Compiler/TDA2SX: DSP starting stopped by XDC ASSERT
Part Number: TDA2SX
Other Parts Discussed in Thread: DRA742, DRA752
Hi TI team:
We are using VSDK 3.07.
Now we replace the memory chip from 1.5G to 1G, and just change the dra7-evm-infoadas.dts and mem_segment_definition_linux.xs to move section memory of DSP(No overlap with other core memory usage ).
When we start the firmware, each core works well except DSP.
How to solve this problem?
ERROR log of BIOS core:
[HOST  ]     12.415360 s:  SYSTEM: System A15 Init in progress !!!
[DSP1  ]     11.044958 s:  ***** DSP1 Firmware build time 11:49:26 Sep 17 2020
[DSP1  ]     11.045019 s:  *** SYSTEM: CPU Frequency <ORG = 600000000 Hz>, <NEW = 750000000 Hz>
[DSP1  ]     11.045263 s:  SYSTEM: System Common Init in progress !!!
[DSP1  ]     11.045507 s:  UTILS: CIO: Init Done !!!
[DSP1  ]     11.045537 s:  SYSTEM: IPC init in progress !!!
[DSP1  ]     11.045568 s:  SYSTEM: Attaching to [IPU2] ...
[DSP1  ]     11.704355 s:  SYSTEM: Attaching to [IPU2] ... SUCCESS !!!
[DSP1  ]     11.709296 s:  SYSTEM: Attaching to [DSP2] ... SUCCESS !!!
[DSP1  ]     11.730555 s:  SYSTEM: Attaching to [EVE1] ... SUCCESS !!!
[DSP1  ]     11.750564 s:  SYSTEM: Attaching to [EVE2] ... SUCCESS !!!
[DSP1  ]     11.770633 s:  SYSTEM: Attaching to [EVE3] ... SUCCESS !!!
[DSP1  ]     11.790550 s:  SYSTEM: Attaching to [EVE4] ... SUCCESS !!!
[DSP1  ]     11.790581 s:  SYSTEM: Notify register to [IPU2] line 0, event 15...
[DSP1  ]     11.790642 s:  SYSTEM: Notify register to [DSP2] line 0, event 15...
[DSP1  ]     11.790672 s:  SYSTEM: Notify register to [EVE1] line 0, event 15...
[DSP1  ]     11.790703 s:  SYSTEM: Notify register to [EVE2] line 0, event 15...
[DSP1  ]     11.790764 s:  SYSTEM: Notify register to [EVE3] line 0, event 15...
[DSP1  ]     11.790794 s:  SYSTEM: Notify register to [EVE4] line 0, event 15...
[DSP1  ]     11.790825 s:  SYSTEM: Notify init done !!!
[DSP1  ]     11.791008 s:  SYSTEM: MsgQ init done !!!
[DSP1  ]     11.791099 s: RpmsgInit in progress...
[DSP1  ]     11.791130 s: Connection established with HLOS, calling rpmsgInit
[DSP1  ]     11.791221 s:
[DSP1  ]     11.791252 s:  ### XDC ASSERT - ERROR CALLBACK START ###
[DSP1  ]     11.791343 s: assertion failure
[DSP1  ]     11.791374 s:
[DSP1  ]     11.791374 s:  ### XDC ASSERT - ERROR CALLBACK END ###
[DSP1  ]     11.791404 s:
[DSP2  ]     11.137802 s: ***** DSP2 Firmware build time 11:49:28 Sep 17 2020
[DSP2  ]     11.137894 s:  *** SYSTEM: CPU Frequency <ORG = 600000000 Hz>, <NEW = 750000000 Hz>
[DSP2  ]     11.138138 s:  SYSTEM: System Common Init in progress !!!
[DSP2  ]     11.138382 s:  UTILS: CIO: Init Done !!!
[DSP2  ]     11.138412 s:  SYSTEM: IPC init in progress !!!
[DSP2  ]     11.138443 s:  SYSTEM: Attaching to [IPU2] ...
[DSP2  ]     11.707619 s:  SYSTEM: Attaching to [IPU2] ... SUCCESS !!!
[DSP2  ]     11.709296 s:  SYSTEM: Attaching to [DSP1] ... SUCCESS !!!
[DSP2  ]     11.740468 s:  SYSTEM: Attaching to [EVE1] ... SUCCESS !!!
[DSP2  ]     11.760477 s:  SYSTEM: Attaching to [EVE2] ... SUCCESS !!!
[DSP2  ]     11.780485 s:  SYSTEM: Attaching to [EVE3] ... SUCCESS !!!
[DSP2  ]     11.800494 s:  SYSTEM: Attaching to [EVE4] ... SUCCESS !!!
[DSP2  ]     11.800524 s:  SYSTEM: Notify register to [IPU2] line 0, event 15...
[DSP2  ]     11.800585 s:  SYSTEM: Notify register to [DSP1] line 0, event 15...
[DSP2  ]     11.800616 s:  SYSTEM: Notify register to [EVE1] line 0, event 15...
[DSP2  ]     11.800677 s:  SYSTEM: Notify register to [EVE2] line 0, event 15...
[DSP2  ]     11.800707 s:  SYSTEM: Notify register to [EVE3] line 0, event 15...
[DSP2  ]     11.800738 s:  SYSTEM: Notify register to [EVE4] line 0, event 15...
[DSP2  ]     11.800768 s:  SYSTEM: Notify init done !!!
[DSP2  ]     11.800951 s:  SYSTEM: MsgQ init done !!!
[DSP2  ]     11.801043 s: RpmsgInit in progress...
