I am using TI's AM5728 EVM with Linux PSDK 6.03 on it. My kernel version is 4.19.94
I have configured pre-shared key based IPSEC Tunnel using StrongSwan between EVM and a local server. I have used standard cryptographic algorithms AES_256-HMAC_SHA2_SHA_256 for configuring IPSEC. I get following when I do -
root@am57xx-evm:~# ipsec statusall Status of IKE charon daemon (strongSwan 5.6.2-nistpqc, Linux 4.19.94-gbe5389fd85, armv7l): uptime: 4 seconds, since Sep 07 18:27:09 2020 malloc: sbrk 802816, mmap 0, used 414008, free 388808 worker threads: 11 of 16 idle, 5/0/0/0 working, job queue: 0/0/0/0, scheduled: 11 loaded plugins: charon aes des rc2 sha2 sha3 sha1 md5 mgf1 random nonce x509 revocation constraints pubkey pkcs1 pkcs7 pkcs8 pkcs12 pgp dnskey sshkey pem openssl fips-prf curve25519 chapoly xcbc cmac s Listening IP addresses: 192.168.139.229 Connections: 1229: 192.168.139.229...192.168.4.241 IKEv2, dpddelay=3s 1229: local: [192.168.139.229] uses pre-shared key authentication 1229: remote: [192.168.4.241] uses pre-shared key authentication 1229: child: dynamic === 40.40.40.0/24 TUNNEL, dpdaction=restart Security Associations (2 up, 0 connecting): 1229[2]: ESTABLISHED 2 seconds ago, 192.168.139.229[192.168.139.229]...192.168.4.241[192.168.4.241] 1229[2]: IKEv2 SPIs: 882989ef14977868_i d4aab913b1010cc0_r*, pre-shared key reauthentication in 8 minutes 1229[2]: IKE proposal: AES_CBC_256/HMAC_SHA2_256_128/PRF_HMAC_SHA2_256/CURVE_25519 1229{2}: INSTALLED, TUNNEL, reqid 1, ESP SPIs: c562de59_i c64dbf79_o 1229{2}: AES_CBC_256/HMAC_SHA2_256_128, 0 bytes_i, 0 bytes_o, rekeying in 78 seconds 1229{2}: 192.168.139.229/32 === 40.40.40.0/24 1229[1]: ESTABLISHED 4 seconds ago, 192.168.139.229[192.168.139.229]...192.168.4.241[192.168.4.241] 1229[1]: IKEv2 SPIs: 492dc6c699ed6e0d_i* 570dcf4001b22b06_r, pre-shared key reauthentication in 7 minutes 1229[1]: IKE proposal: AES_CBC_256/HMAC_SHA2_256_128/PRF_HMAC_SHA2_256/CURVE_25519 1229{1}: INSTALLED, TUNNEL, reqid 1, ESP SPIs: ca75a05c_i cbd2eba6_o 1229{1}: AES_CBC_256/HMAC_SHA2_256_128, 0 bytes_i, 0 bytes_o, rekeying in 91 seconds 1229{1}: 192.168.139.229/32 === 40.40.40.0/24
I am able to ping my server's IP from EVM with ping packet of different sizes (from 64 to 1600 bytes). I am also able to ping EVM's IP from my server using ping packet of standard size (64 bytes).
However, when I try to ping EVM's IP from my server with a ping packet of size greater than 150 bytes, I get kernel panic on EVM.
ON SERVER - ping -s 150 192.168.139.229 PING 192.168.139.229 (192.168.139.229): 150 data bytes
The ping does not work and it produces kernel panic on EVM. I am attaching snapshot of the prints I get on minicom attached to EVM when kernel panic occurs.
