Hello everyone:
I want to use Notify send information from core0 to core1 on my EVM6678L board.
I write a simple code: Core 1 registerEvent : status=Notify_registerEvent(0, 0, EVENTID,(Notify_FnNotifyCbck)cbFxn, NULL), and cor 0 send event :status=Notify_sendEvent(1, 0, EVENTID, 0, TRUE)
,I always get the status back from core0 : event has no registered callback,I can not find out the problem,
and I try other methods:
- Core 1 status=Notify_registerEvent(1, 0, EVENTID,(Notify_FnNotifyCbck)cbFxn, NULL) Core 0 status=Notify_sendEvent(1, 0, EVENTID, 0, TRUE)
- Core 1 status=Notify_registerEvent(1, 0, EVENTID,(Notify_FnNotifyCbck)cbFxn, NULL) Core 0 status=Notify_sendEvent(0, 0, EVENTID, 0, TRUE)
- Core 1 status=Notify_registerEvent(0, 0, EVENTID,(Notify_FnNotifyCbck)cbFxn, NULL) Core 0 status=Notify_sendEvent(1, 0, EVENTID, 0, TRUE)
- Core 1 status=Notify_registerEvent(0, 0, EVENTID,(Notify_FnNotifyCbck)cbFxn, NULL) Core 0 status=Notify_sendEvent(0, 0, EVENTID, 0, TRUE)
I get the same result : event has no registered callback!
I have read the question :e2e.ti.com/support/processors/f/791/p/661148/2429976?tisearch=e2e-quicksearch&keymatch=Ipc.procSync#2429976)
and have read :Processor sdk rtos 06_03_00_106 ->4.4.6.8 Notify Module and->4.4.7.2 MultiProc Module
I think the code is ok,Can any one give some suggestion ?
code :
#include "EVM_init.h"
uint32_t maxFlashes = 3;
uint32_t EVENTID = 0;
UInt16 srcProc, dstProc;
Void cbFxn(UInt16 procId, UInt16 lineId, UInt32 eventId, UArg arg, UInt32 payload)
Semaphore_post(semHandle);
void ledPlayTask (void)
Int status;
uint32_t coreId;
coreId = CSL_chipReadReg (CSL_CHIP_DNUM);
switch(coreId)
case 0:
platform_write("core %d is working\n",coreId);
while(Ipc_attach(1))
Task_sleep(1);
status = Notify_sendEvent(1, 0, EVENTID, 0, TRUE);//core0 sendEvent
my_print_status_for_Notify_sendEvent(status);
break;
case 1:
while(Ipc_attach(0))
Task_sleep(1);
Semaphore_pend(semHandle,BIOS_WAIT_FOREVER);
platform_write("Core0 to core1 Notify event successfully!\n",coreId);
break;
Int main()
Int status;
platform_write("*****************************\n");
status = Ipc_start();
if (status < 0) {
System_abort("Ipc_start failed\n");
if(MultiProc_self()==1)//Core1 register event callback function:
status = Notify_registerEvent(0, 0, EVENTID,(Notify_FnNotifyCbck)cbFxn, NULL);
if (status < 0) {
System_abort("Notify_registerEvent failed\n");
else
platform_write("Core 1 ,registerEvent 0 \n",);
BIOS_start();
return(0);
and the confige .cfg:
var Defaults = xdc.useModule('xdc.runtime.Defaults');
var Diags = xdc.useModule('xdc.runtime.Diags');
var Error = xdc.useModule('xdc.runtime.Error');
var Log = xdc.useModule('xdc.runtime.Log');
var LoggerBuf = xdc.useModule('xdc.runtime.LoggerBuf');
var Main = xdc.useModule('xdc.runtime.Main');
var Memory = xdc.useModule('xdc.runtime.Memory')
var SysMin = xdc.useModule('xdc.runtime.SysMin');
var System = xdc.useModule('xdc.runtime.System');
var Text = xdc.useModule('xdc.runtime.Text');
var Startup= xdc.useModule('xdc.runtime.Startup');
var Csl = xdc.loadPackage('ti.csl');
var BIOS = xdc.useModule('ti.sysbios.BIOS');
var Clock = xdc.useModule('ti.sysbios.knl.Clock');
var Swi = xdc.useModule('ti.sysbios.knl.Swi');
var Task = xdc.useModule('ti.sysbios.knl.Task');
var Semaphore = xdc.useModule('ti.sysbios.knl.Semaphore');
var Hwi = xdc.useModule('ti.sysbios.hal.Hwi');
//Program.argSize = 0x0;
Defaults.common$.diags_ASSERT = Diags.ALWAYS_OFF;
Defaults.common$.namedModule = false;
System.maxAtexitHandlers = 4;
Error.raiseHook = null;
Text.isLoaded = false;
SysMin.flushAtExit = false;
BIOS.heapSize = 0x8000;
BIOS.libType = BIOS.LibType_Custom;
Program.stack = 0x2000;
SysMin.bufSize = 0x200;
var loggerBufParams = new LoggerBuf.Params();
loggerBufParams.numEntries = 16;
var logger0 = LoggerBuf.create(loggerBufParams);
Defaults.common$.logger = logger0;
Main.common$.diags_INFO = Diags.ALWAYS_ON;
System.SupportProxy = SysMin;
