Shutdown issue with Linux Processor SDK
Part Number: TMDX654GPEVM
Shutdown or reboot failed on TMDX654GPEVM (SR1.0) with Linux Processor SDK v07.00.01.
In case of shutdown (shutdown -h now), it fails with the following message.
 ---[ end Kernel panic - not syncing: Attempted to kill init! exitcode=0x00000000 ]---
In the case of reboot (shutdown -r now), it seems to run to the end but it is not reset.
Each log from power-on to failure is attached here:
U-Boot SPL 2020.01-gf9b0d030d3 (Aug 10 2020 - 17:47:39 +0000)
SYSFW ABI: 3.0 (firmware rev 0x0014 '20.04.1-v2020.04a (Terrific Lla')
Trying to boot from MMC2
Starting ATF on ARM64 core...
NOTICE:  BL31: v2.3():07.00.00.005-dirty
NOTICE:  BL31: Built : 17:03:45, Aug 10 2020
U-Boot SPL 2020.01-gf9b0d030d3 (Aug 10 2020 - 17:11:07 +0000)
Detected: SER-PCIEUSBEVM rev E3
U-Boot 2020.01-gf9b0d030d3 (Aug 10 2020 - 17:11:07 +0000)
SoC:   AM65X SR1.0
Model: Texas Instruments AM654 Base Board
Board: AM6-COMPROCEVM rev E3
DRAM:  4 GiB
MMC:   sdhci@4f80000: 0, sdhci@04FA0000: 1
Loading Environment from MMC... OK
In:    serial
Out:   serial
Err:   serial
Net:
Warning: cpsw_nuss@046000000 using MAC address from ROM
eth0: cpsw_nuss@046000000, eth1: pruss2_eth
Hit any key to stop autoboot:  2  1  0
switch to partitions #0, OK
mmc1 is current device
SD/MMC found on device 1
1011 bytes read in 9 ms (109.4 KiB/s)
Loaded env from uEnv.txt
Importing environment from mmc1 ...
Running uenvcmd ...
16654344 bytes read in 1389 ms (11.4 MiB/s)
67584 bytes read in 14 ms (4.6 MiB/s)
757 bytes read in 9 ms (82 KiB/s)
## Flattened Device Tree blob at 82000000
   Booting using the fdt blob at 0x82000000
   Loading Device Tree to 00000000fddb1000, end 00000000fdec4fff ... OK
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[    0.000000] Linux version 5.4.40-g66cf445b76 (oe-user@oe-host) (gcc version 9.2.1 20191025 (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10))) #1 SMP PREEMPT Mon Aug 10 16:54:04 UTC 2020
[    0.000000] Machine model: Texas Instruments AM654 Base Board
[    0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '')
[    0.000000] printk: bootconsole [ns16550a0] enabled
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a0000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node r5f-memory@a0100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a1000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node r5f-memory@a1100000, compatible id shared-dma-pool
[    0.000000] cma: Reserved 512 MiB at 0x00000000c0000000
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: Trusted OS migration not required
[    0.000000] psci: SMC Calling Convention v1.0
[    0.000000] percpu: Embedded 2 pages/cpu s48408 r8192 d74472 u131072
[    0.000000] Detected VIPT I-cache on CPU0
[    0.000000] CPU features: detected: ARM erratum 845719
[    0.000000] CPU features: detected: GIC system register CPU interface
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 55976
[    0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 mtdparts=47040000.spi.0:512k(ospi.tiboot3),2m(ospi.tispl),4m(ospi.u-boot),128k(ospi.env),128k(ospi.env.backup),1m(ospi.sysfw),-@8m(ospi.rootfs) root=PARTUUID=a69909b2-02 rw rootfstype=ext4 rootwait
[    0.000000] Dentry cache hash table entries: 524288 (order: 6, 4194304 bytes, linear)
[    0.000000] Inode-cache hash table entries: 262144 (order: 5, 2097152 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] software IO TLB: mapped [mem 0xbbff0000-0xbfff0000] (64MB)
[    0.000000] Memory: 3515712K/3586048K available (9534K kernel code, 776K rwdata, 3840K rodata, 1728K init, 695K bss, 18446744073709097664K reserved, 524288K cma-reserved)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu: 	RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4.
[    0.000000] 	Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[    0.000000] GICv3: 960 SPIs implemented
[    0.000000] GICv3: 0 Extended SPIs implemented
[    0.000000] GICv3: Distributor has no Range Selector support
[    0.000000] GICv3: 16 PPIs implemented
[    0.000000] GICv3: no VLPI support, no direct LPI support
[    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001880000
[    0.000000] ITS [mem 0x01820000-0x0182ffff]
[    0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
[    0.000000] ITS@0x0000000001820000: allocated 1048576 Devices @8c0800000 (flat, esz 8, psz 64K, shr 0)
[    0.000000] ITS: using cache flushing for cmd queue
[    0.000000] GICv3: using LPI property table @0x00000008c00d0000
[    0.000000] GIC: using cache flushing for LPI property table
[    0.000000] GICv3: CPU0: using allocated LPI pending table @0x00000008c00e0000
[    0.000000] random: get_random_bytes called from start_kernel+0x2b8/0x438 with crng_init=0
[    0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
[    0.000006] sched_clock: 56 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
[    0.008634] Console: colour dummy device 80x25
[    0.013232] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
[    0.023922] pid_max: default: 32768 minimum: 301
[    0.028774] LSM: Security Framework initializing
[    0.033583] Mount-cache hash table entries: 8192 (order: 0, 65536 bytes, linear)
[    0.041177] Mountpoint-cache hash table entries: 8192 (order: 0, 65536 bytes, linear)
[    0.073326] ASID allocator initialised with 32768 entries
[    0.086893] rcu: Hierarchical SRCU implementation.
[    0.099964] Platform MSI: gic-its@1820000 domain created
[    0.105669] PCI/MSI: /interconnect@100000/interrupt-controller@1800000/gic-its@1820000 domain created
[    0.123146] smp: Bringing up secondary CPUs ...
[    0.160357] Detected VIPT I-cache on CPU1
[    0.160394] GICv3: CPU1: found redistributor 1 region 0:0x00000000018a0000
[    0.160409] GICv3: CPU1: using allocated LPI pending table @0x00000008c00f0000
[    0.160455] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[    0.192490] Detected VIPT I-cache on CPU2
[    0.192528] GICv3: CPU2: found redistributor 100 region 0:0x00000000018c0000
[    0.192544] GICv3: CPU2: using allocated LPI pending table @0x00000008c0100000
[    0.192591] CPU2: Booted secondary processor 0x0000000100 [0x410fd034]
[    0.224494] Detected VIPT I-cache on CPU3
[    0.224519] GICv3: CPU3: found redistributor 101 region 0:0x00000000018e0000
[    0.224530] GICv3: CPU3: using allocated LPI pending table @0x00000008c0110000
[    0.224561] CPU3: Booted secondary processor 0x0000000101 [0x410fd034]
[    0.224708] smp: Brought up 1 node, 4 CPUs
[    0.304866] SMP: Total of 4 processors activated.
[    0.309687] CPU features: detected: 32-bit EL0 Support
[    0.314968] CPU features: detected: CRC32 instructions
[    0.331721] CPU: All CPU(s) started at EL2
[    0.335959] alternatives: patching kernel code
[    0.341968] devtmpfs: initialized
[    0.355468] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.365466] futex hash table entries: 1024 (order: 0, 65536 bytes, linear)
[    0.374203] pinctrl core: initialized pinctrl subsystem
[    0.380554] NET: Registered protocol family 16
[    0.392309] DMA: preallocated 256 KiB pool for atomic allocations
[    0.399439] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.429266] HugeTLB registered 16.0 GiB page size, pre-allocated 0 pages
[    0.436151] HugeTLB registered 512 MiB page size, pre-allocated 0 pages
[    0.442935] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.454666] cryptd: max_cpu_qlen set to 1000
[    0.467364] iommu: Default domain type: Translated
[    0.472757] SCSI subsystem initialized
[    0.477312] mc: Linux media interface: v0.10
[    0.481717] videodev: Linux video capture interface: v2.00
[    0.487360] pps_core: LinuxPPS API ver. 1 registered
[    0.492446] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.501809] PTP clock support registered
[    0.505848] EDAC MC: Ver: 3.0.0
[    0.510221] FPGA manager framework
[    0.513791] Advanced Linux Sound Architecture Driver Initialized.
[    0.521042] clocksource: Switched to clocksource arch_sys_counter
[    0.527509] VFS: Disk quotas dquot_6.6.0
[    0.531636] VFS: Dquot-cache hash table entries: 8192 (order 0, 65536 bytes)
[    0.545184] thermal_sys: Registered thermal governor 'step_wise'
[    0.545188] thermal_sys: Registered thermal governor 'power_allocator'
[    0.551928] NET: Registered protocol family 2
[    0.563630] tcp_listen_portaddr_hash hash table entries: 4096 (order: 0, 65536 bytes, linear)
[    0.572497] TCP established hash table entries: 32768 (order: 2, 262144 bytes, linear)
[    0.580912] TCP bind hash table entries: 32768 (order: 3, 524288 bytes, linear)
[    0.588970] TCP: Hash tables configured (established 32768 bind 32768)
[    0.595801] UDP hash table entries: 2048 (order: 0, 65536 bytes, linear)
[    0.602781] UDP-Lite hash table entries: 2048 (order: 0, 65536 bytes, linear)
[    0.610378] NET: Registered protocol family 1
[    0.615565] RPC: Registered named UNIX socket transport module.
[    0.621658] RPC: Registered udp transport module.
[    0.626484] RPC: Registered tcp transport module.