Unable to handle kernel NULL pointer dereference at virtual address 00000000 [ 141.081215] pgd = 2e42394b [ 141.083930] [00000000] *pgd=80000080004003, *pmd=00000000 [ 141.089378] Internal error: Oops: 207 [#1] PREEMPT SMP ARM [ 141.094888] Modules linked in: cbc aes_arm_bs crypto_simd cryptd hmac drbg authenc echainiv xfrm4_mode_tunnel xfrm_user xfrm4_tunnel ipcomp xfrm_ipcomp esp4 ah4 af_key xfrm_algo usbhid arc4 wl18xx wlo [ 141.165714] usbserial usbcore usb_common jailhouse(O) gdbserverproxy(O) cryptodev(O) cmemk(O) [ 141.174371] CPU: 0 PID: 0 Comm: swapper/0 Tainted: G O 4.19.94-gbe5389fd85 #1 [ 141.182842] Hardware name: Generic DRA74X (Flattened Device Tree) [ 141.188966] PC is at page_address+0xc/0xf8 [ 141.193080] LR is at omap_crypto_cleanup+0x48/0xbc [omap_crypto] [ 141.199109] pc : [<c0320af4>] lr : [<bf125048>] psr: 000b0113 [ 141.205399] sp : c1201c98 ip : c1201cc0 fp : c1201cbc [ 141.210642] r10: 00000100 r9 : 00000000 r8 : ed6f34c0 [ 141.215886] r7 : eed482e8 r6 : ed6f8ae0 r5 : c02162e8 r4 : 00000002 [ 141.222436] r3 : 00000100 r2 : 00000000 r1 : ed6f34c0 r0 : 00000000 [ 141.228989] Flags: nzcv IRQs on FIQs on Mode SVC_32 ISA ARM Segment user [ 141.236150] Control: 30c5387d Table: 943c4100 DAC: fffffffd [ 141.241918] Process swapper/0 (pid: 0, stack limit = 0x225b5dfa) [ 141.247947] Stack: (0xc1201c98 to 0xc1202000) [ 141.252318] 1c80: 00000002 c02162e8 [ 141.260530] 1ca0: ed6f8ae0 eed482e8 ed6f34c0 00000000 c1201cf4 c1201cc0 bf125048 c0320af4 [ 141.268741] 1cc0: 00000000 c053b134 00000100 ed6f8a40 c02162e8 00000000 eed482e8 c1068d40 [ 141.276951] 1ce0: 00000040 00000006 c1201d14 c1201cf8 bf1f1f84 bf12500c 0000000a 00000923 [ 141.285161] 1d00: ed6f8a60 ed6f8a64 c1201d3c c1201d18 c0232b84 bf1f1e30 00000000 c1203098 [ 141.293371] 1d20: c1203080 ffffe000 40000006 00000102 c1201d4c c1201d40 c0232c2c c0232b24 [ 141.301582] 1d40: c1201dac c1201d50 c020215c c0232c18 edcd2b40 eea65a00 eea65a68 c0c02ef0 [ 141.309791] 1d60: 00200102 c0dd0be0 c1203d00 ffffc1ea 00000009 c1068d40 c1062358 c1203080 [ 141.318001] 1d80: c1201dac c1068cfc 00000000 00000000 00000001 ee80c000 c1200000 c12081c0 [ 141.326211] 1da0: c1201dbc c1201db0 c0232f88 c0202044 c1201de4 c1201dc0 c0288e50 c0232ec0 [ 141.334421] 1dc0: c1205104 fa21200c fa212000 c1201e10 fa213000 c1200000 c1201e0c c1201de8 [ 141.342632] 1de0: c0565458 c0288df4 c0a2f678 600b0013 ffffffff c1201e44 c0a2a3b4 c1200000 [ 141.350841] 1e00: c1201e6c c1201e10 c02019f8 c0565420 eed4f180 00000002 00000000 000028b6 [ 141.359051] 1e20: eed4f180 00000000 d4110000 00000001 c0a2a3b4 00000000 c12081c0 c1201e6c [ 141.367262] 1e40: c1201e70 c1201e60 c02526e0 c0a2f678 600b0013 ffffffff c024e178 00000000 [ 141.375472] 1e60: c1201eac c1201e70 c02526e0 c0a2f65c 00000000 00000002 c1201eac c1201e88 [ 141.383683] 1e80: c024e478 eed4f180 c12081c0 d40c8a00 00000000 ed71f2c0 00000000 c0c03350 [ 141.391892] 1ea0: c1201f04 c1201eb0 c0a2a3b4 c0252678 edf5c104 eea28190 c1201ee4 c1201ec8 [ 141.400103] 1ec0: c0a2ae00 c1204c48 c128f6d0 000001fe 00000000 d7ef8d58 c1201f0c c1200000 [ 141.408314] 1ee0: c1204c7c c1204cc4 00000001 