PROCESSOR-SDK-DRA8X-TDA4X: Can't complete booting after SDK building
Part Number: PROCESSOR-SDK-DRA8X-TDA4X
Other Parts Discussed in Thread: TDA4VM
Hi
Using pre-built image we have no problem but after building the SDK , ti-processor-sdk-linux-automotive-j7-evm-07_00_01, according to TI's getting started guide.
EVM can't boot and display same log permanently.
Target Board: TDA4VM EVM Rev2
SDK Version : ti-processor-sdk-linux-automotive-j7-evn-07_00_01
Boot device : SD Card boot
Below is the log
U-Boot SPL 2020.01-dirty (Nov 14 2020 - 16:10:14 +0900)
SYSFW ABI: 2.9 (firmware rev 0x0013 '19.12.1-v2019.12a (Terrific Lla')
Trying to boot from MMC2
Loading Environment from MMC... *** Warning - No MMC card found, using default environment
Remoteproc 2 started successfully
** File not found /lib/firmware/j7-mcu-r5f0_0-fw **
Starting ATF on ARM64 core...
NOTICE: BL31: v2.3():07.00.00.005-dirty
NOTICE: BL31: Built : 14:33:55, Jun 17 2020
U-Boot SPL 2020.01-dirty (Nov 14 2020 - 16:08:54 +0900)
Detected: J7X-BASE-CPB rev E3
Detected: J7X-VSC8514-ETH rev E2
U-Boot 2020.01-dirty (Nov 14 2020 - 16:08:54 +0900)
SoC:   J721E SR1.0
Model: Texas Instruments K3 J721E SoC
Board: J721EX-PM2-SOM rev E7
DRAM: 4 GiB
not found for dev hbmc-mux
Flash: 0 Bytes
MMC:   sdhci@4f80000: 0, sdhci@4fb0000: 1
Loading Environment from MMC... *** Warning - bad CRC, using default environment
In:   serial@2800000
Out:   serial@2800000
Err:   serial@2800000
Net:
Warning: ethernet@046000000 using MAC address from ROM
eth0: ethernet@046000000
Hit any key to stop autoboot: 0
switch to partitions #0, OK
mmc1 is current device
SD/MMC found on device 1
55 bytes read in 2 ms (26.4 KiB/s)
Loaded env from uEnv.txt
Importing environment from mmc1 ...
1513584 bytes read in 36 ms (40.1 MiB/s)
Load Remote Processor 6 with data@addr=0x80080000 1513584 bytes: Success!
1513584 bytes read in 37 ms (39 MiB/s)
Load Remote Processor 7 with data@addr=0x80080000 1513584 bytes: Success!
9314288 bytes read in 198 ms (44.9 MiB/s)
Load Remote Processor 8 with data@addr=0x80080000 9314288 bytes: Success!
16654344 bytes read in 336 ms (47.3 MiB/s)
89857 bytes read in 5 ms (17.1 MiB/s)
1719 bytes read in 2 ms (838.9 KiB/s)
## Flattened Device Tree blob at 82000000
   Booting using the fdt blob at 0x82000000
   Loading Device Tree to 00000000fdda1000, end 00000000fdeb9fff ... OK
Starting kernel ...
[   0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd080]
[   0.000000] Linux version 5.4.40-g66cf445b76 (hive21@ubuntu) (gcc version 9.2.1 20191025 (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10))) #1 SMP PREEMPT Sat Nov 14 15:39:54 KST 2020
[   0.000000] Machine model: Texas Instruments K3 J721E SoC
[   0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '')
[   0.000000] printk: bootconsole [ns16550a0] enabled
[   0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB
[   0.000000] OF: reserved mem: initialized node r5f-dma-memory@a0000000, compatible id shared-dma-pool
[   0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB
[   0.000000] OF: reserved mem: initialized node r5f-memory@a0100000, compatible id shared-dma-pool
[   0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB
[   0.000000] OF: reserved mem: initialized node r5f-dma-memory@a1000000, compatible id shared-dma-pool
[   0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 31 MiB
[   0.000000] OF: reserved mem: initialized node r5f-memory@a1100000, compatible id shared-dma-pool
[   0.000000] Reserved memory: created DMA memory pool at 0x00000000a3000000, size 1 MiB
[   0.000000] OF: reserved mem: initialized node r5f-dma-memory@a3000000, compatible id shared-dma-pool
[   0.000000] Reserved memory: created DMA memory pool at 0x00000000a3100000, size 15 MiB
[   0.000000] OF: reserved mem: initialized node r5f-memory@a3100000, compatible id shared-dma-pool
[   0.000000] Reserved memory: created DMA memory pool at 0x00000000a4000000, size 1 MiB
[   0.000000] OF: reserved mem: initialized node r5f-dma-memory@a4000000, compatible id shared-dma-pool
[   0.000000] Reserved memory: created DMA memory pool at 0x00000000a4100000, size 15 MiB
