, err - -1
spl: error reading image dra7-ipu1-fw.lzop, err - -1
Error loading remotecore IPU1!,Continuing with boot ...
reading u-boot.img
reading u-boot.img
reading u-boot.img
reading u-boot.img
U-Boot 2016.05 (Aug 26 2020 - 19:24:04 +0800)
CPU : DRA762-GP ES1.0
Model: TI DRA762 EVM
Board: DRA74x EVM REV
DRAM: 2 GiB
MMC: mmc@4809c000: fail to find sdr104 mode FDT_ERR_NOTFOUND
no pinctrl for sdr104
mmc@4809c000: fail to find ddr50 mode FDT_ERR_NOTFOUND
no pinctrl for ddr50
mmc@4809c000: fail to find sdr50 mode FDT_ERR_NOTFOUND
no pinctrl for sdr50
mmc@4809c000: fail to find sdr25 mode FDT_ERR_NOTFOUND
no pinctrl for sdr25
mmc@4809c000: fail to find sdr12 mode FDT_ERR_NOTFOUND
no pinctrl for sdr12
OMAP SD/MMC: 0, OMAP SD/MMC: 1
Warning: fastboot.board_rev: unknown board revision
ERROR: invalid mmc device
at arch/arm/cpu/armv7/omap-common/utils.c:193/mmc_get_part_size()
Warning: fastboot.userdata_size: unable to calc
SCSI: SATA link 0 timeout.
AHCI 0001.0300 32 slots 1 ports 3 Gbps 0x1 impl SATA mode
flags: 64bit ncq stag pm led clo only pmp pio slum part ccc apst
scanning bus for devices...
Found 0 device(s).
Net: Could not get PHY for ethernet@48484000: addr 2
Warning: ethernet@48484000 using MAC address from ROM
eth0: ethernet@48484000
Hit any key to stop autoboot: 0
## Error: "board_findfdt" not defined
switch to partitions #0, OK
mmc0 is current device
SD/MMC found on device 0
reading boot.scr
** Unable to read file boot.scr **
reading uEnv.txt
166 bytes read in 2 ms (81.1 KiB/s)
Loaded env from uEnv.txt
Importing environment from mmc0 ...
3559024 bytes read in 180 ms (18.9 MiB/s)
106334 bytes read in 38 ms (2.7 MiB/s)
Booting from mmc0 ...
Kernel image @ 0x82000000 [ 0x000000 - 0x364e70 ]
Loading Device Tree to 8ffe3000, end 8fffff5d ... OK
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 4.4.84 (gcc version 5.3.1 20160113 (Linaro GCC 5.3-2016.02) ) #1 SMP PREEMPT Thu Aug 13 19:41:44 CST 2020
[ 0.000000] CPU: ARMv7 Processor [412fc0f2] revision 2 (ARMv7), cr=10c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
[ 0.000000] Machine model: TI DRA762 EVM
[ 0.000000] Reserved memory: created DMA memory pool at 0x40300000, size 3 MiB
[ 0.000000] Reserved memory: initialized node cmem@40300000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: regions without no-map are not yet supported
[ 0.000000] Reserved memory: created CMA memory pool at 0x99000000, size 80 MiB
[ 0.000000] Reserved memory: initialized node ipu2_cma@95800000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created CMA memory pool at 0x9e000000, size 32 MiB
[ 0.000000] Reserved memory: initialized node ipu1_cma@9d000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created CMA memory pool at 0xa1000000, size 32 MiB
[ 0.000000] Reserved memory: initialized node dsp1_cma@99000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created CMA memory pool at 0xa3000000, size 32 MiB
[ 0.000000] Reserved memory: initialized node dsp2_cma@9f000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0xa9000000, size 64 MiB
[ 0.000000] Reserved memory: initialized node cmem@A9000000, compatible id shared-dma-pool
[ 0.000000] cma: Reserved 24 MiB at 0xbe400000
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] OMAP4: Map 0xbfe00000 to fe600000 for dram barrier
[ 0.000000] DRA762 ES1.0
[ 0.000000] PERCPU: Embedded 11 pages/cpu @ef631000 s14912 r8192 d21952 u45056
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 243520
[ 0.000000] Kernel command line: console=ttyO0,115200n8 vram=16M root=PARTUUID=00000000-02 rw rootwait ip=none mem=1024M
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Memory: 329940K/980992K available (6663K kernel code, 318K rwdata, 2392K rodata, 332K init, 286K bss, 446252K reserved, 204800K cma-reserved, 235520K highmem)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
[ 0.000000] vmalloc : 0xf0800000 - 0xff800000 ( 240 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xf0000000 ( 768 MB)
[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
[ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
[ 0.000000] .text : 0xc0008000 - 0xc08e000c (9057 kB)
[ 0.000000] .init : 0xc08e1000 - 0xc0934000 ( 332 kB)
[ 0.000000] .data : 0xc0934000 - 0xc09839e0 ( 319 kB)
[ 0.000000] .bss : 0xc0985000 - 0xc09cc980 ( 287 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 32.
[ 0.000000] NR_IRQS:16 nr_irqs:16 16
[ 0.000000] ti_dt_clocks_register: failed to lookup clock node gmac_gmii_ref_clk_div
[ 0.000000] OMAP clockevent source: timer1 at 32786 Hz
[ 0.000000] Architected cp15 timer(s) running at 6.14MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x16af5adb9, max_idle_ns: 440795202250 ns
[ 0.000005] sched_clock: 56 bits at 6MHz, resolution 162ns, wraps every 4398046511023ns
[ 0.000016] Switching to timer-based delay loop, resolution 162ns
[ 0.000333] clocksource: 32k_counter: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 58327039986419 ns
[ 0.000341] OMAP clocksource: 32k_counter at 32768 Hz
[ 0.000782] Console: colour dummy device 80x30
[ 0.000799] WARNING: Your 'console=ttyO0' has been replaced by 'ttyS0'
[ 0.000805] This ensures that you still see kernel messages. Please
[ 0.000811] update your kernel commandline.
[ 0.000825] Calibrating delay loop (skipped), value calculated using timer frequency.. 12.29 BogoMIPS (lpj=61475)
[ 0.000838] pid_max: default: 32768 minimum: 301
[ 0.000933] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000944] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.001495] Initializing cgroup subsys io
[ 0.001512] Initializing cgroup subsys memory
[ 0.001536] Initializing cgroup subsys devices
[ 0.001549] Initializing cgroup subsys freezer
[ 0.001561] Initializing cgroup subsys perf_event
[ 0.001572] Initializing cgroup subsys pids
[ 0.001599] CPU: Testing write buffer coherency: ok
[ 0.001810] /cpus/cpu@0 missing clock-frequency property
[ 0.001825] /cpus/cpu@1 missing clock-frequency property
[ 0.001836] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.001879] Setting up static identity map for 0x80008340 - 0x800083a0
[ 0.080097] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.080165] Brought up 2 CPUs
[ 0.080177] SMP: Total of 2 processors activated (24.59 BogoMIPS).
[ 0.080184] CPU: All CPU(s) started in HYP mode.
[ 0.080189] CPU: Virtualization extensions available.
[ 0.081225] devtmpfs: initialized
[ 0.110327] VFP support v0.3: implementor 41 architecture 4 part 30 variant f rev 0
[ 0.111284] omap_hwmod: l3_main_2 using broken dt data from ocp
[ 0.214306] omap_hwmod: mcan: cannot clk_get main_clk mcan_clk
[ 0.214320] omap_hwmod: mcan: cannot _init_clocks
[ 0.214327] ------------[ cut here ]------------
[ 0.214340] WARNING: CPU: 0 PID: 1 at arch/arm/mach-omap2/omap_hwmod.c:2529 _init.constprop.23+0x394/0x424()
[ 0.214347] omap_hwmod: mcan: couldn't init clocks
[ 0.214353] Modules linked in:
[ 0.214366] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 4.4.84 #1
[ 0.214374] Hardware name: Generic DRA74X (Flattened Device Tree)
[ 0.214380] Backtrace:
[ 0.214405] [<c0013b1c>] (dump_backtrace) from [<c0013d18>] (show_stack+0x18/0x1c)
[ 0.214412] r7:c08edac0 r6:60000013 r5:00000000 r4:c0953590
[ 0.214440] [<c0013d00>] (show_stack) from [<c02b39a8>] (dump_stack+0x8c/0xa0)
[ 0.214452] [<c02b391c>] (dump_stack) from [<c003581c>] (warn_slowpath_common+0x88/0xb8)
[ 0.214458] r7:c08edac0 r6:000009e1 r5:00000009 r4:ef081e58
[ 0.214481] [<c0035794>] (warn_slowpath_common) from [<c0035884>] (warn_slowpath_fmt+0x38/0x40)
[ 0.214487] r8:c081f0e4 r7:00000000 r6:ffffffea r5:ffffffea r4:c081f13c
[ 0.214512] [<c0035850>] (warn_slowpath_fmt) from [<c08edac0>] (_init.constprop.23+0x394/0x424)
[ 0.214518] r3:c08210f0 r2:c081f13c
[ 0.214529] r4:c0942a5c
[ 0.214541] [<c08ed72c>] (_init.constprop.23) from [<c08edc80>] (__omap_hwmod_setup_all+0x48/0x98)
[ 0.214547] r10:00000000 r9:c08e1600 r8:000000ab r7:ef1e5740 r6:c09396f0 r5:c093b9b8
[ 0.214569] r4:c0942a5c
[ 0.214581] [<c08edc38>] (__omap_hwmod_setup_all) from [<c000988c>] (do_one_initcall+0x98/0x1e4)
[ 0.214587] r5:c08edc38 r4:c09396f0
[ 0.214603] [<c00097f4>] (do_one_initcall) from [<c08e1f40>] (kernel_init_freeable+0x1d4/0x268)
[ 0.214609] r10:00000002 r9:c08e1600 r8:000000ab r7:c0921820 r6:c092f26c r5:c0985000
[ 0.214630] r4:c0985000
[ 0.214646] [<c08e1d6c>] (kernel_init_freeable) from [<c068358c>] (kernel_init+0x18/0xf4)
[ 0.214652] r10:00000000 r9:00000000 r8:00000000 r7:00000000 r6:00000000 r5:c0683574
[ 0.214672] r4:c0985000
[ 0.214685] [<c0683574>] (kernel_init) from [<c000fd18>] (ret_from_fork+0x14/0x3c)
[ 0.214691] r5:c0683574 r4:00000000
[ 0.214713] ---[ end trace 1694446aa6f7a8da ]---
[ 0.222993] omap_hwmod: dcan1: _wait_target_disable failed
[ 0.306786] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.306809] futex hash table entries: 512 (order: 3, 32768 bytes)
[ 0.310952] pinctrl core: initialized pinctrl subsystem
[ 0.311822] NET: Registered protocol family 16
[ 0.312753] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.340215] cpuidle: using governor ladder
[ 0.370242] cpuidle: using governor menu
[ 0.378948] OMAP GPIO hardware version 0.1
[ 0.385530] irq: no irq domain found for /ocp/l4@4a000000/scm@2000/pinmux@1400 !
[ 0.401344] omap-gpmc 50000000.gpmc: GPMC revision 6.0
[ 0.401358] gpmc_mem_init: disabling cs 0 mapped at 0x0-0x1000000
[ 0.410626] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.410636] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.411109] omap4_sram_init:Unable to allocate sram needed to handle errata I688
[ 0.411119] omap4_sram_init:Unable to get sram pool needed to handle errata I688
[ 0.411595] OMAP DMA hardware revision 0.0
[ 0.451730] omap-dma-engine 4a056000.dma-controller: OMAP DMA engine driver (LinkedList1/2/3 supported)
[ 0.452867] edma 43300000.edma: memcpy is disabled
[ 0.457767] edma 43300000.edma: TI EDMA DMA engine driver
[ 0.461952] omap-iommu 40d01000.mmu: 40d01000.mmu registered
[ 0.462139] omap-iommu 40d02000.mmu: 40d02000.mmu registered
[ 0.462300] omap-iommu 58882000.mmu: 58882000.mmu registered
[ 0.462456] omap-iommu 55082000.mmu: 55082000.mmu registered
[ 0.462746] omap-iommu 41501000.mmu: 41501000.mmu registered
[ 0.462934] omap-iommu 41502000.mmu: 41502000.mmu registered
[ 0.465954] palmas 2-0058: IRQ missing: skipping irq request
[ 0.480687] palmas 2-0058: Muxing GPIO 51, PWM 0, LED 2
[ 0.512554] pcf857x: probe of 2-0020 failed with error -121
[ 0.512803] pcf857x: probe of 2-0021 failed with error -121
[ 0.512960] omap_i2c 48060000.i2c: bus 2 rev0.12 at 400 kHz
[ 0.513157] media: Linux media interface: v0.10
[ 0.513206] Linux video capture interface: v2.00
[ 0.513245] pps_core: LinuxPPS API ver. 1 registered
[ 0.513252] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.513275] PTP clock support registered
[ 0.513319] EDAC MC: Ver: 3.0.0
[ 0.514079] omap-mailbox 48840000.mailbox: omap mailbox rev 0x400
[ 0.514369] omap-mailbox 48842000.mailbox: omap mailbox rev 0x400
[ 0.514711] Advanced Linux Sound Architecture Driver Initialized.
[ 0.515555] clocksource: Switched to clocksource arch_sys_counter
[ 0.526132] NET: Registered protocol family 2
[ 0.526627] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.526693] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.526818] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.526866] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.526897] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.527103] NET: Registered protocol family 1
[ 0.527357] RPC: Registered named UNIX socket transport module.
[ 0.527366] RPC: Registered udp transport module.
[ 0.527373] RPC: Registered tcp transport module.
[ 0.527379] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.528374] hw perfevents: enabled with armv7_cortex_a15 PMU driver, 7 counters available
[ 0.529440] ------------[ cut here ]------------
[ 0.529457] WARNING: CPU: 0 PID: 1 at arch/arm/mach-omap2/omap_hwmod.c:2108 _enable+0x2bc/0x2d8()
[ 0.529465] omap_hwmod: timer12: enabled state can only be entered from initialized, idle, or disabled state
[ 0.529471] Modules linked in:
[ 0.529484] CPU: 0 PID: 1 Comm: swapper/0 Tainted: G W 4.4.84 #1
[ 0.529491] Hardware name: Generic DRA74X (Flattened Device Tree)
[ 0.529497] Backtrace:
[ 0.529517] [<c0013b1c>] (dump_backtrace) from [<c0013d18>] (show_stack+0x18/0x1c)
[ 0.529524] r7:c0025730 r6:20000093 r5:00000000 r4:c0953590
[ 0.529551] [<c0013d00>] (show_stack) from [<c02b39a8>] (dump_stack+0x8c/0xa0)
[ 0.529562] [<c02b391c>] (dump_stack) from [<c003581c>] (warn_slowpath_common+0x88/0xb8)
[ 0.529568] r7:c0025730 r6:0000083c r5:00000009 r4:ef081c48
[ 0.529590] [<c0035794>] (warn_slowpath_common) from [<c0035884>] (warn_slowpath_fmt+0x38/0x40)
[ 0.529596] r8:00000004 r7:c0027128 r6:a0000093 r5:c0940dd8 r4:c081ed50
[ 0.529620] [<c0035850>] (warn_slowpath_fmt) from [<c0025730>] (_enable+0x2bc/0x2d8)
[ 0.529626] r3:c0820bac r2:c081ed50
[ 0.529636] r4:c0940d78
[ 0.529648] [<c0025474>] (_enable) from [<c0025ecc>] (omap_hwmod_enable+0x2c/0x4c)
[ 0.529654] r7:c0027128 r6:a0000093 r5:c0940dd8 r4:c0940d78
[ 0.529676] [<c0025ea0>] (omap_hwmod_enable) from [<c00270d8>] (omap_device_enable+0x48/0x98)
[ 0.529683] r7:c0027128 r6:ef240e80 r5:00000000 r4:00000001
[ 0.529704] [<c0027090>] (omap_device_enable) from [<c0027140>] (_od_runtime_resume+0x18/0x2c)
[ 0.529710] r7:c0027128 r6:c0027128 r5:ef23da74 r4:ef23da10
[ 0.529734] [<c0027128>] (_od_runtime_resume) from [<c03f1f34>] (__rpm_callback+0x34/0x68)
[ 0.529740] r5:ef23da74 r4:ef23da10
[ 0.529755] [<c03f1f00>] (__rpm_callback) from [<c03f1f90>] (rpm_callback+0x28/0x88)
[ 0.529761] r7:c0027128 r6:ef206c10 r5:ef23da10 r4:ef23da10
[ 0.529782] [<c03f1f68>] (rpm_callback) from [<c03f2e74>] (rpm_resume+0x374/0x56c)
[ 0.529788] r7:c0027128 r6:ef206c10 r5:c0936100 r4:ef23da10
[ 0.529810] [<c03f2b00>] (rpm_resume) from [<c03f30c0>] (__pm_runtime_resume+0x54/0x6c)
[ 0.529816] r10:00000000 r9:ef240c00 r8:00000000 r7:60000013 r6:00000004 r5:ef23da74
[ 0.529837] r4:ef23da10
[ 0.529851] [<c03f306c>] (__pm_runtime_resume) from [<c0031b44>] (omap_dm_timer_probe+0x1b0/0x3ec)
[ 0.529857] r7:c068c104 r6:ef23da10 r5:ef23da00 r4:ef3c8310
[ 0.529880] [<c0031994>] (omap_dm_timer_probe) from [<c03eaf04>] (platform_drv_probe+0x54/0xb8)
[ 0.529886] r9:c08e1600 r8:00000000 r7:fffffdfb r6:c0945b9c r5:ef23da10 r4:c09bfa44
[ 0.529911] [<c03eaeb0>] (platform_drv_probe) from [<c03e948c>] (driver_probe_device+0x204/0x2f8)
[ 0.529917] r7:c0945b9c r6:00000000 r5:ef23da10 r4:c09bfa44
[ 0.529937] [<c03e9288>] (driver_probe_device) from [<c03e9614>] (__driver_attach+0x94/0x98)
[ 0.529943] r9:c08e1600 r8:000000ab r7:00000000 r6:ef23da44 r5:c0945b9c r4:ef23da10
[ 0.529971] [<c03e9580>] (__driver_attach) from [<c03e7714>] (bus_for_each_dev+0x70/0xa4)
[ 0.529976] r7:00000000 r6:c03e9580 r5:c0945b9c r4:00000000
[ 0.530000] [<c03e76a4>] (bus_for_each_dev) from [<c03e8d78>] (driver_attach+0x24/0x28)
[ 0.530006] r6:c0964310 r5:ef383d00 r4:c0945b9c
[ 0.530027] [<c03e8d54>] (driver_attach) from [<c03e89b4>] (bus_add_driver+0x1a8/0x220)
[ 0.530038] [<c03e880c>] (bus_add_driver) from [<c03e9db4>] (driver_register+0x80/0x100)
[ 0.530044] r7:ef3b6040 r6:c09396f0 r5:c08f0d78 r4:c0945b9c
[ 0.530065] [<c03e9d34>] (driver_register) from [<c03eae2c>] (__platform_driver_register+0x48/0x50)
[ 0.530071] r5:c08f0d78 r4:c0964310
[ 0.530088] [<c03eade4>] (__platform_driver_register) from [<c08f0d90>] (omap_dm_timer_driver_init+0x18/0x20)
[ 0.530093] r5:c08f0d78 r4:c09396f0
[ 0.530110] [<c08f0d78>] (omap_dm_timer_driver_init) from [<c000988c>] (do_one_initcall+0x98/0x1e4)
[ 0.530121] [<c00097f4>] (do_one_initcall) from [<c08e1f40>] (kernel_init_freeable+0x1d4/0x268)
[ 0.530127] r10:00000007 r9:c08e1600 r8:000000ab r7:c0921834 r6:c092f5b4 r5:c0985000
[ 0.530148] r4:c0985000
[ 0.530163] [<c08e1d6c>] (kernel_init_freeable) from [<c068358c>] (kernel_init+0x18/0xf4)
[ 0.530169] r10:00000000 r9:00000000 r8:00000000 r7:00000000 r6:00000000 r5:c0683574
[ 0.530189] r4:c0985000
[ 0.530202] [<c0683574>] (kernel_init) from [<c000fd18>] (ret_from_fork+0x14/0x3c)
[ 0.530208] r5:c0683574 r4:00000000
[ 0.530219] ---[ end trace 1694446aa6f7a8db ]---
[ 0.530231] omap_timer 4ae20000.timer: omap_dm_timer_probe: pm_runtime_get_sync failed!