00000000 00000000 c1204c48 c1201f1c c1201f08 [ 141.416525] 1f00: c0a2ae00 c0a2a10c ffffe000 c1204c7c c1201f6c c1201f20 c025a8f0 c0a2add0 [ 141.424735] 1f20: eed4f180 00000000 c0dd2920 c12522d6 c1204cdc c1204c48 00000000 d7ef8d58 [ 141.432945] 1f40: ffffffff 000000c7 00000002 00000000 c1253e00 ffffffff c1253e00 c104ba38 [ 141.441156] 1f60: c1201f7c c1201f70 c025ad3c c025a7b0 c1201f94 c1201f80 c0a29424 c025ad28 [ 141.449367] 1f80: c1253e58 00000000 c1201ff4 c1201f98 c1000dfc c0a29360 ffffffff ffffffff [ 141.457576] 1fa0: 00000000 c10005dc ffffffff 00000000 c1204c48 c1204c40 00000000 c104ba38 [ 141.465786] 1fc0: d7eb9e06 00000000 00000000 c1000330 00000000 30c0387d 00000000 8ffdc000 [ 141.473996] 1fe0: 412fc0f2 30c5387d 00000000 c1201ff8 00000000 c10009c0 00000000 00000000 [ 141.482203] Backtrace: [ 141.484662] [<c0320ae8>] (page_address) from [<bf125048>] (omap_crypto_cleanup+0x48/0xbc [omap_crypto]) [ 141.494095] r9:00000000 r8:ed6f34c0 r7:eed482e8 r6:ed6f8ae0 r5:c02162e8 r4:00000002 [ 141.501877] [<bf125000>] (omap_crypto_cleanup [omap_crypto]) from [<bf1f1f84>] (omap_aes_done_task+0x160/0x1ec [omap_aes_driver]) [ 141.513577] r10:00000006 r9:00000040 r8:c1068d40 r7:eed482e8 r6:00000000 r5:c02162e8 [ 141.521435] r4:ed6f8a40 [ 141.523984] [<bf1f1e24>] (omap_aes_done_task [omap_aes_driver]) from [<c0232b84>] (tasklet_action_common.constprop.2+0x6c/0xf4) [ 141.535507] r5:ed6f8a64 r4:ed6f8a60 [ 141.539096] [<c0232b18>] (tasklet_action_common.constprop.2) from [<c0232c2c>] (tasklet_action+0x20/0x28) [ 141.548702] r9:00000102 r8:40000006 r7:ffffe000 r6:c1203080 r5:c1203098 r4:00000000 [ 141.556479] [<c0232c0c>] (tasklet_action) from [<c020215c>] (__do_softirq+0x124/0x28c) [ 141.564430] [<c0202038>] (__do_softirq) from [<c0232f88>] (irq_exit+0xd4/0x110) [ 141.571767] r10:c12081c0 r9:c1200000 r8:ee80c000 r7:00000001 r6:00000000 r5:00000000 [ 141.579627] r4:c1068cfc [ 141.582172] [<c0232eb4>] (irq_exit) from [<c0288e50>] (__handle_domain_irq+0x68/0xbc) [ 141.590037] [<c0288de8>] (__handle_domain_irq) from [<c0565458>] (gic_handle_irq+0x44/0x80) [ 141.598421] r9:c1200000 r8:fa213000 r7:c1201e10 r6:fa212000 r5:fa21200c r4:c1205104 [ 141.606195] [<c0565414>] (gic_handle_irq) from [<c02019f8>] (__irq_svc+0x58/0x8c) [ 141.613706] Exception stack(0xc1201e10 to 0xc1201e58) [ 141.618776] 1e00: eed4f180 00000002 00000000 000028b6 [ 141.626986] 1e20: eed4f180 00000000 d4110000 00000001 c0a2a3b4 00000000 c12081c0 c1201e6c [ 141.635195] 1e40: c1201e70 c1201e60 c02526e0 c0a2f678 600b0013 ffffffff [ 141.641836] r9:c1200000 r8:c0a2a3b4 r7:c1201e44 r6:ffffffff r5:600b0013 r4:c0a2f678 [ 141.649615] [<c0a2f650>] (_raw_spin_unlock_irq) from [<c02526e0>] (finish_task_switch+0x74/0x210) [ 141.658525] [<c025266c>] (finish_task_switch) from [<c0a2a3b4>] (__schedule+0x2b4/0x7f4) [ 141.666648] r10:c0c03350 r9:00000000 r8:ed71f2c0 r7:00000000 r6:d40c8a00 r5:c12081c0 [ 141.674507] r4:eed4f180 [ 141.677051] [<c0a2a100>] (__schedule) from [<c0a2ae00>] (schedule_idle+0x3c/0x7c) [ 141.684565] r10:c1204c48 r9:00000000 r8:00000000 r7:00000001 r6:c1204cc4 r5:c1204c7c [ 