[   0.000000] OF: reserved mem: initialized node r5f-memory@a4100000, compatible id shared-dma-pool
[   0.000000] Reserved memory: created DMA memory pool at 0x00000000a5000000, size 1 MiB
[   0.000000] OF: reserved mem: initialized node r5f-dma-memory@a5000000, compatible id shared-dma-pool
[   0.000000] Reserved memory: created DMA memory pool at 0x00000000a5100000, size 15 MiB
[   0.000000] OF: reserved mem: initialized node r5f-memory@a5100000, compatible id shared-dma-pool
[   0.000000] Reserved memory: created DMA memory pool at 0x00000000a6000000, size 1 MiB
[   0.000000] OF: reserved mem: initialized node c66-dma-memory@a6000000, compatible id shared-dma-pool
[   0.000000] Reserved memory: created DMA memory pool at 0x00000000a6100000, size 15 MiB
[   0.000000] OF: reserved mem: initialized node c66-memory@a6100000, compatible id shared-dma-pool
[   0.000000] Reserved memory: created DMA memory pool at 0x00000000a7000000, size 1 MiB
[   0.000000] OF: reserved mem: initialized node c66-dma-memory@a7000000, compatible id shared-dma-pool
[   0.000000] Reserved memory: created DMA memory pool at 0x00000000a7100000, size 15 MiB
[   0.000000] OF: reserved mem: initialized node c66-memory@a7100000, compatible id shared-dma-pool
[   0.000000] Reserved memory: created DMA memory pool at 0x00000000a8000000, size 1 MiB
[   0.000000] OF: reserved mem: initialized node c71-dma-memory@a8000000, compatible id shared-dma-pool
[   0.000000] Reserved memory: created DMA memory pool at 0x00000000a8100000, size 15 MiB
[   0.000000] OF: reserved mem: initialized node c71-memory@a8100000, compatible id shared-dma-pool
[   0.000000] Reserved memory: created DMA memory pool at 0x00000000ac000000, size 32 MiB
[   0.000000] OF: reserved mem: initialized node vision_apps-dma-memory@ac000000, compatible id shared-dma-pool
[   0.000000] OF: reserved mem: initialized node vision_apps_shared-memories, compatible id dma-heap-carveout
[   0.000000] Reserved memory: created DMA memory pool at 0x00000000ce000000, size 720 MiB
[   0.000000] OF: reserved mem: initialized node vision_apps-core-heap-memory@ce000000, compatible id shared-dma-pool
[   0.000000] Reserved memory: created DMA memory pool at 0x00000000fb000000, size 1 MiB
[   0.000000] OF: reserved mem: initialized node r5f-dma-memory@fb000000, compatible id shared-dma-pool
[   0.000000] Reserved memory: created DMA memory pool at 0x00000000fb100000, size 15 MiB
[   0.000000] OF: reserved mem: initialized node r5f-memory@fb100000, compatible id shared-dma-pool
[   0.000000] cma: Failed to reserve 512 MiB
[   0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[   0.000000] psci: Using standard PSCI v0.2 function IDs
[   0.000000] psci: Trusted OS migration not required
[   0.000000] psci: SMC Calling Convention v1.0
[   0.000000] percpu: Embedded 2 pages/cpu s48408 r8192 d74472 u131072
[   0.000000] Detected PIPT I-cache on CPU0
[   0.000000] CPU features: detected: GIC system register CPU interface
[   0.000000] CPU features: detected: EL2 vector hardening
[   0.000000] Built 1 zonelists, mobility grouping off. Total pages: 35779
[   0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 mtdparts=47040000.spi.0:512k(ospi.tiboot3),2m(ospi.tispl),4m(ospi.u-boot),128k(ospi.env),128k(ospi.env.backup),1m(ospi.sysfw),-@8m(ospi.rootfs);47034000.hyperbus:512k(hbmc.tiboot3),2m(hbmc.tispl),4m(hbmc.u-boot),256k(hbmc.env),1m(hbmc.sysfw),-@8m(hbmc.rootfs) root=PARTUUID=696cc807-02 rw rootfstype=ext4 rootwait
[   0.000000] Dentry cache hash table entries: 524288 (order: 6, 4194304 bytes, linear)
[   0.000000] Inode-cache hash table entries: 262144 (order: 5, 2097152 bytes, linear)
[   0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[   0.000000] software IO TLB: mapped [mem 0x9a800000-0x9e800000] (64MB)
[   0.000000] Memory: 2584064K/2293760K available (9534K kernel code, 776K rwdata, 3840K rodata, 1728K init, 695K bss, 18446744073709261312K reserved, 0K cma-reserved)
[   0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[   0.000000] rcu: Preemptible hierarchical RCU implementation.
[   0.000000] rcu:     RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=2.
[   0.000000] Tasks RCU enabled.