[    0.631301] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.637903] PCI: CLS 0 bytes, default 64
[    0.643085] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[    0.661905] Initialise system trusted keyrings
[    0.666661] workingset: timestamp_bits=46 max_order=16 bucket_order=0
[    0.679889] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.686704] NFS: Registering the id_resolver key type
[    0.691917] Key type id_resolver registered
[    0.696286] Key type id_legacy registered
[    0.700405] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    0.707599] 9p: Installing v9fs 9p2000 file system support
[    0.733011] Key type asymmetric registered
[    0.737231] Asymmetric key parser 'x509' registered
[    0.742275] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
[    0.749855] io scheduler mq-deadline registered
[    0.754495] io scheduler kyber registered
[    0.761235] pinctrl-single 4301c000.pinmux: 70 pins, size 280
[    0.767710] pinctrl-single 11c000.pinmux: 185 pins, size 740
[    0.773673] pinctrl-single 11c2e8.pinmux: 9 pins, size 36
[    0.780414] pinctrl-single a40000.timesync_router: 512 pins, size 2048
[    0.793219] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
[    0.799567] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
[    0.809824] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
[    0.833380] brd: module loaded
[    0.844756] loop: module loaded
[    0.851936] libphy: Fixed MDIO Bus: probed
[    0.856757] tun: Universal TUN/TAP device driver, 1.6
[    0.862727] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[    0.870754] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[    0.876862] sky2: driver version 1.30
[    0.881861] VFIO - User Level meta-driver version: 0.3
[    0.888043] i2c /dev entries driver
[    0.892929] sdhci: Secure Digital Host Controller Interface driver
[    0.899264] sdhci: Copyright(c) Pierre Ossman
[    0.904274] sdhci-pltfm: SDHCI platform and OF driver helper
[    0.911342] ledtrig-cpu: registered to indicate activity on CPUs
[    0.917604] ti-sci interconnect@100000:interconnect@28380000:interconnect@42040000:dmsc: invalid resource
[    0.928833] optee: probing for conduit method from DT.
[    0.934127] optee: revision 3.8 (199fca17)
[    0.934846] optee: initialized driver
[    0.944468] NET: Registered protocol family 17
[    0.949218] 9pnet: Installing 9P2000 support
[    0.953661] Key type dns_resolver registered
[    0.958422] registered taskstats version 1
[    0.962634] Loading compiled-in X.509 certificates
[    0.977229] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
[    0.983728] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
[    0.995618] ti-sci interconnect@100000:interconnect@28380000:interconnect@42040000:dmsc: invalid resource
[    1.005641] ti-sci interconnect@100000:interconnect@28380000:interconnect@42040000:dmsc: ABI: 3.0 (firmware rev 0x0014 '20.04.1-v2020.04a (Terrific Lla')
[    1.052230] random: fast init done
[    1.059736] omap_i2c 42120000.i2c: bus 0 rev0.12 at 400 kHz
[    1.066223] omap_i2c 40b00000.i2c: bus 1 rev0.12 at 100 kHz
[    1.072752] pca953x 2-0021: 2-0021 supply vcc not found, using dummy regulator
[    1.101725] omap_i2c 2000000.i2c: bus 2 rev0.12 at 400 kHz
[    1.108212] omap_i2c 2010000.i2c: bus 3 rev0.12 at 400 kHz
[    1.114508] omap_i2c 2020000.i2c: bus 4 rev0.12 at 400 kHz
[    1.120737] omap_i2c 2030000.i2c: bus 5 rev0.12 at 100 kHz
[    1.127365] ti-sci-intr interconnect@100000:interconnect@28380000:interconnect@42040000:interrupt-controller2: Interrupt Router 156 domain created
[    1.141010] ti-sci-intr interconnect@100000:interrupt-controller0: Interrupt Router 100 domain created
[    1.150727] ti-sci-intr interconnect@100000:navss@30800000:interrupt-controller1: Interrupt Router 182 domain created
[    1.161894] ti-sci-inta 33d00000.interrupt-controller: Interrupt Aggregator domain 179 created
[    1.177804] keystone-pcie 5600000.pcie: host bridge /interconnect@100000/pcie@5600000 ranges:
[    1.186575] keystone-pcie 5600000.pcie:    IO 0x18020000..0x1802ffff -> 0x00000000
[    1.194348] keystone-pcie 5600000.pcie:   MEM 0x18030000..0x1fffffff -> 0x18030000
[    2.202513] keystone-pcie 5600000.pcie: Phy link never came up
[    2.208625] keystone-pcie 5600000.pcie: PCI host bridge to bus 0000:00
[    2.215330] pci_bus 0000:00: root bus resource [bus 00-ff]
[    2.220952] pci_bus 0000:00: root bus resource [io  0x0000-0xffff]
[    2.227283] pci_bus 0000:00: root bus resource [mem 0x18030000-0x1fffffff]
[    2.234354] pci 0000:00:00.0: [104c:b00c] type 01 class 0x060400
[    2.240542] pci 0000:00:00.0: reg 0x38: [mem 0x00000000-0x0000ffff pref]
[    2.247469] pci 0000:00:00.0: supports D1
[    2.251581] pci 0000:00:00.0: PME# supported from D0 D1 D3hot
[    2.264630] pci 0000:00:00.0: BAR 6: assigned [mem 0x18030000-0x1803ffff pref]
[    2.272040] pci 0000:00:00.0: PCI bridge to [bus 01-ff]
[    2.277552] pcieport 0000:00:00.0: limiting MRRS to 128
[    2.283187] pcieport 0000:00:00.0: PME: Signaling with IRQ 38
[    2.289462] pcieport 0000:00:00.0: AER: enabled with IRQ 38
[    2.300999] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,160] sci-dev-id:195
[    2.310997] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: enabled
[    2.317689] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66344100, num_proxies:64
[    2.338760] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:818, gp-rings[304,464] sci-dev-id:187
[    2.348853] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: enabled
[    2.355541] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66344100, num_proxies:64
[    2.363624] omap8250 40a00000.serial: PM domain pd:149 will not be powered off
[    2.371413] 40a00000.serial: ttyS1 at MMIO 0x40a00000 (irq = 8, base_baud = 6000000) is a 8250
[    2.381405] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 17, base_baud = 3000000) is a 8250
[    2.390182] printk: console [ttyS2] enabled
[    2.398635] printk: bootconsole [ns16550a0] disabled
[    2.409571] 2810000.serial: ttyS3 at MMIO 0x2810000 (irq = 18, base_baud = 3000000) is a 8250
[    2.418885] 2820000.serial: ttyS4 at MMIO 0x2820000 (irq = 19, base_baud = 3000000) is a 8250
[    2.430539] cadence-qspi 47040000.spi: mt35xu512aba (65536 Kbytes)
[    2.436747] 7 cmdlinepart partitions found on MTD device 47040000.spi.0
[    2.443359] Creating 7 MTD partitions on "47040000.spi.0":
[    2.448854] 0x000000000000-0x000000080000 : "ospi.tiboot3"
[    2.455662] 0x000000080000-0x000000280000 : "ospi.tispl"
[    2.462275] 0x000000280000-0x000000680000 : "ospi.u-boot"
[    2.468925] 0x000000680000-0x0000006a0000 : "ospi.env"
[    2.475211] 0x0000006a0000-0x0000006c0000 : "ospi.env.backup"
[    2.482261] 0x0000006c0000-0x0000007c0000 : "ospi.sysfw"
[    2.488724] 0x000000800000-0x000004000000 : "ospi.rootfs"
[    2.717758] cadence-qspi 47040000.spi: Cadence QSPI NOR probe failed -517
[    2.773063] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[    2.780735] libphy: 46000f00.mdio: probed
[    2.786191] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
[    2.794500] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA07100, cpsw version 0x6BA80100 Ports: 2
[    2.806030] am65-cpsw-nuss 46000000.ethernet: Failed to request tx dma channel -517
[    2.815696] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a2109, freq:200000000, add_val:4 pps:0
[    2.824431] thermal thermal_zone1: failed to read out thermal zone (-22)
[    2.832020] mmc0: CQHCI version 5.10
[    2.866770] mmc0: SDHCI controller on 4f80000.sdhci [4f80000.sdhci] using ADMA 64-bit
[    2.887058] pca953x 0-0039: 0-0039 supply vcc not found, using dummy regulator
[    2.918453] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fc5900
[    2.925423] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fc5900
[    2.935790] ti-udma 285c0000.dma-controller: Channels: 96 (tchan: 48, rchan: 48, gp-rflow: 48)
[    2.958821] ti-udma 31150000.dma-controller: Channels: 267 (tchan: 119, rchan: 148, gp-rflow: 150)
[    2.974643] mmc0: new HS200 MMC card at address 0001
[    2.980496] mmcblk0: mmc0:0001 R1J56L 14.7 GiB
[    2.985410] mmcblk0boot0: mmc0:0001 R1J56L partition 1 8.00 MiB
[    3.001137] mmcblk0boot1: mmc0:0001 R1J56L partition 2 8.00 MiB
[    3.007277] mmcblk0rpmb: mmc0:0001 R1J56L partition 3 4.00 MiB, chardev (240:0)
[    3.016345] cadence-qspi 47040000.spi: mt35xu512aba (65536 Kbytes)
[    3.022543] 7 cmdlinepart partitions found on MTD device 47040000.spi.0
[    3.029747] Creating 7 MTD partitions on "47040000.spi.0":
[    3.035632] 0x000000000000-0x000000080000 : "ospi.tiboot3"
[    3.043240] 0x000000080000-0x000000280000 : "ospi.tispl"
[    3.052233] 0x000000280000-0x000000680000 : "ospi.u-boot"
[    3.058916] 0x000000680000-0x0000006a0000 : "ospi.env"
[    3.065249] 0x0000006a0000-0x0000006c0000 : "ospi.env.backup"
[    3.072229] 0x0000006c0000-0x0000007c0000 : "ospi.sysfw"
[    3.078759] 0x000000800000-0x000004000000 : "ospi.rootfs"
[    3.092322] spi-nor spi7.0: n25q128a13 (16384 Kbytes)
[    3.137083] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[    3.144752] libphy: 46000f00.mdio: probed
[    3.150230] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
[    3.158536] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA07100, cpsw version 0x6BA80100 Ports: 2
[    3.171213] am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48
[    3.179040] pps pps0: new PPS source ptp1
[    3.183369] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a2109, freq:200000000, add_val:4 pps:1
[    3.192339] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 57.4
[    3.199649] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
[    3.209637] mmc1: CQHCI version 5.10
[    3.244472] mmc1: SDHCI controller on 4fa0000.sdhci [4fa0000.sdhci] using ADMA 64-bit
[    3.253240] debugfs: Directory 'pd:121' with parent 'pm_genpd' already present!
[    3.260604] debugfs: Directory 'pd:120' with parent 'pm_genpd' already present!