141.692423] r4:c1200000 [ 141.694968] [<c0a2adc4>] (schedule_idle) from [<c025a8f0>] (do_idle+0x14c/0x2ac) [ 141.702392] r5:c1204c7c r4:ffffe000 [ 141.705982] [<c025a7a4>] (do_idle) from [<c025ad3c>] (cpu_startup_entry+0x20/0x24) [ 141.713582] r10:c104ba38 r9:c1253e00 r8:ffffffff r7:c1253e00 r6:00000000 r5:00000002 [ 141.721440] r4:000000c7 [ 141.723983] [<c025ad1c>] (cpu_startup_entry) from [<c0a29424>] (rest_init+0xd0/0xd4) [ 141.731761] [<c0a29354>] (rest_init) from [<c1000dfc>] (start_kernel+0x448/0x470) [ 141.739271] r5:00000000 r4:c1253e58 [ 141.742860] [<c10009b4>] (start_kernel) from [<00000000>] ( (null)) [ 141.749239] Code: e89da800 e1a0c00d e92ddbf0 e24cb004 (e5903000) [ 141.755402] ---[ end trace ab846def44892ab0 ]--- [ 141.760047] Kernel panic - not syncing: Fatal exception in interrupt [ 141.766431] CPU1: stopping [ 141.769153] CPU: 1 PID: 95 Comm: systemd-journal Tainted: G D O 4.19.94-gbe5389fd85 #1 [ 141.778234] Hardware name: Generic DRA74X (Flattened Device Tree) [ 141.784349] Backtrace: [ 141.786809] [<c020ca34>] (dump_backtrace) from [<c020cd6c>] (show_stack+0x18/0x1c) [ 141.794410] r7:ed53beb0 r6:60000193 r5:00000000 r4:c12506dc [ 141.800095] [<c020cd54>] (show_stack) from [<c0a15124>] (dump_stack+0x9c/0xb0) [ 141.807350] [<c0a15088>] (dump_stack) from [<c020f6b8>] (handle_IPI+0x1b0/0x1dc) [ 141.814776] r7:ed53beb0 r6:00000001 r5:00000000 r4:c1068cfc [ 141.820459] [<c020f508>] (handle_IPI) from [<c0565490>] (gic_handle_irq+0x7c/0x80) [ 141.828058] r6:fa212000 r5:fa21200c r4:c1205104 [ 141.832694] [<c0565414>] (gic_handle_irq) from [<c02019f8>] (__irq_svc+0x58/0x8c) [ 141.840205] Exception stack(0xed53beb0 to 0xed53bef8) [ 141.845275] bea0: ee803c00 edcc9000 edcc9010 c1205024 [ 141.853487] bec0: edcc9000 c1204c48 ee803c00 edcc9000 fffff000 ed53a000 00000142 ed53bf2c [ 141.861696] bee0: ed53bf30 ed53bf00 c0367628 c0343064 60000013 ffffffff [ 141.868337] r9:ed53a000 r8:fffff000 r7:ed53bee4 r6:ffffffff r5:60000013 r4:c0343064 [ 141.876116] [<c0342f54>] (kmem_cache_free) from [<c0367628>] (putname+0x60/0x68) [ 141.883540] r8:fffff000 r7:edcc9000 r6:fffffffe r5:c1204c48 r4:edcc9000 [ 141.890270] [<c03675c8>] (putname) from [<c0354c58>] (do_sys_open+0x12c/0x1f4) [ 141.897520] r5:c1204c48 r4:fffffffe [ 141.901109] [<c0354b2c>] (do_sys_open) from [<c0354d58>] (sys_openat+0x14/0x18) [ 141.908447] r10:00000142 r9:ed53a000 r8:c0201204 r7:00000142 r6:bebd8318 r5:ffffffff [ 141.916306] r4:00470180 [ 141.918849] [<c0354d44>] (sys_openat) from [<c0201000>] (ret_fast_syscall+0x0/0x4c) [ 141.926535] Exception stack(0xed53bfa8 to 0xed53bff0) [ 141.931606] bfa0: 00470180 ffffffff ffffff9c 00470180 000a0842 000001a0 [ 141.939817] bfc0: 00470180 ffffffff bebd8318 00000142 b6ed31e0 0044f8b0 00000001 bebd82e0 [ 141.948027] bfe0: 00000000 bebd8140 b6f052b0 b6d2c6dc [ 141.953103] ---[ end Kernel panic - not syncing: Fatal exception in interrupt ]---
I have no idea about what actually is causing this kernel panic. Also, I have little experience on how to debug a kernel panic. Can you help me out?
Kindly acknowledge and revert.
Thanks & Regards,
Devashish
