Part Number: AM4378
AM4378 has only 6 hardware UART, but under Linux dev has ttyS0-ttyS9, and ttyS6-9 can't be used, otherwise will result in hang.
What is the ttyS6-9 stands for?
Part Number: AM4378
Tony,
/dev/ttyS0~9 are pre-allocated device node by the serial driver, some of them may not associate to a real UART port, which is defined by the device tree. To know which /dev/ttyS<x> node can be used, you can check the procfs:
# cat /proc/tty/driver/serial
