Other Parts Discussed in Thread: AM3517
I am evaluating MMC/SD Interface of AM3517.
TRM (sprugr0b : P2174 19.5.3) describes below.
PBIAS_LITE module supplies this bias voltage,
depending on the CONTROL.CONTROL_PBIAS_LITE register settings.
CAUTION
The BIAS voltage must be set using the procedure described in ,
Extended-Drain I/Os and PBIAS Cell Basic Programming Guide. Failure to
follow this procedure can damage the MMCHS interface.
But, I can not find CONTROL.CONTROL_PBIAS_LITE on memory map.
(While, BSL source is using it which is defined in 0x48002520)
- Does CONTROL.CONTROL_PBIAS_LITE register exist?
- Should I set CONTROL.CONTROL_PBIAS_LITE register?
Best regards, RY