[ 0.530251] omap_timer: probe of 4ae20000.timer failed with error -22
[ 0.538302] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.538939] NFS: Registering the id_resolver key type
[ 0.538965] Key type id_resolver registered
[ 0.538973] Key type id_legacy registered
[ 0.539040] ntfs: driver 2.1.32 [Flags: R/O].
[ 0.540362] bounce: pool size: 64 pages
[ 0.540505] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[ 0.540522] io scheduler noop registered
[ 0.540536] io scheduler deadline registered
[ 0.540568] io scheduler cfq registered (default)
[ 0.545020] pinctrl-single 4a003400.pinmux: 282 pins at pa fc003400 size 1128
[ 0.548170] PCI host bridge /ocp/axi@0/pcie_rc@51000000 ranges:
[ 0.548183] No bus range found for /ocp/axi@0/pcie_rc@51000000, using [bus 00-ff]
[ 0.548216] IO 0x20003000..0x20012fff -> 0x00000000
[ 0.548238] MEM 0x20013000..0x2fffffff -> 0x20013000
[ 0.578188] dra7-pcie 51000000.pcie_rc: link is not up
[ 0.578353] dra7-pcie 51000000.pcie_rc: PCI host bridge to bus 0000:00
[ 0.578366] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 0.578376] pci_bus 0000:00: root bus resource [io 0x0000-0xffff]
[ 0.578386] pci_bus 0000:00: root bus resource [mem 0x20013000-0x2fffffff]
[ 0.578791] PCI: bus0: Fast back to back transfers disabled
[ 0.578909] PCI: bus1: Fast back to back transfers enabled
[ 0.578991] pci 0000:00:00.0: BAR 0: assigned [mem 0x20100000-0x201fffff]
[ 0.579006] pci 0000:00:00.0: BAR 1: assigned [mem 0x20020000-0x2002ffff]
[ 0.579019] pci 0000:00:00.0: PCI bridge to [bus 01]
[ 0.579243] pcieport 0000:00:00.0: Signaling PME through PCIe PME interrupt
[ 0.640217] Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled
[ 0.643623] 4806a000.serial: ttyS0 at MMIO 0x4806a000 (irq = 301, base_baud = 3000000) is a 8250
[ 2.262605] console [ttyS0] enabled
[ 2.267022] 4806c000.serial: ttyS1 at MMIO 0x4806c000 (irq = 302, base_baud = 3000000) is a 8250
[ 2.277043] [drm] Initialized drm 1.1.0 20060810
[ 2.282863] omapdss_dss 58000000.dss: master bind failed: -517
[ 2.346740] loop: module loaded
[ 2.350274] vmemexp device MAJOR num = 245
[ 2.354401] vmemexp class registered
[ 2.358132] /dev/vmemexp device registered
[ 2.362245] ioctl DBUFIOC_EXPORT_VIRTMEM = -1072899120
[ 2.367953] nand: No NAND device found
[ 2.371722] omap2-nand 8000000.nand: scan failed, may be bus-width mismatch
[ 2.381436] m25p80 spi32766.0: unrecognized JEDEC id bytes: 00, 0, 0
[ 2.389000] libphy: Fixed MDIO Bus: probed
[ 2.435588] davinci_mdio 48485000.mdio: davinci mdio revision 1.6
[ 2.441711] davinci_mdio 48485000.mdio: no live phy, scanning all
[ 2.448931] davinci_mdio: probe of 48485000.mdio failed with error -5
[ 2.466382] cpsw 48484000.ethernet: Detected MACID = 90:9a:77:69:da:18
[ 2.473035] cpsw 48484000.ethernet: cpts: overflow check period 800
[ 2.480046] cpsw 48484000.ethernet: cpsw: Detected MACID = 90:9a:77:69:da:19
[ 2.488689] mousedev: PS/2 mouse device common for all mice
[ 2.494856] i2c /dev entries driver
[ 2.503458] omap_hsmmc 4809c000.mmc: Got CD GPIO
[ 2.510296] pbias_mmc_omap5: unsupportable voltage range: 3300000-3000000uV
[ 2.517332] omap_hsmmc 4809c000.mmc: pbias set voltage failed
[ 2.566119] omap_hsmmc 480b4000.mmc: no pinctrl state for sdr25 mode
[ 2.572503] omap_hsmmc 480b4000.mmc: no pinctrl state for sdr12 mode
[ 2.716359] ledtrig-cpu: registered to indicate activity on CPUs
[ 2.726433] tlv320aic3x-codec 2-0019: Failed to get supply 'IOVDD': -517
[ 2.733167] tlv320aic3x-codec 2-0019: Failed to request supplies: -517
[ 2.741210] davinci-mcasp 4847c000.mcasp: invalid tdm slots: 0
[ 2.748646] NET: Registered protocol family 10
[ 2.763922] sit: IPv6 over IPv4 tunneling driver
[ 2.769131] NET: Registered protocol family 17
[ 2.773804] Key type dns_resolver registered
[ 2.778240] omap_voltage_late_init: Voltage driver support not added
[ 2.785114] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm
[ 2.791338] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm
[ 2.797591] ti_oppdm 4a003b20.oppdm: Unable to get vdd regulator:-517
[ 2.804181] Power Management for TI OMAP4+ devices.
[ 2.809272] Registering SWP/SWPB emulation handler
[ 2.816737] dmm 4e000000.dmm: initialized all PAT entries
[ 2.833618] omapdss_dss 58000000.dss: master bind failed: -517
[ 2.840322] omap_hsmmc 480b4000.mmc: no pinctrl state for sdr25 mode
[ 2.846726] omap_hsmmc 480b4000.mmc: no pinctrl state for sdr12 mode
[ 2.853908] tlv320aic3x-codec 2-0019: Failed to get supply 'IOVDD': -517
[ 2.860659] tlv320aic3x-codec 2-0019: Failed to request supplies: -517
[ 2.867929] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm
[ 2.874147] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm
[ 2.880421] ti_oppdm 4a003b20.oppdm: Unable to get vdd regulator:-517
[ 2.887573] hctosys: unable to open rtc device (rtc0)
[ 2.904591] evm_1v8: disabling
[ 2.907682] evm_3v3_sw: disabling
[ 2.911227] ALSA device list:
[ 2.914205] No soundcards found.
[ 2.918517] Waiting for root device PARTUUID=00000000-02...
[ 2.977660] omap_hsmmc 4809c000.mmc: card busy
[ 2.985520] pbias_mmc_omap5: unsupportable voltage range: 3300000-3000000uV
[ 2.992534] omap_hsmmc 4809c000.mmc: pbias set voltage failed
[ 3.105858] mmc0: host does not support reading read-only switch, assuming write-enable
[ 3.119527] mmc0: new high speed SDHC card at address aaaa
[ 3.135506] mmcblk0: mmc0:aaaa SC16G 14.8 GiB
[ 3.144220] mmcblk0: p1 p2
[ 3.148625] omapdss_dss 58000000.dss: master bind failed: -517
[ 3.155327] omap_hsmmc 480b4000.mmc: no pinctrl state for sdr25 mode
[ 3.161867] omap_hsmmc 480b4000.mmc: no pinctrl state for sdr12 mode
[ 3.172333] tlv320aic3x-codec 2-0019: Failed to get supply 'IOVDD': -517
[ 3.179151] tlv320aic3x-codec 2-0019: Failed to request supplies: -517
[ 3.186560] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm
[ 3.192821] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm
[ 3.199145] ti_oppdm 4a003b20.oppdm: Unable to get vdd regulator:-517
[ 3.248370] EXT4-fs (mmcblk0p2): couldn't mount as ext3 due to feature incompatibilities
[ 3.259277] EXT4-fs (mmcblk0p2): couldn't mount as ext2 due to feature incompatibilities
[ 3.493961] EXT4-fs (mmcblk0p2): recovery complete
[ 3.499804] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 3.507980] VFS: Mounted root (ext4 filesystem) on device 179:2.
[ 3.514074] devtmpfs: mounted
[ 3.517295] Freeing unused kernel memory: 332K
[ 3.521756] This architecture does not have kernel memory protection.
[ 3.716686] systemd[1]: System time before build time, advancing clock.
[ 3.758063] random: systemd: uninitialized urandom read (16 bytes read, 14 bits of entropy available)
[ 3.773774] random: systemd: uninitialized urandom read (16 bytes read, 14 bits of entropy available)
[ 3.791575] systemd[1]: systemd 229 running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR +SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT +GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN)
[ 3.810174] systemd[1]: Detected architecture arm.
Welcome to Arago 2016.12!
[ 3.839126] systemd[1]: Set hostname to <dra7xx-evm>.
[ 3.899715] random: systemd-gpt-aut: uninitialized urandom read (16 bytes read, 15 bits of entropy available)
[ 3.910501] random: systemd-gpt-aut: uninitialized urandom read (16 bytes read, 15 bits of entropy available)
[ 3.938544] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read, 16 bits of entropy available)
[ 3.965363] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read, 17 bits of entropy available)
[ 3.979021] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read, 17 bits of entropy available)
[ 4.064371] random: systemd: uninitialized urandom read (16 bytes read, 19 bits of entropy available)
[ 4.073963] random: systemd: uninitialized urandom read (16 bytes read, 19 bits of entropy available)
[ 4.084218] random: systemd: uninitialized urandom read (16 bytes read, 19 bits of entropy available)
[ 4.374813] systemd[1]: sysinit.target: Found ordering cycle on sysinit.target/start
[ 4.382661] systemd[1]: sysinit.target: Found dependency on alignment.service/start
[ 4.390449] systemd[1]: sysinit.target: Found dependency on basic.target/start
[ 4.397748] systemd[1]: sysinit.target: Found dependency on sysinit.target/start
[ 4.405183] systemd[1]: sysinit.target: Breaking ordering cycle by deleting job alignment.service/start
[ 4.414641] systemd[1]: alignment.service: Job alignment.service/start deleted to break ordering cycle starting with sysinit.target/start
[ SKIP ] Ordering cycle found, skipping alignment.service
[ 4.448196] systemd[1]: Listening on Network Service Netlink Socket.
[ OK ] Listening on Network Service Netlink Socket.
[ 4.475904] systemd[1]: Listening on udev Control Socket.
[ OK ] Listening on udev Control Socket.
[ 4.507419] systemd[1]: Created slice User and Session Slice.
[ OK ] Created slice User and Session Slice.
[ 4.535789] systemd[1]: Reached target Remote File Systems.
[ OK ] Reached target Remote File Systems.
[ 4.565782] systemd[1]: Reached target Swap.
[ OK ] Reached target Swap.
[ 4.585864] systemd[1]: Listening on Syslog Socket.
[ OK ] Listening on Syslog Socket.
[ 4.605957] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ OK ] Started Dispatch Password Requests to Console Directory Watch.
[ 4.636492] systemd[1]: Created slice System Slice.
[ OK ] Created slice System Slice.
[ 4.665896] systemd[1]: Listening on Journal Socket (/dev/log).
[ OK ] Listening on Journal Socket (/dev/log).
[ 4.695939] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ OK ] Started Forward Password Requests to Wall Directory Watch.
[ 4.726518] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ OK ] Created slice system-serial\x2dgetty.slice.
[ 4.755786] systemd[1]: Reached target Paths.
[ OK ] Reached target Paths.
[ 4.775765] systemd[1]: Reached target Slices.
[ OK ] Reached target Slices.
[ 4.795880] systemd[1]: Listening on Journal Socket.
[ OK ] Listening on Journal Socket.
[ 4.855996] systemd[1]: Starting Create list of required static device nodes for the current kernel...
Starting Create list of required st... nodes for the current kernel...
[ 4.888616] systemd[1]: Starting Setup Virtual Console...
[ 4.918388] systemd[1]: Mounting POSIX Message Queue File System...
[ 4.985857] systemd[1]: Mounting Debug File System...
[ 5.018252] systemd[1]: Mounting Temporary Directory...
[ 5.075947] systemd[1]: Starting Load Kernel Modules...
[ 5.111183] systemd[1]: Starting Journal Service...
[ 5.135956] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ OK ] Listening on /dev/initctl Compatibility Named Pipe.
[ 5.166727] systemd[1]: Created slice system-getty.slice.
[ OK ] Created slice system-getty.slice.
[ 5.235929] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 5.257607] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 5.266016] systemd[1]: Listening on udev Kernel Socket.
[ OK ] Listening on udev Kernel Socket.
[ 5.338274] systemd[1]: Mounted POSIX Message Queue File System.
[ OK ] Mounted POSIX Message Queue File System.
[ 5.365991] systemd[1]: Mounted Debug File System.
[ OK ] Mounted Debug File System.
[ 5.385840] systemd[1]: Mounted Temporary Directory.
[ OK ] Mounted Temporary Directory.
[ 5.416065] systemd[1]: Started Journal Service.
[ OK ] Started Journal Service.
[ OK ] Started Create list of required sta...ce nodes for the current kernel.
[ OK ] Started Setup Virtual Console.
[FAILED] Failed to start Load Kernel Modules.
See 'systemctl status systemd-modules-load.service' for details.
[ OK ] Started Remount Root and Kernel File Systems.
Starting udev Coldplug all Devices...
Starting Apply Kernel Variables...
Starting Create Static Device Nodes in /dev...
Starting Flush Journal to Persistent Storage...
[ OK ] Started Apply Kernel Variables.
[ OK ] Started Create Static Device Nodes in /dev.
[ 6.152586] systemd-journald[129]: Received request to flush runtime journal from PID 1
Starting udev Kernel Device Manager...
[ OK ] Reached target Local File Systems (Pre).
Mounting /media/ram...
Mounting /var/volatile...
[ OK ] Mounted /var/volatile.
[ OK ] Mounted /media/ram.
[ OK ] Started udev Kernel Device Manager.
[ OK ] Started Flush Journal to Persistent Storage.
[ 6.674821] omap-rproc 55020000.ipu: assigned reserved memory node ipu2_cma@95800000
[ 6.701705] remoteproc0: 55020000.ipu is aailable
Starting Load/Save Random Seed...
[ OK ] Reached target Local File Systems.
[ 6.728022] remoteproc0: Note: remoteproc is still under development and considered experimental.
Starting Create Volatile Files and Directories...
[ 6.756392] remoteproc0: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
[ 6.771789] omap-rproc 40800000.dsp: assigned reserved memory node dsp1_cma@99000000
[ 6.772901] omapdss_dss 58000000.dss: master bind failed: -517
[ 6.773831] omap_hsmmc 480b4000.mmc: no pinctrl state for sdr25 mode
[ 6.773836] omap_hsmmc 480b4000.mmc: no pinctrl state for sdr12 mode
[ 6.806745] tlv320aic3x-codec 2-0019: Failed to get supply 'IOVDD': -517
[ 6.813289] remoteproc1: 40800000.dsp is available
[ 6.813293] remoteproc1: Note: remoteproc is still under development and considered experimental.
[ 6.813296] remoteproc1: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
[ 6.814877] omap-rproc 41000000.dsp: assigned reserved memory node dsp2_cma@9f000000
[ 6.814931] remoteproc2: 41000000.dsp is available
[ 6.814935] remoteproc2: Note: remoteproc is still under development and considered experimental.
[ 6.814938] remoteproc2: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
[ OK ] Started udev Coldplug all Devices.
[ OK ] Started Load/Save Random Seed.
[ OK ] Found device /dev/ttyS0.
