i need to run IMGLIB on DSP and Linux on ARM side how can i do that any suggestions...
if i do program using IMGLIB and compiling it for DSP how to run those executable on ARM while it running Linux what changes i should do...
Prabhu.M
Prabhu.M
The best way to do it would be using C6accel. This allows you to make a remote procedure call from the ARM to the DSP. Performance will be much better that way. Trying to compile IMGLIB for the ARM will result in very poor performance.
Thanks Griffis..
i follow your suggestions let you know how it works if any problems i will ask you...
C6accel is not supported by TI in their new ezsdk releases. Is there any alternative for doing this other than c6accel.
Please explain how function calls from ARM to C674x are done if the C6accel is not available.
Mechi
You can still use C6accel, but TI is no longer actively developing the product or answering questions related to its usage.