[    3.270285] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[    3.277291] hctosys: unable to open rtc device (rtc0)
[    3.292364] ALSA device list:
[    3.295340]   No soundcards found.
[    3.299278] Waiting for root device PARTUUID=a69909b2-02...
[    4.173970] mmc1: Problem switching card into high-speed mode!
[    4.179949] mmc1: new SDHC card at address 0001
[    4.185244] mmcblk1: mmc1:0001 SD32G 29.0 GiB
[    4.197517]  mmcblk1: p1 p2
[    5.215636] EXT4-fs (mmcblk1p2): recovery complete
[    5.223781] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Opts: (null)
[    5.232146] VFS: Mounted root (ext4 filesystem) on device 179:98.
[    5.252338] devtmpfs: mounted
[    5.256013] Freeing unused kernel memory: 1728K
[    5.260616] Run /sbin/init as init process
[    5.813189] systemd[1]: System time before build time, advancing clock.
[    5.980134] NET: Registered protocol family 10
[    5.985774] Segment Routing with IPv6
[    6.039045] systemd[1]: systemd 244.3+ running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR -SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN2 -IDN -PCRE2 default-hierarchy=hybrid)
[    6.061248] systemd[1]: Detected architecture arm64.
Welcome to Arago 2020.05!
[    6.118798] systemd[1]: Set hostname to <am65xx-evm>.
[    6.692492] systemd[1]: /lib/systemd/system/docker.socket:6: ListenStream= references a path below legacy directory /var/run/, updating /var/run/docker.sock �� /run/docker.sock; please update the unit file accordingly.
[    6.870984] random: systemd: uninitialized urandom read (16 bytes read)
[    6.877930] systemd[1]: system-getty.slice: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
[    6.890332] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
[    6.902719] systemd[1]: Created slice system-getty.slice.
[  OK  ] Created slice system-getty.slice.
[    6.925208] random: systemd: uninitialized urandom read (16 bytes read)
[    6.933662] systemd[1]: Created slice system-serial\x2dgetty.slice.
[  OK  ] Created slice system-serial\x2dgetty.slice.
[    6.953195] random: systemd: uninitialized urandom read (16 bytes read)
[    6.961342] systemd[1]: Created slice User and Session Slice.
[  OK  ] Created slice User and Session Slice.
[    6.977459] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[  OK  ] Started Dispatch Password �cts to Console Directory Watch.
[    7.001321] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[  OK  ] Started Forward Password R�cuests to Wall Directory Watch.
[    7.025344] systemd[1]: Reached target Paths.
[  OK  ] Reached target Paths.
[    7.041199] systemd[1]: Reached target Remote File Systems.
[  OK  ] Reached target Remote File Systems.
[    7.057172] systemd[1]: Reached target Slices.
[  OK  ] Reached target Slices.
[    7.073184] systemd[1]: Reached target Swap.
[  OK  ] Reached target Swap.
[    7.092551] systemd[1]: Listening on RPCbind Server Activation Socket.
[  OK  ] Listening on RPCbind Server Activation Socket.
[    7.113218] systemd[1]: Reached target RPC Port Mapper.
[  OK  ] Reached target RPC Port Mapper.
[    7.136255] systemd[1]: Listening on Process Core Dump Socket.
[  OK  ] Listening on Process Core Dump Socket.
[    7.153469] systemd[1]: Listening on initctl Compatibility Named Pipe.
[  OK  ] Listening on initctl Compatibility Named Pipe.
[    7.210454] systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
[    7.219232] systemd[1]: Listening on Journal Socket (/dev/log).
[  OK  ] Listening on Journal Socket (/dev/log).
[    7.237678] systemd[1]: Listening on Journal Socket.
[  OK  ] Listening on Journal Socket.
[    7.257844] systemd[1]: Listening on Network Service Netlink Socket.
[  OK  ] Listening on Network Service Netlink Socket.
[    7.277592] systemd[1]: Listening on udev Control Socket.
[  OK  ] Listening on udev Control Socket.
[    7.293490] systemd[1]: Listening on udev Kernel Socket.
[  OK  ] Listening on udev Kernel Socket.
[    7.315661] systemd[1]: Mounting Huge Pages File System...
[    7.343188] systemd[1]: Mounting POSIX Message Queue File System...
[    7.371307] systemd[1]: Mounting Kernel Debug File System...
[    7.401949] systemd[1]: Mounting Temporary Directory (/tmp)...
[    7.423678] systemd[1]: Starting Create list of static device nodes for the current kernel...
         Starting Create list of st�codes for the current kernel...
[    7.455241] systemd[1]: Starting Start psplash boot splash screen...
[    7.493771] systemd[1]: Started Hardware RNG Entropy Gatherer Daemon.
[  OK  ] Started Hardware RNG Entropy Gatherer Daemon.
[    7.523722] systemd[1]: Starting RPC Bind...
[    7.541481] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[    7.557990] systemd[1]: Starting Journal Service...
[    7.608343] systemd[1]: Starting Load Kernel Modules...
[    7.635271] systemd[1]: Starting Remount Root and Kernel File Systems...
[    7.638633] cryptodev: loading out-of-tree module taints kernel.
         Starting Remount Root and Kernel File Systems cryptodev: driver 1.10 loaded.
[0m...
[    7.675956] systemd[1]: Starting udev Coldplug all Devices...
[    7.677671] EXT4-fs (mmcblk1p2): re-mounted. Opts: (null)
[    7.713598] systemd[1]: Started RPC Bind.
[  OK  ] Started RPC Bind.
[    7.726327] systemd[1]: Mounted Huge Pages File System.
[  OK  ] Mounted Huge Pages File System.
[    7.749956] systemd[1]: Mounted POSIX Message Queue File System.
[  OK  ] Mounted POSIX Message Queue File System.
[    7.773830] systemd[1]: Mounted Kernel Debug File System.
[  OK  ] Mounted Kernel Debug File System.
[    7.793788] systemd[1]: Started Journal Service.
[  OK  ] Started Journal Service.
[  OK  ] Mounted Temporary Directory (/tmp).
[  OK  ] Started Create list of sta�c nodes for the current kernel.
[FAILED] Failed to start Start psplash boot splash screen.
See 'systemctl status psplash-start.service' for details.
[DEPEND] Dependency failed for Star�cprogress communication helper.
[  OK  ] Started Load Kernel Modules.
[  OK  ] Started Remount Root and Kernel File Systems.
         Mounting Kernel Configuration File System...
         Starting Flush Journal to Persistent Storage...
         Starting Apply Kernel Variables...
[    7.999351] systemd-journald[238]: Received client request to flush runtime journal.
         Starting Create Static Device Nodes in /dev...
[  OK  ] Mounted Kernel Configuration File System.
[  OK  ] Started Flush Journal to Persistent Storage.
[  OK  ] Started Apply Kernel Variables.
[  OK  ] Started Create Static Device Nodes in /dev.
[  OK  ] Reached target Local File Systems (Pre).
         Mounting /media/ram...
         Mounting /var/volatile...
         Starting udev Kernel Device Manager...
[  OK  ] Mounted /media/ram.
[  OK  ] Mounted /var/volatile.
         Starting Load/Save Random Seed...
[  OK  ] Reached target Local File Systems.
         Starting Create Volatile Files and Directories...
[  OK  ] Started Create Volatile Files and Directories.
         Starting Network Time Synchronization...
         Starting Update UTMP about System Boot/Shutdown...
[  OK  ] Started udev Kernel Device Manager.
[  OK  ] Started Update UTMP about System Boot/Shutdown.
[  OK  ] Started udev Coldplug all Devices.
[  OK  ] Started Network Time Synchronization.
[  OK  ] Reached target System Initialization.
[  OK  ] Started Daily Cleanup of Temporary Directories.
[  OK  ] Reached target System Time Set.
[  OK  ] Reached target System Time Synchronized.
[  OK  ] Started Daily rotation of log files.
[  OK  ] Reached target Timers.
[  OK  ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
[  OK  ] Listening on D-Bus System Message Bus Socket.
         Starting Docker Socket for the API.
[  OK  ] Listening on dropbear.socket.
         Starting Reboot and dump vmcore via kexec...
[  OK  ] Listening on Docker Socket for the API.
[  OK  ] Reached target Sockets.
[  OK  ] Reached target Basic System.
[  OK  ] Started Job spooling tools.
[  OK  ] Started Periodic Command Scheduler.
[  OK  ] Started D-Bus System Message Bus.
         Starting Print notice about GPLv3 packages...
         Starting IPv6 Packet Filtering Framework...
         Starting IPv4 Packet Filtering Framework...
[  OK  ] Started irqbalance daemon.
         Starting rc.pvr.service...
         Starting Login Service...
[  OK  ] Started TEE Supplicant.
[    9.385408] [drm] Initialized pvr 1.17.4948957 20110701 for 7000000.gpu on minor 0
[    9.474232] PVR_K: UM DDK-(4948957) and KM DDK-(4948957) match. [ OK ]
[    9.524404] ov5640 3-003c: 3-003c supply DOVDD not found, using dummy regulator
[  OK  ] Started Reboot and dump vmcore via kexec.
[  OK  ] Started IPv6 Packet Filtering Framework.
[  OK  ] Started IPv4 Packet Filtering Framework.
[  OK  ] Started rc.pvr.service.
[  OK  ] Reached target Network (Pre).
         Starting Network Service...
         Starting weston.service...
[    9.703017] ov5640 3-003c: 3-003c supply AVDD not found, using dummy regulator
[  OK  ] Started weston.service.
         Starting Matrix GUI...
         Starting telnetd.service...
[  OK  ] Started Login Service.
[  OK  ] Started telnetd.service.
[  OK  ] Started Matrix GUI.
[    9.983500] ov5640 3-003c: 3-003c supply DVDD not found, using dummy regulator
[   10.062124] ov5640 3-003c: ov5640_read_reg: error: reg=300a
[   10.072440] ov5640 3-003c: ov5640_check_chip_id: failed to read chip identifier
[  OK  ] Started Network Service.
         Starting Wait for Network to be Configured...
         Starting Network Name Resolution...