Program.sectMap[".const"] = "DDR3";
Program.sectMap[".text"] = "DDR3";
Program.sectMap[".code"] = "DDR3";
Program.sectMap[".data"] = "DDR3";
Program.sectMap[".sysmem"] = "DDR3";
Program.sectMap[".sharedVar"] = "DDR3";
Program.sectMap["platform_lib"] = "DDR3";
var SHAREDMEM = 0x80000000;
var SHAREDMEMSIZE = 0x00200000;
var SharedRegion = xdc.useModule('ti.sdo.ipc.SharedRegion');
SharedRegion.setEntryMeta(0,
{ base: SHAREDMEM,
len: SHAREDMEMSIZE,
ownerProcId: 0,
isValid: true,
Startup.firstFxns.$add('&EVM_init');
var tskNdkMainThread = Task.create("&ledPlayTask");
tskNdkMainThread.stackSize = 0x2000;
tskNdkMainThread.priority = 0x5;
tskNdkMainThread.instance.name = "ledPlayTask";
Program.global.semHandle = Semaphore.create(0);
//MessageQ:
var Ipc = xdc.useModule('ti.sdo.ipc.Ipc');
var MessageQ = xdc.useModule('ti.sdo.ipc.MessageQ');
var MultiProc = xdc.useModule('ti.sdo.utils.MultiProc');
//Program.global.procName = "CORE0";
var nameList = MultiProc.getDeviceProcNames();
MultiProc.setConfig(null, nameList);
/* To avoid wasting shared memory for MessageQ transports */
for (var i = 0; i < MultiProc.numProcessors; i++) {
Ipc.setEntryMeta({
remoteProcId: i,
setupMessageQ: false,
var Notify = xdc.useModule('ti.sdo.ipc.Notify');
/* Synchronize all processors (this will be done in Ipc_start) */
//Ipc.procSync = Ipc.ProcSync_ALL;
Ipc.procSync = Ipc.ProcSync_PAIR;
output:
[C66xx_0] core 0 is working
[C66xx_1] Core 1 ,registerEvent 0
core 1 is working
[C66xx_0] event has no registered callback
If I use Core 1 to send and Core 1 to receive ,it is ok:
Core 1 status=Notify_registerEvent(1, 0, EVENTID,(Notify_FnNotifyCbck)cbFxn, NULL) Core 1 status=Notify_sendEvent(1, 0, EVENTID, 0, TRUE)
I get the right result : event successfully sent! But If different core ,it does not work.
I use CCS10.1 ,ipc_3_50_04_08 ,pdk_C6678_1_1_2_5,bios_6_76_03_01
uint8_t *Osal_platformMalloc (uint32_t num_bytes, uint32_t alignment)
return malloc(num_bytes);
void Osal_platformFree (uint8_t *dataPtr, uint32_t num_bytes)
if (dataPtr)
free(dataPtr);
void Osal_platformSpiCsEnter(void)
while ((CSL_semAcquireDirect (PLATFORM_SPI_HW_SEM)) == 0);
return;
void Osal_platformSpiCsExit (void)
CSL_semReleaseSemaphore (PLATFORM_SPI_HW_SEM);
return;
uint32_t convert_CoreLocal2GlobalAddr (uint32_t addr)
uint32_t coreNum;
coreNum = CSL_chipReadReg(CSL_CHIP_DNUM);
return ((1 << 28) | (coreNum << 24) | (addr & 0x00ffffff));
void EVM_init()
platform_init_flags sFlags;
platform_init_config sConfig;
int32_t pform_status;
platform_uart_init();
platform_uart_set_baudrate(115200);
(void) platform_write_configure(PLATFORM_WRITE_ALL);
memset( (void *) &sFlags, 0, sizeof(platform_init_flags));
memset( (void *) &sConfig, 0, sizeof(platform_init_config));
sFlags.pll = 0; /* PLLs for clocking */
sFlags.ddr = 0; /* External memory */
//sFlags.tcsl = 1; /* Time stamp counter */
sFlags.phy = 0; /* Ethernet */
sFlags.ecc = 0; /* Memory ECC */
sConfig.pllm = 0; /* Use libraries default clock divisor */
pform_status = platform_init(&sFlags, &sConfig);
if (pform_status != Platform_EOK)
platform_write("Platform failed to initialize. Error code %d \n", pform_status);
platform_write("We will die in an infinite loop... \n");
while (1)
(void) platform_led(1, PLATFORM_LED_ON, PLATFORM_USER_LED_CLASS);
(void) platform_delay(50000);
(void) platform_led(1, PLATFORM_LED_OFF, PLATFORM_USER_LED_CLASS);
return;
Void my_print_status_for_Notify_sendEvent(Int status)
switch(status)
case Notify_E_EVTNOTREGISTERED :
platform_write("event has no registered callback \n");
break;
case Notify_E_NOTINITIALIZED :
platform_write("remote driver has not yet been initialized \n");
break;
case Notify_E_EVTDISABLED :
platform_write("remote event is disabled \n");
break;
case Notify_E_TIMEOUT :
platform_write("timeout occurred (when waitClear is TRUE) \n");
break;
case Notify_S_SUCCESS :
platform_write(" event successfully sent \n");
break;
default :
platform_write(" What? \n");
break;