[   0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[   0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
[   0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[   0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[   0.000000] GICv3: 960 SPIs implemented
[   0.000000] GICv3: 0 Extended SPIs implemented
[   0.000000] GICv3: Distributor has no Range Selector support
[   0.000000] GICv3: 16 PPIs implemented
[   0.000000] GICv3: no VLPI support, no direct LPI support
[   0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001900000
[   0.000000] ITS [mem 0x01820000-0x0182ffff]
[   0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
[   0.000000] ITS@0x0000000001820000: allocated 1048576 Devices @8c0800000 (flat, esz 8, psz 64K, shr 0)
[   0.000000] ITS: using cache flushing for cmd queue
[   0.000000] GICv3: using LPI property table @0x00000008c00c0000
[   0.000000] GIC: using cache flushing for LPI property table
[   0.000000] GICv3: CPU0: using allocated LPI pending table @0x00000008c00d0000
[   0.000000] random: get_random_bytes called from start_kernel+0x2b8/0x438 with crng_init=0
[   0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
[   0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
[   0.000002] sched_clock: 56 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
[   0.008358] Console: colour dummy device 80x25
[   0.012920] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
[   0.023589] pid_max: default: 32768 minimum: 301
[   0.028338] LSM: Security Framework initializing
[   0.033082] Mount-cache hash table entries: 8192 (order: 0, 65536 bytes, linear)
[   0.040650] Mountpoint-cache hash table entries: 8192 (order: 0, 65536 bytes, linear)
[   0.072700] ASID allocator initialised with 32768 entries
[   0.086227] rcu: Hierarchical SRCU implementation.
[   0.099188] Platform MSI: gic-its@1820000 domain created
[   0.104788] PCI/MSI: /interconnect@100000/interrupt-controller@1800000/gic-its@1820000 domain created
[   0.122224] smp: Bringing up secondary CPUs ...
[   0.159179] Detected PIPT I-cache on CPU1
[   0.159203] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000
[   0.159214] GICv3: CPU1: using allocated LPI pending table @0x00000008c00e0000
[   0.159238] CPU1: Booted secondary processor 0x0000000001 [0x411fd080]
[   0.159287] smp: Brought up 1 node, 2 CPUs
[   0.188632] SMP: Total of 2 processors activated.
[   0.193436] CPU features: detected: 32-bit EL0 Support
[   0.198690] CPU features: detected: CRC32 instructions
[   0.210240] CPU: All CPU(s) started at EL2
[   0.214434] alternatives: patching kernel code
[   0.219439] devtmpfs: initialized
[   0.227331] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[   0.237298] futex hash table entries: 512 (order: -1, 32768 bytes, linear)
[   0.244467] pinctrl core: initialized pinctrl subsystem
[   0.250191] NET: Registered protocol family 16
[   0.254908] DMA: preallocated 256 KiB pool for atomic allocations
[   0.261377] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[   0.276680] HugeTLB registered 16.0 GiB page size, pre-allocated 0 pages
[   0.283534] HugeTLB registered 512 MiB page size, pre-allocated 0 pages
[   0.290293] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[   0.298837] cryptd: max_cpu_qlen set to 1000
[   0.305929] vsys_3v3: supplied by evm_12v0
[   0.310249] vsys_5v0: supplied by evm_12v0
[   0.314886] iommu: Default domain type: Translated
[   0.320029] SCSI subsystem initialized
[   0.324141] mc: Linux media interface: v0.10
[   0.328531] videodev: Linux video capture interface: v2.00
[   0.334142] pps_core: LinuxPPS API ver. 1 registered
[   0.339211] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[   0.348548] PTP clock support registered
[   0.352558] EDAC MC: Ver: 3.0.0
[   0.356245] FPGA manager framework
[   0.359754] Advanced Linux Sound Architecture Driver Initialized.
[   0.366294] clocksource: Switched to clocksource arch_sys_counter
[   0.372619] VFS: Disk quotas dquot_6.6.0
[   0.376659] VFS: Dquot-cache hash table entries: 8192 (order 0, 65536 bytes)
[   0.386147] Carveout Heap: Exported 512 MiB at 0x00000000ae000000
[   0.392379] thermal_sys: Registered thermal governor 'step_wise'
[   0.392381] thermal_sys: Registered thermal governor 'power_allocator'
[   0.398750] NET: Registered protocol family 2
[   0.410132] tcp_listen_portaddr_hash hash table entries: 4096 (order: 0, 65536 bytes, linear)
[   0.418892] TCP established hash table entries: 32768 (order: 2, 262144 bytes, linear)
[   0.427084] TCP bind hash table entries: 32768 (order: 3, 524288 bytes, linear)
[   0.435001] TCP: Hash tables configured (established 32768 bind 32768)
[   0.441730] UDP hash table entries: 2048 (order: 0, 65536 bytes, linear)
[   0.448619] UDP-Lite hash table entries: 2048 (order: 0, 65536 bytes, linear)
[   0.456011] NET: Registered protocol family 1
[   0.460730] RPC: Registered named UNIX socket transport module.
[   0.466783] RPC: Registered udp transport module.
[   0.471586] RPC: Registered tcp transport module.
[   0.476388] RPC: Registered tcp NFSv4.1 backchannel transport module.