[ 7.156899] tlv320aic3x-codec 2-0019: Failed to request supplies: -517
[ 7.164431] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm
[ 7.205388] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm
[ 7.218754] ti_oppdm 4a003b20.oppdm: Unable to get vdd regulator:-517
[ 7.227212] omapdss_dss 58000000.dss: master bind failed: -517
[ 7.237990] omap_hsmmc 480b4000.mmc: no pinctrl state for sdr25 mode
[ 7.244389] omap_hsmmc 480b4000.mmc: no pinctrl state for sdr12 mode
[ 7.273712] tlv320aic3x-codec 2-0019: Failed to get supply 'IOVDD': -517
[ 7.284603] tlv320aic3x-codec 2-0019: Failed to request supplies: -517
[ 7.665159] remoteproc1: registered virtio0 (type 7)
[ 7.681034] remoteproc2: registered virtio1 (type 7)
[ 7.715414] omap-des 480a5000.des: OMAP DES hw accel rev: 2.2
[ 7.727941] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm
[ OK ] Started Create Volatile Files and Directories.[ 7.738062] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm
[ 7.747534] ti_oppdm 4a003b20.oppdm: Unable to get vdd regulator:-517
[ 7.755507] omapdss_dss 58000000.dss: master bind failed: -517
[ 7.764696] omap_hsmmc 480b4000.mmc: no pinctrl state for sdr25 mode
[ 7.772707] omap-sham 4b101000.sham: hw accel on OMAP rev 4.3
[ 7.779675] omap_hsmmc 480b4000.mmc: no pinctrl state for sdr12 mode
[ 7.789416] tlv320aic3x-codec 2-0019: Failed to get supply 'IOVDD': -517
[ 7.797360] tlv320aic3x-codec 2-0019: Failed to request supplies: -517
[ 7.806773] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm
[ 7.816291] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm
[ 7.822874] ti_oppdm 4a003b20.oppdm: Unable to get vdd regulator:-517
[ 7.833526] omapdss_dss 58000000.dss: master bind failed: -517
[ 7.846344] omap_hsmmc 480b4000.mmc: no pinctrl state for sdr25 mode
[ 7.854863] omap_hsmmc 480b4000.mmc: no pinctrl state for sdr12 mode
[ 7.877345] omap-aes 4b500000.aes: OMAP AES hw accel rev: 3.3
[ 7.890551] omap-aes 4b700000.aes: OMAP AES hw accel rev: 3.3
Starting Network Time Synchronization...[ 7.915877] tlv320aic3x-codec 2-0019: Failed to get supply 'IOVDD': -517
[ 7.928424] CAN device driver interface
[ 7.934534] tlv320aic3x-codec 2-0019: Failed to request supplies: -517
[ 7.943061] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm
[ 7.967889] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm
[ 7.975508] ti_oppdm 4a003b20.oppdm: Unable to get vdd regulator:-517
[ 7.988926] omapdss_dss 58000000.dss: master bind failed: -517
[ 7.996144] omap_hsmmc 480b4000.mmc: no pinctrl state for sdr25 mode
[ 8.009752] omap_hsmmc 480b4000.mmc: no pinctrl state for sdr12 mode
Starting Update UTMP about System Boot/Shutdown...[ 8.043241] tlv320aic3x-codec 2-0019: Failed to get supply 'IOVDD': -517
[ 8.069228] tlv320aic3x-codec 2-0019: Failed to request supplies: -517
[ 8.077384] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm
[ 8.090270] ------------[ cut here ]------------
[ 8.094926] WARNING: CPU: 1 PID: 238 at arch/arm/mach-omap2/omap_hwmod.c:2108 _enable+0x2bc/0x2d8()
[ 8.104013] omap_hwmod: rng: enabled state can only be entered from initialized, idle, or disabled state
[ 8.113534] Modules linked in: omap_rng(+) rng_core dwc3_omap can_dev omap_aes_driver omap_sham extcon omap_des omap_remoteproc remoteproc virtio virtio_ring sch_fq_codel
[ 8.128929] CPU: 1 PID: 238 Comm: systemd-udevd Tainted: G W 4.4.84 #1
[ 8.136617] Hardware name: Generic DRA74X (Flattened Device Tree)
[ 8.142734] Backtrace:
[ 8.145207] [<c0013b1c>] (dump_backtrace) from [<c0013d18>] (show_stack+0x18/0x1c)
[ 8.152809] r7:c0025730 r6:20010093 r5:00000000 r4:c0953590
[ 8.158534] [<c0013d00>] (show_stack) from [<c02b39a8>] (dump_stack+0x8c/0xa0)
[ 8.165792] [<c02b391c>] (dump_stack) from [<c003581c>] (warn_slowpath_common+0x88/0xb8)
[ 8.173914] r7:c0025730 r6:0000083c r5:00000009 r4:ee7d7b38
[ 8.179633] [<c0035794>] (warn_slowpath_common) from [<c0035884>] (warn_slowpath_fmt+0x38/0x40)
[ 8.188369] r8:00000004 r7:c0027128 r6:a0010013 r5:c09404b0 r4:c081ed50
[ 8.195146] [<c0035850>] (warn_slowpath_fmt) from [<c0025730>] (_enable+0x2bc/0x2d8)
[ 8.202921] r3:c081de88 r2:c081ed50
[ 8.206527] r4:c0940450
[ 8.209083] [<c0025474>] (_enable) from [<c0025ecc>] (omap_hwmod_enable+0x2c/0x4c)
[ 8.216683] r7:c0027128 r6:a0010013 r5:c09404b0 r4:c0940450
[ 8.222400] [<c0025ea0>] (omap_hwmod_enable) from [<c00270d8>] (omap_device_enable+0x48/0x98)
[ 8.230959] r7:c0027128 r6:ef262f00 r5:00000000 r4:00000001
[ 8.236681] [<c0027090>] (omap_device_enable) from [<c0027140>] (_od_runtime_resume+0x18/0x2c)
[ 8.245329] r7:c0027128 r6:c0027128 r5:ef266474 r4:ef266410
[ 8.251053] [<c0027128>] (_od_runtime_resume) from [<c03f1f34>] (__rpm_callback+0x34/0x68)
[ 8.259353] r5:ef266474 r4:ef266410
[ 8.262964] [<c03f1f00>] (__rpm_callback) from [<c03f1f90>] (rpm_callback+0x28/0x88)
[ 8.270738] r7:c0027128 r6:ef206c10 r5:ef266410 r4:ef266410
[ 8.276459] [<c03f1f68>] (rpm_callback) from [<c03f2e74>] (rpm_resume+0x374/0x56c)
[ 8.284060] r7:c0027128 r6:ef206c10 r5:c0936100 r4:ef266410
[ 8.289779] [<c03f2b00>] (rpm_resume) from [<c03f30c0>] (__pm_runtime_resume+0x54/0x6c)
[ 8.297813] r10:00000000 r9:ed829dc8 r8:ef266400 r7:60010013 r6:00000004 r5:ef266474
[ 8.305719] r4:ef266410
[ 8.308287] [<c03f306c>] (__pm_runtime_resume) from [<bf0b84c0>] (omap_rng_probe+0x88/0x278 [omap_rng])
[ 8.317721] r7:ed829a10 r6:ef266410 r5:ef266410 r4:bf0b8aec
[ 8.323446] [<bf0b8438>] (omap_rng_probe [omap_rng]) from [<c03eaf04>] (platform_drv_probe+0x54/0xb8)
[ 8.332703] r8:0000000e r7:fffffdfb r6:bf0b8b50 r5:ef266410 r4:c09bfa44
[ 8.339485] [<c03eaeb0>] (platform_drv_probe) from [<c03e948c>] (driver_probe_device+0x204/0x2f8)
[ 8.348393] r7:bf0b8b50 r6:00000000 r5:ef266410 r4:c09bfa44
[ 8.354112] [<c03e9288>] (driver_probe_device) from [<c03e9614>] (__driver_attach+0x94/0x98)
[ 8.362584] r9:ed829dc8 r8:127d625c r7:00000000 r6:ef266444 r5:bf0b8b50 r4:ef266410
[ 8.370409] [<c03e9580>] (__driver_attach) from [<c03e7714>] (bus_for_each_dev+0x70/0xa4)
[ 8.378621] r7:00000000 r6:c03e9580 r5:bf0b8b50 r4:00000000
[ 8.384342] [<c03e76a4>] (bus_for_each_dev) from [<c03e8d78>] (driver_attach+0x24/0x28)
[ 8.392379] r6:c0964310 r5:ed549f80 r4:bf0b8b50
[ 8.397052] [<c03e8d54>] (driver_attach) from [<c03e89b4>] (bus_add_driver+0x1a8/0x220)
[ 8.405097] [<c03e880c>] (bus_add_driver) from [<c03e9db4>] (driver_register+0x80/0x100)
[ 8.413220] r7:ed829a80 r6:c09396f0 r5:bf0bb000 r4:bf0b8b50
[ 8.418947] [<c03e9d34>] (driver_register) from [<c03eae2c>] (__platform_driver_register+0x48/0x50)
[ 8.428029] r5:bf0bb000 r4:c0964310
[ 8.431641] [<c03eade4>] (__platform_driver_register) from [<bf0bb01c>] (omap_rng_driver_init+0x1c/0x24 [omap_rng])
[ 8.442120] r5:bf0bb000 r4:c09396f0
[ 8.445738] [<bf0bb000>] (omap_rng_driver_init [omap_rng]) from [<c000988c>] (do_one_initcall+0x98/0x1e4)
[ 8.455352] [<c00097f4>] (do_one_initcall) from [<c00d0c70>] (do_init_module+0x68/0x398)
[ 8.463477] r10:bf0b8bc0 r9:ed829dc8 r8:127d625c r7:00000001 r6:ed829b00 r5:00000001
[ 8.471383] r4:bf0b8bc0
[ 8.473939] [<c00d0c08>] (do_init_module) from [<c00ad660>] (load_module+0x1df8/0x2068)
[ 8.481976] r6:ed829dc0 r5:00000001 r4:ee7d7f44
[ 8.486641] [<c00ab868>] (load_module) from [<c00adabc>] (SyS_finit_module+0x88/0x98)
[ 8.494502] r10:00000000 r9:ee7d6000 r8:c000fe24 r7:0000017b r6:b6e58d90 r5:0000000f
[ 8.502416] r4:00000000
[ 8.504971] [<c00ada34>] (SyS_finit_module) from [<c000fc60>] (ret_fast_syscall+0x0/0x3c)
[ 8.513180] r6:00000000 r5:004c6928 r4:00000000
[ 8.517839] ---[ end trace 1694446aa6f7a8dd ]---
[ 8.524996] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm
[ 8.531506] ti_oppdm 4a003b20.oppdm: Unable to get vdd regulator:-517
[ 8.539180] omap_rng 48090000.rng: Failed to runtime_get device: -22
[ 8.551290] omap_rng 48090000.rng: initialization failed.
[ 8.557864] omap_rng: probe of 48090000.rng failed with error -22
[ 8.718742] omap_hwmod: dcan1: _wait_target_disable failed
[ 8.725725] c_can_platform 4ae3c000.can: c_can_platform device registered (regs=fce3c000, irq=355)
[ 8.736556] omapdss_dss 58000000.dss: master bind failed: -517
[ 8.743299] omap_hsmmc 480b4000.mmc: no pinctrl state for sdr25 mode
[ 8.762804] omap_hsmmc 480b4000.mmc: no pinctrl state for sdr12 mode
[ 8.778784] tlv320aic3x-codec 2-0019: Failed to get supply 'IOVDD': -517
[ 8.788450] tlv320aic3x-codec 2-0019: Failed to request supplies: -517
[ OK ] Started Update UTMP about System Boot/Shutdown.[ 8.797016] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm
[ 8.807939] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm
[ 8.814206] ti_oppdm 4a003b20.oppdm: Unable to get vdd regulator:-517
[ OK ] Started Network Time Synchronization.
[ OK ] Reached target System Time Synchronized.
[ 8.878926] SCSI subsystem initialized
Starting Synchronize System and HW clocks...
[ 8.971038] remoteproc0: registered virtio2 (type 7)
[FAILED] Failed to start Synchronize System and HW clocks.
See 'systemctl status sync-clocks.service' for details.
[ OK ] Reached target System Initialization.
[ 9.238330] [drm] Initialized pvr 1.14.3699939 20110701 on minor 0
[ OK ] Listening on dropbear.socket.
[ 9.259785] omapdss_dss 58000000.dss: master bind failed: -517
[ 9.269846] ahci 4a140000.sata: SSS flag set, parallel bus scan disabled
[ 9.284911] ahci 4a140000.sata: AHCI 0001.0300 32 slots 1 ports 3 Gbps 0x1 impl platform mode
[ 9.287715] omap_hsmmc 480b4000.mmc: no pinctrl state for sdr25 mode
[ 9.287721] omap_hsmmc 480b400.mmc: no pinctrl state for sdr12 mode
[ 9.300922] tlv320aic3x-codec 2-0019: Failed to get supply 'IOVDD': -517
[ 9.300927] tlv320aic3x-codec 2-0019: Failed to request supplies: -517
[ 9.301732] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm
[ 9.301737] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm
[ OK [ 9.301778] ti_oppdm 4a003b20.oppdm: Unable to get vdd regulator:-517
[ 9.340577] ahci 4a140000.sata: flags: 64bit ncq sntf stag pm led clo only pmp pio slum part ccc apst
] isLtening on D-Bus System Message Bus Socket.
[ 9.379169] scsi host0: ahci
[ 9.382584] ata1: SATA max UDMA/133 mmio [mem 0x4a140000-0x4a1410ff] port 0x100 irq 340
[ 9.394483] omapdss_dss 58000000.dss: master bind failed: -517
[[032m OK ]Reached target Sockets.[ 9.406152] omap_hsmmc 480b4000.mmc: no pinctrl state for sdr25 mode
[ 9.431157] omap_hsmmc 480b4000.mmc: no pinctrl state for sdr12 mode
[[;32m OK ]Reached target Basic System.[ 9.444093] tlv320aic3x-codec 2-0019: Failed to get supply 'IOVDD': -517
[ 9.469578] tlv320aic3x-codec 2-0019: Failed to request supplies: -517
[ 9.484583] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm
[ 9.510544] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm
[ 9.516832] ti_oppdm 4a003b20.oppdm: Unable to get vdd regulator:-517
tSarting Permit User Sessions...
[[;32m OK ]Started D-Bus System Message Bus.
[ 9.735638] ata1: SATA link down (SStatus 0 SControl 300)
tSarting Network Service...
[ 9.774291] FAT-fs (mmcblk0p1): Volume was not properly umounted. Some data may be corrupt. Please run fsck.
tSarting rc.pvr.service...
[[;32m OK ]Started System Logging Service.
[[;32m OK ]Started Daily Cleanup of Temporary Directorie.
[ 9.882904] omap_hwmod: dcan1: _wait_target_disable failed
[ OK ] Reached target Timers.
[ 9.920484] net eth1: initializing cpsw version 1.15 (0)
[ 9.936666] net eth0: initialized cpsw ale version 1.4
[ 9.941883] net eth0: ALE Table size 1024
[ 9.953485] libphy: PHY 48485000.mdio:03 not found
[ 9.968605] net eth1: phy "48485000.mdio:03" not found on slave 1, err -19
Starting Login Service...
[ 9.989583] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
[ OK ] Started Kernel Logging Service.[ 10.017992] net eth0: initializing cpsw version 1.15 (0)
[ 10.026717] PVR_K: UM DDK-(3699939) and KM DDK-(3699939) match. [ OK ]
[ 10.097608] net eth0: phy found : id is : 0x0
[ 10.099331] omapdss_dss 58000000.dss: master bind failed: -517
[ 10.100297] omap_hsmmc 480b4000.mmc: no pinctrl state for sdr25 mode
[ 10.100302] omap_hsmmc 480b4000.mmc: no pinctrl state for sdr12 mode
[ 10.122011] tlv320aic3x-codec 2-0019: Failed to get supply 'IOVDD': -517
[ 10.139158] tlv320aic3x-codec 2-0019: Failed to request supplies: -517
[ 10.155322] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 10.180090] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm
[ 10.207908] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm
[ 10.236714] ti_oppdm 4a003b20.oppdm: Unable to get vdd regulator:-517
[ OK ] Started Network Service.
[ OK ] Started Permit User Sessions.
[ OK ] Started rc.pvr.service.
[ 10.329960] remoteproc1: powering up 40800000.dsp
[ 10.363073] remoteproc1: Booting fw image dra7-dsp1-fw.xe66, size 5584899
[ 10.377744] omap_hwmod: mmu0_dsp1: _wait_target_disable failed
[ 10.383640] omap-iommu 40d01000.mmu: 40d01000.mmu: version 3.0
[ 10.389603] omap-iommu 40d02000.mmu: 40d02000.mmu: version 3.0
[ 10.440187] remoteproc1: remote processor 40800000.dsp is now up
[ 10.462077] omap_hwmod: dcan1: _wait_target_disable failed
[ 10.467940] virtio_rpmsg_bus virtio0: rpmsg host is online
[ 10.475360] omapdss_dss 58000000.dss: master bind failed: -517
[ 10.483034] remoteproc2: powering up 41000000.dsp
[ 10.488367] omap_hsmmc 480b4000.mmc: no pinctrl state for sdr25 mode
[ 10.494754] omap_hsmmc 480b4000.mmc: no pinctrl state for sdr12 mode
[ 10.505519] tlv320aic3x-codec 2-0019: Failed to get supply 'IOVDD': -517
[ 10.517933] remoteproc2: Booting fw image dra7-dsp2-fw.xe66, size 5584899
[ 10.531676] omap_hwmod: mmu0_dsp2: _wait_target_disable failed
[ 10.537564] omap-iommu 41501000.mmu: 41501000.mmu: version 3.0
[ 10.543498] omap-iommu 41502000.mmu: 41502000.mmu: version 3.0
[ 10.549748] tlv320aic3x-codec 2-0019: Failed to request supplies: -517
[ 10.557374] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm
[ 10.563756] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm
[ 10.570101] ti_oppdm 4a003b20.oppdm: Unable to get vdd regulator:-517
[ 10.597681] remoteproc2: remote processor 41000000.dsp is now up
[ 10.606231] virtio_rpmsg_bus virtio1: rpmsg host is online
[ 10.618781] omapdss_dss 58000000.dss: master bind failed: -517
[ 10.625509] omap_hsmmc 480b4000.mmc: no pinctrl state for sdr25 mode
[ 10.633211] remoteproc0: powering up 55020000.ipu
[ 10.649194] omap_hsmmc 480b4000.mmc: no pinctrl state for sdr12 mode
[ 10.674038] tlv320aic3x-codec 2-0019: Failed to get supply 'IOVDD': -517
[ 10.685782] remoteproc0: Booting fw image dra7-ipu2-fw.xem4, size 8442276
[ 10.697584] tlv320aic3x-codec 2-0019: Failed to request supplies: -517
[ 10.705552] omap-iommu 55082000.mmu: 55082000.mmu: version 2.1
[ 10.719230] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm
[ 10.732681] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm
[ 10.745685] ti_oppdm 4a003b20.oppdm: Unable to get vdd regulator:-517
[ 10.795194] remoteproc0: remote processor 55020000.ipu is now up
[ 10.817268] virtio_rpmsg_bus virtio2: rpmsg host is online
[ 10.824600] omapdss_dss 58000000.dss: master bind failed: -517
[ 10.837935] omap_hsmmc 480b4000.mmc: no pinctrl state for sdr25 mode
[ 10.859668] omap_hsmmc 480b4000.mmc: no pinctrl state for sdr12 mode
[ 10.875258] tlv320aic3x-codec 2-0019: Failed to get supply 'IOVDD': -517
[ 10.889975] tlv320aic3x-codec 2-0019: Failed to request supplies: -517
[ 10.906792] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm
[ 10.913122] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm
[ 10.919407] ti_oppdm 4a003b20.oppdm: Unable to get vdd regulator:-517
[ OK ] Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
Starting weston.service...