[   10.313338] ov5640: probe of 3-003c failed with error -121
[   10.381098] davinci_mdio b232400.mdio: davinci mdio revision 1.7, bus freq 1000000
[   10.416781] libphy: b232400.mdio: probed
[   10.534139] davinci_mdio b232400.mdio: phy[0]: device b232400.mdio:00, driver TI DP83867
[  OK  ] Started Network Name Resolution.
[  OK  ] Reached target Network.
[  OK  ] Reached target Host and Network Name Lookups.
         Starting Avahi mDNS/DNS-SD Stack...
[   10.591452] davinci_mdio b232400.mdio: phy[3]: device b232400.mdio:03, driver TI DP83867
[  OK  ] Started NFS status monitor for NFSv2/3 locking..
         Starting Permit User Sessions...
[   10.725118] random: crng init done
[   10.728550] random: 7 urandom warning(s) missed due to ratelimiting
[  OK  ] Started Permit User Sessions.
[  OK  ] Started Getty on tty1.
[  OK  ] Started Serial Getty on ttyS1.
[  OK  ] Started Serial Getty on ttyS2.
[  OK  ] Reached target Login Prompts.
         Starting Synchronize System and HW clocks...
[  OK  ] Started Avahi mDNS/DNS-SD Stack.
[  OK  ] Started Load/Save Random Seed.
[FAILED] Failed to start Synchronize System and HW clocks.
See 'systemctl status sync-clocks.service' for details.
[   11.436442] TI DP83867 46000f00.mdio:00: attached PHY driver [TI DP83867] (mii_bus:phy_addr=46000f00.mdio:00, irq=POLL)
[   11.457990] am65-cpsw-nuss 46000000.ethernet eth0: Link is Down
[   11.709391] platform 41000000.r5f: configured R5F for remoteproc mode
[   11.740278] platform 41000000.r5f: assigned reserved memory node r5f-dma-memory@a0000000
[   11.757342] remoteproc remoteproc0: 41000000.r5f is available
[   11.867176] remoteproc remoteproc0: powering up 41000000.r5f
[   11.872974] remoteproc remoteproc0: Booting fw image am65x-mcu-r5f0_0-fw, size 83276
[   11.887270] platform 41000000.r5f: booting R5F core using boot addr = 0x0
[   11.897304]  remoteproc0#vdev0buffer: assigned reserved memory node r5f-dma-memory@a0000000
[   11.906516] virtio_rpmsg_bus virtio0: rpmsg host is online
[   11.919722]  remoteproc0#vdev0buffer: registered virtio0 (type 7)
[   11.925910] remoteproc remoteproc0: remote processor 41000000.r5f is now up
[   11.940482] virtio_rpmsg_bus virtio0: creating channel ti.ipc4.ping-pong addr 0xd
[   12.379846] remoteproc remoteproc1: b034000.pru is available
[   12.459116] pru-rproc b034000.pru: PRU rproc node /interconnect@100000/icssg@b000000/pru@34000 probed successfully
[   12.550203] remoteproc remoteproc2: b004000.rtu is available
[   12.593472] pru-rproc b004000.rtu: PRU rproc node /interconnect@100000/icssg@b000000/rtu@4000 probed successfully
[   12.613422] remoteproc remoteproc3: b038000.pru is available
[   12.705507] pru-rproc b038000.pru: PRU rproc node /interconnect@100000/icssg@b000000/pru@38000 probed successfully
[   12.803554] remoteproc remoteproc4: b006000.rtu is available
[   12.857376] pru-rproc b006000.rtu: PRU rproc node /interconnect@100000/icssg@b000000/rtu@6000 probed successfully
[   12.954116] remoteproc remoteproc5: b134000.pru is available
[   12.979583] pru-rproc b134000.pru: PRU rproc node /interconnect@100000/icssg@b100000/pru@34000 probed successfully
[   13.056079] remoteproc remoteproc6: b104000.rtu is available
[   13.092952] pru-rproc b104000.rtu: PRU rproc node /interconnect@100000/icssg@b100000/rtu@4000 probed successfully
[   13.186223] remoteproc remoteproc7: b138000.pru is available
[   13.229766] pru-rproc b138000.pru: PRU rproc node /interconnect@100000/icssg@b100000/pru@38000 probed successfully
[   13.313957] remoteproc remoteproc8: b106000.rtu is available
[   13.337323] pru-rproc b106000.rtu: PRU rproc node /interconnect@100000/icssg@b100000/rtu@6000 probed successfully
[   13.377743] remoteproc remoteproc9: b234000.pru is available
[   13.424598] pru-rproc b234000.pru: PRU rproc node /interconnect@100000/icssg@b200000/pru@34000 probed successfully
[   13.480072] remoteproc remoteproc10: b204000.rtu is available
[   13.500221] pru-rproc b204000.rtu: PRU rproc node /interconnect@100000/icssg@b200000/rtu@4000 probed successfully
[   13.537245] remoteproc remoteproc11: b238000.pru is available
[   13.552465] pru-rproc b238000.pru: PRU rproc node /interconnect@100000/icssg@b200000/pru@38000 probed successfully
[   13.580127] remoteproc remoteproc12: b206000.rtu is available
[   13.600633] pru-rproc b206000.rtu: PRU rproc node /interconnect@100000/icssg@b200000/rtu@6000 probed successfully
[  OK  ] Created slice system-weston.slice.
[  OK  ] Started Weston Wayland Compositor.
[   13.807079] icssg-prueth pruss2_eth: TI PRU ethernet driver initialized: dual EMAC mode
[   13.867369] dwc3 4030000.usb: Failed to get clk 'ref': -2
[   13.985151] omap_usb2: disable chrg det
[   13.995578] OF: graph: no port node found in /interconnect@100000/phy@4110000
[   14.063030] omap_rng 4e10000.trng: Random Number Generator ver. 230b34c
[   14.548673] remoteproc remoteproc9: powering up b234000.pru
[   14.559313] usbcore: registered new interface driver usbfs
[   14.574280] usbcore: registered new interface driver hub
[   14.586545] usbcore: registered new device driver usb
[   14.629806] remoteproc remoteproc9: Booting fw image ti-pruss/am65x-pru0-prueth-fw.elf, size 16744
[   14.638917] remoteproc remoteproc9: remote processor b234000.pru is now up
[  OK  ] Created slice User Slice of UID 0.
[   14.649761] remoteproc remoteproc10: powering up b204000.rtu
         Starting User Runtime Directory /run/user/0...
[   14.697703] remoteproc remoteproc10: Booting fw image ti-pruss/am65x-rtu0-prueth-fw.elf, size 15668
[   14.706910] remoteproc remoteproc10: remote processor b204000.rtu is now up
[  OK  ] [   14.719416] TI DP83867 b232400.mdio:00: attached PHY driver [TI DP83867] (mii_bus:phy_addr=b232400.mdio:00, irq=POLL)
Started User Runtime Directory /run/user/0.
[   14.734618] net eth1: started
         Starting User Manager for UID 0...
[   14.734986] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller
[   14.761253] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 1
[   14.774075] xhci-hcd xhci-hcd.2.auto: hcc params 0x0298fe6d hci version 0x110 quirks 0x0000000000010010
[   14.781305] remoteproc remoteproc11: powering up b238000.pru
[   14.785260] xhci-hcd xhci-hcd.2.auto: irq 1289, io mem 0x04030000
[   14.801448] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
[   14.809831] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   14.817088] usb usb1: Product: xHCI Host Controller
[   14.817909] remoteproc remoteproc11: Booting fw image ti-pruss/am65x-pru1-prueth-fw.elf, size 16744
[   14.829064] usb usb1: Manufacturer: Linux 5.4.40-g66cf445b76 xhci-hcd
[   14.837102] remoteproc remoteproc11: remote processor b238000.pru is now up
[   14.837642] usb usb1: SerialNumber: xhci-hcd.2.auto
[   14.844894] remoteproc remoteproc12: powering up b206000.rtu
[   14.857759] hub 1-0:1.0: USB hub found
[   14.861598] hub 1-0:1.0: 1 port detected
[   14.869174] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller
[   14.874687] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 2
[   14.882368] xhci-hcd xhci-hcd.2.auto: Host supports USB 3.0 SuperSpeed
[   14.893124] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[   14.901407] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.04
[   14.909686] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   14.917199] remoteproc remoteproc12: Booting fw image ti-pruss/am65x-rtu1-prueth-fw.elf, size 15668
[   14.933136] remoteproc remoteproc12: remote processor b206000.rtu is now up
[   14.940556] TI DP83867 b232400.mdio:03: attached PHY driver [TI DP83867] (mii_bus:phy_addr=b232400.mdio:03, irq=POLL)
[   14.941090] usb usb2: Product: xHCI Host Controller
[   14.958128] net eth2: started
[   14.961118] usb usb2: Manufacturer: Linux 5.4.40-g66cf445b76 xhci-hcd
[   14.961129] usb usb2: SerialNumber: xhci-hcd.2.auto
[   14.977608] hub 2-0:1.0: USB hub found
[   14.981488] hub 2-0:1.0: 1 port detected
[  OK  ] Created slice system-systemd\x2dfsck.slice.
[  OK  ] Found device /dev/mmcblk1p1.
         Starting File System Check on /dev/mmcblk1p1...
 _____                    _____           _         _
|  _  |___ ___ ___ ___   |  _  |___ ___  |_|___ ___| |_
|     |  _| .'| . | . |  |   __|  _| . | | | -_|  _|  _|
|__|__|_| |__,|_  |___|  |__|  |_| |___|_| |___|___|_|
              |___|                    |___|
Arago Project http://arago-project.org am65xx-evm ttyS2
Arago 2020.05 am65xx-evm ttyS2
am65xx-evm login: ***************************************************************
NOTICE: This file system contains the following GPLv3 packages:
	bash-dev
	bash
	bc
	binutils
	cifs-utils
	cpio
	dosfstools
	elfutils
	gawk
	gdb
	gdbserver
	glmark2
	gstreamer1.0-libav
	gzip
	less
	libasm1
	libbfd
	libdw1
	libelf1
	libgdbm-compat4
	libgdbm-dev
	libgdbm6
	libgmp10
	libidn2-0
	libreadline-dev
	libreadline8
	libunistring2
	m4-dev
	m4
	nettle
	parted
	pdm-anomaly-detection
	tar
	which
If you do not wish to distribute GPLv3 components please remove
the above packages prior to distribution.  This can be done using
the opkg remove command.  i.e.:
    opkg remove <package>
Where <package> is the name printed in the list above
NOTE: If the package is a dependency of another package you
      will be notified of the dependent packages.  You should
      use the --force-removal-of-dependent-packages option to
      also remove the dependent packages as well
[  132.938494] Initializing XFRM netlink socket
[  140.246409] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[  140.265885] Bridge firewalling registered
am65xx-evm login: root
Last login: Mon Aug 10 16:45:39 UTC 2020
root@am65xx-evm:~# shutdown -h now
         Stopping Session c2 of user root.