[   0.482972] PCI: CLS 0 bytes, default 64
[   0.487295] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[   0.498577] Initialise system trusted keyrings
[   0.503196] workingset: timestamp_bits=46 max_order=16 bucket_order=0
[   0.511845] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[   0.518070] NFS: Registering the id_resolver key type
[   0.523305] Key type id_resolver registered
[   0.527576] Key type id_legacy registered
[   0.531673] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[   0.538687] 9p: Installing v9fs 9p2000 file system support
[   0.551494] Key type asymmetric registered
[   0.555682] Asymmetric key parser 'x509' registered
[   0.560690] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
[   0.568252] io scheduler mq-deadline registered
[   0.572879] io scheduler kyber registered
[   0.578042] pinctrl-single 4301c000.pinmux: 94 pins, size 376
[   0.584127] pinctrl-single 11c000.pinmux: 173 pins, size 692
[   0.590271] pinctrl-single a40000.timesync_router: 512 pins, size 2048
[   0.599286] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
[   0.605551] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
[   0.611886] ti-pat 31010000.pat: Found PAT Rev 1.0 with 16384 pages
[   0.618298] debugfs: Directory '31010000.pat' with parent 'regmap' already present!
[   0.626261] ti-pat 31011000.pat: Found PAT Rev 1.0 with 16384 pages
[   0.632671] debugfs: Directory '31011000.pat' with parent 'regmap' already present!
[   0.640587] ti-pat 31012000.pat: Found PAT Rev 1.0 with 16384 pages
[   0.646997] debugfs: Directory '31012000.pat' with parent 'regmap' already present!
[   0.654935] ti-pat 31013000.pat: Found PAT Rev 1.0 with 2048 pages
[   0.661257] debugfs: Directory '31013000.pat' with parent 'regmap' already present!
[   0.669172] ti-pat 31014000.pat: Found PAT Rev 1.0 with 2048 pages
[   0.675492] debugfs: Directory '31014000.pat' with parent 'regmap' already present!
[   0.684807] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
[   0.696623] brd: module loaded
[   0.702520] loop: module loaded
[   0.706014] sysfs: cannot create duplicate filename '/devices/platform/dma_buf_phys'
[   0.713937] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 5.4.40-g66cf445b76 #1
[   0.721047] Hardware name: Texas Instruments K3 J721E SoC (DT)
[   0.727002] Call trace:
[   0.729499] dump_backtrace+0x0/0x140
[   0.733234] show_stack+0x14/0x20
[   0.736618] dump_stack+0xb4/0xf8
[   0.740002] sysfs_warn_dup+0x5c/0x78
[   0.743736] sysfs_create_dir_ns+0xd8/0xf0
[   0.747916] kobject_add_internal+0x94/0x280
[   0.752271] kobject_add+0x90/0xf8
[   0.755741] device_add+0xdc/0x600
[   0.759210] platform_device_add+0xfc/0x228
[   0.763476] platform_device_register_full+0xc8/0x140
[   0.768634] dma_buf_phys_init+0x68/0x94
[   0.772636] do_one_initcall+0x50/0x190
[   0.776551] kernel_init_freeable+0x194/0x22c
[   0.780997] kernel_init+0x10/0xfc
[   0.784466] ret_from_fork+0x10/0x18
[   0.788122] kobject_add_internal failed for dma_buf_phys with -EEXIST, don't try to register things with the same name in the same directory.
[   0.802200] libphy: Fixed MDIO Bus: probed
[   0.806541] tun: Universal TUN/TAP device driver, 1.6
[   0.811941] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[   0.819944] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[   0.826008] sky2: driver version 1.30
[   0.830227] VFIO - User Level meta-driver version: 0.3
[   0.835822] i2c /dev entries driver
[   0.839871] sdhci: Secure Digital Host Controller Interface driver
[   0.846185] sdhci: Copyright(c) Pierre Ossman
[   0.850826] sdhci-pltfm: SDHCI platform and OF driver helper
[   0.857055] ledtrig-cpu: registered to indicate activity on CPUs
[   0.863806] optee: probing for conduit method from DT.