[ OK ] Started Serial Getty on ttyS0.
[ OK ] Started Getty on tty1.
[ OK ] Reached target Network.
Starting Network Name Resolution...
[ OK ] Started weston.service.
[ OK ] Started Login Service.
[ OK ] Started Network Name Resolution.
Starting tiipclad-daemon.service...
Starting telnetd.service...
[ OK ] Started tiipclad-daemon.service.
[ OK ] Started telnetd.service.
[ 12.095594] cpsw 48484000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
[ 12.103305] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
dra7xx-evm login: root
root@dra7xx-evm:~# ./start.sh
ping: sendto: Network is unreachable
[ 35.039952] DMA: Module install successful, device major num = 242
[ 35.046424] DRV: Module install successful
[ 35.069442] CMEMK module: reference Linux version 4.4.84
[ 35.075484] cmemk initialized
dpll_dra7xx_rates_calc(): incorrect DPLL_EVE status! (4)
dpll_dra7xx_init(): error while extracting DPLL_EVE parameters! (-3)./disableDssInterruptsOnA15.sh: line 11: @0x4A002ACA:: command not found
./disableDssInterruptsOnA15.sh: line 12: @0x4A002ACA:: command not found
./disableDssInterruptsOnA15.sh: line 13: @0x4A002ACA:: command not found
./disableDssInterruptsOnA15.sh: line 14: @0x4A002ACA:: command not found
./disableDssInterruptsOnA15.sh: line 15: @0x4A002ACA:: command not found
./disableDssInterruptsOnA15.sh: line 16: @0x4A002ACA:: command not found
./disableDssInterruptsOnA15.sh: line 17: @0x4A002ACA:: command not found
./disableDssInterruptsOnA15.sh: line 18: @0x4A002ACA:: command not found
./disableDssInterruptsOnA15.sh: line 19: @0x4A002ACA:: command not found
updated 0x4A002ACA value is 00930000
[1596722104.682983] [GBL] [DBG] refobj_1 created
[35.649180] [GBL] [DBG] refobj_2 created
[HOST] OSA: HOST Remote Log Shared Memory @ 0xa024f140
[HOST] OSA: DSP1 Remote Log Shared Memory @ 0xa02769e0
[HOST] OSA: DSP2 Remote Log Shared Memory @ 0xa029e280
[HOST] OSA: EVE1 Remote Log Shared Memory @ 0xa02c5b20
[HOST] OSA: EVE2 Remote Log Shared Memory @ 0xa02ed3c0
[HOST] OSA: IPU2 Remote Log Shared Memory @ 0xa0363da0
[HOST] [HOST ] 41.891569 s: SYSTEM: System A15 Init in progress !!!
[HOST] [DSP1 ] 16.628743 s: ***** DSP1 Firmware build time 19:47:34 Aug 13 2020
[HOST] [DSP1 ] 16.628804 s: *** SYSTEM: CPU Frequency <ORG = 600000000 Hz>, <NEW = 850000000 Hz>
[HOST] [DSP1 ] 16.629048 s: SYSTEM: System Common Init in progress !!!
[HOST] [DSP1 ] 16.629262 s: UTILS: CIO: Init Done !!!
[HOST] [DSP1 ] 16.629292 s: SYSTEM: IPC init in progress !!!
[HOST] [DSP1 ] 16.629323 s: SYSTEM: Attaching to [IPU2] ...
[HOST] [DSP1 ] 17.629567 s: SYSTEM: Attaching to [IPU2] ...
[HOST] [DSP1 ] 18.629597 s: SYSTEM: Attaching to [IPU2] ...
[HOST] [DSP1 ] 19.629628 s: SYSTEM: Attaching to [IPU2] ...
[HOST] [DSP1 ] 20.629659 s: SYSTEM: Attaching to [IPU2] ...
[HOST] [DSP1 ] 21.629689 s: SYSTEM: Attaching to [IPU2] ...
[HOST] [DSP1 ] 22.629689 s: SYSTEM: Attaching to [IPU2] ...
[HOST] [DSP1 ] 23.629720 s: SYSTEM: Attaching to [IPU2] ...
[HOST] [DSP1 ] 24.629750 s: SYSTEM: Attaching to [IPU2] ...
[HOST] [DSP1 ] 25.629781 s: SYSTEM: Attaching to [IPU2] ...
[HOST] [DSP1 ] 26.629811 s: SYSTEM: Attaching to [IPU2] ...
[HOST] [DSP1 ] 27.629842 s: SYSTEM: Attaching to [IPU2] ...
[HOST] [DSP1 ] 28.629872 s: SYSTEM: Attaching to [IPU2] ...
[HOST] [DSP1 ] 29.629903 s: SYSTEM: Attaching to [IPU2] ...
[HOST] [DSP1 ] 30.629933 s: SYSTEM: Attaching to [IPU2] ...
[HOST] [DSP1 ] 31.629933 s: SYSTEM: Attaching to [IPU2] ...
[HOST] [DSP1 ] 32.629964 s: SYSTEM: Attaching to [IPU2] ...
[HOST] [DSP1 ] 33.629994 s: SYSTEM: Attaching to [IPU2] ...
[HOST] [DSP1 ] 34.630025 s: SYSTEM: Attaching to [IPU2] ...
[HOST] [DSP1 ] 35.630055 s: SYSTEM: Attaching to [IPU2] ...
[HOST] [DSP1 ] 36.630086 s: SYSTEM: Attaching to [IPU2] ...
[HOST] [DSP1 ] 37.630116 s: SYSTEM: Attaching to [IPU2] ...
[HOST] [DSP1 ] 38.630147 s: SYSTEM: Attaching to [IPU2] ...
[HOST] [DSP1 ] 39.630147 s: SYSTEM: Attaching to [IPU2] ...
[HOST] [DSP1 ] 40.630177 s: SYSTEM: Attaching to [IPU2] ...
[HOST] [DSP1 ] 41.630208 s: SYSTEM: Attaching to [IPU2] ...
[HOST] [DSP2 ] 16.786250 s: ***** DSP2 Firmware build time 19:47:34 Aug 13 2020
[HOST] [DSP2 ] 16.786311 s: *** SYSTEM: CPU Frequency <ORG = 600000000 Hz>, <NEW = 850000000 Hz>
[HOST] [DSP2 ] 16.786555 s: SYSTEM: System Common Init in progress !!!
[HOST] [DSP2 ] 16.786768 s: UTILS: CIO: Init Done !!!
[HOST] [DSP2 ] 16.786799 s: SYSTEM: IPC init in progress !!!
[HOST] [DSP2 ] 16.786799 s: SYSTEM: Attaching to [IPU2] ...
[HOST] [DSP2 ] 17.786585 s: SYSTEM: Attaching to [IPU2] ...
[HOST] [DSP2 ] 18.786585 s: SYSTEM: Attaching to [IPU2] ...
[HOST] [DSP2 ] 19.786616 s: SYSTEM: Attaching to [IPU2] ...
[HOST] [DSP2 ] 20.786646 s: SYSTEM: Attaching to [IPU2] ...
[HOST] [DSP2 ] 21.786677 s: SYSTEM: Attaching to [IPU2] ...
[HOST] [DSP2 ] 22.786707 s: SYSTEM: Attaching to [IPU2] ...
[HOST] [DSP2 ] 23.786738 s: SYSTEM: Attaching to [IPU2] ...
[HOST] [DSP2 ] 24.786768 s: SYSTEM: Attaching to [IPU2] ...
[HOST] [DSP2 ] 25.786799 s: SYSTEM: Attaching to [IPU2] ...
[HOST] [DSP2 ] 26.786799 s: SYSTEM: Attaching to [IPU2] ...
[HOST] [DSP2 ] 27.786829 s: SYSTEM: Attaching to [IPU2] ...
[HOST] [DSP2 ] 28.786860 s: SYSTEM: Attaching to [IPU2] ...
[HOST] [DSP2 ] 29.786890 s: SYSTEM: Attaching to [IPU2] ...
[HOST] [DSP2 ] 30.786921 s: SYSTEM: Attaching to [IPU2] ...
[HOST] [DSP2 ] 31.786951 s: SYSTEM: Attaching to [IPU2] ...
[HOST] [DSP2 ] 32.786982 s: SYSTEM: Attaching to [IPU2] ...
[HOST] [DSP2 ] 33.787012 s: SYSTEM: Attaching to [IPU2] ...
[HOST] [DSP2 ] 34.787043 s: SYSTEM: Attaching to [IPU2] ...
[HOST] [DSP2 ] 35.787043 s: SYSTEM: Attaching to [IPU2] ...
[HOST] [DSP2 ] 36.787073 s: SYSTEM: Attaching to [IPU2] ...
[HOST] [DSP2 ] 37.787104 s: SYSTEM: Attaching to [IPU2] ...
[HOST] [DSP2 ] 38.787134 s: SYSTEM: Attaching to [IPU2] ...
[HOST] [DSP2 ] 39.787165 s: SYSTEM: Attaching to [IPU2] ...
[HOST] [DSP2 ] 40.787195 s: SYSTEM: Attaching to [IPU2] ...
[HOST] [DSP2 ] 41.787226 s: SYSTEM: Attaching to [IPU2] ...
[35.854913] [STC] [DBG] StitcherTask valid calibration data given, using it.
[36.059259] [STC] [DBG] process new pose data and post result OK.
[HOST] [DSP1 ] 42.630238 s: SYSTEM: Attaching to [IPU2] ...
[HOST] [DSP2 ] 42.787256 s: SYSTEM: Attaching to [IPU2] ...
[HOST] [DSP1 ] 43.630269 s: SYSTEM: Attaching to [IPU2] ...
[HOST] [DSP2 ] 43.787287 s: SYSTEM: Attaching to [IPU2] ...
[HOST] [DSP1 ] 44.630299 s: SYSTEM: Attaching to [IPU2] ...
[HOST] [DSP2 ] 44.787287 s: SYSTEM: Attaching to [IPU2] ...
[HOST] [DSP1 ] 45.630330 s: SYSTEM: Attaching to [IPU2] ...
[HOST] [DSP2 ] 45.787317 s: SYSTEM: Attaching to [IPU2] ...
[HOST] [DSP1 ] 46.630360 s: SYSTEM: Attaching to [IPU2] ...
[HOST] [DSP2 ] 46.787348 s: SYSTEM: Attaching to [IPU2] ...
[HOST] [DSP1 ] 47.630391 s: SYSTEM: Attaching to [IPU2] ...
^Croot@dra7xx-evm:~# [ 263.035583] omap-mailbox 48840000.mailbox: Try increasing MBOX_TX_QUEUE_LEN
[ 263.042588] omap-rproc 40800000.dsp: PM mbox_send_message failed: -105
[ 263.051930] omap-mailbox 48842000.mailbox: Try increasing MBOX_TX_QUEUE_LEN
[ 263.059021] omap-rproc 41000000.dsp: PM mbox_send_message failed: -105
[ 880.631116] random: nonblocking pool is initialized
    Can you run the apps.out from the other board having the old power management chip? let me know the status.
    Gaviraju
  • Here is the log from the board having the old power management chip:
    U-Boot SPL 2016.05 (Jun 30 2020 - 13:36:04)
    DRA762-GP ES1.0
    reading u-boot.img
    reading u-boot.img
    reading u-boot.img
    reading u-boot.img
    U-Boot 2016.05 (Jun 30 2020 - 13:36:04 +0800)
    DRAM: 2 GiB
    Found 0 device(s).
    reading boot.scr
    reading uEnv.txt
    166 bytes read in 3 ms (53.7 KiB/s)
    3559232 bytes read in 178 ms (19.1 MiB/s)
    106314 bytes read in 33 ms (3.1 MiB/s)
    Kernel image @ 0x82000000 [ 0x000000 - 0x364f40 ]
    Loading Device Tree to 8ffe3000, end 8fffff49 ... OK
    Starting kernel ...
    [ 0.000000] Linux version 4.4.84 (gcc version 5.3.1 20160113 (Linaro GCC 5.3-2016.02) ) #140 SMP PREEMPT Tue Jun 30 15:56:05 CST 2020
    [ 0.000000] cma: Reserved 24 MiB at 0xfb400000
    [ 0.000000] OMAP4: Map 0xfce00000 to fe600000 for dram barrier
    [ 0.000000] PERCPU: Embedded 11 pages/cpu @eed97000 s14912 r8192 d21952 u45056
    [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 493376
    [ 0.000000] Kernel command line: console=ttyO0,115200n8 vram=16M root=PARTUUID=5000e638-02 rw rootwait ip=none mem=2000M
    [ 0.000000] Memory: 1320560K/1980416K available (6663K kernel code, 318K rwdata, 2392K rodata, 332K init, 286K bss, 455056K reserved, 204800K cma-reserved, 1234944K highmem)
    [ 0.000004] sched_clock: 56 bits at 6MHz, resolution 162ns, wraps every 4398046511023ns
    [ 0.000328] clocksource: 32k_counter: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 58327039986419 ns
    [ 0.000336] OMAP clocksource: 32k_counter at 32768 Hz
    [ 0.000767] Console: colour dummy device 80x30
    [ 0.000783] WARNING: Your 'console=ttyO0' has been replaced by 'ttyS0'
    [ 0.000789] This ensures that you still see kernel messages. Please
    [ 0.000795] update your kernel commandline.
    [ 0.000808] Calibrating delay loop (skipped), value calculated using timer frequency.. 12.29 BogoMIPS (lpj=61475)
    [ 0.000821] pid_max: default: 32768 minimum: 301
    [ 0.000916] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
    [ 0.000928] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
    [ 0.001482] Initializing cgroup subsys io
    [ 0.001499] Initializing cgroup subsys memory
    [ 0.001524] Initializing cgroup subsys devices
    [ 0.001537] Initializing cgroup subsys freezer
    [ 0.001548] Initializing cgroup subsys perf_event
    [ 0.001558] Initializing cgroup subsys pids
    [ 0.001585] CPU: Testing write buffer coherency: ok
    [ 0.001793] /cpus/cpu@0 missing clock-frequency property
    [ 0.001810] /cpus/cpu@1 missing clock-frequency property
    [ 0.001820] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
    [ 0.001864] Setting up static identity map for 0x80008340 - 0x800083a0
    [ 0.080094] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
    [ 0.080163] Brought up 2 CPUs
    [ 0.080176] SMP: Total of 2 processors activated (24.59 BogoMIPS).
    [ 0.080183] CPU: All CPU(s) started in HYP mode.
    [ 0.080188] CPU: Virtualization extensions available.
    [ 0.081226] devtmpfs: initialized
    [ 0.109953] VFP support v0.3: implementor 41 architecture 4 part 30 variant f rev 0
    [ 0.110918] omap_hwmod: l3_main_2 using broken dt data from ocp
    [ 0.215341] omap_hwmod: mcan: cannot clk_get main_clk mcan_clk
    [ 0.215357] omap_hwmod: mcan: cannot _init_clocks
    [ 0.215363] ------------[ cut here ]------------
    [ 0.215377] WARNING: CPU: 0 PID: 1 at arch/arm/mach-omap2/omap_hwmod.c:2529 _init.constprop.23+0x394/0x424()
    [ 0.215383] omap_hwmod: mcan: couldn't init clocks
    [ 0.215389] Modules linked in:
    [ 0.215404] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 4.4.84 #140
    [ 0.215411] Hardware name: Generic DRA74X (Flattened Device Tree)
    [ 0.215418] Backtrace:
    [ 0.215440] [<c0013b1c>] (dump_backtrace) from [<c0013d18>] (show_stack+0x18/0x1c)
    [ 0.215448] r7:c08edac0 r6:60000013 r5:00000000 r4:c0953590
    [ 0.215476] [<c0013d00>] (show_stack) from [<c02b39a8>] (dump_stack+0x8c/0xa0)
    [ 0.215488] [<c02b391c>] (dump_stack) from [<c003581c>] (warn_slowpath_common+0x88/0xb8)
    [ 0.215494] r7:c08edac0 r6:000009e1 r5:00000009 r4:ee881e58
    [ 0.215515] [<c0035794>] (warn_slowpath_common) from [<c0035884>] (warn_slowpath_fmt+0x38/0x40)
    [ 0.215521] r8:c081f0e4 r7:00000000 r6:ffffffea r5:ffffffea r4:c081f13c
    [ 0.215545] [<c0035850>] (warn_slowpath_fmt) from [<c08edac0>] (_init.constprop.23+0x394/0x424)
    [ 0.215552] r3:c08210f0 r2:c081f13c
    [ 0.215562] r4:c0942a5c
    [ 0.215574] [<c08ed72c>] (_init.constprop.23) from [<c08edc80>] (__omap_hwmod_setup_all+0x48/0x98)
    [ 0.215580] r10:00000000 r9:c08e1600 r8:000000ab r7:ee9e5680 r6:c09396f0 r5:c093b9b8
    [ 0.215602] r4:c0942a5c
    [ 0.215614] [<c08edc38>] (__omap_hwmod_setup_all) from [<c000988c>] (do_one_initcall+0x98/0x1e4)
    [ 0.215621] r5:c08edc38 r4:c09396f0
    [ 0.215637] [<c00097f4>] (do_one_initcall) from [<c08e1f40>] (kernel_init_freeable+0x1d4/0x268)
    [ 0.215643] r10:00000002 r9:c08e1600 r8:000000ab r7:c0921820 r6:c092f26c r5:c0985000
    [ 0.215663] r4:c0985000
    [ 0.215679] [<c08e1d6c>] (kernel_init_freeable) from [<c0683624>] (kernel_init+0x18/0xf4)
    [ 0.215685] r10:00000000 r9:00000000 r8:00000000 r7:00000000 r6:00000000 r5:c068360c
    [ 0.215704] r4:c0985000
    [ 0.215717] [<c068360c>] (kernel_init) from [<c000fd18>] (ret_from_fork+0x14/0x3c)
    [ 0.215723] r5:c068360c r4:00000000
    [ 0.215746] ---[ end trace 19791fcb257323af ]---
    [ 0.224021] omap_hwmod: dcan1: _wait_target_disable failed
    [ 0.320610] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
    [ 0.320633] futex hash table entries: 512 (order: 3, 32768 bytes)
    [ 0.324913] pinctrl core: initialized pinctrl subsystem
    [ 0.325789] NET: Registered protocol family 16
    [ 0.326715] DMA: preallocated 256 KiB pool for atomic coherent allocations
    [ 0.350205] cpuidle: using governor ladder
    [ 0.380232] cpuidle: using governor menu
    [ 0.388942] OMAP GPIO hardware version 0.1
    [ 0.395506] irq: no irq domain found for /ocp/l4@4a000000/scm@2000/pinmux@1400 !