[  OK  ] Removed slice system-systemd\x2dcoredump.slice.
[  OK  ] Removed slice system-weston.slice.
[  OK  ] Stopped target Multi-User System.
[  OK  ] Stopped target Login Prompts.
[  OK  ] Stopped target RPC Port Mapper.
[  OK  ] Stopped target Timers.
[  OK  ] Stopped Daily rotation of log files.
[  OK  ] Stopped Daily Cleanup of Temporary Directories.
         Stopping Job spooling tools...
         Stopping Avahi mDNS/DNS-SD Stack...
         Stopping Periodic Command Scheduler...
         Stopping Docker Application Container Engine...
         Stopping Getty on tty1...
         Stopping irqbalance daemon...
         Stopping Reboot and dump vmcore via kexec...
         Stopping Lighttpd Daemon...
[  OK  ] Stopped Matrix GUI.
         Stopping NFS status monitor for NFSv2/3 locking....
         Stopping Serial Getty on ttyS1...
         Stopping Serial Getty on ttyS2...
         Stopping strongSwan IPsec �cEv2 daemon using ipsec.conf...
         Stopping Load/Save Random Seed...
         Stopping TEE Supplicant...
         Stopping thermal-zone-init.service...
[  OK  ] Stopped Job spooling tools.
[  OK  ] Stopped Periodic Command Scheduler.
[  OK  ] Stopped irqbalance daemon.
[  OK  ] Stopped TEE Supplicant.
[  OK  ] Stopped Avahi mDNS/DNS-SD Stack.
[  OK  ] Stopped NFS status monitor for NFSv2/3 locking..
[  OK  ] Stopped Getty on tty1.
[  OK  ] Stopped Serial Getty on ttyS1.
[  OK  ] Stopped Serial Getty on ttyS2.
[  OK  ] Stopped strongSwan IPsec I�cIKEv2 daemon using ipsec.conf.
[  OK  ] Stopped Lighttpd Daemon.
[  OK  ] Stopped Reboot and dump vmcore via kexec.
[  OK  ] Stopped Load/Save Random Seed.
[  OK  ] Stopped thermal-zone-init.service.
[  OK  ] Stopped Session c2 of user root.
[  OK  ] Removed slice system-getty.slice.
[  OK  ] Removed slice system-serial\x2dgetty.slice.
         Stopping LSB: start and stop docker...
         Stopping LSB: network benchmark...
         Stopping Login Service...
         Stopping User Manager for UID 0...
[  OK  ] Stopped LSB: network benchmark.
[  OK  ] Stopped User Manager for UID 0.
[  OK  ] Stopped LSB: start and stop docker.
[  OK  ] Stopped target Host and Network Name Lookups.
[  OK  ] Stopped target System Time Synchronized.
[  OK  ] Stopped target System Time Set.
         Stopping telnetd.service...
         Stopping User Runtime Directory /run/user/0...
[  OK  ] Unmounted /run/user/0.
[  OK  ] Stopped telnetd.service.
[  OK  ] Stopped User Runtime Directory /run/user/0.
[  OK  ] Removed slice User Slice of UID 0.
         Stopping D-Bus System Message Bus...
         Stopping Permit User Sessions...
         Stopping weston.service...
[  OK  ] Stopped D-Bus System Message Bus.
[  OK  ] Stopped Login Service.
[  OK  ] Stopped Permit User Sessions.
[  OK  ] Stopped weston.service.
[  OK  ] Stopped target Remote File Systems.
         Stopping rc.pvr.service...
[  OK  ] Stopped Docker Application Container Engine.
[  OK  ] Stopped target Network is Online.
[  OK  ] Stopped target Network.
         Stopping Network Name Resolution...
[  OK  ] Stopped Network Name Resolution.
         Stopping Network Service...
[  OK  ] Stopped rc.pvr.service.
[  OK  ] Stopped Network Service.
[  OK  ] Stopped target Network (Pre).
[  OK  ] Stopped IPv6 Packet Filtering Framework.
[  OK  ] Stopped IPv4 Packet Filtering Framework.
[  OK  ] Stopped target Basic System.
[  OK  ] Stopped target Paths.
[  OK  ] Stopped Dispatch Password �cts to Console Directory Watch.
[  OK  ] Stopped Forward Password R�cuests to Wall Directory Watch.
[  OK  ] Stopped target Slices.
[  OK  ] Removed slice User and Session Slice.
[  OK  ] Stopped target Sockets.
[  OK  ] Closed Avahi mDNS/DNS-SD Stack Activation Socket.
[  OK  ] Closed D-Bus System Message Bus Socket.
[  OK  ] Closed Docker Socket for the API.
[  OK  ] Closed dropbear.socket.
[  OK  ] Stopped target System Initialization.
         Stopping Hardware RNG Entropy Gatherer Daemon...
[  OK  ] Stopped Apply Kernel Variables.
[  OK  ] Stopped Load Kernel Modules.
         Stopping Network Time Synchronization...
[  OK  ] Stopped Hardware RNG Entropy Gatherer Daemon.
[  OK  ] Stopped Network Time Synchronization.
[  OK  ] Stopped Create Volatile Files and Directories.
[  OK  ] Stopped target Local File Systems.
         Unmounting /media/ram...
         Unmounting /run/media/mmcblk1p1...
         Unmounting Temporary Directory (/tmp)...
         Unmounting /var/volatile...
[  OK  ] Unmounted /media/ram.
[  OK  ] Unmounted /run/media/mmcblk1p1.
[  OK  ] Unmounted Temporary Directory (/tmp).
[  OK  ] Unmounted /var/volatile.
[  OK  ] Stopped target Swap.
[  OK  ] Reached target Unmount All Filesystems.
[  OK  ] Stopped File System Check on /dev/mmcblk1p1.
[  OK  ] Removed slice system-systemd\x2dfsck.slice.
[  OK  ] Stopped target Local File Systems (Pre).
[  OK  ] Stopped Remount Root and Kernel File Systems.
[  OK  ] Stopped Create Static Device Nodes in /dev.
[  OK  ] Reached target Shutdown.
[  OK  ] Reached target Final Step.
[  OK  ] Started Power-Off.
[  OK  ] Reached target Power-Off.
[  251.593398] systemd-shutdown[1]: Syncing filesystems and block devices.
[  251.671494] systemd-shutdown[1]: Sending SIGTERM to remaining processes...
[  251.692316] systemd-journald[238]: Received SIGTERM from PID 1 (systemd-shutdow).
[  251.701712] systemd-shutdown[1]: Sending SIGKILL to remaining processes...
[  251.722442] systemd-shutdown[1]: Unmounting file systems.
[  251.731066] [1406]: Remounting '/' read-only in with options '(null)'.
[  251.777797] EXT4-fs (mmcblk1p2): re-mounted. Opts: (null)
[  251.788098] systemd-shutdown[1]: All filesystems unmounted.
[  251.793859] systemd-shutdown[1]: Deactivating swaps.
[  251.799043] systemd-shutdown[1]: All swaps deactivated.
[  251.804286] systemd-shutdown[1]: Detaching loop devices.
[  251.814163] systemd-shutdown[1]: All loop devices detached.
[  251.819928] systemd-shutdown[1]: Detaching DM devices.
[  251.825480] systemd-shutdown[1]: All DM devices detached.
[  251.830896] systemd-shutdown[1]: All filesystems, swaps, loop devices and DM devices detached.
[  251.851744] systemd-shutdown[1]: Syncing filesystems and block devices.
[  251.858637] systemd-shutdown[1]: Powering off.
[  251.878848] reboot: Power down
[  251.881961] Kernel panic - not syncing: Attempted to kill init! exitcode=0x00000000
[  251.889609] CPU: 0 PID: 1 Comm: systemd-shutdow Tainted: G           O      5.4.40-g66cf445b76 #1
[  251.898462] Hardware name: Texas Instruments AM654 Base Board (DT)
[  251.904627] Call trace:
[  251.907077]  dump_backtrace+0x0/0x140
[  251.910731]  show_stack+0x14/0x20
[  251.914042]  dump_stack+0xb4/0xf8
[  251.917352]  panic+0x158/0x324
[  251.920400]  do_exit+0x8ec/0x968
[  251.923623]  __do_sys_reboot+0x164/0x240
[  251.927537]  __arm64_sys_reboot+0x20/0x28
[  251.931541]  el0_svc_common.constprop.0+0x68/0x160
[  251.936321]  el0_svc_handler+0x20/0x80
[  251.940061]  el0_svc+0x8/0xc
[  251.942940] Kernel Offset: disabled
[  251.946420] CPU features: 0x0002,2000200c
[  251.950418] Memory Limit: none
[  251.953468] ---[ end Kernel panic - not syncing: Attempted to kill init! exitcode=0x00000000 ]---
��-Boot SPL 2020.01-gf9b0d030d3 (Aug 10 2020 - 17:47:39 +0000)
SoC:   AM65X SR1.0
DRAM:  4 GiB
In:    serial
Out:   serial
Err:   serial
Net:
1011 bytes read in 8 ms (123 KiB/s)
Running uenvcmd ...
16654344 bytes read in 1388 ms (11.4 MiB/s)
67584 bytes read in 13 ms (5 MiB/s)
757 bytes read in 8 ms (91.8 KiB/s)
Starting kernel ...
[    0.008635] Console: colour dummy device 80x25
[    0.013234] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
[    0.023925] pid_max: default: 32768 minimum: 301
[    0.033586] Mount-cache hash table entries: 8192 (order: 0, 65536 bytes, linear)
[    0.041179] Mountpoint-cache hash table entries: 8192 (order: 0, 65536 bytes, linear)
[    0.073327] ASID allocator initialised with 32768 entries
[    0.086892] rcu: Hierarchical SRCU implementation.