[DSP2  ]     11.801073 s: Connection established with HLOS, calling rpmsgInit
[DSP2  ]     11.801165 s:
[DSP2  ]     11.801195 s:  ### XDC ASSERT - ERROR CALLBACK START ###
[DSP2  ]     11.801226 s:
[DSP2  ]     11.801317 s: assertion failure
[DSP2  ]     11.801348 s:  ### XDC ASSERT - ERROR CALLBACK END ###
[EVE1  ]     11.702891 s:  ***** EVE Firmware build time 11:47:41 Sep 17 2020
[EVE1  ]     11.704843 s:  *** SYSTEM: CPU Frequency <ORG = 267500000 Hz>, <NEW = 325000000 Hz>
[EVE1  ]     11.708503 s:  SYSTEM: System Common Init in progress !!!
[EVE1  ]     11.711279 s:  UTILS: CIO: Init Done !!!
[EVE1  ]     11.712346 s:  SYSTEM: IPC init in progress !!!
[EVE1  ]     11.713383 s:  SYSTEM: Attaching to [IPU2] ...
[EVE1  ]     11.720856 s:  SYSTEM: Attaching to [IPU2] ... SUCCESS !!!
[EVE1  ]     11.730555 s:  SYSTEM: Attaching to [DSP1] ... SUCCESS !!!
[EVE1  ]     11.740468 s:  SYSTEM: Attaching to [DSP2] ... SUCCESS !!!
[EVE1  ]     11.780668 s:  SYSTEM: Attaching to [EVE2] ... SUCCESS !!!
[EVE1  ]     11.810589 s:  SYSTEM: Attaching to [EVE3] ... SUCCESS !!!
[EVE1  ]     11.840602 s:  SYSTEM: Attaching to [EVE4] ... SUCCESS !!!
[EVE1  ]     11.841670 s:  SYSTEM: Notify register to [IPU2] line 0, event 15...
[EVE1  ]     11.842951 s:  SYSTEM: Notify register to [DSP1] line 0, event 15...
[EVE1  ]     11.844232 s:  SYSTEM: Notify register to [DSP2] line 0, event 15...
[EVE1  ]     11.845482 s:  SYSTEM: Notify register to [EVE2] line 0, event 15...
[EVE1  ]     11.846763 s:  SYSTEM: Notify register to [EVE3] line 0, event 15...
[EVE1  ]     11.848014 s:  SYSTEM: Notify register to [EVE4] line 0, event 15...
[EVE1  ]     11.849386 s:  SYSTEM: Notify init done !!!
[EVE1  ]     11.851216 s:  SYSTEM: MsgQ init done !!!
[EVE1  ]     11.852101 s:  SYSTEM: IPC init DONE !!!
[EVE1  ]     11.865521 s:  SYSTEM: System Common Init Done !!!
[EVE1  ]     11.866528 s:  SYSTEM: System EVE Init in progress !!!
[EVE1  ]     11.867992 s:  UTILS: DMA: HWI Create for INT8 !!!
[EVE1  ]     11.869181 s:  SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1024
[EVE1  ]     11.870646 s:  SYSTEM: Heap = LOCAL_L2             @ 0x40020000, Total size = 22528 B (22 KB), Free size = 22528 B (22 KB)
[EVE1  ]     11.873055 s:  SYSTEM: Heap = LOCAL_DDR            @ 0x00000000, Total size = 262144 B (256 KB), Free size = 254320 B (248 KB)
[EVE1  ]     11.875221 s:  SYSTEM: Initializing Links !!!
[EVE1  ]     11.970658 s:  SYSTEM: Initializing Links ... DONE !!!
[EVE1  ]     11.971878 s:  SYSTEM: System EVE Init Done !!!
Normal key log of linux kernel:
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 4.4.84+ (zx5@ubuntu) (gcc version 5.3.1 20160113 (Linaro GCC 5.3-2016.02) ) #1 SMP PREEMPT Tue Sep 15 13:45:48 CST 2020
[    0.000000] CPU: ARMv7 Processor [412fc0f2] revision 2 (ARMv7), cr=30c5387d
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
[    0.000000] Machine model: TI DRA742
[    0.000000] Reserved memory: created DMA memory pool at 0x0000000040300000, size 3 MiB
[    0.000000] Reserved memory: initialized node cmem@40300000, compatible id shared-dma-pool
[    0.000000] Reserved memory: regions without no-map are not yet supported
[    0.000000] Reserved memory: created CMA memory pool at 0x000000009d000000, size 48 MiB
[    0.000000] Reserved memory: initialized node ipu2_cma@95800000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created CMA memory pool at 0x00000000a6000000, size 48 MiB
[    0.000000] Reserved memory: initialized node dsp1_cma@99000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created CMA memory pool at 0x00000000a9000000, size 32 MiB
[    0.000000] Reserved memory: initialized node dsp2_cma@9f000000, compatible id shared-dma-pool
[    0.000000] cma: Reserved 64 MiB at 0x00000000bbc00000
[    0.000000] Forcing write-allocate cache policy for SMP
[    0.000000] Memory policy: Data cache writealloc
[    0.000000] OMAP4: Map 0x00000000bfd00000 to fe600000 for dram barrier
[    0.000000] On node 0 totalpages: 261376
[    0.000000] free_area_init_node: node 0, pgdat c0638440, node_mem_map ef7b2000
[    0.000000]   DMA zone: 1536 pages used for memmap
[    0.000000]   DMA zone: 0 pages reserved
[    0.000000]   DMA zone: 196608 pages, LIFO batch:31
[    0.000000]   HighMem zone: 64768 pages, LIFO batch:15
[    0.000000] DRA752 ES2.0
[    0.000000] PERCPU: Embedded 12 pages/cpu @ef742000 s17536 r8192 d23424 u49152
Thanks!
  • Replace the memory chip