    [ 0.411594] omap-gpmc 50000000.gpmc: GPMC revision 6.0
    [ 0.411607] gpmc_mem_init: disabling cs 0 mapped at 0x0-0x1000000
    [ 0.420880] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
    [ 0.420890] hw-breakpoint: maximum watchpoint size is 8 bytes.
    [ 0.421366] omap4_sram_init:Unable to allocate sram needed to handle errata I688
    [ 0.421376] omap4_sram_init:Unable to get sram pool needed to handle errata I688
    [ 0.421852] OMAP DMA hardware revision 0.0
    [ 0.461538] omap-dma-engine 4a056000.dma-controller: OMAP DMA engine driver (LinkedList1/2/3 supported)
    [ 0.462663] edma 43300000.edma: memcpy is disabled
    [ 0.467461] edma 43300000.edma: TI EDMA DMA engine driver
    [ 0.471667] omap-iommu 40d01000.mmu: 40d01000.mmu registered
    [ 0.471854] omap-iommu 40d02000.mmu: 40d02000.mmu registered
    [ 0.472012] omap-iommu 58882000.mmu: 58882000.mmu registered
    [ 0.472167] omap-iommu 55082000.mmu: 55082000.mmu registered
    [ 0.472456] omap-iommu 41501000.mmu: 41501000.mmu registered
    [ 0.472645] omap-iommu 41502000.mmu: 41502000.mmu registered
    [ 0.475699] palmas 0-0058: IRQ missing: skipping irq request
    [ 0.491391] palmas 0-0058: Muxing GPIO 2e, PWM 0, LED 0
    [ 0.574388] pcf857x: probe of 0-0020 failed with error -121
    [ 0.574691] pcf857x: probe of 0-0021 failed with error -121
    [ 0.574849] omap_i2c 48070000.i2c: bus 0 rev0.12 at 400 kHz
    [ 0.575255] omap_i2c 48060000.i2c: bus 2 rev0.12 at 400 kHz
    [ 0.575448] media: Linux media interface: v0.10
    [ 0.575503] Linux video capture interface: v2.00
    [ 0.575541] pps_core: LinuxPPS API ver. 1 registered
    [ 0.575549] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [ 0.575572] PTP clock support registered
    [ 0.575615] EDAC MC: Ver: 3.0.0
    [ 0.576360] omap-mailbox 48840000.mailbox: omap mailbox rev 0x400
    [ 0.576649] omap-mailbox 48842000.mailbox: omap mailbox rev 0x400
    [ 0.576998] Advanced Linux Sound Architecture Driver Initialized.
    [ 0.577840] clocksource: Switched to clocksource arch_sys_counter
    [ 0.588587] NET: Registered protocol family 2
    [ 0.589078] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
    [ 0.589144] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
    [ 0.589268] TCP: Hash tables configured (established 8192 bind 8192)
    [ 0.589317] UDP hash table entries: 512 (order: 2, 16384 bytes)
    [ 0.589348] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
    [ 0.589553] NET: Registered protocol family 1
    [ 0.589791] RPC: Registered named UNIX socket transport module.
    [ 0.589799] RPC: Registered udp transport module.
    [ 0.589805] RPC: Registered tcp transport module.
    [ 0.589811] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [ 0.590811] hw perfevents: enabled with armv7_cortex_a15 PMU driver, 7 counters available
    [ 0.591874] ------------[ cut here ]------------
    [ 0.591890] WARNING: CPU: 0 PID: 1 at arch/arm/mach-omap2/omap_hwmod.c:2108 _enable+0x2bc/0x2d8()
    [ 0.591898] omap_hwmod: timer12: enabled state can only be entered from initialized, idle, or disabled state
    [ 0.591904] Modules linked in:
    [ 0.591917] CPU: 0 PID: 1 Comm: swapper/0 Tainted: G W 4.4.84 #140
    [ 0.591924] Hardware name: Generic DRA74X (Flattened Device Tree)
    [ 0.591930] Backtrace:
    [ 0.591956] [<c0013b1c>] (dump_backtrace) from [<c0013d18>] (show_stack+0x18/0x1c)
    [ 0.591962] r7:c0025730 r6:20000093 r5:00000000 r4:c0953590
    [ 0.591990] [<c0013d00>] (show_stack) from [<c02b39a8>] (dump_stack+0x8c/0xa0)
    [ 0.592002] [<c02b391c>] (dump_stack) from [<c003581c>] (warn_slowpath_common+0x88/0xb8)
    [ 0.592008] r7:c0025730 r6:0000083c r5:00000009 r4:ee881c48
    [ 0.592029] [<c0035794>] (warn_slowpath_common) from [<c0035884>] (warn_slowpath_fmt+0x38/0x40)
    [ 0.592035] r8:00000004 r7:c0027128 r6:a0000093 r5:c0940dd8 r4:c081ed50
    [ 0.592059] [<c0035850>] (warn_slowpath_fmt) from [<c0025730>] (_enable+0x2bc/0x2d8)
    [ 0.592065] r3:c0820bac r2:c081ed50
    [ 0.592076] r4:c0940d78
    [ 0.592088] [<c0025474>] (_enable) from [<c0025ecc>] (omap_hwmod_enable+0x2c/0x4c)
    [ 0.592094] r7:c0027128 r6:a0000093 r5:c0940dd8 r4:c0940d78
    [ 0.592116] [<c0025ea0>] (omap_hwmod_enable) from [<c00270d8>] (omap_device_enable+0x48/0x98)
    [ 0.592122] r7:c0027128 r6:eea41dc0 r5:00000000 r4:00000001
    [ 0.592143] [<c0027090>] (omap_device_enable) from [<c0027140>] (_od_runtime_resume+0x18/0x2c)
    [ 0.592149] r7:c0027128 r6:c0027128 r5:eea3da74 r4:eea3da10
    [ 0.592174] [<c0027128>] (_od_runtime_resume) from [<c03f1f34>] (__rpm_callback+0x34/0x68)
    [ 0.592180] r5:eea3da74 r4:eea3da10
    [ 0.592194] [<c03f1f00>] (__rpm_callback) from [<c03f1f90>] (rpm_callback+0x28/0x88)
    [ 0.592200] r7:c0027128 r6:eea06c10 r5:eea3da10 r4:eea3da10
    [ 0.592222] [<c03f1f68>] (rpm_callback) from [<c03f2e74>] (rpm_resume+0x374/0x56c)
    [ 0.592228] r7:c0027128 r6:eea06c10 r5:c0936100 r4:eea3da10
    [ 0.592249] [<c03f2b00>] (rpm_resume) from [<c03f30c0>] (__pm_runtime_resume+0x54/0x6c)
    [ 0.592255] r10:00000000 r9:eea41b40 r8:00000000 r7:60000013 r6:00000004 r5:eea3da74
    [ 0.592276] r4:eea3da10
    [ 0.592291] [<c03f306c>] (__pm_runtime_resume) from [<c0031b44>] (omap_dm_timer_probe+0x1b0/0x3ec)
    [ 0.592297] r7:c068c108 r6:eea3da10 r5:eea3da00 r4:eeb7bc10
    [ 0.592320] [<c0031994>] (omap_dm_timer_probe) from [<c03eaf04>] (platform_drv_probe+0x54/0xb8)
    [ 0.592325] r9:c08e1600 r8:00000000 r7:fffffdfb r6:c0945b9c r5:eea3da10 r4:c09bfa44
    [ 0.592351] [<c03eaeb0>] (platform_drv_probe) from [<c03e948c>] (driver_probe_device+0x204/0x2f8)
    [ 0.592357] r7:c0945b9c r6:00000000 r5:eea3da10 r4:c09bfa44
    [ 0.592376] [<c03e9288>] (driver_probe_device) from [<c03e9614>] (__driver_attach+0x94/0x98)
    [ 0.592382] r9:c08e1600 r8:000000ab r7:00000000 r6:eea3da44 r5:c0945b9c r4:eea3da10
    [ 0.592409] [<c03e9580>] (__driver_attach) from [<c03e7714>] (bus_for_each_dev+0x70/0xa4)
    [ 0.592415] r7:00000000 r6:c03e9580 r5:c0945b9c r4:00000000
    [ 0.592438] [<c03e76a4>] (bus_for_each_dev) from [<c03e8d78>] (driver_attach+0x24/0x28)
    [ 0.592443] r6:c0964310 r5:eeb9eb00 r4:c0945b9c
    [ 0.592464] [<c03e8d54>] (driver_attach) from [<c03e89b4>] (bus_add_driver+0x1a8/0x220)
    [ 0.592475] [<c03e880c>] (bus_add_driver) from [<c03e9db4>] (driver_register+0x80/0x100)
    [ 0.592481] r7:eebc0040 r6:c09396f0 r5:c08f0d78 r4:c0945b9c
    [ 0.592501] [<c03e9d34>] (driver_register) from [<c03eae2c>] (__platform_driver_register+0x48/0x50)
    [ 0.592507] r5:c08f0d78 r4:c0964310
    [ 0.592524] [<c03eade4>] (__platform_driver_register) from [<c08f0d90>] (omap_dm_timer_driver_init+0x18/0x20)
    [ 0.592530] r5:c08f0d78 r4:c09396f0
    [ 0.592545] [<c08f0d78>] (omap_dm_timer_driver_init) from [<c000988c>] (do_one_initcall+0x98/0x1e4)
    [ 0.592557] [<c00097f4>] (do_one_initcall) from [<c08e1f40>] (kernel_init_freeable+0x1d4/0x268)
    [ 0.592563] r10:00000007 r9:c08e1600 r8:000000ab r7:c0921834 r6:c092f5b4 r5:c0985000
    [ 0.592584] r4:c0985000
    [ 0.592598] [<c08e1d6c>] (kernel_init_freeable) from [<c0683624>] (kernel_init+0x18/0xf4)
    [ 0.592604] r10:00000000 r9:00000000 r8:00000000 r7:00000000 r6:00000000 r5:c068360c
    [ 0.592623] r4:c0985000
    [ 0.592636] [<c068360c>] (kernel_init) from [<c000fd18>] (ret_from_fork+0x14/0x3c)
    [ 0.592642] r5:c068360c r4:00000000
    [ 0.592653] ---[ end trace 19791fcb257323b0 ]---
    [ 0.592665] omap_timer 4ae20000.timer: omap_dm_timer_probe: pm_runtime_get_sync failed!
    [ 0.592685] omap_timer: probe of 4ae20000.timer failed with error -22
    [ 0.600706] squashfs: version 4.0 (2009/01/31) Phillip Lougher
    [ 0.601343] NFS: Registering the id_resolver key type
    [ 0.601371] Key type id_resolver registered
    [ 0.601379] Key type id_legacy registered
    [ 0.601446] ntfs: driver 2.1.32 [Flags: R/O].
    [ 0.602763] bounce: pool size: 64 pages
    [ 0.602910] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
    [ 0.602928] io scheduler noop registered
    [ 0.602942] io scheduler deadline registered
    [ 0.602973] io scheduler cfq registered (default)
    [ 0.608462] pinctrl-single 4a003400.pinmux: 282 pins at pa fc003400 size 1128
    [ 0.611553] PCI host bridge /ocp/axi@0/pcie_rc@51000000 ranges:
    [ 0.611566] No bus range found for /ocp/axi@0/pcie_rc@51000000, using [bus 00-ff]
    [ 0.611599] IO 0x20003000..0x20012fff -> 0x00000000
    [ 0.611620] MEM 0x20013000..0x2fffffff -> 0x20013000
    [ 0.641379] dra7-pcie 51000000.pcie_rc: link is not up
    [ 0.641557] dra7-pcie 51000000.pcie_rc: PCI host bridge to bus 0000:00
    [ 0.641570] pci_bus 0000:00: root bus resource [bus 00-ff]
    [ 0.641581] pci_bus 0000:00: root bus resource [io 0x0000-0xffff]
    [ 0.641591] pci_bus 0000:00: root bus resource [mem 0x20013000-0x2fffffff]
    [ 0.641999] PCI: bus0: Fast back to back transfers disabled
    [ 0.642117] PCI: bus1: Fast back to back transfers enabled
    [ 0.642204] pci 0000:00:00.0: BAR 0: assigned [mem 0x20100000-0x201fffff]
    [ 0.642219] pci 0000:00:00.0: BAR 1: assigned [mem 0x20020000-0x2002ffff]
    [ 0.642232] pci 0000:00:00.0: PCI bridge to [bus 01]
    [ 0.642450] pcieport 0000:00:00.0: Signaling PME through PCIe PME interrupt
    [ 0.703046] Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled
    [ 0.706400] 4806a000.serial: ttyS0 at MMIO 0x4806a000 (irq = 301, base_baud = 3000000) is a 8250
    [ 2.331810] console [ttyS0] enabled
    [ 2.336209] 4806c000.serial: ttyS1 at MMIO 0x4806c000 (irq = 302, base_baud = 3000000) is a 8250
    [ 2.346222] [drm] Initialized drm 1.1.0 20060810
    [ 2.352616] OMAP DSS rev 6.1
    [ 2.356359] omapdss_dss 58000000.dss: bound 58001000.dispc (ops dispc_component_ops)
    [ 2.392124] loop: module loaded
    [ 2.395662] vmemexp device MAJOR num = 245
    [ 2.399813] vmemexp class registered
    [ 2.403522] /dev/vmemexp device registered
    [ 2.407635] ioctl DBUFIOC_EXPORT_VIRTMEM = -1072899120
    [ 2.413335] nand: No NAND device found
    [ 2.417102] omap2-nand 8000000.nand: scan failed, may be bus-width mismatch
    [ 2.426885] m25p80 spi32766.0: unrecognized JEDEC id bytes: 00, 0, 0
    [ 2.434415] libphy: Fixed MDIO Bus: probed
    [ 2.487871] davinci_mdio 48485000.mdio: davinci mdio revision 1.6
    [ 2.493993] davinci_mdio 48485000.mdio: no live phy, scanning all
    [ 2.501222] davinci_mdio: probe of 48485000.mdio failed with error -5
    [ 2.508341] cpsw 48484000.ethernet: Detected MACID = 38:0b:3c:50:2f:34
    [ 2.514995] cpsw 48484000.ethernet: cpts: overflow check period 800
    [ 2.521972] cpsw 48484000.ethernet: cpsw: Detected MACID = 38:0b:3c:50:2f:35
    [ 2.530600] mousedev: PS/2 mouse device common for all mice
    [ 2.536834] i2c /dev entries driver
    [ 2.545491] omap_hsmmc 4809c000.mmc: Got CD GPIO
    [ 2.552307] pbias_mmc_omap5: unsupportable voltage range: 3300000-3000000uV
    [ 2.559341] omap_hsmmc 4809c000.mmc: pbias set voltage failed
    [ 2.608393] omap_hsmmc 480b4000.mmc: no pinctrl state for sdr25 mode
    [ 2.614777] omap_hsmmc 480b4000.mmc: no pinctrl state for sdr12 mode
    [ 2.637981] evm_3v3_sw: supplied by sysen1
    [ 2.798642] ledtrig-cpu: registered to indicate activity on CPUs
    [ 2.808742] 0-0019 supply DVDD not found, using dummy regulator
    [ 2.816250] davinci-mcasp 4847c000.mcasp: invalid tdm slots: 0
    [ 2.823702] NET: Registered protocol family 10
    [ 2.839014] sit: IPv6 over IPv4 tunneling driver
    [ 2.844198] NET: Registered protocol family 17
    [ 2.848926] Key type dns_resolver registered
    [ 2.853319] omap_voltage_late_init: Voltage driver support not added
    [ 2.877896] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm
    [ 2.884103] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm
    [ 2.890968] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm
    [ 2.897176] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm
    [ 2.904095] cpufreq: cpufreq_online: CPU0: Running at unlisted freq: 1000000 KHz
    [ 2.911601] cpufreq: cpufreq_online: CPU0: Unlisted initial frequency changed to: 1500000 KHz
    [ 2.920611] Power Management for TI OMAP4+ devices.
    [ 2.925655] Registering SWP/SWPB emulation handler
    [ 2.932473] dmm 4e000000.dmm: initialized all PAT entries
    [ 2.939722] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
    [ 2.946360] [drm] No driver support for vblank timestamp query.
    [ 2.952662] [drm] Initialized omapdrm 1.0.0 20110917 on minor 0
    [ 2.970121] asoc-simple-card sound0: tlv320aic3x-hifi <-> 48468000.mcasp mapping ok
    [ 2.979524] hctosys: unable to open rtc device (rtc0)
    [ 2.992764] evm_1v8: disabling
    [ 2.995988] ALSA device list:
    [ 2.998978] #0: DRA7xx-EVM
    [ 3.002518] Waiting for root device PARTUUID=5000e638-02...
    [ 3.047215] mmc0: host does not support reading read-only switch, assuming write-enable
    [ 3.063088] mmc0: new ultra high speed SDR104 SDHC card at address aaaa
    [ 3.080086] mmcblk0: mmc0:aaaa SC16G 14.8 GiB
    [ 3.088205] mmcblk0: p1 p2
    [ 3.120354] EXT4-fs (mmcblk0p2): couldn't mount as ext3 due to feature incompatibilities
    [ 3.130893] EXT4-fs (mmcblk0p2): couldn't mount as ext2 due to feature incompatibilities
    [ 3.131576] mmc1: MAN_BKOPS_EN bit is not set
    [ 3.136947] mmc1: mmc_select_hs200 failed, error -74
    [ 3.136949] : switch to mmc1 failed
    [ 3.138654] mmc1: new MMC card at address 0001
    [ 3.149023] mmcblk1: mmc1:0001 MMC04G 3.57 GiB
    [ 3.159218] mmcblk1boot0: mmc1:0001 MMC04G partition 1 8.00 MiB
    [ 3.169388] mmcblk1boot1: mmc1:0001 MMC04G partition 2 8.00 MiB
    [ 3.262710] EXT4-fs (mmcblk0p2): recovery complete
    [ 3.268645] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
    [ 3.276788] VFS: Mounted root (ext4 filesystem) on device 179:2.