[   0.869075] optee: revision 3.8 (199fca17)
[   0.869353] optee: initialized driver
[   0.878060] NET: Registered protocol family 17
[   0.882675] 9pnet: Installing 9P2000 support
[   0.887066] Key type dns_resolver registered
[   0.891573] registered taskstats version 1
[   0.895760] Loading compiled-in X.509 certificates
[   0.904197] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
[   0.910512] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
[   0.918120] ti-sci 44083000.dmsc: ABI: 2.9 (firmware rev 0x0013 '19.12.1-v2019.12a (Terrific Lla')
[   0.943711] random: fast init done
[   0.971258] davinci-mcasp 2ba0000.mcasp: IRQ common not found
[   0.978544] omap_i2c 40b00000.i2c: bus 0 rev0.12 at 100 kHz
[   0.984520] omap_i2c 40b10000.i2c: bus 1 rev0.12 at 100 kHz
[   0.990487] omap_i2c 42120000.i2c: bus 2 rev0.12 at 100 kHz
[   0.996515] pca953x 3-0020: 3-0020 supply vcc not found, using dummy regulator
[   1.026811] pca953x 3-0022: 3-0022 supply vcc not found, using dummy regulator
[   1.034840] GPIO line 481 (MCASP/TRACE_MUX_S0) hogged as output/low
[   1.041433] GPIO line 482 (MCASP/TRACE_MUX_S1) hogged as output/high
[   1.048262] omap_i2c 2000000.i2c: bus 3 rev0.12 at 400 kHz
[   1.054151] omap_i2c 2020000.i2c: bus 4 rev0.12 at 100 kHz
[   1.060107] pca953x 5-0020: 5-0020 supply vcc not found, using dummy regulator
[   1.090660] omap_i2c 2030000.i2c: bus 5 rev0.12 at 400 kHz
[   1.096556] omap_i2c 2040000.i2c: bus 6 rev0.12 at 100 kHz
[   1.102470] omap_i2c 2050000.i2c: bus 7 rev0.12 at 100 kHz
[   1.108779] ti-sci-intr interconnect@100000:interconnect@28380000:interrupt-controller2: Destination irq resource allocation failed
[   1.120875] ti-sci-intr: probe of interconnect@100000:interconnect@28380000:interrupt-controller2 failed with error -22
[   1.132106] ti-sci-intr interconnect@100000:interrupt-controller0: Destination irq resource allocation failed
[   1.142246] ti-sci-intr: probe of interconnect@100000:interrupt-controller0 failed with error -22
[   1.151517] ti-sci-intr interconnect@100000:navss@30000000:interrupt-controller1: Destination irq resource allocation failed
[   1.162988] ti-sci-intr: probe of interconnect@100000:navss@30000000:interrupt-controller1 failed with error -22
[   2.177300] j721e-pcie 2900000.pcie: host bridge /interconnect@100000/pcie@2900000 ranges:
[   2.185774] j721e-pcie 2900000.pcie:   IO 0x10001000..0x10010fff -> 0x10001000
[   2.193252] j721e-pcie 2900000.pcie:   MEM 0x10011000..0x17ffffff -> 0x10011000
[   2.200797] j721e-pcie 2900000.pcie: PCI host bridge to bus 0000:00
[   2.207204] pci_bus 0000:00: root bus resource [bus 00-0f]
[   2.212809] pci_bus 0000:00: root bus resource [io 0x0000-0xffff] (bus address [0x10001000-0x10010fff])
[   2.222499] pci_bus 0000:00: root bus resource [mem 0x10011000-0x17ffffff]
[   2.229538] pci 0000:00:00.0: [104c:b00d] type 01 class 0x060400
[   2.235693] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x4 may corrupt adjacent RW1C bits
[   2.245562] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x4 may corrupt adjacent RW1C bits
[   2.255448] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0xe8 may corrupt adjacent RW1C bits
[   2.265406] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x3e may corrupt adjacent RW1C bits
[   2.275373] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x92 may corrupt adjacent RW1C bits
[   2.285334] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0xb2 may corrupt adjacent RW1C bits
[   2.295334] pci 0000:00:00.0: supports D1
[   2.299427] pci 0000:00:00.0: PME# supported from D0 D1 D3hot
[   2.305298] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x84 may corrupt adjacent RW1C bits
[   2.315263] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x208 may corrupt adjacent RW1C bits
[   2.325315] pci 0000:00:00.0: reg 0x224: [mem 0x00000000-0x003fffff 64bit]
[   2.332341] pci 0000:00:00.0: VF(n) BAR0 space: [mem 0x00000000-0x00ffffff 64bit] (contains BAR0 for 4 VFs)
[   2.342308] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x210 may corrupt adjacent RW1C bits
[   2.352354] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x210 may corrupt adjacent RW1C bits
[   2.364045] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[   2.373716] pci_bus 0000:01: busn_res: [bus 01-0f] end is updated to 01
[   2.380488] pci 0000:00:00.0: BAR 7: assigned [mem 0x10400000-0x113fffff 64bit]
[   2.387964] pci 0000:00:00.0: PCI bridge to [bus 01]
[   2.393213] pcieport 0000:00:00.0: PME: Signaling with IRQ 33
