Part Number: TDA2PXEVM
Hi Team,
I am working on vision SDK v3.07.
I am trying to port the logo usecase from rtos to hlos.
The following is the usecase where, NullSource_m4 -> Display is link added for displaying the logo
NullSource (A15) -> Decode -> VPE -> Sync -> Dup -> Gate_Alg1 -> Alg1 (DSP1) -> Display_HDMI
Dup -> Gate_Alg2 -> Alg2 (DSP1) -> SgxFrmcpy (A15) -> Display_LCD
Dup -> Alg3 (DSP1)
//Dynamic overlays
//ssdOverlayLink (IPU1_0) -> Display_Grpx
I am facing a segmentation fault on reaching the fillSrcBuf function
[HOST] [IPU1-0] 49.845757 s: IPC_IN_1 : Create in progress !!! [HOST] [IPU1-0] 49.846916 s: IPC_IN_1 : Create Done !!! [HOST] [IPU1-0] 49.847312 s: DISPLAY: Create in progress !!! [HOST] [IPU1-0] 49.847953 s: DISPLAY: Create Done !!! [HOST] [DSP1 ] 49.845299 s: ALGORITHM: Create Done (algId = 44) !!! [HOST] [DSP1 ] 49.845452 s: IPC_OUT_0 : Create in progress !!! [HOST] [DSP1 ] 49.845513 s: IPC_OUT_0 : Create Done !!! ****** Segmentation fault caught .... Faulty address is (nil), called from 0x14cad Totally Obtained 0 stack frames. signal number =11 Signal number = 11, Signal errno = 0 SI code = 1 (Address not mapped to object) Fault addr = (nil) [bt] Execution path:
Below is the gdb prints,
Single stepping until exit from function fillSrcBuf, which has no line number information. [HOST] [IPU1-0] 45.669279 s: DISPLAY: Create in progress !!! [HOST] [IPU1-0] 45.669859 s: DISPLAY: Create Done !!! [HOST] [HOST ] 45.670164 s: Calling fillSrcBuf() [HOST] [HOST ] 47.925974 s: Inside fillSrcBuf() [HOST] [HOST ] 47.967455 s: sizeof(NullSrcLink_GetBufInfoParams) : 1a8 [HOST] [HOST ] 47.980174 s: &getBufInfoPrm: 0xbeffcf30 [HOST] [HOST ] 47.993320 s: ptr: 0xbeffcf30 [HOST] [HOST ] 48.006130 s: Address of pBuffer after OSA_memVirt2Phys: (nil) [HOST] [HOST ] 48.016683 s: Inside fillSrcBuf():After System_linkControl() [HOST] [HOST ] 48.031629 s: Inside fillSrcBuf():After UTILS_assert() [HOST] [HOST ] 48.082779 s: pBuffer: 0xbeffcf38 [HOST] [HOST ] 48.102604 s: pBuffer->payload: 0x9b0446b0 [HOST] [HOST ] 48.113066 s: pVideoFrame: 0x26c4 [HOST] [HOST ] 48.125907 s: pVideoFrame: 0x9b0446b0 [HOST] [HOST ] 48.138717 s: pVideoFrame->bufAddr[0]=(nil) [HOST] [HOST ] 48.144634 s: dummy memset () at ../sysdeps/arm/memset.S:29 29 ../sysdeps/arm/memset.S: No such file or directory.
Below is the snippet of the code
Void fillSrcBuf(SVS_3DObj *pUcObj)
Int32 status;
UInt32 ht, bufCnt, logoStartX, logoStartY, offset;
UInt8 *srcAddr, *dstAddr;
NullSrcLink_GetBufInfoParams getBufInfoPrm;
System_Buffer *pBuffer;
System_VideoFrameBuffer *pVideoFrame;
float* ptr = NULL;
Vps_printf(" Inside fillSrcBuf() ");
* Get the Null source buffer info
getBufInfoPrm.chId = 0U;
status = System_linkControl(
pUcObj->NullSource_m4LinkID,
NULL_SRC_LINK_CMD_GET_BUF_INFO,
&getBufInfoPrm,
sizeof(NullSrcLink_GetBufInfoParams),
TRUE);
Vps_printf(" sizeof(NullSrcLink_GetBufInfoParams) : %x", sizeof(NullSrcLink_GetBufInfoParams));
Vps_printf("&getBufInfoPrm: %p",&getBufInfoPrm);
ptr = &getBufInfoPrm;
Vps_printf("ptr: %p",ptr);
//pBuffer = OSA_memVirt2Phys((unsigned int)ptr, OSA_MEM_REGION_TYPE_AUTO);
Vps_printf("Address of pBuffer after OSA_memVirt2Phys: %p",pBuffer);
Vps_printf(" Inside fillSrcBuf():After System_linkControl() ");
UTILS_assert (SYSTEM_LINK_STATUS_SOK == status);
Vps_printf(" Inside fillSrcBuf():After UTILS_assert() "); //done
//pBuffer->hlosTranslationDisable = 0U;
//Vps_printf("pBuffer->hlosTranslationDisable = %lu", pBuffer->hlosTranslationDisable);
for (bufCnt = 0;bufCnt < getBufInfoPrm.numBuf;bufCnt ++)
pBuffer = &getBufInfoPrm.buffer[bufCnt];
//pBuffer = (void *) OSA_memVirt2Phys((unsigned int) pBuffer, OSA_MEM_REGION_TYPE_AUTO);
Vps_printf("pBuffer: %p",pBuffer);
Vps_printf("pBuffer->payload: %p",pBuffer->payload);
Vps_printf("pVideoFrame: %p",pVideoFrame);
pVideoFrame = pBuffer->payload;
Vps_printf("pVideoFrame->bufAddr[0]=%p", pVideoFrame->bufAddr[0]);
dummy_func();
memset(
pVideoFrame->bufAddr[0],
0xFF,
(INPUT_FRAME_RESOLUTION_WIDTH * INPUT_FRAME_RESOLUTION_HEIGHT));
Vps_printf("pVideoFrame->bufAddr[1]=%p", pVideoFrame->bufAddr[1]);
dummy_func();
memset(
pVideoFrame->bufAddr[1],
0x80,
(INPUT_FRAME_RESOLUTION_WIDTH * INPUT_FRAME_RESOLUTION_HEIGHT/2));
Vps_printf("Both memset done");
dummy_func();
/* copy TI logo */
logoStartX = (INPUT_FRAME_RESOLUTION_WIDTH - TILOGO_WIDTH)/2;
logoStartY = (INPUT_FRAME_RESOLUTION_HEIGHT - TILOGO_HEIGHT)/2;
offset = (logoStartY * INPUT_FRAME_RESOLUTION_WIDTH) + logoStartX;
dstAddr = (UInt8*)((UInt32)pVideoFrame->bufAddr[0] + offset);
srcAddr = tiLogo_640_224;
for(ht = 0;ht < TILOGO_HEIGHT;ht++)
memcpy(dstAddr, srcAddr, TILOGO_WIDTH);
dstAddr += INPUT_FRAME_RESOLUTION_WIDTH;
srcAddr += TILOGO_WIDTH;
What could be going wrong here ?
Padmesh