[    0.099962] Platform MSI: gic-its@1820000 domain created
[    0.123148] smp: Bringing up secondary CPUs ...
[    0.160355] Detected VIPT I-cache on CPU1
[    0.160392] GICv3: CPU1: found redistributor 1 region 0:0x00000000018a0000
[    0.160406] GICv3: CPU1: using allocated LPI pending table @0x00000008c00f0000
[    0.160456] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[    0.192486] Detected VIPT I-cache on CPU2
[    0.192524] GICv3: CPU2: found redistributor 100 region 0:0x00000000018c0000
[    0.192539] GICv3: CPU2: using allocated LPI pending table @0x00000008c0100000
[    0.224493] Detected VIPT I-cache on CPU3
[    0.224520] GICv3: CPU3: found redistributor 101 region 0:0x00000000018e0000
[    0.224532] GICv3: CPU3: using allocated LPI pending table @0x00000008c0110000
[    0.224709] smp: Brought up 1 node, 4 CPUs
[    0.304876] SMP: Total of 4 processors activated.
[    0.309696] CPU features: detected: 32-bit EL0 Support
[    0.314976] CPU features: detected: CRC32 instructions
[    0.331731] CPU: All CPU(s) started at EL2
[    0.335968] alternatives: patching kernel code
[    0.341987] devtmpfs: initialized
[    0.355540] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.365537] futex hash table entries: 1024 (order: 0, 65536 bytes, linear)
[    0.374300] pinctrl core: initialized pinctrl subsystem
[    0.380667] NET: Registered protocol family 16
[    0.392400] DMA: preallocated 256 KiB pool for atomic allocations
[    0.399526] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.429300] HugeTLB registered 16.0 GiB page size, pre-allocated 0 pages
[    0.436183] HugeTLB registered 512 MiB page size, pre-allocated 0 pages
[    0.442965] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.454743] cryptd: max_cpu_qlen set to 1000
[    0.468362] iommu: Default domain type: Translated
[    0.473760] SCSI subsystem initialized
[    0.478240] mc: Linux media interface: v0.10
[    0.482649] videodev: Linux video capture interface: v2.00
[    0.488294] pps_core: LinuxPPS API ver. 1 registered
[    0.493378] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.502742] PTP clock support registered
[    0.506782] EDAC MC: Ver: 3.0.0
[    0.511180] FPGA manager framework
[    0.514752] Advanced Linux Sound Architecture Driver Initialized.
[    0.521976] clocksource: Switched to clocksource arch_sys_counter
[    0.528439] VFS: Disk quotas dquot_6.6.0
[    0.532555] VFS: Dquot-cache hash table entries: 8192 (order 0, 65536 bytes)
[    0.546255] thermal_sys: Registered thermal governor 'step_wise'
[    0.546260] thermal_sys: Registered thermal governor 'power_allocator'
[    0.553033] NET: Registered protocol family 2
[    0.564741] tcp_listen_portaddr_hash hash table entries: 4096 (order: 0, 65536 bytes, linear)
[    0.573602] TCP established hash table entries: 32768 (order: 2, 262144 bytes, linear)
[    0.582043] TCP bind hash table entries: 32768 (order: 3, 524288 bytes, linear)
[    0.590178] TCP: Hash tables configured (established 32768 bind 32768)
[    0.597021] UDP hash table entries: 2048 (order: 0, 65536 bytes, linear)
[    0.603999] UDP-Lite hash table entries: 2048 (order: 0, 65536 bytes, linear)
[    0.611599] NET: Registered protocol family 1
[    0.616781] RPC: Registered named UNIX socket transport module.
[    0.622865] RPC: Registered udp transport module.
[    0.627682] RPC: Registered tcp transport module.
[    0.632497] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.639098] PCI: CLS 0 bytes, default 64
[    0.644216] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[    0.661916] Initialise system trusted keyrings
[    0.666653] workingset: timestamp_bits=46 max_order=16 bucket_order=0
[    0.679859] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.686521] NFS: Registering the id_resolver key type
[    0.691841] Key type id_resolver registered
[    0.696131] Key type id_legacy registered
[    0.700248] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    0.707359] 9p: Installing v9fs 9p2000 file system support
[    0.733040] Key type asymmetric registered
[    0.737251] Asymmetric key parser 'x509' registered
[    0.742287] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
[    0.749863] io scheduler mq-deadline registered
[    0.754503] io scheduler kyber registered
[    0.761263] pinctrl-single 4301c000.pinmux: 70 pins, size 280
[    0.767747] pinctrl-single 11c000.pinmux: 185 pins, size 740
[    0.773693] pinctrl-single 11c2e8.pinmux: 9 pins, size 36
[    0.780452] pinctrl-single a40000.timesync_router: 512 pins, size 2048
[    0.793280] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
[    0.799638] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
[    0.810084] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
[    0.833690] brd: module loaded
[    0.845112] loop: module loaded
[    0.852219] libphy: Fixed MDIO Bus: probed
[    0.856994] tun: Universal TUN/TAP device driver, 1.6
[    0.862948] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[    0.870976] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[    0.877086] sky2: driver version 1.30
[    0.882075] VFIO - User Level meta-driver version: 0.3
[    0.888241] i2c /dev entries driver
[    0.893171] sdhci: Secure Digital Host Controller Interface driver
[    0.899506] sdhci: Copyright(c) Pierre Ossman
[    0.904511] sdhci-pltfm: SDHCI platform and OF driver helper
[    0.911578] ledtrig-cpu: registered to indicate activity on CPUs
[    0.917835] ti-sci interconnect@100000:interconnect@28380000:interconnect@42040000:dmsc: invalid resource
[    0.929090] optee: probing for conduit method from DT.
[    0.934411] optee: revision 3.8 (199fca17)
[    0.935113] optee: initialized driver
[    0.944702] NET: Registered protocol family 17
[    0.949436] 9pnet: Installing 9P2000 support
[    0.953876] Key type dns_resolver registered
[    0.958633] registered taskstats version 1
[    0.962844] Loading compiled-in X.509 certificates
[    0.977561] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
[    0.984071] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
[    0.995879] ti-sci interconnect@100000:interconnect@28380000:interconnect@42040000:dmsc: invalid resource
[    1.005900] ti-sci interconnect@100000:interconnect@28380000:interconnect@42040000:dmsc: ABI: 3.0 (firmware rev 0x0014 '20.04.1-v2020.04a (Terrific Lla')
[    1.052456] random: fast init done
[    1.060030] omap_i2c 42120000.i2c: bus 0 rev0.12 at 400 kHz
[    1.066462] omap_i2c 40b00000.i2c: bus 1 rev0.12 at 100 kHz
[    1.073000] pca953x 2-0021: 2-0021 supply vcc not found, using dummy regulator
[    1.102672] omap_i2c 2000000.i2c: bus 2 rev0.12 at 400 kHz
[    1.109151] omap_i2c 2010000.i2c: bus 3 rev0.12 at 400 kHz
[    1.115421] omap_i2c 2020000.i2c: bus 4 rev0.12 at 400 kHz
[    1.121626] omap_i2c 2030000.i2c: bus 5 rev0.12 at 100 kHz
[    1.128253] ti-sci-intr interconnect@100000:interconnect@28380000:interconnect@42040000:interrupt-controller2: Interrupt Router 156 domain created
[    1.141898] ti-sci-intr interconnect@100000:interrupt-controller0: Interrupt Router 100 domain created
[    1.151618] ti-sci-intr interconnect@100000:navss@30800000:interrupt-controller1: Interrupt Router 182 domain created
[    1.162787] ti-sci-inta 33d00000.interrupt-controller: Interrupt Aggregator domain 179 created
[    1.178516] keystone-pcie 5600000.pcie: host bridge /interconnect@100000/pcie@5600000 ranges:
[    1.187293] keystone-pcie 5600000.pcie:    IO 0x18020000..0x1802ffff -> 0x00000000
[    1.195064] keystone-pcie 5600000.pcie:   MEM 0x18030000..0x1fffffff -> 0x18030000
[    2.203229] keystone-pcie 5600000.pcie: Phy link never came up
[    2.209347] keystone-pcie 5600000.pcie: PCI host bridge to bus 0000:00
[    2.216051] pci_bus 0000:00: root bus resource [bus 00-ff]
[    2.221673] pci_bus 0000:00: root bus resource [io  0x0000-0xffff]
[    2.228004] pci_bus 0000:00: root bus resource [mem 0x18030000-0x1fffffff]
[    2.235075] pci 0000:00:00.0: [104c:b00c] type 01 class 0x060400
[    2.241260] pci 0000:00:00.0: reg 0x38: [mem 0x00000000-0x0000ffff pref]
[    2.248185] pci 0000:00:00.0: supports D1
[    2.252295] pci 0000:00:00.0: PME# supported from D0 D1 D3hot
[    2.265332] pci 0000:00:00.0: BAR 6: assigned [mem 0x18030000-0x1803ffff pref]
[    2.272740] pci 0000:00:00.0: PCI bridge to [bus 01-ff]
[    2.278258] pcieport 0000:00:00.0: limiting MRRS to 128
[    2.283851] pcieport 0000:00:00.0: PME: Signaling with IRQ 38
[    2.290084] pcieport 0000:00:00.0: AER: enabled with IRQ 38
[    2.301663] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,160] sci-dev-id:195
[    2.311663] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: enabled
[    2.318349] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66344100, num_proxies:64
[    2.339438] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:818, gp-rings[304,464] sci-dev-id:187