[   2.399254] pcieport 0000:00:00.0: AER: enabled with IRQ 33
[   3.407000] j721e-pcie 2910000.pcie: host bridge /interconnect@100000/pcie@2910000 ranges:
[   3.415477] j721e-pcie 2910000.pcie:   IO 0x18001000..0x18010fff -> 0x18001000
[   3.422954] j721e-pcie 2910000.pcie:   MEM 0x18011000..0x1fffffff -> 0x18011000
[   3.430496] j721e-pcie 2910000.pcie: PCI host bridge to bus 0001:00
[   3.436901] pci_bus 0001:00: root bus resource [bus 00-0f]
[   3.442506] pci_bus 0001:00: root bus resource [io 0x10000-0x1ffff] (bus address [0x18001000-0x18010fff])
[   3.452373] pci_bus 0001:00: root bus resource [mem 0x18011000-0x1fffffff]
[   3.459409] pci 0001:00:00.0: [104c:b00d] type 01 class 0x060400
[   3.465610] pci 0001:00:00.0: supports D1
[   3.469704] pci 0001:00:00.0: PME# supported from D0 D1 D3hot
[   3.477160] pci 0001:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[   3.486797] pci_bus 0001:01: busn_res: [bus 01-0f] end is updated to 01
[   3.493563] pci 0001:00:00.0: PCI bridge to [bus 01]
[   3.498811] pcieport 0001:00:00.0: PME: Signaling with IRQ 36
[   3.504798] pcieport 0001:00:00.0: AER: enabled with IRQ 36
[   4.512746] j721e-pcie 2920000.pcie: host bridge /interconnect@100000/pcie@2920000 ranges:
[   4.521240] j721e-pcie 2920000.pcie:   IO 0x4400001000..0x4400010fff -> 0x00001000
[   4.529074] j721e-pcie 2920000.pcie:   MEM 0x4400011000..0x4407ffffff -> 0x00011000
[   4.536965] j721e-pcie 2920000.pcie: PCI host bridge to bus 0002:00
[   4.543370] pci_bus 0002:00: root bus resource [bus 00-0f]
[   4.548975] pci_bus 0002:00: root bus resource [io 0x20000-0x2ffff] (bus address [0x1000-0x10fff])
[   4.558222] pci_bus 0002:00: root bus resource [mem 0x4400011000-0x4407ffffff] (bus address [0x00011000-0x07ffffff])
[   4.568989] pci 0002:00:00.0: [104c:b00d] type 01 class 0x060400
[   4.575189] pci 0002:00:00.0: supports D1
[   4.579283] pci 0002:00:00.0: PME# supported from D0 D1 D3hot
[   4.586767] pci 0002:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[   4.596491] pci_bus 0002:01: busn_res: [bus 01-0f] end is updated to 01
[   4.603257] pci 0002:00:00.0: PCI bridge to [bus 01]
[   4.608491] pcieport 0002:00:00.0: PME: Signaling with IRQ 39
[   4.614479] pcieport 0002:00:00.0: AER: enabled with IRQ 39
[   4.620580] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
[   4.626894] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
[   4.633329] omap8250 40a00000.serial: PM domain pd:149 will not be powered off
[   4.640851] 40a00000.serial: ttyS1 at MMIO 0x40a00000 (irq = 7, base_baud = 6000000) is a 8250
[   4.650013] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 18, base_baud = 3000000) is a 8250
[   4.658752] printk: console [ttyS2] enabled
[   4.667188] printk: bootconsole [ns16550a0] disabled
[   4.677531] 2810000.serial: ttyS3 at MMIO 0x2810000 (irq = 19, base_baud = 3000000) is a 8250
[   4.686372] 2840000.serial: ttyS6 at MMIO 0x2840000 (irq = 20, base_baud = 3000000) is a 8250
[   4.695106] arm-smmu-v3 36600000.smmu: ias 48-bit, oas 48-bit (features 0x00001faf)
[   4.703797] arm-smmu-v3 36600000.smmu: allocated 524288 entries for cmdq
[   4.712433] arm-smmu-v3 36600000.smmu: allocated 524288 entries for evtq
[   4.719898] arm-smmu-v3 36600000.smmu: msi_domain absent - falling back to wired irqs
[   4.728574] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vdd-hba-supply regulator, assuming enabled
[   4.739080] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vcc-supply regulator, assuming enabled
[   4.749232] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq-supply regulator, assuming enabled
[   4.759470] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq2-supply regulator, assuming enabled
[   4.770222] scsi host0: ufshcd
[   4.777044] cadence-qspi 47040000.spi: mt35xu512aba (65536 Kbytes)
[   4.783227] 7 cmdlinepart partitions found on MTD device 47040000.spi.0
[   4.789824] Creating 7 MTD partitions on "47040000.spi.0":
[   4.795304] 0x000000000000-0x000000080000 : "ospi.tiboot3"
[   4.795308] cdns-ufshcd 4e84000.ufs: ufshcd_print_pwr_info:[RX, TX]: gear=[1, 1], lane[1, 1], pwr[SLOWAUTO_MODE, SLOWAUTO_MODE], rate = 0
[   4.813614] 0x000000080000-0x000000280000 : "ospi.tispl"
[   4.819285] 0x000000280000-0x000000680000 : "ospi.u-boot"
[   4.825086] 0x000000680000-0x0000006a0000 : "ospi.env"
[   4.830593] 0x0000006a0000-0x0000006c0000 : "ospi.env.backup"
[   4.836734] 0x0000006c0000-0x0000007c0000 : "ospi.sysfw"
[   4.842428] 0x000000800000-0x000004000000 : "ospi.rootfs"
