TMS320C6657: Boot with a compressed image
Part Number: TMS320C6657
Hi Experts,
Is there any methods to boot with a compressed program code?
I would like to make the image file smaller with compression.
If we have a processor which supports decompression in the device, please let me know.
Thank you for your kind advice.
Hitoshi
    The C6657 boot info can be found:
    What is the boot mode you intended to choose?
    >>>>I would like to make the image file smaller with compression.>>>>>Do you compare with application ELF file size with the image used to boot? I knew in most boot cases, the ELF file needs to be converted to a different format by using TI tools. The converted file is used for boot and it is typically smaller, does this meet your compression requirement?
    Regards, Eric
  • Hi Eric,
    Thank you for suggesting the resolution.
    It was confirmed that the binary file was smaller than the original out file.
    Is my understanding correct that it was compressed by the conversion?
    Currently, SPI Boot is utilized.
    Is the converted image extracted by the bootloader and copied to RAM?
    Am I making sense?
    Hitoshi
  • Hi Hitoshi,
    >>>>Is my understanding correct that it was compressed by the conversion?>>>>Correct
    >>>>Is the converted image extracted by the bootloader and copied to RAM>>>>>>Correct
    All your understandings are correct.
    Regards, Eric
  • Hi Eric,
    Thank you so much for your kind clarification.
    It helps a lot.
    Hitoshi