[    2.349526] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: enabled
[    2.356215] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66344100, num_proxies:64
[    2.364312] omap8250 40a00000.serial: PM domain pd:149 will not be powered off
[    2.372102] 40a00000.serial: ttyS1 at MMIO 0x40a00000 (irq = 8, base_baud = 6000000) is a 8250
[    2.381919] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 17, base_baud = 3000000) is a 8250
[    2.390704] printk: console [ttyS2] enabled
[    2.399160] printk: bootconsole [ns16550a0] disabled
[    2.410030] 2810000.serial: ttyS3 at MMIO 0x2810000 (irq = 18, base_baud = 3000000) is a 8250
[    2.419329] 2820000.serial: ttyS4 at MMIO 0x2820000 (irq = 19, base_baud = 3000000) is a 8250
[    2.430991] cadence-qspi 47040000.spi: mt35xu512aba (65536 Kbytes)
[    2.437194] 7 cmdlinepart partitions found on MTD device 47040000.spi.0
[    2.443804] Creating 7 MTD partitions on "47040000.spi.0":
[    2.449291] 0x000000000000-0x000000080000 : "ospi.tiboot3"
[    2.456159] 0x000000080000-0x000000280000 : "ospi.tispl"
[    2.462782] 0x000000280000-0x000000680000 : "ospi.u-boot"
[    2.469407] 0x000000680000-0x0000006a0000 : "ospi.env"
[    2.475762] 0x0000006a0000-0x0000006c0000 : "ospi.env.backup"
[    2.482725] 0x0000006c0000-0x0000007c0000 : "ospi.sysfw"
[    2.489260] 0x000000800000-0x000004000000 : "ospi.rootfs"
[    2.718700] cadence-qspi 47040000.spi: Cadence QSPI NOR probe failed -517
[    2.774001] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[    2.781673] libphy: 46000f00.mdio: probed
[    2.787117] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
[    2.795425] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA07100, cpsw version 0x6BA80100 Ports: 2
[    2.806961] am65-cpsw-nuss 46000000.ethernet: Failed to request tx dma channel -517
[    2.816673] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a2109, freq:200000000, add_val:4 pps:0
[    2.825411] thermal thermal_zone1: failed to read out thermal zone (-22)
[    2.832995] mmc0: CQHCI version 5.10
[    2.867757] mmc0: SDHCI controller on 4f80000.sdhci [4f80000.sdhci] using ADMA 64-bit
[    2.887879] pca953x 0-0039: 0-0039 supply vcc not found, using dummy regulator
[    2.919394] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fc5900
[    2.926362] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fc5900
[    2.936741] ti-udma 285c0000.dma-controller: Channels: 96 (tchan: 48, rchan: 48, gp-rflow: 48)
[    2.959739] ti-udma 31150000.dma-controller: Channels: 267 (tchan: 119, rchan: 148, gp-rflow: 150)
[    2.975579] mmc0: new HS200 MMC card at address 0001
[    2.981420] mmcblk0: mmc0:0001 R1J56L 14.7 GiB
[    2.986336] mmcblk0boot0: mmc0:0001 R1J56L partition 1 8.00 MiB
[    3.002120] mmcblk0boot1: mmc0:0001 R1J56L partition 2 8.00 MiB
[    3.008263] mmcblk0rpmb: mmc0:0001 R1J56L partition 3 4.00 MiB, chardev (240:0)
[    3.017312] cadence-qspi 47040000.spi: mt35xu512aba (65536 Kbytes)
[    3.023511] 7 cmdlinepart partitions found on MTD device 47040000.spi.0
[    3.030708] Creating 7 MTD partitions on "47040000.spi.0":
[    3.036487] 0x000000000000-0x000000080000 : "ospi.tiboot3"
[    3.045261] 0x000000080000-0x000000280000 : "ospi.tispl"
[    3.053064] 0x000000280000-0x000000680000 : "ospi.u-boot"
[    3.059677] 0x000000680000-0x0000006a0000 : "ospi.env"
[    3.066131] 0x0000006a0000-0x0000006c0000 : "ospi.env.backup"
[    3.073073] 0x0000006c0000-0x0000007c0000 : "ospi.sysfw"
[    3.079661] 0x000000800000-0x000004000000 : "ospi.rootfs"
[    3.093142] spi-nor spi7.0: n25q128a13 (16384 Kbytes)
[    3.138018] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[    3.145689] libphy: 46000f00.mdio: probed
[    3.151152] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
[    3.159459] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA07100, cpsw version 0x6BA80100 Ports: 2
[    3.172119] am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48
[    3.180007] pps pps0: new PPS source ptp1
[    3.184343] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a2109, freq:200000000, add_val:4 pps:1
[    3.193309] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 57.4
[    3.200616] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
[    3.210633] mmc1: CQHCI version 5.10
[    3.245439] mmc1: SDHCI controller on 4fa0000.sdhci [4fa0000.sdhci] using ADMA 64-bit
[    3.254244] debugfs: Directory 'pd:121' with parent 'pm_genpd' already present!
[    3.261608] debugfs: Directory 'pd:120' with parent 'pm_genpd' already present!
[    3.271431] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[    3.278454] hctosys: unable to open rtc device (rtc0)
[    3.293908] ALSA device list:
[    3.296887]   No soundcards found.
[    3.300974] Waiting for root device PARTUUID=a69909b2-02...
[    4.161850] mmc1: Problem switching card into high-speed mode!
[    4.167845] mmc1: new SDHC card at address 0001
[    4.173124] mmcblk1: mmc1:0001 SD32G 29.0 GiB
[    4.185410]  mmcblk1: p1 p2
[    4.218632] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Opts: (null)
[    4.226826] VFS: Mounted root (ext4 filesystem) on device 179:98.
[    4.246928] devtmpfs: mounted
[    4.250743] Freeing unused kernel memory: 1728K
[    4.255342] Run /sbin/init as init process
[    4.879865] systemd[1]: System time before build time, advancing clock.
[    5.058730] NET: Registered protocol family 10
[    5.064319] Segment Routing with IPv6
[    5.127609] systemd[1]: systemd 244.3+ running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR -SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN2 -IDN -PCRE2 default-hierarchy=hybrid)
[    5.149778] systemd[1]: Detected architecture arm64.
[    5.203785] systemd[1]: Set hostname to <am65xx-evm>.
[    5.788753] systemd[1]: /lib/systemd/system/docker.socket:6: ListenStream= references a path below legacy directory /var/run/, updating /var/run/docker.sock �� /run/docker.sock; please update the unit file accordingly.
[    5.966323] random: systemd: uninitialized urandom read (16 bytes read)
[    5.973266] systemd[1]: system-getty.slice: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
[    5.985620] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
[    5.998136] systemd[1]: Created slice system-getty.slice.
[    6.014168] random: systemd: uninitialized urandom read (16 bytes read)
[    6.022545] systemd[1]: Created slice system-serial\x2dgetty.slice.
[    6.046118] random: systemd: uninitialized urandom read (16 bytes read)
[    6.054262] systemd[1]: Created slice User and Session Slice.
[    6.074409] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[    6.098257] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    6.122325] systemd[1]: Reached target Paths.
[    6.138131] systemd[1]: Reached target Remote File Systems.
[    6.158110] systemd[1]: Reached target Slices.
[    6.174124] systemd[1]: Reached target Swap.
[    6.193603] systemd[1]: Listening on RPCbind Server Activation Socket.
[    6.218179] systemd[1]: Reached target RPC Port Mapper.
[    6.245211] systemd[1]: Listening on Process Core Dump Socket.
[    6.262406] systemd[1]: Listening on initctl Compatibility Named Pipe.
[    6.314860] systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
[    6.323653] systemd[1]: Listening on Journal Socket (/dev/log).
[    6.342640] systemd[1]: Listening on Journal Socket.
[    6.358797] systemd[1]: Listening on Network Service Netlink Socket.
[    6.382553] systemd[1]: Listening on udev Control Socket.
[    6.402402] systemd[1]: Listening on udev Kernel Socket.
[    6.428524] systemd[1]: Mounting Huge Pages File System...
[    6.452277] systemd[1]: Mounting POSIX Message Queue File System...
[    6.476045] systemd[1]: Mounting Kernel Debug File System...
[    6.502883] systemd[1]: Mounting Temporary Directory (/tmp)...
[    6.532345] systemd[1]: Starting Create list of static device nodes for the current kernel...
[    6.563959] systemd[1]: Starting Start psplash boot splash screen...
[    6.592005] systemd[1]: Started Hardware RNG Entropy Gatherer Daemon.
[    6.622984] systemd[1]: Starting RPC Bind...
[    6.642595] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[    6.659627] systemd[1]: Starting Journal Service...
[    6.753044] systemd[1]: Starting Load Kernel Modules...
[    6.776549] systemd[1]: Starting Remount Root and Kernel File Systems...
[    6.796373] cryptodev: loading out-of-tree module taints kernel.
[    6.803749] systemd[1]: Starting udev Coldplug all Devices...
[    6.826938] cryptodev: driver 1.10 loaded.
[    6.827896] EXT4-fs (mmcblk1p2): re-mounted. Opts: (null)
[    6.833476] systemd[1]: Started RPC Bind.
[    6.861358] systemd[1]: Mounted Huge Pages File System.
[    6.886805] systemd[1]: Started Journal Service.
[    7.131874] systemd-journald[239]: Received client request to flush runtime journal.