    [ 3.287586] devtmpfs: mounted
    [ 3.290760] Freeing unused kernel memory: 332K
    [ 3.295242] This architecture does not have kernel memory protection.
    [ 3.380536] systemd[1]: System time before build time, advancing clock.
    [ 3.406737] random: systemd: uninitialized urandom read (16 bytes read, 18 bits of entropy available)
    [ 3.420638] random: systemd: uninitialized urandom read (16 bytes read, 18 bits of entropy available)
    [ 3.435518] systemd[1]: systemd 229 running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR +SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT +GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN)
    [ 3.453986] systemd[1]: Detected architecture arm.
    [ 3.480721] systemd[1]: Set hostname to <dra7xx-evm>.
    [ 3.544673] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read, 20 bits of entropy available)
    [ 3.544899] random: systemd-gpt-aut: uninitialized urandom read (16 bytes read, 20 bits of entropy available)
    [ 3.545025] random: systemd-gpt-aut: uninitialized urandom read (16 bytes read, 20 bits of entropy available)
    [ 3.579732] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read, 20 bits of entropy available)
    [ 3.594259] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read, 21 bits of entropy available)
    [ 3.643054] random: systemd: uninitialized urandom read (16 bytes read, 23 bits of entropy available)
    [ 3.652504] random: systemd: uninitialized urandom read (16 bytes read, 23 bits of entropy available)
    [ 3.662364] random: systemd: uninitialized urandom read (16 bytes read, 23 bits of entropy available)
    [ 3.922794] systemd[1]: sysinit.target: Found ordering cycle on sysinit.target/start
    [ 3.930619] systemd[1]: sysinit.target: Found dependency on alignment.service/start
    [ 3.938370] systemd[1]: sysinit.target: Found dependency on basic.target/start
    [ 3.945625] systemd[1]: sysinit.target: Found dependency on sockets.target/start
    [ 3.953079] systemd[1]: sysinit.target: Found dependency on dbus.socket/start
    [ 3.960254] systemd[1]: sysinit.target: Found dependency on sysinit.target/start
    [ 3.967682] systemd[1]: sysinit.target: Breaking ordering cycle by deleting job alignment.service/start
    [ 3.977126] systemd[1]: alignment.service: Job alignment.service/start deleted to break ordering cycle starting with sysinit.target/start
    [ 4.009608] systemd[1]: Listening on Journal Socket (/dev/log).
    [ 4.028040] systemd[1]: Listening on udev Kernel Socket.
    [ 4.048140] systemd[1]: Listening on Network Service Netlink Socket.
    [ 4.068071] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
    [ 4.088152] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
    [ 4.119093] systemd[1]: Created slice System Slice.
    [ 4.138481] systemd[1]: Created slice system-getty.slice.
    [ 4.158458] systemd[1]: Created slice system-serial\x2dgetty.slice.
    [ 4.178070] systemd[1]: Listening on udev Control Socket.
    [ 4.198020] systemd[1]: Listening on Syslog Socket.
    [ 4.217987] systemd[1]: Reached target Swap.
    [ 4.238422] systemd[1]: Created slice User and Session Slice.
    [ 4.257980] systemd[1]: Reached target Slices.
    [ 4.277981] systemd[1]: Reached target Remote File Systems.
    [ 4.305997] systemd[1]: Listening on Journal Socket.
    [ 4.368005] systemd[1]: Mounting Debug File System...
    [ 4.399913] systemd[1]: Starting Create list of required static device nodes for the current kernel...
    [ 4.429791] systemd[1]: Mounting POSIX Message Queue File System...
    [ 4.459794] systemd[1]: Starting Journal Service...
    [ 4.482205] systemd[1]: Starting Load Kernel Modules...
    [ 4.498150] systemd[1]: Mounting Temporary Directory...
    [ 4.519890] systemd[1]: Starting Setup Virtual Console...
    [ 4.568257] systemd[1]: Starting Remount Root and Kernel File Systems...
    [ 4.582261] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
    [ 4.598237] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
    [ 4.618039] systemd[1]: Reached target Paths.
    [ 4.691653] systemd[1]: Mounted POSIX Message Queue File System.
    [ 4.718063] systemd[1]: Mounted Debug File System.
    [ 4.738027] systemd[1]: Mounted Temporary Directory.
    [ 4.758187] systemd[1]: Started Journal Service.
    [ 5.320233] systemd-journald[124]: Received request to flush runtime journal from PID 1
    [ 5.638552] omap-rproc 55020000.ipu: assigned reserved memory node ipu2_cma@95800000
    [ 5.646380] remoteproc0: 55020000.ipu is available
    [ 5.682197] remoteproc0: Note: remoteproc is still under development and considered experimental.
    [ 5.708077] remoteproc0: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
    [ 5.736344] omap-rproc 40800000.dsp: assigned reserved memory node dsp1_cma@99000000
    [ 5.771243] remoteproc1: 40800000.dsp is available
    [ 5.789036] remoteproc1: Note: remoteproc is still under development and considered experimental.
    [ 5.827654] remoteproc1: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
    [ 5.875576] omap-rproc 41000000.dsp: assigned reserved memory node dsp2_cma@9f000000
    [ 5.887171] remoteproc2: 41000000.dsp is available
    [ 5.905282] remoteproc2: Note: remoteproc is still under development and considered experimental.
    [ 5.922289] remoteproc2: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
    [ 6.065638] ------------[ cut here ]------------
    [ 6.070289] WARNING: CPU: 1 PID: 222 at arch/arm/mach-omap2/omap_hwmod.c:2108 _enable+0x2bc/0x2d8()
    [ 6.079373] omap_hwmod: rng: enabled state can only be entered from initialized, idle, or disabled state
    [ 6.088892] Modules linked in: omap_rng(+) rng_core omap_remoteproc remoteproc virtio virtio_ring sch_fq_codel
    [ 6.098999] CPU: 1 PID: 222 Comm: systemd-udevd Tainted: G W 4.4.84 #140
    [ 6.106859] Hardware name: Generic DRA74X (Flattened Device Tree)
    [ 6.112973] Backtrace:
    [ 6.115439] [<c0013b1c>] (dump_backtrace) from [<c0013d18>] (show_stack+0x18/0x1c)
    [ 6.123037] r7:c0025730 r6:20070193 r5:00000000 r4:c0953590
    [ 6.128747] [<c0013d00>] (show_stack) from [<c02b39a8>] (dump_stack+0x8c/0xa0)
    [ 6.135999] [<c02b391c>] (dump_stack) from [<c003581c>] (warn_slowpath_common+0x88/0xb8)
    [ 6.144120] r7:c0025730 r6:0000083c r5:00000009 r4:edf1db38
    [ 6.149827] [<c0035794>] (warn_slowpath_common) from [<c0035884>] (warn_slowpath_fmt+0x38/0x40)
    [ 6.158557] r8:00000004 r7:c0027128 r6:a0070113 r5:c09404b0 r4:c081ed50
    [ 6.165316] [<c0035850>] (warn_slowpath_fmt) from [<c0025730>] (_enable+0x2bc/0x2d8)
    [ 6.173086] r3:c081de88 r2:c081ed50
    [ 6.176682] r4:c0940450
    [ 6.179229] [<c0025474>] (_enable) from [<c0025ecc>] (omap_hwmod_enable+0x2c/0x4c)
    [ 6.186826] r7:c0027128 r6:a0070113 r5:c09404b0 r4:c0940450
    [ 6.192532] [<c0025ea0>] (omap_hwmod_enable) from [<c00270d8>] (omap_device_enable+0x48/0x98)
    [ 6.201087] r7:c0027128 r6:eea68040 r5:00000000 r4:00000001
    [ 6.206791] [<c0027090>] (omap_device_enable) from [<c0027140>] (_od_runtime_resume+0x18/0x2c)
    [ 6.215435] r7:c0027128 r6:c0027128 r5:eea66674 r4:eea66610
    [ 6.221143] [<c0027128>] (_od_runtime_resume) from [<c03f1f34>] (__rpm_callback+0x34/0x68)
    [ 6.229437] r5:eea66674 r4:eea66610
    [ 6.233037] [<c03f1f00>] (__rpm_callback) from [<c03f1f90>] (rpm_callback+0x28/0x88)
    [ 6.240807] r7:c0027128 r6:eea06c10 r5:eea66610 r4:eea66610
    [ 6.246514] [<c03f1f68>] (rpm_callback) from [<c03f2e74>] (rpm_resume+0x374/0x56c)
    [ 6.254110] r7:c0027128 r6:eea06c10 r5:c0936100 r4:eea66610
    [ 6.259816] [<c03f2b00>] (rpm_resume) from [<c03f30c0>] (__pm_runtime_resume+0x54/0x6c)
    [ 6.267848] r10:00000000 r9:ee3e24c8 r8:eea66600 r7:60070113 r6:00000004 r5:eea66674
    [ 6.275738] r4:eea66610
    [ 6.278289] [<c03f306c>] (__pm_runtime_resume) from [<bf0714c0>] (omap_rng_probe+0x88/0x278 [omap_rng])
    [ 6.287716] r7:ed43a150 r6:eea66610 r5:eea66610 r4:bf071aec
    [ 6.293425] [<bf071438>] (omap_rng_probe [omap_rng]) from [<c03eaf04>] (platform_drv_probe+0x54/0xb8)
    [ 6.302678] r8:00000007 r7:fffffdfb r6:bf071b50 r5:eea66610 r4:c09bfa44
    [ 6.309435] [<c03eaeb0>] (platform_drv_probe) from [<c03e948c>] (driver_probe_device+0x204/0x2f8)
    [ 6.318339] r7:bf071b50 r6:00000000 r5:eea66610 r4:c09bfa44
    [ 6.324042] [<c03e9288>] (driver_probe_device) from [<c03e9614>] (__driver_attach+0x94/0x98)
    [ 6.332509] r9:ee3e24c8 r8:11c1db5c r7:00000000 r6:eea66644 r5:bf071b50 r4:eea66610
    [ 6.340317] [<c03e9580>] (__driver_attach) from [<c03e7714>] (bus_for_each_dev+0x70/0xa4)
    [ 6.348523] r7:00000000 r6:c03e9580 r5:bf071b50 r4:00000000
    [ 6.354230] [<c03e76a4>] (bus_for_each_dev) from [<c03e8d78>] (driver_attach+0x24/0x28)
    [ 6.362263] r6:c0964310 r5:edf48700 r4:bf071b50
    [ 6.366917] [<c03e8d54>] (driver_attach) from [<c03e89b4>] (bus_add_driver+0x1a8/0x220)
    [ 6.374953] [<c03e880c>] (bus_add_driver) from [<c03e9db4>] (driver_register+0x80/0x100)
    [ 6.383073] r7:ed43a080 r6:c09396f0 r5:bf074000 r4:bf071b50
    [ 6.388776] [<c03e9d34>] (driver_register) from [<c03eae2c>] (__platform_driver_register+0x48/0x50)
    [ 6.397854] r5:bf074000 r4:c0964310
    [ 6.401455] [<c03eade4>] (__platform_driver_register) from [<bf07401c>] (omap_rng_driver_init+0x1c/0x24 [omap_rng])
    [ 6.411929] r5:bf074000 r4:c09396f0
    [ 6.415531] [<bf074000>] (omap_rng_driver_init [omap_rng]) from [<c000988c>] (do_one_initcall+0x98/0x1e4)
    [ 6.425140] [<c00097f4>] (do_one_initcall) from [<c00d0c70>] (do_init_module+0x68/0x398)
    [ 6.433259] r10:bf071bc0 r9:ee3e24c8 r8:11c1db5c r7:00000001 r6:ed43a040 r5:00000001
    [ 6.441148] r4:bf071bc0
    [ 6.443697] [<c00d0c08>] (do_init_module) from [<c00ad660>] (load_module+0x1df8/0x2068)
    [ 6.451728] r6:ee3e24c0 r5:00000001 r4:edf1df44
    [ 6.456380] [<c00ab868>] (load_module) from [<c00adabc>] (SyS_finit_module+0x88/0x98)
    [ 6.464238] r10:00000000 r9:edf1c000 r8:c000fe24 r7:0000017b r6:b6e4fd90 r5:0000000f
    [ 6.472128] r4:00000000
    [ 6.474675] [<c00ada34>] (SyS_finit_module) from [<c000fc60>] (ret_fast_syscall+0x0/0x3c)
    [ 6.482881] r6:00000000 r5:0048a928 r4:00000000
    [ 6.487532] ---[ end trace 19791fcb257323b2 ]---
    [ 6.509314] omap_rng 48090000.rng: Failed to runtime_get device: -22
    [ 6.520134] omap_rng 48090000.rng: initialization failed.
    [ 6.526437] omap_rng: probe of 48090000.rng failed with error -22
    [ 6.526566] remoteproc0: registered virtio0 (type 7)
    [ 6.570018] omap-des 480a5000.des: OMAP DES hw accel rev: 2.2
    [ 6.728723] remoteproc2: registered virtio1 (type 7)
    [ 6.734561] remoteproc1: registered virtio2 (type 7)
    [ 6.843464] omap-aes 4b500000.aes: OMAP AES hw accel rev: 3.3
    [ 6.843907] SCSI subsystem initialized
    [ 6.858236] CAN device driver interface
    [ 6.890058] omap-aes 4b700000.aes: OMAP AES hw accel rev: 3.3
    [ 6.897322] omap-sham 4b101000.sham: hw accel on OMAP rev 4.3
    [ 6.944118] c_can_platform 4ae3c000.can: c_can_platform device registered (regs=fce3c000, irq=356)
    [ 6.977797] ahci 4a140000.sata: SSS flag set, parallel bus scan disabled
    [ 6.997142] ahci 4a140000.sata: AHCI 0001.0300 32 slots 1 ports 3 Gbps 0x1 impl platform mode
    [ 7.043401] ahci 4a140000.sata: flags: 64bit ncq sntf stag pm led clo only pmp pio slum part ccc apst
    [ 7.116630] scsi host0: ahci
    [ 7.119881] ata1: SATA max UDMA/133 mmio [mem 0x4a140000-0x4a1410ff] port 0x100 irq 341
    [ 7.166632] [drm] Initialized pvr 1.14.3699939 20110701 on minor 1
    [ OK ] Reached target Sound Card.
    [ 7.445046] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
    [ 7.497889] ata1: SATA link down (SStatus 0 SControl 300)
    [ 7.774422] remoteproc0: powering up 55020000.ipu
    [ 7.815603] remoteproc0: Booting fw image dra7-ipu2-fw.xem4, size 10699092
    [ 7.837955] omap-iommu 55082000.mmu: 55082000.mmu: version 2.1
    [ 7.900332] remoteproc0: remote processor 55020000.ipu is now up
    [ 7.907784] virtio_rpmsg_bus virtio0: rpmsg host is online
    [ 7.914725] remoteproc2: powering up 41000000.dsp
    [ 7.931640] remoteproc2: Booting fw image dra7-dsp2-fw.xe66, size 6851472
    [ 7.954610] omap_hwmod: mmu0_dsp2: _wait_target_disable failed
    [ 7.960494] omap-iommu 41501000.mmu: 41501000.mmu: version 3.0
    [ 7.966413] omap-iommu 41502000.mmu: 41502000.mmu: version 3.0
    [ 8.040864] remoteproc2: remote processor 41000000.dsp is now up
    [ 8.068103] virtio_rpmsg_bus virtio1: rpmsg host is online
    [ 8.074803] remoteproc1: powering up 40800000.dsp
    [ 8.087572] remoteproc1: Booting fw image dra7-dsp1-fw.xe66, size 6851472
    [ 8.101628] omap_hwmod: mmu0_dsp1: _wait_target_disable failed
    [ 8.107504] omap-iommu 40d01000.mmu: 40d01000.mmu: version 3.0
    [ 8.113436] omap-iommu 40d02000.mmu: 40d02000.mmu: version 3.0
    [ 8.145097] remoteproc1: remote processor 40800000.dsp is now up
    [ 8.154654] virtio_rpmsg_bus virtio2: rpmsg host is online
    [ OK ] Started Daily Cleanup of Temporary Directories.
    [ 8.194699] virtio_rpmsg_bus virtio0: creating channel rpmsg-proto addr 0x50
    [ 8.207983] virtio_rpmsg_bus virtio2: creating channel rpmsg-proto addr 0x50
    [ 8.219054] virtio_rpmsg_bus virtio1: creating channel rpmsg-proto addr 0x50
    [ OK ] Listening on D-Bus System Message Bus Socket.[ 8.230040] NET: Registered protocol family 41
    [ OK ] Reached target Sockets.
    [ OK ] Reached target Basic System.
    Starting rc.pvr.service...
    [ OK ] Started System Logging Service.
    [ OK ] Started D-Bus System Message Bus.
    [ 8.411465] usbcore: registered new interface driver usbfs
    [ 8.413298] PVR_K: UM DDK-(3699939) and KM DDK-(3699939) match. [ OK ]
    [ 8.423883] usbcore: registered new interface driver hub
    [ 8.429806] usbcore: registered new device driver usb
    [ 8.469965] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
    [ 8.475933] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
    [ 8.485746] xhci-hcd xhci-hcd.0.auto: hcc params 0x0220f04c hci version 0x100 quirks 0x00210010
    [ 8.495445] xhci-hcd xhci-hcd.0.auto: irq 465, io mem 0x48890000
    [ 8.502440] hub 1-0:1.0: USB hub found
    [ 8.506231] hub 1-0:1.0: 1 port detected
    [ 8.511656] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
    [ 8.517430] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
    [ 8.525905] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
    [ 8.534693] hub 2-0:1.0: USB hub found
    [ 8.539627] hub 2-0:1.0: 1 port detected
    Starting Network Service...[ 8.546518] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
    [ 8.552906] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 3
    [ 8.561919] xhci-hcd xhci-hcd.1.auto: hcc params 0x0220f04c hci version 0x100 quirks 0x00210010
    [ 8.576176] xhci-hcd xhci-hcd.1.auto: irq 466, io mem 0x488d0000
    Starting Permit User Sessions...[ 8.584644] hub 3-0:1.0: USB hub found
    [ 8.590393] hub 3-0:1.0: 1 port detected
    [ 8.604474] omap_hwmod: dcan1: _wait_target_disable failed
    [ 8.608013] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
    [ 8.608024] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 4
    [ 8.608088] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
    [ 8.608643] hub 4-0:1.0: USB hub found
    [ 8.608667] hub 4-0:1.0: 1 port detected
    [ 8.655958] omap_hwmod: dcan1: _wait_target_disable failed
    [ 8.683363] net eth1: initializing cpsw version 1.15 (0)
    [ 8.692355] net eth0: initialized cpsw ale version 1.4
    [ 8.698434] net eth0: ALE Table size 1024
    [ OK ] Started Kernel Logging Service.[ 8.705607] libphy: PHY 48485000.mdio:03 not found
    [ 8.712671] net eth1: phy "48485000.mdio:03" not found on slave 1, err -19
    Starting Save/Restore Sound Card State...