[   4.857849] cdns-ufshcd 4e84000.ufs: ufshcd_print_pwr_info:[RX, TX]: gear=[3, 3], lane[2, 2], pwr[FAST MODE, FAST MODE], rate = 2
[   4.869518] cdns-ufshcd 4e84000.ufs: ufshcd_find_max_sup_active_icc_level: Regulator capability was not set, actvIccLevel=0
[   4.880800] scsi 0:0:0:49488: Well-known LUN   TOSHIBA THGAF8G8T23BAILB 0300 PQ: 0 ANSI: 6
[   4.889545] scsi 0:0:0:49476: Well-known LUN   TOSHIBA THGAF8G8T23BAILB 0300 PQ: 0 ANSI: 6
[   4.898234] cdns-ufshcd 4e84000.ufs: ufshcd_scsi_add_wlus: BOOT WLUN not found
[   5.094533] cadence-qspi 47040000.spi: Cadence QSPI NOR probe failed -517
[   5.102211] cadence-qspi 47050000.spi: mt25qu512a (65536 Kbytes)
[   5.138510] cadence-qspi 47050000.spi: Cadence QSPI NOR probe failed -517
[   5.182303] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[   5.189946] libphy: 46000f00.mdio: probed
[   5.194988] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
[   5.203251] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2
[   5.214653] am65-cpsw-nuss 46000000.ethernet: Failed to request tx dma channel -517
[   5.222966] mmc0: CQHCI version 5.10
[   5.254298] mmc0: SDHCI controller on 4f80000.sdhci [4f80000.sdhci] using ADMA 64-bit
[   5.262938] davinci-mcasp 2ba0000.mcasp: IRQ common not found
[   5.269999] vdd_mmc1: supplied by vsys_3v3
[   5.275653] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
[   5.281839] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
[   5.290537] cadence-qspi 47040000.spi: mt35xu512aba (65536 Kbytes)
[   5.296794] 7 cmdlinepart partitions found on MTD device 47040000.spi.0
[   5.303402] Creating 7 MTD partitions on "47040000.spi.0":
[   5.308878] 0x000000000000-0x000000080000 : "ospi.tiboot3"
[   5.314819] 0x000000080000-0x000000280000 : "ospi.tispl"
[   5.320473] 0x000000280000-0x000000680000 : "ospi.u-boot"
[   5.326201] 0x000000680000-0x0000006a0000 : "ospi.env"
[   5.331758] 0x0000006a0000-0x0000006c0000 : "ospi.env.backup"
[   5.337861] 0x0000006c0000-0x0000007c0000 : "ospi.sysfw"
[   5.343549] 0x000000800000-0x000004000000 : "ospi.rootfs"
[   5.397794] mmc0: Command Queue Engine enabled
[   5.402264] mmc0: new HS400 MMC card at address 0001
[   5.411510] mmcblk0: mmc0:0001 S0J56X 14.8 GiB
[   5.416154] mmcblk0boot0: mmc0:0001 S0J56X partition 1 31.5 MiB
[   5.422176] mmcblk0boot1: mmc0:0001 S0J56X partition 2 31.5 MiB
[   5.428162] mmcblk0rpmb: mmc0:0001 S0J56X partition 3 4.00 MiB, chardev (240:0)
[   5.614542] cadence-qspi 47040000.spi: Cadence QSPI NOR probe failed -517
[   5.622237] cadence-qspi 47050000.spi: mt25qu512a (65536 Kbytes)
[   5.662497] cadence-qspi 47050000.spi: Cadence QSPI NOR probe failed -517
[   5.706297] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[   5.713942] libphy: 46000f00.mdio: probed
[   5.718976] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
[   5.727238] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2
[   5.738639] am65-cpsw-nuss 46000000.ethernet: Failed to request tx dma channel -517
[   5.747319] davinci-mcasp 2ba0000.mcasp: IRQ common not found
[   5.755147] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
[   5.761319] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
[   5.769610] cadence-qspi 47040000.spi: mt35xu512aba (65536 Kbytes)
[   5.775799] 7 cmdlinepart partitions found on MTD device 47040000.spi.0
[   5.782397] Creating 7 MTD partitions on "47040000.spi.0":
[   5.787869] 0x000000000000-0x000000080000 : "ospi.tiboot3"
[   5.793779] 0x000000080000-0x000000280000 : "ospi.tispl"
[   5.799415] 0x000000280000-0x000000680000 : "ospi.u-boot"
[   5.805149] 0x000000680000-0x0000006a0000 : "ospi.env"
[   5.810635] 0x0000006a0000-0x0000006c0000 : "ospi.env.backup"
[   5.816725] 0x0000006c0000-0x0000007c0000 : "ospi.sysfw"
[   5.822394] 0x000000800000-0x000004000000 : "ospi.rootfs"
[   6.070531] cadence-qspi 47040000.spi: Cadence QSPI NOR probe failed -517
[   6.078213] cadence-qspi 47050000.spi: mt25qu512a (65536 Kbytes)
[   6.122498] cadence-qspi 47050000.spi: Cadence QSPI NOR probe failed -517
[   6.166299] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[   6.173944] libphy: 46000f00.mdio: probed
[   6.178980] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
[   6.187243] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2
[   6.198642] am65-cpsw-nuss 46000000.ethernet: Failed to request tx dma channel -517
[   6.207323] davinci-mcasp 2ba0000.mcasp: IRQ common not found
[   6.215132] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