[    8.494465] [drm] Initialized pvr 1.17.4948957 20110701 for 7000000.gpu on minor 0
[    8.582672] PVR_K: UM DDK-(4948957) and KM DDK-(4948957) match. [ OK ]
[    9.067143] ov5640 3-003c: 3-003c supply DOVDD not found, using dummy regulator
[    9.134884] ov5640 3-003c: 3-003c supply AVDD not found, using dummy regulator
[    9.209173] ov5640 3-003c: 3-003c supply DVDD not found, using dummy regulator
[    9.250154] ov5640 3-003c: ov5640_read_reg: error: reg=300a
[    9.275621] ov5640 3-003c: ov5640_check_chip_id: failed to read chip identifier
[    9.293071] ov5640: probe of 3-003c failed with error -121
[    9.574459] davinci_mdio b232400.mdio: davinci mdio revision 1.7, bus freq 1000000
[    9.659532] libphy: b232400.mdio: probed
[    9.796611] davinci_mdio b232400.mdio: phy[0]: device b232400.mdio:00, driver TI DP83867
[    9.820000] davinci_mdio b232400.mdio: phy[3]: device b232400.mdio:03, driver TI DP83867
[    9.950056] random: crng init done
[    9.953519] random: 7 urandom warning(s) missed due to ratelimiting
[   10.597532] TI DP83867 46000f00.mdio:00: attached PHY driver [TI DP83867] (mii_bus:phy_addr=46000f00.mdio:00, irq=POLL)
[   10.616496] am65-cpsw-nuss 46000000.ethernet eth0: Link is Down
[   10.869197] platform 41000000.r5f: configured R5F for remoteproc mode
[   10.916537] platform 41000000.r5f: assigned reserved memory node r5f-dma-memory@a0000000
[   10.940015] remoteproc remoteproc0: 41000000.r5f is available
[   11.015159] remoteproc remoteproc0: powering up 41000000.r5f
[   11.021014] remoteproc remoteproc0: Booting fw image am65x-mcu-r5f0_0-fw, size 83276
[   11.035454] platform 41000000.r5f: booting R5F core using boot addr = 0x0
[   11.046196]  remoteproc0#vdev0buffer: assigned reserved memory node r5f-dma-memory@a0000000
[   11.055733] virtio_rpmsg_bus virtio0: rpmsg host is online
[   11.059247] virtio_rpmsg_bus virtio0: creating channel ti.ipc4.ping-pong addr 0xd
[   11.066179]  remoteproc0#vdev0buffer: registered virtio0 (type 7)
[   11.074979] remoteproc remoteproc0: remote processor 41000000.r5f is now up
[   11.620249] remoteproc remoteproc1: b034000.pru is available
[   11.710130] pru-rproc b034000.pru: PRU rproc node /interconnect@100000/icssg@b000000/pru@34000 probed successfully
[   11.759041] remoteproc remoteproc2: b004000.rtu is available
[   11.774415] pru-rproc b004000.rtu: PRU rproc node /interconnect@100000/icssg@b000000/rtu@4000 probed successfully
[   11.787157] remoteproc remoteproc3: b038000.pru is available
[   11.802424] pru-rproc b038000.pru: PRU rproc node /interconnect@100000/icssg@b000000/pru@38000 probed successfully
[   11.957801] remoteproc remoteproc4: b006000.rtu is available
[   12.048011] pru-rproc b006000.rtu: PRU rproc node /interconnect@100000/icssg@b000000/rtu@6000 probed successfully
[   12.104359] remoteproc remoteproc5: b134000.pru is available
[   12.125368] pru-rproc b134000.pru: PRU rproc node /interconnect@100000/icssg@b100000/pru@34000 probed successfully
[   12.174476] remoteproc remoteproc6: b104000.rtu is available
[   12.199953] pru-rproc b104000.rtu: PRU rproc node /interconnect@100000/icssg@b100000/rtu@4000 probed successfully
[   12.261157] remoteproc remoteproc7: b138000.pru is available
[   12.321006] pru-rproc b138000.pru: PRU rproc node /interconnect@100000/icssg@b100000/pru@38000 probed successfully
[   12.452363] remoteproc remoteproc8: b106000.rtu is available
[   12.533812] pru-rproc b106000.rtu: PRU rproc node /interconnect@100000/icssg@b100000/rtu@6000 probed successfully
[   12.634811] remoteproc remoteproc9: b234000.pru is available
[   12.710296] pru-rproc b234000.pru: PRU rproc node /interconnect@100000/icssg@b200000/pru@34000 probed successfully
[   12.779750] remoteproc remoteproc10: b204000.rtu is available
[   12.793429] pru-rproc b204000.rtu: PRU rproc node /interconnect@100000/icssg@b200000/rtu@4000 probed successfully
[   12.844792] remoteproc remoteproc11: b238000.pru is available
[   12.863948] pru-rproc b238000.pru: PRU rproc node /interconnect@100000/icssg@b200000/pru@38000 probed successfully
[   12.891104] remoteproc remoteproc12: b206000.rtu is available
[   12.911788] pru-rproc b206000.rtu: PRU rproc node /interconnect@100000/icssg@b200000/rtu@6000 probed successfully
[   13.139971] dwc3 4030000.usb: Failed to get clk 'ref': -2
[   13.261016] icssg-prueth pruss2_eth: TI PRU ethernet driver initialized: dual EMAC mode
[   13.334703] omap_usb2: disable chrg det
[   13.348042] OF: graph: no port node found in /interconnect@100000/phy@4110000
[   13.442128] omap_rng 4e10000.trng: Random Number Generator ver. 230b34c
[  OK  ] Started User Runtime Directory /run/user/0.
[   13.806781] usbcore: registered new interface driver usbfs
[   13.835631] usbcore: registered new interface driver hub
[   13.872571] usbcore: registered new device driver usb
[   13.934546] remoteproc remoteproc11: powering up b238000.pru
[   13.968764] remoteproc remoteproc11: Booting fw image ti-pruss/am65x-pru1-prueth-fw.elf, size 16744
[   13.980093] remoteproc remoteproc11: remote processor b238000.pru is now up
[   13.981582] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller
[   13.991200] remoteproc remoteproc12: powering up b206000.rtu
[   14.002322] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 1
[   14.014216] xhci-hcd xhci-hcd.2.auto: hcc params 0x0298fe6d hci version 0x110 quirks 0x0000000000010010
[   14.016234] remoteproc remoteproc12: Booting fw image ti-pruss/am65x-rtu1-prueth-fw.elf, size 15668
[   14.026151] xhci-hcd xhci-hcd.2.auto: irq 1289, io mem 0x04030000
[   14.042047] remoteproc remoteproc12: remote processor b206000.rtu is now up
[   14.046689] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
[   14.054030] TI DP83867 b232400.mdio:03: attached PHY driver [TI DP83867] (mii_bus:phy_addr=b232400.mdio:03, irq=POLL)
[   14.062033] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   14.082058] usb usb1: Product: xHCI Host Controller
[   14.090101] usb usb1: Manufacturer: Linux 5.4.40-g66cf445b76 xhci-hcd
[   14.090929] net eth2: started
[   14.096635] usb usb1: SerialNumber: xhci-hcd.2.auto
[   14.109695] hub 1-0:1.0: USB hub found
[   14.115720] hub 1-0:1.0: 1 port detected
[   14.122704] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller
[   14.128290] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 2
[   14.143532] xhci-hcd xhci-hcd.2.auto: Host supports USB 3.0 SuperSpeed
[   14.153824] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[   14.162066] remoteproc remoteproc9: powering up b234000.pru
[   14.166625] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.04
[   14.180820] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   14.188099] usb usb2: Product: xHCI Host Controller
[   14.193024] usb usb2: Manufacturer: Linux 5.4.40-g66cf445b76 xhci-hcd
[   14.193092] remoteproc remoteproc9: Booting fw image ti-pruss/am65x-pru0-prueth-fw.elf, size 16744
[   14.202036] usb usb2: SerialNumber: xhci-hcd.2.auto
[   14.214032] remoteproc remoteproc9: remote processor b234000.pru is now up
[   14.219416] hub 2-0:1.0: USB hub found
[   14.220971] remoteproc remoteproc10: powering up b204000.rtu
[   14.226251] hub 2-0:1.0: 1 port detected
[   14.250750] remoteproc remoteproc10: Booting fw image ti-pruss/am65x-rtu0-prueth-fw.elf, size 15668
[   14.266035] remoteproc remoteproc10: remote processor b204000.rtu is now up
[   14.274931] TI DP83867 b232400.mdio:00: attached PHY driver [TI DP83867] (mii_bus:phy_addr=b232400.mdio:00, irq=POLL)
[   14.286899] net eth1: started
[  OK  ] Started File System Check on /dev/mmcblk1p1.
         Mounting /run/media/mmcblk1p1...
[  OK  ] Started User Manager for UID 0.
[  OK  ] Started Session c1 of user root.
 _____                    _____           _         _
              |___|                    |___|
	bash-dev
	bash
	bc
	binutils
	cifs-utils
	cpio
	dosfstools
	elfutils
	gawk
	gdb
	gdbserver
	glmark2
	gstreamer1.0-libav
	gzip
	less
	libasm1
	libbfd
	libdw1
	libelf1
	libgdbm-compat4
	libgdbm-dev
	libgdbm6
	libgmp10
	libidn2-0
	libreadline-dev
	libreadline8
	libunistring2
	m4-dev
	m4
	nettle
	parted
	tar
	which
root@am65xx-evm:~# shutdown -r now
[  OK  ] Stopped Wait for Network to be Configured.
         Stopping Update UTMP about System Boot/Shutdown...
[  OK  ] Stopped Update UTMP about System Boot/Shutdown.
[  OK  ] Started Reboot.
[  OK  ] Reached target Reboot.
[  108.027870] systemd-shutdown[1]: Syncing filesystems and block devices.
[  108.207703] systemd-shutdown[1]: Sending SIGTERM to remaining processes...
[  108.230399] systemd-journald[239]: Received SIGTERM from PID 1 (systemd-shutdow).
[  108.239561] systemd-shutdown[1]: Sending SIGKILL to remaining processes...
[  108.260050] systemd-shutdown[1]: Unmounting file systems.
[  108.268676] [1090]: Remounting '/' read-only in with options '(null)'.
[  108.468285] EXT4-fs (mmcblk1p2): re-mounted. Opts: (null)
[  108.477398] systemd-shutdown[1]: All filesystems unmounted.
[  108.483031] systemd-shutdown[1]: Deactivating swaps.
[  108.488202] systemd-shutdown[1]: All swaps deactivated.
[  108.493444] systemd-shutdown[1]: Detaching loop devices.
[  108.503273] systemd-shutdown[1]: All loop devices detached.
[  108.508875] systemd-shutdown[1]: Detaching DM devices.
[  108.514368] systemd-shutdown[1]: All DM devices detached.
[  108.519784] systemd-shutdown[1]: All filesystems, swaps, loop devices and DM devices detached.
[  108.540701] systemd-shutdown[1]: Syncing filesystems and block devices.
[  108.547680] systemd-shutdown[1]: Rebooting.
[  108.571771] reboot: Restarting system
The booting SD card was created with the pre-built binaries by referring to the following documents.
https://software-dl.ti.com/processor-sdk-linux/esd/AM65X/latest/exports/docs/linux/Overview/Download_and_Install_the_SDK.html
https://software-dl.ti.com/processor-sdk-linux/esd/AM65X/latest/exports/docs/linux/Overview/Run_Setup_Scripts.html
https://software-dl.ti.com/processor-sdk-linux/esd/AM65X/latest/exports/docs/linux/Overview/PSDKLA_Formatting_SD_Card.html
Please tell me how to not fail.
Daisuke