    [ 8.732420] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
    [ 8.756477] net eth0: initializing cpsw version 1.15 (0)
    [ 8.764562] libphy: PHY 48485000.mdio:02 not found
    [ 8.769387] net eth0: phy "48485000.mdio:02" not found on slave 0, err -19
    [ 8.781190] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
    [ 8.827942] usb 1-1: new high-speed USB device number 2 using xhci-hcd
    [ OK ] Started Save/Restore Sound Card State.
    [ 9.036330] cdc_ether 1-1:2.0 eth2: register 'cdc_ether' at usb-xhci-hcd.0.auto-1, CDC Ethernet Device, 9c:eb:e8:cb:67:86
    [ 9.053483] usbcore: registered new interface driver cdc_ether
    [ 9.104543] cdc_ether 1-1:2.0 eth2: kevent 12 may have been dropped
    [ 9.185571] omap_hwmod: dcan1: _wait_target_disable failed
    _____ _____ _ _
    | _ |___ ___ ___ ___ | _ |___ ___ |_|___ ___| |_
    | | _| .'| . | . | | __| _| . | | | -_| _| _|
    |__|__|_| |__,|_ |___| |__| |_| |___|_| |___|___|_|
    |___| |___|
    Arago Project http://arago-project.org dra7xx-evm ttyS0
    Arago 2016.12 dra7xx-evm ttyS0
    [ 19.792902] DMA: Module install successful, device major num = 242
    [ 19.799347] DRV: Module install successful
    [ 19.814028] CMEMK module: reference Linux version 4.4.84
    [ 19.821579] cmemk initialized
    ./disableDssInterruptsOnA15.sh: line 11: @0x4A002AC8:: command not found
    ./disableDssInterruptsOnA15.sh: line 12: @0x4A002AC8:: command not found
    ./disableDssInterruptsOnA15.sh: line 13: @0x4A002AC8:: command not found
    ./disableDssInterruptsOnA15.sh: line 14: @0x4A002AC8:: command not found
    ./disableDssInterruptsOnA15.sh: line 15: @0x4A002AC8:: command not found
    ./disableDssInterruptsOnA15.sh: line 16: @0x4A002AC8:: command not found
    ./disableDssInterruptsOnA15.sh: line 17: @0x4A002AC8:: command not found
    ./disableDssInterruptsOnA15.sh: line 18: @0x4A002AC8:: command not found
    ./disableDssInterruptsOnA15.sh: line 19: @0x4A002AC8:: command not found
    [HOST] OSA: MEM: 0: Mapped 0xa0100000 to 0xab700000 of size 0x00100000
    [HOST] OSA: MEM: 1: Mapped 0x84203000 to 0x96c00000 of size 0x14a00000
    [HOST] OSA: MEM: 2: Mapped 0xa0200000 to 0x96b40000 of size 0x00040000
    [HOST] OSA: MEM: 3: Mapped 0xa02c0000 to 0x96b80000 of size 0x00080000
    [HOST] OSA: MEM: 4: Mapped 0x00000000 to 0x00000000 of size 0x00000000
    20.289309] omap_l3_noc 44000000.ocp: L3 application error: target 3 mod:2 (unclearable)
    [ 20.339127] omap_l3_noc 44000000.ocp: L3 debug error: target 3 mod:2 (unclearable)
    [H OST] [HOST ] 26.747056 s: SYSTEM: System A15 Init in proress !!!
    [HOST] [HOST ] 26.747148 s: SYSTEM: IPC: Init in progress !!!
    [HOST] [HOST ] 26.747178 s: SYSTEM: IPC: Notify init in progress !!!
    [HOST] [HOST ] 26.748825 s: SYSTEM: IPC: [IPU2] socket bind success !!! (dst vproc = 1, endpt = 81)
    [HOST] [HOST ] 26.748856 s: SYSTEM: IPC: [IPU2] socket info (family = 41, dst proc id = -1, endpt = 81) !!!
    [HOST] [HOST ] 26.748886 s: SYSTEM: IPC: [IPU2] socket connect success !!! (dst vproc = 1, endpt = 80)
    [HOST] [HOST ] 26.748886 s: SYSTEM: IPC: [IPU2] socket info (family = 41, dst proc id = -1, endpt = 1024) !!!
    [HOST] [HOST ] 26.750320 s: SYSTEM: IPC: [DSP1] socket bind success !!! (dst vproc = 2, endpt = 81)
    [HOST] [HOST ] 26.750320 s: SYSTEM: IPC: [DSP1] socket info (family = 41, dst proc id = -1, endpt = 81) !!!
    [HOST] [HOST ] 26.750350 s: SYSTEM: IPC: [DSP1] socket connect success !!! (dst vproc = 2, endpt = 80)
    [HOST] [HOST ] 26.750350 s: SYSTEM: IPC: [DSP1] socket info (family = 41, dst proc id = -1, endpt = 1024) !!!
    [HOST] [HOST ] 26.751875 s: SYSTEM: IPC: [DSP2] socket bind success !!! (dst vproc = 3, endpt = 81)
    [HOST] [HOST ] 26.751906 s: SYSTEM: IPC: [DSP2] socket info (family = 41, dst proc id = -1, endpt = 81) !!!
    [HOST] [HOST ] 26.751906 s: SYSTEM: IPC: [DSP2] socket connect success !!! (dst vproc = 3, endpt = 80)
    [HOST] [HOST ] 26.751936 s: SYSTEM: IPC: [DSP2] socket info (family = 41, dst proc id = -1, endpt = 1024) !!!
    [HOST] [HOST ] 26.752119 s: SYSTEM: IPC: Notify init DONE !!!
    [HOST] [HOST ] 26.752150 s: SYSTEM: MSGQ: MsgQ init in progress !!!
    [HOST] [HOST ] 26.752272 s: SYSTEM: MSGQ: MsgQ init DONE !!!
    [HOST] [HOST ] 26.752272 s: SYSTEM: IPC: Init DONE !!!
    [HOST] [HOST ] 26.752272 s: SYSTEM: Initializing A15 Links !!!
    [HOST] [HOST ] 26.752394 s: IPC_OUT_0 : Init done - linkid-0x2000000
    [HOST] [HOST ] 26.752485 s: IPC_OUT_1 : Init done - linkid-0x2000001
    [HOST] [HOST ] 26.752577 s: IPC_OUT_2 : Init done - linkid-0x2000002
    [HOST] [HOST ] 26.752699 s: IPC_OUT_3 : Init done - linkid-0x2000003
    [HOST] [HOST ] 26.752790 s: IPC_OUT_4 : Init done - linkid-0x2000004
    [HOST] [HOST ] 26.752912 s: IPC_IN_0 : Init done - linkid-0x200000a
    [HOST] [HOST ] 26.753004 s: IPC_IN_1 : Init done - linkid-0x200000b
    [HOST] [HOST ] 26.753126 s: IPC_IN_2 : Init done - linkid-0x200000c
    [HOST] [HOST ] 26.753248 s: IPC_IN_3 : Init done - linkid-0x200000d
    [HOST] [HOST ] 26.753370 s: IPC_IN_4 : Init done - linkid-0x200000e
    [HOST] [HOST ] 26.753461 s: IPC_IN_5 : Init done - linkid-0x200000f
    [HOST] [HOST ] 26.753583 s: IPC_IN_6 : Init done - linkid-0x2000010
    [HOST] [HOST ] 26.753705 s: NULL_0 : Init done - linkid-0x2000014
    [HOST] [HOST ] 26.753797 s: NULL_1 : Init done - linkid-0x2000015
    [HOST] [HOST ] 26.753980 s: NULL_SRC_0 : Init done - linkid-0x2000039
    [HOST] [HOST ] 26.754132 s: DISP_DIST_SRC_0 : Init done - linkid-0x200005c
    [HOST] [HOST ] 26.754254 s: DISP_DIST_SRC_1 : Init done - linkid-0x200005d
    [HOST] [HOST ] 26.754468 s: DISP_DIST_SRC_2 : Init done - linkid-0x200005e
    [HOST] [HOST ] 26.754651 s: DISP_DIST_SRC_3 : Init done - linkid-0x200005f
    [20.363625] [STC] [DBG] StitcherTask valid calibration data given, using it.
    [HOST] [HOST ] 26.754803 s: DISP_DIST_SRC_4 : Init done - linkid-0x2000060
    [HOST] [HOST ] 26.754925 s: DISP_DIST_SRC_5 : Init done - linkid-0x2000061
    [HOST] [HOST ] 26.755139 s: DISP_DIST_SRC_6 : Init done - linkid-0x2000062
    [HOST] [HOST ] 26.755261 s: DISP_DIST_SRC_7 : Init done - linkid-0x2000063
    [HOST] [HOST ] 26.755383 s: Sgx3Dsrv[id=0] SGX3DSRV_0 : Init done - linkid-0x2000045
    [HOST] [HOST ] 26.755566 s: ALGORITHM_0 : Init done - linkid-0x2000031
    [HOST] [HOST ] 26.755688 s: ALGORITHM_1 : Init done - linkid-0x2000032
    [20.634280] [STC] [DBG] process new pose data and post result OK.
    [HOST] [HOST ] 26.755810 s: ALGORITHM_2 : Init done - linkid-0x2000033
    [HOST] [HOST ] 26.755901 s: ALGORITHM_3 : Init done - linkid-0x2000034
    [HOST] [HOST ] 26.755993 s: ALGORITHM_4 : Init done - linkid-0x2000035
    [HOST] [HOST ] 26.756115 s: ALGORITHM_5 : Init done - linkid-0x2000036
    [HOST] [HOST ] 26.756237 s: ALGORITHM_6 : Init done - linkid-0x2000037
    [HOST] [HOST ] 26.756328 s: ALGORITHM_7 : Init done - linkid-0x2000038
    [HOST] [HOST ] 26.756542 s: DUP0 : Init done - linkid-0x0
    [HOST] [HOST ] 26.756786 s: DUP1 : Init done - linkid-0x0
    [HOST] [HOST ] 26.756999 s: DUP2 : Init done - linkid-0x0
    [HOST] [HOST ] 26.758585 s: DUP3 : Init done - linkid-0x0
    [HOST] [HOST ] 26.758799 s: DUP4 : Init done - linkid-0x0
    [HOST] [HOST ] 26.758890 s: SYNC_0 : Init done - linkid-0x0
    [HOST] [HOST ] 26.760538 s: SYNC_1 : Init done - linkid-0x0
    [HOST] [HOST ] 26.760660 s: SYNC_2 : Init done - linkid-0x0
    [HOST] [HOST ] 26.760812 s: SYNC_3 : Init done - linkid-0x0
    [HOST] [HOST ] 26.760965 s: MERGE_0 : Init done - linkid-0x0
    [HOST] [HOST ] 26.762825 s: MERGE_1 : Init done - linkid-0x0
    [HOST] [HOST ] 26.763557 s: MERGE_2 : Init done - linkid-0x0
    [HOST] [HOST ] 26.764625 s: MERGE_3 : Init done - linkid-0x0
    [HOST] [HOST ] 26.764716 s: MERGE_4 : Init done - linkid-0x0
    [HOST] [HOST ] 26.764808 s: SELECT_0 : Init done - linkid-0x0
    [HOST] [HOST ] 26.764899 s: SELECT_1 : Init done - linkid-0x0
    [HOST] [HOST ] 26.764991 s: GATE_0 : Init done - linkid-0x0
    [HOST] [HOST ] 26.765052 s: GATE_1 : Init done - linkid-0x0
    [HOST] [HOST ] 26.765113 s: GATE_2 : Init done - linkid-0x0
    [HOST] [HOST ] 26.765174 s: GATE_3 : Init done - linkid-0x0
    [HOST] [HOST ] 26.765235 s: SGXFRMCPY_0 : Init done - linkid-0x2000044
    [HOST] [HOST ] 26.765235 s: SYSTEM: Initializing A15 Links ... DONE !!!
    [HOST] [HOST ] 26.765906 s: OSA: Adjusting global time, timeH by 0 units!!!
    [HOST] [HOST ] 26.765906 s: SYSTEM: System A15 Init Done !!!
    [HOST] [HOST ] 26.766150 s: NETWORK_CTRL: Starting Server (port=5000) !!!
    [HOST] [HOST ] 26.766211 s: NETWORK_CTRL: Starting Server ... DONE (port=5000) !!!
    [HOST] [DSP1 ] 14.624382 s: ***** DSP1 Firmware build time 16:11:53 Jun 16 2020
    [HOST] [DSP1 ] 14.624443 s: *** SYSTEM: CPU Frequency <ORG = 600000000 Hz>, <NEW = 850000000 Hz>
    [HOST] [DSP1 ] 14.624687 s: SYSTEM: System Common Init in progress !!!
    [HOST] [DSP1 ] 14.624900 s: UTILS: CIO: Init Done !!!
    [HOST] [DSP1 ] 14.624931 s: SYSTEM: IPC init in progress !!!
    [HOST] [DSP1 ] 14.624931 s: SYSTEM: Attaching to [IPU2] ...
    [HOST] [DSP1 ] 14.626852 s: SYSTEM: Attaching to [IPU2] ... SUCCESS !!!
    [HOST] [DSP1 ] 14.630787 s: SYSTEM: Attaching to [DSP2] ... SUCCESS !!!
    [HOST] [DSP1 ] 14.658665 s: SYSTEM: Attaching to [EVE1] ... SUCCESS !!!
    [HOST] [DSP1 ] 14.678673 s: SYSTEM: Attaching to [EVE2] ... SUCCESS !!!
    [HOST] [DSP1 ] 14.678734 s: SYSTEM: Notify register to [IPU2] line 0, event 15...
    [HOST] [DSP1 ] 14.678765 s: SYSTEM: Notify register to [DSP2] line 0, event 15...
    [HOST] [DSP1 ] 14.678826 s: SYSTEM: Notify register to [EVE1] line 0, event 15...
    [HOST] [DSP1 ] 14.678856 s: SYSTEM: Notify register to [EVE2] line 0, event 15...
    [HOST] [DSP1 ] 14.678887 s: SYSTEM: Notify init done !!!
    [HOST] [DSP1 ] 14.679039 s: SYSTEM: MsgQ init done !!!
    [HOST] [DSP1 ] 14.679131 s: RpmsgInit in progress...
    [HOST] [DSP1 ] 14.679161 s: Connection established with HLOS, calling rpmsgInit
    [HOST] [DSP1 ] 14.679344 s: SYSTEM: IPC init DONE !!!
    [HOST] [DSP1 ] 14.679954 s: SYSTEM: System Common Init Done !!!
    [HOST] [DSP1 ] 14.679985 s: SYSTEM: System DSP Init in progress !!!
    [HOST] [DSP1 ] 14.680198 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1024
    [HOST] [DSP1 ] 14.680229 s: SYSTEM: Heap = LOCAL_L2 @ 0x00800000, Total size = 227264 B (221 KB), Free size = 227264 B (221 KB)
    [HOST] [DSP1 ] 14.680259 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 524288 B (512 KB), Free size = 518440 B (506 KB)
    [HOST] [DSP1 ] 14.680290 s: SYSTEM: Initializing Links !!!
    [HOST] [DSP1 ] 14.688708 s: SYSTEM: Initializing Links ... DONE !!!
    [HOST] [DSP1 ] 14.688769 s: lz4CompDecomp Init
    [HOST] [DSP1 ] 14.688769 s: [TIDL Preproc] algId= 40 ---DSP ------> DSP ------> DSP ------>
    [HOST] [DSP1 ] 14.688800 s: [TIDL Preproc] algId= 41 ---DSP ------> DSP ------> DSP ------>
    [HOST] [DSP1 ] 14.688800 s: [TIDL EmBev] algId= 39 ---DSP ------> DSP ------> DSP ------>
    [HOST] [DSP1 ] 14.688830 s: SYSTEM: System DSP Init Done !!!
    [HOST] [DSP1 ] 15.072683 s: SYSTEM: CACHE: L1P = 32 KB, L1D = 32 KB, L2 = 32 KB ... after boot !!!
    [HOST] [DSP1 ] 15.072713 s: SYSTEM: CACHE: L1P = 32 KB, L1D = 32 KB, L2 = 32 KB ... after update by APP !!!
    [HOST] [DSP2 ] 14.520130 s: ***** DSP2 Firmware build time 16:11:53 Jun 16 2020
    [HOST] [DSP2 ] 14.520191 s: *** SYSTEM: CPU Frequency <ORG = 600000000 Hz>, <NEW = 850000000 Hz>
    [HOST] [DSP2 ] 14.520405 s: SYSTEM: System Common Init in progress !!!
    [HOST] [DSP2 ] 14.520618 s: UTILS: CIO: Init Done !!!
    [HOST] [DSP2 ] 14.520649 s: SYSTEM: IPC init in progress !!!
    [HOST] [DSP2 ] 14.520679 s: SYSTEM: Attaching to [IPU2] ...
    [HOST] [DSP2 ] 14.628835 s: SYSTEM: Attaching to [IPU2] ... SUCCESS !!!
    [HOST] [DSP2 ] 14.630787 s: SYSTEM: Attaching to [DSP1] ... SUCCESS !!!
    [HOST] [DSP2 ] 14.668578 s: SYSTEM: Attaching to [EVE1] ... SUCCESS !!!
    [HOST] [DSP2 ] 14.688586 s: SYSTEM: Attaching to [EVE2] ... SUCCESS !!!