[   6.221308] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
[   6.229603] cadence-qspi 47040000.spi: mt35xu512aba (65536 Kbytes)
[   6.235794] 7 cmdlinepart partitions found on MTD device 47040000.spi.0
[   6.242393] Creating 7 MTD partitions on "47040000.spi.0":
[   6.247865] 0x000000000000-0x000000080000 : "ospi.tiboot3"
[   6.253780] 0x000000080000-0x000000280000 : "ospi.tispl"
[   6.259427] 0x000000280000-0x000000680000 : "ospi.u-boot"
[   6.265155] 0x000000680000-0x0000006a0000 : "ospi.env"
[   6.270635] 0x0000006a0000-0x0000006c0000 : "ospi.env.backup"
[   6.276702] 0x0000006c0000-0x0000007c0000 : "ospi.sysfw"
[   6.282356] 0x000000800000-0x000004000000 : "ospi.rootfs"
[   6.526531] cadence-qspi 47040000.spi: Cadence QSPI NOR probe failed -517
[   6.534191] cadence-qspi 47050000.spi: mt25qu512a (65536 Kbytes)
[    6.574502] cadence-qspi 47050000.spi: Cadence QSPI NOR probe failed -517
[   6.618299] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[   6.625944] libphy: 46000f00.mdio: probed
[   6.630979] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
[   6.639242] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2
[   6.650640] am65-cpsw-nuss 46000000.ethernet: Failed to request tx dma channel -517
[   6.659308] davinci-mcasp 2ba0000.mcasp: IRQ common not found
[   6.667109] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
[   6.673283] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
[   6.681585] cadence-qspi 47040000.spi: mt35xu512aba (65536 Kbytes)
[   6.687770] 7 cmdlinepart partitions found on MTD device 47040000.spi.0
[   6.694367] Creating 7 MTD partitions on "47040000.spi.0":
[   6.699840] 0x000000000000-0x000000080000 : "ospi.tiboot3"
[   6.705752] 0x000000080000-0x000000280000 : "ospi.tispl"
[   6.711396] 0x000000280000-0x000000680000 : "ospi.u-boot"
[   6.717122] 0x000000680000-0x0000006a0000 : "ospi.env"
[   6.722602] 0x0000006a0000-0x0000006c0000 : "ospi.env.backup"
[   6.728674] 0x0000006c0000-0x0000007c0000 : "ospi.sysfw"
[   6.734330] 0x000000800000-0x000004000000 : "ospi.rootfs"
[   6.970530] cadence-qspi 47040000.spi: Cadence QSPI NOR probe failed -517
[   6.978204] cadence-qspi 47050000.spi: mt25qu512a (65536 Kbytes)
[   7.018499] cadence-qspi 47050000.spi: Cadence QSPI NOR probe failed -517
[   7.062298] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[   7.069943] libphy: 46000f00.mdio: probed
[   7.074975] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
[   7.083238] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2
[   7.094636] am65-cpsw-nuss 46000000.ethernet: Failed to request tx dma channel -517
[   7.103307] davinci-mcasp 2ba0000.mcasp: IRQ common not found
[   7.111108] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
[   7.117280] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
[   7.125564] cadence-qspi 47040000.spi: mt35xu512aba (65536 Kbytes)
[   7.131754] 7 cmdlinepart partitions found on MTD device 47040000.spi.0
[   7.138352] Creating 7 MTD partitions on "47040000.spi.0":
[   7.143823] 0x000000000000-0x000000080000 : "ospi.tiboot3"
[   7.149737] 0x000000080000-0x000000280000 : "ospi.tispl"
[   7.155379] 0x000000280000-0x000000680000 : "ospi.u-boot"
[   7.161107] 0x000000680000-0x0000006a0000 : "ospi.env"
[   7.166585] 0x0000006a0000-0x0000006c0000 : "ospi.env.backup"
[   7.172660] 0x0000006c0000-0x0000007c0000 : "ospi.sysfw"
[   7.178316] 0x000000800000-0x000004000000 : "ospi.rootfs"
[   7.430532] cadence-qspi 47040000.spi: Cadence QSPI NOR probe failed -517
[   7.438201] cadence-qspi 47050000.spi: mt25qu512a (65536 Kbytes)
[   7.482500] cadence-qspi 47050000.spi: Cadence QSPI NOR probe failed -517
[   7.526299] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[   7.533943] libphy: 46000f00.mdio: probed
[   7.538974] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
[   7.547237] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2
[   7.558635] am65-cpsw-nuss 46000000.ethernet: Failed to request tx dma channel -517
[   7.567310] davinci-mcasp 2ba0000.mcasp: IRQ common not found
[   7.575117] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
[   7.581292] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
Thanks In advance
Hennessy
  • Hi Hennessy,
    Couple of questions:
    1) Are you using a custom board or TI TDA4-EVM?
    2) I see that your sysfw.itb is old. Can you please replace that with the pre-built sysfw.itb for 7.0 release? To me that should solve your boot issue.
    3) Can you please share the commands that you used to build?
    Keerthy