    [HOST] [DSP2 ] 14.688647 s: SYSTEM: Notify register to [IPU2] line 0, event 15...
    [HOST] [DSP2 ] 14.688708 s: SYSTEM: Notify register to [DSP1] line 0, event 15...
    [HOST] [DSP2 ] 14.688739 s: SYSTEM: Notify register to [EVE1] line 0, event 15...
    [HOST] [DSP2 ] 14.688800 s: SYSTEM: Notify register to [EVE2] line 0, event 15...
    [HOST] [DSP2 ] 14.688830 s: SYSTEM: Notify init done !!!
    [HOST] [DSP2 ] 14.688983 s: SYSTEM: MsgQ init done !!!
    [HOST] [DSP2 ] 14.689074 s: RpmsgInit in progress...
    [HOST] [DSP2 ] 14.689105 s: Connection established with HLOS, calling rpmsgInit
    [HOST] [DSP2 ] 14.689288 s: SYSTEM: IPC init DONE !!!
    [HOST] [DSP2 ] 14.689867 s: SYSTEM: System Common Init Done !!!
    [HOST] [DSP2 ] 14.689898 s: SYSTEM: System DSP Init in progress !!!
    [HOST] [DSP2 ] 14.690111 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1024
    [HOST] [DSP2 ] 14.690142 s: SYSTEM: Heap = LOCAL_L2 @ 0x00800000, Total size = 227264 B (221 KB), Free size = 227264 B (221 KB)
    [HOST] [DSP2 ] 14.690172 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 524288 B (512 KB), Free size = 518440 B (506 KB)
    [HOST] [DSP2 ] 14.690203 s: SYSTEM: Initializing Links !!!
    [HOST] [DSP2 ] 14.698590 s: SYSTEM: Initializing Links ... DONE !!!
    [HOST] [DSP2 ] 14.698651 s: lz4CompDecomp Init
    [HOST] [DSP2 ] 14.698651 s: [TIDL Preproc] algId= 40 ---DSP ------> DSP ------> DSP ------>
    [HOST] [DSP2 ] 14.698712 s: [TIDL Preproc] algId= 41 ---DSP ------> DSP ------> DSP ------>
    [HOST] [DSP2 ] 14.698712 s: [TIDL EmBev] algId= 39 ---DSP ------> DSP ------> DSP ------>
    [HOST] [DSP2 ] 14.698743 s: SYSTEM: System DSP Init Done !!!
    [HOST] [DSP2 ] 15.074696 s: SYSTEM: CACHE: L1P = 32 KB, L1D = 32 KB, L2 = 32 KB ... after boot !!!
    [HOST] [DSP2 ] 15.074696 s: SYSTEM: CACHE: L1P = 32 KB, L1D = 32 KB, L2 = 32 KB ... after update by APP !!!
    [HOST] [EVE1 ] 14.502714 s: ***** EVE Firmware build time 16:11:17 Jun 16 2020
    [HOST] [EVE1 ] 14.504605 s: *** SYSTEM: CPU Frequency <ORG = 267500000 Hz>, <NEW = 267500000 Hz>
    [HOST] [EVE1 ] 14.507442 s: SYSTEM: System Common Init in progress !!!
    [HOST] [EVE1 ] 14.509424 s: UTILS: CIO: Init Done !!!
    [HOST] [EVE1 ] 14.510309 s: SYSTEM: IPC init in progress !!!
    [HOST] [EVE1 ] 14.511224 s: SYSTEM: Attaching to [IPU2] ...
    [HOST] [EVE1 ] 14.648966 s: SYSTEM: Attaching to [IPU2] ... SUCCESS !!!
    [HOST] [EVE1 ] 14.658665 s: SYSTEM: Attaching to [DSP1] ... SUCCESS !!!
    [HOST] [EVE1 ] 14.668578 s: SYSTEM: Attaching to [DSP2] ... SUCCESS !!!
    [HOST] [EVE1 ] 14.708839 s: SYSTEM: Attaching to [EVE2] ... SUCCESS !!!
    [HOST] [EVE1 ] 14.709845 s: SYSTEM: Notify register to [IPU2] line 0, event 15...
    [HOST] [EVE1 ] 14.711126 s: SYSTEM: Notify register to [DSP1] line 0, event 15...
    [HOST] [EVE1 ] 14.712407 s: SYSTEM: Notify register to [DSP2] line 0, event 15...
    [HOST] [EVE1 ] 14.713688 s: SYSTEM: Notify register to [EVE2] line 0, event 15...
    [HOST] [EVE1 ] 14.714969 s: SYSTEM: Notify init done !!!
    [HOST] [EVE1 ] 14.716769 s: SYSTEM: MsgQ init done !!!
    [HOST] [EVE1 ] 14.717775 s: SYSTEM: IPC init DONE !!!
    [HOST] [EVE1 ] 14.730189 s: SYSTEM: System Common Init Done !!!
    [HOST] [EVE1 ] 14.731135 s: SYSTEM: System EVE Init in progress !!!
    [HOST] [EVE1 ] 14.732568 s: UTILS: DMA: HWI Create for INT8 !!!
    [HOST] [EVE1 ] 14.733697 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1024
    [HOST] [EVE1 ] 14.734886 s: SYSTEM: Heap = LOCAL_L2 @ 0x40020000, Total size = 22528 B (22 KB), Free size = 22528 B (22 KB)
    [HOST] [EVE1 ] 14.737052 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 262144 B (256 KB), Free size = 256528 B (250 KB)
    [HOST] [EVE1 ] 14.739156 s: SYSTEM: Initializing Links !!!
    [HOST] [EVE1 ] 14.818093 s: SYSTEM: Initializing Links ... DONE !!!
    [HOST] [EVE1 ] 14.819099 s: SYSTEM: System EVE Init Done !!!
    [HOST] [EVE2 ] 14.502867 s: ***** EVE Firmware build time 16:11:17 Jun 16 2020
    [HOST] [EVE2 ] 14.504758 s: *** SYSTEM: CPU Frequency <ORG = 267500000 Hz>, <NEW = 267500000 Hz>
    [HOST] [EVE2 ] 14.507503 s: SYSTEM: System Common Init in progress !!!
    [HOST] [EVE2 ] 14.509485 s: UTILS: CIO: Init Done !!!
    [HOST] [EVE2 ] 14.510370 s: SYSTEM: IPC init in progress !!!
    [HOST] [EVE2 ] 14.511285 s: SYSTEM: Attaching to [IPU2] ...
    [HOST] [EVE2 ] 14.669035 s: SYSTEM: Attaching to [IPU2] ... SUCCESS !!!
    [HOST] [EVE2 ] 14.678673 s: SYSTEM: Attaching to [DSP1] ... SUCCESS !!!
    [HOST] [EVE2 ] 14.688586 s: SYSTEM: Attaching to [DSP2] ... SUCCESS !!!
    [HOST] [EVE2 ] 14.708839 s: SYSTEM: Attaching to [EVE1] ... SUCCESS !!!
    [HOST] [EVE2 ] 14.709845 s: SYSTEM: Notify register to [IPU2] line 0, event 15...
    [HOST] [EVE2 ] 14.711126 s: SYSTEM: Notify register to [DSP1] line 0, event 15...
    [HOST] [EVE2 ] 14.712407 s: SYSTEM: Notify register to [DSP2] line 0, event 15...
    [HOST] [EVE2 ] 14.713719 s: SYSTEM: Notify register to [EVE1] line 0, event 15...
    [HOST] [EVE2 ] 14.715000 s: SYSTEM: Notify init done !!!
    [HOST] [EVE2 ] 14.716830 s: SYSTEM: MsgQ init done !!!
    [HOST] [EVE2 ] 14.717836 s: SYSTEM: IPC init DONE !!!
    [HOST] [EVE2 ] 14.730281 s: SYSTEM: System Common Init Done !!!
    [HOST] [EVE2 ] 14.731196 s: SYSTEM: System EVE Init in progress !!!
    [HOST] [EVE2 ] 14.732599 s: UTILS: DMA: HWI Create for INT8 !!!
    [HOST] [EVE2 ] 14.733758 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1024
    [HOST] [EVE2 ] 14.734978 s: SYSTEM: Heap = LOCAL_L2 @ 0x40020000, Total size = 22528 B (22 KB), Free size = 22528 B (22 KB)
    [HOST] [EVE2 ] 14.737113 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 262144 B (256 KB), Free size = 256528 B (250 KB)
    [HOST] [EVE2 ] 14.739248 s: SYSTEM: Initializing Links !!!
    [HOST] [EVE2 ] 14.818672 s: SYSTEM: Initializing Links ... DONE !!!
    [HOST] [EVE2 ] 14.819709 s: SYSTEM: System EVE Init Done !!!
    [HOST] [IPU2 ] 14.385621 s: uart_can Create_Can_Task ......
    [HOST] [IPU2 ] 14.415146 s:
    [HOST] [IPU2 ] WARNING: Device Id Does not Match
    [HOST] [IPU2 ] 14.450680 s:
    [HOST] [IPU2 ] EVE1 Image Load Completed
    [HOST] [IPU2 ] 14.486854 s:
    [HOST] [IPU2 ] EVE2 Image Load Completed
    [HOST] [IPU2 ] 14.486945 s:
    [HOST] [IPU2 ] EVE MMU configuration completed
    [HOST] [IPU2 ] 14.487037 s:
    [HOST] [IPU2 ] 14.487098 s: ***** IPU2 Firmware build time 16:13:33 Jun 16 2020
    [HOST] [IPU2 ] 14.487250 s: *** SYSTEM: CPU Frequency <ORG = 212800000 Hz>, <NEW = 212800000 Hz>
    [HOST] [IPU2 ] 14.490392 s: ************Uart Hardware Init Start*********************
    [HOST] [IPU2 ] 14.490575 s: SYSTEM: System Common Init in progress !!!
    [HOST] [IPU2 ] 14.502775 s: UTILS: CIO: Init Done !!!
    [HOST] [IPU2 ] 14.502897 s: SYSTEM: IPC init in progress !!!
    [HOST] [IPU2 ] 14.502958 s: SYSTEM: Attaching to [DSP1] ...
    [HOST] [IPU2 ] 14.626852 s: SYSTEM: Attaching to [DSP1] ... SUCCESS !!!
    [HOST] [IPU2 ] 14.628835 s: SYSTEM: Attaching to [DSP2] ... SUCCESS !!!
    [HOST] [IPU2 ] 14.648966 s: SYSTEM: Attaching to [EVE1] ... SUCCESS !!!
    [HOST] [IPU2 ] 14.669035 s: SYSTEM: Attaching to [EVE2] ... SUCCESS !!!
    [HOST] [IPU2 ] 14.669127 s: SYSTEM: Notify register to [DSP1] line 0, event 15...
    [HOST] [IPU2 ] 14.669279 s: SYSTEM: Notify register to [DSP2] line 0, event 15...
    [HOST] [IPU2 ] 14.669401 s: SYSTEM: Notify register to [EVE1] line 0, event 15...
    [HOST] [IPU2 ] 14.669523 s: SYSTEM: Notify register to [EVE2] line 0, event 15...
    [HOST] [IPU2 ] 14.669645 s: SYSTEM: Notify init done !!!
    [HOST] [IPU2 ] 14.671353 s: SYSTEM: MsgQ init done !!!
    [HOST] [IPU2 ] 14.672299 s: RpmsgInit in progress...
    [HOST] [IPU2 ] 14.672390 s: Connection established with HLOS, calling rpmsgInit
    [HOST] [IPU2 ] 14.672970 s: SYSTEM: IPC init DONE !!!
    [HOST] [IPU2 ] 14.678094 s: SYSTEM: System Common Init Done !!!
    [HOST] [IPU2 ] 14.678185 s: SYSTEM: System Init in progress !!!
    [HOST] [IPU2 ] 14.678246 s: SYSTEM: BSP Common Init in progress !!!
    [HOST] [IPU2 ] 14.678307 s: SYSTEM: BSP Common Init Done !!!
    [HOST] [IPU2 ] 14.678368 s: SYSTEM: BSP Platform Init in progress !!!
    [HOST] [IPU2 ] 14.678490 s: SYSTEM: BSP Platform Init Done !!!
    [HOST] [IPU2 ] 14.678551 s: SYSTEM: FVID2 Init in progress !!!
    [HOST] [IPU2 ] 14.678673 s: SYSTEM: FVID2 Init Done !!!
    [HOST] [IPU2 ] 14.678795 s: SYSTEM: VPS Init in progress !!!
    [HOST] [IPU2 ] 14.678856 s: SYSTEM: VPDMA Descriptor Memory Address translation ENABLED [0x80000000 -> 0x80000000]
    [HOST] [IPU2 ] 14.681937 s: *** VPDMA Firmware Loading... ***
    [HOST] [IPU2 ] 14.682059 s: VPDMA Firmware Address = 0xa035b5c0
    [HOST] [IPU2 ] 14.682150 s: VPDMA Load Address = 0x4897d004
    [HOST] [IPU2 ] 14.682242 s: VPDMA Firmware Version = 0x4d0001b8
    [HOST] [IPU2 ] 14.682333 s: VPDMA List Busy Status = 0x00000000
    [HOST] [IPU2 ] 14.682394 s: *** VPDMA Firmware Load Success ***
    [HOST] [IPU2 ] 14.682791 s: *** VPDMA Firmware Loading... ***
    [HOST] [IPU2 ] 14.682852 s: VPDMA Firmware Address = 0xa035b5c0
    [HOST] [IPU2 ] 14.682943 s: VPDMA Load Address = 0x4899d004
    [HOST] [IPU2 ] 14.683035 s: VPDMA Firmware Version = 0x4d0001b8
    [HOST] [IPU2 ] 14.683126 s: VPDMA List Busy Status = 0x00000000
    [HOST] [IPU2 ] 14.683218 s: *** VPDMA Firmware Load Success ***
    [HOST] [IPU2 ] 14.683553 s: *** VPDMA Firmware Loading... ***
    [HOST] [IPU2 ] 14.683614 s: VPDMA Firmware Address = 0xa035b5c0
    [HOST] [IPU2 ] 14.683736 s: VPDMA Load Address = 0x489dd004
    [HOST] [IPU2 ] 14.683828 s: VPDMA Firmware Version = 0x4d0001b8
    [HOST] [IPU2 ] 14.683919 s: VPDMA List Busy Status = 0x00000000
    [HOST] [IPU2 ] 14.683980 s: *** VPDMA Firmware Load Success ***
    [HOST] [IPU2 ] 14.759348 s: SYSTEM: VPS Init Done !!!
    [HOST] [IPU2 ] 14.760263 s: UTILS: DMA: HWI Create for INT25 !!!
    [HOST] [IPU2 ] 14.760507 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1024
    [HOST] [IPU2 ] 14.760599 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 262144 B (256 KB), Free size = 256040 B (250 KB)
    [HOST] [IPU2 ] 14.760843 s: SYSTEM: Heap = SR_OCMC @ 0x00000000, Total size = 0 B (0 KB), Free size = 0 B (0 KB)
    [HOST] [IPU2 ] 14.760965 s: SYSTEM: Heap = SR_DDR_CACHED @ 0x84203000, Total size = 346030080 B (330 MB), Free size = 346030080 B (330 MB)
    [HOST] [IPU2 ] 14.761178 s: SYSTEM: Heap = SR_DDR_NON_CACHED @ 0xa0100000, Total size = 1046656 B (0 MB), Free size = 954496 B (0 MB)
    [HOST] [IPU2 ] 14.761331 s: SYSTEM: Initializing Links !!!
    [HOST] [IPU2 ] 15.005703 s: malloc addr :84203000!,size:128!
    [HOST] [IPU2 ] 15.014945 s: uart_can test capturelink init ..............
    [HOST] [IPU2 ] 15.065515 s: SYSTEM: Initializing Links ... DONE !!!
    [HOST] [IPU2 ] 15.065637 s: [TIDL Preproc] algId= 11 ---IPU ------> IPU ------> IPU ------>
    [HOST] [IPU2 ] 15.107606 s: CHAINS: Application Started !!!
    [HOST] [IPU2 ] 15.121484 s: BOARD: Board Init in progress !!!
    [HOST] [IPU2 ] 15.122033 s: BOARD: Board Init Done !!!
    [20.634984] [StcW] [DBG] =========stitcher result comming...==
    [HOST] [HOST ] 27.267980 s:
    [HOST] [HOST ]
    [HOST] [HOST ] ====================
    [HOST] [HOST ] EP12 Vision SDK_3.4 Usecases
    [HOST] [HOST ] 1: Single Camera Usecases
    [HOST] [HOST ] 2: Multi-Camera LVDS Usecases
    [HOST] [HOST ] 3: Open-Compute Usecases
    [HOST] [HOST ] 5: ISS Usecases, (TDA2Px ONLY)
    [HOST] [HOST ] a: EnjoyMove 3d AVM Usecases
    [HOST] [HOST ] b: EnjoyMove BEV, test case Not Ready
    [HOST] [HOST ] g: EnjoyMove tidl SEG 384x384 Usecases
    [HOST] [HOST ] d: EnjoyMove tidl PLD 256 video input Usecases
    [HOST] [HOST ] r: EnjoyMove DVR Usecases
    [HOST] [HOST ] h: TIDL DVR/VPE file IO Usecases
    [HOST] [HOST ] o: (it's o,not zero) TIDL SSD OD Usecases
    [HOST] [HOST ] f: EnjoyMove tidl 384 sgx Freesapce Usecases
    [HOST] [HOST ] m: EnjoyMove Capture + 256 pld + bev Usecases
    [HOST] [HOST ]
    [HOST] [HOST ] p: CPU Status
    [HOST] [HOST ] i: Show IP Addr (IPU + NDK + AVB)
    [HOST] [HOST ]
    [HOST] [HOST ] s: System Settings
    [HOST] [HOST ]
    [HOST] [HOST ] x: Exit
    [HOST] [HOST ] z: Exit - AND SHUTDOWN Remote CPUs
    [HOST] [HOST ]
    [HOST] [HOST ] Enter Choice:
    [HOST] [HOST ]
    From vision_sdk/build folder, run the below commands
    make linux_clean
    make clean
    rm -rf ../binaries
    rm -rf ../links_fw/include/config
    make linux
    make linux_install
    make -s -j depend
    make -s -j
    Copy the all-new images(MLO, u-boot, kernel image, dtb, firmware,  etc) & try to run the demo application
    Gaviraju
